  4. Test Adapter TP-Link Tapo
887 Beiträge 123 Kommentatoren 450.8k Aufrufe 107 Beobachtet
  • V Verblizz
    @tombox
    EDIT: Neues Logfile, Adapter aktualisier über Github...
    Version: 0.6.1
    2026-08-09 19:57:11.652 - info: tapo.0 (37287) terminating
    2026-08-09 19:57:11.714 - info: host.iobroker instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-08-09 19:57:15.066 - info: host.iobroker instance system.adapter.tapo.0 in version "0.6.1" (non-npm: TA2k/ioBroker.tapo) started with pid 37340
    2026-08-09 19:57:16.259 - debug: tapo.0 (37340) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2026-08-09 19:57:16.303 - debug: tapo.0 (37340) Objects client ready ... initialize now
    2026-08-09 19:57:16.325 - debug: tapo.0 (37340) Objects create System PubSub Client
    2026-08-09 19:57:16.325 - debug: tapo.0 (37340) Objects create User PubSub Client
    2026-08-09 19:57:16.404 - debug: tapo.0 (37340) Objects client initialize lua scripts
    2026-08-09 19:57:16.412 - debug: tapo.0 (37340) Objects connected to redis: 127.0.0.1:9001
    2026-08-09 19:57:16.461 - debug: tapo.0 (37340) Redis States: Use Redis connection: 127.0.0.1:9000
    2026-08-09 19:57:16.561 - debug: tapo.0 (37340) States create System PubSub Client
    2026-08-09 19:57:16.561 - debug: tapo.0 (37340) States create User PubSub Client
    2026-08-09 19:57:16.655 - debug: tapo.0 (37340) States connected to redis: 127.0.0.1:9000
    2026-08-09 19:57:16.987 - info: tapo.0 (37340) starting. Version 0.6.1 (non-npm: TA2k/ioBroker.tapo) in /opt/iobroker/node_modules/iobroker.tapo, node: v22.23.2, js-controller: 7.2.2
    2026-08-09 19:57:17.070 - info: tapo.0 (37340) Login tp TAPO App
    2026-08-09 19:57:17.117 - debug: tapo.0 (37340) PhfpcfgLhDIE0EjXyvdL6A==
    2026-08-09 19:57:17.365 - debug: tapo.0 (37340) {"error_code":0,"result":{"accountApiUrl":"https://euw1-account-api.i.tplinkcloud.com","lockedMinutes":0,"appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"982be621-BTnz2hJCxtzspuSEZG6fVr0","accountId":"12622011259772","regionCode":"DE","regTime":"2026-08-08 11:35:10","nickname":"reinhardjanz","email":"reinhardjanz@gmx.de","appServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com","refreshToken":"982be621-BTTpLMqxqDHOhE3HHQlVTu0"}}
    2026-08-09 19:57:17.365 - info: tapo.0 (37340) Login succesfull
    2026-08-09 19:57:17.365 - debug: tapo.0 (37340) yfoQzXVQIYQWjRDZuXyppQ==
    2026-08-09 19:57:17.506 - debug: tapo.0 (37340) {"error_code":0,"result":{"totalNum":0,"deviceList":[],"currentIndex":0}}
    2026-08-09 19:57:17.507 - info: tapo.0 (37340) Found 0 devices
    2026-08-09 19:57:17.509 - info: tapo.0 (37340) Wait for connections for non camera devices
    2026-08-09 19:57:27.510 - info: tapo.0 (37340) Start first Update
    2026-08-09 19:57:27.511 - debug: tapo.0 (37340) Update done
    2026-08-09 19:57:37.511 - debug: tapo.0 (37340) Update done
    T
    T
    tombox
    #872
    @Verblizz nochmal via GitHub installieren
    V 2 Antworten Letzte Antwort
    • T tombox
      V
      V
      Verblizz
      #873
      @tombox
      Super, jetzt funktioniert es, vielen Dank!
      • T tombox
        V
        V
        Verblizz
        #874
        @tombox
        Einzig ein Fehler taucht noch auf:
        2026-08-10 15:55:34.013 - info: tapo.0 (128259) Init device 803D23D0309E68C507631FA1A1EA727F259B436D type D100C with ip 192.168.30.126
        2026-08-10 15:55:34.013 - debug: tapo.0 (128259) UDP discovery for 192.168.30.126 on port 20002
        2026-08-10 15:55:34.131 - info: tapo.0 (128259) UDP discovery for 192.168.30.126: port=80 https=false encrypt=TPAP lv=2 mac=EC-B9-31-02-21-51
        2026-08-10 15:55:34.148 - error: tapo.0 (128259) connect ECONNREFUSED 192.168.30.126:2020
        2026-08-10 15:55:34.148 - debug: tapo.0 (128259) initResult camera 803D23D0309E68C507631FA1A1EA727F259B436D undefined
        2026-08-10 15:55:34.149 - debug: tapo.0 (128259) Found device 803C16BCB6C302A281023FB31A8A9C8925A27E43 Haustür
        Kannst Du damit etwas anfangen?
        Ansonsten habe ich scheinbar alle Datenpunkte, vor allem das RingEvent, das war mir wichtig...
        • metaxaM
          metaxaM
          metaxa
          #875
          Servus @tombox
          Ich hatte schon vor ca. 1 Jahr einen Versuch unternommen meine Tapo Cams über deinen Adapter einzubinden.
          1x C520WS, 1x C200, 1x C530WS (2x C310)
          Alle Cams wurden sofort vom Adapter gefunden, sehr viele DP angelegt und diese tun was sie sollen. Fast.
          Leider funktionieren bei allen PTZ Cams die DP "MoveToPreset" nicht.
          Log im Debug Modus
          2026-08-10 19:47:22.472 - info: host.iOProduktiv "system.adapter.tapo.0" enabled
          2026-08-10 19:47:24.522 - info: host.iOProduktiv instance system.adapter.tapo.0 in version "0.5.5" (non-npm: TA2k/ioBroker.tapo) started with pid 1411942
          2026-08-10 19:47:25.656 - debug: tapo.0 (1411942) Redis Objects: Use Redis connection: 0.0.0.0:9001
          2026-08-10 19:47:25.713 - debug: tapo.0 (1411942) Objects client ready ... initialize now
          2026-08-10 19:47:25.759 - debug: tapo.0 (1411942) Objects create System PubSub Client
          2026-08-10 19:47:25.760 - debug: tapo.0 (1411942) Objects create User PubSub Client
          2026-08-10 19:47:25.877 - debug: tapo.0 (1411942) Objects client initialize lua scripts
          2026-08-10 19:47:25.880 - debug: tapo.0 (1411942) Objects connected to redis: 0.0.0.0:9001
          2026-08-10 19:47:25.950 - debug: tapo.0 (1411942) Redis States: Use Redis connection: 0.0.0.0:9000
          2026-08-10 19:47:26.004 - debug: tapo.0 (1411942) States create System PubSub Client
          2026-08-10 19:47:26.005 - debug: tapo.0 (1411942) States create User PubSub Client
          2026-08-10 19:47:26.157 - debug: tapo.0 (1411942) States connected to redis: 0.0.0.0:9000
          2026-08-10 19:47:26.333 - info: tapo.0 (1411942) starting. Version 0.5.5 (non-npm: TA2k/ioBroker.tapo) in /opt/iobroker/node_modules/iobroker.tapo, node: v22.23.0, js-controller: 7.2.2
          2026-08-10 19:47:26.392 - info: tapo.0 (1411942) Login tp TAPO App
          2026-08-10 19:47:26.395 - debug: tapo.0 (1411942) xaYE4SMWpkdB/E8dxzgSWA==
          2026-08-10 19:47:26.688 - debug: tapo.0 (1411942) {"error_code":0,"result":{"accountApiUrl":"https://euw1-account-api.i.tplinkcloud.com","lockedMinutes":0,"appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"38ee8e2b-BTKHJrLsh89rCNWrqHQI6DZ","accountId":"37806770","regionCode":"AT","regTime":"2021-06-23 14:33:54","nickname":"mxa","email":"mxa@gmx.at","appServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com","refreshToken":"38ee8e2b-BTQsPoCVASGPAYEwdb5gnGd"}}
          2026-08-10 19:47:26.689 - info: tapo.0 (1411942) Login succesfull
          2026-08-10 19:47:26.689 - debug: tapo.0 (1411942) yfoQzXVQIYQWjRDZuXyppQ==
          2026-08-10 19:47:26.924 - debug: tapo.0 (1411942) {"error_code":0,"result":{"totalNum":5,"deviceList":[{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0","deviceName":"C310 2.0","lastBindTime":1784968460000,"deviceHwVer":"2.0","alias":"Postkasten","deviceMac":"005F67798FDD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.4 Build 250811 Rel.34127n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80219D887A52D32D03212C4C2DE37E4D21EC8028","deviceName":"C520WS 1.0","lastBindTime":1705169151000,"deviceHwVer":"1.0","alias":"Terrasse","deviceMac":"F0A731D87F97","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","deviceModel":"C520WS","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.4.4 Build 260527 Rel.28339n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802114698B0C4DB803277811859F5C6723111712","deviceName":"C200 5.0","lastBindTime":1785313977000,"deviceHwVer":"5.0","alias":"Beet","deviceMac":"B019213463BA","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","deviceModel":"C200","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021314EFB57E17626EC16DBDB2A31A51E64292E","deviceName":"C310 2.0","lastBindTime":1632395306000,"deviceHwVer":"2.0","alias":"Haus Eingang vorne","deviceMac":"005F67798FBD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.5 Build 260323 Rel.35521n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802173FB22D1FB8B96E616F599FE462C24EBEDA7","deviceName":"C530WS 2.0","lastBindTime":1782991868000,"deviceHwVer":"2.0","alias":"Einfahrt","deviceMac":"6C4CBC025F2C","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","deviceModel":"C530WS","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0}],"currentIndex":4}}
          2026-08-10 19:47:26.925 - info: tapo.0 (1411942) Found 5 devices
          2026-08-10 19:47:26.925 - debug: tapo.0 (1411942) Found device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Postkasten
          2026-08-10 19:47:27.430 - debug: tapo.0 (1411942) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"","mac":"005F67798FDD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.110","onboardingTime":1784968460,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
          2026-08-10 19:47:27.431 - info: tapo.0 (1411942) Init device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 type C310 2.0 with ip 192.168.0.110
          2026-08-10 19:47:27.432 - debug: tapo.0 (1411942) UDP discovery for 192.168.0.110 on port 20002
          2026-08-10 19:47:27.546 - info: tapo.0 (1411942) UDP discovery for 192.168.0.110: port=80 https=true encrypt=undefined lv=undefined mac=00-5F-67-79-8F-DD
          2026-08-10 19:47:27.629 - info: tapo.0 (1411942) 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2}
          2026-08-10 19:47:27.629 - debug: tapo.0 (1411942) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2}
          2026-08-10 19:47:27.629 - debug: tapo.0 (1411942) Init event emitter for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0
          2026-08-10 19:47:27.633 - debug: tapo.0 (1411942) Init event listener for "motion"
          2026-08-10 19:47:27.633 - info: tapo.0 (1411942) Initialized 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0
          2026-08-10 19:47:27.633 - debug: tapo.0 (1411942) initResult camera 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 undefined
          2026-08-10 19:47:27.633 - debug: tapo.0 (1411942) Found device 80219D887A52D32D03212C4C2DE37E4D21EC8028 M��j�
          2026-08-10 19:47:27.912 - debug: tapo.0 (1411942) {"hwVer":"1.0","category":"camera","model":"C520WS 1.0","ssid":"","mac":"F0A731D87F97","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","fwVer":"1.3.4 Build 250811 Rel.34127n","ip":"192.168.0.112","onboardingTime":1705169153,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
          2026-08-10 19:47:27.912 - info: tapo.0 (1411942) Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.112
          2026-08-10 19:47:27.912 - debug: tapo.0 (1411942) UDP discovery for 192.168.0.112 on port 20002
          2026-08-10 19:47:27.990 - info: tapo.0 (1411942) UDP discovery for 192.168.0.112: port=80 https=true encrypt=undefined lv=undefined mac=F0-A7-31-D8-7F-97
          2026-08-10 19:47:28.518 - info: tapo.0 (1411942) 80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1}
          2026-08-10 19:47:28.518 - debug: tapo.0 (1411942) {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1}
          2026-08-10 19:47:28.518 - debug: tapo.0 (1411942) Init event emitter for 80219D887A52D32D03212C4C2DE37E4D21EC8028
          2026-08-10 19:47:28.546 - debug: tapo.0 (1411942) Init event listener for "motion"
          2026-08-10 19:47:28.546 - info: tapo.0 (1411942) Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
          2026-08-10 19:47:28.546 - debug: tapo.0 (1411942) initResult camera 80219D887A52D32D03212C4C2DE37E4D21EC8028 undefined
          2026-08-10 19:47:28.547 - debug: tapo.0 (1411942) Found device 802114698B0C4DB803277811859F5C6723111712 �
          2026-08-10 19:47:28.857 - debug: tapo.0 (1411942) {"hwVer":"5.0","category":"camera","model":"C200 5.0","ssid":"videosun","mac":"B019213463BA","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","fwVer":"1.4.4 Build 260527 Rel.28339n","ip":"192.168.0.114","onboardingTime":1785313979,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
          2026-08-10 19:47:28.857 - info: tapo.0 (1411942) Init device 802114698B0C4DB803277811859F5C6723111712 type C200 5.0 with ip 192.168.0.114
          2026-08-10 19:47:28.857 - debug: tapo.0 (1411942) UDP discovery for 192.168.0.114 on port 20002
          2026-08-10 19:47:28.965 - info: tapo.0 (1411942) UDP discovery for 192.168.0.114: port=80 https=true encrypt=undefined lv=undefined mac=B0-19-21-34-63-BA
          2026-08-10 19:47:29.251 - info: tapo.0 (1411942) 802114698B0C4DB803277811859F5C6723111712 Received device info {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5}
          2026-08-10 19:47:29.251 - debug: tapo.0 (1411942) {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5}
          2026-08-10 19:47:29.252 - debug: tapo.0 (1411942) Init event emitter for 802114698B0C4DB803277811859F5C6723111712
          2026-08-10 19:47:29.254 - debug: tapo.0 (1411942) Init event listener for "motion"
          2026-08-10 19:47:29.254 - info: tapo.0 (1411942) Initialized 802114698B0C4DB803277811859F5C6723111712
          2026-08-10 19:47:29.254 - debug: tapo.0 (1411942) initResult camera 802114698B0C4DB803277811859F5C6723111712 undefined
          2026-08-10 19:47:29.254 - debug: tapo.0 (1411942) Found device 8021314EFB57E17626EC16DBDB2A31A51E64292E Haus Eingang vorne
          2026-08-10 19:47:29.581 - debug: tapo.0 (1411942) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"Sun 2.4","mac":"005F67798FBD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.113","onboardingTime":0,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
          2026-08-10 19:47:29.582 - info: tapo.0 (1411942) Init device 8021314EFB57E17626EC16DBDB2A31A51E64292E type C310 2.0 with ip 192.168.0.113
          2026-08-10 19:47:29.582 - debug: tapo.0 (1411942) UDP discovery for 192.168.0.113 on port 20002
          2026-08-10 19:47:29.639 - info: tapo.0 (1411942) UDP discovery for 192.168.0.113: port=80 https=true encrypt=undefined lv=undefined mac=00-5F-67-79-8F-BD
          2026-08-10 19:47:30.011 - info: tapo.0 (1411942) 8021314EFB57E17626EC16DBDB2A31A51E64292E Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2}
          2026-08-10 19:47:30.011 - debug: tapo.0 (1411942) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2}
          2026-08-10 19:47:30.011 - debug: tapo.0 (1411942) Init event emitter for 8021314EFB57E17626EC16DBDB2A31A51E64292E
          2026-08-10 19:47:30.013 - debug: tapo.0 (1411942) Init event listener for "motion"
          2026-08-10 19:47:30.014 - info: tapo.0 (1411942) Initialized 8021314EFB57E17626EC16DBDB2A31A51E64292E
          2026-08-10 19:47:30.014 - debug: tapo.0 (1411942) initResult camera 8021314EFB57E17626EC16DBDB2A31A51E64292E undefined
          2026-08-10 19:47:30.014 - debug: tapo.0 (1411942) Found device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 )�j�
          2026-08-10 19:47:30.326 - debug: tapo.0 (1411942) {"hwVer":"2.0","category":"camera","model":"C530WS 2.0","ssid":"","mac":"6C4CBC025F2C","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","fwVer":"1.3.5 Build 260323 Rel.35521n","ip":"192.168.0.115","onboardingTime":1782991869,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
          2026-08-10 19:47:30.327 - info: tapo.0 (1411942) Init device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 type C530WS 2.0 with ip 192.168.0.115
          2026-08-10 19:47:30.327 - debug: tapo.0 (1411942) UDP discovery for 192.168.0.115 on port 20002
          2026-08-10 19:47:30.393 - info: tapo.0 (1411942) UDP discovery for 192.168.0.115: port=80 https=true encrypt=undefined lv=undefined mac=6C-4C-BC-02-5F-2C
          2026-08-10 19:47:30.865 - info: tapo.0 (1411942) 802173FB22D1FB8B96E616F599FE462C24EBEDA7 Received device info {"manufacturer":"tp-link","model":"Tapo C530WS","firmwareVersion":"1.3.5 Build 260323 Rel.35521n","serialNumber":"74615f2c","hardwareId":2}
          2026-08-10 19:47:30.865 - debug: tapo.0 (1411942) {"manufacturer":"tp-link","model":"Tapo C530WS","firmwareVersion":"1.3.5 Build 260323 Rel.35521n","serialNumber":"74615f2c","hardwareId":2}
          2026-08-10 19:47:30.865 - debug: tapo.0 (1411942) Init event emitter for 802173FB22D1FB8B96E616F599FE462C24EBEDA7
          2026-08-10 19:47:30.870 - debug: tapo.0 (1411942) Init event listener for "motion"
          2026-08-10 19:47:30.870 - info: tapo.0 (1411942) Initialized 802173FB22D1FB8B96E616F599FE462C24EBEDA7
          2026-08-10 19:47:30.870 - debug: tapo.0 (1411942) initResult camera 802173FB22D1FB8B96E616F599FE462C24EBEDA7 undefined
          2026-08-10 19:47:30.931 - info: tapo.0 (1411942) Wait for connections for non camera devices
          2026-08-10 19:47:40.932 - info: tapo.0 (1411942) Start first Update
          2026-08-10 19:47:40.933 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:47:40.933 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:40.933 - debug: tapo.0 (1411942) isSecureConnection: Checking secure connection...
