  4. HILFE: iobroker läuft nicht mehr
30 Beiträge 7 Kommentatoren 3.9k Aufrufe
    Berndi
    Hallo Gemeinde,
    nach einem Update des admin-Adapters hat das Drama begonnen! ;-)
    sudo iobroker start
    bringt:
    module.js:549
        throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (module.js:547:15)
        at Function.Module._load (module.js:474:25)
        at Function.Module.runMain (module.js:693:10)
        at startup (bootstrap_node.js:191:16)
        at bootstrap_node.js:612:3
    und
    sudo npm i iobroker.js-controller@1.0.3
    bringt dann:
    npm WARN deprecated tar.gz@1.0.7: ⚠️  WARNING ⚠️ tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
    > iobroker.js-controller@1.0.3 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    fs.js:1061
      return binding.unlink(pathModule._makeLong(path));
    Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
        at Object.fs.unlinkSync (fs.js:1061:18)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:126:24)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:590:27
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:622:15)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2903:5)
        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
        at Module._compile (module.js:652:30)
        at Object.Module._extensions..js (module.js:663:10)
        at Module.load (module.js:565:32)
        at tryModuleLoad (module.js:505:12)
    npm WARN npm@2.15.12 had bundled packages that do not match the required version(s). They have been replaced with non-bundled versions.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@1.0.3 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@1.0.3 install script.
    npm ERR!     /root/.npm/_logs/2018-06-17T13_48_47_212Z-debug.log</anonymous>
    Bitte helft mir, ich komme nicht mehr weiter! :-(
    • HomoranH Offline
      HomoranH Offline
      Karte hin?
      Gruß Rainer
        Berndi
        Hallo Rainer,
        ich hoffe nicht, die ist erst ca. 4 Wochen alt… :?
        • U Offline
          U Offline
          Ulti
          Habe exakt dasselbe Problem. Kann keiner helfen??? :(
          mfg
          • StabilostickS Offline
            Stabilostick
            Evtl. bring die Reinstallation des js-controllers etwas?
            sudo iobroker stop
            sudo npm install -g npm@4
            sudo npm install iobroker.js-controller --production
            sudo iobroker start
            Edit: npm eingefügt
              Morrio
              ich schließe mich den Problemen an. Habe genau die selben Fehlermeldungen.
              Habe mich längere Zeit nicht um meine Installation gekümmert und wollte jetzt wieder einsteigen. Bei den Updates etc ist dann das Problem aufgetreten.
              @Stabilostick:
              sudo iobroker stop
              sudo iobroker start
              Hier kommt bei mir die Fehlermeldung wie im Anhang gezeigt.
                daniello
                Wollte mich anschließen .. aber was ich als Log beifügen wollte hat irgendwie dazu geführt, dass ich iobroker wieder starten konnte .. vielleicht hilfts.
                nodejs: v8.11.1
                npm: 6.2.0
                sudo iobroker start
                pi@raspi:~ $ sudo iobroker start
                module.js:549
                    throw err;
                    at startup (bootstrap_node.js:188:16)
                    at bootstrap_node.js:609:3
                pi@raspi:~ $
                npm install iobroker .js-controller –production
                > iobroker.js-controller@1.4.2 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                > node lib/preinstall_check.js
                NPM version: 6.2.0
                npm version >= 5: disabling package-lock
                > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
                > node-gyp rebuild
                make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
                  CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                  SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                  COPY Release/unix_dgram.node
                make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                > iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
                + iobroker.js-controller@1.4.2
                added 341 packages from 239 contributors and audited 1773 packages in 94.343s
                found 11 vulnerabilities (8 low, 3 high)
                  run `npm audit fix` to fix them, or `npm audit` for details
                  Stabilostick
                  Habe oben noch
                  eingefügt.
                  npm 5.6.0 sollte man gar nicht verwenden. Und mit npm>5.7.0 habe ich wegen automatisch gelöschter Pakete auf Raspberries schlechte Erfahrungen gemacht.
                    daniello
                    ist 6.2.0 auch böse? Ach so .. sehe grad .. das "Größerzeichen".
                    Kann ich mit Deinem Befehl ein Downgrade machen?
                    Und wird NPM dann nicht verändert, wenn ich in per Shell ein
                    sudo apt-get update && sudo apt-get upgrade -y
                    absetzte?
                    • paul53P Offline
                      @daniello:
                      Kann ich mit Deinem Befehl ein Downgrade machen? `
                      Ja.
                      @daniello:
                      absetzte? `
                      Ja, wobei es passieren kann, dass hinterher kein NPM mehr existiert.
                        daniello
                        stimmt .. das hatte ich schon .. kein NPM .. musste erstmal drauf kommen :-(
                        Danke!
                          daniello
                          Hab ich mal gemacht das
                          /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                          + npm@4.6.1
                          added 297 packages from 135 contributors and updated 2 packages in 26.683s
                          erhalte aber noch immer
                          npm -v 6.2.0
                            Stabilostick
                            Dann hast du noch ein zweites npm mal ohne -g installiert. Wenn du keine Lust hast, den Fehler zu suchen oder was zu löschen, mach im ioBroker-Ordner noch mal den Befehl ohne -g
                              daniello
                              Mit Lust hat das nichts zu tun .. eher mit Ahnungslosigkeit :-)
                              Hat nichts geändert:
                              pi@raspi:/opt/iobroker $ sudo npm install npm@4
                              + npm@4.6.1
                              added 299 packages from 591 contributors and audited 4433 packages in 50.961s
                              found 80 vulnerabilities (22 low, 44 moderate, 14 high)
                              pi@raspi:/opt/iobroker $ npm -v
                              6.2.0
                                Stabilostick
                                Ups, da war ich zu voreilig. Aber keine Sorge, nichts kaputt.
                                  Stabilostick
                                  Tipp mal ein````
                                  which npm
                                    daniello
                                    Hatte schon geschaut .. gibt nur einen Eintrag:
                                    /usr/local/bin/npm
                                      Stabilostick
                                      Der hat vorhin aber nach /usr/bin/npm installiert…
                                      • paul53P Offline
                                        Die Version 6.2.0 ist wahrscheinlich die in /usr/local/bin (im Suchpfad vorn). Da npm und npx nur (relative) Links sind, solltest Du sie in absolute Links auf die Version 4.6.1 ändern: Austausch der .. vorne gegen /usr. Das musste ich auch machen.
                                        root@rpihm:~# ls -l /usr/local/bin/np*
                                        lrwxrwxrwx 1 root staff 40 Jul 19 20:29 /usr/local/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                                        lrwxrwxrwx 1 root staff 40 Jul 19 20:29 /usr/local/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
                                        EDIT: Sehr einfach mit WinSCP "Verknüpfung bearbeiten"
                                          daniello
                                          hmm npx wird dan rot .. glaube da passt was nicht.
                                          Mir ist auch nicht ganz klar was ich nach dem ändern auf Absolut machen soll .. nochmal das Downgrade auf npm 4 versuchen?
