  4. Eurotronic spirit z-wave Plus übernimmt keinen Schaltpunkt
89 Beiträge 21 Kommentatoren 22.6k Aufrufe 4 Beobachtet
  • N Offline
    N Offline
    Nitramius
    Ahhh - sorry - wieder was gelernt ;)
    Ich habe zum Vergleich 2 Befehle gesetzt:
    1. Backlight geändert - funktioniert
    2. THERMOSTAT_MODE geändert - funktioniert nicht
    Das wurde ins Log geschrieben (bereinigt von anderem Kram):
    2018-07-06 10:01:33.383  - [34mdebug[39m: zwave.0 redis pmessage  io.zwave.0.* io.zwave.0.NODE11.CONFIGURATION.Backlight {"val":1,"ack":false,"ts":1530864093382,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1530864093382}
    2018-07-06 10:01:33.384  - [34mdebug[39m: zwave.0 stateChange zwave.0.NODE11.CONFIGURATION.Backlight set {"val":1,"ack":false,"ts":1530864093382,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1530864093382}
    2018-07-06 10:01:33.384  - [34mdebug[39m: zwave.0 setConfigParam for: nodeID=11: index=3: value=1
    2018-07-06 10:01:35.163  - [34mdebug[39m: zwave.0 value changed: 11 comClass: 112 value: {"value_id":"11-112-1-3","node_id":11,"class_id":112,"type":"list","genre":"config","instance":1,"index":3,"label":"Backlight","units":"","help":"Default: Backlight enabled","read_only":false,"write_only":false,"min":0,"max":1,"is_polled":false,"values":["Backlight disabled","Backlight enabled"],"value":"Backlight enabled"}
    2018-07-06 10:01:35.165  - [34mdebug[39m: zwave.0 redis pmessage  io.zwave.0.* io.zwave.0.NODE11.CONFIGURATION.Backlight {"val":"1","ack":true,"ts":1530864095164,"q":0,"from":"system.adapter.zwave.0","user":"system.user.admin","lc":1530864095164}
    2018-07-06 10:01:36.317  - [34mdebug[39m: zwave.0 value changed: 10 comClass: 50 value: {"value_id":"10-50-1-32","node_id":10,"class_id":50,"type":"bool","genre":"user","instance":1,"index":32,"label":"Exporting","units":"","help":"","read_only":true,"write_only":false,"min":0,"max":0,"is_polled":false,"value":false}
    2018-07-06 10:01:36.318  - [34mdebug[39m: zwave.0 value changed: 10 comClass: 50 value: {"value_id":"10-50-1-8","node_id":10,"class_id":50,"type":"decimal","genre":"user","instance":1,"index":8,"label":"Power","units":"W","help":"","read_only":true,"write_only":false,"min":0,"max":0,"is_polled":false,"value":"0.0"}
    2018-07-06 10:01:37.992  - [34mdebug[39m: zwave.0 value changed: 18 comClass: 50 value: {"value_id":"18-50-1-32","node_id":18,"class_id":50,"type":"bool","genre":"user","instance":1,"index":32,"label":"Exporting","units":"","help":"","read_only":true,"write_only":false,"min":0,"max":0,"is_polled":false,"value":false}
    2018-07-06 10:01:37.993  - [34mdebug[39m: zwave.0 value changed: 18 comClass: 50 value: {"value_id":"18-50-1-8","node_id":18,"class_id":50,"type":"decimal","genre":"user","instance":1,"index":8,"label":"Power","units":"W","help":"","read_only":true,"write_only":false,"min":0,"max":0,"is_polled":false,"value":"0.1"}
    2018-07-06 10:01:44.874  - [34mdebug[39m: zwave.0 redis pmessage  io.zwave.0.* io.zwave.0.NODE11.THERMOSTAT_MODE._1 {"val":1,"ack":false,"ts":1530864104874,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1530864104874}
    2018-07-06 10:01:44.875  - [34mdebug[39m: zwave.0 stateChange zwave.0.NODE11.THERMOSTAT_MODE._1 set {"val":1,"ack":false,"ts":1530864104874,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1530864104874}
    2018-07-06 10:01:44.875  - [34mdebug[39m: zwave.0 setState for: nodeID=11: comClass=64: index=0: instance=1: value=1
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      Ich habe das Gefühl, dein Objekt bildet den Node aus ZWave nicht richtig ab. THERMOSTAT_MODE ist die CommandClass, die aber benannte Eigenschaften haben müsste, die das Verhalten steuern. Normalerweise haben die States einen richtigen Namen, z.B. Mode_1. Deiner heißt nur _1 und hat außerdem "index: 0", was ich so auch noch nicht gesehen habe.