          2026-08-10 19:47:41.198 - debug: tapo.0 (1411942) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"B648B02C8FBAA0AD","device_confirm":"6DDE6DCF0ED10AE0846114E4AE9011E816401ED27E6A56E29469B2AF728D8232B648B02C8FBAA0AD4A23C8D6F4ECD67E"}}}
          2026-08-10 19:47:41.198 - debug: tapo.0 (1411942) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
          2026-08-10 19:47:41.198 - debug: tapo.0 (1411942) refreshStok: Refreshing stok...
          2026-08-10 19:47:41.199 - debug: tapo.0 (1411942) refreshStok: isSecureConnection=true username=admin cnonce=B2407FF12CC681EC
          2026-08-10 19:47:41.473 - debug: tapo.0 (1411942) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"9635A1EF7E960BE1","device_confirm":"AAE738A78D110D9CD0D04B04EF48D6B6EBF5F627B1426478DA4D011860CC3F4B9635A1EF7E960BE1B2407FF12CC681EC"}}}
          2026-08-10 19:47:41.473 - debug: tapo.0 (1411942) refreshStok: nonce=9635A1EF7E960BE1... deviceConfirm=AAE738A78D110D9C...
          2026-08-10 19:47:41.473 - debug: tapo.0 (1411942) refreshStok: deviceConfirm validated, encryptionMethod=sha256
          2026-08-10 19:47:41.474 - debug: tapo.0 (1411942) refreshStok: sending start_seq request
          2026-08-10 19:47:41.710 - debug: tapo.0 (1411942) refreshStok: start_seq response
          2026-08-10 19:47:41.710 - debug: tapo.0 (1411942) refreshStok: start_seq=6541043 user_group=root stok=present
          2026-08-10 19:47:41.710 - debug: tapo.0 (1411942) refreshStok: Success in obtaining STOK
          2026-08-10 19:47:41.953 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:41.954 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
          2026-08-10 19:47:41.954 - info: tapo.0 (1411942) Reconnected to undefined
          2026-08-10 19:47:41.954 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:42.243 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:42.244 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:47:42.363 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:42.577 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:42.579 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:47:42.877 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:43.100 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:43.126 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:47:43.126 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:43.126 - debug: tapo.0 (1411942) isSecureConnection: Checking secure connection...
          2026-08-10 19:47:43.374 - debug: tapo.0 (1411942) isSecureConnection response status=200 data={"result":{"data":{"code":-40401,"time":9,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"EF4AAE02BF4F4C05","device_confirm":"0748416CA64187108C6091E6FAA18B81F07A43D5510B8567CA60A8D2CC1323EBEF4AAE02BF4F4C0594DCAC7B43399A3C"}},"error_code":-40413}
          2026-08-10 19:47:43.374 - debug: tapo.0 (1411942) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
          2026-08-10 19:47:43.374 - debug: tapo.0 (1411942) refreshStok: Refreshing stok...
          2026-08-10 19:47:43.374 - debug: tapo.0 (1411942) refreshStok: isSecureConnection=true username=admin cnonce=A9B3FCA390357FFF
          2026-08-10 19:47:43.593 - debug: tapo.0 (1411942) refreshStok: Login response status=200 data={"result":{"data":{"code":-40401,"time":8,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"EBAEEBF7DBBB2AB9","device_confirm":"0A529C52702829F7D443F999F2025B9234C59E0FE93B9E425C0A414FA77D1E8CEBAEEBF7DBBB2AB9A9B3FCA390357FFF"}},"error_code":-40413}
          2026-08-10 19:47:43.593 - debug: tapo.0 (1411942) refreshStok: nonce=EBAEEBF7DBBB2AB9... deviceConfirm=0A529C52702829F7...
          2026-08-10 19:47:43.594 - debug: tapo.0 (1411942) refreshStok: deviceConfirm validated, encryptionMethod=sha256
          2026-08-10 19:47:43.594 - debug: tapo.0 (1411942) refreshStok: sending start_seq request
          2026-08-10 19:47:43.887 - debug: tapo.0 (1411942) refreshStok: start_seq response
          2026-08-10 19:47:43.888 - debug: tapo.0 (1411942) refreshStok: start_seq=372 user_group=root stok=present
          2026-08-10 19:47:43.888 - debug: tapo.0 (1411942) refreshStok: Success in obtaining STOK
          2026-08-10 19:47:44.199 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:44.199 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:47:44.199 - info: tapo.0 (1411942) Reconnected to undefined
          2026-08-10 19:47:44.199 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:44.487 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:44.487 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:47:44.628 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:44.937 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:44.937 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:47:45.113 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:45.427 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:45.445 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:47:45.445 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:45.445 - debug: tapo.0 (1411942) isSecureConnection: Checking secure connection...
          2026-08-10 19:47:45.911 - debug: tapo.0 (1411942) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"2FAFBFED5C8B54B6","device_confirm":"D49509BB99A9C40AD01163425D0FB69E6CD63D14071F31F5D41D6F154DDBD7F82FAFBFED5C8B54B6F8D240D788AB5F5E"}}}
          2026-08-10 19:47:45.912 - debug: tapo.0 (1411942) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
          2026-08-10 19:47:45.912 - debug: tapo.0 (1411942) refreshStok: Refreshing stok...
          2026-08-10 19:47:45.912 - debug: tapo.0 (1411942) refreshStok: isSecureConnection=true username=admin cnonce=D3FF93A23A11C8C1
          2026-08-10 19:47:46.283 - debug: tapo.0 (1411942) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"A284ADE22178AD11","device_confirm":"91F6164C299654DB917FE4D7D29135347F7A9B8D4BBF74C2C65F74AE8673E596A284ADE22178AD11D3FF93A23A11C8C1"}}}
          2026-08-10 19:47:46.283 - debug: tapo.0 (1411942) refreshStok: nonce=A284ADE22178AD11... deviceConfirm=91F6164C299654DB...
          2026-08-10 19:47:46.283 - debug: tapo.0 (1411942) refreshStok: deviceConfirm validated, encryptionMethod=sha256
          2026-08-10 19:47:46.283 - debug: tapo.0 (1411942) refreshStok: sending start_seq request
          2026-08-10 19:47:46.758 - debug: tapo.0 (1411942) refreshStok: start_seq response
          2026-08-10 19:47:46.759 - debug: tapo.0 (1411942) refreshStok: start_seq=3528198 user_group=root stok=present
          2026-08-10 19:47:46.759 - debug: tapo.0 (1411942) refreshStok: Success in obtaining STOK
          2026-08-10 19:47:47.303 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:47.303 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
          2026-08-10 19:47:47.303 - info: tapo.0 (1411942) Reconnected to undefined
          2026-08-10 19:47:47.303 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:47.755 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:47.756 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:47:47.813 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:48.312 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:48.312 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:47:48.355 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:48.755 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:48.771 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:47:48.772 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:48.772 - debug: tapo.0 (1411942) isSecureConnection: Checking secure connection...
          2026-08-10 19:47:49.249 - debug: tapo.0 (1411942) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"7DAAD745586EBA88","device_confirm":"AE6040A242FE265FF01C477DDF82D7B359C73C9144CB6189DE04687A260373FE7DAAD745586EBA885053599C34D4778E"}}}
          2026-08-10 19:47:49.249 - debug: tapo.0 (1411942) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
          2026-08-10 19:47:49.249 - debug: tapo.0 (1411942) refreshStok: Refreshing stok...
          2026-08-10 19:47:49.249 - debug: tapo.0 (1411942) refreshStok: isSecureConnection=true username=admin cnonce=146B98D33B5EB882
          2026-08-10 19:47:49.569 - debug: tapo.0 (1411942) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"A99ECDBE04E20F94","device_confirm":"DA041A367DE263CB6E654CA9B5862271E223BCADFB839D9A1241B3979219DE55A99ECDBE04E20F94146B98D33B5EB882"}}}
          2026-08-10 19:47:49.569 - debug: tapo.0 (1411942) refreshStok: nonce=A99ECDBE04E20F94... deviceConfirm=DA041A367DE263CB...
          2026-08-10 19:47:49.569 - debug: tapo.0 (1411942) refreshStok: deviceConfirm validated, encryptionMethod=sha256
          2026-08-10 19:47:49.569 - debug: tapo.0 (1411942) refreshStok: sending start_seq request
          2026-08-10 19:47:49.978 - debug: tapo.0 (1411942) refreshStok: start_seq response
          2026-08-10 19:47:49.978 - debug: tapo.0 (1411942) refreshStok: start_seq=47061845 user_group=root stok=present
          2026-08-10 19:47:49.978 - debug: tapo.0 (1411942) refreshStok: Success in obtaining STOK
          2026-08-10 19:47:50.334 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:50.334 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:47:50.334 - info: tapo.0 (1411942) Reconnected to undefined
          2026-08-10 19:47:50.334 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:50.706 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:50.706 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:47:50.816 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:50.938 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:47:50.939 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:51.180 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:51.180 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:47:51.211 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:51.211 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
          2026-08-10 19:47:51.211 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:51.469 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:51.469 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:47:51.526 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:51.584 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:51.762 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:51.763 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:47:51.794 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:51.920 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:51.948 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:47:51.948 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:51.948 - debug: tapo.0 (1411942) isSecureConnection: Checking secure connection...
          2026-08-10 19:47:52.039 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:52.053 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:47:52.053 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:52.194 - debug: tapo.0 (1411942) isSecureConnection response status=200 data={"result":{"data":{"code":-40401,"time":9,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBANfyaCxWxMa52IdRMGjaeHLX25OYmTsnAjA4VTT/yOY4svxCh1Xgz2EYJkXPkxKMwt1+AS2MfWQ0ewXZqTCOJz0CAwEAAQ==","nonce":"AFDA7AAB11ACDD83","device_confirm":"D577C479BE60ADA7B009B45C0DDDC4006A5D61482BB6AB0F4C3460F2489D0FCBAFDA7AAB11ACDD8371CB15174D95F8E5"}},"error_code":-40413}
          2026-08-10 19:47:52.194 - debug: tapo.0 (1411942) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
          2026-08-10 19:47:52.194 - debug: tapo.0 (1411942) refreshStok: Refreshing stok...
          2026-08-10 19:47:52.195 - debug: tapo.0 (1411942) refreshStok: isSecureConnection=true username=admin cnonce=4AB72712C7FF1F63
          2026-08-10 19:47:52.325 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:52.325 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:47:52.325 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:52.394 - debug: tapo.0 (1411942) refreshStok: Login response status=200 data={"result":{"data":{"code":-40401,"time":8,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBANfyaCxWxMa52IdRMGjaeHLX25OYmTsnAjA4VTT/yOY4svxCh1Xgz2EYJkXPkxKMwt1+AS2MfWQ0ewXZqTCOJz0CAwEAAQ==","nonce":"778EF9FCB3D1AE5C","device_confirm":"22DC165FE8E4CFF68C80AF690F27D6E4751C83DA150803BDFFCB054261CFFD36778EF9FCB3D1AE5C4AB72712C7FF1F63"}},"error_code":-40413}
          2026-08-10 19:47:52.394 - debug: tapo.0 (1411942) refreshStok: nonce=778EF9FCB3D1AE5C... deviceConfirm=22DC165FE8E4CFF6...
          2026-08-10 19:47:52.395 - debug: tapo.0 (1411942) refreshStok: deviceConfirm validated, encryptionMethod=sha256
          2026-08-10 19:47:52.395 - debug: tapo.0 (1411942) refreshStok: sending start_seq request
          2026-08-10 19:47:52.646 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:52.647 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:47:52.650 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:52.721 - debug: tapo.0 (1411942) refreshStok: start_seq response
          2026-08-10 19:47:52.721 - debug: tapo.0 (1411942) refreshStok: start_seq=722 user_group=root stok=present
          2026-08-10 19:47:52.722 - debug: tapo.0 (1411942) refreshStok: Success in obtaining STOK
          2026-08-10 19:47:52.947 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:52.947 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:47:52.967 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:53.011 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:53.011 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:47:53.011 - info: tapo.0 (1411942) Reconnected to undefined
          2026-08-10 19:47:53.011 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:53.227 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:53.251 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:53.251 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:47:53.324 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:47:53.324 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:53.374 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:53.634 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:53.634 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:47:53.803 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:53.803 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
          2026-08-10 19:47:53.803 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:54.176 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:54.191 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:54.191 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:47:54.237 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:54.437 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:54.474 - debug: tapo.0 (1411942) Update done
          2026-08-10 19:47:54.648 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:54.648 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:47:54.677 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:55.091 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:55.103 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:47:55.103 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:55.517 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:55.518 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:47:55.518 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:55.850 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:55.850 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:47:55.854 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:56.142 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:56.142 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:47:56.187 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:56.527 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:56.536 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:47:56.536 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:56.836 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:56.836 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:47:56.837 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:57.120 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:57.120 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:47:57.123 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:57.395 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:57.396 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:47:57.418 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:47:57.625 - debug: tapo.0 (1411942) API response
          2026-08-10 19:47:57.635 - debug: tapo.0 (1411942) Update done
          2026-08-10 19:48:00.938 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:00.939 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:01.204 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:01.204 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
          2026-08-10 19:48:01.204 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:01.476 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:01.476 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:01.480 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:01.699 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:01.699 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:01.718 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:01.977 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:01.997 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:01.997 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:02.322 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:02.322 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:02.322 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:02.605 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:02.606 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:02.609 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:02.993 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:02.993 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:03.012 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:03.408 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:03.420 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:03.421 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:03.887 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:03.887 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
          2026-08-10 19:48:03.887 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:04.278 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:04.278 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:04.282 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:04.688 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:04.688 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:04.706 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:05.124 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:05.133 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:05.133 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:05.546 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:05.546 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:05.546 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:05.862 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:05.862 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:05.866 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:06.201 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:06.201 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:06.220 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:06.500 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:06.508 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:06.508 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:06.876 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:06.876 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:06.876 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:07.155 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:07.156 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:07.159 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:07.430 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:07.431 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:07.451 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:07.711 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:07.721 - debug: tapo.0 (1411942) Update done
          2026-08-10 19:48:10.939 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:10.939 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:11.386 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:11.386 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
          2026-08-10 19:48:11.386 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:11.643 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:11.643 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:11.733 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:11.976 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:11.976 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:11.993 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:12.272 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:12.287 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:12.288 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:12.585 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:12.585 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:12.586 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:12.803 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:12.804 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:12.849 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:13.030 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:13.030 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:13.047 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:13.358 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:13.367 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:13.367 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:13.881 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:13.881 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
          2026-08-10 19:48:13.881 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:13.912 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:14.150 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:14.150 - info: tapo.0 (1411942) moveToPreset was set to : Garage for device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 was successful: false
          2026-08-10 19:48:14.357 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:14.358 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:14.361 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:14.768 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:14.768 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:14.785 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:15.345 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:15.353 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:15.353 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:15.847 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:15.847 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:15.847 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:16.147 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:16.147 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:16.150 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:16.152 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:16.152 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:16.415 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:16.415 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
          2026-08-10 19:48:16.415 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:16.457 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:16.457 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:16.658 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:16.658 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:16.668 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:16.727 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:16.931 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:16.932 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:16.973 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:17.121 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:17.130 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:17.130 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:17.210 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:17.218 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:17.219 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:17.421 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:17.421 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:17.422 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:17.560 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:17.560 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:17.560 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:17.671 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:17.671 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:17.720 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:17.874 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:17.875 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:17.880 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:17.992 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:17.993 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:18.010 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:18.170 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:18.170 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:18.189 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:18.279 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:18.291 - debug: tapo.0 (1411942) Update done
          2026-08-10 19:48:18.443 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:18.451 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:18.452 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:18.916 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:18.916 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
          2026-08-10 19:48:18.916 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:19.323 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:19.324 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:19.327 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:19.810 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:19.810 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:19.844 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:20.266 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:20.273 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:20.273 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:20.939 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:20.940 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:21.073 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:21.073 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:21.073 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:21.419 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:21.419 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
          2026-08-10 19:48:21.419 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:21.552 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:21.552 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:21.598 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:21.649 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:21.649 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:21.652 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:21.883 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:21.883 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:21.930 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:22.017 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:22.017 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:22.040 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:22.187 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:22.195 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:22.195 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:22.453 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:22.453 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:22.453 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:22.565 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:22.573 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:22.573 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:22.693 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:22.693 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:22.699 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:22.843 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:22.843 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:22.843 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:22.961 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:22.961 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:23.019 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:23.082 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:23.082 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:23.085 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:23.309 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:23.330 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:23.330 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:23.371 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:23.371 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:23.444 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:23.664 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:23.675 - debug: tapo.0 (1411942) Update done
          2026-08-10 19:48:23.837 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:23.838 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
          2026-08-10 19:48:23.838 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:24.237 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:24.237 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:24.240 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:24.668 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:24.669 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:24.687 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:25.112 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:25.119 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:25.119 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:25.543 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:25.543 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:25.543 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:25.916 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:25.916 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:25.920 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:26.339 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:26.339 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:26.409 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:27.012 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:27.020 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:27.020 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:27.732 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:27.732 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:27.732 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:28.468 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:28.468 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:28.487 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:29.391 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:29.392 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:29.416 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:29.925 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:29.936 - debug: tapo.0 (1411942) Update done
          2026-08-10 19:48:30.939 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:30.940 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:31.144 - info: sonoff.0 (1140) Client [Plug03-KEL-IT-152] connection closed: Error: read ECONNRESET
          2026-08-10 19:48:31.404 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:31.404 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
          2026-08-10 19:48:31.404 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:31.633 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:31.633 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:31.637 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:31.864 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:31.864 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:31.884 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:32.147 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:32.158 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:32.158 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:32.454 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:32.455 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:32.455 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:32.762 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:32.762 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:32.765 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:33.038 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:33.038 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:33.060 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:33.367 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:33.386 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:33.386 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:33.906 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:33.906 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
          2026-08-10 19:48:33.906 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:34.303 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:34.304 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:34.308 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:34.715 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:34.715 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:34.738 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:35.162 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:35.171 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:35.171 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:35.580 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:35.580 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:35.580 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:35.921 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:35.921 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:35.925 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:36.763 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:36.763 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:36.780 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:37.265 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:37.275 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:37.275 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:37.528 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:37.528 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:37.528 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:37.765 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:37.765 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:37.770 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:38.038 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:38.038 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:38.056 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:38.356 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:38.373 - debug: tapo.0 (1411942) Update done
          2026-08-10 19:48:40.940 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:40.940 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:41.211 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:41.212 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
          2026-08-10 19:48:41.212 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:41.338 - info: sonoff.0 (1140) Client [Plug03-KEL-IT-152] connected with secret 1786384121336_904
          2026-08-10 19:48:41.467 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:41.467 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:41.525 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:41.776 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:41.776 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:41.801 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:42.048 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:42.058 - debug: tapo.0 (1411942) Receive camera status
          2026-08-10 19:48:42.059 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:42.368 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:42.368 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
          2026-08-10 19:48:42.368 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:42.531 - info: host.iOProduktiv "system.adapter.tapo.0" disabled
          2026-08-10 19:48:42.531 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 (force=false, process=true)
          2026-08-10 19:48:42.533 - info: tapo.0 (1411942) Got terminate signal TERMINATE_YOURSELF
          2026-08-10 19:48:42.533 - info: tapo.0 (1411942) terminating
          2026-08-10 19:48:42.534 - info: tapo.0 (1411942) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2026-08-10 19:48:42.640 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 send kill signal
          2026-08-10 19:48:42.685 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:42.685 - debug: tapo.0 (1411942) searchDetectionList raw: {}
          2026-08-10 19:48:42.763 - debug: tapo.0 (1411942) New API request
          2026-08-10 19:48:42.986 - debug: tapo.0 (1411942) API response
          2026-08-10 19:48:42.986 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
          2026-08-10 19:48:43.034 - info: tapo.0 (1411942) terminating
          2026-08-10 19:48:43.038 - debug: tapo.0 (1411942) redis get tapo.0.80219D887A52D32D03212C4C2DE37E4D21EC8028.alarmInfo.alarm_mode.light, error - Connection is closed.
