  4. Hannah — Open Source Smart-Home-Sprachassistentin
443 Beiträge 24 Kommentatoren 46.0k Aufrufe 35 Beobachtet
  • L
    L
    Leonie
    #399
    Was steht in /etc/mosquitto/mosquitto.conf?
    Walter.O.W 1 Antwort Letzte Antwort
    • L Leonie
      Walter.O.W
      Walter.O.W
      Walter.O.
      #400
      @Leonie
      nichts
      • Walter.O.W
        Walter.O.W
        Walter.O.
        #401
        sorry falscher name.
        Place your local configuration in /etc/mosquitto/conf.d/
        A full description of the configuration file is at
        /usr/share/doc/mosquitto/examples/mosquitto.conf
        #pid_file /run/mosquitto/mosquitto.pid
        persistence true
        persistence_location /var/lib/mosquitto/
        log_dest file /var/log/mosquitto/mosquitto.log
        include_dir /etc/mosquitto/conf.d
        • L
          L
          Leonie
          #402
          Na dann ist die Sache klar.
          Erstelle die Datei /etc/mosquitto/conf.d/hannah.conf mit dem Inhalt:
          echo listener 1883
          allow_anonymous true
          Danach den Service neustarten:
          sudo systemctl restart mosquitto
          möglicherweise musst du den Port anpassen wenn der Port 1883 bei dir bereits belegt ist.
          • L Leonie
            echo listener 1883
            Walter.O.W
            Walter.O.W
            Walter.O.
            schrieb am zuletzt editiert von Walter.O.
            #403
            @Leonie
            Port ist angepasst.
            iob@iob:~$ sudo systemctl restart mosquitto
            Job for mosquitto.service failed because the control process exited with error code.
            See "systemctl status mosquitto.service" and "journalctl -xeu mosquitto.service" for details.
            iob@iob:~$ journalctl -xeu mosquitto.service
            ░░ A start job for unit mosquitto.service has begun execution.
            ░░ The job identifier is 69348.
            Nov 03 14:42:05 iob mosquitto[669018]: 1793713325: Loading config file /etc/mosquitto/conf.d/mosquitto.conf
            Nov 03 14:42:05 iob mosquitto[669018]: 1793713325: Error: Unknown configuration variable "echo".
            Nov 03 14:42:05 iob mosquitto[669018]: 1793713325: Error found at /etc/mosquitto/conf.d/mosquitto.conf:1.
            Nov 03 14:42:05 iob mosquitto[669018]: 1793713325: Error found at /etc/mosquitto/mosquitto.conf:13.
            Nov 03 14:42:05 iob systemd[1]: mosquitto.service: Main process exited, code=exited, status=3/NOTIMPLEMENTED
            ░░ Subject: Unit process exited
            ░░ Defined-By: systemd
            ░░ Support: http://www.ubuntu.com/support
            ░░ An ExecStart= process belonging to unit mosquitto.service has exited.
            ░░ The process' exit code is 'exited' and its exit status is 3.
            Nov 03 14:42:05 iob systemd[1]: mosquitto.service: Failed with result 'exit-code'.
            ░░ Subject: Unit failed
            ░░ The unit mosquitto.service has entered the 'failed' state with result 'exit-code'.
            Nov 03 14:42:05 iob systemd[1]: Failed to start mosquitto.service - Mosquitto MQTT Broker.
            ░░ Subject: A start job for unit mosquitto.service has failed
            ░░ A start job for unit mosquitto.service has finished with a failure.
            ░░ The job identifier is 69348 and the job result is failed.
            Nov 03 14:42:05 iob systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
            ░░ Subject: Automatic restarting of a unit has been scheduled
            ░░ Automatic restarting of the unit mosquitto.service has been scheduled, as the result for
            ░░ the configured Restart= setting for the unit.
            Nov 03 14:42:05 iob systemd[1]: mosquitto.service: Start request repeated too quickly.
            ░░ The job identifier is 69495 and the job result is failed.
            • Walter.O.W Walter.O.
              @Leonie
              Port ist angepasst.
              OliverIOO
              OliverIOO
              OliverIO
              #404
              @Walter.O.
              Es heißt
              journalctl Nicht ournalctl
              Stand aber in der Meldung auch drunter
              Meine Adapter und Widgets
              Links im Profil
              • OliverIOO OliverIO
                @Walter.O.
                Es heißt
                Walter.O.W
                Walter.O.W
                Walter.O.
                #405
                @OliverIO
                e Nov 3 15:07:41 2026 from 192.168.178.38
                ░░ The job identifier is 71406.
                Nov 03 15:05:27 iob mosquitto[674181]: 1793714727: Loading config file /etc/mosquitto/conf.d/hannah.conf
                Nov 03 15:05:27 iob mosquitto[674181]: 1793714727: Error: Unknown configuration variable "echo".
                Nov 03 15:05:27 iob mosquitto[674181]: 1793714727: Error found at /etc/mosquitto/conf.d/hannah.conf:1.
                Nov 03 15:05:27 iob mosquitto[674181]: 1793714727: Error found at /etc/mosquitto/mosquitto.conf:13.
                Nov 03 15:05:27 iob systemd[1]: mosquitto.service: Main process exited, code=exited, status=3/NOTIMPLEMENTED
                Nov 03 15:05:27 iob systemd[1]: mosquitto.service: Failed with result 'exit-code'.
                Nov 03 15:05:27 iob systemd[1]: Failed to start mosquitto.service - Mosquitto MQTT Broker.
                ░░ The job identifier is 71406 and the job result is failed.
                Nov 03 15:05:27 iob systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
                Nov 03 15:05:27 iob systemd[1]: mosquitto.service: Start request repeated too quickly.
