Test Adapter nspanel-lovelace-ui v2.x.x
Zeige mal das Log aus der Tasmota Konsole, vom Neustart an. Ob der Berry geladen wird.
00:00:00.003 HDW: ESP32-D0WD-V3 00:00:00.022 CFG: Loaded from NVS, Count 24421 00:00:00.027 Project tasmota - NSPanel-Flur Version 13.1.0(safeboot)-2_0_11(2023-08-15T07:58:37) 00:00:00.028 WARNING This version does not support persistent settings 00:00:00.683 WIF: Connecting to AP1 lesiflo Channel 1 BSSId 1C:ED:6F:56:6F:59 in mode 11n as Panel-Flur... 00:00:02.453 WIF: Connected 00:00:02.707 HTP: Web server active on Panel-Flur with IP address 192.168.2.178 20:05:51.582 MQT: Attempting connection... 20:05:52.138 MQT: Connected 20:05:52.142 MQT: NsPanelFlur/tele/LWT = Online (retained) 20:05:52.145 MQT: NsPanelFlur/cmnd/POWER = 20:05:52.149 MQT: NsPanelFlur/tele/INFO1 = {"Info1":{"Module":"ESP32-DevKit","Version":"13.1.0(safeboot)","FallbackTopic":"cmnd/Panel-Flur-32B994_fb/","GroupTopic":"NsPanelFlur/cmnd/"}} 20:05:52.162 MQT: NsPanelFlur/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"Panel-Flur","IPAddress":"192.168.2.178","IP6Global":"","IP6Local":"fe80::edc:7eff:fe32:b994"}} 20:05:52.175 MQT: NsPanelFlur/tele/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":415}} 20:05:52.542 MQT: NsPanelFlur/stat/RESULT = {"Command":"Error"} 20:05:52.691 MQT: NsPanelFlur/stat/RESULT = {"Command":"Unknown"} 20:05:52.740 MQT: NsPanelFlur/stat/RESULT = {"Command":"Error"} 20:05:52.790 MQT: NsPanelFlur/stat/RESULT = {"Command":"Unknown"} 20:05:53.014 MQT: NsPanelFlur/stat/STATUS0 = {"Status":{"Module":1,"DeviceName":"NSPanel-Flur","FriendlyName":["Panel-Flur"],"Topic":"nspanel_32B994","ButtonTopic":"0","Power":1,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:00:05","StartupUTC":"2026-11-12T19:05:47","Sleep":0,"CfgHolder":4617,"BootCount":414,"BCResetTime":"2022-12-03T14:18:14","SaveCount":24421},"StatusFWR":{"Version":"13.1.0(safeboot)","BuildDateTime":"2023-08-15T07:58:37","Core":"2_0_11","SDK":"4.4.5.230722","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 rev.3","CR":"407/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["lesiflo",""],"TelePeriod":60,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","20006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":801,"Free":30,"Heap":145,"StackLowMark":4,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["00000809","008005C0","00000003","00000002","00000000","00000000","40000000","00000000","00000000","00000000"],"Drivers":"1,2,8,82","Sensors":"2"},"StatusNET":{"Hostname":"Panel-Flur","IPAddress":"192.168.2.178","Gateway":"192.168.2.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.2.1","DNSServer2":"0.0.0.0","Mac":"0C:DC:7E:32:B9:94","IP6Global":"","IP6Local":"fe80::edc:7eff:fe32:b994","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.2.1","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0},"StatusMQT":{"MqttHost":"192.168.2.50","MqttPort":1884,"MqttClientMask":"Panel-Flur-32B994","MqttClient":"Panel-Flur-32B994","MqttUser":"iobroker","MqttCount":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2026-11-12T19:05:53","Local":"2026-11-12T20:05:53","StartDST":"2026-03-29T02:00:00","EndDST":"2026-10-25T03:00:00","Timezone":"+01:00"},"StatusSNS":{"Time":"2026-11-12T20:05:53"},"StatusSTS":{"Time":"2026-11-12T20:05:53","Uptime":"0T00:00:06","UptimeSec":6,"Heap":145,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":112,"MqttCount":1,"Wifi":{"AP":1,"SSId":"lesiflo","BSSId":"1C:ED:6F:56:6F:59","Channel":1,"Mode":"11n","RSSI":76,"Signal":-62,"LinkCount":1,"Downtime":"0T00:00:03"}}} 20:05:54.190 MQT: NsPanelFlur/stat/RESULT = {"TempOffset":0.0}Das läuft dann ständig immer wieder so durch
sieht aus als ob dein Berry Treiber fehlt. Sieh dir die Autoexec.be an, findest du unter Dateisystem verwalten. Was steht da drin?