          2026-08-10 19:48:43.038 - error: tapo.0 (1411942) Error extract keys: 80219D887A52D32D03212C4C2DE37E4D21EC8028.alarmInfo.alarm_mode.light "light"
          2026-08-10 19:48:43.039 - error: tapo.0 (1411942) Error: DB closed
          2026-08-10 19:48:43.382 - info: host.iOProduktiv instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          Was kann ich zur Fehlerbehebung beitragen?
          LG
          • metaxaM metaxa
            Servus @tombox
            Ich hatte schon vor ca. 1 Jahr einen Versuch unternommen meine Tapo Cams über deinen Adapter einzubinden.
            1x C520WS, 1x C200, 1x C530WS (2x C310)
            Alle Cams wurden sofort vom Adapter gefunden, sehr viele DP angelegt und diese tun was sie sollen. Fast.
            Leider funktionieren bei allen PTZ Cams die DP "MoveToPreset" nicht.
            Log im Debug Modus
            2026-08-10 19:47:22.472 - info: host.iOProduktiv "system.adapter.tapo.0" enabled
            2026-08-10 19:47:24.522 - info: host.iOProduktiv instance system.adapter.tapo.0 in version "0.5.5" (non-npm: TA2k/ioBroker.tapo) started with pid 1411942
            2026-08-10 19:47:25.656 - debug: tapo.0 (1411942) Redis Objects: Use Redis connection: 0.0.0.0:9001
            2026-08-10 19:47:25.713 - debug: tapo.0 (1411942) Objects client ready ... initialize now
            2026-08-10 19:47:25.759 - debug: tapo.0 (1411942) Objects create System PubSub Client
            2026-08-10 19:47:25.760 - debug: tapo.0 (1411942) Objects create User PubSub Client
            2026-08-10 19:47:25.877 - debug: tapo.0 (1411942) Objects client initialize lua scripts
            2026-08-10 19:47:25.880 - debug: tapo.0 (1411942) Objects connected to redis: 0.0.0.0:9001
            2026-08-10 19:47:25.950 - debug: tapo.0 (1411942) Redis States: Use Redis connection: 0.0.0.0:9000
            2026-08-10 19:47:26.004 - debug: tapo.0 (1411942) States create System PubSub Client
            2026-08-10 19:47:26.005 - debug: tapo.0 (1411942) States create User PubSub Client
            2026-08-10 19:47:26.157 - debug: tapo.0 (1411942) States connected to redis: 0.0.0.0:9000
            2026-08-10 19:47:26.333 - info: tapo.0 (1411942) starting. Version 0.5.5 (non-npm: TA2k/ioBroker.tapo) in /opt/iobroker/node_modules/iobroker.tapo, node: v22.23.0, js-controller: 7.2.2
            2026-08-10 19:47:26.392 - info: tapo.0 (1411942) Login tp TAPO App
            2026-08-10 19:47:26.395 - debug: tapo.0 (1411942) xaYE4SMWpkdB/E8dxzgSWA==
            2026-08-10 19:47:26.688 - debug: tapo.0 (1411942) {"error_code":0,"result":{"accountApiUrl":"https://euw1-account-api.i.tplinkcloud.com","lockedMinutes":0,"appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"38ee8e2b-BTKHJrLsh89rCNWrqHQI6DZ","accountId":"37806770","regionCode":"AT","regTime":"2021-06-23 14:33:54","nickname":"mxa","email":"mxa@gmx.at","appServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com","refreshToken":"38ee8e2b-BTQsPoCVASGPAYEwdb5gnGd"}}
            2026-08-10 19:47:26.689 - info: tapo.0 (1411942) Login succesfull
            2026-08-10 19:47:26.689 - debug: tapo.0 (1411942) yfoQzXVQIYQWjRDZuXyppQ==
            2026-08-10 19:47:26.924 - debug: tapo.0 (1411942) {"error_code":0,"result":{"totalNum":5,"deviceList":[{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0","deviceName":"C310 2.0","lastBindTime":1784968460000,"deviceHwVer":"2.0","alias":"Postkasten","deviceMac":"005F67798FDD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.4 Build 250811 Rel.34127n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80219D887A52D32D03212C4C2DE37E4D21EC8028","deviceName":"C520WS 1.0","lastBindTime":1705169151000,"deviceHwVer":"1.0","alias":"Terrasse","deviceMac":"F0A731D87F97","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","deviceModel":"C520WS","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.4.4 Build 260527 Rel.28339n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802114698B0C4DB803277811859F5C6723111712","deviceName":"C200 5.0","lastBindTime":1785313977000,"deviceHwVer":"5.0","alias":"Beet","deviceMac":"B019213463BA","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","deviceModel":"C200","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021314EFB57E17626EC16DBDB2A31A51E64292E","deviceName":"C310 2.0","lastBindTime":1632395306000,"deviceHwVer":"2.0","alias":"Haus Eingang vorne","deviceMac":"005F67798FBD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.5 Build 260323 Rel.35521n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802173FB22D1FB8B96E616F599FE462C24EBEDA7","deviceName":"C530WS 2.0","lastBindTime":1782991868000,"deviceHwVer":"2.0","alias":"Einfahrt","deviceMac":"6C4CBC025F2C","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","deviceModel":"C530WS","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0}],"currentIndex":4}}
            2026-08-10 19:47:26.925 - info: tapo.0 (1411942) Found 5 devices
            2026-08-10 19:47:26.925 - debug: tapo.0 (1411942) Found device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Postkasten
            2026-08-10 19:47:27.430 - debug: tapo.0 (1411942) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"","mac":"005F67798FDD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.110","onboardingTime":1784968460,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
            2026-08-10 19:47:27.431 - info: tapo.0 (1411942) Init device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 type C310 2.0 with ip 192.168.0.110
            2026-08-10 19:47:27.432 - debug: tapo.0 (1411942) UDP discovery for 192.168.0.110 on port 20002
            2026-08-10 19:47:27.546 - info: tapo.0 (1411942) UDP discovery for 192.168.0.110: port=80 https=true encrypt=undefined lv=undefined mac=00-5F-67-79-8F-DD
            2026-08-10 19:47:27.629 - info: tapo.0 (1411942) 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2}
            2026-08-10 19:47:27.629 - debug: tapo.0 (1411942) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2}
            2026-08-10 19:47:27.629 - debug: tapo.0 (1411942) Init event emitter for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0
            2026-08-10 19:47:27.633 - debug: tapo.0 (1411942) Init event listener for "motion"
            2026-08-10 19:47:27.633 - info: tapo.0 (1411942) Initialized 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0
            2026-08-10 19:47:27.633 - debug: tapo.0 (1411942) initResult camera 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 undefined
            2026-08-10 19:47:27.633 - debug: tapo.0 (1411942) Found device 80219D887A52D32D03212C4C2DE37E4D21EC8028 M��j�
            2026-08-10 19:47:27.912 - debug: tapo.0 (1411942) {"hwVer":"1.0","category":"camera","model":"C520WS 1.0","ssid":"","mac":"F0A731D87F97","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","fwVer":"1.3.4 Build 250811 Rel.34127n","ip":"192.168.0.112","onboardingTime":1705169153,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
            2026-08-10 19:47:27.912 - info: tapo.0 (1411942) Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.112
            2026-08-10 19:47:27.912 - debug: tapo.0 (1411942) UDP discovery for 192.168.0.112 on port 20002
            2026-08-10 19:47:27.990 - info: tapo.0 (1411942) UDP discovery for 192.168.0.112: port=80 https=true encrypt=undefined lv=undefined mac=F0-A7-31-D8-7F-97
            2026-08-10 19:47:28.518 - info: tapo.0 (1411942) 80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1}
            2026-08-10 19:47:28.518 - debug: tapo.0 (1411942) {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1}
            2026-08-10 19:47:28.518 - debug: tapo.0 (1411942) Init event emitter for 80219D887A52D32D03212C4C2DE37E4D21EC8028
            2026-08-10 19:47:28.546 - debug: tapo.0 (1411942) Init event listener for "motion"
            2026-08-10 19:47:28.546 - info: tapo.0 (1411942) Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
            2026-08-10 19:47:28.546 - debug: tapo.0 (1411942) initResult camera 80219D887A52D32D03212C4C2DE37E4D21EC8028 undefined
            2026-08-10 19:47:28.547 - debug: tapo.0 (1411942) Found device 802114698B0C4DB803277811859F5C6723111712 �
            2026-08-10 19:47:28.857 - debug: tapo.0 (1411942) {"hwVer":"5.0","category":"camera","model":"C200 5.0","ssid":"videosun","mac":"B019213463BA","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","fwVer":"1.4.4 Build 260527 Rel.28339n","ip":"192.168.0.114","onboardingTime":1785313979,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
            2026-08-10 19:47:28.857 - info: tapo.0 (1411942) Init device 802114698B0C4DB803277811859F5C6723111712 type C200 5.0 with ip 192.168.0.114
            2026-08-10 19:47:28.857 - debug: tapo.0 (1411942) UDP discovery for 192.168.0.114 on port 20002
            2026-08-10 19:47:28.965 - info: tapo.0 (1411942) UDP discovery for 192.168.0.114: port=80 https=true encrypt=undefined lv=undefined mac=B0-19-21-34-63-BA
            2026-08-10 19:47:29.251 - info: tapo.0 (1411942) 802114698B0C4DB803277811859F5C6723111712 Received device info {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5}
            2026-08-10 19:47:29.251 - debug: tapo.0 (1411942) {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5}
            2026-08-10 19:47:29.252 - debug: tapo.0 (1411942) Init event emitter for 802114698B0C4DB803277811859F5C6723111712
            2026-08-10 19:47:29.254 - debug: tapo.0 (1411942) Init event listener for "motion"
            2026-08-10 19:47:29.254 - info: tapo.0 (1411942) Initialized 802114698B0C4DB803277811859F5C6723111712
            2026-08-10 19:47:29.254 - debug: tapo.0 (1411942) initResult camera 802114698B0C4DB803277811859F5C6723111712 undefined
            2026-08-10 19:47:29.254 - debug: tapo.0 (1411942) Found device 8021314EFB57E17626EC16DBDB2A31A51E64292E Haus Eingang vorne
            2026-08-10 19:47:29.581 - debug: tapo.0 (1411942) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"Sun 2.4","mac":"005F67798FBD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.113","onboardingTime":0,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
            2026-08-10 19:47:29.582 - info: tapo.0 (1411942) Init device 8021314EFB57E17626EC16DBDB2A31A51E64292E type C310 2.0 with ip 192.168.0.113
            2026-08-10 19:47:29.582 - debug: tapo.0 (1411942) UDP discovery for 192.168.0.113 on port 20002
            2026-08-10 19:47:29.639 - info: tapo.0 (1411942) UDP discovery for 192.168.0.113: port=80 https=true encrypt=undefined lv=undefined mac=00-5F-67-79-8F-BD
            2026-08-10 19:47:30.011 - info: tapo.0 (1411942) 8021314EFB57E17626EC16DBDB2A31A51E64292E Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2}
            2026-08-10 19:47:30.011 - debug: tapo.0 (1411942) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2}
            2026-08-10 19:47:30.011 - debug: tapo.0 (1411942) Init event emitter for 8021314EFB57E17626EC16DBDB2A31A51E64292E
            2026-08-10 19:47:30.013 - debug: tapo.0 (1411942) Init event listener for "motion"
            2026-08-10 19:47:30.014 - info: tapo.0 (1411942) Initialized 8021314EFB57E17626EC16DBDB2A31A51E64292E
            2026-08-10 19:47:30.014 - debug: tapo.0 (1411942) initResult camera 8021314EFB57E17626EC16DBDB2A31A51E64292E undefined
            2026-08-10 19:47:30.014 - debug: tapo.0 (1411942) Found device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 )�j�
            2026-08-10 19:47:30.326 - debug: tapo.0 (1411942) {"hwVer":"2.0","category":"camera","model":"C530WS 2.0","ssid":"","mac":"6C4CBC025F2C","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","fwVer":"1.3.5 Build 260323 Rel.35521n","ip":"192.168.0.115","onboardingTime":1782991869,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
            2026-08-10 19:47:30.327 - info: tapo.0 (1411942) Init device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 type C530WS 2.0 with ip 192.168.0.115
            2026-08-10 19:47:30.327 - debug: tapo.0 (1411942) UDP discovery for 192.168.0.115 on port 20002
            2026-08-10 19:47:30.393 - info: tapo.0 (1411942) UDP discovery for 192.168.0.115: port=80 https=true encrypt=undefined lv=undefined mac=6C-4C-BC-02-5F-2C
            2026-08-10 19:47:30.865 - info: tapo.0 (1411942) 802173FB22D1FB8B96E616F599FE462C24EBEDA7 Received device info {"manufacturer":"tp-link","model":"Tapo C530WS","firmwareVersion":"1.3.5 Build 260323 Rel.35521n","serialNumber":"74615f2c","hardwareId":2}
            2026-08-10 19:47:30.865 - debug: tapo.0 (1411942) {"manufacturer":"tp-link","model":"Tapo C530WS","firmwareVersion":"1.3.5 Build 260323 Rel.35521n","serialNumber":"74615f2c","hardwareId":2}
            2026-08-10 19:47:30.865 - debug: tapo.0 (1411942) Init event emitter for 802173FB22D1FB8B96E616F599FE462C24EBEDA7
            2026-08-10 19:47:30.870 - debug: tapo.0 (1411942) Init event listener for "motion"
            2026-08-10 19:47:30.870 - info: tapo.0 (1411942) Initialized 802173FB22D1FB8B96E616F599FE462C24EBEDA7
            2026-08-10 19:47:30.870 - debug: tapo.0 (1411942) initResult camera 802173FB22D1FB8B96E616F599FE462C24EBEDA7 undefined
            2026-08-10 19:47:30.931 - info: tapo.0 (1411942) Wait for connections for non camera devices
            2026-08-10 19:47:40.932 - info: tapo.0 (1411942) Start first Update
            2026-08-10 19:47:40.933 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:47:40.933 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:40.933 - debug: tapo.0 (1411942) isSecureConnection: Checking secure connection...
            2026-08-10 19:47:41.198 - debug: tapo.0 (1411942) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"B648B02C8FBAA0AD","device_confirm":"6DDE6DCF0ED10AE0846114E4AE9011E816401ED27E6A56E29469B2AF728D8232B648B02C8FBAA0AD4A23C8D6F4ECD67E"}}}
            2026-08-10 19:47:41.198 - debug: tapo.0 (1411942) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
            2026-08-10 19:47:41.198 - debug: tapo.0 (1411942) refreshStok: Refreshing stok...
            2026-08-10 19:47:41.199 - debug: tapo.0 (1411942) refreshStok: isSecureConnection=true username=admin cnonce=B2407FF12CC681EC
            2026-08-10 19:47:41.473 - debug: tapo.0 (1411942) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"9635A1EF7E960BE1","device_confirm":"AAE738A78D110D9CD0D04B04EF48D6B6EBF5F627B1426478DA4D011860CC3F4B9635A1EF7E960BE1B2407FF12CC681EC"}}}
            2026-08-10 19:47:41.473 - debug: tapo.0 (1411942) refreshStok: nonce=9635A1EF7E960BE1... deviceConfirm=AAE738A78D110D9C...
            2026-08-10 19:47:41.473 - debug: tapo.0 (1411942) refreshStok: deviceConfirm validated, encryptionMethod=sha256
            2026-08-10 19:47:41.474 - debug: tapo.0 (1411942) refreshStok: sending start_seq request
            2026-08-10 19:47:41.710 - debug: tapo.0 (1411942) refreshStok: start_seq response
            2026-08-10 19:47:41.710 - debug: tapo.0 (1411942) refreshStok: start_seq=6541043 user_group=root stok=present
            2026-08-10 19:47:41.710 - debug: tapo.0 (1411942) refreshStok: Success in obtaining STOK
            2026-08-10 19:47:41.953 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:41.954 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
            2026-08-10 19:47:41.954 - info: tapo.0 (1411942) Reconnected to undefined
            2026-08-10 19:47:41.954 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:42.243 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:42.244 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:47:42.363 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:42.577 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:42.579 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:47:42.877 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:43.100 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:43.126 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:47:43.126 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:43.126 - debug: tapo.0 (1411942) isSecureConnection: Checking secure connection...
            2026-08-10 19:47:43.374 - debug: tapo.0 (1411942) isSecureConnection response status=200 data={"result":{"data":{"code":-40401,"time":9,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"EF4AAE02BF4F4C05","device_confirm":"0748416CA64187108C6091E6FAA18B81F07A43D5510B8567CA60A8D2CC1323EBEF4AAE02BF4F4C0594DCAC7B43399A3C"}},"error_code":-40413}
            2026-08-10 19:47:43.374 - debug: tapo.0 (1411942) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
            2026-08-10 19:47:43.374 - debug: tapo.0 (1411942) refreshStok: Refreshing stok...
