  3. Entwicklung
  4. Wichtige Änderung: Objekt/State-ID-Bezeichner dürfen keine *, ? [, ], " oder ' mehr enthalten
83 Beiträge 23 Kommentatoren 169.9k Aufrufe 1 Beobachtet
  • TomTT Offline
    TomTT Offline
    TomT
    javascript.0	2018-05-17 12:36:23.746	info	script.js.Skript1: Found 6 problems
    javascript.0	2018-05-17 12:36:23.745	info	script.js.Skript1: Checked 1518 devices, 1662 channels, 1849 states
    javascript.0	2018-05-17 12:36:23.742	warn	Object "web.0.connected" does not exist
    javascript.0	2018-05-17 12:36:23.679	warn	Object "tankerkoenig.0.stations.8.e10.combined" does not exist
    javascript.0	2018-05-17 12:36:23.490	warn	Object "system.adapter.vis.0.uptime" does not exist
    javascript.0	2018-05-17 12:36:23.487	warn	Object "system.adapter.vis.0.outputCount" does not exist
    javascript.0	2018-05-17 12:36:23.480	warn	Object "system.adapter.vis.0.memRss" does not exist
    javascript.0	2018-05-17 12:36:23.477	warn	Object "system.adapter.vis.0.memHeapUsed" does not exist
    javascript.0	2018-05-17 12:36:23.470	warn	Object "system.adapter.vis.0.memHeapTotal" does not exist
    javascript.0	2018-05-17 12:36:23.465	warn	Object "system.adapter.vis.0.inputCount" does not exist
    javascript.0	2018-05-17 12:36:23.460	warn	Object "system.adapter.vis.0.connected" does not exist
    javascript.0	2018-05-17 12:36:23.455	warn	Object "system.adapter.vis.0.alive" does not exist
    javascript.0	2018-05-17 12:36:23.446	info	script.js.Skript1: Checking.... 200 left
    javascript.0	2018-05-17 12:36:23.175	warn	Object "socketio.0.connected" does not exist
    javascript.0	2018-05-17 12:36:23.139	info	script.js.Skript1: Checking.... 400 left
    javascript.0	2018-05-17 12:36:22.822	info	script.js.Skript1: Checking.... 600 left
    javascript.0	2018-05-17 12:36:22.505	info	script.js.Skript1: Checking.... 800 left
    javascript.0	2018-05-17 12:36:22.197	info	script.js.Skript1: Checking.... 1000 left
    javascript.0	2018-05-17 12:36:21.896	info	script.js.Skript1: Checking.... 1200 left
    javascript.0	2018-05-17 12:36:21.634	info	script.js.Skript1: Checking.... 1400 left
    javascript.0	2018-05-17 12:36:21.564	warn	Object "hm-rpc.0.CENTRAL.PONG" does not exist
    javascript.0	2018-05-17 12:36:21.342	warn	script.js.Skript1: Invalid ID: hm-rpc.0.*LEQ0229115.1.STATE
    javascript.0	2018-05-17 12:36:21.340	warn	script.js.Skript1: Invalid ID: hm-rpc.0.*LEQ0229115.1.INSTALL_TEST
    javascript.0	2018-05-17 12:36:21.335	info	script.js.Skript1: Checking.... 1600 left
    javascript.0	2018-05-17 12:36:21.048	info	script.js.Skript1: Checking.... 1800 left
    javascript.0	2018-05-17 12:36:20.789	info	script.js.Skript1: Checking.... 2000 left
    javascript.0	2018-05-17 12:36:20.753	warn	script.js.Skript1: Invalid ID: hm-rpc.0.*LEQ0229115.1.STATE
    javascript.0	2018-05-17 12:36:20.750	warn	script.js.Skript1: Invalid ID: hm-rpc.0.*LEQ0229115.1.INSTALL_TEST
    javascript.0	2018-05-17 12:36:20.508	info	script.js.Skript1: Checking.... 2200 left
    javascript.0	2018-05-17 12:36:20.204	info	script.js.Skript1: Checking.... 2400 left
    javascript.0	2018-05-17 12:36:19.893	info	script.js.Skript1: Checking.... 2600 left
    javascript.0	2018-05-17 12:36:19.576	info	script.js.Skript1: Checking.... 2800 left
    javascript.0	2018-05-17 12:36:19.264	info	script.js.Skript1: Checking.... 3000 left
    javascript.0	2018-05-17 12:36:18.962	info	script.js.Skript1: Checking.... 3200 left
    javascript.0	2018-05-17 12:36:18.638	info	script.js.Skript1: Checking.... 3400 left
    javascript.0	2018-05-17 12:36:18.318	info	script.js.Skript1: Checking.... 3600 left
    javascript.0	2018-05-17 12:36:18.218	warn	script.js.Skript1: Invalid ID: hm-rpc.0.*LEQ0229115.1.STATE
    javascript.0	2018-05-17 12:36:18.212	warn	script.js.Skript1: Invalid ID: hm-rpc.0.*LEQ0229115.1.INSTALL_TEST
    javascript.0	2018-05-17 12:36:17.965	info	script.js.Skript1: Checking.... 3800 left
    javascript.0	2018-05-17 12:36:17.708	info	script.js.Skript1: Checking.... 4000 left
    javascript.0	2018-05-17 12:36:17.402	info	script.js.Skript1: Checking.... 4200 left
    javascript.0	2018-05-17 12:36:17.140	info	script.js.Skript1: Checking.... 4400 left
    javascript.0	2018-05-17 12:36:16.854	info	script.js.Skript1: Checking.... 4600 left
    javascript.0	2018-05-17 12:36:16.552	info	script.js.Skript1: Checking.... 4800 left
    javascript.0	2018-05-17 12:36:16.287	info	script.js.Skript1: Checking.... 5000 left
    javascript.0	2018-05-17 12:36:16.243	info	script.js.Skript1: registered 0 subscriptions and 0 schedules
    javascript.0	2018-05-17 12:36:16.082	info	Start javascript script.js.Skript1
    Ist das Alarmteam der Rauchmelder, was da Warnung ausgibt.
    Kann man das einfach so umbenennen, daß das * weggelöscht wird, oder was muss man da tun?
    Tom
    PI3B > Raspimatic / Opi+2 > ioBroker / ESP8266
    if (System == "running") {finger = "weg";} else {lastAction = "Rückgängig";}
    • apollon77A Offline
      @TomT:
      Kann man das einfach so umbenennen, daß das * weggelöscht wird, oder was muss man da tun? `
      Die Adapter müssen das fixen. Wir sammeln gerade alle relevante Fälle das wir wissen was getan werden muss
      • TomTT Offline
        TomTT Offline
        TomT
        Ok :-)
        Dann warte ich ab, was ihr da so schönes zaubert ;)
        Danke für die schnelle Info
        Tom
        • P Offline
          Pman
          Könnte man das nicht auch global im js-controller lösen, so dass get/set state/object alle ungewollten Zeichen durch z.B. "_" ersetzen?
          In etwa so:
          setState("foo*bar") -> setState("foo_bar")
          getState("foo*bar") -> getState("foo_bar")
          Zusätzlich könnte bei setObject noch z. B. ein obj.native.replacedName = 'foo*bar' eingefügt werden.
          Es besteht natürlich ein gewisses Kollisionsrisiko, das dürfte aber geringer sein, als unkorrekte Ids in irgendeinem Adapter.
          EDIT:
          Zusätzlich oder alternativ wäre eine vorgegebene Bereinigungs-Funktion gut, die man im Adapter nutzen kann.
            soetwas hatten wir überlegt. Für einfache Adapter die nur Werte schreiben ist das simpel. Sobald der Adapter aber auch auf State-Änderungen reagiert müsste man hier das ganze auch wieder "zurückrechnen". Und am Ende wäre es "magie" die trotzdem jeder Adapterentwickler wissen und beachten muss weil es sonst, wie Du korrekt sagst, zu Kollisionen kommen kann.
            Auch weil die Anzahl der Adapter (aktuell 5 von ca. 200+) die laut aktuellen Erkenntnissen betroffen sind eher überschaubar ist, haben wir uns entschieden es nicht zentral zu lösen. So ist jeder Adapterentwickler unabhängig und kann es so lösen wie er es für Sinn voll hält.
            Ich hatte überlegt das man durchaus eine "Regex zum Ersetzen" als EIgenschaft der Adapter-Instanz zur Verfügung stellen kann, sodass dies jeder, wenn er will, nutzen kann für seine Ersetzungen.
            Bereinigung ist auch so ein Thema. Ggf hängen an den Alten Datenpunkten noch Statistikdaten die verloren gehen würden wenn wir die einfach wegwerfen. Von daher auch hier eher der manuelle Weg das der User aufräumt oder der Adapternetwickler entscheidet das er aufräumt. Für SMartmeter plane ich als Beispiel einen check bei den relevanten States der beim neuanlegen der "Korrigierten" die History-Einstellungen von den States mit "+" überimmt …
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              @apollon77:
              Log-Ausgabe dann bitte posten!
              Danke `
              18:25:43.956	[warn]	javascript.0 script.js.Test_Omgeving.States: Invalid ID: zwave.0.NODE4.CONFIGURATION.Wall_Plug's_response_to_alarm_frames
              18:25:44.072	[warn]	javascript.0 script.js.Test_Omgeving.States: Invalid ID: zwave.0.NODE3.CONFIGURATION.Wall_Plug's_response_to_alarm_frames
              18:25:45.308	[warn]	javascript.0 script.js.Test_Omgeving.States: Invalid ID: zwave.0.NODE4.CONFIGURATION.Wall_Plug's_response_to_alarm_frames
              18:25:45.553	[warn]	javascript.0 script.js.Test_Omgeving.States: Invalid ID: zwave.0.NODE3.CONFIGURATION.Wall_Plug's_response_to_alarm_frames
              18:25:51.215	[warn]	javascript.0 script.js.Test_Omgeving.States: Invalid ID: zwave.0.NODE3.CONFIGURATION.Wall_Plug's_response_to_alarm_frames
              18:25:51.269	[warn]	javascript.0 script.js.Test_Omgeving.States: Invalid ID: zwave.0.NODE4.CONFIGURATION.Wall_Plug's_response_to_alarm_frames
              18:25:51.347	[info]	javascript.0 script.js.Test_Omgeving.States: Checked 1046 devices, 1174 channels, 4211 states
              18:25:51.347	[info]	javascript.0 script.js.Test_Omgeving.States: Found 6 problems
              • ruhr70R Offline
                ruhr70R Offline
                ruhr70
                @apollon77:
                Danke `
                Viel Spaß
                2018-05-17 19:19:38.600 - info: javascript.1 script.js.test: Found 231 problems
                Bei hm-ip sind Objekte auf einmal verschwunden.
                Warum andere fehlen, obwohl sie da sein müssten…
                2018-05-17 19:18:50.361 - info: javascript.1 Start javascript script.js.test
                2018-05-17 19:18:50.531 - info: javascript.1 script.js.test: registered 0 subscriptions and 0 schedules
                2018-05-17 19:18:50.659 - info: javascript.1 script.js.test: Checking.... 41200 left
                2018-05-17 19:18:50.895 - info: javascript.1 script.js.test: Checking.... 41000 left
                2018-05-17 19:18:51.128 - info: javascript.1 script.js.test: Checking.... 40800 left
                2018-05-17 19:18:51.429 - info: javascript.1 script.js.test: Checking.... 40600 left
                2018-05-17 19:18:51.658 - info: javascript.1 script.js.test: Checking.... 40400 left
                2018-05-17 19:18:51.895 - info: javascript.1 script.js.test: Checking.... 40200 left
                2018-05-17 19:18:52.124 - info: javascript.1 script.js.test: Checking.... 40000 left
                2018-05-17 19:18:52.358 - info: javascript.1 script.js.test: Checking.... 39800 left
                2018-05-17 19:18:52.593 - info: javascript.1 script.js.test: Checking.... 39600 left
                2018-05-17 19:18:52.821 - info: javascript.1 script.js.test: Checking.... 39400 left
                2018-05-17 19:18:53.047 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Roku_3.Options*
                2018-05-17 19:18:53.050 - info: javascript.1 script.js.test: Checking.... 39200 left
                2018-05-17 19:18:53.281 - info: javascript.1 script.js.test: Checking.... 39000 left
                2018-05-17 19:18:53.311 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.'
                2018-05-17 19:18:53.314 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer."
                2018-05-17 19:18:53.325 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.?
                2018-05-17 19:18:53.328 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.[
                2018-05-17 19:18:53.330 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.]
                2018-05-17 19:18:53.510 - info: javascript.1 script.js.test: Checking.... 38800 left
                2018-05-17 19:18:53.742 - info: javascript.1 script.js.test: Checking.... 38600 left
                2018-05-17 19:18:53.979 - info: javascript.1 script.js.test: Checking.... 38400 left
                2018-05-17 19:18:54.234 - info: javascript.1 script.js.test: Checking.... 38200 left
                2018-05-17 19:18:54.481 - info: javascript.1 script.js.test: Checking.... 38000 left
                2018-05-17 19:18:54.710 - info: javascript.1 script.js.test: Checking.... 37800 left
                2018-05-17 19:18:54.951 - info: javascript.1 script.js.test: Checking.... 37600 left
                2018-05-17 19:18:55.207 - info: javascript.1 script.js.test: Checking.... 37400 left
                2018-05-17 19:18:55.441 - info: javascript.1 script.js.test: Checking.... 37200 left
                2018-05-17 19:18:55.665 - info: javascript.1 script.js.test: Checking.... 37000 left
                2018-05-17 19:18:55.900 - info: javascript.1 script.js.test: Checking.... 36800 left
                2018-05-17 19:18:56.172 - info: javascript.1 script.js.test: Checking.... 36600 left
                2018-05-17 19:18:56.400 - info: javascript.1 script.js.test: Checking.... 36400 left
                2018-05-17 19:18:56.627 - info: javascript.1 script.js.test: Checking.... 36200 left
                2018-05-17 19:18:56.858 - info: javascript.1 script.js.test: Checking.... 36000 left
                2018-05-17 19:18:57.085 - info: javascript.1 script.js.test: Checking.... 35800 left
                2018-05-17 19:18:57.318 - info: javascript.1 script.js.test: Checking.... 35600 left
                2018-05-17 19:18:57.546 - info: javascript.1 script.js.test: Checking.... 35400 left
                2018-05-17 19:18:57.774 - info: javascript.1 script.js.test: Checking.... 35200 left
                2018-05-17 19:18:58.005 - info: javascript.1 script.js.test: Checking.... 35000 left
                2018-05-17 19:18:58.233 - info: javascript.1 script.js.test: Checking.... 34800 left
                2018-05-17 19:18:58.469 - info: javascript.1 script.js.test: Checking.... 34600 left
                2018-05-17 19:18:58.705 - info: javascript.1 script.js.test: Checking.... 34400 left
                2018-05-17 19:18:58.939 - info: javascript.1 script.js.test: Checking.... 34200 left
                2018-05-17 19:18:59.167 - info: javascript.1 script.js.test: Checking.... 34000 left
                2018-05-17 19:18:59.396 - info: javascript.1 script.js.test: Checking.... 33800 left
                2018-05-17 19:18:59.635 - info: javascript.1 script.js.test: Checking.... 33600 left
                2018-05-17 19:18:59.873 - info: javascript.1 script.js.test: Checking.... 33400 left
                2018-05-17 19:19:00.113 - info: javascript.1 script.js.test: Checking.... 33200 left
                2018-05-17 19:19:00.345 - info: javascript.1 script.js.test: Checking.... 33000 left
                2018-05-17 19:19:00.578 - info: javascript.1 script.js.test: Checking.... 32800 left
                2018-05-17 19:19:00.806 - info: javascript.1 script.js.test: Checking.... 32600 left
                2018-05-17 19:19:01.034 - info: javascript.1 script.js.test: Checking.... 32400 left
                2018-05-17 19:19:01.321 - info: javascript.1 script.js.test: Checking.... 32200 left
                2018-05-17 19:19:01.604 - info: javascript.1 script.js.test: Checking.... 32000 left
                2018-05-17 19:19:01.837 - info: javascript.1 script.js.test: Checking.... 31800 left
                2018-05-17 19:19:02.065 - info: javascript.1 script.js.test: Checking.... 31600 left
                2018-05-17 19:19:02.302 - info: javascript.1 script.js.test: Checking.... 31400 left
                2018-05-17 19:19:02.533 - info: javascript.1 script.js.test: Checking.... 31200 left
                2018-05-17 19:19:02.768 - info: javascript.1 script.js.test: Checking.... 31000 left
                2018-05-17 19:19:02.996 - info: javascript.1 script.js.test: Checking.... 30800 left
                2018-05-17 19:19:03.226 - info: javascript.1 script.js.test: Checking.... 30600 left
                2018-05-17 19:19:03.468 - info: javascript.1 script.js.test: Checking.... 30400 left
                2018-05-17 19:19:03.698 - info: javascript.1 script.js.test: Checking.... 30200 left
                2018-05-17 19:19:03.936 - info: javascript.1 script.js.test: Checking.... 30000 left
                2018-05-17 19:19:04.169 - info: javascript.1 script.js.test: Checking.... 29800 left
                2018-05-17 19:19:04.400 - info: javascript.1 script.js.test: Checking.... 29600 left
                2018-05-17 19:19:04.627 - info: javascript.1 script.js.test: Checking.... 29400 left
                2018-05-17 19:19:04.854 - info: javascript.1 script.js.test: Checking.... 29200 left
                2018-05-17 19:19:05.081 - info: javascript.1 script.js.test: Checking.... 29000 left
                2018-05-17 19:19:05.310 - info: javascript.1 script.js.test: Checking.... 28800 left
                2018-05-17 19:19:05.541 - info: javascript.1 script.js.test: Checking.... 28600 left
                2018-05-17 19:19:05.770 - info: javascript.1 script.js.test: Checking.... 28400 left
                2018-05-17 19:19:05.787 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Roku_3.Options*
                2018-05-17 19:19:06.006 - info: javascript.1 script.js.test: Checking.... 28200 left
                2018-05-17 19:19:06.059 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.'