# Sonoff NSPanel Tasmota Lovelace UI Berry Driver (improved Message Handling)| code by Armilar # based on; # Sonoff NSPanel Tasmota Lovelace UI Berry Driver (Extended Flashing to faster speeds; improved Error Handling)| code by joBr99 # based on; # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21 # based on; # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger # # v11 changes (Diagnose 2026-05-03 -> doc/diagnose_2026-05-03_final.md): # - Driver-Version: 10 -> 11 # - write_block cleanup condition: == -> >= (avoids 99.99% hang on partial last block) # - write_block wait-loop TIMEOUT: 30s -> 60s # - write_block: skip partial sub-block write when TIMEOUT hits before end-of-stream # - every_100ms: handle 5-byte combined frame {0x08, off0, off1, off2, off3} (Patch 8) # - open_url_at: header-read in loop until \r\n\r\n or 3s deadline (defensive race-fix) # - open_url_at: hard return -1 when headers==nil or flash_size<=0 # - try/except in write_block and every_100ms -> on exception: flash_mode=0, tcp.close() # Example Flash # FlashNextion http://nspanel.de/nspanel-vX.X.X.tft class Nextion : Driver static header = bytes('55BB') static flash_block_size = 4096 var flash_mode var flash_start_millis var flash_size var flash_written var flash_buff var flash_offset var flash_proto_version var flash_proto_baud var awaiting_offset var tcp var ser var last_per var url var _wb_count def split_55(b) var ret = [] var s = size(b) var i = s-2 # start from last-1 while i > 0 if b[i] == 0x55 && b[i+1] == 0xBB ret.push(b[i..s-1]) # push last msg to list b = b[(0..i-1)] # write the rest back to b end i -= 1 end ret.push(b) return ret end def crc16(data, poly) if !poly poly = 0xA001 end # CRC-16 MODBUS HASHING ALGORITHM var crc = 0xFFFF for i:0..size(data)-1 crc = crc ^ data[i] for j:0..7 if crc & 1 crc = (crc >> 1) ^ poly else crc = crc >> 1 end end end return crc end # encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc] def encode(payload) var b = bytes() b += self.header b.add(size(payload), 2) # add size as 2 bytes, little endian b += bytes().fromstring(payload) var msg_crc = self.crc16(b) b.add(msg_crc, 2) # crc 2 bytes, little endian return b end def encodenx(payload) var b = bytes().fromstring(payload) b += bytes('FFFFFF') return b end def sendnx(payload) import string var payload_bin = self.encodenx(payload) self.ser.write(payload_bin) log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3) end def send(payload) var payload_bin = self.encode(payload) if self.flash_mode==1 log("NXP: skipped command because still flashing", 3) else self.ser.write(payload_bin) log("NXP: payload sent = " + str(payload_bin), 3) end end def write_to_nextion(b) self.ser.write(b) end def screeninit() log("NXP: Screen Initialized") self.sendnx("recmod=1") end def write_block() import string try # diagnose-only ENTER-sample (auskommentiert nach v11-Verifikation 2026-05-04) #if self._wb_count == nil self._wb_count = 0 end #self._wb_count += 1 #if self._wb_count % 100 == 1 # log(string.format("FLH: write_block ENTER #%d buf=%d written=%d size=%d tcp_conn=%s avail=%d", # self._wb_count, size(self.flash_buff), self.flash_written, self.flash_size, # str(self.tcp.connected()), self.tcp.available()), 3) #end var wait_iters = 0 var wait_start = tasmota.millis() var timed_out = false while size(self.flash_buff)<self.flash_block_size && self.tcp.connected() if self.tcp.available()>0 self.flash_buff += self.tcp.readbytes(4096) else wait_iters += 1 tasmota.delay(50) #log("FLH: Wait for available...",4) if tasmota.millis() - wait_start > 60000 log(string.format("FLH: TIMEOUT in wait loop after %d iters, buf=%d, forcing exit", wait_iters, size(self.flash_buff)), 2) timed_out = true break end end end # diagnose-only waited-iters sample (auskommentiert) #if wait_iters > 100 # log(string.format("FLH: waited %d iters (%d ms) for tcp data, buf=%d tcp_conn=%s", # wait_iters, tasmota.millis()-wait_start, size(self.flash_buff), str(self.tcp.connected())), 3) #end var to_write if size(self.flash_buff)>self.flash_block_size to_write = self.flash_buff[0..self.flash_block_size-1] self.flash_buff = self.flash_buff[self.flash_block_size..] else # Sub-block write only allowed when: # - we did NOT timeout, OR # - this really is the end of the stream (would complete the flash) # Otherwise: skip — Nextion-Bootloader expects full 4096 blocks and would # ignore/queue a partial block, leaving us stuck. var is_end_of_stream = (self.flash_written + size(self.flash_buff)) >= self.flash_size if timed_out && !is_end_of_stream log(string.format("FLH: skip partial write after TIMEOUT (buf=%d, remaining=%d)", size(self.flash_buff), self.flash_size - self.flash_written), 2) return end to_write = self.flash_buff self.flash_buff = bytes() end var per = (self.flash_written*100)/self.flash_size if (self.last_per!=per) self.last_per = per tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": \"%d\", \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT") end if size(to_write)>0 self.flash_written += size(to_write) self.ser.write(to_write) end log("FLH: Read block - Writing: "+str(size(to_write))+" - Total: "+str(self.flash_written)+" - Buffer size: "+str(size(self.flash_buff)) ,3) # diagnose-only EXIT-sample (auskommentiert) #if self._wb_count != nil && self._wb_count % 100 == 1 # log(string.format("FLH: write_block EXIT #%d remain=%d tcp_conn=%s", # self._wb_count, self.flash_size - self.flash_written, str(self.tcp.connected())), 3) #end if self.flash_written > self.flash_size self.flash_written = self.flash_size end if (self.flash_written>=self.flash_size) tasmota.delay(25) log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000) tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": \"done\", \"time_elapsed\": %d}}", (tasmota.millis()-self.flash_start_millis)/1000), "RESULT") tasmota.cmd('RuleTimer3 120') tasmota.cmd('Rule3 1') tasmota.delay(50) self.flash_mode = 0 self.ser.deinit() self.ser = serial(17, 16, 115200, serial.SERIAL_8N1) end except .. as e, m log("FLH: write_block EXCEPTION "+str(e)+" "+str(m), 1) self.flash_mode = 0 if self.tcp != nil self.tcp.close() end end end def every_100ms() import string try if self.ser.available() > 0 var msg = self.ser.read() if size(msg) > 0 log(string.format("NXP: Received Raw = %s",str(msg)), 4) if (self.flash_mode==1) var strv = msg[0..