  4. Test Adapter zigbee 3.6.z
36 Beiträge 6 Kommentatoren 1.2k Aufrufe 10 Beobachtet
  • Peter V.P
    Peter V.P
    Peter V.
    @asgothian
    läuft bisher fast unauffällig.
    ...jetzt das "kleine" fast...
    wenn ich auf OTA prüfen klicke:
    zigbee.0
    	2026-11-24 21:56:54.543	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    	2026-11-24 21:56:54.543	info	terminating
    zigbee.0
    	2026-11-24 21:56:54.542	info	cleanup successful
    zigbee.0
    	2026-11-24 21:56:54.542	info	zigbecontroller stopped successfully
    zigbee.0
    	2026-11-24 21:56:42.583	info	Closing network.
    zigbee.0
    	2026-11-24 21:56:42.356	info	Saved local configuration data
    zigbee.0
    	2026-11-24 21:56:42.356	info	cleaning everything up
    zigbee.0
    	2026-11-24 21:56:42.356	info	Halting zigbee adapter. Restart delay is at least 30 seconds.
    zigbee.0
    	2026-11-24 21:56:42.354	error	Timeout after 60000ms [address=62342 endpoint=1 clusterId=25 cmdId=1 tsn=undefined]
    zigbee.0
    	2026-11-24 21:56:42.354	error	Error: Timeout after 60000ms [address=62342 endpoint=1 clusterId=25 cmdId=1 tsn=undefined] at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:48:23) at ZStackAdapter.waitFor (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:794:57) at #waitForOtaCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:1210:49) at #notifyOta (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:1252:62) at Device.checkOta (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:1278:56) at Ota.checkOtaforEntity (/opt/iobroker/node_modules/iobroker.zigbee/lib/pluginOta.js:284:55) at async Ota.multiCheckOtaAvail (/opt/iobroker/node_modules/iobroker.zigbee/lib/pluginOta.js:138:28) at async Ota.onStateChange (/opt/iobroker/node_modules/iobroker.zigbee/lib/pluginOta.js:70:25)
    zigbee.0
    	2026-11-24 21:56:42.354	error	unhandled promise rejection: Timeout after 60000ms [address=62342 endpoint=1 clusterId=25 cmdId=1 tsn=undefined]
    zigbee.0
    	2026-11-24 21:56:42.354	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Codm ,
    type:ZStack3x0
    version:2-1.2.7.1.
    revision:20250321
    port:tcp://192.168.178.102:6638
    channel:25
    Debug kann ich erst morgen nachreichen.
    • D
      D
      dimaiv
      schrieb am zuletzt editiert von dimaiv
      Bei mir flackern die Icons oben rechts sobald ich die Zigbee Geräte Startseite auf mache, und ich kann nichts bedienen.
      Z. B Kachel umdrehen, springt sofort wieder zurück, also, gar nichts.
      Alles seit dem Update auf 3.6.1.
      Egal in welchem Browser ich es auf mache, oder auf welchem Gerät..
      video_2026-11-25_14-36-36.mp4
      ioBroker- NUC8i3 / Proxmox / VM
      Node.js v24.23.3
      NPM v11.19.1
      JS controller 7.2.5
      Admin 8.3.15
      ZigBee Adapter 3.6.1
      Zigbee LAN Gateway CC2652P
      Zigbee Firmware 20250321
      • D dimaiv
        AsgothianA
        AsgothianA
        Asgothian
        @dimaiv sagte:
        Zeig bitte mal das Log. Dieses Icon kommt eigentlich nur, wenn der Adapter zwischendurch abstürzt und vollständig nicht läuft.
        A.
        • Peter V.P Peter V.
          @asgothian
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          Codm ,
          type:ZStack3x0
          version:2-1.2.7.1.
          revision:20250321
          channel:25
          AsgothianA
          AsgothianA
          Asgothian
          @Peter-V.
          Kannst feststellen von welchem Gerät diese Meldung kommt (ein Blick in die shepherd.db sollte es möglich machen die Address (62342) gegen die IEEE aufzulösen, und dann prüfen ob der Fehler auch auftritt wenn du den befehl checkota in send_payload für dieses Device schreibst ?
          Auch: Hast du Sonoff ZBN5 Wandschalter mit Firmware 1.06 in deinem Netz ?
          A.
          • AsgothianA Asgothian
            @dimaiv sagte:
            A.
            D
            D
            dimaiv
            @Asgothian
            Im log kommt nix ungewöhnliches an, selbst im Debug Modus, und die Geräte funktionieren, also Adapter läuft ohne Unterbrechung dabei.
            Node.js v24.23.3
            NPM v11.19.1
            JS controller 7.2.5
            Admin 8.3.15
            • D dimaiv
              @Asgothian
              AsgothianA
              AsgothianA
              Asgothian
              @dimaiv sagte:
              @Asgothian
              Github oder NPM Installation ? Auch: Welche NodeJS Version ?
              A.
                @dimaiv sagte:
                @Asgothian
                A.
