  4. [Aufruf] Xbox Adapter testen
    1.0k
    6.1k
adapterxbox
205 Beiträge 13 Kommentatoren 50.4k Aufrufe 2 Beobachtet
  • DutchmanD Offline
    DutchmanD Offline
    Dutchman
    @foxriver76:
    Okay, leider kein Link für nopy vorhanden.. another try:
    Wenn du dich in /opt/iobroker/node_modules/iobroker.xbox/ befindest und den Befehlnpm rootabsetzt, was kommt dabei raus? `
    Hier das ergebnis :
    rafal@HomeControl:/opt/iobroker/node_modules/iobroker.xbox$ npm root
    /opt/iobroker/node_modules/iobroker.xbox/node_modules
    Ich habe den adapter jetzt mal komplett geloescht und per console mit sudo installiert das ergebnis ==> Er laeuft !
    Installiert ist jetzt die 0.0.6 auf meinem ubuntu system
    log der installation:
    xxx@xxx:/opt/iobroker$ sudo npm i iobroker.xbox --unsafe-perm
    > iobroker.xbox@0.0.6 preinstall /opt/iobroker/node_modules/.staging/iobroker.xbox-4a3b83e7
    > apt install -y build-essential libssl-dev libffi-dev python3-dev || echo -e '[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.'
    Reading package lists... Done
    Building dependency tree
    build-essential is already the newest version (12.1ubuntu2).
    libssl-dev is already the newest version (1.0.2g-1ubuntu4.13).
    The following additional packages will be installed:
      libexpat1-dev libpython3-dev libpython3.5-dev python3.5-dev
    The following NEW packages will be installed:
      libexpat1-dev libffi-dev libpython3-dev libpython3.5-dev python3-dev python3.5-dev
    0 upgraded, 6 newly installed, 0 to remove and 86 not upgraded.
    Need to get 38.0 MB of archives.
    After this operation, 55.3 MB of additional disk space will be used.
    Get:1 http://nl.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libexpat1-dev amd64 2.1.0-7ubuntu0.16.04.3 [115 kB]
    Get:2 http://nl.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libpython3.5-dev amd64 3.5.2-2ubuntu0~16.04.4 [37.3 MB]
    Get:3 http://nl.archive.ubuntu.com/ubuntu xenial/main amd64 libpython3-dev amd64 3.5.1-3 [6,926 B]
    Get:4 http://nl.archive.ubuntu.com/ubuntu xenial-updates/main amd64 python3.5-dev amd64 3.5.2-2ubuntu0~16.04.4 [413 kB]
    Get:5 http://nl.archive.ubuntu.com/ubuntu xenial/main amd64 python3-dev amd64 3.5.1-3 [1,186 B]
    Get:6 http://nl.archive.ubuntu.com/ubuntu xenial/main amd64 libffi-dev amd64 3.2.1-4 [161 kB]
    Fetched 38.0 MB in 3s (9,803 kB/s)
    Selecting previously unselected package libexpat1-dev:amd64.
    (Reading database ... 100125 files and directories currently installed.)
    Preparing to unpack .../libexpat1-dev_2.1.0-7ubuntu0.16.04.3_amd64.deb ...
    Unpacking libexpat1-dev:amd64 (2.1.0-7ubuntu0.16.04.3) ...
    Selecting previously unselected package libpython3.5-dev:amd64.
    Preparing to unpack .../libpython3.5-dev_3.5.2-2ubuntu0~16.04.4_amd64.deb ...
    Unpacking libpython3.5-dev:amd64 (3.5.2-2ubuntu0~16.04.4) ...
    Selecting previously unselected package libpython3-dev:amd64.
    Preparing to unpack .../libpython3-dev_3.5.1-3_amd64.deb ...
    Unpacking libpython3-dev:amd64 (3.5.1-3) ...
    Selecting previously unselected package python3.5-dev.
    Preparing to unpack .../python3.5-dev_3.5.2-2ubuntu0~16.04.4_amd64.deb ...
    Unpacking python3.5-dev (3.5.2-2ubuntu0~16.04.4) ...
    Selecting previously unselected package python3-dev.
    Preparing to unpack .../python3-dev_3.5.1-3_amd64.deb ...