            2026-08-10 19:47:43.374 - debug: tapo.0 (1411942) refreshStok: isSecureConnection=true username=admin cnonce=A9B3FCA390357FFF
            2026-08-10 19:47:43.593 - debug: tapo.0 (1411942) refreshStok: Login response status=200 data={"result":{"data":{"code":-40401,"time":8,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"EBAEEBF7DBBB2AB9","device_confirm":"0A529C52702829F7D443F999F2025B9234C59E0FE93B9E425C0A414FA77D1E8CEBAEEBF7DBBB2AB9A9B3FCA390357FFF"}},"error_code":-40413}
            2026-08-10 19:47:43.593 - debug: tapo.0 (1411942) refreshStok: nonce=EBAEEBF7DBBB2AB9... deviceConfirm=0A529C52702829F7...
            2026-08-10 19:47:43.594 - debug: tapo.0 (1411942) refreshStok: deviceConfirm validated, encryptionMethod=sha256
            2026-08-10 19:47:43.594 - debug: tapo.0 (1411942) refreshStok: sending start_seq request
            2026-08-10 19:47:43.887 - debug: tapo.0 (1411942) refreshStok: start_seq response
            2026-08-10 19:47:43.888 - debug: tapo.0 (1411942) refreshStok: start_seq=372 user_group=root stok=present
            2026-08-10 19:47:43.888 - debug: tapo.0 (1411942) refreshStok: Success in obtaining STOK
            2026-08-10 19:47:44.199 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:44.199 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:47:44.199 - info: tapo.0 (1411942) Reconnected to undefined
            2026-08-10 19:47:44.199 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:44.487 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:44.487 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:47:44.628 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:44.937 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:44.937 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:47:45.113 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:45.427 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:45.445 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:47:45.445 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:45.445 - debug: tapo.0 (1411942) isSecureConnection: Checking secure connection...
            2026-08-10 19:47:45.911 - debug: tapo.0 (1411942) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"2FAFBFED5C8B54B6","device_confirm":"D49509BB99A9C40AD01163425D0FB69E6CD63D14071F31F5D41D6F154DDBD7F82FAFBFED5C8B54B6F8D240D788AB5F5E"}}}
            2026-08-10 19:47:45.912 - debug: tapo.0 (1411942) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
            2026-08-10 19:47:45.912 - debug: tapo.0 (1411942) refreshStok: Refreshing stok...
            2026-08-10 19:47:45.912 - debug: tapo.0 (1411942) refreshStok: isSecureConnection=true username=admin cnonce=D3FF93A23A11C8C1
            2026-08-10 19:47:46.283 - debug: tapo.0 (1411942) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"A284ADE22178AD11","device_confirm":"91F6164C299654DB917FE4D7D29135347F7A9B8D4BBF74C2C65F74AE8673E596A284ADE22178AD11D3FF93A23A11C8C1"}}}
            2026-08-10 19:47:46.283 - debug: tapo.0 (1411942) refreshStok: nonce=A284ADE22178AD11... deviceConfirm=91F6164C299654DB...
            2026-08-10 19:47:46.283 - debug: tapo.0 (1411942) refreshStok: deviceConfirm validated, encryptionMethod=sha256
            2026-08-10 19:47:46.283 - debug: tapo.0 (1411942) refreshStok: sending start_seq request
            2026-08-10 19:47:46.758 - debug: tapo.0 (1411942) refreshStok: start_seq response
            2026-08-10 19:47:46.759 - debug: tapo.0 (1411942) refreshStok: start_seq=3528198 user_group=root stok=present
            2026-08-10 19:47:46.759 - debug: tapo.0 (1411942) refreshStok: Success in obtaining STOK
            2026-08-10 19:47:47.303 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:47.303 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
            2026-08-10 19:47:47.303 - info: tapo.0 (1411942) Reconnected to undefined
            2026-08-10 19:47:47.303 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:47.755 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:47.756 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:47:47.813 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:48.312 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:48.312 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:47:48.355 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:48.755 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:48.771 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:47:48.772 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:48.772 - debug: tapo.0 (1411942) isSecureConnection: Checking secure connection...
            2026-08-10 19:47:49.249 - debug: tapo.0 (1411942) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"7DAAD745586EBA88","device_confirm":"AE6040A242FE265FF01C477DDF82D7B359C73C9144CB6189DE04687A260373FE7DAAD745586EBA885053599C34D4778E"}}}
            2026-08-10 19:47:49.249 - debug: tapo.0 (1411942) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
            2026-08-10 19:47:49.249 - debug: tapo.0 (1411942) refreshStok: Refreshing stok...
            2026-08-10 19:47:49.249 - debug: tapo.0 (1411942) refreshStok: isSecureConnection=true username=admin cnonce=146B98D33B5EB882
            2026-08-10 19:47:49.569 - debug: tapo.0 (1411942) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"A99ECDBE04E20F94","device_confirm":"DA041A367DE263CB6E654CA9B5862271E223BCADFB839D9A1241B3979219DE55A99ECDBE04E20F94146B98D33B5EB882"}}}
            2026-08-10 19:47:49.569 - debug: tapo.0 (1411942) refreshStok: nonce=A99ECDBE04E20F94... deviceConfirm=DA041A367DE263CB...
            2026-08-10 19:47:49.569 - debug: tapo.0 (1411942) refreshStok: deviceConfirm validated, encryptionMethod=sha256
            2026-08-10 19:47:49.569 - debug: tapo.0 (1411942) refreshStok: sending start_seq request
            2026-08-10 19:47:49.978 - debug: tapo.0 (1411942) refreshStok: start_seq response
            2026-08-10 19:47:49.978 - debug: tapo.0 (1411942) refreshStok: start_seq=47061845 user_group=root stok=present
            2026-08-10 19:47:49.978 - debug: tapo.0 (1411942) refreshStok: Success in obtaining STOK
            2026-08-10 19:47:50.334 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:50.334 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:47:50.334 - info: tapo.0 (1411942) Reconnected to undefined
            2026-08-10 19:47:50.334 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:50.706 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:50.706 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:47:50.816 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:50.938 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:47:50.939 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:51.180 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:51.180 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:47:51.211 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:51.211 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
            2026-08-10 19:47:51.211 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:51.469 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:51.469 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:47:51.526 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:51.584 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:51.762 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:51.763 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:47:51.794 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:51.920 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:51.948 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:47:51.948 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:51.948 - debug: tapo.0 (1411942) isSecureConnection: Checking secure connection...
            2026-08-10 19:47:52.039 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:52.053 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:47:52.053 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:52.194 - debug: tapo.0 (1411942) isSecureConnection response status=200 data={"result":{"data":{"code":-40401,"time":9,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBANfyaCxWxMa52IdRMGjaeHLX25OYmTsnAjA4VTT/yOY4svxCh1Xgz2EYJkXPkxKMwt1+AS2MfWQ0ewXZqTCOJz0CAwEAAQ==","nonce":"AFDA7AAB11ACDD83","device_confirm":"D577C479BE60ADA7B009B45C0DDDC4006A5D61482BB6AB0F4C3460F2489D0FCBAFDA7AAB11ACDD8371CB15174D95F8E5"}},"error_code":-40413}
            2026-08-10 19:47:52.194 - debug: tapo.0 (1411942) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
            2026-08-10 19:47:52.194 - debug: tapo.0 (1411942) refreshStok: Refreshing stok...
            2026-08-10 19:47:52.195 - debug: tapo.0 (1411942) refreshStok: isSecureConnection=true username=admin cnonce=4AB72712C7FF1F63
            2026-08-10 19:47:52.325 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:52.325 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:47:52.325 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:52.394 - debug: tapo.0 (1411942) refreshStok: Login response status=200 data={"result":{"data":{"code":-40401,"time":8,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBANfyaCxWxMa52IdRMGjaeHLX25OYmTsnAjA4VTT/yOY4svxCh1Xgz2EYJkXPkxKMwt1+AS2MfWQ0ewXZqTCOJz0CAwEAAQ==","nonce":"778EF9FCB3D1AE5C","device_confirm":"22DC165FE8E4CFF68C80AF690F27D6E4751C83DA150803BDFFCB054261CFFD36778EF9FCB3D1AE5C4AB72712C7FF1F63"}},"error_code":-40413}
            2026-08-10 19:47:52.394 - debug: tapo.0 (1411942) refreshStok: nonce=778EF9FCB3D1AE5C... deviceConfirm=22DC165FE8E4CFF6...
            2026-08-10 19:47:52.395 - debug: tapo.0 (1411942) refreshStok: deviceConfirm validated, encryptionMethod=sha256
            2026-08-10 19:47:52.395 - debug: tapo.0 (1411942) refreshStok: sending start_seq request
            2026-08-10 19:47:52.646 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:52.647 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:47:52.650 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:52.721 - debug: tapo.0 (1411942) refreshStok: start_seq response
            2026-08-10 19:47:52.721 - debug: tapo.0 (1411942) refreshStok: start_seq=722 user_group=root stok=present
            2026-08-10 19:47:52.722 - debug: tapo.0 (1411942) refreshStok: Success in obtaining STOK
            2026-08-10 19:47:52.947 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:52.947 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:47:52.967 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:53.011 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:53.011 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:47:53.011 - info: tapo.0 (1411942) Reconnected to undefined
            2026-08-10 19:47:53.011 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:53.227 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:53.251 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:53.251 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:47:53.324 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:47:53.324 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:53.374 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:53.634 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:53.634 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:47:53.803 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:53.803 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
            2026-08-10 19:47:53.803 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:54.176 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:54.191 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:54.191 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:47:54.237 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:54.437 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:54.474 - debug: tapo.0 (1411942) Update done
            2026-08-10 19:47:54.648 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:54.648 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:47:54.677 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:55.091 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:55.103 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:47:55.103 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:55.517 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:55.518 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:47:55.518 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:55.850 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:55.850 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:47:55.854 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:56.142 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:56.142 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:47:56.187 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:56.527 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:56.536 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:47:56.536 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:56.836 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:56.836 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:47:56.837 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:57.120 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:57.120 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:47:57.123 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:57.395 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:57.396 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:47:57.418 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:47:57.625 - debug: tapo.0 (1411942) API response
            2026-08-10 19:47:57.635 - debug: tapo.0 (1411942) Update done
            2026-08-10 19:48:00.938 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:00.939 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:01.204 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:01.204 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
            2026-08-10 19:48:01.204 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:01.476 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:01.476 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:01.480 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:01.699 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:01.699 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:01.718 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:01.977 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:01.997 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:01.997 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:02.322 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:02.322 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:02.322 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:02.605 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:02.606 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:02.609 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:02.993 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:02.993 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:03.012 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:03.408 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:03.420 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:03.421 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:03.887 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:03.887 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
            2026-08-10 19:48:03.887 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:04.278 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:04.278 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:04.282 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:04.688 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:04.688 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:04.706 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:05.124 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:05.133 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:05.133 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:05.546 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:05.546 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:05.546 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:05.862 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:05.862 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:05.866 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:06.201 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:06.201 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:06.220 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:06.500 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:06.508 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:06.508 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:06.876 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:06.876 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:06.876 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:07.155 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:07.156 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:07.159 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:07.430 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:07.431 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:07.451 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:07.711 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:07.721 - debug: tapo.0 (1411942) Update done
            2026-08-10 19:48:10.939 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:10.939 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:11.386 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:11.386 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
            2026-08-10 19:48:11.386 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:11.643 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:11.643 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:11.733 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:11.976 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:11.976 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:11.993 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:12.272 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:12.287 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:12.288 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:12.585 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:12.585 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:12.586 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:12.803 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:12.804 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:12.849 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:13.030 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:13.030 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:13.047 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:13.358 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:13.367 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:13.367 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:13.881 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:13.881 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
            2026-08-10 19:48:13.881 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:13.912 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:14.150 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:14.150 - info: tapo.0 (1411942) moveToPreset was set to : Garage for device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 was successful: false
            2026-08-10 19:48:14.357 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:14.358 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:14.361 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:14.768 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:14.768 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:14.785 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:15.345 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:15.353 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:15.353 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:15.847 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:15.847 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:15.847 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:16.147 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:16.147 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:16.150 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:16.152 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:16.152 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:16.415 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:16.415 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
            2026-08-10 19:48:16.415 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:16.457 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:16.457 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:16.658 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:16.658 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:16.668 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:16.727 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:16.931 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:16.932 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:16.973 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:17.121 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:17.130 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:17.130 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:17.210 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:17.218 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:17.219 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:17.421 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:17.421 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:17.422 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:17.560 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:17.560 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:17.560 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:17.671 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:17.671 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:17.720 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:17.874 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:17.875 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:17.880 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:17.992 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:17.993 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:18.010 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:18.170 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:18.170 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:18.189 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:18.279 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:18.291 - debug: tapo.0 (1411942) Update done
            2026-08-10 19:48:18.443 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:18.451 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:18.452 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:18.916 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:18.916 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
            2026-08-10 19:48:18.916 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:19.323 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:19.324 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:19.327 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:19.810 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:19.810 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:19.844 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:20.266 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:20.273 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:20.273 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:20.939 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:20.940 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:21.073 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:21.073 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:21.073 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:21.419 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:21.419 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
            2026-08-10 19:48:21.419 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:21.552 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:21.552 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:21.598 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:21.649 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:21.649 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:21.652 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:21.883 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:21.883 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:21.930 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:22.017 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:22.017 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:22.040 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:22.187 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:22.195 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:22.195 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:22.453 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:22.453 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:22.453 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:22.565 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:22.573 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:22.573 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:22.693 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:22.693 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:22.699 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:22.843 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:22.843 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:22.843 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:22.961 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:22.961 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:23.019 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:23.082 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:23.082 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:23.085 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:23.309 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:23.330 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:23.330 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:23.371 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:23.371 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:23.444 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:23.664 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:23.675 - debug: tapo.0 (1411942) Update done
            2026-08-10 19:48:23.837 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:23.838 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
            2026-08-10 19:48:23.838 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:24.237 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:24.237 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:24.240 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:24.668 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:24.669 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:24.687 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:25.112 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:25.119 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:25.119 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:25.543 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:25.543 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:25.543 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:25.916 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:25.916 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:25.920 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:26.339 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:26.339 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:26.409 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:27.012 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:27.020 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:27.020 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:27.732 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:27.732 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:27.732 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:28.468 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:28.468 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:28.487 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:29.391 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:29.392 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:29.416 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:29.925 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:29.936 - debug: tapo.0 (1411942) Update done
            2026-08-10 19:48:30.939 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:30.940 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:31.144 - info: sonoff.0 (1140) Client [Plug03-KEL-IT-152] connection closed: Error: read ECONNRESET
            2026-08-10 19:48:31.404 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:31.404 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
            2026-08-10 19:48:31.404 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:31.633 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:31.633 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:31.637 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:31.864 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:31.864 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:31.884 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:32.147 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:32.158 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:32.158 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:32.454 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:32.455 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:32.455 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:32.762 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:32.762 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:32.765 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:33.038 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:33.038 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:33.060 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:33.367 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:33.386 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:33.386 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:33.906 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:33.906 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
            2026-08-10 19:48:33.906 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:34.303 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:34.304 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:34.308 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:34.715 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:34.715 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:34.738 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:35.162 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:35.171 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:35.171 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:35.580 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:35.580 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:35.580 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:35.921 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:35.921 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:35.925 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:36.763 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:36.763 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:36.780 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:37.265 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:37.275 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:37.275 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:37.528 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:37.528 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:37.528 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:37.765 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:37.765 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:37.770 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:38.038 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:38.038 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:38.056 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:38.356 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:38.373 - debug: tapo.0 (1411942) Update done
            2026-08-10 19:48:40.940 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:40.940 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:41.211 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:41.212 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
            2026-08-10 19:48:41.212 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:41.338 - info: sonoff.0 (1140) Client [Plug03-KEL-IT-152] connected with secret 1786384121336_904
            2026-08-10 19:48:41.467 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:41.467 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:41.525 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:41.776 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:41.776 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:41.801 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:42.048 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:42.058 - debug: tapo.0 (1411942) Receive camera status
            2026-08-10 19:48:42.059 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:42.368 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:42.368 - debug: tapo.0 (1411942) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
            2026-08-10 19:48:42.368 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:42.531 - info: host.iOProduktiv "system.adapter.tapo.0" disabled
            2026-08-10 19:48:42.531 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 (force=false, process=true)
            2026-08-10 19:48:42.533 - info: tapo.0 (1411942) Got terminate signal TERMINATE_YOURSELF
            2026-08-10 19:48:42.533 - info: tapo.0 (1411942) terminating
            2026-08-10 19:48:42.534 - info: tapo.0 (1411942) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2026-08-10 19:48:42.640 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 send kill signal
            2026-08-10 19:48:42.685 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:42.685 - debug: tapo.0 (1411942) searchDetectionList raw: {}
            2026-08-10 19:48:42.763 - debug: tapo.0 (1411942) New API request
            2026-08-10 19:48:42.986 - debug: tapo.0 (1411942) API response
            2026-08-10 19:48:42.986 - debug: tapo.0 (1411942) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
            2026-08-10 19:48:43.034 - info: tapo.0 (1411942) terminating
            2026-08-10 19:48:43.038 - debug: tapo.0 (1411942) redis get tapo.0.80219D887A52D32D03212C4C2DE37E4D21EC8028.alarmInfo.alarm_mode.light, error - Connection is closed.
            2026-08-10 19:48:43.038 - error: tapo.0 (1411942) Error extract keys: 80219D887A52D32D03212C4C2DE37E4D21EC8028.alarmInfo.alarm_mode.light "light"
            2026-08-10 19:48:43.039 - error: tapo.0 (1411942) Error: DB closed
            2026-08-10 19:48:43.382 - info: host.iOProduktiv instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            Was kann ich zur Fehlerbehebung beitragen?
            LG
            T
            T
            tombox
            #876
            @metaxa die GitHub version nochmal installieren
            metaxaM 1 Antwort Letzte Antwort
            • T tombox
              metaxaM
              metaxaM
              metaxa
              #877
              @tombox
              Leider keine Besserung.