                2018-05-17 19:19:06.062 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer."
                2018-05-17 19:19:06.075 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.?
                2018-05-17 19:19:06.077 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.[
                2018-05-17 19:19:06.080 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.]
                2018-05-17 19:19:06.241 - info: javascript.1 script.js.test: Checking.... 28000 left
                2018-05-17 19:19:06.472 - info: javascript.1 script.js.test: Checking.... 27800 left
                2018-05-17 19:19:06.703 - info: javascript.1 script.js.test: Checking.... 27600 left
                2018-05-17 19:19:06.936 - info: javascript.1 script.js.test: Checking.... 27400 left
                2018-05-17 19:19:07.166 - info: javascript.1 script.js.test: Checking.... 27200 left
                2018-05-17 19:19:07.395 - info: javascript.1 script.js.test: Checking.... 27000 left
                2018-05-17 19:19:07.624 - info: javascript.1 script.js.test: Checking.... 26800 left
                2018-05-17 19:19:07.857 - info: javascript.1 script.js.test: Checking.... 26600 left
                2018-05-17 19:19:08.083 - info: javascript.1 script.js.test: Checking.... 26400 left
                2018-05-17 19:19:08.313 - info: javascript.1 script.js.test: Checking.... 26200 left
                2018-05-17 19:19:08.545 - info: javascript.1 script.js.test: Checking.... 26000 left
                2018-05-17 19:19:08.775 - info: javascript.1 script.js.test: Checking.... 25800 left
                2018-05-17 19:19:09.020 - info: javascript.1 script.js.test: Checking.... 25600 left
                2018-05-17 19:19:09.252 - info: javascript.1 script.js.test: Checking.... 25400 left
                2018-05-17 19:19:09.481 - info: javascript.1 script.js.test: Checking.... 25200 left
                2018-05-17 19:19:09.708 - info: javascript.1 script.js.test: Checking.... 25000 left
                2018-05-17 19:19:09.940 - info: javascript.1 script.js.test: Checking.... 24800 left
                2018-05-17 19:19:10.169 - info: javascript.1 script.js.test: Checking.... 24600 left
                2018-05-17 19:19:10.407 - info: javascript.1 script.js.test: Checking.... 24400 left
                2018-05-17 19:19:10.637 - info: javascript.1 script.js.test: Checking.... 24200 left
                2018-05-17 19:19:10.868 - info: javascript.1 script.js.test: Checking.... 24000 left
                2018-05-17 19:19:11.096 - info: javascript.1 script.js.test: Checking.... 23800 left
                2018-05-17 19:19:11.322 - info: javascript.1 script.js.test: Checking.... 23600 left
                2018-05-17 19:19:11.550 - info: javascript.1 script.js.test: Checking.... 23400 left
                2018-05-17 19:19:11.778 - info: javascript.1 script.js.test: Checking.... 23200 left
                2018-05-17 19:19:12.016 - info: javascript.1 script.js.test: Checking.... 23000 left
                2018-05-17 19:19:12.246 - info: javascript.1 script.js.test: Checking.... 22800 left
                2018-05-17 19:19:12.476 - info: javascript.1 script.js.test: Checking.... 22600 left
                2018-05-17 19:19:12.707 - info: javascript.1 script.js.test: Checking.... 22400 left
                2018-05-17 19:19:12.944 - info: javascript.1 script.js.test: Checking.... 22200 left
                2018-05-17 19:19:13.177 - info: javascript.1 script.js.test: Checking.... 22000 left
                2018-05-17 19:19:13.418 - info: javascript.1 script.js.test: Checking.... 21800 left
                2018-05-17 19:19:13.649 - info: javascript.1 script.js.test: Checking.... 21600 left
                2018-05-17 19:19:13.876 - info: javascript.1 script.js.test: Checking.... 21400 left
                2018-05-17 19:19:14.105 - info: javascript.1 script.js.test: Checking.... 21200 left
                2018-05-17 19:19:14.333 - info: javascript.1 script.js.test: Checking.... 21000 left
                2018-05-17 19:19:14.560 - info: javascript.1 script.js.test: Checking.... 20800 left
                2018-05-17 19:19:14.789 - info: javascript.1 script.js.test: Checking.... 20600 left
                2018-05-17 19:19:15.016 - info: javascript.1 script.js.test: Checking.... 20400 left
                2018-05-17 19:19:15.243 - info: javascript.1 script.js.test: Checking.... 20200 left
                2018-05-17 19:19:15.474 - info: javascript.1 script.js.test: Checking.... 20000 left
                2018-05-17 19:19:15.700 - info: javascript.1 script.js.test: Checking.... 19800 left
                2018-05-17 19:19:15.930 - info: javascript.1 script.js.test: Checking.... 19600 left
                2018-05-17 19:19:16.165 - info: javascript.1 script.js.test: Checking.... 19400 left
                2018-05-17 19:19:16.397 - info: javascript.1 script.js.test: Checking.... 19200 left
                2018-05-17 19:19:16.626 - info: javascript.1 script.js.test: Checking.... 19000 left
                2018-05-17 19:19:16.855 - info: javascript.1 script.js.test: Checking.... 18800 left
                2018-05-17 19:19:17.081 - info: javascript.1 script.js.test: Checking.... 18600 left
                2018-05-17 19:19:17.312 - info: javascript.1 script.js.test: Checking.... 18400 left
                2018-05-17 19:19:17.542 - info: javascript.1 script.js.test: Checking.... 18200 left
                2018-05-17 19:19:17.565 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer."
                2018-05-17 19:19:17.570 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.'
                2018-05-17 19:19:17.582 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.?
                2018-05-17 19:19:17.702 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.[
                2018-05-17 19:19:17.704 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Mac-Computer.]
                2018-05-17 19:19:17.773 - info: javascript.1 script.js.test: Checking.... 18000 left
                2018-05-17 19:19:17.861 - warn: javascript.1 script.js.test: Invalid ID: harmony.0.Harmony_Hub.Roku_3.Options*
                2018-05-17 19:19:17.999 - info: javascript.1 script.js.test: Checking.... 17800 left
                2018-05-17 19:19:18.229 - info: javascript.1 script.js.test: Checking.... 17600 left
                2018-05-17 19:19:18.231 - warn: javascript.1 Object "hm-rpc.1.0000D3C9905FFD.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.232 - warn: javascript.1 Object "hm-rpc.1.0000D3C9905FFD.0.LOW_BAT_ALARM" does not exist
                2018-05-17 19:19:18.234 - warn: javascript.1 Object "hm-rpc.1.0000D3C9905FFD.0.SABOTAGE_ALARM" does not exist
                2018-05-17 19:19:18.235 - warn: javascript.1 Object "hm-rpc.1.0000D3C9905FFD.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.236 - warn: javascript.1 Object "hm-rpc.1.000313C9906D6B.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.237 - warn: javascript.1 Object "hm-rpc.1.000313C9906D6B.0.LOW_BAT_ALARM" does not exist
                2018-05-17 19:19:18.240 - warn: javascript.1 Object "hm-rpc.1.000C17099A020B.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.241 - warn: javascript.1 Object "hm-rpc.1.000C17099A020B.0.LOW_BAT_ALARM" does not exist
                2018-05-17 19:19:18.242 - warn: javascript.1 Object "hm-rpc.1.000C17099A020B.0.SABOTAGE_ALARM" does not exist
                2018-05-17 19:19:18.243 - warn: javascript.1 Object "hm-rpc.1.000C17099A020B.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.246 - warn: javascript.1 Object "hm-rpc.1.000C5709AE6A68.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.247 - warn: javascript.1 Object "hm-rpc.1.000C5709AE6A68.0.LOW_BAT_ALARM" does not exist
                2018-05-17 19:19:18.248 - warn: javascript.1 Object "hm-rpc.1.000C5709AE6A68.0.SABOTAGE_ALARM" does not exist
                2018-05-17 19:19:18.249 - warn: javascript.1 Object "hm-rpc.1.000C5709AE6A68.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.429 - warn: javascript.1 Object "hm-rpc.1.CENTRAL.PONG" does not exist
                2018-05-17 19:19:18.432 - warn: javascript.1 Object "hm-rpc.1.FEQ0039183.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.434 - warn: javascript.1 Object "hm-rpc.1.FEQ0039183.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.439 - warn: javascript.1 Object "hm-rpc.1.FEQ0039183.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.441 - warn: javascript.1 Object "hm-rpc.1.FEQ0039183.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.447 - warn: javascript.1 Object "hm-rpc.1.FEQ0052402.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.450 - warn: javascript.1 Object "hm-rpc.1.FEQ0052402.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.455 - warn: javascript.1 Object "hm-rpc.1.FEQ0052402.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.466 - info: javascript.1 script.js.test: Checking.... 17400 left
                2018-05-17 19:19:18.484 - warn: javascript.1 Object "hm-rpc.1.FEQ0060867.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.487 - warn: javascript.1 Object "hm-rpc.1.FEQ0060867.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:18.488 - warn: javascript.1 Object "hm-rpc.1.FEQ0060867.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.493 - warn: javascript.1 Object "hm-rpc.1.FEQ0060867.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.495 - warn: javascript.1 Object "hm-rpc.1.FEQ0060867.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.510 - warn: javascript.1 Object "hm-rpc.1.FEQ0081297.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.513 - warn: javascript.1 Object "hm-rpc.1.FEQ0081297.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.517 - warn: javascript.1 Object "hm-rpc.1.FEQ0081297.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.520 - warn: javascript.1 Object "hm-rpc.1.FEQ0081297.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.641 - warn: javascript.1 Object "hm-rpc.1.FEQ0081501.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.643 - warn: javascript.1 Object "hm-rpc.1.FEQ0081501.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.648 - warn: javascript.1 Object "hm-rpc.1.FEQ0081501.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.651 - warn: javascript.1 Object "hm-rpc.1.FEQ0081501.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.675 - warn: javascript.1 Object "hm-rpc.1.FEQ0081718.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.675 - warn: javascript.1 Object "hm-rpc.1.FEQ0081718.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:18.676 - warn: javascript.1 Object "hm-rpc.1.FEQ0081718.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.679 - warn: javascript.1 Object "hm-rpc.1.FEQ0081718.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.681 - warn: javascript.1 Object "hm-rpc.1.FEQ0081718.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.690 - warn: javascript.1 Object "hm-rpc.1.GEQ0003759.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.694 - info: javascript.1 script.js.test: Checking.... 17200 left
                2018-05-17 19:19:18.694 - warn: javascript.1 Object "hm-rpc.1.GEQ0003759.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.699 - warn: javascript.1 Object "hm-rpc.1.GEQ0003759.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.701 - warn: javascript.1 Object "hm-rpc.1.GEQ0003759.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.705 - warn: javascript.1 Object "hm-rpc.1.GEQ0003759.1.ERROR-1_ALARM" does not exist
                2018-05-17 19:19:18.706 - warn: javascript.1 Object "hm-rpc.1.GEQ0003759.1.ERROR-2_ALARM" does not exist
                2018-05-17 19:19:18.707 - warn: javascript.1 Object "hm-rpc.1.GEQ0003759.1.ERROR-3_ALARM" does not exist
                2018-05-17 19:19:18.708 - warn: javascript.1 Object "hm-rpc.1.GEQ0003759.1.ERROR-4_ALARM" does not exist
                2018-05-17 19:19:18.710 - warn: javascript.1 Object "hm-rpc.1.GEQ0003759.1.ERROR-5_ALARM" does not exist
                2018-05-17 19:19:18.711 - warn: javascript.1 Object "hm-rpc.1.GEQ0003759.1.ERROR-6_ALARM" does not exist
                2018-05-17 19:19:18.712 - warn: javascript.1 Object "hm-rpc.1.GEQ0003759.1.ERROR-7_ALARM" does not exist
                2018-05-17 19:19:18.718 - warn: javascript.1 Object "hm-rpc.1.GEQ0008383.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.721 - warn: javascript.1 Object "hm-rpc.1.GEQ0008383.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.726 - warn: javascript.1 Object "hm-rpc.1.GEQ0008383.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.728 - warn: javascript.1 Object "hm-rpc.1.GEQ0008383.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.732 - warn: javascript.1 Object "hm-rpc.1.GEQ0008383.1.ERROR-1_ALARM" does not exist
                2018-05-17 19:19:18.733 - warn: javascript.1 Object "hm-rpc.1.GEQ0008383.1.ERROR-2_ALARM" does not exist
                2018-05-17 19:19:18.734 - warn: javascript.1 Object "hm-rpc.1.GEQ0008383.1.ERROR-3_ALARM" does not exist
                2018-05-17 19:19:18.736 - warn: javascript.1 Object "hm-rpc.1.GEQ0008383.1.ERROR-4_ALARM" does not exist
                2018-05-17 19:19:18.737 - warn: javascript.1 Object "hm-rpc.1.GEQ0008383.1.ERROR-5_ALARM" does not exist
                2018-05-17 19:19:18.738 - warn: javascript.1 Object "hm-rpc.1.GEQ0008383.1.ERROR-6_ALARM" does not exist
                2018-05-17 19:19:18.740 - warn: javascript.1 Object "hm-rpc.1.GEQ0008383.1.ERROR-7_ALARM" does not exist
                2018-05-17 19:19:18.745 - warn: javascript.1 Object "hm-rpc.1.GEQ0044946.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.747 - warn: javascript.1 Object "hm-rpc.1.GEQ0044946.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:18.750 - warn: javascript.1 Object "hm-rpc.1.GEQ0044946.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.755 - warn: javascript.1 Object "hm-rpc.1.GEQ0044946.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.757 - warn: javascript.1 Object "hm-rpc.1.GEQ0044946.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.767 - warn: javascript.1 Object "hm-rpc.1.GEQ0045058.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.769 - warn: javascript.1 Object "hm-rpc.1.GEQ0045058.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:18.771 - warn: javascript.1 Object "hm-rpc.1.GEQ0045058.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.776 - warn: javascript.1 Object "hm-rpc.1.GEQ0045058.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.779 - warn: javascript.1 Object "hm-rpc.1.GEQ0045058.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.787 - warn: javascript.1 Object "hm-rpc.1.GEQ0071478.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.789 - warn: javascript.1 Object "hm-rpc.1.GEQ0071478.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.794 - warn: javascript.1 Object "hm-rpc.1.GEQ0071478.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.796 - warn: javascript.1 Object "hm-rpc.1.GEQ0071478.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.801 - warn: javascript.1 Object "hm-rpc.1.GEQ0071605.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.803 - warn: javascript.1 Object "hm-rpc.1.GEQ0071605.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.808 - warn: javascript.1 Object "hm-rpc.1.GEQ0071605.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.810 - warn: javascript.1 Object "hm-rpc.1.GEQ0071605.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.818 - warn: javascript.1 Object "hm-rpc.1.GEQ0132484.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.820 - warn: javascript.1 Object "hm-rpc.1.GEQ0132484.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:18.822 - warn: javascript.1 Object "hm-rpc.1.GEQ0132484.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.827 - warn: javascript.1 Object "hm-rpc.1.GEQ0132484.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.830 - warn: javascript.1 Object "hm-rpc.1.GEQ0132484.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.839 - warn: javascript.1 Object "hm-rpc.1.GEQ0132764.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.841 - warn: javascript.1 Object "hm-rpc.1.GEQ0132764.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:18.843 - warn: javascript.1 Object "hm-rpc.1.GEQ0132764.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.848 - warn: javascript.1 Object "hm-rpc.1.GEQ0132764.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.850 - warn: javascript.1 Object "hm-rpc.1.GEQ0132764.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.866 - warn: javascript.1 Object "hm-rpc.1.GEQ0133143.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.868 - warn: javascript.1 Object "hm-rpc.1.GEQ0133143.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:18.873 - warn: javascript.1 Object "hm-rpc.1.GEQ0133143.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.876 - warn: javascript.1 Object "hm-rpc.1.GEQ0133143.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.887 - warn: javascript.1 Object "hm-rpc.1.GEQ0133240.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.890 - warn: javascript.1 Object "hm-rpc.1.GEQ0133240.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:18.894 - warn: javascript.1 Object "hm-rpc.1.GEQ0133240.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.897 - warn: javascript.1 Object "hm-rpc.1.GEQ0133240.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.907 - warn: javascript.1 Object "hm-rpc.1.GEQ0285823.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:18.909 - warn: javascript.1 Object "hm-rpc.1.GEQ0285823.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:18.914 - warn: javascript.1 Object "hm-rpc.1.GEQ0285823.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.915 - warn: javascript.1 Object "hm-rpc.1.GEQ0285823.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:18.932 - info: javascript.1 script.js.test: Checking.... 17000 left
