ZigBee Adapter CZC Zigbee Coordinator
Syslog CZC
[1212] | [ZB] Chip: CC2652P7 [1213] | [ZB] IEEE: 00:12:4B:00:2E:11:3D:9B [1224] | [ZB] Flash size: 704 KB [3799] | [Time] Fri Nov 20 14:44:33 2026 [3800] | [UPD_CHK] cron 21 0 1 * * * [4135] | [ZB] FW: 20250321 [4681] | [DNS] Saved ETH - 192.168.178.1 [14865] | [SOCK IP WHITELIST] Accepted connection from IP: 192.168.178.100 [14867] | [SOCK IP WHITELIST] Accepted connection from IP: 192.168.178.100 [14878] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [14889] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [14900] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [43878] | [SOCK IP WHITELIST] Accepted connection from IP: 192.168.178.100 [43881] | [SOCK IP WHITELIST] Accepted connection from IP: 192.168.178.100 [43892] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [43903] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [43914] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [72903] | [SOCK IP WHITELIST] Accepted connection from IP: 192.168.178.100 [72904] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [72916] | [SOCK IP WHITELIST] Accepted connection from IP: 192.168.178.100 [72927] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [72937] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [101940] | [SOCK IP WHITELIST] Accepted connection from IP: 192.168.178.100 [101941] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [101953] | [SOCK IP WHITELIST] Accepted connection from IP: 192.168.178.100 [101964] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [101975] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [130980] | [SOCK IP WHITELIST] Accepted connection from IP: 192.168.178.100 [130981] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [130992] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0 [131004] | [SOCK IP WHITELIST] Accepted connection from IP: 192.168.178.100 [131015] | [SOCK IP WHITELIST] Rejected connection from unknown IP: 0.0.0.0IOB LOG
zigbee.0 2026-11-20 14:51:31.072 warn zbcontroller start started 16 times zigbee.0 2026-11-20 14:51:31.072 info Installed Version: iobroker.zigbee@3.5.5 (Converters 26.128.0 Herdsman 10.10.0) zigbee.0 2026-11-20 14:51:31.071 info Starting Adapter npm ... zigbee.0 2026-11-20 14:51:31.071 info Try to reconnect. zigbee.0 2026-11-20 14:51:21.068 error Failed to start Zigbee: no message given zigbee.0 2026-11-20 14:51:21.068 error Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) zigbee.0 2026-11-20 14:51:21.063 info Network parameters on Coordinator: panID=<masked> channel=25 extendedPanID=<masked> zigbee.0 2026-11-20 14:51:21.063 info Network parameters in Config : panID=<masked> channel=25 extendedPanID=<masked> zigbee.0 2026-11-20 14:51:02.053 info Starting Zigbee-Herdsman zigbee.0 2026-11-20 14:51:02.052 info configured transmit power : high zigbee.0 2026-11-20 14:51:02.052 warn zbcontroller start started 15 times -
Welcher Router,
7590AX 7.51 Mesh Master
3000AX 7.51 Mesh Client (Lan1 iobroker / Lan2 CZC)
Matter over Thread ja (Amazon Echo 4 & Samsung Smartthinks)
Matter ja: IoBroker, Fritz-SmartGateway, Amazon Echo 4, Dreame, GoveeWie ist der CZC angebunden: LAN, Strom über USB
Springt die Gerätelaufzeit im CZC-Webinterface nach einem Ausfall zurück? Ja
Sind MQTT oder VPN im CZC aktiv? Nein
Reboot bringt keinen Erfolg, Stromlos machen leider nur kurzzeitig -
journalctl -u iobroker --since "2026-11-20" -o short-iso-precise > ~/iobroker-journal.log
keine Anzeige... also ihr lieben eins ist klar:
Houston wir haben ein Problem
kleine Update, evtl hat das etwas mit dem Fehler zu tun.
Im CZC-System-Sicherheit habe ich mal "IP-Whitelist für Socket" wieder raus genommen, auf Netzwerk umgeschaltet, jetzt läuft das Gerät seit ca 30 min ohne Aussetzer (vorher nach ca 5 min Verbindung verloren), ich beobachte weiter.
Update:
alle ca 30 min startet das Gerät (ESP32) neu, zu sehen in der Debug-Konsole.
Parallel habe ich dazu einen Ping laufen lassen und hatte für 2 sekunden einen Verbindungsverlust.