              • metaxaM metaxa
                @tombox
                T
                T
                tombox
                #878
                @metaxa ich brauch den log
                • T tombox
                  metaxaM
                  metaxaM
                  metaxa
                  #879
                  @tombox
                  DebugLog
                  2026-08-11 00:28:15.571 - info: host.iOProduktiv "system.adapter.tapo.0" enabled
                  2026-08-11 00:28:16.389 - info: host.iOProduktiv instance system.adapter.tapo.0 in version "0.6.3" (non-npm: TA2k/ioBroker.tapo) started with pid 1635498
                  2026-08-11 00:28:17.159 - debug: tapo.0 (1635498) Redis Objects: Use Redis connection: 0.0.0.0:9001
                  2026-08-11 00:28:17.205 - debug: tapo.0 (1635498) Objects client ready ... initialize now
                  2026-08-11 00:28:17.206 - debug: tapo.0 (1635498) Objects create System PubSub Client
                  2026-08-11 00:28:17.206 - debug: tapo.0 (1635498) Objects create User PubSub Client
                  2026-08-11 00:28:17.337 - debug: tapo.0 (1635498) Objects client initialize lua scripts
                  2026-08-11 00:28:17.340 - debug: tapo.0 (1635498) Objects connected to redis: 0.0.0.0:9001
                  2026-08-11 00:28:17.398 - debug: tapo.0 (1635498) Redis States: Use Redis connection: 0.0.0.0:9000
                  2026-08-11 00:28:17.440 - debug: tapo.0 (1635498) States create System PubSub Client
                  2026-08-11 00:28:17.440 - debug: tapo.0 (1635498) States create User PubSub Client
                  2026-08-11 00:28:17.563 - debug: tapo.0 (1635498) States connected to redis: 0.0.0.0:9000
                  2026-08-11 00:28:17.725 - info: tapo.0 (1635498) starting. Version 0.6.3 (non-npm: TA2k/ioBroker.tapo) in /opt/iobroker/node_modules/iobroker.tapo, node: v22.23.0, js-controller: 7.2.2
                  2026-08-11 00:28:17.751 - info: tapo.0 (1635498) Login tp TAPO App
                  2026-08-11 00:28:17.839 - debug: tapo.0 (1635498) xaYE4SMWpkdB/E8dxzgSWA==
                  2026-08-11 00:28:18.124 - debug: tapo.0 (1635498) {"error_code":0,"result":{"accountApiUrl":"https://euw1-account-api.i.tplinkcloud.com","lockedMinutes":0,"appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"38ee8e2b-BTUVbh4MOQqn9tvUwi1w78C","accountId":"37806770","regionCode":"AT","regTime":"2021-06-23 14:33:54","nickname":"mxa","email":"mxa@gmx.at","appServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com","refreshToken":"38ee8e2b-BTQsPoCVASGPAYEwdb5gnGd"}}
                  2026-08-11 00:28:18.125 - info: tapo.0 (1635498) Login succesfull
                  2026-08-11 00:28:18.125 - debug: tapo.0 (1635498) 3tJNSNko5EAYJ06dPx9ulA==
                  2026-08-11 00:28:18.340 - debug: tapo.0 (1635498) {"error_code":0,"result":{"totalNum":5,"deviceList":[{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0","deviceName":"C310 2.0","lastBindTime":1784968460000,"deviceHwVer":"2.0","alias":"Postkasten","deviceMac":"005F67798FDD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.4 Build 250811 Rel.34127n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80219D887A52D32D03212C4C2DE37E4D21EC8028","deviceName":"C520WS 1.0","lastBindTime":1705169151000,"deviceHwVer":"1.0","alias":"Terrasse","deviceMac":"F0A731D87F97","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","deviceModel":"C520WS","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.4.4 Build 260527 Rel.28339n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802114698B0C4DB803277811859F5C6723111712","deviceName":"C200 5.0","lastBindTime":1785313977000,"deviceHwVer":"5.0","alias":"Beet","deviceMac":"B019213463BA","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","deviceModel":"C200","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021314EFB57E17626EC16DBDB2A31A51E64292E","deviceName":"C310 2.0","lastBindTime":1632395306000,"deviceHwVer":"2.0","alias":"Haus Eingang vorne","deviceMac":"005F67798FBD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.5 Build 260323 Rel.35521n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802173FB22D1FB8B96E616F599FE462C24EBEDA7","deviceName":"C530WS 2.0","lastBindTime":1782991868000,"deviceHwVer":"2.0","alias":"Einfahrt","deviceMac":"6C4CBC025F2C","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","deviceModel":"C530WS","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0}],"currentIndex":4}}
                  2026-08-11 00:28:18.340 - info: tapo.0 (1635498) Found 5 devices
                  2026-08-11 00:28:18.341 - debug: tapo.0 (1635498) Found device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Postkasten
                  2026-08-11 00:28:18.612 - debug: tapo.0 (1635498) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"","mac":"005F67798FDD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.110","onboardingTime":1784968460,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                  2026-08-11 00:28:18.612 - info: tapo.0 (1635498) Init device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 type C310 2.0 with ip 192.168.0.110
                  2026-08-11 00:28:18.613 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.110 on port 20002
                  2026-08-11 00:28:18.676 - info: tapo.0 (1635498) UDP discovery for 192.168.0.110: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-DD
                  2026-08-11 00:28:18.741 - info: tapo.0 (1635498) 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2}
                  2026-08-11 00:28:18.741 - debug: tapo.0 (1635498) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2}
                  2026-08-11 00:28:18.741 - debug: tapo.0 (1635498) Init event emitter for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0
                  2026-08-11 00:28:18.744 - debug: tapo.0 (1635498) Init event listener for "motion"
                  2026-08-11 00:28:18.744 - info: tapo.0 (1635498) Initialized 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0
                  2026-08-11 00:28:18.745 - debug: tapo.0 (1635498) initResult camera 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 undefined
                  2026-08-11 00:28:18.745 - debug: tapo.0 (1635498) Found device 80219D887A52D32D03212C4C2DE37E4D21EC8028 M��j�
                  2026-08-11 00:28:18.997 - debug: tapo.0 (1635498) {"hwVer":"1.0","category":"camera","model":"C520WS 1.0","ssid":"","mac":"F0A731D87F97","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","fwVer":"1.3.4 Build 250811 Rel.34127n","ip":"192.168.0.112","onboardingTime":1705169153,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                  2026-08-11 00:28:18.997 - info: tapo.0 (1635498) Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.112
                  2026-08-11 00:28:18.997 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.112 on port 20002
                  2026-08-11 00:28:19.113 - info: tapo.0 (1635498) UDP discovery for 192.168.0.112: port=80 https=true encrypt=undefined lv=3 mac=F0-A7-31-D8-7F-97
                  2026-08-11 00:28:19.596 - info: tapo.0 (1635498) 80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1}
                  2026-08-11 00:28:19.596 - debug: tapo.0 (1635498) {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1}
                  2026-08-11 00:28:19.596 - debug: tapo.0 (1635498) Init event emitter for 80219D887A52D32D03212C4C2DE37E4D21EC8028
                  2026-08-11 00:28:19.598 - debug: tapo.0 (1635498) Init event listener for "motion"
                  2026-08-11 00:28:19.598 - info: tapo.0 (1635498) Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
                  2026-08-11 00:28:19.598 - debug: tapo.0 (1635498) initResult camera 80219D887A52D32D03212C4C2DE37E4D21EC8028 undefined
                  2026-08-11 00:28:19.598 - debug: tapo.0 (1635498) Found device 802114698B0C4DB803277811859F5C6723111712 �
                  2026-08-11 00:28:19.865 - debug: tapo.0 (1635498) {"hwVer":"5.0","category":"camera","model":"C200 5.0","ssid":"videosun","mac":"B019213463BA","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","fwVer":"1.4.4 Build 260527 Rel.28339n","ip":"192.168.0.114","onboardingTime":1785313979,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                  2026-08-11 00:28:19.865 - info: tapo.0 (1635498) Init device 802114698B0C4DB803277811859F5C6723111712 type C200 5.0 with ip 192.168.0.114
                  2026-08-11 00:28:19.865 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.114 on port 20002
                  2026-08-11 00:28:19.949 - info: tapo.0 (1635498) UDP discovery for 192.168.0.114: port=80 https=true encrypt=undefined lv=4 mac=B0-19-21-34-63-BA
                  2026-08-11 00:28:20.066 - info: tapo.0 (1635498) 802114698B0C4DB803277811859F5C6723111712 Received device info {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5}
                  2026-08-11 00:28:20.066 - debug: tapo.0 (1635498) {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5}
                  2026-08-11 00:28:20.066 - debug: tapo.0 (1635498) Init event emitter for 802114698B0C4DB803277811859F5C6723111712
                  2026-08-11 00:28:20.068 - debug: tapo.0 (1635498) Init event listener for "motion"
                  2026-08-11 00:28:20.069 - info: tapo.0 (1635498) Initialized 802114698B0C4DB803277811859F5C6723111712
                  2026-08-11 00:28:20.069 - debug: tapo.0 (1635498) initResult camera 802114698B0C4DB803277811859F5C6723111712 undefined
                  2026-08-11 00:28:20.069 - debug: tapo.0 (1635498) Found device 8021314EFB57E17626EC16DBDB2A31A51E64292E Haus Eingang vorne
                  2026-08-11 00:28:20.345 - debug: tapo.0 (1635498) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"Sun 2.4","mac":"005F67798FBD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.113","onboardingTime":0,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                  2026-08-11 00:28:20.345 - info: tapo.0 (1635498) Init device 8021314EFB57E17626EC16DBDB2A31A51E64292E type C310 2.0 with ip 192.168.0.113
                  2026-08-11 00:28:20.345 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.113 on port 20002
                  2026-08-11 00:28:20.456 - info: tapo.0 (1635498) UDP discovery for 192.168.0.113: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-BD
                  2026-08-11 00:28:20.692 - info: tapo.0 (1635498) 8021314EFB57E17626EC16DBDB2A31A51E64292E Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2}
                  2026-08-11 00:28:20.692 - debug: tapo.0 (1635498) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2}
                  2026-08-11 00:28:20.692 - debug: tapo.0 (1635498) Init event emitter for 8021314EFB57E17626EC16DBDB2A31A51E64292E
                  2026-08-11 00:28:20.695 - debug: tapo.0 (1635498) Init event listener for "motion"
                  2026-08-11 00:28:20.695 - info: tapo.0 (1635498) Initialized 8021314EFB57E17626EC16DBDB2A31A51E64292E
                  2026-08-11 00:28:20.695 - debug: tapo.0 (1635498) initResult camera 8021314EFB57E17626EC16DBDB2A31A51E64292E undefined
                  2026-08-11 00:28:20.695 - debug: tapo.0 (1635498) Found device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 )�j�
                  2026-08-11 00:28:20.978 - debug: tapo.0 (1635498) {"hwVer":"2.0","category":"camera","model":"C530WS 2.0","ssid":"","mac":"6C4CBC025F2C","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","fwVer":"1.3.5 Build 260323 Rel.35521n","ip":"192.168.0.115","onboardingTime":1782991869,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                  2026-08-11 00:28:20.979 - info: tapo.0 (1635498) Init device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 type C530WS 2.0 with ip 192.168.0.115
                  2026-08-11 00:28:20.979 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.115 on port 20002
                  2026-08-11 00:28:23.979 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.115: no response (will use default port 80)
                  2026-08-11 00:28:34.124 - error: tapo.0 (1635498) connect EHOSTUNREACH 192.168.0.115:2020
                  2026-08-11 00:28:34.124 - debug: tapo.0 (1635498) initResult camera 802173FB22D1FB8B96E616F599FE462C24EBEDA7 undefined
                  2026-08-11 00:28:34.126 - info: tapo.0 (1635498) Wait for connections for non camera devices
                  2026-08-11 00:28:44.128 - info: tapo.0 (1635498) Start first Update
                  2026-08-11 00:28:44.128 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:28:44.129 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:44.129 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                  2026-08-11 00:28:44.360 - debug: tapo.0 (1635498) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"F688FEBE5847D23A","device_confirm":"3C18F40AA86CE9B08A6882B3103275B402522A639F8DE58995781A5F1FA01B05F688FEBE5847D23A04A145A70521F763"}}}
                  2026-08-11 00:28:44.360 - debug: tapo.0 (1635498) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                  2026-08-11 00:28:44.361 - debug: tapo.0 (1635498) refreshStok: Refreshing stok...
                  2026-08-11 00:28:44.361 - debug: tapo.0 (1635498) refreshStok: isSecureConnection=true username=admin cnonce=286830A82BFB9E5C
                  2026-08-11 00:28:44.575 - debug: tapo.0 (1635498) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"3BAC3FF2BB42869A","device_confirm":"D86C12523BA3E3DF2E132625E4800DDC9DA052CC7EA792A06D93D8366B8D75853BAC3FF2BB42869A286830A82BFB9E5C"}}}
                  2026-08-11 00:28:44.576 - debug: tapo.0 (1635498) refreshStok: nonce=3BAC3FF2BB42869A... deviceConfirm=D86C12523BA3E3DF...
                  2026-08-11 00:28:44.576 - debug: tapo.0 (1635498) validateDeviceConfirm: matched candidate #1 via sha256
                  2026-08-11 00:28:44.576 - debug: tapo.0 (1635498) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                  2026-08-11 00:28:44.576 - debug: tapo.0 (1635498) refreshStok: sending start_seq request
                  2026-08-11 00:28:44.807 - debug: tapo.0 (1635498) refreshStok: start_seq response
                  2026-08-11 00:28:44.807 - debug: tapo.0 (1635498) refreshStok: start_seq=72935683 user_group=root stok=present
                  2026-08-11 00:28:44.808 - debug: tapo.0 (1635498) refreshStok: Success in obtaining STOK
                  2026-08-11 00:28:45.163 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:45.163 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                  2026-08-11 00:28:45.163 - info: tapo.0 (1635498) Reconnected to undefined
                  2026-08-11 00:28:45.164 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:45.388 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:45.388 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:28:45.490 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:45.716 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:45.716 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:28:46.002 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:46.218 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:46.240 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:28:46.240 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:46.240 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                  2026-08-11 00:28:46.479 - debug: tapo.0 (1635498) isSecureConnection response status=200 data={"result":{"data":{"code":-40401,"time":9,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"EBAEEBF7DBBB2AB9","device_confirm":"181B7D313497BA437E4856116424C0A5FEDF3853D83FF31028C3764A9D729F9FEBAEEBF7DBBB2AB97F2E2FFCE37E1D15"}},"error_code":-40413}
                  2026-08-11 00:28:46.479 - debug: tapo.0 (1635498) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                  2026-08-11 00:28:46.479 - debug: tapo.0 (1635498) refreshStok: Refreshing stok...
                  2026-08-11 00:28:46.479 - debug: tapo.0 (1635498) refreshStok: isSecureConnection=true username=admin cnonce=F1E25C6257A9A399
                  2026-08-11 00:28:46.793 - debug: tapo.0 (1635498) refreshStok: Login response status=200 data={"result":{"data":{"code":-40401,"time":8,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"DC3DE6207DC31AB1","device_confirm":"117FE25F6BEFCECB1F7B6BE5F81C220A773121D26C0A707E19A2EA33996BD617DC3DE6207DC31AB1F1E25C6257A9A399"}},"error_code":-40413}
                  2026-08-11 00:28:46.794 - debug: tapo.0 (1635498) refreshStok: nonce=DC3DE6207DC31AB1... deviceConfirm=117FE25F6BEFCECB...
                  2026-08-11 00:28:46.794 - debug: tapo.0 (1635498) validateDeviceConfirm: matched candidate #1 via sha256
                  2026-08-11 00:28:46.794 - debug: tapo.0 (1635498) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                  2026-08-11 00:28:46.794 - debug: tapo.0 (1635498) refreshStok: sending start_seq request
                  2026-08-11 00:28:47.209 - debug: tapo.0 (1635498) refreshStok: start_seq response
                  2026-08-11 00:28:47.209 - debug: tapo.0 (1635498) refreshStok: start_seq=422 user_group=root stok=present
                  2026-08-11 00:28:47.209 - debug: tapo.0 (1635498) refreshStok: Success in obtaining STOK
                  2026-08-11 00:28:47.671 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:47.671 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:28:47.671 - info: tapo.0 (1635498) Reconnected to undefined
                  2026-08-11 00:28:47.671 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:47.913 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:47.913 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:28:47.968 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:48.266 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:48.266 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:28:48.303 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:48.559 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:48.579 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:28:48.579 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:48.579 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                  2026-08-11 00:28:49.020 - debug: tapo.0 (1635498) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"9308AB4CDFC345FA","device_confirm":"32276E6A943433EE433A1EFAD7C288D4BA08A58A62F2952A4CFFBAC9822E1D6B9308AB4CDFC345FA3C6F651CC99E1C6A"}}}
                  2026-08-11 00:28:49.020 - debug: tapo.0 (1635498) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                  2026-08-11 00:28:49.020 - debug: tapo.0 (1635498) refreshStok: Refreshing stok...
                  2026-08-11 00:28:49.020 - debug: tapo.0 (1635498) refreshStok: isSecureConnection=true username=admin cnonce=C83B020405BC6B56
                  2026-08-11 00:28:49.346 - debug: tapo.0 (1635498) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"BA9C77DB4DE5B8B5","device_confirm":"11447F557B886D8332DEF778450D3A756AB5887640D709B2493EC72506D20D32BA9C77DB4DE5B8B5C83B020405BC6B56"}}}
                  2026-08-11 00:28:49.346 - debug: tapo.0 (1635498) refreshStok: nonce=BA9C77DB4DE5B8B5... deviceConfirm=11447F557B886D83...
                  2026-08-11 00:28:49.346 - debug: tapo.0 (1635498) validateDeviceConfirm: matched candidate #1 via sha256
                  2026-08-11 00:28:49.346 - debug: tapo.0 (1635498) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                  2026-08-11 00:28:49.346 - debug: tapo.0 (1635498) refreshStok: sending start_seq request
                  2026-08-11 00:28:49.721 - debug: tapo.0 (1635498) refreshStok: start_seq response
                  2026-08-11 00:28:49.721 - debug: tapo.0 (1635498) refreshStok: start_seq=47392456 user_group=root stok=present
                  2026-08-11 00:28:49.721 - debug: tapo.0 (1635498) refreshStok: Success in obtaining STOK
                  2026-08-11 00:28:50.071 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:50.072 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                  2026-08-11 00:28:50.072 - info: tapo.0 (1635498) Reconnected to undefined
                  2026-08-11 00:28:50.072 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:50.481 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:50.481 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:28:50.591 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:50.950 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:50.950 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:28:50.980 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:51.401 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:51.416 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:28:51.416 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:51.416 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                  2026-08-11 00:28:51.783 - debug: tapo.0 (1635498) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"D4AF77AFA23CE6F1","device_confirm":"2E00701DC345289B8607409C2AD6662BD464446FC3902C8A51BBD97B7F006AF2D4AF77AFA23CE6F15C77BB7CBA33D043"}}}
                  2026-08-11 00:28:51.784 - debug: tapo.0 (1635498) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                  2026-08-11 00:28:51.784 - debug: tapo.0 (1635498) refreshStok: Refreshing stok...