-4].asstring() if string.find(strv,"comok 2")>=0 tasmota.delay(20) log("FLH: Send (High Speed) flash start") self.flash_start_millis = tasmota.millis() if self.flash_proto_version == 0 self.sendnx(string.format("whmi-wri %d,%d,res0",self.flash_size,self.flash_proto_baud)) else self.sendnx(string.format("whmi-wris %d,%d,res0",self.flash_size,self.flash_proto_baud)) end if self.flash_proto_baud != 115200 tasmota.delay(20) self.ser.deinit() self.ser = serial(17, 16, self.flash_proto_baud, serial.SERIAL_8N1) end elif size(msg)==1 && msg[0]==0x08 log("FLH: Waiting offset...",3) self.awaiting_offset = 1 elif size(msg)==4 && self.awaiting_offset==1 self.awaiting_offset = 0 self.flash_offset = msg.get(0,4) log("FLH: Flash offset marker "+str(self.flash_offset),3) if self.flash_offset != 0 self.open_url_at(self.url, self.flash_offset) self.flash_written = self.flash_offset end self.write_block() elif size(msg)==5 && msg[0]==0x08 # Patch 8: 5-byte combined frame {0x08, off0..off3} self.awaiting_offset = 0 self.flash_offset = msg[1..4].get(0,4) log("FLH: Flash offset marker (combined 5B) "+str(self.flash_offset),3) if self.flash_offset != 0 self.open_url_at(self.url, self.flash_offset) self.flash_written = self.flash_offset end self.write_block() elif size(msg)==1 && msg[0]==0x05 self.write_block() else log(string.format("FLH: UNKNOWN display response in flash_mode (size=%d, hex=%s)", size(msg), str(msg)), 2) if self.flash_size > 0 var per_done = (self.flash_written * 100) / self.flash_size if per_done >= 99 log(string.format("FLH: late-stage unknown msg at %d%% (written=%d size=%d)", per_done, self.flash_written, self.flash_size), 2) end end end else var msg_list = self.split_55(msg) for i:0..size(msg_list)-1 msg = msg_list[i] if size(msg) > 0 if msg == bytes('000000FFFFFF88FFFFFF') self.screeninit() elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring()) tasmota.publish_result(jm, "RESULT") elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer tasmota.cmd("buzzer 1,1") else var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4])) tasmota.publish_result(jm, "RESULT") end end end end end end except .. as e, m log("FLH: every_100ms EXCEPTION "+str(e)+" "+str(m), 1) if self.flash_mode == 1 self.flash_mode = 0 if self.tcp != nil self.tcp.close() end end end end def begin_nextion_flash() tasmota.cmd('RuleTimer3 0') tasmota.cmd('Rule3 0') self.flash_written = 0 self.awaiting_offset = 0 self.flash_offset = 0 self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN') self.sendnx('recmod=0') self.flash_mode = 1 self.sendnx("connect") end def open_url_at(url, pos) self.url = url import string var host var port var s1 = string.split(url,7)[1] var i = string.find(s1,":") var sa if i<0 port = 80 i = string.find(s1,"/") sa = string.split(s1,i) host = sa[0] else sa = string.split(s1,i) host = sa[0] s1 = string.split(sa[1],1)[1] i = string.find(s1,"/") sa = string.split(s1,i) port = int(sa[0]) end var get = sa[1] log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get)) self.tcp = tcpclient() self.tcp.connect(host,port) log("FLH: Connected:"+str(self.tcp.connected()),3) var get_req = "GET "+get+" HTTP/1.0\r\n" get_req += string.format("Range: bytes=%d-\r\n", pos) get_req += string.format("HOST: %s:%s\r\n\r\n",host,port) self.tcp.write(get_req) # v11 defensive: read in loop until \r\n\r\n marker found or 3s deadline var b = bytes() var deadline = tasmota.millis() + 3000 var headers var header_end = -1 while tasmota.millis() < deadline && headers == nil if self.tcp.available() > 0 b += self.tcp.readbytes() var k = 0 while k <= size(b) - 4 && headers == nil if b[k..(k+3)] == bytes().fromstring("\r\n\r\n") headers = b[0..(k+3)].asstring() self.flash_buff = b[(k+4)..] header_end = k end k += 1 end else tasmota.delay(50) end end # diagnose-only header-bytes trace (auskommentiert) #log(string.format("FLH: header read total bytes %d", size(b)), 3) if headers == nil var preview_len = size(b) if preview_len > 120 preview_len = 120 end if preview_len > 0 log(string.format("FLH: NO header marker in %d bytes; first %d as string: %s", size(b), preview_len, b[0..preview_len-1].asstring()), 2) else log("FLH: NO header marker, no bytes read at all", 2) end log("FLH: HTTP header incomplete - aborting", 2) self.tcp.close() return -1 end # diagnose-only header-found trace (auskommentiert) #log(string.format("FLH: header found at byte %d (header=%d B, body remainder=%d B)", # header_end, size(headers), size(self.flash_buff)), 3) # check http response for code 200/206 if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0 log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3) else log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3) print(headers) self.tcp.close() return -1 end # only set flash size if pos is zero if pos == 0 # check http response for content-length var tag = "Content-Length: " i = string.find(headers,tag) # diagnose-only Content-Length-Parse trace (auskommentiert) #log(string.format("FLH: find('Content-Length: ') = %d", i), 3) if (i>0) var i2 = string.find(headers,"\r\n",i) var s = headers[i+size(tag)..i2-1] #log(string.format("FLH: content-length slice = '%s' (len=%d)", s, size(s)), 3) self.flash_size=int(s) #log(string.format("FLH: int(s) = %d", self.flash_size), 3) end log("FLH: Flash file size: "+str(self.flash_size),3) # v11 hard guard: never proceed with bogus size if self.flash_size == nil || self.flash_size <= 0 log("FLH: Content-Length missing or zero - aborting", 2) self.tcp.close() return -1 end end end def flash_nextion(url) self.flash_size = 0 var res = self.open_url_at(url, 0) if res != -1 self.begin_nextion_flash() end end def init() log("NXP: Initializing Driver") self.ser = serial(17, 16, 115200, serial.SERIAL_8N1) self.flash_mode = 0 self.flash_proto_version = 1 self.flash_proto_baud = 921600 self._wb_count = 0 end end var nextion = Nextion() tasmota.add_driver(nextion) def get_current_version(cmd, idx, payload, payload_json) import string var version_of_this_script = 11 var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script) tasmota.publish_result(jm, "RESULT") end tasmota.add_cmd('GetDriverVersion', get_current_version) def update_berry_driver(cmd, idx, payload, payload_json) def task() import path import string if string.find(payload, ".tapp") > 0 print("tapp in URL; will do .tapp update and migration if necessary") if path.exists("autoexec.be") print("autoexec.be found; will check for migration") var autoexecfile = open('autoexec.be') var line = autoexecfile.readline() autoexecfile.close() if string.find(line, "NSPanel Tasmota Lovelace UI Berry Driver") > 0 print("found lovelace berry driver, going to delete autoexec.be and .bec") path.remove("autoexec.be") path.remove("autoexec.bec") end end var r = tasmota.urlfetch(payload, "nsp-lovelace-driver.tapp") if r < 0 print("Update failed") else tasmota.cmd("Restart 1") end elif string.find(payload, ".be") > 0 print("be in URL; will do .be update") if path.exists("nsp-lovelace-driver.tapp") print("Error: there is the tapp version of the berry driver installed; cannot do .be update.") else var cl = webclient() cl.begin(payload) var r = cl.GET() if r == 200 print("Sucessfully downloaded nspanel-lovelace-ui berry driver") else print("Error while