- ioBroker Community Home
- Deutsch
- Tester
- Test Adapter TP-Link Tapo
@tombox leider nein
DebugLog:
2026-08-11 20:43:51.049 - info: host.iOProduktiv "system.adapter.tapo.0" enabled 2026-08-11 20:43:51.612 - info: host.iOProduktiv instance system.adapter.tapo.0 in version "0.6.7" (non-npm: TA2k/ioBroker.tapo) started with pid 2730550 2026-08-11 20:43:53.066 - info: tapo.0 (2730550) starting. Version 0.6.7 (non-npm: TA2k/ioBroker.tapo) in /opt/iobroker/node_modules/iobroker.tapo, node: v22.23.0, js-controller: 7.2.2 2026-08-11 20:43:53.082 - info: tapo.0 (2730550) Login tp TAPO App 2026-08-11 20:43:53.468 - info: tapo.0 (2730550) Login succesfull 2026-08-11 20:43:53.720 - info: tapo.0 (2730550) Found 5 devices 2026-08-11 20:43:54.062 - info: tapo.0 (2730550) Init device 802114698B0C4DB803277811859F5C6723111712 type C200 5.0 with ip 192.168.0.114 2026-08-11 20:43:54.130 - info: tapo.0 (2730550) UDP discovery for 192.168.0.114: port=80 https=true encrypt=undefined lv=4 mac=B0-19-21-34-63-BA 2026-08-11 20:43:54.327 - info: tapo.0 (2730550) 802114698B0C4DB803277811859F5C6723111712 Received device info {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5} 2026-08-11 20:43:54.330 - info: tapo.0 (2730550) Initialized 802114698B0C4DB803277811859F5C6723111712 2026-08-11 20:43:54.607 - info: tapo.0 (2730550) Init device 8021314EFB57E17626EC16DBDB2A31A51E64292E type C310 2.0 with ip 192.168.0.113 2026-08-11 20:43:54.672 - info: tapo.0 (2730550) UDP discovery for 192.168.0.113: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-BD 2026-08-11 20:43:54.889 - info: tapo.0 (2730550) 8021314EFB57E17626EC16DBDB2A31A51E64292E Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2} 2026-08-11 20:43:54.890 - info: tapo.0 (2730550) Initialized 8021314EFB57E17626EC16DBDB2A31A51E64292E 2026-08-11 20:43:55.112 - info: tapo.0 (2730550) Init device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 type C530WS 2.0 with ip 192.168.0.115 2026-08-11 20:44:06.631 - info: admin.0 (664) ==> Connected system.user.admin from ::ffff:192.168.0.132 2026-08-11 20:44:08.267 - info: tapo.0 (2730550) Camera 802173FB22D1FB8B96E616F599FE462C24EBEDA7 device info unavailable (connect EHOSTUNREACH 192.168.0.115:2020). Continuing (battery/hub doorbells are not locally reachable). 2026-08-11 20:44:11.339 - info: tapo.0 (2730550) ONVIF port 2020 not reachable for 192.168.0.115. Enable ONVIF in the Tapo app under camera settings to use motion events. 2026-08-11 20:44:11.339 - info: tapo.0 (2730550) Initialized 802173FB22D1FB8B96E616F599FE462C24EBEDA7 2026-08-11 20:44:11.655 - info: tapo.0 (2730550) Init device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 type C310 2.0 with ip 192.168.0.110 2026-08-11 20:44:11.711 - info: tapo.0 (2730550) UDP discovery for 192.168.0.110: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-DD 2026-08-11 20:44:11.774 - info: tapo.0 (2730550) 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2} 2026-08-11 20:44:11.828 - info: tapo.0 (2730550) Initialized 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 2026-08-11 20:44:12.105 - info: tapo.0 (2730550) Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.112 2026-08-11 20:44:12.176 - info: tapo.0 (2730550) UDP discovery for 192.168.0.112: port=80 https=true encrypt=undefined lv=3 mac=F0-A7-31-D8-7F-97 2026-08-11 20:44:12.658 - info: tapo.0 (2730550) 80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1} 2026-08-11 20:44:12.660 - info: tapo.0 (2730550) Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028 2026-08-11 20:44:12.662 - info: tapo.0 (2730550) Wait for connections for non camera devices 2026-08-11 20:44:22.662 - info: tapo.0 (2730550) Start first Update 2026-08-11 20:44:25.756 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 20:44:28.628 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 20:44:35.934 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 20:44:38.699 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 20:44:48.456 - info: tapo.0 (2730550) moveToPreset was set to : Sabine for device 802114698B0C4DB803277811859F5C6723111712 was successful: false 2026-08-11 20:45:00.007 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2731506 2026-08-11 20:45:01.600 - info: ical.0 (2731506) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2 2026-08-11 20:45:02.078 - info: ical.0 (2731506) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics 2026-08-11 20:45:02.343 - info: ical.0 (2731506) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics 2026-08-11 20:45:02.352 - info: ical.0 (2731506) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics 2026-08-11 20:45:02.664 - info: ical.0 (2731506) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics 2026-08-11 20:45:07.571 - info: tapo.0 (2730550) moveToPreset was set to : Beet for device 802114698B0C4DB803277811859F5C6723111712 was successful: false 2026-08-11 20:45:07.754 - info: ical.0 (2731506) Terminated (NO_ERROR): Without reason 2026-08-11 20:45:08.307 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2731506 terminated with code 0 (NO_ERROR) 2026-08-11 20:45:27.693 - info: tapo.0 (2730550) moveToPreset was set to : Sabine for device 802114698B0C4DB803277811859F5C6723111712 was successful: false 2026-08-11 20:46:09.295 - info: tapo.0 (2730550) moveToPreset was set to : Pool for device 80219D887A52D32D03212C4C2DE37E4D21EC8028 was successful: false 2026-08-11 20:48:57.699 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0} 2026-08-11 20:51:16.007 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2736155 2026-08-11 20:51:17.068 - info: netatmo-crawler.0 (2736155) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2 2026-08-11 20:51:17.088 - info: netatmo-crawler.0 (2736155) Getting data for stationid:70:ee:50:05:f2:d4 2026-08-11 20:51:19.290 - info: netatmo-crawler.0 (2736155) Getting data for stationid:70:ee:50:90:ce:ea 2026-08-11 20:51:19.642 - info: netatmo-crawler.0 (2736155) Getting data for stationid:70:ee:50:2e:f6:c0 2026-08-11 20:51:20.079 - info: netatmo-crawler.0 (2736155) Getting data for stationid:70:ee:50:90:e4:da 2026-08-11 20:51:20.633 - info: netatmo-crawler.0 (2736155) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value') 2026-08-11 20:51:21.072 - info: netatmo-crawler.0 (2736155) Getting data for stationid:70:ee:50:01:13:24 2026-08-11 20:51:21.258 - info: netatmo-crawler.0 (2736155) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule 2026-08-11 20:51:21.769 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2736155 terminated with code 0 (NO_ERROR) 2026-08-11 20:51:55.616 - info: tapo.0 (2730550) moveToPreset was set to : Terrasse for device 80219D887A52D32D03212C4C2DE37E4D21EC8028 was successful: false 2026-08-11 20:52:56.642 - info: web.1 (2112) <== Disconnect system.user.admin from ::ffff:192.168.0.97 iqontrol.0 2026-08-11 20:54:33.055 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 20:54:33.283 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 20:54:43.795 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 20:54:45.694 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 20:54:51.901 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 20:54:59.103 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 20:55:00.008 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2738456 2026-08-11 20:55:01.760 - info: ical.0 (2738456) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2 2026-08-11 20:55:02.270 - info: ical.0 (2738456) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics 2026-08-11 20:55:02.485 - info: ical.0 (2738456) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics 2026-08-11 20:55:02.558 - info: ical.0 (2738456) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics 2026-08-11 20:55:02.812 - info: ical.0 (2738456) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics 2026-08-11 20:55:07.935 - info: ical.0 (2738456) Terminated (NO_ERROR): Without reason 2026-08-11 20:55:08.450 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2738456 terminated with code 0 (NO_ERROR) 2026-08-11 20:55:38.783 - info: web.1 (2112) ==> Connected system.user.admin from ::ffff:192.168.0.97 2026-08-11 20:57:59.088 - info: daikin.0 (842) 4 Values updated: {"deviceInfo":0,"modelInfo":0,"control":2,"controlInfo":1,"sensorInfo":1,"demandControl":0} 2026-08-11 21:00:10.002 - info: javascript.0 (2499876) script.js.common.800-899_Energie.810_6_EPEX_Spot_Std_VIS: 22 2026-08-11 21:00:16.011 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2743063 2026-08-11 21:00:17.151 - info: netatmo-crawler.0 (2743063) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2 2026-08-11 21:00:17.173 - info: netatmo-crawler.0 (2743063) Getting data for stationid:70:ee:50:05:f2:d4 2026-08-11 21:00:25.537 - info: netatmo-crawler.0 (2743063) Getting data for stationid:70:ee:50:90:ce:ea 2026-08-11 21:00:28.286 - info: netatmo-crawler.0 (2743063) Getting data for stationid:70:ee:50:2e:f6:c0 2026-08-11 21:00:33.545 - info: netatmo-crawler.0 (2743063) Getting data for stationid:70:ee:50:90:e4:da 2026-08-11 21:00:39.658 - info: netatmo-crawler.0 (2743063) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value') 2026-08-11 21:00:42.104 - info: netatmo-crawler.0 (2743063) Getting data for stationid:70:ee:50:01:13:24 2026-08-11 21:00:43.307 - info: netatmo-crawler.0 (2743063) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule 2026-08-11 21:00:43.818 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2743063 terminated with code 0 (NO_ERROR) 2026-08-11 21:00:59.510 - info: daikin.0 (842) 3 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":3,"demandControl":0} 2026-08-11 21:03:59.964 - info: daikin.0 (842) 2 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":2,"demandControl":0} 2026-08-11 21:04:53.059 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:04:53.381 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:05:00.006 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2746708 2026-08-11 21:05:01.637 - info: ical.0 (2746708) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2 2026-08-11 21:05:02.284 - info: ical.0 (2746708) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics 2026-08-11 21:05:02.439 - info: ical.0 (2746708) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics 2026-08-11 21:05:02.529 - info: ical.0 (2746708) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics 2026-08-11 21:05:02.973 - info: ical.0 (2746708) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics 2026-08-11 21:05:03.871 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:05:05.930 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:05:08.067 - info: ical.0 (2746708) Terminated (NO_ERROR): Without reason 2026-08-11 21:05:08.599 - warn: ical.0 (2746708) get state error: Connection is closed. 2026-08-11 21:05:08.621 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2746708 terminated with code 0 (NO_ERROR) 2026-08-11 21:05:12.513 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:05:21.435 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:07:00.376 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0} 2026-08-11 21:11:02.011 - info: web.1 (2112) <== Disconnect system.user.admin from ::ffff:192.168.0.97 iqontrol.0 2026-08-11 21:13:37.938 - info: web.1 (2112) ==> Connected system.user.admin from ::ffff:192.168.0.97 2026-08-11 21:15:00.005 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2754582 2026-08-11 21:15:01.605 - info: ical.0 (2754582) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2 2026-08-11 21:15:02.113 - info: ical.0 (2754582) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics 2026-08-11 21:15:02.331 - info: ical.0 (2754582) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics 2026-08-11 21:15:02.446 - info: ical.0 (2754582) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics 2026-08-11 21:15:02.678 - info: ical.0 (2754582) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics 2026-08-11 21:15:07.770 - info: ical.0 (2754582) Terminated (NO_ERROR): Without reason 2026-08-11 21:15:08.286 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2754582 terminated with code 0 (NO_ERROR) 2026-08-11 21:15:13.180 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:15:13.447 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:15:23.911 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:15:25.926 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:15:32.502 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:15:39.134 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:16:01.794 - info: daikin.0 (842) 2 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":2,"demandControl":0} 2026-08-11 21:17:16.008 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2756615 2026-08-11 21:17:17.099 - info: netatmo-crawler.0 (2756615) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2 2026-08-11 21:17:17.138 - info: netatmo-crawler.0 (2756615) Getting data for stationid:70:ee:50:05:f2:d4 2026-08-11 21:17:18.265 - info: netatmo-crawler.0 (2756615) Getting data for stationid:70:ee:50:90:ce:ea 2026-08-11 21:17:18.433 - info: netatmo-crawler.0 (2756615) Getting data for stationid:70:ee:50:2e:f6:c0 2026-08-11 21:17:19.537 - info: netatmo-crawler.0 (2756615) Getting data for stationid:70:ee:50:90:e4:da 2026-08-11 21:17:20.145 - info: netatmo-crawler.0 (2756615) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value') 2026-08-11 21:17:20.519 - info: netatmo-crawler.0 (2756615) Getting data for stationid:70:ee:50:01:13:24 2026-08-11 21:17:20.724 - info: netatmo-crawler.0 (2756615) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule 2026-08-11 21:17:21.240 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2756615 terminated with code 0 (NO_ERROR) 2026-08-11 21:19:02.224 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0} 2026-08-11 21:22:02.616 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0} 2026-08-11 21:25:00.008 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2762187 2026-08-11 21:25:01.613 - info: ical.0 (2762187) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2 2026-08-11 21:25:02.117 - info: ical.0 (2762187) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics 2026-08-11 21:25:02.291 - info: ical.0 (2762187) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics 2026-08-11 21:25:02.393 - info: ical.0 (2762187) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics 2026-08-11 21:25:02.633 - info: ical.0 (2762187) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics 2026-08-11 21:25:07.740 - info: ical.0 (2762187) Terminated (NO_ERROR): Without reason 2026-08-11 21:25:08.254 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2762187 terminated with code 0 (NO_ERROR) 2026-08-11 21:25:33.089 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:25:33.327 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:25:43.897 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:25:45.976 