    Unpacking python3-dev (3.5.1-3) ...
    Selecting previously unselected package libffi-dev:amd64.
    Preparing to unpack .../libffi-dev_3.2.1-4_amd64.deb ...
    Unpacking libffi-dev:amd64 (3.2.1-4) ...
    Processing triggers for man-db (2.7.5-1) ...
    Processing triggers for install-info (6.1.0.dfsg.1-5) ...
    Setting up libexpat1-dev:amd64 (2.1.0-7ubuntu0.16.04.3) ...
    Setting up libpython3.5-dev:amd64 (3.5.2-2ubuntu0~16.04.4) ...
    Setting up libpython3-dev:amd64 (3.5.1-3) ...
    Setting up python3.5-dev (3.5.2-2ubuntu0~16.04.4) ...
    Setting up python3-dev (3.5.1-3) ...
    Setting up libffi-dev:amd64 (3.2.1-4) ...
    > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
    > node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/authenticate-pam/build'
      CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: No such file or directory
    compilation terminated.
    authenticate_pam.target.mk:94: recipe for target 'Release/obj.target/authenticate_pam/authenticate_pam.o' failed
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/authenticate-pam/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack     at emitTwo (events.js:106:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.4.0-62-generic
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v6.14.1
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    > iobroker.xbox@0.0.6 install /opt/iobroker/node_modules/iobroker.xbox
    > npip install
    No python_modules directory; installing pip locally if needed.
    Successfully completed pip check.
    The directory '/home/rafal/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
    The directory '/home/rafal/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
    Collecting xbox-smartglass-rest
      Downloading https://files.pythonhosted.org/packages/d4/f6/73521851d42496d7d703036bc5cb79a49144602bf4fffd85ba3bfb4afa8f/xbox_smartglass_rest-0.9.5-py2.py3-none-any.whl
    Collecting xbox-smartglass-core
      Downloading https://files.pythonhosted.org/packages/3f/9f/2e9c16dce7523dabf37dd8f1cdff44de42851d5970534baf0fe2a4f9badb/xbox_smartglass_core-1.0.10-py2.py3-none-any.whl (56kB)
        100% |████████████████████████████████| 61kB 8.5MB/s
    Collecting Flask (from xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/7f/e7/08578774ed4536d3242b14dacb4696386634607af824ea997202cd0edb4b/Flask-1.0.2-py2.py3-none-any.whl (91kB)
        100% |████████████████████████████████| 92kB 9.5MB/s
    Collecting xbox-smartglass-stump>=0.9.4 (from xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/7e/ea/fae9ae03e3ef0afc3c27638e8872254bf96bd14f06dc1ba5bce08b7916c7/xbox_smartglass_stump-0.9.4-py2.py3-none-any.whl
    Collecting urwid==2.0.1 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/c7/90/415728875c230fafd13d118512bde3184d810d7bf798a631abc05fac09d0/urwid-2.0.1.tar.gz (604kB)
        100% |████████████████████████████████| 614kB 11.3MB/s
    Collecting construct==2.9.41 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/e6/f5/064be5013506d54212b396e8fc3e9890e60ed6a27df6d52529f0b8361cd5/construct-2.9.41.tar.gz (54kB)
        100% |████████████████████████████████| 61kB 13.0MB/s
    Collecting gevent==1.2.2 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/13/a9/81166b3ad2d344882ab42eb222e7723f93838fdf641b17b319b3a84821a7/gevent-1.2.2-cp35-cp35m-manylinux1_x86_64.whl (1.7MB)
        100% |████████████████████████████████| 1.7MB 9.2MB/s
    Collecting xbox-webapi>=1.1.2 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/04/9c/bd60a0093db35f32263306987cb6776ac12e0d9a8911a4be1c5856ff6d0b/xbox_webapi-1.1.5-py2.py3-none-any.whl (44kB)
        100% |████████████████████████████████| 51kB 10.1MB/s
    Collecting appdirs==1.4.3 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