                2018-05-17 19:19:19.035 - warn: javascript.1 Object "hm-rpc.1.HEQ0407783.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.037 - warn: javascript.1 Object "hm-rpc.1.HEQ0407783.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:19.040 - warn: javascript.1 Object "hm-rpc.1.HEQ0407783.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.044 - warn: javascript.1 Object "hm-rpc.1.HEQ0407783.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.047 - warn: javascript.1 Object "hm-rpc.1.HEQ0407783.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.062 - warn: javascript.1 Object "hm-rpc.1.HEQ0408145.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.064 - warn: javascript.1 Object "hm-rpc.1.HEQ0408145.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:19.066 - warn: javascript.1 Object "hm-rpc.1.HEQ0408145.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.071 - warn: javascript.1 Object "hm-rpc.1.HEQ0408145.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.073 - warn: javascript.1 Object "hm-rpc.1.HEQ0408145.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.091 - warn: javascript.1 Object "hm-rpc.1.IEQ0059002.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.094 - warn: javascript.1 Object "hm-rpc.1.IEQ0059002.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.099 - warn: javascript.1 Object "hm-rpc.1.IEQ0059002.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.102 - warn: javascript.1 Object "hm-rpc.1.IEQ0059002.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.105 - warn: javascript.1 Object "hm-rpc.1.IEQ0059002.1.ERROR-1_ALARM" does not exist
                2018-05-17 19:19:19.106 - warn: javascript.1 Object "hm-rpc.1.IEQ0059002.1.ERROR-2_ALARM" does not exist
                2018-05-17 19:19:19.108 - warn: javascript.1 Object "hm-rpc.1.IEQ0059002.1.ERROR-3_ALARM" does not exist
                2018-05-17 19:19:19.108 - warn: javascript.1 Object "hm-rpc.1.IEQ0059002.1.ERROR-4_ALARM" does not exist
                2018-05-17 19:19:19.110 - warn: javascript.1 Object "hm-rpc.1.IEQ0059002.1.ERROR-5_ALARM" does not exist
                2018-05-17 19:19:19.111 - warn: javascript.1 Object "hm-rpc.1.IEQ0059002.1.ERROR-6_ALARM" does not exist
                2018-05-17 19:19:19.111 - warn: javascript.1 Object "hm-rpc.1.IEQ0059002.1.ERROR-7_ALARM" does not exist
                2018-05-17 19:19:19.118 - warn: javascript.1 Object "hm-rpc.1.IEQ0060023.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.121 - warn: javascript.1 Object "hm-rpc.1.IEQ0060023.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.125 - warn: javascript.1 Object "hm-rpc.1.IEQ0060023.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.127 - warn: javascript.1 Object "hm-rpc.1.IEQ0060023.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.130 - warn: javascript.1 Object "hm-rpc.1.IEQ0060023.1.ERROR-1_ALARM" does not exist
                2018-05-17 19:19:19.130 - warn: javascript.1 Object "hm-rpc.1.IEQ0060023.1.ERROR-2_ALARM" does not exist
                2018-05-17 19:19:19.132 - warn: javascript.1 Object "hm-rpc.1.IEQ0060023.1.ERROR-3_ALARM" does not exist
                2018-05-17 19:19:19.133 - warn: javascript.1 Object "hm-rpc.1.IEQ0060023.1.ERROR-4_ALARM" does not exist
                2018-05-17 19:19:19.134 - warn: javascript.1 Object "hm-rpc.1.IEQ0060023.1.ERROR-5_ALARM" does not exist
                2018-05-17 19:19:19.136 - warn: javascript.1 Object "hm-rpc.1.IEQ0060023.1.ERROR-6_ALARM" does not exist
                2018-05-17 19:19:19.136 - warn: javascript.1 Object "hm-rpc.1.IEQ0060023.1.ERROR-7_ALARM" does not exist
                2018-05-17 19:19:19.143 - warn: javascript.1 Object "hm-rpc.1.IEQ0060729.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.147 - warn: javascript.1 Object "hm-rpc.1.IEQ0060729.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.153 - warn: javascript.1 Object "hm-rpc.1.IEQ0060729.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.156 - warn: javascript.1 Object "hm-rpc.1.IEQ0060729.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.159 - warn: javascript.1 Object "hm-rpc.1.IEQ0060729.1.ERROR-1_ALARM" does not exist
                2018-05-17 19:19:19.159 - warn: javascript.1 Object "hm-rpc.1.IEQ0060729.1.ERROR-2_ALARM" does not exist
                2018-05-17 19:19:19.161 - warn: javascript.1 Object "hm-rpc.1.IEQ0060729.1.ERROR-3_ALARM" does not exist
                2018-05-17 19:19:19.162 - warn: javascript.1 Object "hm-rpc.1.IEQ0060729.1.ERROR-4_ALARM" does not exist
                2018-05-17 19:19:19.164 - warn: javascript.1 Object "hm-rpc.1.IEQ0060729.1.ERROR-5_ALARM" does not exist
                2018-05-17 19:19:19.165 - warn: javascript.1 Object "hm-rpc.1.IEQ0060729.1.ERROR-6_ALARM" does not exist
                2018-05-17 19:19:19.167 - warn: javascript.1 Object "hm-rpc.1.IEQ0060729.1.ERROR-7_ALARM" does not exist
                2018-05-17 19:19:19.172 - info: javascript.1 script.js.test: Checking.... 16800 left
                2018-05-17 19:19:19.172 - warn: javascript.1 Object "hm-rpc.1.KEQ0175649.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.175 - warn: javascript.1 Object "hm-rpc.1.KEQ0175649.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.179 - warn: javascript.1 Object "hm-rpc.1.KEQ0175649.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.180 - warn: javascript.1 Object "hm-rpc.1.KEQ0175649.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.190 - warn: javascript.1 Object "hm-rpc.1.KEQ0175954.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.191 - warn: javascript.1 Object "hm-rpc.1.KEQ0175954.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.196 - warn: javascript.1 Object "hm-rpc.1.KEQ0175954.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.199 - warn: javascript.1 Object "hm-rpc.1.KEQ0175954.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.208 - warn: javascript.1 Object "hm-rpc.1.KEQ0175977.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.211 - warn: javascript.1 Object "hm-rpc.1.KEQ0175977.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.216 - warn: javascript.1 Object "hm-rpc.1.KEQ0175977.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.217 - warn: javascript.1 Object "hm-rpc.1.KEQ0175977.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.227 - warn: javascript.1 Object "hm-rpc.1.KEQ0850896.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.228 - warn: javascript.1 Object "hm-rpc.1.KEQ0850896.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.233 - warn: javascript.1 Object "hm-rpc.1.KEQ0850896.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.236 - warn: javascript.1 Object "hm-rpc.1.KEQ0850896.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.241 - warn: javascript.1 Object "hm-rpc.1.KEQ0955547.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.243 - warn: javascript.1 Object "hm-rpc.1.KEQ0955547.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.248 - warn: javascript.1 Object "hm-rpc.1.KEQ0955547.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.251 - warn: javascript.1 Object "hm-rpc.1.KEQ0955547.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.253 - warn: javascript.1 Object "hm-rpc.1.KEQ0955547.1.ERROR-1_ALARM" does not exist
                2018-05-17 19:19:19.254 - warn: javascript.1 Object "hm-rpc.1.KEQ0955547.1.ERROR-2_ALARM" does not exist
                2018-05-17 19:19:19.255 - warn: javascript.1 Object "hm-rpc.1.KEQ0955547.1.ERROR-3_ALARM" does not exist
                2018-05-17 19:19:19.257 - warn: javascript.1 Object "hm-rpc.1.KEQ0955547.1.ERROR-4_ALARM" does not exist
                2018-05-17 19:19:19.257 - warn: javascript.1 Object "hm-rpc.1.KEQ0955547.1.ERROR-5_ALARM" does not exist
                2018-05-17 19:19:19.259 - warn: javascript.1 Object "hm-rpc.1.KEQ0955547.1.ERROR-6_ALARM" does not exist
                2018-05-17 19:19:19.260 - warn: javascript.1 Object "hm-rpc.1.KEQ0955547.1.ERROR-7_ALARM" does not exist
                2018-05-17 19:19:19.268 - warn: javascript.1 Object "hm-rpc.1.KEQ0956324.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.271 - warn: javascript.1 Object "hm-rpc.1.KEQ0956324.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.277 - warn: javascript.1 Object "hm-rpc.1.KEQ0956324.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.279 - warn: javascript.1 Object "hm-rpc.1.KEQ0956324.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.282 - warn: javascript.1 Object "hm-rpc.1.KEQ0956324.1.ERROR-1_ALARM" does not exist
                2018-05-17 19:19:19.284 - warn: javascript.1 Object "hm-rpc.1.KEQ0956324.1.ERROR-2_ALARM" does not exist
                2018-05-17 19:19:19.285 - warn: javascript.1 Object "hm-rpc.1.KEQ0956324.1.ERROR-3_ALARM" does not exist
                2018-05-17 19:19:19.286 - warn: javascript.1 Object "hm-rpc.1.KEQ0956324.1.ERROR-4_ALARM" does not exist
                2018-05-17 19:19:19.288 - warn: javascript.1 Object "hm-rpc.1.KEQ0956324.1.ERROR-5_ALARM" does not exist
                2018-05-17 19:19:19.288 - warn: javascript.1 Object "hm-rpc.1.KEQ0956324.1.ERROR-6_ALARM" does not exist
                2018-05-17 19:19:19.289 - warn: javascript.1 Object "hm-rpc.1.KEQ0956324.1.ERROR-7_ALARM" does not exist
                2018-05-17 19:19:19.297 - warn: javascript.1 Object "hm-rpc.1.LEQ0273778.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.298 - warn: javascript.1 Object "hm-rpc.1.LEQ0273778.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                2018-05-17 19:19:19.301 - warn: javascript.1 Object "hm-rpc.1.LEQ0273778.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:19.305 - warn: javascript.1 Object "hm-rpc.1.LEQ0273778.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.306 - warn: javascript.1 Object "hm-rpc.1.LEQ0273778.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.309 - warn: javascript.1 Object "hm-rpc.1.LEQ0273778.0.UPDATE_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.328 - warn: javascript.1 Object "hm-rpc.1.LEQ0531965.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.331 - warn: javascript.1 Object "hm-rpc.1.LEQ0531965.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                2018-05-17 19:19:19.334 - warn: javascript.1 Object "hm-rpc.1.LEQ0531965.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:19.338 - warn: javascript.1 Object "hm-rpc.1.LEQ0531965.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.340 - warn: javascript.1 Object "hm-rpc.1.LEQ0531965.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.343 - warn: javascript.1 Object "hm-rpc.1.LEQ0531965.0.UPDATE_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.361 - warn: javascript.1 Object "hm-rpc.1.LEQ0535573.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.364 - warn: javascript.1 Object "hm-rpc.1.LEQ0535573.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                2018-05-17 19:19:19.367 - warn: javascript.1 Object "hm-rpc.1.LEQ0535573.0.DUTYCYCLE_ALARM" does not exist
                2018-05-17 19:19:19.371 - warn: javascript.1 Object "hm-rpc.1.LEQ0535573.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.372 - warn: javascript.1 Object "hm-rpc.1.LEQ0535573.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.375 - warn: javascript.1 Object "hm-rpc.1.LEQ0535573.0.UPDATE_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.395 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.398 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                2018-05-17 19:19:19.402 - info: javascript.1 script.js.test: Checking.... 16600 left
                2018-05-17 19:19:19.402 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.406 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.409 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.411 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.0.UPDATE_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.415 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.1.ERROR-1_ALARM" does not exist
                2018-05-17 19:19:19.415 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.1.ERROR-2_ALARM" does not exist
                2018-05-17 19:19:19.416 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.1.ERROR-3_ALARM" does not exist
                2018-05-17 19:19:19.418 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.1.ERROR-4_ALARM" does not exist
                2018-05-17 19:19:19.418 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.1.ERROR-5_ALARM" does not exist
                2018-05-17 19:19:19.420 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.1.ERROR-6_ALARM" does not exist
                2018-05-17 19:19:19.421 - warn: javascript.1 Object "hm-rpc.1.LEQ0643551.1.ERROR-7_ALARM" does not exist
                2018-05-17 19:19:19.427 - warn: javascript.1 Object "hm-rpc.1.LEQ1072823.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.428 - warn: javascript.1 Object "hm-rpc.1.LEQ1072823.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                2018-05-17 19:19:19.432 - warn: javascript.1 Object "hm-rpc.1.LEQ1072823.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.437 - warn: javascript.1 Object "hm-rpc.1.LEQ1072823.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.440 - warn: javascript.1 Object "hm-rpc.1.LEQ1072823.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.442 - warn: javascript.1 Object "hm-rpc.1.LEQ1072823.0.UPDATE_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.477 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.478 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                2018-05-17 19:19:19.481 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.486 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.487 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.490 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.0.UPDATE_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.491 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.1.ERROR-1_ALARM" does not exist
                2018-05-17 19:19:19.493 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.1.ERROR-2_ALARM" does not exist
                2018-05-17 19:19:19.494 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.1.ERROR-3_ALARM" does not exist
                2018-05-17 19:19:19.496 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.1.ERROR-4_ALARM" does not exist
                2018-05-17 19:19:19.497 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.1.ERROR-5_ALARM" does not exist
                2018-05-17 19:19:19.497 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.1.ERROR-6_ALARM" does not exist
                2018-05-17 19:19:19.499 - warn: javascript.1 Object "hm-rpc.1.LEQ1172143.1.ERROR-7_ALARM" does not exist
                2018-05-17 19:19:19.506 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.0.CONFIG_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.508 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                2018-05-17 19:19:19.511 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.0.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.516 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.0.STICKY_UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.518 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.0.UNREACH_ALARM" does not exist
                2018-05-17 19:19:19.521 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.0.UPDATE_PENDING_ALARM" does not exist
                2018-05-17 19:19:19.523 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.1.ERROR-1_ALARM" does not exist
                2018-05-17 19:19:19.525 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.1.ERROR-2_ALARM" does not exist
                2018-05-17 19:19:19.526 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.1.ERROR-3_ALARM" does not exist
                2018-05-17 19:19:19.527 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.1.ERROR-4_ALARM" does not exist
                2018-05-17 19:19:19.529 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.1.ERROR-5_ALARM" does not exist
                2018-05-17 19:19:19.529 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.1.ERROR-6_ALARM" does not exist
                2018-05-17 19:19:19.530 - warn: javascript.1 Object "hm-rpc.1.MEQ1722911.1.ERROR-7_ALARM" does not exist
                2018-05-17 19:19:19.536 - warn: javascript.1 Object "hm-rpc.1.System.1.LOWBAT_ALARM" does not exist
                2018-05-17 19:19:19.537 - warn: javascript.1 Object "hm-rpc.1.System.1.USBH_POWERFAIL_ALARM" does not exist
                2018-05-17 19:19:19.538 - warn: javascript.1 Object "hm-rpc.1.System.1.U_SOURCE_FAIL_ALARM" does not exist
                2018-05-17 19:19:19.635 - info: javascript.1 script.js.test: Checking.... 16400 left