      Kannst du den Node bitte nochmal aus ZWave ablernen, dann den kompletten Objektbaum zu NODE11 löschen und neu anlernen?
      • N Offline
        N Offline
        Nitramius
        @AlCalzone:
        Kannst du den Node bitte nochmal aus ZWave ablernen, dann den kompletten Objektbaum zu NODE11 löschen und neu anlernen? `
        Hi, habs versucht - jedoch ohne Erfolg! Das Gerät wird wieder genau gleich eingebunden. Das "_1" taucht übrigens genau gleich bei der Zipato Bulb auf…
          AlCalzoneA Offline
          AlCalzone
          Habe nochmal in den Source Code von OZW geschaut. Anscheinend ist Index 0 korrekt, die Variable hat aber eigentlich den Namen "Mode". Keine Ahnung warum die in ioBroker nicht ankommt.
          Was bezüglich der Schaltbefehle sein kann: Die Thermostate wachen üblicherweise nur alle paar Minuten kurz auf und holen sich die neuesten Daten. Eventuell siehst du deswegen nichts im Log, weil direkt erst mal nix passiert. Werden die Änderungen übernommen, wenn du das Thermostat manuell aufweckst?
          • N Offline
            N Offline
            Nitramius
            Nachdem alle anderen Befehle auch sofort umgesetzt werden, solllte das mit dem "Thermostat_Mode" auch so sein. Die Eurotronic Thermostate sind FLiRS Geräte und sollten sich schnell aufwecken lassen.
            Ich vermute eher einen BUG in openzwave / ioBroker, da sich das selbe Szenario bei der Zipato Bulb zeigt. Eventuell kann openzwave mit "_1" nichts anfangen, weil es eigentlich "Mode_1" heißen sollte… aber da kenne ich mich zu wenig aus...
              AlCalzoneA Offline
              AlCalzone
              @Nitramius:
              Eventuell kann openzwave mit "_1" nichts anfangen, weil es eigentlich "Mode_1" heißen sollte… aber da kenne ich mich zu wenig aus... `
              Intern sollten bei OZW nur die ValueIDs ankommen, d.h. <node>-<commandclass>-<instance>-<index>. Der Aufruf seitens ioBroker ist soweit ich das beurteilen kann korrekt - hier wird keine Unterscheidung getroffen, um welchen State es sich handelt. ioBroker geht rein über die value-ID die im Objekt hinterlegt ist. Wo genau das Problem jetzt liegt (openzwave-shared, OZW-Lib, …), weiß ich aber leider auch nicht.</index></instance></commandclass></node>
              • E Offline
                Exelant
                Hallo Zusammen,
                schade das es hier nicht weiter geht.
                Ich hab aus dem node-openzwave-shared mal das test2.js ausprobiert.
                Auf der Node CLI kann man damit die Temperaturen ändern, aber den Modus auch nicht.
                ##Temperatur ändern:
                > zwave.setValue(3, 67, 1, 1, 10);
                m2018-07-26 11:48:21.803 Info, Node003, Value::Set - COMMAND_CLASS_THERMOSTAT_SETPOINT -  - 1 - 1 - 10
                2018-07-26 11:48:21.803 Detail, Node003, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_THERMOSTAT_SETPOINT
                2018-07-26 11:48:21.804 Detail, Node003, Queuing (Send) ThermostatSetpointCmd_Set (Node=3): 0x01, 0x0c, 0x00, 0x13, 0x03, 0x05, 0x43, 0x01, 0x01, 0x01, 0x0a, 0x25, 0x3d, 0xb6
                2018-07-26 11:48:21.804 Detail, Node003, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_THERMOSTAT_SETPOINT
                2018-07-26 11:48:21.804 Detail, Node003, Queuing (Send) ThermostatSetpointCmd_Get (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x43, 0x02, 0x01, 0x25, 0x3e, 0xbd
                2018-07-26 11:48:21.804 Info, Node003, Processing (Send) Nonce Request message (Callback ID=0x3d, Expected Reply=0x13)
                2018-07-26 11:48:21.804 Info, Node003, Sending (Send) message (Callback ID=0x02, Expected Reply=0x13) - Nonce_Get(ThermostatSetpointCmd_Set) - 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x98, 0x40, 0x05, 0x02:
                undefined