downloading nspanel-lovelace-ui berry driver") end r = cl.write_file("autoexec.be") if r < 0 print("Error while writeing nspanel-lovelace-ui berry driver") else print("Sucessfully written nspanel-lovelace-ui berry driver") tasmota.cmd("Restart 1") end end else print("invalid url filetype") end if path.exists("nsp-lovelace-driver.tapp") var r = string.find(payload, ".tapp") if r < 0 print("URL doesn't contain .tapp skipping update") else end else var r = string.find(payload, ".be") if r < 0 print("URL doesn't contain .be skipping update") else end end end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end tasmota.add_cmd('UpdateDriverVersion', update_berry_driver) def flash_nextion(cmd, idx, payload, payload_json) def task() nextion.flash_proto_version = 1 nextion.flash_proto_baud = 921600 nextion.flash_nextion(payload) end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end def flash_nextion_adv(cmd, idx, payload, payload_json) def task() if idx==0 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 921600 elif idx==1 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 921600 elif idx==2 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 115200 elif idx==3 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 115200 elif idx==4 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 256000 elif idx==5 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 256000 elif idx==6 nextion.ser.deinit() nextion.ser = serial(17, 16, 9600, serial.SERIAL_8N1) nextion.flash_proto_version = 0 nextion.flash_proto_baud = 921600 else nextion.flash_proto_version = 0 nextion.flash_proto_baud = 115200 end nextion.flash_nextion(payload) end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end def send_cmd(cmd, idx, payload, payload_json) nextion.sendnx(payload) tasmota.resp_cmnd_done() end def send_cmd2(cmd, idx, payload, payload_json) nextion.send(payload) tasmota.resp_cmnd_done() end tasmota.add_cmd('Nextion', send_cmd) tasmota.add_cmd('CustomSend', send_cmd2) tasmota.add_cmd('FlashNextion', flash_nextion) tasmota.add_cmd('FlashNextionAdv', flash_nextion_adv) -
# Sonoff NSPanel Tasmota Lovelace UI Berry Driver (improved Message Handling)| code by Armilar # based on; # Sonoff NSPanel Tasmota Lovelace UI Berry Driver (Extended Flashing to faster speeds; improved Error Handling)| code by joBr99 # based on; # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21 # based on; # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger # # v11 changes (Diagnose 2026-05-03 -> doc/diagnose_2026-05-03_final.md): # - Driver-Version: 10 -> 11 # - write_block cleanup condition: == -> >= (avoids 99.99% hang on partial last block) # - write_block wait-loop TIMEOUT: 30s -> 60s # - write_block: skip partial sub-block write when TIMEOUT hits before end-of-stream # - every_100ms: handle 5-byte combined frame {0x08, off0, off1, off2, off3} (Patch 8) # - open_url_at: header-read in loop until \r\n\r\n or 3s deadline (defensive race-fix) # - open_url_at: hard return -1 when headers==nil or flash_size<=0 # - try/except in write_block and every_100ms -> on exception: flash_mode=0, tcp.close() # Example Flash # FlashNextion http://nspanel.de/nspanel-vX.X.X.tft class Nextion : Driver static header = bytes('55BB') static flash_block_size = 4096 var flash_mode var flash_start_millis var flash_size var flash_written var flash_buff var flash_offset var flash_proto_version var flash_proto_baud var awaiting_offset var tcp var ser var last_per var url var _wb_count def split_55(b) var ret = [] var s = size(b) var i = s-2 # start from last-1 while i > 0 if b[i] == 0x55 && b[i+1] == 0xBB ret.push(b[i..s-1]) # push last msg to list b = b[(0..i-1)] # write the rest back to b end i -= 1 end ret.push(b) return ret end def crc16(data, poly) if !poly poly = 0xA001 end # CRC-16 MODBUS HASHING ALGORITHM var crc = 0xFFFF for i:0..size(data)-1 crc = crc ^ data[i] for j:0..7 if crc & 1 crc = (crc >> 1) ^ poly else crc = crc >> 1 end end end return crc end # encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc] def encode(payload) var b = bytes() b += self.header b.add(size(payload), 2) # add size as 2 bytes, little endian b += bytes().fromstring(payload) var msg_crc = self.crc16(b) b.add(msg_crc, 2) # crc 2 bytes, little endian return b end def encodenx(payload) var b = bytes().fromstring(payload) b += bytes('FFFFFF') return b end def sendnx(payload) import string var payload_bin = self.encodenx(payload) self.ser.write(payload_bin) log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3) end def send(payload) var payload_bin = self.encode(payload) if self.flash_mode==1 log("NXP: skipped command because still flashing", 3) else self.ser.write(payload_bin) log("NXP: payload sent = " + str(payload_bin), 3) end end def write_to_nextion(b) self.ser.write(b) end def screeninit() log("NXP: Screen Initialized") self.sendnx("recmod=1") end def write_block() import string try # diagnose-only ENTER-sample (auskommentiert nach v11-Verifikation 2026-05-04) #if self._wb_count == nil self._wb_count = 0 end #self._wb_count += 1 #if self._wb_count % 100 == 1 # log(string.format("FLH: write_block ENTER #%d buf=%d written=%d size=%d tcp_conn=%s avail=%d", # self._wb_count, size(self.flash_buff), self.flash_written, self.flash_size, # str(self.tcp.connected()), self.tcp.available()), 3) #end var wait_iters = 0 var wait_start = tasmota.millis() var timed_out = false while size(self.flash_buff)<self.flash_block_size && self.tcp.connected() if self.tcp.available()>0 self.flash_buff += self.tcp.readbytes(4096) else wait_iters += 1 tasmota.delay(50) #log("FLH: Wait for available...",4) if tasmota.millis() - wait_start > 60000 log(string.format("FLH: TIMEOUT in wait loop after %d iters, buf=%d, forcing exit", wait_iters, size(self.flash_buff)), 2) timed_out = true break end end end # diagnose-only waited-iters sample (auskommentiert) #if wait_iters > 100 # log(string.format("FLH: waited %d iters (%d ms) for tcp data, buf=%d tcp_conn=%s", # wait_iters, tasmota.millis()-wait_start, size(self.flash_buff), str(self.tcp.connected())), 3) #end var to_write if size(self.flash_buff)>self.flash_block_size to_write = self.flash_buff[0..self.flash_block_size-1] self.flash_buff = self.flash_buff[self.flash_block_size..] else # Sub-block write only allowed when: # - we did NOT timeout, OR # - this really is the end of the stream (would complete the flash) # Otherwise: skip — Nextion-Bootloader expects full 4096 blocks and would # ignore/queue a partial block, leaving us stuck. var is_end_of_stream = (self.flash_written + size(self.flash_buff)) >= self.flash_size if timed_out && !is_end_of_stream log(string.format("FLH: skip partial write after TIMEOUT (buf=%d, remaining=%d)", size(self.flash_buff), self.flash_size - self.flash_written), 2) return end to_write = self.flash_buff self.flash_buff = bytes() end var per = (self.flash_written*100)/self.flash_size if (self.last_per!