  4. [Aufruf] Adapter: Snips - Offline Speak2Text
snips
635 Beiträge 43 Kommentatoren 208.7k Aufrufe 22 Beobachtet
  • WalW Offline
    WalW Offline
    Wal
    So, habe im ersten Thread den die Einstellungen vom Adapter mal erklärt. Ich hoffe das reicht. :roll:
    Walter
    DoorIO-Adapter
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Moin,
      irgendwie bin ich (mal wieder) zu doof dazu ….
      Musste erst Python2 installieren - mit Python3 ging es nicht.
      Nun kommt bei der Installation folgende Meldungen
      $ ./iobroker url "https://github.com/Bettman66/ioBroker.snips" --debug
      install https://github.com/Bettman66/ioBroker.snips/tarball/master
      npm install https://github.com/Bettman66/ioBroker.snips/tarball/master --production --save --prefix "/opt/iobroker" (System call)
      npm WARN eric@0.0.3 requires a peer of eric-types@0.0.1 but none is installed. You must install peer dependencies yourself.npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
      npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
      npm WARN react-beautiful-dnd@8.0.7 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      ! + iobroker.snips@0.0.6added 1 package from 1 contributor in 22.812s
      ! process exited with code 0
      Muss das etwa auf der selben Hardware laufen (iobroker rund snips)?
      Gruß,
      Eric
      • WalW Offline
        WalW Offline
        Wal
        Nein, Snips läuft besser auf einer eigenen Hardware.
        Ich wüsste nicht das für den Snips-Adapter Python benötigt wird.
        Der Adapter ist nur ein MQTT-Client.
        edit: Ich bekomm die Krise, die io-package.json war defekt. Bitte nochmal laden.
        P.S. Ich bin zu doof.
        Walter
        DoorIO-Adapter
        • ? Offline
          Hallo Zusammen,
          Version James Bond 0.0.7 installiert…. 8-) 8-)
          Den NodeRed Flow habe ich jetzt entfernt um Überschneidungen in der Kommunikation zu vermeiden.
          Im Augeblick ist Training von Räumen angesagt, mal sehen wie das funzt.
          Hierzu erneut die Frage, wenn ich einen neuen Raum eingetragen habe und erfolgreich angelernt habe, kann oder muss ich dann den Raum aus der
          inject.room entfernen um einen neuen Raum anzulernen?
          Trifft dieser Prozess auch auf inject.device zu?
          PS: Mein Hund mag die Stimme von Snips überhaupt nicht.....
          Herzliche Grüße und Danke für den Adapter.
          Equilora aka Harald
          • WalW Offline
            WalW Offline
            Wal
            Nein, du kannst das nächste Wort zum lernen einfach drüber schreiben. Es muß nicht geleert werden.
            Gesendet von meinem Ulefone_Armor_5 mit Tapatalk
            Walter
            DoorIO-Adapter
            • ? Offline
              Servus Walter,
              habe unter Snips.ai eine neue App mit dem Namen IoBroker-Snips erstellt, damit erkennt Snips jetzt auch meine landwirtschaftlichen Gebäude ein wenig besser….. :D :D :D
              IoBroker-Snips baut auf dem FHEM Packet auf.
              Hier noch ein Issue:
              Wenn ich die NodeRed Variante verwende und z.B einen Schaltbefehl für ein Licht sende, dann bekomme ich die Quittung ein- oder ausgeschaltet von Snips, sofern ich eine Antwort im text2command hinterlegt habe.
              Beim Adapter hingegen, erfolgt diese Sprachausgabe nicht, ich bekomme nur einen Quittungstone egal ob der Befehl erfolgreich oder nicht, es ist im Adapter kein Filter gesetzt.
              Kannst Du da bitte mal drüberschauen - Danke.
              Ansosten läuft es schon recht gut, da IoBroker-Snips ganze gesprochene Sätze zurücksendet und es damit mit den Schlagworten auf welche der
              text2command Adapter reagiert zu weniger Kollisionen kommt.
              Herzliche Grüße
              Equilora
              • WalW Offline
                WalW Offline
                Wal
                @equilora:
                habe unter Snips.ai eine neue App mit dem Namen IoBroker-Snips erstellt, damit erkennt Snips jetzt auch meine landwirtschaftlichen Gebäude ein wenig besser….. :D :D :D `
                Werde ich mal testen.