    Collecting dpkt==1.9.1 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/bf/a4/8e4622fac4841b5e4a347fa9da4c057a7974258df247031280008d6ac0d0/dpkt-1.9.1.tar.gz (115kB)
        100% |████████████████████████████████| 122kB 15.1MB/s
    Collecting aenum==2.1.2; python_version <= "3.5" (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/0d/46/5b6a6c13fee40f9dfaba84de1394bfe082c0c7d95952ba0ffbd56ce3a3f7/aenum-2.1.2-py3-none-any.whl
    Collecting cryptography==2.2.2 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/fa/f4/3cde3604972dfa2b0fea85b9711948bb4fb70ab64095322aef35071bd254/cryptography-2.2.2-cp34-abi3-manylinux1_x86_64.whl (2.2MB)
        100% |████████████████████████████████| 2.2MB 11.6MB/s
    Collecting Werkzeug>=0.14 (from Flask->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/20/c4/12e3e56473e52375aa29c4764e70d1b8f3efa6682bef8d0aae04fe335243/Werkzeug-0.14.1-py2.py3-none-any.whl (322kB)
        100% |████████████████████████████████| 327kB 16.5MB/s
    Collecting Jinja2>=2.10 (from Flask->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/7f/ff/ae64bacdfc95f27a016a7bed8e8686763ba4d277a78ca76f32659220a731/Jinja2-2.10-py2.py3-none-any.whl (126kB)
        100% |████████████████████████████████| 133kB 10.3MB/s
    Collecting click>=5.1 (from Flask->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/34/c1/8806f99713ddb993c5366c362b2f908f18269f8d792aff1abfd700775a77/click-6.7-py2.py3-none-any.whl (71kB)
        100% |████████████████████████████████| 71kB 9.7MB/s
    Collecting itsdangerous>=0.24 (from Flask->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/dc/b4/a60bcdba945c00f6d608d8975131ab3f25b22f2bcfe1dab221165194b2d4/itsdangerous-0.24.tar.gz (46kB)
        100% |████████████████████████████████| 51kB 8.5MB/s
    Collecting marshmallow-objects (from xbox-smartglass-stump>=0.9.4->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/2a/46/710e3383d1216f1f066ee16da24d144c04c2d3180bdd962f08194f123849/marshmallow_objects-1.0.14-py2.py3-none-any.whl
    Collecting greenlet>=0.4.10 (from gevent==1.2.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/2e/65/27f35497cc0102a792390d056e793e064da95fc9eae45d75ae0ba49c0a0d/greenlet-0.4.15-cp35-cp35m-manylinux1_x86_64.whl (41kB)
        100% |████████████████████████████████| 51kB 9.3MB/s
    Collecting demjson (from xbox-webapi>=1.1.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/96/67/6db789e2533158963d4af689f961b644ddd9200615b8ce92d6cad695c65a/demjson-2.2.4.tar.gz (131kB)
        100% |████████████████████████████████| 133kB 14.6MB/s
    Requirement already satisfied: requests in /usr/lib/python3/dist-packages (from xbox-webapi>=1.1.2->xbox-smartglass-core) (2.9.1)
    Collecting idna>=2.1 (from cryptography==2.2.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/4b/2a/0276479a4b3caeb8a8c1af2f8e4355746a97fab05a372e4a2c6a6b876165/idna-2.7-py2.py3-none-any.whl (58kB)
        100% |████████████████████████████████| 61kB 14.3MB/s
    Collecting cffi>=1.7; platform_python_implementation != "PyPy" (from cryptography==2.2.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/59/cc/0e1635b4951021ef35f5c92b32c865ae605fac2a19d724fb6ff99d745c81/cffi-1.11.5-cp35-cp35m-manylinux1_x86_64.whl (420kB)
        100% |████████████████████████████████| 430kB 11.0MB/s
    Requirement already satisfied: six>=1.4.1 in /usr/lib/python3/dist-packages (from cryptography==2.2.2->xbox-smartglass-core) (1.10.0)
    Collecting asn1crypto>=0.21.0 (from cryptography==2.2.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/ea/cd/35485615f45f30a510576f1a56d1e0a7ad7bd8ab5ed7cdc600ef7cd06222/asn1crypto-0.24.0-py2.py3-none-any.whl (101kB)
        100% |████████████████████████████████| 102kB 13.7MB/s
    Collecting MarkupSafe>=0.23 (from Jinja2>=2.10->Flask->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/4d/de/32d741db316d8fdb7680822dd37001ef7a448255de9699ab4bfcbdf4172b/MarkupSafe-1.0.tar.gz
