  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • SegwayS Offline
    SegwayS Offline
    Segway
    #550
    @simatec:
    Ja stelle bitte die Adapterinstanz auf debug und poste den kompletten Log
    Gesendet von iPhone mit Tapatalk `
    Okay hier das Log:
    backitup.0	2018-08-09 09:01:20.934	debug	[minimal] --- Delete old backups ---
    backitup.0	2018-08-09 09:01:20.920	debug	[minimal] success --- Checking and deletion of the old MySql backup files was successful ---
    backitup.0	2018-08-09 08:55:26.551	debug	[minimal] success --- Minimal Backup created ---
    backitup.0	2018-08-09 08:55:26.382	debug	[minimal] Backup created: /opt/iobroker/backups/minimal-2018_08_09-08_55_10_backupiobroker.tar.gz
    backitup.0	2018-08-09 08:55:10.720	debug	[minimal] --- Minimal Backup started ---
    backitup.0	2018-08-09 08:55:10.685	debug	[minimal] success --- MySql was compressed ---
    backitup.0	2018-08-09 08:55:10.654	debug	[minimal] error --- MYSQL Backup was not created ---
    backitup.0	2018-08-09 08:55:10.647	error	[minimal] mysqldump: Got error: 2003: Can't connect to MySQL server on '192.168.xxx.xxx' (111) when trying to connect
    backitup.0	2018-08-09 08:55:10.448	debug	[minimal] --- Creating MYSQL-Backup ---
    backitup.0	2018-08-09 08:55:10.186	debug	[minimal] Creating minimal backup [minimal||5|192.168.xxx.xxx|Daten/Daten/iobroker|xxxxx|xxxxx||||FTP|false|false||iobroker|xxxx|xxx|5|192.168.xxx.xxx|3307|/opt/iobroker]
    backitup.0	2018-08-09 08:55:10.131	debug	[minimal] bash /opt/iobroker/node_modules/iobroker.backitup/backitup.sh "minimal||5|192.168.40.11|Daten/Daten/iobroker|admin|*****|||*****|FTP|false|false||iobroker|xxxx|*****|5|192.168.xxx.xxx|3307|/op
    backitup.0	2018-08-09 08:52:30.594	info	[total] backup was activated at 08:55 every 7 day(s)
    backitup.0	2018-08-09 08:52:30.512	info	[minimal] backup was activated at 08:55 every 1 day(s)
    backitup.0	2018-08-09 08:52:30.439	info	starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v6.14.3
    backitup.0	2018-08-09 08:52:30.154	debug	statesDB connected
    backitup.0	2018-08-09 08:52:29.946	debug	objectDB connected
    backitup.0	2018-08-09 08:52:24.644	info	terminating
    backitup.0	2018-08-09 08:51:23.652	info	[total] backup was activated at 02:15 every 7 day(s)
    backitup.0	2018-08-09 08:51:23.531	info	[minimal] backup was activated at 02:00 every 1 day(s)
    backitup.0	2018-08-09 08:51:23.462	info	starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v6.14.3
    backitup.0	2018-08-09 08:51:23.177	debug	statesDB connected
    backitup.0	2018-08-09 08:51:22.922	debug	objectDB connected
    Gruß Dirk
    • F Offline
      fraeggle
      #551
      Daten/Daten/iobroker Stimmt das????
      Ich geh mal davon aus das du die xxx bei der IP nachträglich reingeschrieben hast, wobei ein paar posts weiter oben hast du die IP Adresse eh nicht "unterdrückt".
      Gruß Peter
      • SegwayS Offline
        SegwayS Offline
        Segway
        #552
        @fraeggle:
        Daten/Daten/iobroker Stimmt das???? `
        Ja so heisst der Share auf dem NAS. Wobei er warum auch immer direkt in Daten/Daten schreibt und nicht ins Unterverzeichnis iobroker
        @fraeggle:
        Gruß Peter `
        Ja habe ich nachträglich bearbeitet weil mir zu viel Sachen drin standen :D
        Gruß Dirk
        • C Offline
          csamaggi
          #553
          Hallo erstmal,
          und danke für diesen Adapter.
          Jedoch bekomme ich ihn nicht zum laufen ich habe meinen Daten für mein NAS eingetragen auf FTP.
          Wenn ich es mit Filezille versuche komme ich auch drauf.