=per) self.last_per = per tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": \"%d\", \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT") end if size(to_write)>0 self.flash_written += size(to_write) self.ser.write(to_write) end log("FLH: Read block - Writing: "+str(size(to_write))+" - Total: "+str(self.flash_written)+" - Buffer size: "+str(size(self.flash_buff)) ,3) # diagnose-only EXIT-sample (auskommentiert) #if self._wb_count != nil && self._wb_count % 100 == 1 # log(string.format("FLH: write_block EXIT #%d remain=%d tcp_conn=%s", # self._wb_count, self.flash_size - self.flash_written, str(self.tcp.connected())), 3) #end if self.flash_written > self.flash_size self.flash_written = self.flash_size end if (self.flash_written>=self.flash_size) tasmota.delay(25) log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000) tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": \"done\", \"time_elapsed\": %d}}", (tasmota.millis()-self.flash_start_millis)/1000), "RESULT") tasmota.cmd('RuleTimer3 120') tasmota.cmd('Rule3 1') tasmota.delay(50) self.flash_mode = 0 self.ser.deinit() self.ser = serial(17, 16, 115200, serial.SERIAL_8N1) end except .. as e, m log("FLH: write_block EXCEPTION "+str(e)+" "+str(m), 1) self.flash_mode = 0 if self.tcp != nil self.tcp.close() end end end def every_100ms() import string try if self.ser.available() > 0 var msg = self.ser.read() if size(msg) > 0 log(string.format("NXP: Received Raw = %s",str(msg)), 4) if (self.flash_mode==1) var strv = msg[0..-4].asstring() if string.find(strv,"comok 2")>=0 tasmota.delay(20) log("FLH: Send (High Speed) flash start") self.flash_start_millis = tasmota.millis() if self.flash_proto_version == 0 self.sendnx(string.format("whmi-wri %d,%d,res0",self.flash_size,self.flash_proto_baud)) else self.sendnx(string.format("whmi-wris %d,%d,res0",self.flash_size,self.flash_proto_baud)) end if self.flash_proto_baud != 115200 tasmota.delay(20) self.ser.deinit() self.ser = serial(17, 16, self.flash_proto_baud, serial.SERIAL_8N1) end elif size(msg)==1 && msg[0]==0x08 log("FLH: Waiting offset...",3) self.awaiting_offset = 1 elif size(msg)==4 && self.awaiting_offset==1 self.awaiting_offset = 0 self.flash_offset = msg.get(0,4) log("FLH: Flash offset marker "+str(self.flash_offset),3) if self.flash_offset != 0 self.open_url_at(self.url, self.flash_offset) self.flash_written = self.flash_offset end self.write_block() elif size(msg)==5 && msg[0]==0x08 # Patch 8: 5-byte combined frame {0x08, off0..off3} self.awaiting_offset = 0 self.flash_offset = msg[1..4].get(0,4) log("FLH: Flash offset marker (combined 5B) "+str(self.flash_offset),3) if self.flash_offset != 0 self.open_url_at(self.url, self.flash_offset) self.flash_written = self.flash_offset end self.write_block() elif size(msg)==1 && msg[0]==0x05 self.write_block() else log(string.format("FLH: UNKNOWN display response in flash_mode (size=%d, hex=%s)", size(msg), str(msg)), 2) if self.flash_size > 0 var per_done = (self.flash_written * 100) / self.flash_size if per_done >= 99 log(string.format("FLH: late-stage unknown msg at %d%% (written=%d size=%d)", per_done, self.flash_written, self.flash_size), 2) end end end else var msg_list = self.split_55(msg) for i:0..size(msg_list)-1 msg = msg_list[i] if size(msg) > 0 if msg == bytes('000000FFFFFF88FFFFFF') self.screeninit() elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring()) tasmota.publish_result(jm, "RESULT") elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer tasmota.cmd("buzzer 1,1") else var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4])) tasmota.publish_result(jm, "RESULT") end end end end end end except .. as e, m log("FLH: every_100ms EXCEPTION "+str(e)+" "+str(m), 1) if self.flash_mode == 1 self.flash_mode = 0 if self.tcp != nil self.tcp.close() end end end end def begin_nextion_flash() tasmota.cmd('RuleTimer3 0') tasmota.cmd('Rule3 0') self.flash_written = 0 self.awaiting_offset = 0 self.flash_offset = 0 self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN') self.sendnx('recmod=0') self.flash_mode = 1 self.sendnx("connect") end def open_url_at(url, pos) self.url = url import string var host var port var s1 = string.split(url,7)[1] var i = string.find(s1,":") var sa if i<0 port = 80 i = string.find(s1,"/") sa = string.split(s1,i) host = sa[0] else sa = string.split(s1,i) host = sa[0] s1 = string.split(sa[1],1)[1] i = string.find(s1,"/") sa = string.split(s1,i) port = int(sa[0]) end var get = sa[1] log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get)) self.tcp = tcpclient() self.tcp.connect(host,port) log("FLH: Connected:"+str(self.tcp.connected()),3) var get_req = "GET "+get+" HTTP/1.0\r\n" get_req += string.format("Range: bytes=%d-\r\n", pos) get_req += string.format("HOST: %s:%s\r\n\r\n",host,port) self.tcp.write(get_req) # v11 defensive: read in loop until \r\n\r\n marker found or 3s deadline var b = bytes() var deadline = tasmota.millis() + 3000 var headers var header_end = -1 while tasmota.millis() < deadline && headers == nil if self.tcp.available() > 0 b += self.tcp.readbytes() var k = 0 while k <= size(b) - 4 && headers == nil if b[k..(k+3)] == bytes().fromstring("\r\n\r\n") headers = b[0..(k+3)].asstring() self.flash_buff = b[(k+4)..] header_end = k end k += 1 end else tasmota.delay(50) end end # diagnose-only header-bytes trace (auskommentiert) #log(string.format("FLH: header read total bytes %d", size(b)), 3) if headers == nil var preview_len = size(b) if preview_len > 120 preview_len = 120 end if preview_len > 0 log(string.format("FLH: NO header marker in %d bytes; first %d as string: %s", size(b), preview_len, b[0..preview_len-1].asstring()), 2) else log("FLH: NO header marker, no bytes read at all", 2) end log("FLH: HTTP header incomplete - aborting", 2) self.tcp.close() return -1 end # diagnose-only header-found trace (auskommentiert) #log(string.format("FLH: header found at byte %d (header=%d B, body remainder=%d B)", # header_end, size(headers), size(self.flash_buff)), 3) # check http response for code 200/206 if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0 log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3) else log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3) print(headers) self.tcp.close() return -1 end # only set flash size if pos is zero if pos == 0 # check http response for content-length var tag = "Content-Length: " i = string.find(headers,tag) # diagnose-only Content-Length-Parse trace (auskommentiert) #log(string.format("FLH: find('Content-Length: ') = %d", i), 3) if (i>0) var i2 = string.find(headers,"\r\n",i) var s = headers[i+size(tag)..i2-1] #log(string.format("FLH: content-length slice = '%s' (len=%d)", s, size(s)), 