                  2026-08-11 00:28:51.784 - debug: tapo.0 (1635498) refreshStok: isSecureConnection=true username=admin cnonce=FBFE19CE2B3F3A9E
                  2026-08-11 00:28:52.023 - debug: tapo.0 (1635498) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"7BEDFC1FCD571230","device_confirm":"D0E801F10120DC9B3D28637505ED41E7485F0F10B0C94E75319D9E1F538A53DE7BEDFC1FCD571230FBFE19CE2B3F3A9E"}}}
                  2026-08-11 00:28:52.023 - debug: tapo.0 (1635498) refreshStok: nonce=7BEDFC1FCD571230... deviceConfirm=D0E801F10120DC9B...
                  2026-08-11 00:28:52.024 - debug: tapo.0 (1635498) validateDeviceConfirm: matched candidate #1 via sha256
                  2026-08-11 00:28:52.024 - debug: tapo.0 (1635498) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                  2026-08-11 00:28:52.024 - debug: tapo.0 (1635498) refreshStok: sending start_seq request
                  2026-08-11 00:28:52.347 - debug: tapo.0 (1635498) refreshStok: start_seq response
                  2026-08-11 00:28:52.347 - debug: tapo.0 (1635498) refreshStok: start_seq=38021225 user_group=root stok=present
                  2026-08-11 00:28:52.347 - debug: tapo.0 (1635498) refreshStok: Success in obtaining STOK
                  2026-08-11 00:28:52.667 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:52.668 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:28:52.668 - info: tapo.0 (1635498) Reconnected to undefined
                  2026-08-11 00:28:52.668 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:52.963 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:52.963 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:28:53.021 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:53.288 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:53.288 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:28:53.440 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:53.801 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:53.829 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:28:53.829 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:53.829 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                  2026-08-11 00:28:54.133 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:28:54.134 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:54.381 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:54.381 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                  2026-08-11 00:28:54.381 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:54.594 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:54.594 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:28:54.598 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:54.817 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:54.817 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:28:54.837 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:55.047 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:55.058 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:28:55.058 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:55.314 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:55.314 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:28:55.314 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:55.633 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:55.633 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:28:55.636 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:55.954 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:55.954 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:28:56.006 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:56.269 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:56.278 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:28:56.278 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:56.727 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:56.727 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                  2026-08-11 00:28:56.727 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:57.073 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:57.074 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:28:57.077 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:57.436 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:57.436 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:28:57.453 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:57.744 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:57.753 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:28:57.754 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:58.040 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:58.041 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:28:58.041 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:58.322 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:58.322 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:28:58.326 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:58.602 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:58.603 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:28:58.621 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:28:58.881 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:28:58.888 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:28:58.888 - debug: tapo.0 (1635498) API request already pending
                  2026-08-11 00:28:59.293 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                  2026-08-11 00:28:59.294 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                  2026-08-11 00:28:59.294 - debug: tapo.0 (1635498) undefined
                  2026-08-11 00:28:59.294 - debug: tapo.0 (1635498) Update done
                  2026-08-11 00:29:04.133 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:04.134 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:04.365 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:04.365 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                  2026-08-11 00:29:04.366 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:04.585 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:04.585 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:04.588 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:04.813 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:04.813 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:04.839 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:05.035 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:05.045 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:05.045 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:05.286 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:05.286 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:29:05.286 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:05.560 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:05.560 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:05.564 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:05.827 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:05.827 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:05.848 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:06.089 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:06.106 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:06.106 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:06.472 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:06.472 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                  2026-08-11 00:29:06.473 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:06.913 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:06.913 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:06.916 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:07.236 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:07.236 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:07.261 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:07.635 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:07.642 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:07.642 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:07.884 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:07.884 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:29:07.884 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:08.175 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:08.176 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:08.179 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:08.443 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:08.443 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:08.459 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:08.724 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:08.732 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:08.732 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:08.732 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                  2026-08-11 00:29:14.129 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                  2026-08-11 00:29:14.129 - debug: tapo.0 (1635498) undefined
                  2026-08-11 00:29:14.129 - debug: tapo.0 (1635498) Update done
                  2026-08-11 00:29:14.133 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:14.133 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:14.474 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:14.474 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                  2026-08-11 00:29:14.474 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:14.695 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:14.695 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:14.699 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:14.938 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:14.938 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:14.957 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:15.155 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:15.164 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:15.164 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:15.408 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:15.409 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:29:15.409 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:15.650 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:15.650 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:15.654 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:15.926 - debug: tapo.0 (1635498) [C520WS 1.0] "Motion detected" true
                  2026-08-11 00:29:15.951 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:15.951 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:16.017 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:16.109 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:16.149 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:16.149 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:16.521 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:16.521 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                  2026-08-11 00:29:16.521 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:16.996 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:16.997 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:17.000 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:17.346 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:17.346 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:17.364 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:17.399 - debug: tapo.0 (1635498) [C520WS 1.0] "Motion detected" false
                  2026-08-11 00:29:17.710 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:17.718 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:17.718 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:18.003 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:18.004 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:29:18.004 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:18.266 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:18.266 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:18.269 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:18.546 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:18.546 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:18.565 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:18.825 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:18.835 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:18.835 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:18.835 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                  2026-08-11 00:29:21.899 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                  2026-08-11 00:29:21.899 - debug: tapo.0 (1635498) undefined
                  2026-08-11 00:29:21.906 - debug: tapo.0 (1635498) Update done
                  2026-08-11 00:29:24.134 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:24.134 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:24.371 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:24.371 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                  2026-08-11 00:29:24.371 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:24.598 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:24.598 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:24.649 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:24.842 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:24.842 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:24.861 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:25.069 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:25.078 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:25.079 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:25.358 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:25.358 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:29:25.359 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:25.630 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:25.630 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:25.635 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:25.920 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:25.921 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:25.938 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:26.237 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:26.248 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:26.248 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:26.673 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:26.673 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                  2026-08-11 00:29:26.673 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:27.079 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:27.079 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:27.083 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:27.421 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:27.421 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:27.443 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:27.756 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:27.764 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:27.764 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:28.052 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:28.052 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:29:28.052 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:28.302 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:28.302 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:28.306 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:28.617 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:28.617 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:28.673 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:28.897 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:28.908 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:28.908 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:28.908 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                  2026-08-11 00:29:34.135 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:34.135 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:34.169 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                  2026-08-11 00:29:34.170 - debug: tapo.0 (1635498) undefined
                  2026-08-11 00:29:34.170 - debug: tapo.0 (1635498) Update done
                  2026-08-11 00:29:34.366 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:34.367 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                  2026-08-11 00:29:34.367 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:34.581 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:34.581 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:34.585 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:34.802 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:34.802 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:34.825 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:35.035 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:35.046 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:35.046 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:35.325 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:35.326 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:29:35.326 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:35.554 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:35.555 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:35.839 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:36.077 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:36.078 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:36.157 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:36.438 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:36.448 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:36.449 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:37.341 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:37.342 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                  2026-08-11 00:29:37.342 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:37.705 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:37.705 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:37.711 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:38.186 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:38.186 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:38.209 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:38.590 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:38.604 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:38.604 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:38.919 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:38.919 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:29:38.919 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:39.225 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:39.225 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:39.232 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:39.553 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:39.554 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:39.575 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:39.860 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:39.878 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:39.879 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:39.879 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                  2026-08-11 00:29:44.136 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:44.136 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:44.379 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:44.379 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                  2026-08-11 00:29:44.379 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:44.593 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:44.593 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:44.597 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:44.812 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:44.812 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:44.843 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:45.066 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:45.079 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:45.079 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:45.346 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:45.346 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                  2026-08-11 00:29:45.347 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:45.352 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                  2026-08-11 00:29:45.352 - debug: tapo.0 (1635498) undefined
                  2026-08-11 00:29:45.352 - debug: tapo.0 (1635498) Update done
                  2026-08-11 00:29:45.627 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:45.627 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:45.674 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:45.945 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:45.945 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:45.968 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:46.274 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:46.286 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:46.286 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:46.473 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:46.958 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:46.958 - info: tapo.0 (1635498) moveToPreset was set to : Sabine for device 802114698B0C4DB803277811859F5C6723111712 was successful: false
                  2026-08-11 00:29:46.975 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:46.976 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                  2026-08-11 00:29:46.976 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:47.340 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:47.340 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                  2026-08-11 00:29:47.343 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:47.678 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:47.678 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                  2026-08-11 00:29:47.697 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:48.003 - debug: tapo.0 (1635498) API response
                  2026-08-11 00:29:48.009 - debug: tapo.0 (1635498) Receive camera status
                  2026-08-11 00:29:48.010 - debug: tapo.0 (1635498) New API request
                  2026-08-11 00:29:48.309 - debug: tapo.0 (1635498) API response
                  Cam C530WS (IP 115) ist, warum auch immer im Moment offline, geht auch nicht über die App. Da kann ich erst tagsüber raufturnen und manuell neu starten.
                  Danke für deine Mühe, LG
                  • metaxaM metaxa
                    @tombox
                    DebugLog
                    2026-08-11 00:28:15.571 - info: host.iOProduktiv "system.adapter.tapo.0" enabled
                    2026-08-11 00:28:16.389 - info: host.iOProduktiv instance system.adapter.tapo.0 in version "0.6.3" (non-npm: TA2k/ioBroker.tapo) started with pid 1635498
                    2026-08-11 00:28:17.159 - debug: tapo.0 (1635498) Redis Objects: Use Redis connection: 0.0.0.0:9001
                    2026-08-11 00:28:17.205 - debug: tapo.0 (1635498) Objects client ready ... initialize now
                    2026-08-11 00:28:17.206 - debug: tapo.0 (1635498) Objects create System PubSub Client
                    2026-08-11 00:28:17.206 - debug: tapo.0 (1635498) Objects create User PubSub Client
                    2026-08-11 00:28:17.337 - debug: tapo.0 (1635498) Objects client initialize lua scripts
                    2026-08-11 00:28:17.340 - debug: tapo.0 (1635498) Objects connected to redis: 0.0.0.0:9001
                    2026-08-11 00:28:17.398 - debug: tapo.0 (1635498) Redis States: Use Redis connection: 0.0.0.0:9000
                    2026-08-11 00:28:17.440 - debug: tapo.0 (1635498) States create System PubSub Client
                    2026-08-11 00:28:17.440 - debug: tapo.0 (1635498) States create User PubSub Client
                    2026-08-11 00:28:17.563 - debug: tapo.0 (1635498) States connected to redis: 0.0.0.0:9000
                    2026-08-11 00:28:17.725 - info: tapo.0 (1635498) starting. Version 0.6.3 (non-npm: TA2k/ioBroker.tapo) in /opt/iobroker/node_modules/iobroker.tapo, node: v22.23.0, js-controller: 7.2.2
                    2026-08-11 00:28:17.751 - info: tapo.0 (1635498) Login tp TAPO App
                    2026-08-11 00:28:17.839 - debug: tapo.0 (1635498) xaYE4SMWpkdB/E8dxzgSWA==
                    2026-08-11 00:28:18.124 - debug: tapo.0 (1635498) {"error_code":0,"result":{"accountApiUrl":"https://euw1-account-api.i.tplinkcloud.com","lockedMinutes":0,"appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"38ee8e2b-BTUVbh4MOQqn9tvUwi1w78C","accountId":"37806770","regionCode":"AT","regTime":"2021-06-23 14:33:54","nickname":"mxa","email":"mxa@gmx.at","appServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com","refreshToken":"38ee8e2b-BTQsPoCVASGPAYEwdb5gnGd"}}
                    2026-08-11 00:28:18.125 - info: tapo.0 (1635498) Login succesfull
                    2026-08-11 00:28:18.125 - debug: tapo.0 (1635498) 3tJNSNko5EAYJ06dPx9ulA==
                    2026-08-11 00:28:18.340 - debug: tapo.0 (1635498) {"error_code":0,"result":{"totalNum":5,"deviceList":[{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0","deviceName":"C310 2.0","lastBindTime":1784968460000,"deviceHwVer":"2.0","alias":"Postkasten","deviceMac":"005F67798FDD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.4 Build 250811 Rel.34127n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80219D887A52D32D03212C4C2DE37E4D21EC8028","deviceName":"C520WS 1.0","lastBindTime":1705169151000,"deviceHwVer":"1.0","alias":"Terrasse","deviceMac":"F0A731D87F97","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","deviceModel":"C520WS","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.4.4 Build 260527 Rel.28339n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802114698B0C4DB803277811859F5C6723111712","deviceName":"C200 5.0","lastBindTime":1785313977000,"deviceHwVer":"5.0","alias":"Beet","deviceMac":"B019213463BA","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","deviceModel":"C200","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021314EFB57E17626EC16DBDB2A31A51E64292E","deviceName":"C310 2.0","lastBindTime":1632395306000,"deviceHwVer":"2.0","alias":"Haus Eingang vorne","deviceMac":"005F67798FBD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.5 Build 260323 Rel.35521n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802173FB22D1FB8B96E616F599FE462C24EBEDA7","deviceName":"C530WS 2.0","lastBindTime":1782991868000,"deviceHwVer":"2.0","alias":"Einfahrt","deviceMac":"6C4CBC025F2C","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","deviceModel":"C530WS","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0}],"currentIndex":4}}
                    2026-08-11 00:28:18.340 - info: tapo.0 (1635498) Found 5 devices
                    2026-08-11 00:28:18.341 - debug: tapo.0 (1635498) Found device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Postkasten
                    2026-08-11 00:28:18.612 - debug: tapo.0 (1635498) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"","mac":"005F67798FDD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.110","onboardingTime":1784968460,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                    2026-08-11 00:28:18.612 - info: tapo.0 (1635498) Init device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 type C310 2.0 with ip 192.168.0.110
                    2026-08-11 00:28:18.613 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.110 on port 20002
                    2026-08-11 00:28:18.676 - info: tapo.0 (1635498) UDP discovery for 192.168.0.110: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-DD
                    2026-08-11 00:28:18.741 - info: tapo.0 (1635498) 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2}
                    2026-08-11 00:28:18.741 - debug: tapo.0 (1635498) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2}
                    2026-08-11 00:28:18.741 - debug: tapo.0 (1635498) Init event emitter for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0
                    2026-08-11 00:28:18.744 - debug: tapo.0 (1635498) Init event listener for "motion"
                    2026-08-11 00:28:18.744 - info: tapo.0 (1635498) Initialized 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0
                    2026-08-11 00:28:18.745 - debug: tapo.0 (1635498) initResult camera 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 undefined
                    2026-08-11 00:28:18.745 - debug: tapo.0 (1635498) Found device 80219D887A52D32D03212C4C2DE37E4D21EC8028 M��j�
                    2026-08-11 00:28:18.997 - debug: tapo.0 (1635498) {"hwVer":"1.0","category":"camera","model":"C520WS 1.0","ssid":"","mac":"F0A731D87F97","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","fwVer":"1.3.4 Build 250811 Rel.34127n","ip":"192.168.0.112","onboardingTime":1705169153,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                    2026-08-11 00:28:18.997 - info: tapo.0 (1635498) Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.112
                    2026-08-11 00:28:18.997 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.112 on port 20002
                    2026-08-11 00:28:19.113 - info: tapo.0 (1635498) UDP discovery for 192.168.0.112: port=80 https=true encrypt=undefined lv=3 mac=F0-A7-31-D8-7F-97
                    2026-08-11 00:28:19.596 - info: tapo.0 (1635498) 80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1}
                    2026-08-11 00:28:19.596 - debug: tapo.0 (1635498) {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1}
                    2026-08-11 00:28:19.596 - debug: tapo.0 (1635498) Init event emitter for 80219D887A52D32D03212C4C2DE37E4D21EC8028
                    2026-08-11 00:28:19.598 - debug: tapo.0 (1635498) Init event listener for "motion"
                    2026-08-11 00:28:19.598 - info: tapo.0 (1635498) Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
                    2026-08-11 00:28:19.598 - debug: tapo.0 (1635498) initResult camera 80219D887A52D32D03212C4C2DE37E4D21EC8028 undefined
                    2026-08-11 00:28:19.598 - debug: tapo.0 (1635498) Found device 802114698B0C4DB803277811859F5C6723111712 �
                    2026-08-11 00:28:19.865 - debug: tapo.0 (1635498) {"hwVer":"5.0","category":"camera","model":"C200 5.0","ssid":"videosun","mac":"B019213463BA","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","fwVer":"1.4.4 Build 260527 Rel.28339n","ip":"192.168.0.114","onboardingTime":1785313979,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                    2026-08-11 00:28:19.865 - info: tapo.0 (1635498) Init device 802114698B0C4DB803277811859F5C6723111712 type C200 5.0 with ip 192.168.0.114
                    2026-08-11 00:28:19.865 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.114 on port 20002
                    2026-08-11 00:28:19.949 - info: tapo.0 (1635498) UDP discovery for 192.168.0.114: port=80 https=true encrypt=undefined lv=4 mac=B0-19-21-34-63-BA
                    2026-08-11 00:28:20.066 - info: tapo.0 (1635498) 802114698B0C4DB803277811859F5C6723111712 Received device info {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5}
                    2026-08-11 00:28:20.066 - debug: tapo.0 (1635498) {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5}
                    2026-08-11 00:28:20.066 - debug: tapo.0 (1635498) Init event emitter for 802114698B0C4DB803277811859F5C6723111712
                    2026-08-11 00:28:20.068 - debug: tapo.0 (1635498) Init event listener for "motion"
                    2026-08-11 00:28:20.069 - info: tapo.0 (1635498) Initialized 802114698B0C4DB803277811859F5C6723111712
                    2026-08-11 00:28:20.069 - debug: tapo.0 (1635498) initResult camera 802114698B0C4DB803277811859F5C6723111712 undefined
                    2026-08-11 00:28:20.069 - debug: tapo.0 (1635498) Found device 8021314EFB57E17626EC16DBDB2A31A51E64292E Haus Eingang vorne
                    2026-08-11 00:28:20.345 - debug: tapo.0 (1635498) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"Sun 2.4","mac":"005F67798FBD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.113","onboardingTime":0,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                    2026-08-11 00:28:20.345 - info: tapo.0 (1635498) Init device 8021314EFB57E17626EC16DBDB2A31A51E64292E type C310 2.0 with ip 192.168.0.113
                    2026-08-11 00:28:20.345 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.113 on port 20002
                    2026-08-11 00:28:20.456 - info: tapo.0 (1635498) UDP discovery for 192.168.0.113: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-BD
                    2026-08-11 00:28:20.692 - info: tapo.0 (1635498) 8021314EFB57E17626EC16DBDB2A31A51E64292E Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2}
                    2026-08-11 00:28:20.692 - debug: tapo.0 (1635498) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2}
                    2026-08-11 00:28:20.692 - debug: tapo.0 (1635498) Init event emitter for 8021314EFB57E17626EC16DBDB2A31A51E64292E
                    2026-08-11 00:28:20.695 - debug: tapo.0 (1635498) Init event listener for "motion"
                    2026-08-11 00:28:20.695 - info: tapo.0 (1635498) Initialized 8021314EFB57E17626EC16DBDB2A31A51E64292E
                    2026-08-11 00:28:20.695 - debug: tapo.0 (1635498) initResult camera 8021314EFB57E17626EC16DBDB2A31A51E64292E undefined
                    2026-08-11 00:28:20.695 - debug: tapo.0 (1635498) Found device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 )�j�
                    2026-08-11 00:28:20.978 - debug: tapo.0 (1635498) {"hwVer":"2.0","category":"camera","model":"C530WS 2.0","ssid":"","mac":"6C4CBC025F2C","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","fwVer":"1.3.5 Build 260323 Rel.35521n","ip":"192.168.0.115","onboardingTime":1782991869,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                    2026-08-11 00:28:20.979 - info: tapo.0 (1635498) Init device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 type C530WS 2.0 with ip 192.168.0.115
                    2026-08-11 00:28:20.979 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.115 on port 20002
                    2026-08-11 00:28:23.979 - debug: tapo.0 (1635498) UDP discovery for 192.168.0.115: no response (will use default port 80)
                    2026-08-11 00:28:34.124 - error: tapo.0 (1635498) connect EHOSTUNREACH 192.168.0.115:2020
                    2026-08-11 00:28:34.124 - debug: tapo.0 (1635498) initResult camera 802173FB22D1FB8B96E616F599FE462C24EBEDA7 undefined
                    2026-08-11 00:28:34.126 - info: tapo.0 (1635498) Wait for connections for non camera devices
                    2026-08-11 00:28:44.128 - info: tapo.0 (1635498) Start first Update
                    2026-08-11 00:28:44.128 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:28:44.129 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:44.129 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                    2026-08-11 00:28:44.360 - debug: tapo.0 (1635498) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"F688FEBE5847D23A","device_confirm":"3C18F40AA86CE9B08A6882B3103275B402522A639F8DE58995781A5F1FA01B05F688FEBE5847D23A04A145A70521F763"}}}
                    2026-08-11 00:28:44.360 - debug: tapo.0 (1635498) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                    2026-08-11 00:28:44.361 - debug: tapo.0 (1635498) refreshStok: Refreshing stok...