                > m2018-07-26 11:48:21.810 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                2018-07-26 11:48:21.810 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
                2018-07-26 11:48:23.030 Detail, Node003,   Received: 0x01, 0x18, 0x00, 0x13, 0x02, 0x00, 0x00, 0x7a, 0x00, 0xbf, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x42, 0x04, 0x00, 0x00, 0x77
                2018-07-26 11:48:23.030 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
                2018-07-26 11:48:23.030 Info, Node003, Request RTT 1226 Average Request RTT 673
                2018-07-26 11:48:23.054 Detail, Node003,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x03, 0x0a, 0x98, 0x80, 0x57, 0xce, 0xc8, 0xba, 0x21, 0xa3, 0x49, 0x67, 0xbf, 0x00, 0x00
                2018-07-26 11:48:23.055 Info, Node003, Received SecurityCmd_NonceReport from node 3
                2018-07-26 11:48:23.055 Info, Node003, Sending (Send) message (Callback ID=0x3f, Expected Reply=0x13) - ThermostatSetpointCmd_Set (Node=3): 0x01, 0x0c, 0x00, 0x13, 0x03, 0x05, 0x43, 0x01, 0x01, 0x01, 0x0a, 0x25, 0x3f, 0xb4
                2018-07-26 11:48:23.064 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                2018-07-26 11:48:23.064 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
                2018-07-26 11:48:23.091 Detail, Node003,   Received: 0x01, 0x18, 0x00, 0x13, 0x3f, 0x00, 0x00, 0x02, 0x00, 0xbf, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x77
                2018-07-26 11:48:23.092 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x3f received (expected 0x3f)
                2018-07-26 11:48:23.092 Info, Node003, Request RTT 1288 Average Request RTT 980
                2018-07-26 11:48:23.092 Detail,   Expected callbackId was received
                2018-07-26 11:48:23.092 Detail,   Expected reply was received
                2018-07-26 11:48:23.093 Detail,   Message transaction complete
                2018-07-26 11:48:23.093 Detail, Node003, Removing current message
                2018-07-26 11:48:23.094 Info, Node003, Processing (Send) Nonce Request message (Callback ID=0x3e, Expected Reply=0x04)
                2018-07-26 11:48:23.094 Info, Node003, Sending (Send) message (Callback ID=0x02, Expected Reply=0x04) - Nonce_Get(ThermostatSetpointCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x98, 0x40, 0x05, 0x02:
                2018-07-26 11:48:23.099 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                2018-07-26 11:48:23.099 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
                2018-07-26 11:48:23.122 Detail, Node003,   Received: 0x01, 0x18, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0x00, 0xbf, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x4a
                2018-07-26 11:48:23.122 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
                2018-07-26 11:48:23.122 Info, Node003, Request RTT 28 Average Request RTT 504
                2018-07-26 11:48:23.146 Detail, Node003,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x03, 0x0a, 0x98, 0x80, 0xa9, 0xfe, 0x8b, 0x4b, 0x81, 0x6f, 0xc7, 0x62, 0xbf, 0x00, 0x9b
                2018-07-26 11:48:23.147 Info, Node003, Received SecurityCmd_NonceReport from node 3
                2018-07-26 11:48:23.147 Info, Node003, Sending (Send) message (Callback ID=0x40, Expected Reply=0x04) - ThermostatSetpointCmd_Get (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x43, 0x02, 0x01, 0x25, 0x40, 0xc3
                2018-07-26 11:48:23.155 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                2018-07-26 11:48:23.156 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
                2018-07-26 11:48:23.182 Detail, Node003,   Received: 0x01, 0x18, 0x00, 0x13, 0x40, 0x00, 0x00, 0x03, 0x00, 0xbf, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x09