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:25:52.701 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:25:59.416 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:26:54.595 - info: javascript.0 (2499876) script.js.common.000-050_System.001_HM_Servicemeldungen_04_2021: Neue Servicemeldung: Thermostat Küche (GEQ0162204) --- HM-CC-TC--- Typ: CONFIG_PENDING_ALARM --- Status: 1 Konfigurationsdaten stehen zur Übertragung an 2026-08-11 21:26:58.281 - info: javascript.0 (2499876) script.js.common.000-050_System.001_2_HM_Servicmeldungen_neu_2025: Zeitverbrauch fuer Routine Check_All: 3 Millisekunden Routine:Check_All 2026-08-11 21:28:04.341 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0} 2026-08-11 21:28:57.037 - info: web.1 (2112) <== Disconnect system.user.admin from ::ffff:192.168.0.97 iqontrol.0 2026-08-11 21:29:24.536 - info: javascript.0 (2499876) script.js.common.000-050_System.001_HM_Servicemeldungen_04_2021: Servicemeldung aufgehoben: Thermostat Küche (GEQ0162204) --- HM-CC-TC--- Typ: CONFIG_PENDING_ALARM --- Status: 2 Konfigurationsdaten standen zur Übertragung an 2026-08-11 21:29:28.280 - info: javascript.0 (2499876) script.js.common.000-050_System.001_2_HM_Servicmeldungen_neu_2025: Zeitverbrauch fuer Routine Check_All: 1 Millisekunden Routine:Check_All 2026-08-11 21:30:00.026 - info: javascript.0 (2499876) script.js.common.800-899_Energie.810_1_EPEX_Spot_morgen_aktualisieren: Strompreise erfolgreich importiert 2026-08-11 21:31:07.558 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0} 2026-08-11 21:31:33.775 - info: tapo.0 (2730550) moveToPreset was set to : Terrasse for device 80219D887A52D32D03212C4C2DE37E4D21EC8028 was successful: false 2026-08-11 21:31:35.564 - info: web.1 (2112) ==> Connected system.user.admin from ::ffff:192.168.0.97 2026-08-11 21:34:08.280 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0} 2026-08-11 21:34:16.005 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2769473 2026-08-11 21:34:17.163 - info: netatmo-crawler.0 (2769473) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2 2026-08-11 21:34:17.224 - info: netatmo-crawler.0 (2769473) Getting data for stationid:70:ee:50:05:f2:d4 2026-08-11 21:34:18.225 - info: netatmo-crawler.0 (2769473) Getting data for stationid:70:ee:50:90:ce:ea 2026-08-11 21:34:18.778 - info: netatmo-crawler.0 (2769473) Getting data for stationid:70:ee:50:2e:f6:c0 2026-08-11 21:34:18.998 - info: netatmo-crawler.0 (2769473) Getting data for stationid:70:ee:50:90:e4:da 2026-08-11 21:34:20.255 - info: netatmo-crawler.0 (2769473) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value') 2026-08-11 21:34:20.753 - info: netatmo-crawler.0 (2769473) Getting data for stationid:70:ee:50:01:13:24 2026-08-11 21:34:21.455 - info: netatmo-crawler.0 (2769473) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule 2026-08-11 21:34:21.973 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2769473 terminated with code 0 (NO_ERROR) 2026-08-11 21:35:00.011 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2769831 2026-08-11 21:35:01.798 - info: ical.0 (2769831) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2 2026-08-11 21:35:02.274 - info: ical.0 (2769831) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics 2026-08-11 21:35:02.484 - info: ical.0 (2769831) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics 2026-08-11 21:35:02.751 - info: ical.0 (2769831) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics 2026-08-11 21:35:02.862 - info: ical.0 (2769831) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics 2026-08-11 21:35:07.943 - info: ical.0 (2769831) Terminated (NO_ERROR): Without reason 2026-08-11 21:35:08.459 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2769831 terminated with code 0 (NO_ERROR) 2026-08-11 21:35:53.134 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:35:53.435 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:36:04.088 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:36:06.352 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:36:11.999 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:36:22.199 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:43:10.955 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0} 2026-08-11 21:45:00.009 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2777706 2026-08-11 21:45:01.696 - info: ical.0 (2777706) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2 2026-08-11 21:45:02.251 - info: ical.0 (2777706) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics 2026-08-11 21:45:02.441 - info: ical.0 (2777706) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics 2026-08-11 21:45:02.520 - info: ical.0 (2777706) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics 2026-08-11 21:45:02.787 - info: ical.0 (2777706) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics 2026-08-11 21:45:07.870 - info: ical.0 (2777706) Terminated (NO_ERROR): Without reason 2026-08-11 21:45:08.385 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2777706 terminated with code 0 (NO_ERROR) 2026-08-11 21:46:13.150 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:46:13.436 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:46:24.014 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:46:26.179 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:46:32.699 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:46:41.498 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:46:54.435 - info: web.1 (2112) <== Disconnect system.user.admin from ::ffff:192.168.0.97 iqontrol.0 2026-08-11 21:49:37.116 - info: web.1 (2112) ==> Connected system.user.admin from ::ffff:192.168.0.97 2026-08-11 21:51:16.014 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2782683 2026-08-11 21:51:17.119 - info: netatmo-crawler.0 (2782683) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2 2026-08-11 21:51:17.181 - info: netatmo-crawler.0 (2782683) Getting data for stationid:70:ee:50:05:f2:d4 2026-08-11 21:51:24.537 - info: netatmo-crawler.0 (2782683) Getting data for stationid:70:ee:50:90:ce:ea 2026-08-11 21:51:26.548 - info: netatmo-crawler.0 (2782683) Getting data for stationid:70:ee:50:2e:f6:c0 2026-08-11 21:51:27.798 - info: netatmo-crawler.0 (2782683) Getting data for stationid:70:ee:50:90:e4:da 2026-08-11 21:51:28.551 - info: netatmo-crawler.0 (2782683) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value') 2026-08-11 21:51:28.948 - info: netatmo-crawler.0 (2782683) Getting data for stationid:70:ee:50:01:13:24 2026-08-11 21:51:30.281 - info: netatmo-crawler.0 (2782683) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule 2026-08-11 21:51:30.794 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2782683 terminated with code 0 (NO_ERROR) 2026-08-11 21:52:13.917 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0} 2026-08-11 21:55:00.008 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2785639 2026-08-11 21:55:01.631 - info: ical.0 (2785639) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2 2026-08-11 21:55:02.145 - info: ical.0 (2785639) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics 2026-08-11 21:55:02.292 - info: ical.0 (2785639) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics 2026-08-11 21:55:02.406 - info: ical.0 (2785639) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics 2026-08-11 21:55:02.634 - info: ical.0 (2785639) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics 2026-08-11 21:55:07.718 - info: ical.0 (2785639) Terminated (NO_ERROR): Without reason 2026-08-11 21:55:08.232 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2785639 terminated with code 0 (NO_ERROR) 2026-08-11 21:56:33.174 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:56:33.444 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:56:44.062 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:56:46.193 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 21:56:52.514 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 21:56:59.589 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 22:00:10.002 - info: javascript.0 (2499876) script.js.common.800-899_Energie.810_6_EPEX_Spot_Std_VIS: 23 2026-08-11 22:00:16.013 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2789293 2026-08-11 22:00:17.075 - info: netatmo-crawler.0 (2789293) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2 2026-08-11 22:00:17.140 - info: netatmo-crawler.0 (2789293) Getting data for stationid:70:ee:50:05:f2:d4 2026-08-11 22:00:18.980 - info: netatmo-crawler.0 (2789293) Getting data for stationid:70:ee:50:90:ce:ea 2026-08-11 22:00:21.856 - info: netatmo-crawler.0 (2789293) Getting data for stationid:70:ee:50:2e:f6:c0 2026-08-11 22:00:22.209 - info: netatmo-crawler.0 (2789293) Getting data for stationid:70:ee:50:90:e4:da 2026-08-11 22:00:25.878 - info: netatmo-crawler.0 (2789293) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value') 2026-08-11 22:00:26.285 - info: netatmo-crawler.0 (2789293) Getting data for stationid:70:ee:50:01:13:24 2026-08-11 22:00:30.455 - info: netatmo-crawler.0 (2789293) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule 2026-08-11 22:00:30.966 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2789293 terminated with code 0 (NO_ERROR) 2026-08-11 22:04:53.241 - info: web.1 (2112) <== Disconnect system.user.admin from ::ffff:192.168.0.97 iqontrol.0 2026-08-11 22:05:00.005 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2793194 2026-08-11 22:05:01.593 - info: ical.0 (2793194) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2 2026-08-11 22:05:02.042 - info: ical.0 (2793194) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics 2026-08-11 22:05:02.261 - info: ical.0 (2793194) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics 2026-08-11 22:05:02.271 - info: ical.0 (2793194) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics 2026-08-11 22:05:02.613 - info: ical.0 (2793194) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics 2026-08-11 22:05:07.698 - info: ical.0 (2793194) Terminated (NO_ERROR): Without reason 2026-08-11 22:05:08.215 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2793194 terminated with code 0 (NO_ERROR) 2026-08-11 22:06:53.236 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 22:06:53.515 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 22:07:04.096 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 22:07:06.316 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 22:07:12.733 - info: tapo.0 (2730550) Connection lost to undefined 2026-08-11 22:07:22.500 - info: tapo.0 (2730550) Reconnected to undefined 2026-08-11 22:07:32.239 - info: web.1 (2112) ==> Connected system.user.admin from ::ffff:192.168.0.97 2026-08-11 22:15:00.007 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2800300 2026-08-11 22:15:01.643 - info: ical.0 (2800300) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2 2026-08-11 22:15:02.151 - info: ical.0 (2800300) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics 2026-08-11 22:15:02.297 - info: ical.0 (2800300) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics 2026-08-11 22:15:02.532 - info: ical.0 (2800300) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics 2026-08-11 22:15:02.704 - info: ical.0 (2800300) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics 2026-08-11 22:15:07.791 - info: ical.0 (2800300) Terminated (NO_ERROR): Without reason 2026-08-11 22:15:08.305 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2800300 terminated with code 0 (NO_ERROR) 2026-08-11 22:15:40.633 - info: host.iOProduktiv "system.adapter.tapo.0" disabled 2026-08-11 22:15:40.633 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 (force=false, process=true) 2026-08-11 22:15:40.636 - info: tapo.0 (2730550) Got terminate signal TERMINATE_YOURSELF 2026-08-11 22:15:40.636 - info: tapo.0 (2730550) terminating 2026-08-11 22:15:40.636 - info: tapo.0 (2730550) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2026-08-11 22:15:40.716 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 send kill signal 2026-08-11 22:15:41.137 - info: tapo.0 (2730550) terminating 2026-08-11 22:15:41.137 - info: tapo.0 (2730550) terminating 2026-08-11 22:15:41.279 - info: host.iOProduktiv instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-08-11 22:16:12.758 - info: admin.0 (664) ==> Connected system.user.admin from ::ffff:192.168.0.132 2026-08-11 22:16:33.890 - info: host.iOProduktiv "system.adapter.tapo.0" enabled 2026-08-11 22:16:34.925 - info: host.iOProduktiv instance system.adapter.tapo.0 in version "0.6.7" (non-npm: TA2k/ioBroker.tapo) started with pid 2801788 2026-08-11 22:16:35.772 - debug: tapo.0 (2801788) Redis Objects: Use Redis connection: 0.0.0.0:9001 2026-08-11 22:16:35.817 - debug: tapo.0 (2801788) Objects client ready ... initialize now 2026-08-11 22:16:35.817 - debug: tapo.0 (2801788) Objects create System PubSub Client 2026-08-11 22:16:35.818 - debug: tapo.0 (2801788) Objects create User PubSub Client 2026-08-11 22:16:35.947 - debug: tapo.0 (2801788) Objects client initialize lua scripts 2026-08-11 22:16:35.953 - debug: tapo.0 (2801788) Objects connected to redis: 0.0.0.0:9001 2026-08-11 22:16:36.020 - debug: tapo.0 (2801788) Redis States: Use Redis connection: 0.0.0.0:9000 2026-08-11 22:16:36.115 - debug: tapo.0 (2801788) States create System PubSub Client 2026-08-11 22:16:36.115 - debug: tapo.0 (2801788) States create User PubSub Client 2026-08-11 22:16:36.243 - debug: tapo.0 (2801788) States connected to redis: 0.0.0.0:9000 2026-08-11 22:16:36.388 - info: tapo.0 (2801788) starting. Version 0.6.7 (non-npm: TA2k/ioBroker.tapo) in /opt/iobroker/node_modules/iobroker.tapo, node: v22.23.0, js-controller: 7.2.2 2026-08-11 22:16:36.408 - info: tapo.0 (2801788) Login tp TAPO App 2026-08-11 22:16:36.453 - debug: tapo.0 (2801788) xaYE4SMWpkdB/E8dxzgSWA== 2026-08-11 22:16:36.749 - debug: tapo.0 (2801788) {"error_code":0,"result":{"accountApiUrl":"https://euw1-account-api.i.tplinkcloud.com","lockedMinutes":0,"appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"38ee8e2b-BTzbC0DcrEtEfMVYIT6h2p0","accountId":"37806770","regionCode":"AT","regTime":"2021-06-23 14:33:54","nickname":"mxa","email":"mxa@gmx.at","appServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com","refreshToken":"38ee8e2b-BTQsPoCVASGPAYEwdb5gnGd"}} 2026-08-11 22:16:36.749 - info: tapo.0 (2801788) Login succesfull 2026-08-11 22:16:36.750 - debug: tapo.0 (2801788) 3tJNSNko5EAYJ06dPx9ulA== 2026-08-11 22:16:36.985 - debug: tapo.0 (2801788) {"error_code":0,"result":{"totalNum":5,"deviceList":[{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0","deviceName":"C310 2.0","lastBindTime":1784968460316,"deviceHwVer":"2.0","alias":"Postkasten","deviceMac":"005F67798FDD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.4 Build 250811 Rel.34127n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80219D887A52D32D03212C4C2DE37E4D21EC8028","deviceName":"C520WS 