3) self.flash_size=int(s) #log(string.format("FLH: int(s) = %d", self.flash_size), 3) end log("FLH: Flash file size: "+str(self.flash_size),3) # v11 hard guard: never proceed with bogus size if self.flash_size == nil || self.flash_size <= 0 log("FLH: Content-Length missing or zero - aborting", 2) self.tcp.close() return -1 end end end def flash_nextion(url) self.flash_size = 0 var res = self.open_url_at(url, 0) if res != -1 self.begin_nextion_flash() end end def init() log("NXP: Initializing Driver") self.ser = serial(17, 16, 115200, serial.SERIAL_8N1) self.flash_mode = 0 self.flash_proto_version = 1 self.flash_proto_baud = 921600 self._wb_count = 0 end end var nextion = Nextion() tasmota.add_driver(nextion) def get_current_version(cmd, idx, payload, payload_json) import string var version_of_this_script = 11 var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script) tasmota.publish_result(jm, "RESULT") end tasmota.add_cmd('GetDriverVersion', get_current_version) def update_berry_driver(cmd, idx, payload, payload_json) def task() import path import string if string.find(payload, ".tapp") > 0 print("tapp in URL; will do .tapp update and migration if necessary") if path.exists("autoexec.be") print("autoexec.be found; will check for migration") var autoexecfile = open('autoexec.be') var line = autoexecfile.readline() autoexecfile.close() if string.find(line, "NSPanel Tasmota Lovelace UI Berry Driver") > 0 print("found lovelace berry driver, going to delete autoexec.be and .bec") path.remove("autoexec.be") path.remove("autoexec.bec") end end var r = tasmota.urlfetch(payload, "nsp-lovelace-driver.tapp") if r < 0 print("Update failed") else tasmota.cmd("Restart 1") end elif string.find(payload, ".be") > 0 print("be in URL; will do .be update") if path.exists("nsp-lovelace-driver.tapp") print("Error: there is the tapp version of the berry driver installed; cannot do .be update.") else var cl = webclient() cl.begin(payload) var r = cl.GET() if r == 200 print("Sucessfully downloaded nspanel-lovelace-ui berry driver") else print("Error while downloading nspanel-lovelace-ui berry driver") end r = cl.write_file("autoexec.be") if r < 0 print("Error while writeing nspanel-lovelace-ui berry driver") else print("Sucessfully written nspanel-lovelace-ui berry driver") tasmota.cmd("Restart 1") end end else print("invalid url filetype") end if path.exists("nsp-lovelace-driver.tapp") var r = string.find(payload, ".tapp") if r < 0 print("URL doesn't contain .tapp skipping update") else end else var r = string.find(payload, ".be") if r < 0 print("URL doesn't contain .be skipping update") else end end end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end tasmota.add_cmd('UpdateDriverVersion', update_berry_driver) def flash_nextion(cmd, idx, payload, payload_json) def task() nextion.flash_proto_version = 1 nextion.flash_proto_baud = 921600 nextion.flash_nextion(payload) end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end def flash_nextion_adv(cmd, idx, payload, payload_json) def task() if idx==0 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 921600 elif idx==1 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 921600 elif idx==2 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 115200 elif idx==3 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 115200 elif idx==4 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 256000 elif idx==5 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 256000 elif idx==6 nextion.ser.deinit() nextion.ser = serial(17, 16, 9600, serial.SERIAL_8N1) nextion.flash_proto_version = 0 nextion.flash_proto_baud = 921600 else nextion.flash_proto_version = 0 nextion.flash_proto_baud = 115200 end nextion.flash_nextion(payload) end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end def send_cmd(cmd, idx, payload, payload_json) nextion.sendnx(payload) tasmota.resp_cmnd_done() end def send_cmd2(cmd, idx, payload, payload_json) nextion.send(payload) tasmota.resp_cmnd_done() end tasmota.add_cmd('Nextion', send_cmd) tasmota.add_cmd('CustomSend', send_cmd2) tasmota.add_cmd('FlashNextion', flash_nextion) tasmota.add_cmd('FlashNextionAdv', flash_nextion_adv)Abhilfe: Im Safeboot-Webinterface (http://192.168.2.178) unter Firmware Upgrade die normale NSPanel-Firmware einspielen:
- per OTA-URL http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin
- oder die .bin hochladen.
Danach startet das Panel normal, autoexec.be wird geladen und das Display kommt wieder. Die Einstellungen liegen im NVS (CFG: Loaded from NVS) und
sollten erhalten bleiben. Dabei kommt er gleich von der alten 13.1.0 weg.Das ist von claude - hätte ich so aber auch ohne claude versucht, nur war mir nicht sicher.
2.2.0 (2026-11-12)
- (ticaki) Web-Panel: Smartphone-Modelle
web-pundweb-l, Hochformat-Layout für alle Karten, Popups und Bildschirmschoner auf us-p/web-p, die Hardware-Tasten lassen sich abschalten, viele Layout-Korrekturen; kein Absturz mehr bei der ersten Verbindung, weniger Log-Meldungen ohne Browser - (ticaki) Admin: Konfiguration eines Panels exportieren und importieren (zusammenführen oder komplett überschreiben, Konfliktübersicht, PINs und Passwörter nur auf ausdrücklichen Wunsch)
- (ticaki) Bildschirmschoner: eigene Aktion bei langem Drücken und eigene Icon-Schrift für Indikatoren (TFT 6.0.9), neue Indikator-Aktion „Werte durchschalten“, Vorlagen für Müllabfuhrtermine
text.trash.next/text.trash.afterNext - (ticaki) Bildschirmschoner: Ein Indikator reagiert nur noch, wenn eine Aktion eingestellt ist, die Option „Indikatoren als Taster“ entfällt – bitte eure Indikatoren prüfen
- (ticaki) Bildschirmschoner: Es wird nur noch gesendet, was sich geändert hat, ein Tastendruck zeigt sein Ergebnis sofort; Korrekturen für Indikatoren mit TFT 6.0.8/6.1.0, Sonnenaufgang von Bright Sky, Batterie-Icons und die Farbskala im Admin
- (ticaki) Admin: Die Farben folgen dem Farbthema der Instanz, Entwickler-Tab mit „Teststates anlegen“
- (ticaki) Navigation: Ein fehlendes Ziel öffnet die Systemseite „Nav error“; die Service-Seite bringt die Navigation mehrerer Panels nicht mehr durcheinander
- (ticaki) Panel: Tasmota-Safeboot wird erkannt, Nachrichten über 1017 Byte werden gemeldet, lange Überschriften werden mit … gekürzt
- (ticaki) Korrekturen: Status-Datenpunkt neuer Alarm-/Unlock-Seiten, Emulator-Erkennung, weniger Info-Logs beim Start
- (tt-tom17) Admin: Editoren der QR-, Chart-, Müll- und Menüseiten überarbeitet (klarere Beschriftungen, Menüvorschau wie auf dem Panel, „Auswahl übernehmen“ der Müllseite befüllt die Seite vollständig), restliche feste Texte übersetzt
- (tt-tom17) pageQR: WPA2 ist die Standard-Verschlüsselung fürs WLAN
Wer bisher Indikatoren ohne Aktion als Schalter benutzt hat: Dort jetzt eine Aktion (z. B. „Datenpunkt umschalten“) einstellen.
