  4. Raspberry Image Hostname ändern zerstört Installation?
73 Beiträge 21 Kommentatoren 18.0k Aufrufe 3 Beobachtet
  • P Offline
    plazmatic07
    Ja, funktionier leider nicht.
    und der Befehl iobroker host set newHostName zeigt, dass ioBroker es schon mit bekommen hat, der WebAdmin funktioniert leider trotzdem danach nicht mehr.
    pi@ioBroker-Master:/opt/iobroker $ iobroker host set newHostName
    Rename state "system.host.ioBroker-Master.mem".
    Rename state "system.host.ioBroker-Master.memHeapUsed".
    Rename state "system.host.ioBroker-Master.memHeapTotal".
    Rename state "system.host.ioBroker-Master.memRss".
    Rename state "system.host.ioBroker-Master.uptime".
    Rename state "system.host.ioBroker-Master.load".
    Rename state "system.host.ioBroker-Master.alive".
    Rename state "system.host.ioBroker-Master.freemem".
    Rename state "system.host.ioBroker-Master.inputCount".
    Rename state "system.host.ioBroker-Master.outputCount".
    Instance host changed for "system.adapter.admin.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.discovery.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.hm-rpc.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.hm-rega.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.web.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.flot.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.rpi2.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.socketio.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.cloud.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.vis.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.history.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.javascript.0" from "ioBroker-Master" to "newHostName".
    Instance host changed for "system.adapter.mobile.0" from "ioBroker-Master" to "newHostName".
    Habe ich dann anschließend nochmal mit dem richtigen name gemacht
    in der Hosts past es
    127.0.0.1       localhost
    ::1             localhost ip6-localhost ip6-loopback
    ff02::1         ip6-allnodes
    ff02::2         ip6-allrouters
    127.0.1.1       ioBroker-Master
    und in hostname auch
    pi@ioBroker-Master:~ $ sudo nano /etc/hostname
      GNU nano 2.7.4        Datei: /etc/hostname
    ioBroker-Master
    ioBroker host this funktioniert weiterhin nicht
    pi@ioBroker-Master:/opt/iobroker $ sudo iobroker host this
    No instances found for host "this".
    Vor dem Hostname change funktioniert alles super.
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Eh, Du solltest „newHostName“ schon mit dem neuen/aktuelle Hostnamen ersetzen, wenn Du den Befehl eingibst (oder heißt der Host tatsächlich „newHostName“?)
      Gruß,
      Eric
      Von unterwegs getippert
      • eric2905E Offline
        eric2905E Offline
        eric2905
        Ah, jetzt gesehen, das Du das schon probiert hast….
        Nachher, wenn ich zu Hause bin, mal schauen.
        Gruß,
        Eric
        • P Offline
          plazmatic07
          Super, danke.
          Ist das letzte Image für den Raspberry.
          • H Offline
            hmanfred
            Ich hänge mich hier mal dran.
            Neuinstallation mit dem Image "ioBroker_Image_RPi_2-3_20180401_stretch.img".
            Nach durchlaufen der Setup-Prozedur in raspi-config (Hostnamen ändern, Expand Filesystem) den Befehl "iobroker host this" ausgeführt. Gleiches Problem wie vorne von plazmatic07 beschrieben.
            Reboot und erneuter Versuch: "iobroker host this" erfolgreich. Zeigt allerdings, dass der Hostname bereits geändert war (sinngemäß "…von raspberrypi01 auf raspberrypi01 geändert...").
            Aufruf Admin:
            Endlos!
            Admin Adapter läuft:
            pi@raspberrypi01:/opt/iobroker $ iobroker list instances
            system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            Prüfen ob js-controller läuft:
            pi@raspberrypi01:/opt/iobroker $ sudo ps -A | grep iobroker
             6191 ?        00:00:00 iobroker contro
            Läuft er???
            Dann:
            pi@raspberrypi01:/opt/iobroker $ netstat -n -a -p TCP
            (Es konnten nicht alle Prozesse identifiziert werden; Informationen über
            nicht-eigene Processe werden nicht angezeigt; Root kann sie anzeigen.)
            Aktive Internetverbindungen (Server und stehende Verbindungen)
            Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      -
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42790         TIME_WAIT   -
            Der Port 9001 steht so mehrfach mit anderem Foreign-Port drin.
            Edit:
            netstat als ROOT aufgerufen:
            pi@raspberrypi01:~ $ sudo netstat -n -a -p TCP
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      29590/iobroker.js-c
            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      547/redis-server 12
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      535/sshd
            tcp        0      0 127.0.0.1:37058         127.0.0.1:6379          TIME_WAIT   -
            tcp        0      0 127.0.0.1:9001          127.0.0.1:60324         TIME_WAIT   -
            • P Offline
              plazmatic07
              Hört sich langsam nach einem generellen Problem an.
                iobroker host this muss durchgeführt werden bevor iobroker gestartet wird.