                @equilora:
                Kannst Du da bitte mal drüberschauen - Danke. `
                Zu Befehl. :mrgreen:
                Walter
                DoorIO-Adapter
                • WalW Offline
                  WalW Offline
                  Wal
                  Der Quittierungstext funzt bei mir, schau mal in der Text2Command-Config, ob snips.0.send.say.text in Antwort in ID gesetzt ist. Er verliert ab und zu die Einstellung.
                  Walter
                  DoorIO-Adapter
                  • ? Offline
                    Läuft…. Danke!
                    @Wal:
                    Der Quittierungstext funzt bei mir, schau mal in der Text2Command-Config, ob snips.0.send.say.text in Antwort in ID gesetzt ist. Er verliert ab und zu die Einstellung. `
                    Achtung der IoBroker Snips liefert ganze Sätze zurück wie. z.B. "wie ist die temperatur in der sattelkammer"
                    Kurze Befehle sollten auch gehen, nur kracht es dann wenn man gleiche Schlagwörter in mehreren Regeln beim text2command verwendet.
                    Herzliche Grüße
                    Equilora aka Harald
                    • L Offline
                      Linedancer
                      Inzwischen läuft mein snips wirklich gut. Danke für den Adapter.
                      2 Fragen:
                      Kann ich irgendwo in einer Datei nachschauen welche Worte ich schon angelernt habe?
                      Kann ich schlecht gewählte Worte wieder löschen?
                      Probleme:
                      Den Jabra speaker muss ich wieder zurückschicken. Die Sprachausgabe ist nicht brauchbar. Hab als Zwischenlösung ein paar uralte PC Aktivboxen dran gehängt.
                      Hin und wieder reagiert snips auf den Fernsehton und sagt dann "ich verstehe bla bla bla nicht" oder so ähnlich.
                      Ciao, Gerhard
                      • WalW Offline
                        WalW Offline
                        Wal
                        @Linedancer:
                        Kann ich schlecht gewählte Worte wieder löschen? `
                        Die Injections findest du unter "/var/lib/snips" auf der Snips-Hardware.
                        Walter
                        DoorIO-Adapter
                        • ? Offline
                          Hallo Zusammen,
                          soweit läuft der Adapter recht nett.
                          Werde heute eine zweite Instanz vom text2command Adapter installieren und den Snips Adapter auf die neue Instanz umziehen.
                          Das einzige Problem ist derzeit, das der text2command manchmal die Einstellungen im Feld "Antwort in ID:" verschmeisst, mal sehen ob das mit der zweiten Instanz vom text2command Adapter dann auch passiert.
                          Nochmals Danke für den Adapter.
                          Herzliche Grüße
                          Equilora aka Harald
                            Morgon
                            Hi
                            Ich weiß nicht ob ich hier richtig frage, aber ich hab Probleme das Ganze zum laufen zu bekommen und weiß nicht genau woran es liegt. Ich habe Snips installiert, habe es auch hinbekommen ein eigenes hotword zu erstellen welches er erkennt. Ich habe den assistant installiert (mehrfach in verschiedenen Ausführungen mit verschiedenen Apps (gerade sollte eine mit nur der iobroker app von equilora laufen)).
                            In iobroker alle relevanten Instanzen aktiviert (vielleicht sollte man irgendwo noch dazu schreiben, dass die mqtt-client Instanz aktiviert werden muss, das ist zwar im Nachhinein logisch, hat mich jedoch ne halbe Stunde gekostet bis ich mal in den log geguckt hab).
                            So weit bin ich jetzt. In Iobroker wird erkannt wenn ich mein hotword sage, es wird aber nie der state "wait" aktiviert und es kommt scheinbar danach auch nichts rüber.
                            Ich kriege snips auch nicht dazu, dass er mir antwortet. Ich habe die Vermutung, dass der assistant nicht funktioniert, habe aber eigentlich alles wie in der Anleitung gemacht und in /usr/share/snips entpackt.
                            Hat jemand eine Idee was ich vergessen haben könnte?
                            Zusatzproblem: ich habe auf der Klinke des Pi jedesmal ein Knacken wenn die rote LED ausgeht, was alle paar Sekunden vorkommt. Ich vermute das hat nichts mit all dem zu tun, vielleicht hat aber da jemand eine Idee woran das liegen kann.