          Hier mein Log ` > backitup.0 2018-08-10 18:20:24.726 error [ccu] Exited with 1
          backitup.0 2018-08-10 18:20:24.718 debug [ccu] –- Error by Homematic-Login!! Details here: /opt/iobroker/node_modules/iobroker.backitup/backitup.sh.lastrun ---
          backitup.0 2018-08-10 18:20:24.716 debug [ccu] invalid username oder password
          backitup.0 2018-08-10 18:20:24.709 debug [ccu] Error by Homematic-Login !
          backitup.0 2018-08-10 18:20:24.694 debug [ccu] success –- Login Homematic CCU successful ---
          backitup.0 2018-08-10 18:20:24.213 debug [ccu] –- Start Homematic CCU Backup ---
          backitup.0 2018-08-10 18:20:24.211 debug [ccu] Creating ccu backup [ccu||5|192.168.1.206|/Backup/CCU/|Backup|backup|192.168.1.117|Admin||FTP|false|false||||||||/opt/iobroker]
          backitup.0 2018-08-10 18:20:24.180 debug sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
          backitup.0 2018-08-10 18:20:24.177 debug [ccu] Telegram Message enabled
          backitup.0 2018-08-10 18:20:24.175 debug [ccu] used Telegram-Instance: telegram.0
          backitup.0 2018-08-10 18:20:24.175 info [ccu] bash /opt/iobroker/node_modules/iobroker.backitup/backitup.sh "ccu||5|192.168.1.206|/Backup/CCU/|Backup|backup|192.168.1.117|Admin||FTP|false|false||||||||/opt/iobroker"
          backitup.0 2018-08-10 18:20:24.169 info [ccu] oneClick backup started `
          Das bekomme ich angezeigt also es wird kein Backup angelegt.
          MFG Maggi
          • simatecS Offline
            simatecS Offline
            simatec
            #554
            Laut dem Log fehlt das Passwort für die CCU
            • Besuche meine Github Seite
            • HowTo Restore ioBroker
            • C Offline
              csamaggi
              #555
              Danke sehr habe es auch gesehen dachte ich hätte keins gesetzt.
              MFG Maggi
              • MicM Offline
                MicM Offline
                Mic
                #556
                @Bluefox:
                @Mic:
                @Chaot:
                Das Problem ist jetzt zwar weg, aber das sollte man eventuell im Hinterkopf behalten das alte Installationen die Objekte nicht neu schreiben. Das könnte die ein- oder andere Fehlerquelle erklären. `
                Ich kenne die Problematik von anderen Systemen bei der Plugin-Programmierung.
                Die Lösung ist hier, dass im Plugin die aktuell zu installierende Version in eine Konstante kommt, z.B. '3.17'. Dann wird im Skript im Bereich "Plugin-Installation" die derzeit installierte Version abgefragt. Wenn man dann hier z.B. "< '3.11'" hat, dann wird bei bestehenden Installationen kleiner Version 3.11 was durchgeführt, in diesem Fall könnten die Objektinhalte in die neue Objektstruktur übertragen - oder falls nicht relevant - alle alten Objekte gelöscht werden.
                Nur meine 2 Cents… Wäre gegebenfalls auch was für ein Adapter-Framework. `
                Adapter ist gerade 2 Wochen alt und ist noch tiefe BETA Version.
                Adapter wurde stark überarbeitet und es gibt noch viel zu tun. Und du schlägst vor die Zeit in Kompatibilität zu stecken?
                Wieso machst das selbst nicht? `
                Sorry für die falsch angebrachte Kritik, so sollte das nicht ankommen. Vielmehr als Anregung generell, da auch bei Adaptern jenseits der 2 Wochen doch mal Datenpunkte geändert werden etc., und dies gerade nicht versierte Benutzer verunsichert und vor allem viel Arbeit der Umstellung bedeuten kann. Aber hier in dem Zusammenhang wirklich nicht angebracht, entschuldigt bitte.
                • MathiasJM Offline
                  MathiasJM Offline
                  MathiasJ
                  #557
                  Jetzt habe ich doch noch ein (kleines).Problem:
                  Alle Backups werden ordnungsgemäß gemacht, aber die alten nicht gelöscht.
                  Ich habe angegeben, dass jeden Tag um 01:30 ein CCU-Backup, um 2:00 ein minimales Backup gemacht werden soll. Das wird erledigt.
                  Alle Backups älter als 5 Tage sollen gelöscht werden.
                  Das wird nicht erledigt.
                  Gruß, Mathias
                  Gesendet von meinem SM-N915FY mit Tapatalk
                  IObroker auf dem NUC als VM.
                  • simatecS Offline
                    simatecS Offline
                    simatec
                    #558
                    Kannst du kurz beschreiben, wie du die Backups ablegst? CiFS oder FTP?
                    • SegwayS Offline
                      SegwayS Offline
                      Segway
                      #559
                      Bei mir ist das gleiche Probleme.
                      Das löschen der alten Backups geht nicht - da bleibt er einfach stehen und nichts passiert.
                      Ebenso kann ich unter Pfad eingeben was ich will aber der nimmt einfach nicht den Pfad an den ich dort eingebe.
                      Nun habe ich mir einfach mal die backitip.sh angeschaut und dort steht:
                      # Define backup path in ioBroker
                      backupDir="${IOBROKER_DIR}/backups"
                      Also wird doch egal was ich mache immer in ./backups die Backups landen. und genauso ist es auch bei mir - genau dort kommen alle Backups an !