Update hat geklappt, Meldung im Adapter aber bleibt so und Anzeige weiterhin schwarz
Nachdem ich im Webinterface kurz auf Informationen gegangen bin war wieder die vorherige Version aktiv. Und auch wieder Safeboot-Schleife in der Console.
Ich würde mla folgendes Probieren - ausgehend davon das der verwendete Adapter das schon kann:
Panel in maintain deaktivieren
Tasmota updaten - mindestens 1 Minute warten
auf Nspanel Einstellungen die panel einstellungen aktualisieren (tamota einstellung, berry und tft wird geflasht). siehe bild - auf den stift und dann auf aktualisieren
panel aktivieren -
Hab's jetzt hinbekommen. Nachdem ich hier auf Typ "Panel-Flur" eingestellt hatte ging es wieder. Mein 2. Panel hatte nach Restart den gleichen Fehler
Okay, danke für die Rückmeldung. Werde es mal notieren, als Fehlerquelle. Was stand da dann vorher drin, weißt du das noch?
NSPanel Lovelace UI 2.3.0
Das Wichtigste in Kürze
- Berry-Treiber 12 ist da, und alles ist vorbereitet für TFT 6.1.0: Mit dem kommenden TFT bestätigt das Display jede Nachricht, Seiten und Screensaver bauen sich dann deutlich schneller auf. Bis dahin läuft alles wie gewohnt mit TFT 6.0.9.
- Screensaver aktualisiert schneller, veraltete Werte stauen sich nicht mehr.
- Sauberer Adapterstart: ein Startup pro Panel statt mehrfach neu startender Animation.
- Statustexte, Einheiten & Co. werden ohne Adapterneustart übernommen.
- Admin: Berry-Treiber-Update im Tab Wartung, Seitenfilter und Suche im Navigationsfluss.
- ⚠️ Bitte prüfen: Der linke Button der Popup-Benachrichtigung schreibt jetzt wie die anderen Buttons. Skripte, die den lokalen Datenpunkt auswerten, müssen ggf. angepasst werden.
- Admin >= 8.1.0 wird vorausgesetzt.
Changelog
Panel & Display
- (ticaki) Vorbereitet für TFT 6.1.0: Zusammen mit Berry-Treiber 12 bestätigt das Display dann jede Nachricht mit ihrer Prüfsumme, und der Adapter schickt die nächste sofort statt nach 250 ms. Seiten und Screensaver bauen sich damit spürbar schneller auf. Der Screensaver übernimmt seine Farben schon beim Seitenwechsel (kein schwarzes Aufblitzen), der Screensaver „advanced“ folgt dem Farbthema. Ältere TFTs werden erkannt und wie bisher bedient.
- (ticaki) Berry-Treiber 12 (auch Emulator-Berry): schnellere Prüfsumme, die der Adapter fertig mitliefern kann; eine über zwei serielle Lesevorgänge verteilte Nachricht geht nicht mehr verloren. Der Tab Wartung zeigt den Berry-Treiber jedes Panels und bietet ein Update an.
- (ticaki) Adapterstart: ein Startup pro Panel statt eines Startup-Sturms; ein Adapterneustart während eines TFT-Updates bricht das Update nicht mehr ab.
- (ticaki) Geänderte Statustexte und Anzeigewerte (
common.states, Einheit, min, max, step, Name) werden zur Laufzeit ohne Adapterneustart übernommen. - (ticaki) Icons: Mediaplayer-Logos
alexa,mpd,sonos,boseundvolumiovorbereitet (ab TFT 6.1.0).
Screensaver
- (ticaki) Kurz nacheinander eintreffende Änderungen werden zusammen gesendet, weatherUpdate höchstens einmal pro Sekunde statt alle 2 s, veraltete Werte stauen sich nicht mehr in der Sendewarteschlange. Das Update-Symbol erscheint nur noch bei einem TFT, das älter als das empfohlene ist.
- (ticaki) Benachrichtigung bei Standby-Helligkeit 0: Der erste Tipp weckt das Display, der zweite schließt die Benachrichtigung, der dritte verlässt den Screensaver.
- (tt-tom17) Ein Tipp auf eine nicht schließbare Benachrichtigung geht nicht mehr verloren; eine quittierte Meldung des ioBroker-Hosts kommt nicht wieder.
Popup & Karten
- (tt-tom17) Popup-Benachrichtigung: Der linke Button schreibt die reine ID nach
setStateIDund die ID mit Panelname nachsetGlobalID, wie die anderen Buttons. Skripte prüfen, die den lokalen Datenpunkt lesen! FehlttextSize, wird Größe 3 verwendet. - (tt-tom17) cardThermo/cardThermo2: Modus-Zeile auch bei
common.statesals Objekt, LüftermodusFAN_ONLYwird angezeigt, kein umrandetes A mehr bei inaktiven Modi, kein doppelter Schraubenschlüssel; Lüften- und Trocknen-Modus heißen jetzt nach ihrer Funktion (Lüften/Trocknen).
Admin
- (ticaki) Eigenes TFT auf ein oder alle Panels flashen (Tab Entwickler, Expertenmodus); Namensfilter in der Seitenkonfiguration, Suche im Navigationsfluss, lesbare Zoom-Buttons im dunklen Thema.
- (tt-tom17) Checkbox für die Farbskala bei Item-Farben, Wertbedingung für weitere Navigationsrollen, „Navigation“ und „eigener Button“ schließen sich gegenseitig aus, verständlichere Startseiten-Zusammenfassung und Hinweise, fehlgeschlagene Skript-Updates werden gemeldet, Hinweis zur Zeitzone, Warnung bei ungespeicherten Panels.
Sonstiges
- (ticaki) Admin >= 8.1.0 erforderlich; Abhängigkeiten aktualisiert (MQTT-Broker aedes 1.2.0 mit Sicherheitskorrekturen).