    Collecting marshmallow (from marshmallow-objects->xbox-smartglass-stump>=0.9.4->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/3f/4d/cb555dfc2e2f926179884665fa1e6ae6b8f8102e4f8228b73e2a30eb0ee0/marshmallow-2.15.6-py2.py3-none-any.whl (44kB)
        100% |████████████████████████████████| 51kB 14.6MB/s
    Collecting pycparser (from cffi>=1.7; platform_python_implementation != "PyPy"->cryptography==2.2.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/68/9e/49196946aee219aead1290e00d1e7fdeab8567783e83e1b9ab5585e6206a/pycparser-2.19.tar.gz (158kB)
        100% |████████████████████████████████| 163kB 12.8MB/s
    Installing collected packages: Werkzeug, MarkupSafe, Jinja2, click, itsdangerous, Flask, urwid, construct, greenlet, gevent, appdirs, demjson, xbox-webapi, dpkt, aenum, idna, pycparser, cffi, asn1crypto, cryptography, xbox-smartglass-core, marshmallow, marshmallow-objects, xbox-smartglass-stump, xbox-smartglass-rest
      Running setup.py install for MarkupSafe ... done
      Running setup.py install for itsdangerous ... done
      Running setup.py install for urwid ... done
      Running setup.py install for construct ... done
      Running setup.py install for demjson ... done
      Running setup.py install for dpkt ... done
      Running setup.py install for pycparser ... done
    Successfully installed Flask-1.0.2 Jinja2-2.10 MarkupSafe-1.0 Werkzeug-0.14.1 aenum-2.1.2 appdirs-1.4.3 asn1crypto-0.24.0 cffi-1.11.5 click-6.7 construct-2.9.41 cryptography-2.2.2 demjson-2.2.4 dpkt-1.9.1 gevent-1.2.2 greenlet-0.4.15 idna-2.7 itsdangerous-0.24 marshmallow-2.15.6 marshmallow-objects-1.0.14 pycparser-2.19 urwid-2.0.1 xbox-smartglass-core-1.0.10 xbox-smartglass-rest-0.9.5 xbox-smartglass-stump-0.9.4 xbox-webapi-1.1.5
    iobroker.core@1.0.0 /opt/iobroker
    └─┬ iobroker.xbox@0.0.6
      ├── nopy@0.2.6
      ├── ping@0.2.2
      └─┬ request@2.88.0
        ├── aws4@1.8.0
        ├── combined-stream@1.0.7
        ├── extend@3.0.2
        ├─┬ form-data@2.3.2
        │ └── combined-stream@1.0.6
        ├─┬ har-validator@5.1.0
        │ └─┬ ajv@5.5.2
        │   └── fast-json-stable-stringify@2.0.0
        ├─┬ mime-types@2.1.20
        │ └── mime-db@1.36.0
        ├── oauth-sign@0.9.0
        ├── qs@6.5.2
        ├── safe-buffer@5.1.2
        ├─┬ tough-cookie@2.4.3
        │ └── psl@1.1.29
        └── uuid@3.3.2
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    xxx@xxx:/opt/iobroker$ sudo iobroker add xbox
    host.HomeControl install adapter xbox
    got /opt/iobroker/node_modules/iobroker.xbox/admin
    upload [2] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/xbox.png xbox.png image/png
    upload [1] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/words.js words.js application/javascript
    upload [0] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/index_m.html index_m.html text/html
    host.HomeControl object system.adapter.xbox created
    host.HomeControl create instance xbox
    host.HomeControl object xbox.0.media.stop created
    host.HomeControl object xbox.0.media.fastForward created
    host.HomeControl object xbox.0.media.view created
    host.HomeControl object xbox.0.media.rewind created
    host.HomeControl object xbox.0.media.back created
    host.HomeControl object xbox.0.media.menu created
    host.HomeControl object xbox.0.media.channelDown created
    host.HomeControl object xbox.0.media.nextTrack created
    host.HomeControl object xbox.0.media.channelUp created
    host.HomeControl object xbox.0.media.seek created
    host.HomeControl object xbox.0.media.playPause created
    host.HomeControl object xbox.0.media.previousTrack created
    host.HomeControl object xbox.0.media.record created
    host.HomeControl object xbox.0.media.pause created
    host.HomeControl object xbox.0.media.play created
    host.HomeControl object xbox.0.gamepad.dpadDown created