                      Wie kann ich denn nun den Pfad ändern ? Connected wird per ftp da mit cifs ein Fehler kommt (device busy)
                      Gruß Dirk
                      • J Offline
                        Jan1
                        #560
                        richtig, in diesem Verzeichnis werden die Backups abgelegt und von dort aus weiter auf z.B. den NAS gesichert und die Backups in dem Verzeichnis sollten auch nach der eingestellten Zeit gelöscht werden
                        • SegwayS Offline
                          SegwayS Offline
                          Segway
                          #561
                          @Jan1:
                          richtig, in diesem Verzeichnis werden die Backups abgelegt und von dort aus weiter auf z.B. den NAS gesichert und die Backups in dem Verzeichnis sollten auch nach der eingestellten Zeit gelöscht werden `
                          Das ist richtig ABER wenn ich auf dem pi in diesen Verzeichnis gehe ist diese Verzeichnis bereits das verzeichnis auf dem NAS, d.h. der schreibt schon direkt auf den NAS
                          Kopiert wird nix mehr
                          Gruß Dirk
                          • simatecS Offline
                            simatecS Offline
                            simatec
                            #562
                            Mach mal ein Screenshot deiner FTP Einstellungen
                            • SegwayS Offline
                              SegwayS Offline
                              Segway
                              #563
                              Hab jetzt viel rumgestest,
                              Sobald ich auf CIFS umstelle (Testzwecke) bleibt er bei delete backup einfach stehen. da passiert nichts mehr. Problem ist natürlich, dass kein umount mehr gemacht wird. Sobald ich das nächste mal teste kommt die bekannte Meldung –> drive busy.
                              Hier meine FTP-Einstellungen:
                              Gruß Dirk
                              • J Offline
                                Jan1
                                #564
                                @Segway:
                                @Jan1:
                                Kopiert wird nix mehr `
                                Bei mir läuft der IOBroker auf dem PI und das Backup Verzeichnis befindet sich auch auf der SD Karte im PI und genau von diesem werden bei mir eben diese Backups so auf das in den Einstellungen angegebene Verzeichnis auf dem NAS kopiert und auf der SD wie voreingestellt gelöscht.
                                Was Du da hast entspricht wohl nicht dem Standard und verhält sich dementsprechend anders.
                                Bei Deiner Pfadangabe fehlt übrigens der "/" am Anfang für FTP!
                                Hinweis der Anleitung:
                                Pfadangaben (Schreibweise beachten):
                                CIFS: "Freigabename/Pfadangabe"
                                FTP: "/Pfadangabe"
                                • SegwayS Offline
                                  SegwayS Offline
                                  Segway
                                  #565
                                  Mhhhh,
                                  also ich bin kein Freund davon auf die SD-Karte des Pi's zu schreiben. Dadurch habe ich mir mittlerweile bereits 2 SD-Karten geschrottet. Und das nur durch einen Neustart des Pi's - vorher lief alles !
                                  @Jan1:
                                  FTP: "/Pfadangabe" `
                                  Hab ich was überlesen ? Wo steht die Anleitung bzw. dieser Hinweis ?
                                  Gruß Dirk
                                    Kueppert
                                    #566
                                    @Segway:
                                    Mhhhh,
                                    @Jan1:
                                    Hab ich was überlesen ? Wo steht die Anleitung bzw. dieser Hinweis ? ` Punkt 3 in der readme ;) hatte ich auch erst überlesen
                                    Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
                                    • SegwayS Offline
                                      SegwayS Offline
                                      Segway
                                      #567
                                      Jau habs gefunden !
                                      Puh….dann sollte es jetzt ja klappen .... mal sehen
                                      Gruß Dirk
                                      • SegwayS Offline
                                        SegwayS Offline
                                        Segway
                                        #568
                                        Welche Einstellungen / Sicherungen sollte man denn unter den Haupteinstellungen wählen ???
                                        ioBroker Stop bei einem Backup <u>ja/nein</u> (dann wird doch auch kein Wert mehr geschrieben ?)
                                        Redis Status sichern <u>ja/nein</u> (kann ich ehrlich gesagt nix mit anfangen?)
                                        Benachrichtigungen per Telegram <u>ja/nein</u> (?)
                                        Gruß Dirk
                                        • PeoplesP Offline
                                          PeoplesP Offline
                                          Peoples
                                          #569
                                          @Segway:
                                          Benachrichtigungen per Telegram <u>ja/nein</u> (?) `
                                          Iobroker Stop wenn du beim komplett Backup auch die aktuellsten states sichern willst.
                                          Redis ja wenn du Redis nutzt und gesichert haben willst.
                                          Telegram ja wenn du eine Benachrichtigung via telegram bekommen möchtest