Feedback wäre wünschenswert - ja wir machen da viele release - ist ja auch kein sommer mehr :)
EDIT: Berry12 an sich beschleunigt auch ohne tft 6.1 den datenaustausch und kommt mit mehrfach antworten vom display klar - wobei das mit den mehrfach antworten wohl eher selten vorkommt in 6.0.9
Die Doku die Tom da erstellt hat ist echt cool
Da werden in der nächsten version wohl ein haufen direkt links vom admin auf die entsprechende doku seite eingebaut.
https://ticaki.github.io/ioBroker.nspanel-lovelace-ui/de/Home.html -
NSPanel Lovelace UI 2.3.1
- Hilfe direkt im Admin: Bei vielen Einstellungen führt ein Link direkt zur passenden Stelle in der Dokumentation, in der Systemsprache des ioBroker.
- Farbskala mit Best-Farbe repariert: Oberhalb des Best-Werts lief die Skala bisher verkehrt herum.
Changelog
Farbskala
- (ticaki) Bei einer Farbskala mit Best-Wert und Best-Farbe ist der Bereich oberhalb des Best-Werts nicht mehr invertiert. Die Farben laufen jetzt wie erwartet von der Min-Farbe über die Best-Farbe zur Max-Farbe. Liegen Best-Wert und Max-Wert gleich, entsteht keine ungültige Farbe mehr. (#896)
- (ticaki) Admin, Farboptionen: In den Gradient-Modi (Tri-Gradient, Quadri-Gradient und ihre Anker-Varianten) sind die Farbfelder Min/Max/Best deaktiviert, denn diese Modi verwenden feste Farben.
Admin
- (ticaki) Hilfe-Links zur Dokumentation bei vielen Einstellungen, in der Systemsprache des ioBroker.
- (tt-tom17) Tab Entwickler, „Eigenes TFT flashen“: funktioniert auch mit einem externen MQTT-Broker. Die Box fragt die „IP des ioBroker“ dann selbst ab.
Im Tab "Maintain" gibt es die Option "Skript in Admin übernehmen" - was bedeutet das?
Gemeint ist das Konfigurationsskript des Adapters, also das Skript im JavaScript-Adapter, das dem Adapter die Seiten, den Screensaver usw. schickt. Das eigenständige NSPanel-Skript ohne Adapter ist nicht gemeint.
Der Knopf überträgt diese Konfiguration in den Admin. Zuerst kommt eine Vorschau, dann legt der Adapter alles im Admin an und sichert das Skript als deaktiviertes Backup. Danach entfernt er die übernommenen Seiten aus dem Skript. Vorher speichern und hinterher den Admin neu laden.
Wer alles im Admin einrichtet, braucht den Knopf nicht.
Details: https://ticaki.github.io/ioBroker.nspanel-lovelace-ui/de/Migration.html
EDIT: hm da fehlt das ? neben dem button :)
EDIT2: Ja Regeln - ein ? in jeder Kachel widerspricht der "keine icon wüste" regel :) -
Ich nutze das NSPanel EU seit Samstag und bin soweit begeistert vom Adapter und allem drum rum. Dafür schon mal ein Danke!
Aktuell habe ich 3 Probleme.
- im log taucht immer wieder diese Meldung auf:
nspanel-lovelace-ui.0 2026-11-17 17:04:09.920 warn [Eingang] setActivePage called but nothing changed! Resending active page to panel. Page: main - Sleep: false- im Screensaver habe ich auf Platz 1-3 der Indikatoren Statusobjekte für Licht in Räumen
Bei der Sichtbarkeit ist eingestellt, dass diese bei
falsenicht angezeigt werden sollen. Sie sind aber immer da. Bei Indikator 2 und 3 ist der Wertfalse.
- wenn ich ein Channel vom Typ gate erstelle, erhalte ich folgenden Fehler:
nspanel-lovelace-ui.0 2026-11-17 17:22:29.233 error [config-manager] Required: SET: alias.0.NSPanel.Grundstueck.Gate, channel role: gate - missing - searching for type: "boolean", role: "switch.gate", common.write: true nspanel-lovelace-ui.0 2026-11-17 17:33:46.045 warn [Haus_Grundstueck|PI] Entity gate has no value! No Actual or Set nspanel-lovelace-ui.0 2026-11-17 17:33:46.046 warn [Haus_Grundstueck|PI] Something went wrong on 16?7 type: shutter role: gate dataitems.type: shutter!Die Objekte dazu sehen so aus:
und hier die json:
"_id": "alias.0.NSPanel.Grundstueck.Gate.ACTUAL", "type": "state", "common": { "name": "Swing Gate Status", "type": "boolean", "alias": { "id": "0_userdata.0.Door_Window.Swing_Gate_Switch" }, "role": "sensor.gate", "read": true, "write": false }, "native": {}und
"_id": "alias.0.NSPanel.Grundstueck.Gate.SET", "type": "state", "common": { "name": "Swing Gate Switch", "type": "boolean", "alias": { "id": "0_userdata.0.Door_Window.Swing_Gate_Switch" }, "role": "switch.gate", "read": true, "write": true }, "native": {}Beim Einfügen in einer Kachel gibt es auch keinen Fehler. Aber im Display erscheint an der Stelle nichts.
Versionen:
Adapter: 2.3.1
Tasmota 16
TFT 6.1.0
Berry 12
Skript 0.21.8 -
Punkt 2. kann ich schon mal bestätigtigen... hab mich schon gefragt wieso bei mir immer soviele Indikatoren auf dem Flur panel sind :)
Rest gucke ich mir an nachdem ich hier den Fehler gefunden habe.EDIT: HAHAHA
Ne ist kein "Bug", sondern eine fehlende Option im Admin - es gibtScreensaverEntityFillIfBelowMindamit bestimmt man das ein ausgeblendetes Element doch eingeblendet wird wenn sonst nicht alle Plätze belegt sind.Die ist aktuell per default
true- wird auffalsegeändert und bekommt eine option im admin.Hatte ganz vergessen dass es das gibt ^^
Das Leben eines Entwicklers. Ich hoffe du nutzt Claude Code o.ä.?
btw: Ich habe Wischgesten auf Screensaver aktiv. Aber selbst wenn Bereiche mehr als die sichtbaren Plätze nutzen, kann ich nichts "bewegen". Hatte im Layout Advanced unten 12 Wetter Icons. Aber nur das automatische Rollen alle x Sek. zeigt die 2x6 alternierend. Ich dachte ich könnte da auch selbst per Touch scrollen?
Habe die Lösung in der Doku gefunden ;-)