1.0","lastBindTime":1705169151588,"deviceHwVer":"1.0","alias":"Terrasse","deviceMac":"F0A731D87F97","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","deviceModel":"C520WS","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.4.4 Build 260527 Rel.28339n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802114698B0C4DB803277811859F5C6723111712","deviceName":"C200 5.0","lastBindTime":1785313977891,"deviceHwVer":"5.0","alias":"Beet","deviceMac":"B019213463BA","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","deviceModel":"C200","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021314EFB57E17626EC16DBDB2A31A51E64292E","deviceName":"C310 2.0","lastBindTime":1632395306454,"deviceHwVer":"2.0","alias":"Haus Eingang vorne","deviceMac":"005F67798FBD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.5 Build 260323 Rel.35521n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802173FB22D1FB8B96E616F599FE462C24EBEDA7","deviceName":"C530WS 2.0","lastBindTime":1782991868008,"deviceHwVer":"2.0","alias":"Einfahrt","deviceMac":"6C4CBC025F2C","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","deviceModel":"C530WS","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0}],"currentIndex":4}} 2026-08-11 22:16:36.986 - info: tapo.0 (2801788) Found 5 devices 2026-08-11 22:16:36.986 - debug: tapo.0 (2801788) Found device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Postkasten 2026-08-11 22:16:37.491 - debug: tapo.0 (2801788) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"","mac":"005F67798FDD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.110","onboardingTime":1784968460,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"} 2026-08-11 22:16:37.492 - info: tapo.0 (2801788) Init device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 type C310 2.0 with ip 192.168.0.110 2026-08-11 22:16:37.492 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.110 on port 20002 2026-08-11 22:16:37.623 - info: tapo.0 (2801788) UDP discovery for 192.168.0.110: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-DD 2026-08-11 22:16:37.687 - info: tapo.0 (2801788) 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2} 2026-08-11 22:16:37.687 - debug: tapo.0 (2801788) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2} 2026-08-11 22:16:37.688 - debug: tapo.0 (2801788) Init event emitter for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 2026-08-11 22:16:37.692 - debug: tapo.0 (2801788) Init event listener for "motion" 2026-08-11 22:16:37.693 - info: tapo.0 (2801788) Initialized 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 2026-08-11 22:16:37.694 - debug: tapo.0 (2801788) initResult camera 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 undefined 2026-08-11 22:16:37.694 - debug: tapo.0 (2801788) Found device 80219D887A52D32D03212C4C2DE37E4D21EC8028 M��j� 2026-08-11 22:16:37.961 - debug: tapo.0 (2801788) {"hwVer":"1.0","category":"camera","model":"C520WS 1.0","ssid":"","mac":"F0A731D87F97","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","fwVer":"1.3.4 Build 250811 Rel.34127n","ip":"192.168.0.112","onboardingTime":1705169153,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"} 2026-08-11 22:16:37.961 - info: tapo.0 (2801788) Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.112 2026-08-11 22:16:37.961 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.112 on port 20002 2026-08-11 22:16:38.014 - info: tapo.0 (2801788) UDP discovery for 192.168.0.112: port=80 https=true encrypt=undefined lv=3 mac=F0-A7-31-D8-7F-97 2026-08-11 22:16:38.474 - info: tapo.0 (2801788) 80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1} 2026-08-11 22:16:38.475 - debug: tapo.0 (2801788) {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1} 2026-08-11 22:16:38.475 - debug: tapo.0 (2801788) Init event emitter for 80219D887A52D32D03212C4C2DE37E4D21EC8028 2026-08-11 22:16:38.478 - debug: tapo.0 (2801788) Init event listener for "motion" 2026-08-11 22:16:38.478 - info: tapo.0 (2801788) Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028 2026-08-11 22:16:38.478 - debug: tapo.0 (2801788) initResult camera 80219D887A52D32D03212C4C2DE37E4D21EC8028 undefined 2026-08-11 22:16:38.479 - debug: tapo.0 (2801788) Found device 802114698B0C4DB803277811859F5C6723111712 � 2026-08-11 22:16:38.777 - debug: tapo.0 (2801788) {"hwVer":"5.0","category":"camera","model":"C200 5.0","ssid":"videosun","mac":"B019213463BA","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","fwVer":"1.4.4 Build 260527 Rel.28339n","ip":"192.168.0.114","onboardingTime":1785313979,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"} 2026-08-11 22:16:38.777 - info: tapo.0 (2801788) Init device 802114698B0C4DB803277811859F5C6723111712 type C200 5.0 with ip 192.168.0.114 2026-08-11 22:16:38.777 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.114 on port 20002 2026-08-11 22:16:38.878 - info: tapo.0 (2801788) UDP discovery for 192.168.0.114: port=80 https=true encrypt=undefined lv=4 mac=B0-19-21-34-63-BA 2026-08-11 22:16:39.231 - info: tapo.0 (2801788) 802114698B0C4DB803277811859F5C6723111712 Received device info {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5} 2026-08-11 22:16:39.231 - debug: tapo.0 (2801788) {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5} 2026-08-11 22:16:39.232 - debug: tapo.0 (2801788) Init event emitter for 802114698B0C4DB803277811859F5C6723111712 2026-08-11 22:16:39.234 - debug: tapo.0 (2801788) Init event listener for "motion" 2026-08-11 22:16:39.234 - info: tapo.0 (2801788) Initialized 802114698B0C4DB803277811859F5C6723111712 2026-08-11 22:16:39.234 - debug: tapo.0 (2801788) initResult camera 802114698B0C4DB803277811859F5C6723111712 undefined 2026-08-11 22:16:39.234 - debug: tapo.0 (2801788) Found device 8021314EFB57E17626EC16DBDB2A31A51E64292E Haus Eingang vorne 2026-08-11 22:16:39.565 - debug: tapo.0 (2801788) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"Sun 2.4","mac":"005F67798FBD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.113","onboardingTime":0,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"} 2026-08-11 22:16:39.565 - info: tapo.0 (2801788) Init device 8021314EFB57E17626EC16DBDB2A31A51E64292E type C310 2.0 with ip 192.168.0.113 2026-08-11 22:16:39.565 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.113 on port 20002 2026-08-11 22:16:39.625 - info: tapo.0 (2801788) UDP discovery for 192.168.0.113: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-BD 2026-08-11 22:16:39.909 - info: tapo.0 (2801788) 8021314EFB57E17626EC16DBDB2A31A51E64292E Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2} 2026-08-11 22:16:39.909 - debug: tapo.0 (2801788) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2} 2026-08-11 22:16:39.909 - debug: tapo.0 (2801788) Init event emitter for 8021314EFB57E17626EC16DBDB2A31A51E64292E 2026-08-11 22:16:39.914 - debug: tapo.0 (2801788) Init event listener for "motion" 2026-08-11 22:16:39.914 - info: tapo.0 (2801788) Initialized 8021314EFB57E17626EC16DBDB2A31A51E64292E 2026-08-11 22:16:39.914 - debug: tapo.0 (2801788) initResult camera 8021314EFB57E17626EC16DBDB2A31A51E64292E undefined 2026-08-11 22:16:39.914 - debug: tapo.0 (2801788) Found device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 )�j� 2026-08-11 22:16:40.202 - debug: tapo.0 (2801788) {"hwVer":"2.0","category":"camera","model":"C530WS 2.0","ssid":"","mac":"6C4CBC025F2C","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","fwVer":"1.3.5 Build 260323 Rel.35521n","ip":"192.168.0.115","onboardingTime":1782991869,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"} 2026-08-11 22:16:40.202 - info: tapo.0 (2801788) Init device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 type C530WS 2.0 with ip 192.168.0.115 2026-08-11 22:16:40.202 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.115 on port 20002 2026-08-11 22:16:43.202 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.115: no response (will use default port 80) 2026-08-11 22:16:53.452 - info: tapo.0 (2801788) Camera 802173FB22D1FB8B96E616F599FE462C24EBEDA7 device info unavailable (connect EHOSTUNREACH 192.168.0.115:2020). Continuing (battery/hub doorbells are not locally reachable). 