                2018-05-17 19:19:19.864 - info: javascript.1 script.js.test: Checking.... 16200 left
                2018-05-17 19:19:20.095 - info: javascript.1 script.js.test: Checking.... 16000 left
                2018-05-17 19:19:20.326 - info: javascript.1 script.js.test: Checking.... 15800 left
                2018-05-17 19:19:20.557 - info: javascript.1 script.js.test: Checking.... 15600 left
                2018-05-17 19:19:20.787 - info: javascript.1 script.js.test: Checking.... 15400 left
                2018-05-17 19:19:21.022 - info: javascript.1 script.js.test: Checking.... 15200 left
                2018-05-17 19:19:21.258 - info: javascript.1 script.js.test: Checking.... 15000 left
                2018-05-17 19:19:21.493 - info: javascript.1 script.js.test: Checking.... 14800 left
                2018-05-17 19:19:21.604 - warn: javascript.1 Object "javascript.1.scriptEnabled.Alexa.Alexa_Licht_an" does not exist
                2018-05-17 19:19:21.606 - warn: javascript.1 Object "javascript.1.scriptEnabled.Alexa.Alexa_LogOn" does not exist
                2018-05-17 19:19:21.606 - warn: javascript.1 Object "javascript.1.scriptEnabled.Alexa.Alexa_cURL_Kommandos" does not exist
                2018-05-17 19:19:21.608 - warn: javascript.1 Object "javascript.1.scriptEnabled.Alexa.Trigger_für_Routinen.Status_Fenster" does not exist
                2018-05-17 19:19:21.610 - warn: javascript.1 Object "javascript.1.scriptEnabled.Backup.backup_mit_vis" does not exist
                2018-05-17 19:19:21.610 - warn: javascript.1 Object "javascript.1.scriptEnabled.Daten.Feinstaub_2576" does not exist
                2018-05-17 19:19:21.612 - warn: javascript.1 Object "javascript.1.scriptEnabled.Daten.Feinstaub_6713" does not exist
                2018-05-17 19:19:21.612 - warn: javascript.1 Object "javascript.1.scriptEnabled.Daten.Lueftungsemnpfehlung" does not exist
                2018-05-17 19:19:21.614 - warn: javascript.1 Object "javascript.1.scriptEnabled.Daten.TFA_Dostmann_rasp31" does not exist
                2018-05-17 19:19:21.614 - warn: javascript.1 Object "javascript.1.scriptEnabled.Daten.Termine" does not exist
                2018-05-17 19:19:21.616 - warn: javascript.1 Object "javascript.1.scriptEnabled.Daten.Verbrauchszaehler" does not exist
                2018-05-17 19:19:21.616 - warn: javascript.1 Object "javascript.1.scriptEnabled.Daten.Verkehr_Fahrzeit_zur_Arbeit" does not exist
                2018-05-17 19:19:21.618 - warn: javascript.1 Object "javascript.1.scriptEnabled.Daten.deviceCounter" does not exist
                2018-05-17 19:19:21.620 - warn: javascript.1 Object "javascript.1.scriptEnabled.Daten.todoist" does not exist
                2018-05-17 19:19:21.621 - warn: javascript.1 Object "javascript.1.scriptEnabled.Daten.withings" does not exist
                2018-05-17 19:19:21.623 - warn: javascript.1 Object "javascript.1.scriptEnabled.Daten.withings2" does not exist
                2018-05-17 19:19:21.623 - warn: javascript.1 Object "javascript.1.scriptEnabled.Datenpunkte_anlegen.global_Var" does not exist
                2018-05-17 19:19:21.625 - warn: javascript.1 Object "javascript.1.scriptEnabled.Ereignislisten.Ereignisliste-default" does not exist
                2018-05-17 19:19:21.625 - warn: javascript.1 Object "javascript.1.scriptEnabled.Ereignisse.Anruf" does not exist
                2018-05-17 19:19:21.627 - warn: javascript.1 Object "javascript.1.scriptEnabled.Ereignisse.DWD_Wetterwarnungen" does not exist
                2018-05-17 19:19:21.627 - warn: javascript.1 Object "javascript.1.scriptEnabled.Ereignisse.Tageswechsel" does not exist
                2018-05-17 19:19:21.629 - warn: javascript.1 Object "javascript.1.scriptEnabled.Ereignisse.Wohnungstür_geöffnet" does not exist
                2018-05-17 19:19:21.629 - warn: javascript.1 Object "javascript.1.scriptEnabled.Ereignisse.host_linux_updates" does not exist
                2018-05-17 19:19:21.631 - warn: javascript.1 Object "javascript.1.scriptEnabled.Ereignisse.javascript_Instanz_0_gestartet" does not exist
                2018-05-17 19:19:21.633 - warn: javascript.1 Object "javascript.1.scriptEnabled.Ereignisse.javascript_Instanz_1_gestartet" does not exist
                2018-05-17 19:19:21.633 - warn: javascript.1 Object "javascript.1.scriptEnabled.Ereignisse.javascript_Instanz_3_gestartet" does not exist
                2018-05-17 19:19:21.635 - warn: javascript.1 Object "javascript.1.scriptEnabled.Ereignisse.neue_externe_IP" does not exist
                2018-05-17 19:19:21.635 - warn: javascript.1 Object "javascript.1.scriptEnabled.Ereignisse.xiaomi_staubsauger" does not exist
                2018-05-17 19:19:21.637 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.Router_OS_FW_Internet" does not exist
                2018-05-17 19:19:21.637 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.Router_OS_FW_Ist-Stand" does not exist
                2018-05-17 19:19:21.638 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.Router_OS_Karte_sichtbar" does not exist
                2018-05-17 19:19:21.640 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.Router_OS_Test_ob_FW_neu" does not exist
                2018-05-17 19:19:21.642 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.ccu2.CCU2_Karte_sichtbar" does not exist
                2018-05-17 19:19:21.642 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.ccu2.Read_CUxD" does not exist
                2018-05-17 19:19:21.644 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.ccu2.akt_ccu2_FW_im_Web_anfragen" does not exist
                2018-05-17 19:19:21.644 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.ccu2.prüfen_ob_neue_FW_für_ccu2_verfügbar" does not exist
                2018-05-17 19:19:21.645 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.cuxd.cuxd_Karte_sichtbar" does not exist
                2018-05-17 19:19:21.647 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.cuxd.prüfen_ob_neue_cuxd_Version_verfügbar_ist" does not exist
                2018-05-17 19:19:21.647 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.hue_updates" does not exist
                2018-05-17 19:19:21.648 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.innovaphone.Firmware_Vergleich" does not exist
                2018-05-17 19:19:21.650 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.innovaphone.Testmodus_erneuern" does not exist
                2018-05-17 19:19:21.650 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.innovaphone.aktuelle_FW_12r2_im_Internet" does not exist
                2018-05-17 19:19:21.652 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.innovaphone.innovaphone_ipva_ist_FW_Testmode" does not exist
                2018-05-17 19:19:21.653 - warn: javascript.1 Object "javascript.1.scriptEnabled.Geräteinfos.innovaphone.test_ob_neue_Releasegruppe_plus_vis" does not exist
                2018-05-17 19:19:21.653 - warn: javascript.1 Object "javascript.1.scriptEnabled.IFTTT.von_IFTTT" does not exist
                2018-05-17 19:19:21.654 - warn: javascript.1 Object "javascript.1.scriptEnabled.Steuerung.Gaestebad" does not exist
                2018-05-17 19:19:21.656 - warn: javascript.1 Object "javascript.1.scriptEnabled.Steuerung.Systemtakt_1_Sek" does not exist
                2018-05-17 19:19:21.657 - warn: javascript.1 Object "javascript.1.scriptEnabled.Steuerung.hue_Szene_AZ_waehlen" does not exist
                2018-05-17 19:19:21.658 - warn: javascript.1 Object "javascript.1.scriptEnabled.Steuerung.hue_dynamische_Szenen" does not exist
                2018-05-17 19:19:21.660 - warn: javascript.1 Object "javascript.1.scriptEnabled.Steuerung.signalleuchte" does not exist
                2018-05-17 19:19:21.661 - warn: javascript.1 Object "javascript.1.scriptEnabled.Systeminfos.DHCP_Test" does not exist
                2018-05-17 19:19:21.663 - warn: javascript.1 Object "javascript.1.scriptEnabled.Systeminfos.Host.Ubuntu_Reboot_required" does not exist
                2018-05-17 19:19:21.664 - warn: javascript.1 Object "javascript.1.scriptEnabled.Systeminfos.Host.Ubuntu_Updates" does not exist
                2018-05-17 19:19:21.665 - warn: javascript.1 Object "javascript.1.scriptEnabled.Systeminfos.Host.Ubuntu_Uptime_und_Load" does not exist
                2018-05-17 19:19:21.667 - warn: javascript.1 Object "javascript.1.scriptEnabled.Systeminfos.Host.Ubuntu_update_npm_oder_node_js" does not exist
                2018-05-17 19:19:21.668 - warn: javascript.1 Object "javascript.1.scriptEnabled.Systeminfos.Host.ioBroker_Test_Prozesse" does not exist
                2018-05-17 19:19:21.670 - warn: javascript.1 Object "javascript.1.scriptEnabled.Systeminfos.Host.ioBroker_hd_Platz_für_ioBroker" does not exist
                2018-05-17 19:19:21.671 - warn: javascript.1 Object "javascript.1.scriptEnabled.Systeminfos.dns_Abfrage" does not exist
                2018-05-17 19:19:21.672 - warn: javascript.1 Object "javascript.1.scriptEnabled.Systeminfos.npm_Version_Alarm" does not exist
                2018-05-17 19:19:21.674 - warn: javascript.1 Object "javascript.1.scriptEnabled.Telegram.Dialog" does not exist
                2018-05-17 19:19:21.674 - warn: javascript.1 Object "javascript.1.scriptEnabled.Test.ble" does not exist
                2018-05-17 19:19:21.676 - warn: javascript.1 Object "javascript.1.scriptEnabled.Tools.Adapter_Konfig_einlesen" does not exist
                2018-05-17 19:19:21.676 - warn: javascript.1 Object "javascript.1.scriptEnabled.Tools.Adapter_Konfig_sichern" does not exist
                2018-05-17 19:19:21.678 - warn: javascript.1 Object "javascript.1.scriptEnabled.Tools.SQL_Type_ändern" does not exist
                2018-05-17 19:19:21.679 - warn: javascript.1 Object "javascript.1.scriptEnabled.Visualisierung.card_DWD" does not exist
                2018-05-17 19:19:21.681 - warn: javascript.1 Object "javascript.1.scriptEnabled.Visualisierung.card_DWD1" does not exist
                2018-05-17 19:19:21.682 - warn: javascript.1 Object "javascript.1.scriptEnabled.Visualisierung.card_DWD2" does not exist
                2018-05-17 19:19:21.683 - warn: javascript.1 Object "javascript.1.scriptEnabled.Visualisierung.card_Duty_Cycle" does not exist
                2018-05-17 19:19:21.685 - warn: javascript.1 Object "javascript.1.scriptEnabled.Visualisierung.card_Update_Linux" does not exist
                2018-05-17 19:19:21.685 - warn: javascript.1 Object "javascript.1.scriptEnabled.Visualisierung.card_VW_Navi" does not exist
                2018-05-17 19:19:21.687 - warn: javascript.1 Object "javascript.1.scriptEnabled.Visualisierung.card_Wetter_Farben" does not exist
                2018-05-17 19:19:21.688 - warn: javascript.1 Object "javascript.1.scriptEnabled.Visualisierung.card_epson_px830" does not exist
                2018-05-17 19:19:21.690 - warn: javascript.1 Object "javascript.1.scriptEnabled.Visualisierung.card_ioBroker_Systemauslastung" does not exist
                2018-05-17 19:19:21.690 - warn: javascript.1 Object "javascript.1.scriptEnabled.Visualisierung.card_xiaomi" does not exist
                2018-05-17 19:19:21.692 - warn: javascript.1 Object "javascript.1.scriptEnabled.backup_DiskStation_Feb-14-2011-2018_CaseConflict.backup_mit_vis" does not exist
                2018-05-17 19:19:21.693 - warn: javascript.1 Object "javascript.1.scriptEnabled.javascript-global_d" does not exist
                2018-05-17 19:19:21.693 - warn: javascript.1 Object "javascript.1.scriptEnabled.jsconfig" does not exist
                2018-05-17 19:19:21.694 - warn: javascript.1 Object "javascript.1.scriptEnabled.node_modules.optimist.test." does not exist
                2018-05-17 19:19:21.696 - warn: javascript.1 Object "javascript.1.scriptEnabled.node_modules.require.lib.getRequireStatements" does not exist
                2018-05-17 19:19:21.696 - warn: javascript.1 Object "javascript.1.scriptEnabled.node_modules.source-map.lib.source-map" does not exist
                2018-05-17 19:19:21.698 - warn: javascript.1 Object "javascript.1.scriptEnabled.node_modules.source-map.test.run-tests" does not exist
                2018-05-17 19:19:21.699 - warn: javascript.1 Object "javascript.1.scriptEnabled.node_modules.std.isArguments" does not exist
                2018-05-17 19:19:21.699 - warn: javascript.1 Object "javascript.1.scriptEnabled.node_modules.uglify-js.test.run-tests" does not exist
                2018-05-17 19:19:21.700 - warn: javascript.1 Object "javascript.1.scriptEnabled.test" does not exist
                2018-05-17 19:19:21.702 - warn: javascript.1 Object "javascript.1.scriptEnabled.test-inno-calls" does not exist
                2018-05-17 19:19:21.702 - warn: javascript.1 Object "javascript.1.scriptEnabled.vorlage" does not exist
                2018-05-17 19:19:21.704 - warn: javascript.1 Object "javascript.1.scriptEnabled.zz_todos" does not exist
                2018-05-17 19:19:21.726 - info: javascript.1 script.js.test: Checking.... 14600 left
                2018-05-17 19:19:21.960 - info: javascript.1 script.js.test: Checking.... 14400 left
                2018-05-17 19:19:22.098 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id10.chain
                2018-05-17 19:19:22.100 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                10.comment
                2018-05-17 19:19:22.101 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id10.disabled
                2018-05-17 19:19:22.103 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                10.id
                2018-05-17 19:19:22.104 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id11.chain
                2018-05-17 19:19:22.106 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                11.comment
                2018-05-17 19:19:22.106 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id11.disabled
                2018-05-17 19:19:22.108 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                11.id
                2018-05-17 19:19:22.109 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id12.chain
                2018-05-17 19:19:22.111 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                12.comment
                2018-05-17 19:19:22.112 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id12.disabled
                2018-05-17 19:19:22.113 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                12.id
                2018-05-17 19:19:22.115 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id13.chain
                2018-05-17 19:19:22.116 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                13.comment
                2018-05-17 19:19:22.118 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id13.disabled
                2018-05-17 19:19:22.119 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                13.id
                2018-05-17 19:19:22.121 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id15.chain
                15.comment
                2018-05-17 19:19:22.123 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id15.disabled
                15.id
                2018-05-17 19:19:22.125 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id16.chain
                2018-05-17 19:19:22.126 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                16.comment
                2018-05-17 19:19:22.127 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id16.disabled
                2018-05-17 19:19:22.129 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                16.id
                2018-05-17 19:19:22.129 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id17.chain
                2018-05-17 19:19:22.130 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                17.comment
                2018-05-17 19:19:22.132 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id17.disabled
                17.id
                2018-05-17 19:19:22.134 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id18.chain
                2018-05-17 19:19:22.135 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                18.disabled
                2018-05-17 19:19:22.135 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id18.id
                2018-05-17 19:19:22.137 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                19.chain
                2018-05-17 19:19:22.138 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id19.comment
                19.disabled
                2018-05-17 19:19:22.139 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id19.id
                2018-05-17 19:19:22.141 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                1A.chain
                2018-05-17 19:19:22.142 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1A.comment
                2018-05-17 19:19:22.144 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                1A.disabled
                2018-05-17 19:19:22.146 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1A.id
                2018-05-17 19:19:22.148 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                1B.chain