    host.HomeControl object xbox.0.gamepad.dpadLeft created
    host.HomeControl object xbox.0.gamepad.dpadRight created
    host.HomeControl object xbox.0.gamepad.clear created
    host.HomeControl object xbox.0.gamepad.dpadUp created
    host.HomeControl object xbox.0.gamepad.y created
    host.HomeControl object xbox.0.gamepad.x created
    host.HomeControl object xbox.0.gamepad.b created
    host.HomeControl object xbox.0.gamepad.a created
    host.HomeControl object xbox.0.gamepad.nexus created
    host.HomeControl object xbox.0.gamepad.menu created
    host.HomeControl object xbox.0.gamepad.view created
    host.HomeControl object xbox.0.gamepad.enroll created
    host.HomeControl object xbox.0.gamepad.rightThumbstick created
    host.HomeControl object xbox.0.gamepad.leftThumbstick created
    host.HomeControl object xbox.0.gamepad.leftShoulder created
    host.HomeControl object xbox.0.gamepad.rightShoulder created
    host.HomeControl object xbox.0.settings.power created
    host.HomeControl object xbox.0.settings created
    host.HomeControl object xbox.0.gamepad created
    host.HomeControl object xbox.0.media created
    host.HomeControl object xbox.0.info.connection created
    host.HomeControl object xbox.0.info created
    host.HomeControl object system.adapter.xbox.0.outputCount created
    host.HomeControl object system.adapter.xbox.0.inputCount created
    host.HomeControl object system.adapter.xbox.0.uptime created
    host.HomeControl object system.adapter.xbox.0.memRss created
    host.HomeControl object system.adapter.xbox.0.memHeapTotal created
    host.HomeControl object system.adapter.xbox.0.memHeapUsed created
    host.HomeControl object system.adapter.xbox.0.connected created
    host.HomeControl object system.adapter.xbox.0.alive created
    host.HomeControl object system.adapter.xbox.0 created
    • foxriver76F Offline
      foxriver76F Offline
      foxriver76
      @Dutchman:
      @foxriver76:
      Hier das ergebnis :
      Okay, darüber findet er auch net wriklich raus wo seine Module liegen. Jedenfalls kann es laut npm sein, dass wenn ein npm Package (iobroker.xbox in diesem Fall) in dem Projekt eines anderen npm Packages liegt (iobroker), dass er es dann in die node_modules des übergeordneten Packages installiert. Zumindest habe ich es so verstanden, nur wovon das abhängt weiß ich nicht.
      Jedenfalls probiert er jetzt erst mal nopy in iobroker.xbox zu finden und sonst schaut er noch in iobroker selbst.
      Und wenn Packages fehlen muss unter Linux mit sudo (sonst kann er apt install nicht ausführen) installiert werden, oder man installiert sie eben händisch. Super, dass es auf den Linux-basierten Systemen zumindest schon mal klappt. :)
      Vielen Dank fürs testen soweit.
      Videotutorials & mehr
      • X Offline
        X Offline
        Xyolyp
        Den Adapter hatte ich zufälligerweise schon vor einigen Wochen gefunden und ausprobiert, aber nicht zum Laufen bekommen. Werde heute Abend direkt den nächsten Versuch starten.
          foxriver76F Offline
          foxriver76
          @Xyolyp:
          Den Adapter hatte ich zufälligerweise schon vor einigen Wochen gefunden und ausprobiert, aber nicht zum Laufen bekommen. Werde heute Abend direkt den nächsten Versuch starten. `
          Da gab es ihn noch nicht :)
          Es gibt einen auf Github von Idittmar oder so, wahrscheinlich war es der.
          beste Grüße
          • X Offline
            X Offline
            Xyolyp
            @foxriver76:
            Es gibt einen auf Github von Idittmar oder so, wahrscheinlich war es der. `
            Jetzt wo du es sagst…
            Deiner funktioniert nachdem ich bei der Installation erst Probleme hatte. Ich habe im home Ordner von meinem SSH Benutzer (Linux Raspbian) sudo npm i iobroker.xbox --unsafe-perm ausgeführt, nachdem die Installation via Admin nicht funktioniert hat.