                D
                D
                dimaiv
                @Asgothian
                Ich habe es erstmal normal updated und paar Tage später über GitHub nochmal versucht. Gleiches verhalten.
                Nodejs 22 und 24 gleiches verhalten.
                Es ist ein Zigbee Lan Koordinator.
                Mit 3.5.5 lief alles normal und stabil.
                Mit 3.6.1 läuft stabil aber Webinterface funktioniert nicht, die SteuerIcons flackern nur und funktionieren nicht.
                Node.js v24.23.3
                NPM v11.19.1
                JS controller 7.2.5
                Admin 8.3.15
                • Peter V.P
                  Peter V.P
                  Peter V.
                  @asgothian
                  {"id":14,"type":"EndDevice","ieeeAddr":"0x54ef44100087e21b","nwkAddr":62342,"manufId":4447,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.motion.ac02","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":263,"inClusterList":[0,1,3,64704],"outClusterList":[3,25,64704],"clusters":{"genBasic":{"attributes":{"appVersion":10,"modelId":"lumi.motion.ac02","manufacturerName":"LUMI","powerSource":3,"zclVersion":3,"hwVersion":1,"dateCode":"Jan  4 2023","swBuildId":"0.0.0_0010"}},"genPowerCfg":{"attributes":{"batteryVoltage":28}},"manuSpecificLumi":{"attributes":{"247":{"type":"Buffer","data":[1,33,40,12,3,40,24,4,33,0,0,5,33,3,0,8,33,10,1,10,33,0,0,12,32,1,19,32,0,20,32,0,100,16,0,101,33,8,0,105,32,30,106,32,2,107,32,1]},"258":30,"268":2,"338":1,"illuminance":65561}}},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":10,"hwVersion":1,"dateCode":"Jan  4 2023","swBuildId":"0.0.0_0010","zclVersion":3,"interviewCompleted":true,"interviewState":"SUCCESSFUL","meta":{"configured":"0.0.0"},"lastSeen":1795631298999,"checkinInterval":3600}
                  Habe 7 Stück davon
                  Bei sendpayload checkota passiert nichts
                  Im Netzwerk sind WS-EUK03, RTCGQ14LM, 3RSM0147Z,SMSZB-120,TS0505B_1, WXKG01LM,ZT-B-EU3
                  In der Version 3.5.5 stürzt ZigbeeAdapter nicht ab.
                  • D dimaiv
                    @Asgothian
                    AsgothianA
                    AsgothianA
                    Asgothian
                    @dimaiv das ist seltsam. Das flackern deutet darauf hin das der Adapter selber nicht stabil innerhalb von 100 ms auf den Activity Check reagiert.
                    Patch mal bitte folgendes:
                    admin.js, Zeile 96: aus
                    UpdateAdapterAlive(false);, 100);
                    müsstest du
                    UpdateAdapterAlive(false);, 500);
                    machen, dann ein Force-Reload der Admin Seite. ggf. musst du auch ein Upload machen.
                    A.
                      @asgothian
                      Habe 7 Stück davon
                      AsgothianA
                      AsgothianA
                      Asgothian
                      @Peter-V. sagte:
                      Habe 7 Stück davon
                      Kannst du bei genau dem Parameter anpassen, oder meldet der Adapter da eine Fehlermeldung ?
                      A.
                      • Peter V.P
                        Peter V.P
                        Peter V.
                        schrieb am zuletzt editiert von Peter V.
                        Mit der Version 3.5.5 läuft der Update Check jetzt gerade durch und updatet die 3RSM0147Z, dauert jetzt etwas, sind 5 Pflanzensensoren....
                        Danach schau ich mal, ob ich bei dem parameter ändern kann.
                        Übrigends flackert der Adapter dann auch wie bei @dimaiv und dann kommt oben geschriebenes Protokoll
                        • Peter V.P
                          Peter V.P
                          Peter V.
                          @asgothian
                          Nach Update auf 3.6.1 bei dem Sensor ein reconfig gemacht: geht. Parameter der LED geändert: geht.
                          Firmwarecheck angestoßen (global), gleicher Fehler wie bereits geschrieben (3.5.5 kein Fehler)
                          Kann man das Gerät vom OTA Check ausschließen? Möchte es ungern löschen.
                            müsstest du
                            A.
                            D
                            D
                            dimaiv
                            @Asgothian
                            bei mir sieht die Zeile aber so aus:
                            UpdateAdapterAlive(false); }, 500);
                            ist so Ok?
                            Aber hat nix geändert (100 auf 500)
                            Node.js v24.23.3
                            NPM v11.19.1
                            JS controller 7.2.5
                            Admin 8.3.15
                            • AsgothianA
                              AsgothianA
                              Asgothian
                              Ja, das war ok. Trotzdem seltsam.