                    2026-08-11 00:28:44.361 - debug: tapo.0 (1635498) refreshStok: isSecureConnection=true username=admin cnonce=286830A82BFB9E5C
                    2026-08-11 00:28:44.575 - debug: tapo.0 (1635498) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"3BAC3FF2BB42869A","device_confirm":"D86C12523BA3E3DF2E132625E4800DDC9DA052CC7EA792A06D93D8366B8D75853BAC3FF2BB42869A286830A82BFB9E5C"}}}
                    2026-08-11 00:28:44.576 - debug: tapo.0 (1635498) refreshStok: nonce=3BAC3FF2BB42869A... deviceConfirm=D86C12523BA3E3DF...
                    2026-08-11 00:28:44.576 - debug: tapo.0 (1635498) validateDeviceConfirm: matched candidate #1 via sha256
                    2026-08-11 00:28:44.576 - debug: tapo.0 (1635498) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                    2026-08-11 00:28:44.576 - debug: tapo.0 (1635498) refreshStok: sending start_seq request
                    2026-08-11 00:28:44.807 - debug: tapo.0 (1635498) refreshStok: start_seq response
                    2026-08-11 00:28:44.807 - debug: tapo.0 (1635498) refreshStok: start_seq=72935683 user_group=root stok=present
                    2026-08-11 00:28:44.808 - debug: tapo.0 (1635498) refreshStok: Success in obtaining STOK
                    2026-08-11 00:28:45.163 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:45.163 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                    2026-08-11 00:28:45.163 - info: tapo.0 (1635498) Reconnected to undefined
                    2026-08-11 00:28:45.164 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:45.388 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:45.388 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:28:45.490 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:45.716 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:45.716 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:28:46.002 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:46.218 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:46.240 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:28:46.240 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:46.240 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                    2026-08-11 00:28:46.479 - debug: tapo.0 (1635498) isSecureConnection response status=200 data={"result":{"data":{"code":-40401,"time":9,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"EBAEEBF7DBBB2AB9","device_confirm":"181B7D313497BA437E4856116424C0A5FEDF3853D83FF31028C3764A9D729F9FEBAEEBF7DBBB2AB97F2E2FFCE37E1D15"}},"error_code":-40413}
                    2026-08-11 00:28:46.479 - debug: tapo.0 (1635498) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                    2026-08-11 00:28:46.479 - debug: tapo.0 (1635498) refreshStok: Refreshing stok...
                    2026-08-11 00:28:46.479 - debug: tapo.0 (1635498) refreshStok: isSecureConnection=true username=admin cnonce=F1E25C6257A9A399
                    2026-08-11 00:28:46.793 - debug: tapo.0 (1635498) refreshStok: Login response status=200 data={"result":{"data":{"code":-40401,"time":8,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"DC3DE6207DC31AB1","device_confirm":"117FE25F6BEFCECB1F7B6BE5F81C220A773121D26C0A707E19A2EA33996BD617DC3DE6207DC31AB1F1E25C6257A9A399"}},"error_code":-40413}
                    2026-08-11 00:28:46.794 - debug: tapo.0 (1635498) refreshStok: nonce=DC3DE6207DC31AB1... deviceConfirm=117FE25F6BEFCECB...
                    2026-08-11 00:28:46.794 - debug: tapo.0 (1635498) validateDeviceConfirm: matched candidate #1 via sha256
                    2026-08-11 00:28:46.794 - debug: tapo.0 (1635498) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                    2026-08-11 00:28:46.794 - debug: tapo.0 (1635498) refreshStok: sending start_seq request
                    2026-08-11 00:28:47.209 - debug: tapo.0 (1635498) refreshStok: start_seq response
                    2026-08-11 00:28:47.209 - debug: tapo.0 (1635498) refreshStok: start_seq=422 user_group=root stok=present
                    2026-08-11 00:28:47.209 - debug: tapo.0 (1635498) refreshStok: Success in obtaining STOK
                    2026-08-11 00:28:47.671 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:47.671 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:28:47.671 - info: tapo.0 (1635498) Reconnected to undefined
                    2026-08-11 00:28:47.671 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:47.913 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:47.913 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:28:47.968 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:48.266 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:48.266 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:28:48.303 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:48.559 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:48.579 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:28:48.579 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:48.579 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                    2026-08-11 00:28:49.020 - debug: tapo.0 (1635498) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"9308AB4CDFC345FA","device_confirm":"32276E6A943433EE433A1EFAD7C288D4BA08A58A62F2952A4CFFBAC9822E1D6B9308AB4CDFC345FA3C6F651CC99E1C6A"}}}
                    2026-08-11 00:28:49.020 - debug: tapo.0 (1635498) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                    2026-08-11 00:28:49.020 - debug: tapo.0 (1635498) refreshStok: Refreshing stok...
                    2026-08-11 00:28:49.020 - debug: tapo.0 (1635498) refreshStok: isSecureConnection=true username=admin cnonce=C83B020405BC6B56
                    2026-08-11 00:28:49.346 - debug: tapo.0 (1635498) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"BA9C77DB4DE5B8B5","device_confirm":"11447F557B886D8332DEF778450D3A756AB5887640D709B2493EC72506D20D32BA9C77DB4DE5B8B5C83B020405BC6B56"}}}
                    2026-08-11 00:28:49.346 - debug: tapo.0 (1635498) refreshStok: nonce=BA9C77DB4DE5B8B5... deviceConfirm=11447F557B886D83...
                    2026-08-11 00:28:49.346 - debug: tapo.0 (1635498) validateDeviceConfirm: matched candidate #1 via sha256
                    2026-08-11 00:28:49.346 - debug: tapo.0 (1635498) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                    2026-08-11 00:28:49.346 - debug: tapo.0 (1635498) refreshStok: sending start_seq request
                    2026-08-11 00:28:49.721 - debug: tapo.0 (1635498) refreshStok: start_seq response
                    2026-08-11 00:28:49.721 - debug: tapo.0 (1635498) refreshStok: start_seq=47392456 user_group=root stok=present
                    2026-08-11 00:28:49.721 - debug: tapo.0 (1635498) refreshStok: Success in obtaining STOK
                    2026-08-11 00:28:50.071 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:50.072 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                    2026-08-11 00:28:50.072 - info: tapo.0 (1635498) Reconnected to undefined
                    2026-08-11 00:28:50.072 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:50.481 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:50.481 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:28:50.591 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:50.950 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:50.950 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:28:50.980 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:51.401 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:51.416 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:28:51.416 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:51.416 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                    2026-08-11 00:28:51.783 - debug: tapo.0 (1635498) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"D4AF77AFA23CE6F1","device_confirm":"2E00701DC345289B8607409C2AD6662BD464446FC3902C8A51BBD97B7F006AF2D4AF77AFA23CE6F15C77BB7CBA33D043"}}}
                    2026-08-11 00:28:51.784 - debug: tapo.0 (1635498) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                    2026-08-11 00:28:51.784 - debug: tapo.0 (1635498) refreshStok: Refreshing stok...
                    2026-08-11 00:28:51.784 - debug: tapo.0 (1635498) refreshStok: isSecureConnection=true username=admin cnonce=FBFE19CE2B3F3A9E
                    2026-08-11 00:28:52.023 - debug: tapo.0 (1635498) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"7BEDFC1FCD571230","device_confirm":"D0E801F10120DC9B3D28637505ED41E7485F0F10B0C94E75319D9E1F538A53DE7BEDFC1FCD571230FBFE19CE2B3F3A9E"}}}
                    2026-08-11 00:28:52.023 - debug: tapo.0 (1635498) refreshStok: nonce=7BEDFC1FCD571230... deviceConfirm=D0E801F10120DC9B...
                    2026-08-11 00:28:52.024 - debug: tapo.0 (1635498) validateDeviceConfirm: matched candidate #1 via sha256
                    2026-08-11 00:28:52.024 - debug: tapo.0 (1635498) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                    2026-08-11 00:28:52.024 - debug: tapo.0 (1635498) refreshStok: sending start_seq request
                    2026-08-11 00:28:52.347 - debug: tapo.0 (1635498) refreshStok: start_seq response
                    2026-08-11 00:28:52.347 - debug: tapo.0 (1635498) refreshStok: start_seq=38021225 user_group=root stok=present
                    2026-08-11 00:28:52.347 - debug: tapo.0 (1635498) refreshStok: Success in obtaining STOK
                    2026-08-11 00:28:52.667 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:52.668 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:28:52.668 - info: tapo.0 (1635498) Reconnected to undefined
                    2026-08-11 00:28:52.668 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:52.963 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:52.963 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:28:53.021 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:53.288 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:53.288 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:28:53.440 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:53.801 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:53.829 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:28:53.829 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:53.829 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                    2026-08-11 00:28:54.133 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:28:54.134 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:54.381 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:54.381 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                    2026-08-11 00:28:54.381 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:54.594 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:54.594 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:28:54.598 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:54.817 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:54.817 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:28:54.837 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:55.047 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:55.058 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:28:55.058 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:55.314 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:55.314 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:28:55.314 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:55.633 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:55.633 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:28:55.636 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:55.954 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:55.954 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:28:56.006 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:56.269 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:56.278 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:28:56.278 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:56.727 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:56.727 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                    2026-08-11 00:28:56.727 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:57.073 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:57.074 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:28:57.077 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:57.436 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:57.436 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:28:57.453 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:57.744 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:57.753 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:28:57.754 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:58.040 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:58.041 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:28:58.041 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:58.322 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:58.322 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:28:58.326 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:58.602 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:58.603 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:28:58.621 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:28:58.881 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:28:58.888 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:28:58.888 - debug: tapo.0 (1635498) API request already pending
                    2026-08-11 00:28:59.293 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                    2026-08-11 00:28:59.294 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                    2026-08-11 00:28:59.294 - debug: tapo.0 (1635498) undefined
                    2026-08-11 00:28:59.294 - debug: tapo.0 (1635498) Update done
                    2026-08-11 00:29:04.133 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:04.134 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:04.365 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:04.365 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                    2026-08-11 00:29:04.366 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:04.585 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:04.585 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:04.588 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:04.813 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:04.813 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:04.839 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:05.035 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:05.045 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:05.045 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:05.286 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:05.286 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:29:05.286 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:05.560 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:05.560 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:05.564 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:05.827 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:05.827 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:05.848 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:06.089 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:06.106 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:06.106 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:06.472 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:06.472 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                    2026-08-11 00:29:06.473 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:06.913 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:06.913 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:06.916 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:07.236 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:07.236 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:07.261 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:07.635 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:07.642 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:07.642 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:07.884 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:07.884 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:29:07.884 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:08.175 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:08.176 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:08.179 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:08.443 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:08.443 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:08.459 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:08.724 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:08.732 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:08.732 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:08.732 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                    2026-08-11 00:29:14.129 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                    2026-08-11 00:29:14.129 - debug: tapo.0 (1635498) undefined
                    2026-08-11 00:29:14.129 - debug: tapo.0 (1635498) Update done
                    2026-08-11 00:29:14.133 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:14.133 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:14.474 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:14.474 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                    2026-08-11 00:29:14.474 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:14.695 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:14.695 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:14.699 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:14.938 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:14.938 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:14.957 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:15.155 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:15.164 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:15.164 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:15.408 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:15.409 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:29:15.409 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:15.650 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:15.650 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:15.654 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:15.926 - debug: tapo.0 (1635498) [C520WS 1.0] "Motion detected" true
                    2026-08-11 00:29:15.951 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:15.951 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:16.017 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:16.109 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:16.149 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:16.149 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:16.521 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:16.521 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                    2026-08-11 00:29:16.521 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:16.996 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:16.997 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:17.000 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:17.346 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:17.346 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:17.364 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:17.399 - debug: tapo.0 (1635498) [C520WS 1.0] "Motion detected" false
                    2026-08-11 00:29:17.710 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:17.718 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:17.718 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:18.003 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:18.004 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:29:18.004 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:18.266 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:18.266 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:18.269 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:18.546 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:18.546 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:18.565 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:18.825 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:18.835 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:18.835 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:18.835 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                    2026-08-11 00:29:21.899 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                    2026-08-11 00:29:21.899 - debug: tapo.0 (1635498) undefined
                    2026-08-11 00:29:21.906 - debug: tapo.0 (1635498) Update done
                    2026-08-11 00:29:24.134 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:24.134 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:24.371 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:24.371 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                    2026-08-11 00:29:24.371 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:24.598 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:24.598 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:24.649 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:24.842 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:24.842 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:24.861 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:25.069 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:25.078 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:25.079 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:25.358 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:25.358 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:29:25.359 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:25.630 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:25.630 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:25.635 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:25.920 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:25.921 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:25.938 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:26.237 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:26.248 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:26.248 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:26.673 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:26.673 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                    2026-08-11 00:29:26.673 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:27.079 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:27.079 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:27.083 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:27.421 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:27.421 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:27.443 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:27.756 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:27.764 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:27.764 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:28.052 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:28.052 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:29:28.052 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:28.302 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:28.302 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:28.306 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:28.617 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:28.617 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:28.673 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:28.897 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:28.908 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:28.908 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:28.908 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                    2026-08-11 00:29:34.135 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:34.135 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:34.169 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                    2026-08-11 00:29:34.170 - debug: tapo.0 (1635498) undefined
                    2026-08-11 00:29:34.170 - debug: tapo.0 (1635498) Update done
                    2026-08-11 00:29:34.366 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:34.367 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                    2026-08-11 00:29:34.367 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:34.581 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:34.581 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:34.585 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:34.802 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:34.802 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:34.825 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:35.035 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:35.046 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:35.046 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:35.325 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:35.326 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:29:35.326 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:35.554 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:35.555 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:35.839 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:36.077 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:36.078 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:36.157 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:36.438 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:36.448 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:36.449 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:37.341 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:37.342 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                    2026-08-11 00:29:37.342 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:37.705 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:37.705 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:37.711 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:38.186 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:38.186 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:38.209 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:38.590 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:38.604 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:38.604 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:38.919 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:38.919 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:29:38.919 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:39.225 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:39.225 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:39.232 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:39.553 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:39.554 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:39.575 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:39.860 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:39.878 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:39.879 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:39.879 - debug: tapo.0 (1635498) isSecureConnection: Checking secure connection...
                    2026-08-11 00:29:44.136 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:44.136 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:44.379 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:44.379 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                    2026-08-11 00:29:44.379 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:44.593 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:44.593 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:44.597 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:44.812 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:44.812 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:44.843 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:45.066 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:45.079 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:45.079 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:45.346 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:45.346 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                    2026-08-11 00:29:45.347 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:45.352 - debug: tapo.0 (1635498) Get camera Status failed: fetch failed
                    2026-08-11 00:29:45.352 - debug: tapo.0 (1635498) undefined
                    2026-08-11 00:29:45.352 - debug: tapo.0 (1635498) Update done
                    2026-08-11 00:29:45.627 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:45.627 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:45.674 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:45.945 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:45.945 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:45.968 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:46.274 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:46.286 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:46.286 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:46.473 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:46.958 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:46.958 - info: tapo.0 (1635498) moveToPreset was set to : Sabine for device 802114698B0C4DB803277811859F5C6723111712 was successful: false
                    2026-08-11 00:29:46.975 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:46.976 - debug: tapo.0 (1635498) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                    2026-08-11 00:29:46.976 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:47.340 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:47.340 - debug: tapo.0 (1635498) searchDetectionList raw: {}
                    2026-08-11 00:29:47.343 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:47.678 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:47.678 - debug: tapo.0 (1635498) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                    2026-08-11 00:29:47.697 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:48.003 - debug: tapo.0 (1635498) API response
                    2026-08-11 00:29:48.009 - debug: tapo.0 (1635498) Receive camera status
                    2026-08-11 00:29:48.010 - debug: tapo.0 (1635498) New API request
                    2026-08-11 00:29:48.309 - debug: tapo.0 (1635498) API response
                    Cam C530WS (IP 115) ist, warum auch immer im Moment offline, geht auch nicht über die App. Da kann ich erst tagsüber raufturnen und manuell neu starten.