2026-08-11 22:16:53.452 - debug: tapo.0 (2801788) Init event emitter for 802173FB22D1FB8B96E616F599FE462C24EBEDA7 2026-08-11 22:16:56.523 - info: tapo.0 (2801788) ONVIF port 2020 not reachable for 192.168.0.115. Enable ONVIF in the Tapo app under camera settings to use motion events. 2026-08-11 22:16:56.523 - info: tapo.0 (2801788) Initialized 802173FB22D1FB8B96E616F599FE462C24EBEDA7 2026-08-11 22:16:56.523 - debug: tapo.0 (2801788) initResult camera 802173FB22D1FB8B96E616F599FE462C24EBEDA7 undefined 2026-08-11 22:16:56.526 - info: tapo.0 (2801788) Wait for connections for non camera devices 2026-08-11 22:17:06.204 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:06.204 - debug: tapo.0 (2801788) isSecureConnection: Checking secure connection... 2026-08-11 22:17:06.524 - debug: tapo.0 (2801788) isSecureConnection response status=200 data={"result":{"data":{"code":-40401,"time":9,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"B7738EE72E2FB59B","device_confirm":"7D409664A4EF44787D7751BFFB72D14CEC36E0AAB7C04484A3ACE16BB97B202EB7738EE72E2FB59B5B1099EB805EC3D9"}},"error_code":-40413} 2026-08-11 22:17:06.524 - debug: tapo.0 (2801788) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true 2026-08-11 22:17:06.525 - debug: tapo.0 (2801788) refreshStok: Refreshing stok... 2026-08-11 22:17:06.525 - debug: tapo.0 (2801788) refreshStok: isSecureConnection=true username=admin cnonce=4899BBB77DCC7277 2026-08-11 22:17:06.529 - info: tapo.0 (2801788) Start first Update 2026-08-11 22:17:06.529 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:06.530 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:06.530 - debug: tapo.0 (2801788) isSecureConnection: Checking secure connection... 2026-08-11 22:17:06.710 - debug: tapo.0 (2801788) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"B648B02C8FBAA0AD","device_confirm":"49AEE82480ECAFD44EA9164A9C45BFB6EAEF5605B8174D70310979A4DFC6E99AB648B02C8FBAA0ADEFB4B4484F877200"}}} 2026-08-11 22:17:06.710 - debug: tapo.0 (2801788) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true 2026-08-11 22:17:06.710 - debug: tapo.0 (2801788) refreshStok: Refreshing stok... 2026-08-11 22:17:06.711 - debug: tapo.0 (2801788) refreshStok: isSecureConnection=true username=admin cnonce=8738F327933DC1E9 2026-08-11 22:17:06.807 - debug: tapo.0 (2801788) refreshStok: Login response status=200 data={"result":{"data":{"code":-40401,"time":8,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"EF4AAE02BF4F4C05","device_confirm":"F8672F1EF8664548C229634CB5FCAE6D419BFF07357241D1875D774284512226EF4AAE02BF4F4C054899BBB77DCC7277"}},"error_code":-40413} 2026-08-11 22:17:06.807 - debug: tapo.0 (2801788) refreshStok: nonce=EF4AAE02BF4F4C05... deviceConfirm=F8672F1EF8664548... 2026-08-11 22:17:06.807 - debug: tapo.0 (2801788) validateDeviceConfirm: matched candidate #1 via sha256 2026-08-11 22:17:06.807 - debug: tapo.0 (2801788) refreshStok: deviceConfirm validated, encryptionMethod=sha256 2026-08-11 22:17:06.807 - debug: tapo.0 (2801788) refreshStok: sending start_seq request 2026-08-11 22:17:06.926 - debug: tapo.0 (2801788) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"9635A1EF7E960BE1","device_confirm":"E4187BE06E88CF0E2E000A85F93687A78257A9778F91AB098BE9CE73B1ADF6969635A1EF7E960BE18738F327933DC1E9"}}} 2026-08-11 22:17:06.926 - debug: tapo.0 (2801788) refreshStok: nonce=9635A1EF7E960BE1... deviceConfirm=E4187BE06E88CF0E... 2026-08-11 22:17:06.926 - debug: tapo.0 (2801788) validateDeviceConfirm: matched candidate #1 via sha256 2026-08-11 22:17:06.926 - debug: tapo.0 (2801788) refreshStok: deviceConfirm validated, encryptionMethod=sha256 2026-08-11 22:17:06.926 - debug: tapo.0 (2801788) refreshStok: sending start_seq request 2026-08-11 22:17:07.027 - debug: tapo.0 (2801788) refreshStok: start_seq response 2026-08-11 22:17:07.027 - debug: tapo.0 (2801788) refreshStok: start_seq=476 user_group=root stok=present 2026-08-11 22:17:07.027 - debug: tapo.0 (2801788) refreshStok: Success in obtaining STOK 2026-08-11 22:17:07.127 - debug: tapo.0 (2801788) refreshStok: start_seq response 2026-08-11 22:17:07.127 - debug: tapo.0 (2801788) refreshStok: start_seq=96210518 user_group=root stok=present 2026-08-11 22:17:07.127 - debug: tapo.0 (2801788) refreshStok: Success in obtaining STOK 2026-08-11 22:17:07.314 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:07.314 - info: tapo.0 (2801788) moveToPreset was set to : Terrasse for device 80219D887A52D32D03212C4C2DE37E4D21EC8028 was successful: false 2026-08-11 22:17:07.465 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:07.465 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true} 2026-08-11 22:17:07.465 - info: tapo.0 (2801788) Reconnected to undefined 2026-08-11 22:17:07.465 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:07.683 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:07.683 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:07.784 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:07.980 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:07.980 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:08.301 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:08.513 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:08.535 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:08.535 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:08.875 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:08.875 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false} 2026-08-11 22:17:08.875 - info: tapo.0 (2801788) Reconnected to undefined 2026-08-11 22:17:08.875 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:09.206 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:09.206 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:09.314 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:09.315 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:09.364 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:09.604 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:09.605 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:09.722 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:09.723 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true} 2026-08-11 22:17:09.723 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:09.938 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:09.938 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:09.949 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:09.996 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:10.150 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:10.150 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:10.171 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:10.295 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:10.315 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:10.315 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:10.315 - debug: tapo.0 (2801788) isSecureConnection: Checking secure connection... 