                              Was der Code macht - er prüft ob der Adapter überhaupt antwortet. Mach mal bitte folgende Anpassung am admin.js:
                              aus
                              function sendToWrapper(target,command,msg,callback) {
                                  keepAlive(() => {
                                      if (connectionStatus.connected)
                                          sendTo(target,command,msg,callback);
                                      else if (callback) callback({error:'Cannot execute command - adapter is not running'});
                              muss
                              /*    keepAlive(() => {
                              werden - mal sehen wie er sich dann verhält.
                                aus
                                    keepAlive(() => {
                                muss
                                D
                                D
                                dimaiv
                                @Asgothian
                                ich mache es hier :
                                "/opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js"
                                ist doch richtig, oder?
                                Dann starte ich Raspberry komplett neu, es hat sich nix geändert, immer noch so.
                                Node.js v24.23.3
                                NPM v11.19.1
                                JS controller 7.2.5
                                Admin 8.3.15
                                • D dimaiv
                                  @Asgothian
                                  ich mache es hier :
                                  AsgothianA
                                  AsgothianA
                                  Asgothian
                                  @dimaiv sagte:
                                  @Asgothian
                                  ich mache es hier :
                                  Raspi neustarten ist nicht wichtig. Wichtig sind:
                                  • Upoad des Adapters
                                  • Neu Laden des Interface (idealerweise nach leeren des BrowserCache
                                  A.
                                    @dimaiv sagte:
                                    @Asgothian
                                    ich mache es hier :
                                    A.
                                    D
                                    D
                                    dimaiv
                                    @Asgothian
                                    Upload des Adapters hat gefehlt...
                                    Es hat sogar die erste Maßnahme:
                                    schon geholfen.
                                    Jetzt läuft es.
                                    Danke dir.
                                    Edit: reichen sogar 200. Es flackert nicht mehr und lässt sich gut bedienen.
                                    Node.js v24.23.3
                                    NPM v11.19.1
                                    JS controller 7.2.5
                                    Admin 8.3.15
                                    • D dimaiv
                                      @Asgothian
                                      schon geholfen.
                                      Jetzt läuft es.
                                      Danke dir.
                                      AsgothianA
                                      AsgothianA
                                      Asgothian
                                      @dimaiv sagte:
                                      Perfekt. Ich denke ich mach das User-Einstellbar. Dann kann das jeder auf die Antwortszeit seines ioBroker einstellen.
                                      A.
                                      • S
                                        S
                                        Shadowhunter23
                                        schrieb zuletzt editiert von
                                        Hallo asgothian,
                                        mit 3.6.1 (Converters 26.135.0, Herdsman 11.2.2) habe ich bei einem LAN-Koordinator (CC2652P2 über TCP-Serial-Server,
                                        ZStack3x0 20250321 / 2-1.2.7.1, 11 Geräte) folgendes Verhalten:
                                        Nach einem TCP-Abbruch verbindet sich der Adapter selbst wieder und meldet „Zigbee started“ – danach kommen aber
                                        keine Werte der Geräte mehr an. Erst ein Neustart der Instanz bringt sie zurück.
                                        Log (zigbee.1):
                                        15:09:37.892 error [zh:adapter:transport] TCP socket error: Error: read ECONNRESET
                                        15:09:37.892 error Adapter disconnected, stopping
                                        15:09:37.897 info  zigbecontroller stopped successfully - ZH was not running
                                        15:09:37.897 warn  Adapter stopped
                                        15:09:47.901 info  Try to reconnect.
                                        15:09:47.902 warn  zbcontroller start started 2 times
                                        15:09:47.902 info  Starting Zigbee-Herdsman
                                        15:09:48.080 info  Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20250321 (2-1.2.7.1)
                                        15:09:48.083 info  11 devices are part of the network
                                        15:09:48.318 info  Zigbee started
                                        Danach keine Gerätewerte mehr, bis die Instanz von Hand neu gestartet wurde.
                                        Heute kam das 11× (die TCP-Abbrüche selbst liegen vermutlich am Gateway, daran arbeite ich).
                                        Mit 3.6.1 lief dieselbe Instanz am Vortag ohne Abbruch, die anderen 4 Instanzen (gleiche Hardware, gleiche Version)
                                        hatten heute keinen Abbruch – das Wiederverbinden selbst habe ich deshalb nur auf dieser Instanz gesehen.
                                        Ist nach dem automatischen Reconnect ein vollständiger Neustart vorgesehen, oder sollte der Reconnect die Geräte wieder
                                        aufnehmen? Gern liefere ich ein Debug-Log, wenn es wieder auftritt.
                                        Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                                        ioBroker Backup Analyzer
                                        • S Shadowhunter23
                                          Hallo asgothian,
                                          Log (zigbee.1):
                                          AsgothianA
                                          AsgothianA
                                          Asgothian
                                          @Shadowhunter23 sagte:
                                          Nach dem automatischen Reconnect sollte nur das Zigbee subsystem neu starten. Kannst du bitte mal wenn keine Werte ankommen schauen ob es Fehlermeldungen im Log gibt, bzw. ein Gerät in DeviceDebug setzen und bei dem Gerät ein DeviceQuery auslösen ?
                                          \A.
                                          33.2k
                                          84.4k