Entweder spukt hier was im Netzwerk rum, welches in den 30 min Abständen den ESP zum Absturz bringt, aber dann müssten auch die anderen ESP´s ausfallen (Sonoff Touch/Shelly/OpenDTU/WLED/ Luftsensoren etc).
Was ich im IOB-Log noch gefunden habe, direkt vor dem Ausfall meldet der Matter Adapter "Node3 connected".
Hat vielleicht was mit dem Issue auf GIT zu tun (https://github.com/codm/czc-fw/issues/15).
Ob beide Fehler zusammen hängen, kann ich nicht sagen. -
Update:
Ich hatte Anfang Oktober auch massive Probleme mit meinem CZC, zuerst wurde mein Zigbee Netz immer langsamer dann ist mir der CZC ständig abgestürzt teilweise alle paar Sekunden nach Neustart.
Ich habe Stunden mit Fehlersuche verbracht da der Fehler gefühlt sich auf mein ganzes Netzwerk ausgewirkt hat und es immer schlimmer wurde. Serverlast und Netzwerkverkehr deutlich gestiegen. Ich hab dann meinen Netzwerkverkehr geloggt und bin auf eine sehr hohe Anzahl von mDNS Paketen gestoßen. Es wurden so gut 30.000 Pakete in 10 Sekunden logging verschickt. Der Verursacher ist bei mir mein Fire TV Stick (4k Max) dieser fängt aktuell völlig das spinnen an (läuft aber an sich problemlos -streaming geht) und versendet diese Flut an mDNS Paketen. Nach einem Reboot geht es erstmal aber er fängt damit wieder an. Ich habe auch einen aktuellen Post gefunden bei Amazon Developers bei dem es genau um das Thema geht.
Ohne Stick im Netz läuft mein CZC jetzt wieder seit gut 12 Tagen problemlos durch.
Evtl habt ihr auch einen Amazon Stick im Netz der Amok läuft und euch den CZC abschießt... Nur so ein Gedanke bezüglich Spuk im Netzwerk... -
Evtl habt ihr auch einen Amazon Stick im Netz der Amok läuft und euch den CZC abschießt... Nur so ein Gedanke bezüglich Spuk im Netzwerk...Der Verursacher ist bei mir mein Fire TV Stick (4k Max)
... sehr interressant was du da schreibst. Ich habe auch einen Fire TV Stick 4k Max, aber schon was länger evt. und das lief auch alles und läuft immer noch. Vielleicht besteht da ja ein Zusammnehang mit Updates von Amazon?! Das könnte ne gut Spur sein.
Herzliche Grüße
FabioPS: An alle anderen die Frage habt ihr auch einen Fire TV Stick?
@fabio
Ja mein Stick hab ich bestimmt auch schon an die 2 Jahre, ich vermute auch ein Update weil er bisher völlig unauffällig war und keine Probleme verursacht hat.
Wäre ja super wenn es bei dir auch hilft.@Xsev interresant auch das hier:
Zitat:FRITZ!OS 8.51 behebt einen mDNS-Sturm im Zusammenspiel mit Amazon-Geräten (wie Echo oder Fire TV)
Eine Frage: per Lan oder Wlan bei dir und wenn ja, hast du auch einen Repeater von Fritz. So viele Pakete könnten den cod.m in die Knie zwingen wenn er keine richtige Verbindungen mehr bekommt.
Bei mir tritt das ja abends ab 21.00 UHr bis morgens extrem auf. Also werde ich heute Abend den Fire TV Stick Max vom Strom nehmen und schauen was die Cod.M machen. Auch wäre zu klären ob auch andere Amazon Geräte das machen.
Herzliche Grüße
Fabio -
Herzliche Grüße
Fabio -
Herzliche Grüße
Fabio@Fabio Ich habe meinen Stick via Ethernet Adapter also via Lan Kabel am Netz. Laut Amazon Dev Forum, scheint es in beiden Varianten also W-Lan und Lan aufzutreten.
Und ja ich habe auch einen Fritz Repeater und eine Fritz Box (Wlan Accespoint) im Netz. Größtenteils läuft alles über Unifi aber ein paar "Altlasten" hab ich noch im Netz. FritzOS muss ich mal prüfen was ich da habe. -
Das ist ne Idee, da aber leider für die Fritz4060 noch kein 8.51 zur Verfügung steht, muss ich wohl mal warten.
Für die 7590AX und den 3000AX gabs bereits das 8.51 Update.
FTV-4k Sticks habe ich 2 (1x 4k / 1x 4k2max) im Einsatz.