            Der Adapter war aber auch nach einem Reboot nicht in der Liste. Also einmal wieder entfernt, cd /opt/iobroker und nochmal sudo npm i iobroker.xbox --unsafe-perm und tadaa, der Adapter ist da und funktioniert.
            Einziges Problemchen, das ich bisher noch feststellen konnte war, dass das DPad nicht immer funktioniert. Da im Log nichts dazu steht kann ich mir aber auch vorstellen, dass es ein Problem meiner XBox ist (sie hat so einige...)
              foxriver76F Offline
              foxriver76
              @Xyolyp:
              @foxriver76:
              Einziges Problemchen, das ich bisher noch feststellen konnte war, dass das DPad nicht immer funktioniert. Da im Log nichts dazu steht kann ich mir aber auch vorstellen, dass es ein Problem meiner XBox ist (sie hat so einige...) `
              Dpad funktioniert nicht und der Rest schon?
              Also Logging sollte es soweit geben, wenn was nicht passt.
              Zur Installation: Grundsätzlich sollte man ioBroker Adapter isntallieren, während man sich im Ordner /opt/iobroker/ befindet oder man geht auf nummer sicher mittels dem –prefix flag, dann ist es egal wo man sich aktuell befindet.
              sudo npm i iobroker.xbox --unsafe-perm --prefix /opt/iobroker/
              beste Grüße und schon mal Danke fürs testen
                foxriver76F Offline
                foxriver76
                Aktuell gibt es 0.0.8 als Version, es wurde lediglich das Logging etwas zurückgeschraubt im Falle, dass die Xbox online ist und mehrmals hintereinander keine Verbindung zustande kommt, werden die wiederholten Meldungen nur auf Debug geloggt. Ansonsten hatte ich am Anfang ein paar Attribute in der io-package erstellt, die nicht benötigt werden –> habe sie entfernt.
                Ich plane den Adapter in 1 - 2 Wochen ins offizielle Repo aufzunehmen (vorerst nur latest), falls ihr Feedback jeglicher Art habt, schreibt es bitte.
                beste Grüße
                fox
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  Hi fox
                  Klasse Arbeit also bei mir läuft er immernoch Stabiel also ab in npm damit :)
                  • X Offline
                    X Offline
                    Xyolyp
                    @foxriver76:
                    Dpad funktioniert nicht und der Rest schon? `
                    Das Dpad funktioniert manchmal nach dem Starten der Xbox ein, zwei Minuten nicht. Ich konnte noch keine Regelmäßigkeit feststellen und im Log seh ich auch nichts was dazu passen könnte. Die Xbox macht aber auch abseits vom Adapter einiges an Spirenzchen. Ich werde dieses Wochenende mal gucken ob ich's rauskriegen kann woher der Murks kommt.
                    Da ich den Adapter aber bisher nur zum Ein- und Ausschalten, sowie zum aufzeichnen der Aktivität nutze funktioniert der Adapter für mich trotz des Problemchen.
                    Ich würde mir noch wünschen, dass ich in einem Datenpunkt sehe wer gerade angemeldet ist und welches Spiel gerade gespielt wird. Falls es das schon gibt ignorier das einfach, hatte heute einen langen Tag.
                      foxriver76F Offline
                      foxriver76
                      @Xyolyp:
                      Da ich den Adapter aber bisher nur zum Ein- und Ausschalten, sowie zum aufzeichnen der Aktivität nutze funktioniert der Adapter für mich trotz des Problemchen. `
                      Kannst du mir verraten unter welchen Umständen das aufzeichnen funktioniert?
                      @Xyolyp:
                      Ich würde mir noch wünschen, dass ich in einem Datenpunkt sehe wer gerade angemeldet ist und welches Spiel gerade gespielt wird. Falls es das schon gibt ignorier das einfach, hatte heute einen langen Tag. `
                      Ich werde mal schauen ob das möglich ist.