                2018-05-17 19:19:22.150 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1B.comment
                1B.disabled
                2018-05-17 19:19:22.152 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1B.id
                1C.chain
                2018-05-17 19:19:22.154 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1C.comment
                2018-05-17 19:19:22.155 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                1C.disabled
                2018-05-17 19:19:22.157 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1C.id
                2018-05-17 19:19:22.158 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                1D.chain
                2018-05-17 19:19:22.160 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1D.comment
                2018-05-17 19:19:22.161 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                1D.disabled
                2018-05-17 19:19:22.162 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1D.id
                2018-05-17 19:19:22.164 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                1E.chain
                2018-05-17 19:19:22.164 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1E.comment
                2018-05-17 19:19:22.166 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                1E.disabled
                2018-05-17 19:19:22.167 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1E.id
                2018-05-17 19:19:22.168 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                1F.chain
                2018-05-17 19:19:22.170 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1F.comment
                1F.disabled
                2018-05-17 19:19:22.172 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id1F.id
                2018-05-17 19:19:22.173 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                20.chain
                2018-05-17 19:19:22.174 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id20.comment
                2018-05-17 19:19:22.176 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                20.disabled
                2018-05-17 19:19:22.177 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id20.id
                2018-05-17 19:19:22.179 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                21.chain
                2018-05-17 19:19:22.179 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id21.comment
                2018-05-17 19:19:22.181 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                21.disabled
                2018-05-17 19:19:22.182 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id21.id
                2018-05-17 19:19:22.183 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                22.chain
                2018-05-17 19:19:22.185 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id22.comment
                2018-05-17 19:19:22.186 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                22.disabled
                2018-05-17 19:19:22.188 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id22.id
                23.chain
                2018-05-17 19:19:22.190 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id23.comment
                23.disabled
                2018-05-17 19:19:22.192 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id23.id
                2018-05-17 19:19:22.193 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                24.chain
                2018-05-17 19:19:22.195 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id24.comment
                2018-05-17 19:19:22.196 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                24.disabled
                2018-05-17 19:19:22.198 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id24.id
                2018-05-17 19:19:22.199 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                25.chain
                2018-05-17 19:19:22.200 - info: javascript.1 script.js.test: Checking.... 14200 left
                2018-05-17 19:19:22.200 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id25.comment
                2018-05-17 19:19:22.202 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                25.disabled
                2018-05-17 19:19:22.204 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id25.id
                2018-05-17 19:19:22.205 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                26.chain
                2018-05-17 19:19:22.206 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id26.comment
                2018-05-17 19:19:22.208 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                26.disabled
                2018-05-17 19:19:22.210 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id26.id
                27.chain
                2018-05-17 19:19:22.212 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id27.comment
                27.disabled
                2018-05-17 19:19:22.214 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id27.id
                2018-05-17 19:19:22.215 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                28.chain
                2018-05-17 19:19:22.216 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id28.comment
                2018-05-17 19:19:22.218 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                28.disabled
                2018-05-17 19:19:22.218 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id28.id
                2018-05-17 19:19:22.219 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                29.chain
                2018-05-17 19:19:22.221 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id29.comment
                29.disabled
                2018-05-17 19:19:22.223 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id29.id
                2018-05-17 19:19:22.224 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                2A.chain
                2018-05-17 19:19:22.225 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2A.comment
                2018-05-17 19:19:22.227 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                2A.disabled
                2018-05-17 19:19:22.227 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2A.id
                2018-05-17 19:19:22.229 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                2B.chain
                2018-05-17 19:19:22.230 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2B.comment
                2018-05-17 19:19:22.231 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                2B.disabled
                2018-05-17 19:19:22.233 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2B.id
                2C.chain
                2018-05-17 19:19:22.234 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2C.comment
                2018-05-17 19:19:22.236 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                2C.disabled
                2018-05-17 19:19:22.237 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2C.id
                2018-05-17 19:19:22.239 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                2D.chain
                2018-05-17 19:19:22.240 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2D.comment
                2018-05-17 19:19:22.242 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                2D.disabled
                2018-05-17 19:19:22.243 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2D.id
                2018-05-17 19:19:22.244 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                2E.chain
                2018-05-17 19:19:22.246 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2E.comment
                2E.disabled
                2018-05-17 19:19:22.248 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2E.id
                2018-05-17 19:19:22.249 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                2F.chain
                2018-05-17 19:19:22.250 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2F.comment
                2018-05-17 19:19:22.252 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                2F.disabled
                2018-05-17 19:19:22.253 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id2F.id
                2018-05-17 19:19:22.255 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                30.chain
                2018-05-17 19:19:22.256 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id30.comment
                2018-05-17 19:19:22.257 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                30.disabled
                2018-05-17 19:19:22.259 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id30.id
                2018-05-17 19:19:22.261 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                31.chain
                2018-05-17 19:19:22.262 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id31.comment
                2018-05-17 19:19:22.264 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                31.disabled
                2018-05-17 19:19:22.264 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id31.id
                2018-05-17 19:19:22.266 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                32.chain
                2018-05-17 19:19:22.267 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id32.comment
                2018-05-17 19:19:22.268 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                32.disabled
                2018-05-17 19:19:22.270 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id32.id
                33.chain
                2018-05-17 19:19:22.272 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id33.comment
                2018-05-17 19:19:22.273 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                33.disabled
                2018-05-17 19:19:22.274 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id33.id
                2018-05-17 19:19:22.276 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                34.chain
                2018-05-17 19:19:22.277 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id34.comment
                2018-05-17 19:19:22.279 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                34.disabled
                2018-05-17 19:19:22.280 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id34.id
                2018-05-17 19:19:22.282 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                35.chain
                2018-05-17 19:19:22.283 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id35.comment
                2018-05-17 19:19:22.285 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                35.disabled
                2018-05-17 19:19:22.285 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id35.id
                2018-05-17 19:19:22.288 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                36.chain
                2018-05-17 19:19:22.289 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id36.comment
                2018-05-17 19:19:22.291 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                36.disabled
                2018-05-17 19:19:22.292 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id36.id
                2018-05-17 19:19:22.294 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                37.chain
                2018-05-17 19:19:22.296 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id37.comment
                2018-05-17 19:19:22.297 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                37.disabled
                2018-05-17 19:19:22.299 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id37.id
                2018-05-17 19:19:22.300 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                38.chain
                2018-05-17 19:19:22.302 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id38.disabled
                2018-05-17 19:19:22.303 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                38.id
                2018-05-17 19:19:22.304 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.idB.chain
                2018-05-17 19:19:22.306 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                B.disabled
                2018-05-17 19:19:22.307 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.idB.id
                2018-05-17 19:19:22.309 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                C.chain
                2018-05-17 19:19:22.310 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.idC.disabled
                2018-05-17 19:19:22.312 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                C.id
                2018-05-17 19:19:22.312 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.idD.chain
                2018-05-17 19:19:22.314 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                D.comment
                2018-05-17 19:19:22.315 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.idD.disabled
                D.id
                2018-05-17 19:19:22.317 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.idE.chain
                2018-05-17 19:19:22.318 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                E.comment
                2018-05-17 19:19:22.318 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.idE.disabled
                2018-05-17 19:19:22.320 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                E.id
                2018-05-17 19:19:22.321 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.idF.chain
                2018-05-17 19:19:22.322 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                F.comment
                2018-05-17 19:19:22.324 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.idF.disabled
                2018-05-17 19:19:22.325 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.filter.id
                F.id
                2018-05-17 19:19:22.378 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id1.action
                1.chain
                2018-05-17 19:19:22.380 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id1.comment
                1.disabled
                2018-05-17 19:19:22.382 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id1.id
                2018-05-17 19:19:22.383 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id
                1.out-interface
                2018-05-17 19:19:22.384 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id2.action
                2018-05-17 19:19:22.386 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id
                2.chain
                2018-05-17 19:19:22.386 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id2.comment
                2018-05-17 19:19:22.388 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id
                2.disabled
                2018-05-17 19:19:22.389 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id2.id
                9.action
                2018-05-17 19:19:22.391 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id9.chain
                2018-05-17 19:19:22.392 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id
                9.comment
                2018-05-17 19:19:22.393 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id9.disabled
                2018-05-17 19:19:22.395 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id
                9.id
                2018-05-17 19:19:22.395 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id9.out-interface
                2018-05-17 19:19:22.397 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id
                A.action
                2018-05-17 19:19:22.398 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.idA.chain
                2018-05-17 19:19:22.399 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id
                A.comment
                2018-05-17 19:19:22.401 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.idA.disabled
                A.id
                2018-05-17 19:19:22.403 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.idA.out-interface
                2018-05-17 19:19:22.404 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id
                B.action
                2018-05-17 19:19:22.405 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.idB.chain
                2018-05-17 19:19:22.407 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id
                B.comment
                2018-05-17 19:19:22.407 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.idB.disabled
                2018-05-17 19:19:22.409 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id
                B.id
                2018-05-17 19:19:22.410 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.idC.action
                C.chain
                2018-05-17 19:19:22.412 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.idC.comment
                2018-05-17 19:19:22.413 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id
                C.disabled
                2018-05-17 19:19:22.414 - warn: javascript.1 script.js.test: Invalid ID: mikrotik.0.nat.id*C.id
                2018-05-17 19:19:22.446 - info: javascript.1 script.js.test: Checking.... 14000 left