                ░░ The job identifier is 71553 and the job result is failed.
                lines 1313-1364/1364 (END)
                • L
                  L
                  Leonie
                  #406
                  Eigentlich steht in deinem Log was der Fehler ist und der ist in meinem Beitrag ;)
                  Das echo muss raus. die erste Teile lautet nur "listener 1883". Das echo ist mir beim Kopieren reingertuscht.
                  • L Leonie
                    Walter.O.W
                    Walter.O.W
                    Walter.O.
                    #407
                    @Leonie
                    Immer noch Fehlermeldungen
                    Was muss denn im mqtt adapter Client/Subscriber eingestellt werdenBenutzer Passwort.?
                    Sorry aber mit mosquitto hatte ich noch nie was zu tun.
                    iob@iob:/etc/mosquitto/conf.d$ sudo systemctl restart mosquitto
                    iob@iob:/etc/mosquitto/conf.d$ systemctl status mosquitto.service
                    × mosquitto.service - Mosquitto MQTT Broker
                        Loaded: loaded (/usr/lib/systemd/system/mosquitto.service; enabled; preset: enabled)
                        Active: failed (Result: exit-code) since Tue 2026-11-03 17:20:29 CET; 27s ago
                    Invocation: 34cc919d5fe74941a0c84927d2172659
                          Docs: man:mosquitto.conf(5)
                                man:mosquitto(8)
                       Process: 28225 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=3)
                      Main PID: 28225 (code=exited, status=3)
                      Mem peak: 2M
                           CPU: 49ms
                    Nov 03 17:20:29 iob systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
                    Nov 03 17:20:29 iob systemd[1]: mosquitto.service: Start request repeated too quickly.
                    Nov 03 17:20:29 iob systemd[1]: mosquitto.service: Failed with result 'exit-code'.
                    Nov 03 17:20:29 iob systemd[1]: Failed to start mosquitto.service - Mosquitto MQTT Broker.
                    iob@iob:/etc/mosquitto/conf.d$ journalctl -xeu mosquitto.service
                    ░░ The job identifier is 6513.
                    Nov 03 17:20:29 iob mosquitto[28225]: 1793722829: Loading config file /etc/mosquitto/conf.d/hannah.conf
                    Nov 03 17:20:29 iob mosquitto[28225]: 1793722829: Loading config file /etc/mosquitto/conf.d/mosquitto.conf
                    Nov 03 17:20:29 iob mosquitto[28225]: 1793722829: Error: Duplicate persistence_location value in configuration.
                    Nov 03 17:20:29 iob mosquitto[28225]: 1793722829: Error found at /etc/mosquitto/mosquitto.conf:26.
                    Nov 03 17:20:29 iob systemd[1]: mosquitto.service: Main process exited, code=exited, status=3/NOTIMPLEMENTED
                    ░░ The job identifier is 6513 and the job result is failed.
                    ░░ The job identifier is 6660 and the job result is failed.
                    • L
                      L
                      Leonie
                      #408
                      Was steht in /etc/mosquitto/conf.d/mosquitto.conf? evtl. brauchst du die hannah.conf gar nicht. In dem von mir bereitgestellten Beispiel ist der Broker anonym, man braucht also gar keine Anmeldedaten.
                      • Walter.O.W
                        Walter.O.W
                        Walter.O.
                        #409
                        Dort steht nichts drin
                        • Walter.O.W
                          Walter.O.W
                          Walter.O.
                          #410
                          Muss ich was in den .yaml Dateien ändern?
                          • L
                            L
                            Leonie
                            #411
                            Dein Log ist eigentlich eindeutig genug:
                            Du hast "persistence_location" mindestens zweimal in den Conifgs stehen.
                            • Walter.O.W
                              Walter.O.W
                              Walter.O.
                              #412
                              Ja habs gefunden da war noch eine zweite .conf die hab ich gelöscht, dann ging der restart sauber durch.
                              Der mqtt adapter bleibt bei "Verbunden mit Gerät oder Dienst" rot.
                              • L
                                L
                                Leonie
                                #413
                                du brauchst den mqtt-adapter gar nicht für Hannah
                                • L Leonie
                                  Walter.O.W
                                  Walter.O.W
                                  Walter.O.
                                  #414
                                  @Leonie sagte:
                                  • L
                                    L
                                    Leonie
                                    #415
                                    Naja, Hannah spricht mit ioBroker nicht über MQTT. Und wenn du Mosqiutto als Broker nutzt, brauchst den Adapter in dem Kontext einfach nicht.
                                    • L Leonie
                                      Walter.O.W
                                      Walter.O.W
                                      Walter.O.
                                      #416
                                      @Leonie sagte:
                                      Woher weis denn hannah das sie jetzt mit mosquitto spricht und wo kann ich wie im mqtt die Datenpunkte sehen?
                                      • L
                                        L
                                        Leonie
                                        #417
                                        in dem du das in den configs (core+Satelliten) einträgst.
                                        Den MQTT-Adapter in ioBroker brauchst du nur, wenn du z. B. MQTT-Datenpunkte aus Mosquitto in ioBroker visualisieren oder verarbeiten willst. Für die reine Funktion von Hannah und den Satelliten ist der ioBroker-MQTT-Adapter komplett überflüssig. Wenn er auf Client steht und Mosquitto ohne Passwort läuft, müsste dort als Server IP 127.0.0.1 und Port 1883 eingetragen sein. Wenn du ihn nicht für andere Geräte brauchst: Einfach deaktivieren.
                                        • L Leonie
                                          Walter.O.W
                                          Walter.O.W
                                          Walter.O.
                                          #418
                                          @Leonie sagte:
                                          also die mqtt daten löschen?
                                          84.2k