                      • X Offline
                        X Offline
                        Xyolyp
                        @foxriver76:
                        Kannst du mir verraten unter welchen Umständen das aufzeichnen funktioniert? `
                        Da der interne Lüfter defekt ist ist ein externer drauf, der von der Xbox gesteuert wird. Manchmal geht der einfach so für ca eine Minute an und gerade nachts hat mich das so sehr gestört, dass die Xbox an einer geschalteten Steckdose hängt. Die Xbox kann also nicht via Controller eingeschaltet werden, sondern wurde sonst immer manuell eingeschaltet nachdem via ioBroker die Steckdose eingeschaltet wurde. Jetzt schalte ich die Xbox eine Sekunde nach der Steckdose ein und die Xbox nur via ioBroker aus und danach die Steckdose. Somit kann ich einfach aufzeichnen in welchem Zustand ich die Xbox geschalten habe.
                          foxriver76F Offline
                          foxriver76
                          Ach so, ich dachte du meinst aufzeichnen mittels der Media.record Taste. Also wie man während einem Spiel aufzeichnen kann. <emoji seq="1f600">😀</emoji>
                            foxriver76F Offline
                            foxriver76
                            Der Xbox Adapter wurde nun ins Latest Repo aufgenommen. Bin gespannt ob die Installation über die Oberfläche zuverlässig klappen wird, ansonsten werde ich mal schauen, dass bei dem Adapter automatisch die entsprechende Flag gesetzt wird.
                            • DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              sobald er in der repro ist werden wir testen, wird denke ich mal die nacht ueberdauern ?
                                foxriver76F Offline
                                foxriver76
                                @Dutchman:
                                sobald er in der repro ist werden wir testen, wird denke ich mal die nacht ueberdauern ? `
                                Jop glaube um 3 oder so ist die Aktualisierung. Also ab morgen.
                                  foxriver76F Offline
                                  foxriver76
                                  Mit 0.0.9 (latest) entfällt die Angabe der LiveID in der Konfiguration, da diese über die IP beschafft werden kann.
                                  • DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    @foxriver76:
                                    Mit 0.0.9 (latest) entfällt die Angabe der LiveID in der Konfiguration, da diese über die IP beschafft werden kann. `
                                    Argh und das nachdem ich den Adapter in 3häusern eingerichtet habe grr ;)
                                    Muss noch 2 also Änderung kommt zeitlich gut :)
                                      foxriver76F Offline
                                      foxriver76
                                      0.0.10 hat noch kleine Verbesserungen bezüglich der Verbindungshandhabung bekommen, sonst alles beim Alten.
                                        beboe
                                        konnte den Adapter problemlos installieren und einrichten. Soweit ich probiert habe läuft auch alles, allerdings produziert der Adapter dauerhafte Verbindungsabbrüche, sobald die Xbox ausgeschaltet ist:
                                        ` > xbox.0 2018-10-20 22:19:25.336 info [PING] Lost connection to your Xbox
                                        xbox.0 2018-10-20 22:19:19.882 info [CONNECT] <=== Successfully connected to FD00977CF2F9C495 ("192.168.178.30")
                                        xbox.0 2018-10-20 22:18:01.014 info [PING] Lost connection to your Xbox
                                        xbox.0 2018-10-20 22:17:49.524 info [CONNECT] <=== Successfully connected to FD00977CF2F9C495 ("192.168.178.30")
                                        xbox.0 2018-10-20 22:17:06.804 info [PING] Lost connection to your Xbox
                                        xbox.0 2018-10-20 22:17:01.342 info [CONNECT] <=== Successfully connected to FD00977CF2F9C495 ("192.168.178.30")
                                        xbox.0 2018-10-20 22:16:48.739 info [PING] Lost connection to your Xbox `
                                        Woran könnte das liegen?
                                          foxriver76F Offline
                                          foxriver76
                                          Kurz nach dem ausschalten oder allgemein? Der Adapter hält normalerweise keine Verbindung zur Xbox wenn diese aus ist. Allerdings scheinen die Konsolen manchmal aufzuwachen und auf einen Ping zu antworten.