                            Edit: nachdem ich noch etwas gesucht hab, hab ich beim troubleshooting gefunden wie ich sehen kann, ob die einzelnen snips-services laufen. Dabei hat sich rausgestellt, dass diese wohl mit "Hotword component is missing" in den Error gehen. Ich weiß jetzt leider noch nicht warum und finde auch per Google Suche nichts dazu, aber es scheint wohl hierran zu liegen -.-
                            edit 2: das hat sich erledigt, ich hab im snips-forum Hilfe gefunden :D da wurde wohl ein Verzeichnis nicht angelegt und jetzt geht das
                            edit 3: das knacken war wohl ein zu lasches Netzteil alle Probleme gelöst. :mrgreen:
                            • WalW Offline
                              WalW Offline
                              Wal
                              Achtung !!!
                              Es gibt ein neues Snips-Update Ver. 0.60.1, dort wurde an der Snips-Injection herumgefrickelt, dadurch funktioniert das Anlernen der Wörter nicht mehr. Es gibt demnächst ein Patch dafür.
                              Walter
                              DoorIO-Adapter
                              • WalW Offline
                                WalW Offline
                                Wal
                                @Morgon:
                                Ich habe Snips installiert, habe es auch hinbekommen ein eigenes hotword zu erstellen welches er erkennt. `
                                Eine Anleitung wäre nett, danke im vorraus. :mrgreen:
                                Walter
                                DoorIO-Adapter
                                • smartboartS Offline
                                  smartboartS Offline
                                  smartboart
                                  Hi, tolle Sache…Hab Snips zusammengebaut und installiert...Für sich funktioniert das Ding schonmal und antwortet auch fleißig.
                                  Im Moment hänge ich an der Anpassung der snips.toml wegen der mqtt konfig...
                                  Kann mir hier jemand weiter helfen?
                                  Da ich den Mqtt Port bereits benutze ( sonoff Adater ) müsste ich den port auch anpassen sowe die nötigen Einstellungen dazu vornehmen..
                                  Wenn snips so prinzipiell schoin funktioniert, muss auf snips sonst noch was installiert werden, oder reicht die Anpassung der snips.toml?
                                  • WalW Offline
                                    WalW Offline
                                    Wal
                                    sudo nano /etc/mosquitto/mosquitto.conf
                                    # Place your local configuration in /etc/mosquitto/conf.d/
                                    # A full description of the configuration file is at
                                    # /usr/share/doc/mosquitto/examples/mosquitto.conf.example
                                    pid_file /var/run/mosquitto.pid
                                    persistence false
                                    persistence_location /var/lib/mosquitto/
                                    log_dest file /var/log/mosquitto/mosquitto.log
                                    include_dir /etc/mosquitto/conf.d
                                    listener 1500
                                    "listener" ist dein gewünschter Port.
                                    sudo nano /etc/snips.toml
                                    [snips-common]
                                     bus = "mqtt"
                                     mqtt = "localhost:1500"
                                    Walter
                                    DoorIO-Adapter
                                      smartboartS Offline
                                      smartboart
                                      Hallo Walter,
                                      vielen lieben Dank…habe es angeasst und den raspy neu gestartet..
                                      sam watch zeigt mir jetzt den gewünschten port an..
                                      Bekomme immer noch folgende Meldungen vom iobroker.snips adapter..
                                      Dazu noch jemand ne Idee?
                                      host.tinkerboard	2018-11-02 21:47:21.382	info	Restart adapter system.adapter.snips.0 because enabled
                                      host.tinkerboard	2018-11-02 21:47:21.382	error	instance system.adapter.snips.0 terminated with code 0 (OK)
                                      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at Function.Module._load (module.js:498:3) code: 'MODULE_NOT_FOUND' }
                                      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at tryModuleLoad (module.js:506:12)
                                      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at Module.load (module.js:566:32)
                                      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                                      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at Module._compile (module.js:653:30)
                                      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.snips/lib/client.js:3:25)
                                      Caught	2018-11-02 21:47:21.381	error	by controller[0]: at require (internal/module.js:11:18)
                                      Caught	2018-11-02 21:47:21.381	error	by controller[0]: at Module.require (module.js:597:17)
                                      Caught	2018-11-02 21:47:21.381	error	by controller[0]: at Function.Module._load (module.js:475:25)
                                      Caught	2018-11-02 21:47:21.381	error	by controller[0]: at Function.Module._resolveFilename (module.js:548:15)
                                      Caught	2018-11-02 21:47:21.381	error	by controller[0]: { Error: Cannot find module 'mqtt'</anonymous>
                                      • ? Offline
                                        Servus Smartboart,
                                        im Snips Adapter ist der neue Port gesetzt?
                                        Herzliche Grüße
                                        Equilora aka Harald
                                          smartboartS Offline
                                          smartboart
                                          Hi ..ja ist er…deshalb wundert mich die log Ausgabe ja...