                2018-07-26 11:48:23.183 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x40 received (expected 0x40)
                2018-07-26 11:48:23.183 Info, Node003, Request RTT 89 Average Request RTT 296
                2018-07-26 11:48:23.183 Detail,   Expected callbackId was received
                2018-07-26 11:48:23.229 Detail, Node003,   Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x03, 0x02, 0x98, 0x40, 0xbe, 0x00, 0x96
                2018-07-26 11:48:23.229 Info, Node003, Received SecurityCmd_NonceGet from node 3
                2018-07-26 11:48:23.229 Info, NONCES: 0xd6, 0xb9, 0x2d, 0x38, 0x7f, 0x1f, 0x23, 0x5c
                2018-07-26 11:48:23.229 Info, NONCES: 0x65, 0xa8, 0x9b, 0x42, 0x26, 0x12, 0x1b, 0xa5
                2018-07-26 11:48:23.230 Info, NONCES: 0xa8, 0xc3, 0x7c, 0x28, 0xe2, 0xa0, 0x84, 0x35
                2018-07-26 11:48:23.230 Info, NONCES: 0x4b, 0x1d, 0xdd, 0xb8, 0x0c, 0x72, 0xfc, 0xb5
                2018-07-26 11:48:23.230 Info, NONCES: 0x6a, 0xb2, 0xac, 0xa3, 0x58, 0x2f, 0x9b, 0xa0
                2018-07-26 11:48:23.230 Info, NONCES: 0x94, 0x97, 0xaa, 0x49, 0xc6, 0x49, 0x54, 0x30
                2018-07-26 11:48:23.230 Info, NONCES: 0xc4, 0xb2, 0x1f, 0xaf, 0x62, 0xc6, 0xf1, 0xea
                2018-07-26 11:48:23.230 Info, NONCES: 0x80, 0x93, 0x29, 0x46, 0xdd, 0x7e, 0x76, 0xd9
                2018-07-26 11:48:23.230 Info, Node003, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x03, 0x0a, 0x98, 0x80, 0x4b, 0x1d, 0xdd, 0xb8, 0x0c, 0x72, 0xfc, 0xb5, 0x05, 0x01, 0xec:
                2018-07-26 11:48:23.237 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
                2018-07-26 11:48:23.237 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
                2018-07-26 11:48:23.261 Detail, Node003,   Received: 0x01, 0x18, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0x00, 0xbf, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x49
                2018-07-26 11:48:23.262 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
                2018-07-26 11:48:23.262 Info, Node003, Request RTT 167 Average Request RTT 231
                2018-07-26 11:48:23.294 Detail, Node003,   Received: 0x01, 0x22, 0x00, 0x04, 0x00, 0x03, 0x1a, 0x98, 0x81, 0x9e, 0xf0, 0xed, 0x15, 0xb2, 0xa1, 0x7a, 0x35, 0xc9, 0xba, 0x36, 0x8d, 0xc8, 0x6d, 0x7f, 0x4b, 0x6a, 0xa7, 0x19, 0x2e, 0x23, 0x80, 0x1a, 0x97, 0xbf, 0x00, 0x21
                2018-07-26 11:48:23.295 Info, Raw: 0x98, 0x81, 0x9e, 0xf0, 0xed, 0x15, 0xb2, 0xa1, 0x7a, 0x35, 0xc9, 0xba, 0x36, 0x8d, 0xc8, 0x6d, 0x7f, 0x4b, 0x6a, 0xa7, 0x19, 0x2e, 0x23, 0x80, 0x1a, 0x97, 0xbf
                2018-07-26 11:48:23.295 Detail, Node003, Decrypted Packet: 0x00, 0x43, 0x03, 0x01, 0x22, 0x00, 0x64
                2018-07-26 11:48:23.296 Info, Node003, Response RTT 201 Average Response RTT 205
                2018-07-26 11:48:23.296 Detail, Node003, Refreshed Value: old value=11.0, new value=10.0, type=decimal
                2018-07-26 11:48:23.296 Detail, Node003, Changes to this value are not verified
                2018-07-26 11:48:23.296 Info, Node003, Received thermostat setpoint report: Setpoint  = 10.0C
                2018-07-26 11:48:23.296 Detail, Node003,   Expected reply and command class was received
                2018-07-26 11:48:23.297 Detail, Node003,   Message transaction complete
                2018-07-26 11:48:23.297 Detail, Node003, Removing current message
                2018-07-26 11:48:23.298 Detail, Node003, Notification: ValueChanged
                ode3: changed: 67::11.0->10.0
                ##Thermostat Mode ändern
                > zwave.setValue(3, 64, 1, 0, 1);
                undefined
                Gefühlt passiert dabei überhaupt nix.
                Leider fehlen mir die Kenntnisse wie ich das am sinnvollsten debugge…
                Kann man das openzwave selbst irgendwie testen ohne iobroker/nodejs modul?