                2018-05-17 19:19:22.677 - info: javascript.1 script.js.test: Checking.... 13800 left
                2018-05-17 19:19:22.905 - info: javascript.1 script.js.test: Checking.... 13600 left
                2018-05-17 19:19:22.986 - warn: javascript.1 Object "system.adapter.cloud.0.alive" does not exist
                2018-05-17 19:19:22.986 - warn: javascript.1 Object "system.adapter.cloud.0.connected" does not exist
                2018-05-17 19:19:22.988 - warn: javascript.1 Object "system.adapter.cloud.0.inputCount" does not exist
                2018-05-17 19:19:22.988 - warn: javascript.1 Object "system.adapter.cloud.0.memHeapTotal" does not exist
                2018-05-17 19:19:22.990 - warn: javascript.1 Object "system.adapter.cloud.0.memHeapUsed" does not exist
                2018-05-17 19:19:22.992 - warn: javascript.1 Object "system.adapter.cloud.0.memRss" does not exist
                2018-05-17 19:19:22.992 - warn: javascript.1 Object "system.adapter.cloud.0.outputCount" does not exist
                2018-05-17 19:19:22.994 - warn: javascript.1 Object "system.adapter.cloud.0.uptime" does not exist
                2018-05-17 19:19:23.090 - warn: javascript.1 Object "system.adapter.hm-rega.0.alive" does not exist
                2018-05-17 19:19:23.091 - warn: javascript.1 Object "system.adapter.hm-rega.0.connected" does not exist
                2018-05-17 19:19:23.093 - warn: javascript.1 Object "system.adapter.hm-rega.0.inputCount" does not exist
                2018-05-17 19:19:23.093 - warn: javascript.1 Object "system.adapter.hm-rega.0.memHeapTotal" does not exist
                2018-05-17 19:19:23.095 - warn: javascript.1 Object "system.adapter.hm-rega.0.memHeapUsed" does not exist
                2018-05-17 19:19:23.095 - warn: javascript.1 Object "system.adapter.hm-rega.0.memRss" does not exist
                2018-05-17 19:19:23.097 - warn: javascript.1 Object "system.adapter.hm-rega.0.outputCount" does not exist
                2018-05-17 19:19:23.097 - warn: javascript.1 Object "system.adapter.hm-rega.0.uptime" does not exist
                2018-05-17 19:19:23.100 - warn: javascript.1 Object "system.adapter.hm-rpc.0.alive" does not exist
                2018-05-17 19:19:23.102 - warn: javascript.1 Object "system.adapter.hm-rpc.0.connected" does not exist
                2018-05-17 19:19:23.104 - warn: javascript.1 Object "system.adapter.hm-rpc.0.inputCount" does not exist
                2018-05-17 19:19:23.104 - warn: javascript.1 Object "system.adapter.hm-rpc.0.memHeapTotal" does not exist
                2018-05-17 19:19:23.106 - warn: javascript.1 Object "system.adapter.hm-rpc.0.memHeapUsed" does not exist
                2018-05-17 19:19:23.106 - warn: javascript.1 Object "system.adapter.hm-rpc.0.memRss" does not exist
                2018-05-17 19:19:23.108 - warn: javascript.1 Object "system.adapter.hm-rpc.0.outputCount" does not exist
                2018-05-17 19:19:23.109 - warn: javascript.1 Object "system.adapter.hm-rpc.0.uptime" does not exist
                2018-05-17 19:19:23.109 - warn: javascript.1 Object "system.adapter.hm-rpc.1.alive" does not exist
                2018-05-17 19:19:23.110 - warn: javascript.1 Object "system.adapter.hm-rpc.1.connected" does not exist
                2018-05-17 19:19:23.112 - warn: javascript.1 Object "system.adapter.hm-rpc.1.inputCount" does not exist
                2018-05-17 19:19:23.113 - warn: javascript.1 Object "system.adapter.hm-rpc.1.memHeapTotal" does not exist
                2018-05-17 19:19:23.114 - warn: javascript.1 Object "system.adapter.hm-rpc.1.memHeapUsed" does not exist
                2018-05-17 19:19:23.115 - warn: javascript.1 Object "system.adapter.hm-rpc.1.memRss" does not exist
                2018-05-17 19:19:23.117 - warn: javascript.1 Object "system.adapter.hm-rpc.1.outputCount" does not exist
                2018-05-17 19:19:23.118 - warn: javascript.1 Object "system.adapter.hm-rpc.1.uptime" does not exist
                2018-05-17 19:19:23.119 - warn: javascript.1 Object "system.adapter.hm-rpc.2.alive" does not exist
                2018-05-17 19:19:23.121 - warn: javascript.1 Object "system.adapter.hm-rpc.2.connected" does not exist
                2018-05-17 19:19:23.122 - warn: javascript.1 Object "system.adapter.hm-rpc.2.inputCount" does not exist
                2018-05-17 19:19:23.123 - warn: javascript.1 Object "system.adapter.hm-rpc.2.memHeapTotal" does not exist
                2018-05-17 19:19:23.125 - warn: javascript.1 Object "system.adapter.hm-rpc.2.memHeapUsed" does not exist
                2018-05-17 19:19:23.126 - warn: javascript.1 Object "system.adapter.hm-rpc.2.memRss" does not exist
                2018-05-17 19:19:23.127 - warn: javascript.1 Object "system.adapter.hm-rpc.2.outputCount" does not exist
                2018-05-17 19:19:23.129 - warn: javascript.1 Object "system.adapter.hm-rpc.2.uptime" does not exist
                2018-05-17 19:19:23.133 - info: javascript.1 script.js.test: Checking.... 13400 left
                2018-05-17 19:19:23.175 - warn: javascript.1 Object "system.adapter.javascript.0.alive" does not exist
                2018-05-17 19:19:23.177 - warn: javascript.1 Object "system.adapter.javascript.0.connected" does not exist
                2018-05-17 19:19:23.178 - warn: javascript.1 Object "system.adapter.javascript.0.inputCount" does not exist
                2018-05-17 19:19:23.179 - warn: javascript.1 Object "system.adapter.javascript.0.memHeapTotal" does not exist
                2018-05-17 19:19:23.181 - warn: javascript.1 Object "system.adapter.javascript.0.memHeapUsed" does not exist
                2018-05-17 19:19:23.182 - warn: javascript.1 Object "system.adapter.javascript.0.memRss" does not exist
                2018-05-17 19:19:23.183 - warn: javascript.1 Object "system.adapter.javascript.0.outputCount" does not exist
                2018-05-17 19:19:23.184 - warn: javascript.1 Object "system.adapter.javascript.0.uptime" does not exist
                2018-05-17 19:19:23.299 - warn: javascript.1 Object "system.adapter.ping.0.alive" does not exist
                2018-05-17 19:19:23.301 - warn: javascript.1 Object "system.adapter.ping.0.connected" does not exist
                2018-05-17 19:19:23.301 - warn: javascript.1 Object "system.adapter.ping.0.inputCount" does not exist
                2018-05-17 19:19:23.303 - warn: javascript.1 Object "system.adapter.ping.0.memHeapTotal" does not exist
                2018-05-17 19:19:23.304 - warn: javascript.1 Object "system.adapter.ping.0.memHeapUsed" does not exist
                2018-05-17 19:19:23.305 - warn: javascript.1 Object "system.adapter.ping.0.memRss" does not exist
                2018-05-17 19:19:23.307 - warn: javascript.1 Object "system.adapter.ping.0.outputCount" does not exist
                2018-05-17 19:19:23.308 - warn: javascript.1 Object "system.adapter.ping.0.uptime" does not exist
                2018-05-17 19:19:23.364 - info: javascript.1 script.js.test: Checking.... 13200 left
                2018-05-17 19:19:23.403 - warn: javascript.1 Object "system.adapter.sonos.0.alive" does not exist
                2018-05-17 19:19:23.404 - warn: javascript.1 Object "system.adapter.sonos.0.connected" does not exist
                2018-05-17 19:19:23.405 - warn: javascript.1 Object "system.adapter.sonos.0.inputCount" does not exist
                2018-05-17 19:19:23.407 - warn: javascript.1 Object "system.adapter.sonos.0.memHeapTotal" does not exist
                2018-05-17 19:19:23.408 - warn: javascript.1 Object "system.adapter.sonos.0.memHeapUsed" does not exist
                2018-05-17 19:19:23.409 - warn: javascript.1 Object "system.adapter.sonos.0.memRss" does not exist
                2018-05-17 19:19:23.411 - warn: javascript.1 Object "system.adapter.sonos.0.outputCount" does not exist
                2018-05-17 19:19:23.412 - warn: javascript.1 Object "system.adapter.sonos.0.uptime" does not exist
                2018-05-17 19:19:23.502 - warn: javascript.1 Object "system.adapter.tr-064.0.alive" does not exist
                2018-05-17 19:19:23.504 - warn: javascript.1 Object "system.adapter.tr-064.0.connected" does not exist
                2018-05-17 19:19:23.504 - warn: javascript.1 Object "system.adapter.tr-064.0.inputCount" does not exist
                2018-05-17 19:19:23.505 - warn: javascript.1 Object "system.adapter.tr-064.0.memHeapTotal" does not exist
                2018-05-17 19:19:23.507 - warn: javascript.1 Object "system.adapter.tr-064.0.memHeapUsed" does not exist
                2018-05-17 19:19:23.508 - warn: javascript.1 Object "system.adapter.tr-064.0.memRss" does not exist
                2018-05-17 19:19:23.510 - warn: javascript.1 Object "system.adapter.tr-064.0.outputCount" does not exist
                2018-05-17 19:19:23.512 - warn: javascript.1 Object "system.adapter.tr-064.0.uptime" does not exist
                2018-05-17 19:19:23.541 - warn: javascript.1 Object "system.adapter.web.0.alive" does not exist
                2018-05-17 19:19:23.542 - warn: javascript.1 Object "system.adapter.web.0.connected" does not exist
                2018-05-17 19:19:23.544 - warn: javascript.1 Object "system.adapter.web.0.inputCount" does not exist
                2018-05-17 19:19:23.545 - warn: javascript.1 Object "system.adapter.web.0.memHeapTotal" does not exist
                2018-05-17 19:19:23.546 - warn: javascript.1 Object "system.adapter.web.0.memHeapUsed" does not exist
                2018-05-17 19:19:23.548 - warn: javascript.1 Object "system.adapter.web.0.memRss" does not exist
                2018-05-17 19:19:23.549 - warn: javascript.1 Object "system.adapter.web.0.outputCount" does not exist
                2018-05-17 19:19:23.551 - warn: javascript.1 Object "system.adapter.web.0.uptime" does not exist
                2018-05-17 19:19:23.598 - info: javascript.1 script.js.test: Checking.... 13000 left
                2018-05-17 19:19:23.605 - warn: javascript.1 script.js.test: Invalid ID: systeminfo.0.SW.?
                2018-05-17 19:19:23.831 - info: javascript.1 script.js.test: Checking.... 12800 left
                2018-05-17 19:19:24.061 - info: javascript.1 script.js.test: Checking.... 12600 left
                2018-05-17 19:19:24.293 - info: javascript.1 script.js.test: Checking.... 12400 left
                2018-05-17 19:19:24.530 - info: javascript.1 script.js.test: Checking.... 12200 left
                2018-05-17 19:19:24.759 - info: javascript.1 script.js.test: Checking.... 12000 left
                2018-05-17 19:19:24.988 - info: javascript.1 script.js.test: Checking.... 11800 left
                2018-05-17 19:19:25.219 - info: javascript.1 script.js.test: Checking.... 11600 left
                2018-05-17 19:19:25.451 - info: javascript.1 script.js.test: Checking.... 11400 left
                2018-05-17 19:19:25.679 - info: javascript.1 script.js.test: Checking.... 11200 left
                2018-05-17 19:19:25.909 - info: javascript.1 script.js.test: Checking.... 11000 left
                2018-05-17 19:19:26.139 - info: javascript.1 script.js.test: Checking.... 10800 left
                2018-05-17 19:19:26.374 - info: javascript.1 script.js.test: Checking.... 10600 left
                2018-05-17 19:19:26.608 - info: javascript.1 script.js.test: Checking.... 10400 left
                2018-05-17 19:19:26.843 - info: javascript.1 script.js.test: Checking.... 10200 left
                2018-05-17 19:19:27.075 - info: javascript.1 script.js.test: Checking.... 10000 left
                2018-05-17 19:19:27.308 - info: javascript.1 script.js.test: Checking.... 9800 left
                2018-05-17 19:19:27.538 - info: javascript.1 script.js.test: Checking.... 9600 left
                2018-05-17 19:19:27.772 - info: javascript.1 script.js.test: Checking.... 9400 left
                2018-05-17 19:19:28.006 - info: javascript.1 script.js.test: Checking.... 9200 left
                2018-05-17 19:19:28.238 - info: javascript.1 script.js.test: Checking.... 9000 left
                2018-05-17 19:19:28.475 - info: javascript.1 script.js.test: Checking.... 8800 left
                2018-05-17 19:19:28.704 - info: javascript.1 script.js.test: Checking.... 8600 left
                2018-05-17 19:19:28.934 - info: javascript.1 script.js.test: Checking.... 8400 left
                2018-05-17 19:19:29.165 - info: javascript.1 script.js.test: Checking.... 8200 left
                2018-05-17 19:19:29.392 - info: javascript.1 script.js.test: Checking.... 8000 left
                2018-05-17 19:19:29.626 - info: javascript.1 script.js.test: Checking.... 7800 left
                2018-05-17 19:19:29.855 - info: javascript.1 script.js.test: Checking.... 7600 left
                2018-05-17 19:19:30.084 - info: javascript.1 script.js.test: Checking.... 7400 left
                2018-05-17 19:19:30.114 - warn: javascript.1 script.js.test: Invalid ID: systeminfo.0.TVProgramm.?
                2018-05-17 19:19:30.153 - warn: javascript.1 script.js.test: Invalid ID: systeminfo.1.NAS.Space
                2018-05-17 19:19:30.277 - warn: javascript.1 script.js.test: Invalid ID: systeminfo.1.Web.extern.google.?
                2018-05-17 19:19:30.313 - info: javascript.1 script.js.test: Checking.... 7200 left
                2018-05-17 19:19:30.542 - info: javascript.1 script.js.test: Checking.... 7000 left
                2018-05-17 19:19:30.771 - info: javascript.1 script.js.test: Checking.... 6800 left
                2018-05-17 19:19:30.999 - info: javascript.1 script.js.test: Checking.... 6600 left
                2018-05-17 19:19:31.244 - info: javascript.1 script.js.test: Checking.... 6400 left
                2018-05-17 19:19:31.477 - info: javascript.1 script.js.test: Checking.... 6200 left
                2018-05-17 19:19:31.709 - info: javascript.1 script.js.test: Checking.... 6000 left
                2018-05-17 19:19:31.937 - info: javascript.1 script.js.test: Checking.... 5800 left
                2018-05-17 19:19:32.167 - info: javascript.1 script.js.test: Checking.... 5600 left
                2018-05-17 19:19:32.394 - info: javascript.1 script.js.test: Checking.... 5400 left
                2018-05-17 19:19:32.625 - info: javascript.1 script.js.test: Checking.... 5200 left
                2018-05-17 19:19:32.853 - info: javascript.1 script.js.test: Checking.... 5000 left
                2018-05-17 19:19:33.078 - info: javascript.1 script.js.test: Checking.... 4800 left
                2018-05-17 19:19:33.308 - info: javascript.1 script.js.test: Checking.... 4600 left
                2018-05-17 19:19:33.537 - info: javascript.1 script.js.test: Checking.... 4400 left
                2018-05-17 19:19:33.766 - info: javascript.1 script.js.test: Checking.... 4200 left
                2018-05-17 19:19:33.996 - info: javascript.1 script.js.test: Checking.... 4000 left
                2018-05-17 19:19:34.222 - info: javascript.1 script.js.test: Checking.... 3800 left
                2018-05-17 19:19:34.449 - info: javascript.1 script.js.test: Checking.... 3600 left
                2018-05-17 19:19:34.684 - info: javascript.1 script.js.test: Checking.... 3400 left
                2018-05-17 19:19:34.912 - info: javascript.1 script.js.test: Checking.... 3200 left
                2018-05-17 19:19:35.138 - info: javascript.1 script.js.test: Checking.... 3000 left
                2018-05-17 19:19:35.368 - info: javascript.1 script.js.test: Checking.... 2800 left
                2018-05-17 19:19:35.597 - info: javascript.1 script.js.test: Checking.... 2600 left
                2018-05-17 19:19:35.829 - info: javascript.1 script.js.test: Checking.... 2400 left
                2018-05-17 19:19:36.063 - info: javascript.1 script.js.test: Checking.... 2200 left
                2018-05-17 19:19:36.300 - info: javascript.1 script.js.test: Checking.... 2000 left
                2018-05-17 19:19:36.531 - info: javascript.1 script.js.test: Checking.... 1800 left
                2018-05-17 19:19:36.763 - info: javascript.1 script.js.test: Checking.... 1600 left
                2018-05-17 19:19:36.995 - info: javascript.1 script.js.test: Checking.... 1400 left
                2018-05-17 19:19:37.223 - info: javascript.1 script.js.test: Checking.... 1200 left
                2018-05-17 19:19:37.454 - info: javascript.1 script.js.test: Checking.... 1000 left
                2018-05-17 19:19:37.682 - info: javascript.1 script.js.test: Checking.... 800 left
                2018-05-17 19:19:37.912 - info: javascript.1 script.js.test: Checking.... 600 left
                2018-05-17 19:19:38.139 - info: javascript.1 script.js.test: Checking.... 400 left
                2018-05-17 19:19:38.369 - info: javascript.1 script.js.test: Checking.... 200 left
                2018-05-17 19:19:38.559 - warn: javascript.1 Object "web.0.connected" does not exist
                2018-05-17 19:19:38.600 - info: javascript.1 script.js.test: Checked 10661 devices, 11140 channels, 19502 states
                2018-05-17 19:19:38.600 - info: javascript.1 script.js.test: Found 231 problems
                • twonkyT Offline
                  twonkyT Offline
                  twonky
                  Im spotify-premium ist es ab Version 0.2.4 gefixed.