2026-08-11 22:17:10.381 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:10.388 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:10.388 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:10.641 - debug: tapo.0 (2801788) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"2FAFBFED5C8B54B6","device_confirm":"907C6AE839829304B93CD128781343F82D3D5426EBD2D180255108F34E51625A2FAFBFED5C8B54B6E2A185D2F8527D28"}}} 2026-08-11 22:17:10.641 - debug: tapo.0 (2801788) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true 2026-08-11 22:17:10.641 - debug: tapo.0 (2801788) refreshStok: Refreshing stok... 2026-08-11 22:17:10.642 - debug: tapo.0 (2801788) refreshStok: isSecureConnection=true username=admin cnonce=072CCDD98547C673 2026-08-11 22:17:10.675 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:10.675 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false} 2026-08-11 22:17:10.675 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:10.949 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:10.949 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:10.952 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:11.121 - debug: tapo.0 (2801788) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"A284ADE22178AD11","device_confirm":"C64A7FCB68CFD3E3766132395254E3993A9D4899F7B3D7026A29B9841522759DA284ADE22178AD11072CCDD98547C673"}}} 2026-08-11 22:17:11.122 - debug: tapo.0 (2801788) refreshStok: nonce=A284ADE22178AD11... deviceConfirm=C64A7FCB68CFD3E3... 2026-08-11 22:17:11.122 - debug: tapo.0 (2801788) validateDeviceConfirm: matched candidate #1 via sha256 2026-08-11 22:17:11.122 - debug: tapo.0 (2801788) refreshStok: deviceConfirm validated, encryptionMethod=sha256 2026-08-11 22:17:11.122 - debug: tapo.0 (2801788) refreshStok: sending start_seq request 2026-08-11 22:17:11.285 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:11.285 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:11.303 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:11.468 - debug: tapo.0 (2801788) refreshStok: start_seq response 2026-08-11 22:17:11.469 - debug: tapo.0 (2801788) refreshStok: start_seq=3564538 user_group=root stok=present 2026-08-11 22:17:11.469 - debug: tapo.0 (2801788) refreshStok: Success in obtaining STOK 2026-08-11 22:17:11.606 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:11.627 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:11.627 - debug: tapo.0 (2801788) API request already pending 2026-08-11 22:17:11.903 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:11.904 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false} 2026-08-11 22:17:11.904 - info: tapo.0 (2801788) Reconnected to undefined 2026-08-11 22:17:11.904 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:11.904 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false} 2026-08-11 22:17:11.904 - debug: tapo.0 (2801788) API request already pending 2026-08-11 22:17:12.257 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:12.257 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:12.257 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:12.323 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:12.371 - debug: tapo.0 (2801788) API request already pending 2026-08-11 22:17:12.701 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:12.701 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:12.701 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:12.789 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:12.833 - debug: tapo.0 (2801788) API request already pending 2026-08-11 22:17:13.181 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:13.203 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:13.203 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:13.203 - debug: tapo.0 (2801788) isSecureConnection: Checking secure connection... 2026-08-11 22:17:13.299 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:13.300 - debug: tapo.0 (2801788) API request already pending 2026-08-11 22:17:13.516 - debug: tapo.0 (2801788) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"7DAAD745586EBA88","device_confirm":"21FE946BF70DC4CF1D9B21F6B9B570F9EF138DAE34CE1D04FD9D35A67263E1197DAAD745586EBA885A233A46DB9EB4DC"}}} 2026-08-11 22:17:13.516 - debug: tapo.0 (2801788) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true 2026-08-11 22:17:13.516 - debug: tapo.0 (2801788) refreshStok: Refreshing stok... 2026-08-11 22:17:13.516 - debug: tapo.0 (2801788) refreshStok: isSecureConnection=true username=admin cnonce=7C8E9FB345EEB39E 2026-08-11 22:17:13.839 - debug: tapo.0 (2801788) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"A99ECDBE04E20F94","device_confirm":"CE2DFC8ACD8E90B2679280F8485E75CD1686769B29270D0A1AD39E4933FC2FE8A99ECDBE04E20F947C8E9FB345EEB39E"}}} 2026-08-11 22:17:13.839 - debug: tapo.0 (2801788) refreshStok: nonce=A99ECDBE04E20F94... deviceConfirm=CE2DFC8ACD8E90B2... 2026-08-11 22:17:13.840 - debug: tapo.0 (2801788) validateDeviceConfirm: matched candidate #1 via sha256 2026-08-11 22:17:13.840 - debug: tapo.0 (2801788) refreshStok: deviceConfirm validated, encryptionMethod=sha256 2026-08-11 22:17:13.840 - debug: tapo.0 (2801788) refreshStok: sending start_seq request 2026-08-11 22:17:14.141 - debug: tapo.0 (2801788) refreshStok: start_seq response 2026-08-11 22:17:14.141 - debug: tapo.0 (2801788) refreshStok: start_seq=6210465 user_group=root stok=present 2026-08-11 22:17:14.141 - debug: tapo.0 (2801788) refreshStok: Success in obtaining STOK 2026-08-11 22:17:14.508 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:14.508 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false} 2026-08-11 22:17:14.508 - info: tapo.0 (2801788) Reconnected to undefined 2026-08-11 22:17:14.509 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:14.509 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false} 2026-08-11 22:17:14.509 - debug: tapo.0 (2801788) API request already pending 2026-08-11 22:17:14.829 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:14.829 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:14.829 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:14.857 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:14.864 - debug: tapo.0 (2801788) API request already pending 2026-08-11 22:17:15.165 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:15.165 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:15.165 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:15.245 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:15.288 - debug: tapo.0 (2801788) API request already pending 2026-08-11 22:17:15.571 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:15.612 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:15.613 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:15.613 - debug: tapo.0 (2801788) isSecureConnection: Checking secure connection... 