                Gruß Linde
                  AlCalzoneA Offline
                  AlCalzone
                  @Exelant:
                  Kann man das openzwave selbst irgendwie testen ohne iobroker/nodejs modul? `
                  Ja, indem du es mit C/C++ ansprichst. Aber da du schonmal die ioBroker-Implementation als Fehlerquelle ausgeschlossen hast, wäre das ein Fall für ein Issue im openzwave-repo:
                  https://github.com/OpenZWave/node-openz … red/issues (fürs node-modul)
                  https://github.com/OpenZWave/open-zwave/issues (für OpenZWave selbst, was ich eher glaube)
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    ich hab mal eben auf neue version upgedated openzwave 1.4 (master brunch)
                    sollte der eurotronic nicht drinn sein ?? damals im DEV wurde er zumindest richtig erkannt
                    https://github.com/OpenZWave/open-zwave/pull/1553
                      AlCalzoneA Offline
                      AlCalzone
                      Der verlinkte PR wurde nicht gemerged, da hat ein User auf GitHub Mist gebaut.
                      • arteckA Offline
                        arteckA Offline
                        arteck
                        jo schitte garnicht bis nach unten gescrollt… dann kram ich wieder die alte version raus..
                        • N Offline
                          N Offline
                          Nitramius
                          Sorry - hatte die letzten Tage keine Zeit das weiter zu verfolgen.
                          Leider fehlt mir das Knowhow um hier weiter zu machen.
                          Ich kann nur sagen, dass zwar der gesetzte Wert vom "Thermostatmode" problemlos ausgelesen wird (bei manueller Bedienung am Thermostat), jedoch das Setzen des Wertes über ioBroker mit ZWave Adapter nicht möglich ist.
                          Warum ist mir schleierhaft…. :roll:
                          • C Offline
                            Calle
                            Ich bin neu von openHAB zu ioBroker umgestiegen. Leider musste ich feststellen das der SPIRIT hier noch wenig geht als in meiner openHAB Installation…
                            Hat mittlerweile jemand einen Workarround um das Teil zum laufen zu bekommen? Darf auch vollgepackt mit IT begriffen sein hab da ein wenig viel ahnung :D
                            • arteckA Offline
                              arteckA Offline
                              arteck
                              ich hab mal was zusammengeschustert um das Thermostat zu unterstützen ..
                              allerdings habe ich irgendwo ein Problem…. muss ich schauen.. aber erstmal Zeit finden...
                              bin aber dran
                                muerzi
                                Habe OZW wie in viewtopic.php?f=17&t=9789#p127695 beschrieben installiert.
                                Jetzt wollte ich das Display um 180grad drehen und den Temperaturreport auf 0,2Grad stellen (Parameter 5)
                                Jedoch sind "CLASSES94" und "CONFIGURATION" keine "Ordner" sondern einfach Einträge.
                                ![](</s><ATTACHMENT 9146_2018-10-10_11_14_59-browser_station.jpg )[attachment=0]~~2018-10-10 11_14_59-Browser Station.jpg[/attachment]" />
                                Hatte jemand ein ähnliches Problem bzw. bereits gelöst?
                                lg~~
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  dann sind die Datenpunkte noch nicht gemeldet worden vom Device…
                                  oder
                                  hast du openzwave neu installiert.. da ist das Thermostat nicht drinn ..es gab ein PR Problem und es wurde raus genommen..
                                    muerzi
                                    Könnte man nicht einfach die spirit.xml aus dem dev repo config folder lokal auf den raspi kopieren und dabei ozw auf standard (ohne neu kompilieren) belassen?
                                    Danach im zwave adapter bei den spirits einfach „info aktualisieren“ auswählen?
                                    • arteckA Offline
                                      arteckA Offline
                                      arteck
                                      probier es aus…
                                      wird aber nicht gehen.da die device xml explizit angegeben werden im code.. die werden nicht dynamisch angezogen
                                        muerzi
                                        Hast recht.
                                        Funktioniert nicht….
                                        Hab von tobiasgraf die Eurotronic_Spirit_Z branch genommen.
                                        Damit funktionierts jetzt.
                                        Werde in 2-3Tagen wenns stabil läuft meine vorgehensweise posten.
                                        Vielen Dank für deine Hilfe!
                                        • arteckA Offline
                                          arteckA Offline
                                          arteck
                                          den hab ich auch.. läuft schon seit über einem Jahr.. nur würde gerne auch die neuen sachen von OpenZwave haben wollen..
                                          sein PR wurde abgelehnt.. so nach 9 Monaten..
                                          ich habe mir gerade den dev branch angeschaut da ist der euronic auch schon drin
                                          https://github.com/OpenZWave/open-zwave/tree/Dev