                Das heisst natürlich auch, dass iobroker -sollte im laufenden Betrieb der Hostname geändert werden- vor der Änderung gestoppt wird.
                @plazmatic07:
                No instances found for host "this". `
                Das ist mir neu!
                Das ist unmittelbar nach aufspielen des Images passiert?
                ohne vorher Updates bei ioBroker durchzuführen?
                • P Offline
                  plazmatic07
                  Das versuche ich morgen nochmal und gebe bescheid, eventuell lief der iobroker bei der Änderung. Danke schonmal
                  • P Offline
                    plazmatic07
                    So,
                    ich habe nochmal alles durchgespielt.
                    • Aktuelles Image heruntergeladen und mit etcher aufgespielt
                    • erster Start, läuft! Admin über Web auch erreichbar
                    • Dann mal iobroker gestoppt und raps-config ausgeführt
                    • Expand filesystem
                    • Hostname geändert und Raspi-Config verlassen ohne Neustart
                    • sudo iobroker host this - Diesmal ohne Fehler!, jedoch der falsche Hostname (Sollte ioBroker-Master sein)
                    Instance host changed for "system.adapter.admin.0" from "ioBroker-RasPi" to "ioBroker-RasPi".
                    Hostname wurde aber im System geändert
                    pi@ioBroker-Master:~ $ hostname
                    ioBroker-Master
                    • Reboot
                    Danach iobroker Web nicht mehr erreichbar.
                    Admin Läuft
                    pi@ioBroker-Master:/opt/iobroker $ iobroker list instances
                    system.adapter.cloud.0                 : cloud       - disabled
                    system.adapter.discovery.0             : discovery   -  enabled
                    system.adapter.flot.0                  : flot        -  enabled
                    system.adapter.history.0               : history     -  enabled
                    system.adapter.hm-rega.0               : hm-rega     - disabled
                    system.adapter.hm-rpc.0                : hm-rpc      - disabled, port: 0
                    system.adapter.javascript.0            : javascript  -  enabled
                    system.adapter.mobile.0                : mobile      - disabled
                    system.adapter.rpi2.0                  : rpi2        -  enabled
                    system.adapter.socketio.0              : socketio    -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    system.adapter.vis.0                   : vis         -  enabled
                    system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      Das muss ich mir mal in einer ruhigen Minute nachvollziehen.
                      Der Hostname wird ja nicht direkt im System geändert/angewandt (sieht man am Prompt)!
                      Das geschieht erst nach einem reboot.
                      Dann arbeitet iobroker host this natürlich (?) noch mit dem alten Namen.
                      Nach einem restart startet iobroker natürlich bereits das erste mal.
                      … und jetzt brauch ich Zeit fürs Hirn ;-)
                      • wendy2702W Online
                        wendy2702W Online
                        @plazmatic07:
                        • Hostname geändert und Raspi-Config verlassen ohne Neustart `
                        Meine mich erinnern zu können das der Neustart erforderlich ist damit der geänderte Hostname verwendet und nicht nur angezeigt wird.
                        6\. Hostname ändern (optional)
                        Der Hostname legt fest, unter welchem Computernamen der Raspberry Pi im Netzwerk erreichbar ist. Standardmäßig hat ein frisches Raspbian den Hostnamen "raspberrypi". Das möchte man vielleicht ändern. Zum Beispiel dann, wenn man mehrere betreibt. Dann möchte man sie vielleicht vom Namen her unterscheiden.
                            Menü-Reihenfolge in Deutsch: Einstellungen / Raspberry-Pi-Konfiguration / System / Hostname / OK
                            Menü-Reihenfolge in Englisch: Preferences / Raspberry Pi Configuration / System / Hostname / OK
                        Der neue Hostname kann in das Textfeld mit dem vorgegebenen Namen eingetragen werden. Er wird mit einem Klick auf "OK" gespeichert, aber erst bei einem Neustart übernommen.
                        Wenn man es manuell machen möchte:
                        sudo hostname -b {NEUER_NAME}
                        Danach kurz prüfen:
                        hostname
                        Hinweis: Es empfiehlt sich, den Hostnamen über das Raspberry-Pi-Konfigurationstool zu ändern.
                        • P Offline
                          plazmatic07
                          Okay, habe ich eben nochmal versucht und folgende Schritte durchgeführt:
                          • Vorbereitungen wie oben beschrieben
                          • Dann iobroker gestoppt und raps-config ausgeführt
                          • Expand filesystem
                          • Hostname geändert und Raspi-Config verlassen MIT Neustart
                          <u>Danach:</u>
                          pi@ioBroker-Master:/opt/iobroker $ hostname
                          ioBroker-Master
                          pi@ioBroker-Master:/opt/iobroker $ sudo iobroker stop
                          Stopping iobroker controller daemon...