Wäre mal ein Ansatz zum testen. -
wow, hier mal ein Vergleich, einmal mit 4k2MAX und einmal ohne:
sudo timeout 10 tcpdump -i eno1 -n -q udp port 5353 | awk '{print $3}' | cut -d. -f1-4 | sort | uniq -c | sort -nr | headmit 4KMAX: listening on eno1, link-type EN10MB (Ethernet), snapshot length 262144 bytes 10196 packets captured 10204 packets received by filter 0 packets dropped by kernel 5297 192.168.178.165 4307 192.168.178.1 104 192.168.178.243 62 192.168.178.12 58 fe80::b2f2:8ff:fea8:f3d1.5353 52 2002:bc66:13c7:0:7f88:5a34:8712:c2a1.5353 24 192.168.178.241 24 192.168.178.18 24 192.168.178.114 20 192.168.178.207ohne 4K2MAX: listening on eno1, link-type EN10MB (Ethernet), snapshot length 262144 bytes 30 packets captured 30 packets received by filter 0 packets dropped by kernel 8 2002:bc66:13c7:0:3af7:3dff:fefd:e51a.5353 6 fe80::da33:b7ff:fee5:65f7.5353 6 192.168.178.214 2 2002:bc66:13c7:0:c28d:51ff:fe7f:f5b4.5353 2 2002:bc66:13c7:0:8628:59ff:fecd:b87.5353 2 2002:bc66:13c7:0:7f88:5a34:8712:c2a1.5353 2 2002:bc66:13c7:0:2210:b1ff:fed7:3e0f.5353 2 192.168.178.207 1 -
sudo timeout 10 tcpdump -i eno1 -n -q udp port 5353 | awk '{print $3}' | cut -d. -f1-4 | sort | uniq -c | sort -nr | headmit 4KMAX: listening on eno1, link-type EN10MB (Ethernet), snapshot length 262144 bytes 10196 packets captured 10204 packets received by filter 0 packets dropped by kernel 5297 192.168.178.165 4307 192.168.178.1 104 192.168.178.243 62 192.168.178.12 58 fe80::b2f2:8ff:fea8:f3d1.5353 52 2002:bc66:13c7:0:7f88:5a34:8712:c2a1.5353 24 192.168.178.241 24 192.168.178.18 24 192.168.178.114 20 192.168.178.207ohne 4K2MAX: listening on eno1, link-type EN10MB (Ethernet), snapshot length 262144 bytes 30 packets captured 30 packets received by filter 0 packets dropped by kernel 8 2002:bc66:13c7:0:3af7:3dff:fefd:e51a.5353 6 fe80::da33:b7ff:fee5:65f7.5353 6 192.168.178.214 2 2002:bc66:13c7:0:c28d:51ff:fe7f:f5b4.5353 2 2002:bc66:13c7:0:8628:59ff:fecd:b87.5353 2 2002:bc66:13c7:0:7f88:5a34:8712:c2a1.5353 2 2002:bc66:13c7:0:2210:b1ff:fed7:3e0f.5353 2 192.168.178.207 1@Peter-V.
Genau so sah es bei mir auch aus, hatte teils in 10 Sekunden bis zu 30.000 Pakete.
FireTV aus - Paketzahl unter 50.Ich sehe es sofort an meiner Serverauslastung, die steigt auf meinem Proxmox um den Faktor 3 wenn mein Fire TV läuft und so raus ballert.
@Peter-V.
@Xsev sag mal könnte ihr nicht mal den cod.m von euch auslesen wieviele Pakete da laufen? Das würde mich echt interessieren.
Herzliche Grüße
FabioIch habe meinen cod.m CZC über tcpdump am Proxmox-Host geprüft.
In 10 Sekunden wurden 0 mDNS-Pakete erfasst (5 vom Filter registriert). Aktuell sehe ich also keinen auffälligen mDNS-Verkehr vom cod.m.
Der Koordinator hängt direkt an meinem UniFi-Switch. Da Proxmox an einem anderen Port hängt, kann ich damit allerdings nicht den gesamten Netzwerkverkehr des cod.m erfassen.
Im Amazon Dev Forum sind die Leute (zurecht) ziemlich angepisst da es anscheinend auch mit der neuen Fritz Version Probs gibt und diese eindeutig vom Fire TV ausgehen. Amazon muss das mit ner neuen FW fixen denke ich. Die mDNS Flut zerlegt einfach das gesamte Netz auf Dauer... Gerade ESP Geräte scheinen recht sensibel auf das ganze zu reagieren.