                  • C Offline
                    ChristianF
                    Hier mein Log-Extrakt:
                    2018-05-17 23:02:38.007 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checked 5243 devices, 5607 channels, 6379 states
                    2018-05-17 23:02:38.008 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Found 20 problems
                    Details:
                    2018-05-17 23:02:14.830 - info: javascript.0 Start javascript script.js.common.Homematic-Scripte.Skript1
                    2018-05-17 23:02:15.287 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: registered 0 subscriptions and 0 schedules
                    2018-05-17 23:02:15.329 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 17200 left
                    2018-05-17 23:02:15.614 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 17000 left
                    2018-05-17 23:02:15.896 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 16800 left
                    2018-05-17 23:02:16.158 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 16600 left
                    2018-05-17 23:02:16.415 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 16400 left
                    2018-05-17 23:02:16.679 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 16200 left
                    2018-05-17 23:02:16.934 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 16000 left
                    2018-05-17 23:02:17.191 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 15800 left
                    2018-05-17 23:02:17.439 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 15600 left
                    2018-05-17 23:02:17.691 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 15400 left
                    2018-05-17 23:02:17.937 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 15200 left
                    2018-05-17 23:02:18.195 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 15000 left
                    2018-05-17 23:02:18.453 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 14800 left
                    2018-05-17 23:02:18.706 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 14600 left
                    2018-05-17 23:02:18.957 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 14400 left
                    2018-05-17 23:02:19.212 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 14200 left
                    2018-05-17 23:02:19.481 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 14000 left
                    2018-05-17 23:02:19.742 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 13800 left
                    2018-05-17 23:02:20.003 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 13600 left
                    2018-05-17 23:02:20.252 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 13400 left
                    2018-05-17 23:02:20.498 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 13200 left
                    2018-05-17 23:02:20.743 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 13000 left
                    2018-05-17 23:02:21.010 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 12800 left
                    2018-05-17 23:02:21.275 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 12600 left
                    2018-05-17 23:02:21.540 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 12400 left
                    2018-05-17 23:02:21.818 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 12200 left
                    2018-05-17 23:02:22.082 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 12000 left
                    2018-05-17 23:02:22.385 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 11800 left
                    2018-05-17 23:02:22.650 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 11600 left
                    2018-05-17 23:02:22.922 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 11400 left
                    2018-05-17 23:02:23.169 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 11200 left
                    2018-05-17 23:02:23.418 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 11000 left
                    2018-05-17 23:02:23.677 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 10800 left
                    2018-05-17 23:02:23.933 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 10600 left
                    2018-05-17 23:02:24.195 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 10400 left
                    2018-05-17 23:02:24.445 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 10200 left
                    2018-05-17 23:02:24.689 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 10000 left
                    2018-05-17 23:02:24.938 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 9800 left
                    2018-05-17 23:02:25.188 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 9600 left
                    2018-05-17 23:02:25.411 - info: robonect.0 Polling done (Status)
                    2018-05-17 23:02:25.447 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 9400 left
                    2018-05-17 23:02:25.709 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 9200 left
                    2018-05-17 23:02:25.968 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 9000 left
                    2018-05-17 23:02:26.218 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 8800 left
                    2018-05-17 23:02:26.480 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 8600 left
                    2018-05-17 23:02:26.757 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 8400 left
                    2018-05-17 23:02:27.014 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 8200 left
                    2018-05-17 23:02:27.266 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 8000 left
                    2018-05-17 23:02:27.512 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 7800 left
                    2018-05-17 23:02:27.785 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 7600 left
                    2018-05-17 23:02:27.971 - info: nut.0 Start NUT update
                    2018-05-17 23:02:27.994 - info: nut.0 All Nut values set
                    2018-05-17 23:02:28.052 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 7400 left
                    2018-05-17 23:02:28.374 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 7200 left
                    2018-05-17 23:02:28.641 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 7000 left
                    2018-05-17 23:02:28.899 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 6800 left
                    2018-05-17 23:02:29.153 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 6600 left
                    2018-05-17 23:02:29.184 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.129-129:199_130_3*255.value
                    2018-05-17 23:02:29.186 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:0_0_9*255.value
                    2018-05-17 23:02:29.190 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:1_8_0*255.value
                    2018-05-17 23:02:29.194 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:1_8_1*255.value
                    2018-05-17 23:02:29.199 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:1_8_2*255.value
                    2018-05-17 23:02:29.202 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:2_8_0*255.value
                    2018-05-17 23:02:29.208 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:2_8_1*255.value
                    2018-05-17 23:02:29.211 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:2_8_2*255.value
                    2018-05-17 23:02:29.216 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:15_7_0*255.value
                    2018-05-17 23:02:29.218 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.129-129:199_130_5*255.value
                    2018-05-17 23:02:29.437 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 6400 left
                    2018-05-17 23:02:29.488 - warn: javascript.0 Object "dwd.0.warning1.level" does not exist
                    2018-05-17 23:02:29.495 - warn: javascript.0 Object "dwd.0.warning1.type" does not exist
                    2018-05-17 23:02:29.505 - warn: javascript.0 Object "dwd.0.warning2.level" does not exist
                    2018-05-17 23:02:29.517 - warn: javascript.0 Object "dwd.0.warning2.type" does not exist
                    2018-05-17 23:02:29.524 - warn: javascript.0 Object "dwd.0.warning3.level" does not exist
                    2018-05-17 23:02:29.534 - warn: javascript.0 Object "dwd.0.warning3.type" does not exist
                    2018-05-17 23:02:29.545 - warn: javascript.0 Object "dwd.0.warning4.level" does not exist
                    2018-05-17 23:02:29.552 - warn: javascript.0 Object "dwd.0.warning4.type" does not exist
                    2018-05-17 23:02:29.562 - warn: javascript.0 Object "dwd.0.warning5.level" does not exist
                    2018-05-17 23:02:29.568 - warn: javascript.0 Object "dwd.0.warning5.type" does not exist
                    2018-05-17 23:02:29.576 - warn: javascript.0 Object "dwd.0.warning6.level" does not exist
                    2018-05-17 23:02:29.582 - warn: javascript.0 Object "dwd.0.warning6.type" does not exist
                    2018-05-17 23:02:29.590 - warn: javascript.0 Object "dwd.0.warning7.level" does not exist
                    2018-05-17 23:02:29.596 - warn: javascript.0 Object "dwd.0.warning7.type" does not exist
                    2018-05-17 23:02:29.604 - warn: javascript.0 Object "dwd.0.warning8.level" does not exist
                    2018-05-17 23:02:29.610 - warn: javascript.0 Object "dwd.0.warning8.type" does not exist
                    2018-05-17 23:02:29.617 - warn: javascript.0 Object "dwd.0.warning9.level" does not exist
                    2018-05-17 23:02:29.623 - warn: javascript.0 Object "dwd.0.warning9.type" does not exist
                    2018-05-17 23:02:29.740 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 6200 left
                    2018-05-17 23:02:29.992 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 6000 left
                    2018-05-17 23:02:30.181 - warn: javascript.0 Object "hm-rpc.0.CENTRAL.PONG" does not exist
                    2018-05-17 23:02:30.185 - warn: javascript.0 Object "hm-rpc.0.IEQ0023424.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:30.189 - warn: javascript.0 Object "hm-rpc.0.IEQ0023424.0.DUTYCYCLE_ALARM" does not exist
                    2018-05-17 23:02:30.194 - warn: javascript.0 Object "hm-rpc.0.IEQ0023424.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:30.202 - warn: javascript.0 Object "hm-rpc.0.IEQ0023424.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:30.234 - warn: javascript.0 Object "hm-rpc.0.IEQ0087115.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:30.240 - warn: javascript.0 Object "hm-rpc.0.IEQ0087115.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:30.248 - warn: javascript.0 Object "hm-rpc.0.IEQ0087115.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:30.265 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 5800 left
                    2018-05-17 23:02:30.520 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 5600 left
                    2018-05-17 23:02:30.779 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 5400 left
                    2018-05-17 23:02:30.862 - warn: javascript.0 Object "hm-rpc.0.LEQ0984665.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:30.867 - warn: javascript.0 Object "hm-rpc.0.LEQ0984665.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                    2018-05-17 23:02:30.871 - warn: javascript.0 Object "hm-rpc.0.LEQ0984665.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:30.880 - warn: javascript.0 Object "hm-rpc.0.LEQ0984665.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:30.883 - warn: javascript.0 Object "hm-rpc.0.LEQ0984665.0.UNREACH_ALARM" does not exist
                    2018-05-17 23:02:31.049 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 5200 left
                    2018-05-17 23:02:31.308 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 5000 left
                    2018-05-17 23:02:31.561 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 4800 left
                    2018-05-17 23:02:31.853 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 4600 left
                    2018-05-17 23:02:32.128 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 4400 left
                    2018-05-17 23:02:32.398 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 4200 left
                    2018-05-17 23:02:32.654 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 4000 left
                    2018-05-17 23:02:32.911 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 3800 left
                    2018-05-17 23:02:33.165 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 3600 left
                    2018-05-17 23:02:33.427 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 3400 left
                    2018-05-17 23:02:33.688 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 3200 left
                    2018-05-17 23:02:33.935 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 3000 left
                    2018-05-17 23:02:33.962 - warn: javascript.0 Object "hm-rpc.0.MEQ0357451.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:33.969 - warn: javascript.0 Object "hm-rpc.0.MEQ0357451.0.DUTYCYCLE_ALARM" does not exist
                    2018-05-17 23:02:33.973 - warn: javascript.0 Object "hm-rpc.0.MEQ0357451.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:33.981 - warn: javascript.0 Object "hm-rpc.0.MEQ0357451.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:33.985 - warn: javascript.0 Object "hm-rpc.0.MEQ0357451.0.UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.080 - warn: javascript.0 Object "hm-rpc.0.MEQ1511482.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.085 - warn: javascript.0 Object "hm-rpc.0.MEQ1511482.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:34.092 - warn: javascript.0 Object "hm-rpc.0.MEQ1511482.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.104 - warn: javascript.0 Object "hm-rpc.0.MEQ1593213.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.109 - warn: javascript.0 Object "hm-rpc.0.MEQ1593213.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:34.116 - warn: javascript.0 Object "hm-rpc.0.MEQ1593213.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.119 - warn: javascript.0 Object "hm-rpc.0.MEQ1593213.0.UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.124 - warn: javascript.0 Object "hm-rpc.0.MEQ1593213.1.ERROR-1_ALARM" does not exist
                    2018-05-17 23:02:34.126 - warn: javascript.0 Object "hm-rpc.0.MEQ1593213.1.ERROR-2_ALARM" does not exist
                    2018-05-17 23:02:34.128 - warn: javascript.0 Object "hm-rpc.0.MEQ1593213.1.ERROR-3_ALARM" does not exist
                    2018-05-17 23:02:34.130 - warn: javascript.0 Object "hm-rpc.0.MEQ1593213.1.ERROR-4_ALARM" does not exist
                    2018-05-17 23:02:34.132 - warn: javascript.0 Object "hm-rpc.0.MEQ1593213.1.ERROR-5_ALARM" does not exist
                    2018-05-17 23:02:34.133 - warn: javascript.0 Object "hm-rpc.0.MEQ1593213.1.ERROR-6_ALARM" does not exist
                    2018-05-17 23:02:34.135 - warn: javascript.0 Object "hm-rpc.0.MEQ1593213.1.ERROR-7_ALARM" does not exist
                    2018-05-17 23:02:34.145 - warn: javascript.0 Object "hm-rpc.0.MEQ1593521.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.149 - warn: javascript.0 Object "hm-rpc.0.MEQ1593521.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:34.156 - warn: javascript.0 Object "hm-rpc.0.MEQ1593521.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.159 - warn: javascript.0 Object "hm-rpc.0.MEQ1593521.0.UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.162 - warn: javascript.0 Object "hm-rpc.0.MEQ1593521.1.ERROR-1_ALARM" does not exist
                    2018-05-17 23:02:34.166 - warn: javascript.0 Object "hm-rpc.0.MEQ1593521.1.ERROR-2_ALARM" does not exist
                    2018-05-17 23:02:34.169 - warn: javascript.0 Object "hm-rpc.0.MEQ1593521.1.ERROR-3_ALARM" does not exist
                    2018-05-17 23:02:34.172 - warn: javascript.0 Object "hm-rpc.0.MEQ1593521.1.ERROR-4_ALARM" does not exist
                    2018-05-17 23:02:34.176 - warn: javascript.0 Object "hm-rpc.0.MEQ1593521.1.ERROR-5_ALARM" does not exist
                    2018-05-17 23:02:34.178 - warn: javascript.0 Object "hm-rpc.0.MEQ1593521.1.ERROR-6_ALARM" does not exist
                    2018-05-17 23:02:34.178 - warn: javascript.0 Object "hm-rpc.0.MEQ1593521.1.ERROR-7_ALARM" does not exist
                    2018-05-17 23:02:34.190 - warn: javascript.0 Object "hm-rpc.0.MEQ1891307.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.193 - warn: javascript.0 Object "hm-rpc.0.MEQ1891307.0.DUTYCYCLE_ALARM" does not exist
                    2018-05-17 23:02:34.197 - warn: javascript.0 Object "hm-rpc.0.MEQ1891307.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:34.204 - warn: javascript.0 Object "hm-rpc.0.MEQ1891307.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.261 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 2800 left
                    2018-05-17 23:02:34.392 - warn: javascript.0 Object "hm-rpc.0.NEQ0250795.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.395 - warn: javascript.0 Object "hm-rpc.0.NEQ0250795.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                    2018-05-17 23:02:34.399 - warn: javascript.0 Object "hm-rpc.0.NEQ0250795.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:34.406 - warn: javascript.0 Object "hm-rpc.0.NEQ0250795.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.409 - warn: javascript.0 Object "hm-rpc.0.NEQ0250795.0.UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.413 - warn: javascript.0 Object "hm-rpc.0.NEQ0250795.0.UPDATE_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.466 - warn: javascript.0 Object "hm-rpc.0.NEQ0357697.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.469 - warn: javascript.0 Object "hm-rpc.0.NEQ0357697.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                    2018-05-17 23:02:34.473 - warn: javascript.0 Object "hm-rpc.0.NEQ0357697.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:34.479 - warn: javascript.0 Object "hm-rpc.0.NEQ0357697.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.482 - warn: javascript.0 Object "hm-rpc.0.NEQ0357697.0.UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.486 - warn: javascript.0 Object "hm-rpc.0.NEQ0357697.0.UPDATE_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.507 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.509 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                    2018-05-17 23:02:34.513 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.0.DUTYCYCLE_ALARM" does not exist
                    2018-05-17 23:02:34.519 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.525 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.0.UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.540 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.0.UPDATE_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.548 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.1.ERROR_OVERHEAT_ALARM" does not exist
                    2018-05-17 23:02:34.553 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.1.ERROR_OVERLOAD_ALARM" does not exist
                    2018-05-17 23:02:34.561 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 2600 left
                    2018-05-17 23:02:34.562 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.1.ERROR_REDUCED_ALARM" does not exist