                          iobroker controller daemon stopped.
                          Exit code for "killall.sh": 123
                          Diesmal hatte sich kurz die Admin Seite öffnen lassen oben bei Host wird nichts angezeigt
                          ~~![](</s><URL url=)<link_text text="https://image.ibb.co/md1z7o/Bildschirmf ... _33_30.png">https://image.ibb.co/md1z7o/Bildschirmfoto_2018_06_06_um_20_33_30.png</link_text>" />
                          Nach 1sek wieder spinnig wheel.
                          Also wenn der Befehl sudo iobroker host this einfach nicht funktioniert, wie kann ich iobroker den geänderten Hostnamen beibringen.
                          Grüße und Danke~~
                          • wendy2702W Online
                            wendy2702W Online
                            Also ich habe das mal erfolgreich gemacht… weiß aber nicht ob ich das Logfile davon noch habe und wenn ist das knappe 500km entfernt.
                            Ich mache mir mal ne Erinnerung und suche am WE danach.
                              mhund
                              Zusammenfassend sieht es für mich so aus, als ob es bisher niemand eindeutig geschafft hat mit diesem Image eine Installation zu erzeugen, bei der man anschließend erfolgreich den Hostnamen ändern konnte. Diejenigen, die das Image erfolgreich nutzen, haben den Hostnamen einfach nicht geändert (so wie ich im Moment). Diejenigen, die den Hostnamen erfolgreich geändert haben, nutzen vermutlich nicht das Image sondern haben eine manuelle Installation vorgenommen. Liege ich richtig oder gibt es einen Gegenbeweis?
                                @mhund:
                                Zusammenfassend sieht es für mich so aus… `
                                Wenn man bedenkt, dass sich hier, wie in allen Foren, nur die zu Wort melden, die Probleme haben ist das mal wieder ein vollkommen verzerrtes Bild.
                                Von dem Image sind bis jetzt 3058 Downloads gezählt und eine Handvoll User hat Probleme.
                                @mhund:
                                Diejenigen, die das Image erfolgreich nutzen, haben den Hostnamen einfach nicht geändert `
                                eine mutige Behauptung.
                                @mhund:
                                Liege ich richtig oder gibt es einen Gegenbeweis? `
                                Nichts ist unmöglich, aber es gibt auch keinen Beweis, dass das Problem wirklich bei allen Usern auftritt.
                                Ich habe nur keine Ahnung warum das bei der Handvoll User so ist.
                                  mhund
                                  Natürlich alles Mutmassungen. Da hast du Recht. Ich versuche nur herauszuarbeiten, ob es ein Bedienfehler ist (was ich hoffe) oder ein Fehler im Image. Wenn sich EINER meldet, der das Image nutzt und den Hostnamen erfolgreich geändert hat, wissen wir besser wo wir suchen müssen.
                                    mrburns
                                    bin seit Kurzem auch Besitzer eines RasPi 3B+ und habe das image com 14.04.2018 über etcher installiert.
                                    Habe dieselben Probleme, kann ioBroker nur verwednen, wenn ich den Hostnamen nicht ändere.
                                    Habe das auch in einem Thread erzählt (viewtopic.php?f=17&t=14795&p=154687#p154687).
                                    Werde das aber jetzt hier weiter verfolgen.
                                    Dazu Frage, ich habe ja bisher einige Einstellungen in ioBroker vorgenommen. Kann man irgendwie eine Art Backup von ioBroker machen, so dass man, wenn man ein neues Image auf die SD-Karte zieht diese Einstellungen wieder laden kann? Sonst muss man ja alles wieder von vorne machen.
                                    Danke…
                                      @mrburns:
                                      Kann man irgendwie eine Art Backup von ioBroker machen `
                                      klar doch!
                                      Das soll man sogar regelmäßig.
                                      Infos dazu gibt es http://www.iobroker.net/docu/?page_id=2380&lang=de und mehrfach im Forum, z.B. https://forum.iobroker.net/viewtopic.php?f=17&t=13487&p=153492&hilit=backups+pc#p153492.
                                      • J Offline
                                        JoeXXL
                                        Moinsen,
                                        hatte das gleiche Problem - und so gelöst:
                                        Als root mit Putty angemeldet , dann :
                                        iobroker stop
                                        npm cache clean --force
                                        npm install iobroker.js-controller --production
                                        iobroker host this
                                        npm install -g npm@4
                                        iobroker start
                                        Nun läuft es mit geändertem hostname.
                                        -Joe
                                        • StabilostickS Offline
                                          Stabilostick
                                          Vorher schauen, ob überhaupt ein neues npm notwendig ist. Aktuell nur wenn
                                          npm -v
                                          eine Version > 5 ausgibt.
                                          Dann diese Sequenz:
                                          iobroker stop
                                          iobroker host this
                                          iobroker start