2026-08-11 22:17:15.699 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:15.700 - debug: tapo.0 (2801788) API request already pending 2026-08-11 22:17:16.006 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2802654 2026-08-11 22:17:16.530 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:16.531 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:16.955 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:16.955 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true} 2026-08-11 22:17:16.956 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:17.176 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:17.176 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:17.250 - info: netatmo-crawler.0 (2802654) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2 2026-08-11 22:17:17.264 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:17.313 - info: netatmo-crawler.0 (2802654) Getting data for stationid:70:ee:50:05:f2:d4 2026-08-11 22:17:17.470 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:17.470 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:17.485 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:17.674 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:17.681 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:17.681 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:17.952 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:17.953 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false} 2026-08-11 22:17:17.953 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:18.286 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:18.286 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:18.288 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:18.584 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:18.584 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:18.614 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:18.876 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:18.886 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:18.886 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:19.392 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:19.392 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false} 2026-08-11 22:17:19.393 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:19.808 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:19.808 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:19.811 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:20.169 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:20.169 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:20.190 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:20.265 - info: netatmo-crawler.0 (2802654) Getting data for stationid:70:ee:50:90:ce:ea 2026-08-11 22:17:20.539 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:20.548 - debug: tapo.0 (2801788) Receive camera status 2026-08-11 22:17:20.548 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:20.864 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:20.864 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false} 2026-08-11 22:17:20.864 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:20.889 - debug: tapo.0 (2801788) Get camera Status failed: fetch failed 2026-08-11 22:17:20.889 - debug: tapo.0 (2801788) Get camera Status failed: fetch failed 2026-08-11 22:17:20.889 - debug: tapo.0 (2801788) undefined 2026-08-11 22:17:20.889 - debug: tapo.0 (2801788) Update done 2026-08-11 22:17:20.889 - debug: tapo.0 (2801788) undefined 2026-08-11 22:17:20.889 - debug: tapo.0 (2801788) Update done 2026-08-11 22:17:21.057 - info: host.iOProduktiv "system.adapter.tapo.0" disabled 2026-08-11 22:17:21.057 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 (force=false, process=true) 2026-08-11 22:17:21.062 - info: tapo.0 (2801788) Got terminate signal TERMINATE_YOURSELF 2026-08-11 22:17:21.063 - info: tapo.0 (2801788) terminating 2026-08-11 22:17:21.063 - info: tapo.0 (2801788) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2026-08-11 22:17:21.165 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:21.165 - debug: tapo.0 (2801788) searchDetectionList raw: {} 2026-08-11 22:17:21.217 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 send kill signal 2026-08-11 22:17:21.248 - info: netatmo-crawler.0 (2802654) Getting data for stationid:70:ee:50:2e:f6:c0 2026-08-11 22:17:21.276 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:21.563 - info: tapo.0 (2801788) terminating 2026-08-11 22:17:21.563 - info: tapo.0 (2801788) terminating 2026-08-11 22:17:21.593 - debug: tapo.0 (2801788) API response 2026-08-11 22:17:21.593 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0} 2026-08-11 22:17:21.594 - debug: tapo.0 (2801788) redis get tapo.0.8021314EFB57E17626EC16DBDB2A31A51E64292E.alarmInfo.enabled, error - Connection is closed. 2026-08-11 22:17:21.594 - error: tapo.0 (2801788) Error extract keys: 8021314EFB57E17626EC16DBDB2A31A51E64292E.alarmInfo {"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"} 2026-08-11 22:17:21.596 - error: tapo.0 (2801788) Error: DB closed 2026-08-11 22:17:21.596 - debug: tapo.0 (2801788) New API request 2026-08-11 22:17:21.718 - info: host.iOProduktiv instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)An dieser Stelle, noch einmal Danke für deinen vielen Aufwand mit meinem Problem.
LG -
Moien,
ich hab mehrere CW520 und auch eine CW560 hier werden mir keine Bewegungen angezeigt oder bin ich hier falsch ? Der Adapter ist der Aktuelle 0.6.12 und der Login ergab auch keine Fehler im Log !
unter
zeigt er mir immer wieder mal eine Bewegung an !
aber diese Ordner finde ich unter keiner Kamera,
Nach etwas Nutzen des Adapters mit meinen Kameras habe ich gemerkt, dass ich die batteriebetriebenen Geräte (C425) lieber nicht standardmäßig aktiviere, da der Akkuverbrauch zu groß ist.
Dennoch würde ich gerne den Privatsphärenmodus schalten können.
Mögliche Ideen wären:- Das Polling-Interval für Batterie-Geräte separat einzustellen und auf einen sehr hohen Wert zu stellen oder auszuschalten
- die Option "Batteriegeräte aktivieren" als Datenpunkt (?) mit anzusteuern, wenn man einen remote Befehl senden möchte und dann wieder ausschaltet.
Ist das irgendwie möglich oder hat jemand eine Idee für einen Workaround?
Ich antworte mir mal selbst, aber vielleicht ist das Vorgehen auch für den Adapter nutzbar oder für andere Nutzer von Interesse:
ich habe mir ein pythonskript erstellt:
import sys import time from pytapo import Tapo if len(sys.argv) < 5: print("Fehler: Zu wenige Argumente.") print("Nutzung: python tapo_privacy.py <IP> <USER> <PASS> <TRUE/FALSE>") sys.exit(1) ip = sys.argv[1] user = sys.argv[2] password = sys.argv[3] # Akzeptiert 'true', '1', 'on' als Aktivierung state = sys.argv[4].lower() in ['true', '1', 'on'] max_retries = 3 retry_delay = 2 # Sekunden Pause zwischen Versuchen for attempt in range(1, max_retries + 1): try: tapo = Tapo(ip, user, password) tapo.setPrivacyMode(state) print(f"Erfolg: Privatsphäre-Modus auf {state} gesetzt (Versuch {attempt}).") sys.exit(0) except Exception as e: print(f"Versuch {attempt} fehlgeschlagen: {e}") if attempt < max_retries: time.sleep(retry_delay) print("Fehler: Privatsphäre-Modus konnte nicht geschaltet werden.") sys.exit(1)schalten kann ich dann mit
/opt/iobroker/scripts/venv/bin/python /opt/iobroker/scripts/tapo_privacy.py 192.168.x.x "DeinUser" "DeinPasswort" true/false -
Hallo zusammen. Habe mir heute den Adapter Installiert ohne Probleme.
Habe 2 Geräte 1 x P100 und 1x C520WS beide Geräte werden erkannt und unter Objecte angezeigt und Änderungen am Geräte werden erkannt und in iobroker übernommen.
Nur kann ich leider die Geräte mit dem Adapter nicht steuern. Was mache ich falsch? -
Nur kann ich leider die Geräte mit dem Adapter nicht steuern. Was mache ich falsch?Linux-Werkzeugkasten:
iob_diag: curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh -
Und was war es nun? So für die Nachwelt und andere 'Suchende'.