                    2018-05-17 23:02:34.578 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.2.ERROR_OVERHEAT_ALARM" does not exist
                    2018-05-17 23:02:34.581 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.2.ERROR_OVERLOAD_ALARM" does not exist
                    2018-05-17 23:02:34.585 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.2.ERROR_REDUCED_ALARM" does not exist
                    2018-05-17 23:02:34.600 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.3.ERROR_OVERHEAT_ALARM" does not exist
                    2018-05-17 23:02:34.603 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.3.ERROR_OVERLOAD_ALARM" does not exist
                    2018-05-17 23:02:34.607 - warn: javascript.0 Object "hm-rpc.0.NEQ0388441.3.ERROR_REDUCED_ALARM" does not exist
                    2018-05-17 23:02:34.622 - warn: javascript.0 Object "hm-rpc.0.NEQ0796966.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.625 - warn: javascript.0 Object "hm-rpc.0.NEQ0796966.0.DUTYCYCLE_ALARM" does not exist
                    2018-05-17 23:02:34.628 - warn: javascript.0 Object "hm-rpc.0.NEQ0796966.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:34.634 - warn: javascript.0 Object "hm-rpc.0.NEQ0796966.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.666 - warn: javascript.0 Object "hm-rpc.0.NEQ1681985.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.669 - warn: javascript.0 Object "hm-rpc.0.NEQ1681985.0.LOWBAT_ALARM" does not exist
                    2018-05-17 23:02:34.677 - warn: javascript.0 Object "hm-rpc.0.NEQ1681985.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.680 - warn: javascript.0 Object "hm-rpc.0.NEQ1681985.0.UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.683 - warn: javascript.0 Object "hm-rpc.0.NEQ1681985.1.ERROR-1_ALARM" does not exist
                    2018-05-17 23:02:34.685 - warn: javascript.0 Object "hm-rpc.0.NEQ1681985.1.ERROR-2_ALARM" does not exist
                    2018-05-17 23:02:34.689 - warn: javascript.0 Object "hm-rpc.0.NEQ1681985.1.ERROR-3_ALARM" does not exist
                    2018-05-17 23:02:34.691 - warn: javascript.0 Object "hm-rpc.0.NEQ1681985.1.ERROR-4_ALARM" does not exist
                    2018-05-17 23:02:34.693 - warn: javascript.0 Object "hm-rpc.0.NEQ1681985.1.ERROR-5_ALARM" does not exist
                    2018-05-17 23:02:34.697 - warn: javascript.0 Object "hm-rpc.0.NEQ1681985.1.ERROR-6_ALARM" does not exist
                    2018-05-17 23:02:34.707 - warn: javascript.0 Object "hm-rpc.0.OEQ0294256.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.711 - warn: javascript.0 Object "hm-rpc.0.OEQ0294256.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                    2018-05-17 23:02:34.714 - warn: javascript.0 Object "hm-rpc.0.OEQ0294256.0.DUTYCYCLE_ALARM" does not exist
                    2018-05-17 23:02:34.721 - warn: javascript.0 Object "hm-rpc.0.OEQ0294256.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.724 - warn: javascript.0 Object "hm-rpc.0.OEQ0294256.0.UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.728 - warn: javascript.0 Object "hm-rpc.0.OEQ0294256.0.UPDATE_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.740 - warn: javascript.0 Object "hm-rpc.0.OEQ0294317.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.744 - warn: javascript.0 Object "hm-rpc.0.OEQ0294317.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                    2018-05-17 23:02:34.747 - warn: javascript.0 Object "hm-rpc.0.OEQ0294317.0.DUTYCYCLE_ALARM" does not exist
                    2018-05-17 23:02:34.753 - warn: javascript.0 Object "hm-rpc.0.OEQ0294317.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.757 - warn: javascript.0 Object "hm-rpc.0.OEQ0294317.0.UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.760 - warn: javascript.0 Object "hm-rpc.0.OEQ0294317.0.UPDATE_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.773 - warn: javascript.0 Object "hm-rpc.0.OEQ0996333.0.CONFIG_PENDING_ALARM" does not exist
                    2018-05-17 23:02:34.777 - warn: javascript.0 Object "hm-rpc.0.OEQ0996333.0.DEVICE_IN_BOOTLOADER_ALARM" does not exist
                    2018-05-17 23:02:34.783 - warn: javascript.0 Object "hm-rpc.0.OEQ0996333.0.STICKY_UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.788 - warn: javascript.0 Object "hm-rpc.0.OEQ0996333.0.UNREACH_ALARM" does not exist
                    2018-05-17 23:02:34.855 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 2400 left
                    2018-05-17 23:02:35.103 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 2200 left
                    2018-05-17 23:02:35.353 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 2000 left
                    2018-05-17 23:02:35.598 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 1800 left
                    2018-05-17 23:02:35.837 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 1600 left
                    2018-05-17 23:02:36.082 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 1400 left
                    2018-05-17 23:02:36.326 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 1200 left
                    2018-05-17 23:02:36.582 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 1000 left
                    2018-05-17 23:02:36.844 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 800 left
                    2018-05-17 23:02:37.108 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 600 left
                    2018-05-17 23:02:37.422 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 400 left
                    2018-05-17 23:02:37.555 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:0_0_9*255.value
                    2018-05-17 23:02:37.557 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:15_7_0*255.value
                    2018-05-17 23:02:37.559 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:1_8_0*255.value
                    2018-05-17 23:02:37.562 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:1_8_1*255.value
                    2018-05-17 23:02:37.565 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:1_8_2*255.value
                    2018-05-17 23:02:37.568 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:2_8_0*255.value
                    2018-05-17 23:02:37.573 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:2_8_1*255.value
                    2018-05-17 23:02:37.577 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.1-0:2_8_2*255.value
                    2018-05-17 23:02:37.581 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.129-129:199_130_3*255.value
                    2018-05-17 23:02:37.582 - warn: javascript.0 script.js.common.Homematic-Scripte.Skript1: Invalid ID: smartmeter.0.129-129:199_130_5*255.value
                    2018-05-17 23:02:37.589 - warn: javascript.0 Object "system.adapter.admin.0.inputCount" does not exist
                    2018-05-17 23:02:37.596 - warn: javascript.0 Object "system.adapter.admin.0.outputCount" does not exist
                    2018-05-17 23:02:37.620 - warn: javascript.0 Object "system.adapter.dwd.0.inputCount" does not exist
                    2018-05-17 23:02:37.627 - warn: javascript.0 Object "system.adapter.dwd.0.outputCount" does not exist
                    2018-05-17 23:02:37.658 - warn: javascript.0 Object "system.adapter.fritzbox.0.inputCount" does not exist
                    2018-05-17 23:02:37.664 - warn: javascript.0 Object "system.adapter.fritzbox.0.outputCount" does not exist
                    2018-05-17 23:02:37.672 - warn: javascript.0 Object "system.adapter.hm-rega.0.inputCount" does not exist
                    2018-05-17 23:02:37.679 - warn: javascript.0 Object "system.adapter.hm-rega.0.outputCount" does not exist
                    2018-05-17 23:02:37.689 - warn: javascript.0 Object "system.adapter.hm-rpc.0.inputCount" does not exist
                    2018-05-17 23:02:37.698 - warn: javascript.0 Object "system.adapter.hm-rpc.0.outputCount" does not exist
                    2018-05-17 23:02:37.705 - warn: javascript.0 Object "system.adapter.hm-rpc.1.inputCount" does not exist
                    2018-05-17 23:02:37.711 - warn: javascript.0 Object "system.adapter.hm-rpc.1.outputCount" does not exist
                    2018-05-17 23:02:37.720 - info: javascript.0 script.js.common.Homematic-Scripte.Skript1: Checking.... 200 left
                    2018-05-17 23:02:37.724 - warn: javascript.0 Object "system.adapter.ical.0.inputCount" does not exist
                    2018-05-17 23:02:37.733 - warn: javascript.0 Object "system.adapter.ical.0.outputCount" does not exist
                    2018-05-17 23:02:37.740 - warn: javascript.0 Object "system.adapter.ical.1.inputCount" does not exist
                    2018-05-17 23:02:37.746 - warn: javascript.0 Object "system.adapter.ical.1.outputCount" does not exist
                    2018-05-17 23:02:37.756 - warn: javascript.0 Object "system.adapter.javascript.0.inputCount" does not exist
                    2018-05-17 23:02:37.762 - warn: javascript.0 Object "system.adapter.javascript.0.outputCount" does not exist
                    2018-05-17 23:02:37.826 - warn: javascript.0 Object "system.adapter.nut.0.inputCount" does not exist
                    2018-05-17 23:02:37.832 - warn: javascript.0 Object "system.adapter.nut.0.outputCount" does not exist
                    2018-05-17 23:02:37.840 - warn: javascript.0 Object "system.adapter.ping.0.inputCount" does not exist
                    2018-05-17 23:02:37.847 - warn: javascript.0 Object "system.adapter.ping.0.outputCount" does not exist
                    2018-05-17 23:02:37.941 - warn: javascript.0 Object "system.adapter.web.0.inputCount" does not exist
                    2018-05-17 23:02:37.948 - warn: javascript.0 Object "system.adapter.web.0.outputCount" does not exist
                    2018-05-17 23:02:38.005 - warn: javascript.0 Object "web.0.connected" does not exist
                    Danke für Eure tolle Arbeit!!!
                    Viele Grüße
                    Christian
                    • AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      ZWave in nächster Version gefixt: https://github.com/ioBroker/ioBroker.zwave/pull/38
                      • apollon77A Offline
                        @ruhr70:
                        Bei hm-ip sind Objekte auf einmal verschwunden. `
                        Am besten mal die Objekte neu mit HM syncen. Diese Fehler kommen weil das Check.Skript alle States liesst und dann versucht die Objekte dazu zu lesen. diese "*_ALARM" kommen von ioBroker dazu, andere auch. Also mal neu syncen würde ich vorschlagen.
                        Mikritik ist cool. Der Adapter war bisher nicht auf der Problemliste. Super!!
                        Zu deinen Ungültigen IDs vom "systeminfo" Adapter da liegt es an deinen angegebenen Namen oder ?! Kannst Du da die "?" rausnehmen?
                        • P Offline
                          Pman
                          @apollon77:
                          soetwas hatten wir überlegt. Für einfache Adapter die nur Werte schreiben ist das simpel. Sobald der Adapter aber auch auf State-Änderungen reagiert müsste man hier das ganze auch wieder "zurückrechnen". Und am Ende wäre es "magie" die trotzdem jeder Adapterentwickler wissen und beachten muss weil es sonst, wie Du korrekt sagst, zu Kollisionen kommen kann. `
                          Das darauf reagieren ginge schon, wenn alle Funktionen (get, set, subscribe) für States und Objects die selbe Wandlung vorgeschaltet bekommen, oder habe ich da einen Denkfehler drinnen? Die Kollisionsgefahr bleibt natürlich, aber das ist denke ich dann eher etwas, was nur in ganz seltenen Fällen auftritt. Wenn setObject initial, falls eine Änderungen statt findet, den original-Namen unter .native speichert, wäre auch die Rückwandlung ohne Magie möglich.
                          Ich habe so das Gefühl, dass dieses Problem immer wieder auftreten wird, auch wenn jetzt alle Problem-Adapter einmal gefixt werden.
                          Zum Regex-Filter: macht es nicht mehr sinn einen Whitelist-Filter zu machen mit Zeichen, welche erlaubt sind? Vermutlich gibt es endlos viele Problematische Zeichen, welche auftreten könnten. Ganz zu schweigen von Zeichenfolgen, welche möglicherweise im Admin und Vis problematisch sind.
                          • ruhr70R Offline
                            ruhr70R Offline
                            ruhr70
                            @apollon77:
                            @ruhr70:
                            Am besten mal die Objekte neu mit HM syncen. Diese Fehler kommen weil das Check.Skript alle States liesst und dann versucht die Objekte dazu zu lesen. diese "*_ALARM" kommen von ioBroker dazu, andere auch. Also mal neu syncen würde ich vorschlagen. `
                            Neu syncen hatte ich mehrmals versucht. Ich weiss nicht, was passiert ist, aber seit irgendeinem Zeitpunkt sind die Datenpunkte eines hm-ip Klimasensors verschwunden und die neuen hm-ips (Durhcgangssensor, Präsenzmelder) werden nicht vollständig angelegt (trotz geschlossenem Issue).
                            @apollon77:
                            Zu deinen Ungültigen IDs vom "systeminfo" Adapter da liegt es an deinen angegebenen Namen oder ?! Kannst Du da die "?" rausnehmen? `
                            Zu:
                            2018-05-17 19:19:30.153 - warn: javascript.1 script.js.test: Invalid ID: systeminfo.1.NAS.Space_?
                            Tja. Die ? kommen bei mir mit den Standardeinstellung vom systeminfo Adapter. Das müsste dann wohl auch beim Adapter angepasst werden.
                            <code>TVProgramm.[name/text]
                            http://www.tvmovie.de/tv/programm-jetzt
                            {"[0][*][!(({name: @.name.split(' ')[0], text: @.name.split(' ').slice(@.name.slice(' ').indexOf('Seit')).join(' ')}))]":{'[section[class=item]]': {'name[span[class=h2]]':0}}}</code>
                              Hey all,
                              Wir sind noch über User gestolpert die Leerzeichen in Objekt ids haben und haben beschlossen das im Rahmen der geplanten Änderung mit zu verbieten.
                              Ich habe daher das Test Skript in Post #8 oben erweitert das es jetzt auch darauf prüft.
                              Von daher eine Bitte an alle die bisher mitgemacht haben: bitte Skript aktualisieren und sicherheitshalber nochmal laufen lassen. Unterschiede zu davor bitte noch Posten.
                              Ich hoffe das kein Adapter leerzeichen in ids hat sondern pot. nur eigene Skripte ;-)
                              Danke!!
                              • TomTT Offline
                                TomTT Offline
                                TomT
                                Der Samsung Adapter hat Leerzeichen :
                                2018-05-27 07:41:11.113 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Volume.Mute Toggle
                                2018-05-27 07:41:11.115 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Volume.Volume Up
                                2018-05-27 07:41:11.119 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Volume.Volume Down
                                2018-05-27 07:41:11.136 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Channel.Channel Up
                                2018-05-27 07:41:11.140 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Channel.Channel Down
                                2018-05-27 07:41:11.142 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Channel.Channel List
                                2018-05-27 07:41:11.144 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Channel.Previous Channel
                                2018-05-27 07:41:11.146 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Channel.Picture Size
                                2018-05-27 07:41:11.157 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Input.Media Player
                                2018-05-27 07:41:11.186 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.MediaPlayer.Fast Forward
                                2018-05-27 07:41:14.396 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Channel.Channel Down
                                2018-05-27 07:41:14.398 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Channel.Channel List
                                2018-05-27 07:41:14.401 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Channel.Channel Up
                                2018-05-27 07:41:14.403 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Channel.Picture Size
                                2018-05-27 07:41:14.406 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Channel.Previous Channel
                                2018-05-27 07:41:14.416 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Input.Media Player
                                2018-05-27 07:41:14.428 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.MediaPlayer.Fast Forward
                                2018-05-27 07:41:14.448 - info: javascript.0 script.js.Skript1: Checking.... 400 left
                                2018-05-27 07:41:14.459 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Volume.Mute Toggle
                                2018-05-27 07:41:14.462 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Volume.Volume Down
                                2018-05-27 07:41:14.463 - warn: javascript.0 script.js.Skript1: Invalid ID: samsung.0.Volume.Volume Up
                                Ausserdem bekomme ich auf einmal elendig viele does not exist Warnungen
                                2018-05-27 07:41:14.224 - warn: javascript.0 Object "hm-rpc.0.OEQ020xxxx.0.STICKY_UNREACH_ALARM" does not exist
                                2018-05-27 07:41:14.712 - warn: javascript.0 Object "system.adapter.vis.0.inputCount" does not exist
                                Gefühlte 400 Stück, die meisten vom hm.rpc
                                Hatte ich vorher nicht….
                                Ist das Normal?
                                Tom
                                PI3B > Raspimatic / Opi+2 > ioBroker / ESP8266
                                if (System == "running") {finger = "weg";} else {lastAction = "Rückgängig";}
                                  Superdad
                                  Wenn ich das Script ausführe, bekomme ich ein Log von ca. 18000 Zeichen.
                                  Soviel kann ich leider nicht posten.
                                  Kann ich das Log an Jemanden schicken?
                                  CCU3
                                  iOBroker auf IntelNUC Proxmox
                                    Mir als pn als zip oder so. Gibt es häufungen? Was für „Typen“ von Ausgaben gibt’s oder alles das gleiche?
                                      @TomT:
                                      Ist das Normal? `
                                      Samsung kommt damit auf die Liste.
                                      Fie object missing hätten vorher auch da sein müssen. Komisch.
                                      Aber die erstmal ignorieren.
                                        Superdad
                                        Jede Menge Unifi-Adapter.
                                        Dann Rauchmelder, weil ein * in der Seriennummer ist.
                                        Weiss aber nicht wie ich das weg bekomme.
                                        Schicke es dir mal.
                                        CCU3
                                          Unifi wegen welchem Zeichen? Leerzeichen?
                                          Da müssen überall die Adapter Entwickler ran. Also abwarten.
