Hannah — Open Source Smart-Home-Sprachassistentin
Na dann ist die Sache klar.
Erstelle die Datei /etc/mosquitto/conf.d/hannah.conf mit dem Inhalt:
echo listener 1883 allow_anonymous trueDanach den Service neustarten:
sudo systemctl restart mosquittomöglicherweise musst du den Port anpassen wenn der Port 1883 bei dir bereits belegt ist.
@Leonie
Port ist angepasst.
iob@iob:~$ sudo systemctl restart mosquitto
Job for mosquitto.service failed because the control process exited with error code.
See "systemctl status mosquitto.service" and "journalctl -xeu mosquitto.service" for details. -
@Leonie
Port ist angepasst.
@OliverIO
e Nov 3 15:07:41 2026 from 192.168.178.38
iob@iob:~$ journalctl -xeu mosquitto.service
░░ A start job for unit mosquitto.service has begun execution.
░░ The job identifier is 71406.
Nov 03 15:05:27 iob mosquitto[674181]: 1793714727: Loading config file /etc/mosquitto/conf.d/hannah.conf
Nov 03 15:05:27 iob mosquitto[674181]: 1793714727: Error: Unknown configuration variable "echo".
Nov 03 15:05:27 iob mosquitto[674181]: 1793714727: Error found at /etc/mosquitto/conf.d/hannah.conf:1.
Nov 03 15:05:27 iob mosquitto[674181]: 1793714727: Error found at /etc/mosquitto/mosquitto.conf:13.
Nov 03 15:05:27 iob systemd[1]: mosquitto.service: Main process exited, code=exited, status=3/NOTIMPLEMENTED
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: http://www.ubuntu.com/support
░░ An ExecStart= process belonging to unit mosquitto.service has exited.
░░ The process' exit code is 'exited' and its exit status is 3.
Nov 03 15:05:27 iob systemd[1]: mosquitto.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit mosquitto.service has entered the 'failed' state with result 'exit-code'.
Nov 03 15:05:27 iob systemd[1]: Failed to start mosquitto.service - Mosquitto MQTT Broker.
░░ Subject: A start job for unit mosquitto.service has failed
░░ A start job for unit mosquitto.service has finished with a failure.
░░ The job identifier is 71406 and the job result is failed.
Nov 03 15:05:27 iob systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Automatic restarting of the unit mosquitto.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
Nov 03 15:05:27 iob systemd[1]: mosquitto.service: Start request repeated too quickly.
░░ The job identifier is 71553 and the job result is failed.
lines 1313-1364/1364 (END) -
Eigentlich steht in deinem Log was der Fehler ist und der ist in meinem Beitrag ;)
Das echo muss raus. die erste Teile lautet nur "listener 1883". Das echo ist mir beim Kopieren reingertuscht.
Dein Log ist eigentlich eindeutig genug:
Nov 03 17:20:29 iob mosquitto[28225]: 1793722829: Error: Duplicate persistence_location value in configuration. Nov 03 17:20:29 iob mosquitto[28225]: 1793722829: Error found at /etc/mosquitto/mosquitto.conf:26.Du hast "persistence_location" mindestens zweimal in den Conifgs stehen.
Naja, Hannah spricht mit ioBroker nicht über MQTT. Und wenn du Mosqiutto als Broker nutzt, brauchst den Adapter in dem Kontext einfach nicht.
in dem du das in den configs (core+Satelliten) einträgst.
Den MQTT-Adapter in ioBroker brauchst du nur, wenn du z. B. MQTT-Datenpunkte aus Mosquitto in ioBroker visualisieren oder verarbeiten willst. Für die reine Funktion von Hannah und den Satelliten ist der ioBroker-MQTT-Adapter komplett überflüssig. Wenn er auf Client steht und Mosquitto ohne Passwort läuft, müsste dort als Server IP
127.0.0.1und Port1883eingetragen sein. Wenn du ihn nicht für andere Geräte brauchst: Einfach deaktivieren. -
127.0.0.1und Port1883eingetragen sein. Wenn du ihn nicht für andere Geräte brauchst: Einfach deaktivieren.in dem du das in den configs (core+Satelliten) einträgst.
also die mqtt daten löschen?
In der Config vom Core gibt es einen MQTT-Block. Auszug:
mqtt: host: "192.168.1.1" port: 1883 username: "mqtt" password: "IHR_MQTT_PASSWORT"Host ist die Adrese von deinem Broker, der Port muss auch zu deinem Broker passen. Wenn du keinen Nutzernamen und kein Passwort brauchst (weil dein Broker anonym arbeitet), kannst du die einfach weglassen.
In der WebUI der Satelliten gibt es ebenfalls einen MQTT-Block:
Auch da müssen Broker (Host) und Port zu deinem System passen. Wenn du keinen Nutzernamen und kein Passwort brauchst (weil dein Broker anonym arbeitet), kannst du die einfach weglassen.