                    Danke für deine Mühe, LG
                    T
                    T
                    tombox
                    #880
                    @metaxa ok sieht gut aus. nochmal GitHub installieren dann sollte es ok sein
                    • metaxaM
                      metaxaM
                      metaxa
                      #881
                      @tombox leider nein
                      DebugLog:
                      2026-08-11 20:43:51.049 - info: host.iOProduktiv "system.adapter.tapo.0" enabled
                      2026-08-11 20:43:51.612 - info: host.iOProduktiv instance system.adapter.tapo.0 in version "0.6.7" (non-npm: TA2k/ioBroker.tapo) started with pid 2730550
                      2026-08-11 20:43:53.066 - info: tapo.0 (2730550) starting. Version 0.6.7 (non-npm: TA2k/ioBroker.tapo) in /opt/iobroker/node_modules/iobroker.tapo, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 20:43:53.082 - info: tapo.0 (2730550) Login tp TAPO App
                      2026-08-11 20:43:53.468 - info: tapo.0 (2730550) Login succesfull
                      2026-08-11 20:43:53.720 - info: tapo.0 (2730550) Found 5 devices
                      2026-08-11 20:43:54.062 - info: tapo.0 (2730550) Init device 802114698B0C4DB803277811859F5C6723111712 type C200 5.0 with ip 192.168.0.114
                      2026-08-11 20:43:54.130 - info: tapo.0 (2730550) UDP discovery for 192.168.0.114: port=80 https=true encrypt=undefined lv=4 mac=B0-19-21-34-63-BA
                      2026-08-11 20:43:54.327 - info: tapo.0 (2730550) 802114698B0C4DB803277811859F5C6723111712 Received device info {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5}
                      2026-08-11 20:43:54.330 - info: tapo.0 (2730550) Initialized 802114698B0C4DB803277811859F5C6723111712
                      2026-08-11 20:43:54.607 - info: tapo.0 (2730550) Init device 8021314EFB57E17626EC16DBDB2A31A51E64292E type C310 2.0 with ip 192.168.0.113
                      2026-08-11 20:43:54.672 - info: tapo.0 (2730550) UDP discovery for 192.168.0.113: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-BD
                      2026-08-11 20:43:54.889 - info: tapo.0 (2730550) 8021314EFB57E17626EC16DBDB2A31A51E64292E Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2}
                      2026-08-11 20:43:54.890 - info: tapo.0 (2730550) Initialized 8021314EFB57E17626EC16DBDB2A31A51E64292E
                      2026-08-11 20:43:55.112 - info: tapo.0 (2730550) Init device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 type C530WS 2.0 with ip 192.168.0.115
                      2026-08-11 20:44:06.631 - info: admin.0 (664) ==> Connected system.user.admin from ::ffff:192.168.0.132
                      2026-08-11 20:44:08.267 - info: tapo.0 (2730550) Camera 802173FB22D1FB8B96E616F599FE462C24EBEDA7 device info unavailable (connect EHOSTUNREACH 192.168.0.115:2020). Continuing (battery/hub doorbells are not locally reachable).
                      2026-08-11 20:44:11.339 - info: tapo.0 (2730550) ONVIF port 2020 not reachable for 192.168.0.115. Enable ONVIF in the Tapo app under camera settings to use motion events.
                      2026-08-11 20:44:11.339 - info: tapo.0 (2730550) Initialized 802173FB22D1FB8B96E616F599FE462C24EBEDA7
                      2026-08-11 20:44:11.655 - info: tapo.0 (2730550) Init device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 type C310 2.0 with ip 192.168.0.110
                      2026-08-11 20:44:11.711 - info: tapo.0 (2730550) UDP discovery for 192.168.0.110: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-DD
                      2026-08-11 20:44:11.774 - info: tapo.0 (2730550) 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2}
                      2026-08-11 20:44:11.828 - info: tapo.0 (2730550) Initialized 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0
                      2026-08-11 20:44:12.105 - info: tapo.0 (2730550) Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.112
                      2026-08-11 20:44:12.176 - info: tapo.0 (2730550) UDP discovery for 192.168.0.112: port=80 https=true encrypt=undefined lv=3 mac=F0-A7-31-D8-7F-97
                      2026-08-11 20:44:12.658 - info: tapo.0 (2730550) 80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1}
                      2026-08-11 20:44:12.660 - info: tapo.0 (2730550) Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
                      2026-08-11 20:44:12.662 - info: tapo.0 (2730550) Wait for connections for non camera devices
                      2026-08-11 20:44:22.662 - info: tapo.0 (2730550) Start first Update
                      2026-08-11 20:44:25.756 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 20:44:28.628 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 20:44:35.934 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 20:44:38.699 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 20:44:48.456 - info: tapo.0 (2730550) moveToPreset was set to : Sabine for device 802114698B0C4DB803277811859F5C6723111712 was successful: false
                      2026-08-11 20:45:00.007 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2731506
                      2026-08-11 20:45:01.600 - info: ical.0 (2731506) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 20:45:02.078 - info: ical.0 (2731506) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics
                      2026-08-11 20:45:02.343 - info: ical.0 (2731506) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics
                      2026-08-11 20:45:02.352 - info: ical.0 (2731506) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics
                      2026-08-11 20:45:02.664 - info: ical.0 (2731506) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics
                      2026-08-11 20:45:07.571 - info: tapo.0 (2730550) moveToPreset was set to : Beet for device 802114698B0C4DB803277811859F5C6723111712 was successful: false
                      2026-08-11 20:45:07.754 - info: ical.0 (2731506) Terminated (NO_ERROR): Without reason
                      2026-08-11 20:45:08.307 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2731506 terminated with code 0 (NO_ERROR)
                      2026-08-11 20:45:27.693 - info: tapo.0 (2730550) moveToPreset was set to : Sabine for device 802114698B0C4DB803277811859F5C6723111712 was successful: false
                      2026-08-11 20:46:09.295 - info: tapo.0 (2730550) moveToPreset was set to : Pool for device 80219D887A52D32D03212C4C2DE37E4D21EC8028 was successful: false
                      2026-08-11 20:48:57.699 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0}
                      2026-08-11 20:51:16.007 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2736155
                      2026-08-11 20:51:17.068 - info: netatmo-crawler.0 (2736155) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 20:51:17.088 - info: netatmo-crawler.0 (2736155) Getting data for stationid:70:ee:50:05:f2:d4
                      2026-08-11 20:51:19.290 - info: netatmo-crawler.0 (2736155) Getting data for stationid:70:ee:50:90:ce:ea
                      2026-08-11 20:51:19.642 - info: netatmo-crawler.0 (2736155) Getting data for stationid:70:ee:50:2e:f6:c0
                      2026-08-11 20:51:20.079 - info: netatmo-crawler.0 (2736155) Getting data for stationid:70:ee:50:90:e4:da
                      2026-08-11 20:51:20.633 - info: netatmo-crawler.0 (2736155) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value')
                      2026-08-11 20:51:21.072 - info: netatmo-crawler.0 (2736155) Getting data for stationid:70:ee:50:01:13:24
                      2026-08-11 20:51:21.258 - info: netatmo-crawler.0 (2736155) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
                      2026-08-11 20:51:21.769 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2736155 terminated with code 0 (NO_ERROR)
                      2026-08-11 20:51:55.616 - info: tapo.0 (2730550) moveToPreset was set to : Terrasse for device 80219D887A52D32D03212C4C2DE37E4D21EC8028 was successful: false
                      2026-08-11 20:52:56.642 - info: web.1 (2112) <== Disconnect system.user.admin from ::ffff:192.168.0.97 iqontrol.0
                      2026-08-11 20:54:33.055 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 20:54:33.283 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 20:54:43.795 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 20:54:45.694 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 20:54:51.901 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 20:54:59.103 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 20:55:00.008 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2738456
                      2026-08-11 20:55:01.760 - info: ical.0 (2738456) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 20:55:02.270 - info: ical.0 (2738456) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics
                      2026-08-11 20:55:02.485 - info: ical.0 (2738456) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics
                      2026-08-11 20:55:02.558 - info: ical.0 (2738456) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics
                      2026-08-11 20:55:02.812 - info: ical.0 (2738456) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics
                      2026-08-11 20:55:07.935 - info: ical.0 (2738456) Terminated (NO_ERROR): Without reason
                      2026-08-11 20:55:08.450 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2738456 terminated with code 0 (NO_ERROR)
                      2026-08-11 20:55:38.783 - info: web.1 (2112) ==> Connected system.user.admin from ::ffff:192.168.0.97
                      2026-08-11 20:57:59.088 - info: daikin.0 (842) 4 Values updated: {"deviceInfo":0,"modelInfo":0,"control":2,"controlInfo":1,"sensorInfo":1,"demandControl":0}
                      2026-08-11 21:00:10.002 - info: javascript.0 (2499876) script.js.common.800-899_Energie.810_6_EPEX_Spot_Std_VIS: 22
                      2026-08-11 21:00:16.011 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2743063
                      2026-08-11 21:00:17.151 - info: netatmo-crawler.0 (2743063) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 21:00:17.173 - info: netatmo-crawler.0 (2743063) Getting data for stationid:70:ee:50:05:f2:d4
                      2026-08-11 21:00:25.537 - info: netatmo-crawler.0 (2743063) Getting data for stationid:70:ee:50:90:ce:ea
                      2026-08-11 21:00:28.286 - info: netatmo-crawler.0 (2743063) Getting data for stationid:70:ee:50:2e:f6:c0
                      2026-08-11 21:00:33.545 - info: netatmo-crawler.0 (2743063) Getting data for stationid:70:ee:50:90:e4:da
                      2026-08-11 21:00:39.658 - info: netatmo-crawler.0 (2743063) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value')
                      2026-08-11 21:00:42.104 - info: netatmo-crawler.0 (2743063) Getting data for stationid:70:ee:50:01:13:24
                      2026-08-11 21:00:43.307 - info: netatmo-crawler.0 (2743063) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
                      2026-08-11 21:00:43.818 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2743063 terminated with code 0 (NO_ERROR)
                      2026-08-11 21:00:59.510 - info: daikin.0 (842) 3 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":3,"demandControl":0}
                      2026-08-11 21:03:59.964 - info: daikin.0 (842) 2 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":2,"demandControl":0}
                      2026-08-11 21:04:53.059 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:04:53.381 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:05:00.006 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2746708
                      2026-08-11 21:05:01.637 - info: ical.0 (2746708) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 21:05:02.284 - info: ical.0 (2746708) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics
                      2026-08-11 21:05:02.439 - info: ical.0 (2746708) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics
                      2026-08-11 21:05:02.529 - info: ical.0 (2746708) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics
                      2026-08-11 21:05:02.973 - info: ical.0 (2746708) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics
                      2026-08-11 21:05:03.871 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:05:05.930 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:05:08.067 - info: ical.0 (2746708) Terminated (NO_ERROR): Without reason
                      2026-08-11 21:05:08.599 - warn: ical.0 (2746708) get state error: Connection is closed.
                      2026-08-11 21:05:08.621 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2746708 terminated with code 0 (NO_ERROR)
                      2026-08-11 21:05:12.513 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:05:21.435 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:07:00.376 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0}
                      2026-08-11 21:11:02.011 - info: web.1 (2112) <== Disconnect system.user.admin from ::ffff:192.168.0.97 iqontrol.0
                      2026-08-11 21:13:37.938 - info: web.1 (2112) ==> Connected system.user.admin from ::ffff:192.168.0.97
                      2026-08-11 21:15:00.005 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2754582
                      2026-08-11 21:15:01.605 - info: ical.0 (2754582) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 21:15:02.113 - info: ical.0 (2754582) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics
                      2026-08-11 21:15:02.331 - info: ical.0 (2754582) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics
                      2026-08-11 21:15:02.446 - info: ical.0 (2754582) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics
                      2026-08-11 21:15:02.678 - info: ical.0 (2754582) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics
                      2026-08-11 21:15:07.770 - info: ical.0 (2754582) Terminated (NO_ERROR): Without reason
                      2026-08-11 21:15:08.286 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2754582 terminated with code 0 (NO_ERROR)
                      2026-08-11 21:15:13.180 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:15:13.447 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:15:23.911 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:15:25.926 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:15:32.502 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:15:39.134 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:16:01.794 - info: daikin.0 (842) 2 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":2,"demandControl":0}
                      2026-08-11 21:17:16.008 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2756615
                      2026-08-11 21:17:17.099 - info: netatmo-crawler.0 (2756615) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 21:17:17.138 - info: netatmo-crawler.0 (2756615) Getting data for stationid:70:ee:50:05:f2:d4
                      2026-08-11 21:17:18.265 - info: netatmo-crawler.0 (2756615) Getting data for stationid:70:ee:50:90:ce:ea
                      2026-08-11 21:17:18.433 - info: netatmo-crawler.0 (2756615) Getting data for stationid:70:ee:50:2e:f6:c0
                      2026-08-11 21:17:19.537 - info: netatmo-crawler.0 (2756615) Getting data for stationid:70:ee:50:90:e4:da
                      2026-08-11 21:17:20.145 - info: netatmo-crawler.0 (2756615) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value')
                      2026-08-11 21:17:20.519 - info: netatmo-crawler.0 (2756615) Getting data for stationid:70:ee:50:01:13:24
                      2026-08-11 21:17:20.724 - info: netatmo-crawler.0 (2756615) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
                      2026-08-11 21:17:21.240 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2756615 terminated with code 0 (NO_ERROR)
                      2026-08-11 21:19:02.224 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0}
                      2026-08-11 21:22:02.616 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0}
                      2026-08-11 21:25:00.008 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2762187
                      2026-08-11 21:25:01.613 - info: ical.0 (2762187) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 21:25:02.117 - info: ical.0 (2762187) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics
                      2026-08-11 21:25:02.291 - info: ical.0 (2762187) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics
                      2026-08-11 21:25:02.393 - info: ical.0 (2762187) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics
                      2026-08-11 21:25:02.633 - info: ical.0 (2762187) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics
                      2026-08-11 21:25:07.740 - info: ical.0 (2762187) Terminated (NO_ERROR): Without reason
                      2026-08-11 21:25:08.254 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2762187 terminated with code 0 (NO_ERROR)
                      2026-08-11 21:25:33.089 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:25:33.327 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:25:43.897 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:25:45.976 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:25:52.701 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:25:59.416 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:26:54.595 - info: javascript.0 (2499876) script.js.common.000-050_System.001_HM_Servicemeldungen_04_2021: Neue Servicemeldung: Thermostat Küche (GEQ0162204) --- HM-CC-TC--- Typ: CONFIG_PENDING_ALARM --- Status: 1 Konfigurationsdaten stehen zur Übertragung an
                      2026-08-11 21:26:58.281 - info: javascript.0 (2499876) script.js.common.000-050_System.001_2_HM_Servicmeldungen_neu_2025: Zeitverbrauch fuer Routine Check_All: 3 Millisekunden Routine:Check_All
                      2026-08-11 21:28:04.341 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0}
                      2026-08-11 21:28:57.037 - info: web.1 (2112) <== Disconnect system.user.admin from ::ffff:192.168.0.97 iqontrol.0
                      2026-08-11 21:29:24.536 - info: javascript.0 (2499876) script.js.common.000-050_System.001_HM_Servicemeldungen_04_2021: Servicemeldung aufgehoben: Thermostat Küche (GEQ0162204) --- HM-CC-TC--- Typ: CONFIG_PENDING_ALARM --- Status: 2 Konfigurationsdaten standen zur Übertragung an
                      2026-08-11 21:29:28.280 - info: javascript.0 (2499876) script.js.common.000-050_System.001_2_HM_Servicmeldungen_neu_2025: Zeitverbrauch fuer Routine Check_All: 1 Millisekunden Routine:Check_All
                      2026-08-11 21:30:00.026 - info: javascript.0 (2499876) script.js.common.800-899_Energie.810_1_EPEX_Spot_morgen_aktualisieren: Strompreise erfolgreich importiert
                      2026-08-11 21:31:07.558 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0}
                      2026-08-11 21:31:33.775 - info: tapo.0 (2730550) moveToPreset was set to : Terrasse for device 80219D887A52D32D03212C4C2DE37E4D21EC8028 was successful: false
                      2026-08-11 21:31:35.564 - info: web.1 (2112) ==> Connected system.user.admin from ::ffff:192.168.0.97
                      2026-08-11 21:34:08.280 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0}
                      2026-08-11 21:34:16.005 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2769473
                      2026-08-11 21:34:17.163 - info: netatmo-crawler.0 (2769473) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 21:34:17.224 - info: netatmo-crawler.0 (2769473) Getting data for stationid:70:ee:50:05:f2:d4
                      2026-08-11 21:34:18.225 - info: netatmo-crawler.0 (2769473) Getting data for stationid:70:ee:50:90:ce:ea
                      2026-08-11 21:34:18.778 - info: netatmo-crawler.0 (2769473) Getting data for stationid:70:ee:50:2e:f6:c0
                      2026-08-11 21:34:18.998 - info: netatmo-crawler.0 (2769473) Getting data for stationid:70:ee:50:90:e4:da
                      2026-08-11 21:34:20.255 - info: netatmo-crawler.0 (2769473) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value')
                      2026-08-11 21:34:20.753 - info: netatmo-crawler.0 (2769473) Getting data for stationid:70:ee:50:01:13:24
                      2026-08-11 21:34:21.455 - info: netatmo-crawler.0 (2769473) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
                      2026-08-11 21:34:21.973 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2769473 terminated with code 0 (NO_ERROR)
                      2026-08-11 21:35:00.011 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2769831
                      2026-08-11 21:35:01.798 - info: ical.0 (2769831) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 21:35:02.274 - info: ical.0 (2769831) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics
                      2026-08-11 21:35:02.484 - info: ical.0 (2769831) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics
                      2026-08-11 21:35:02.751 - info: ical.0 (2769831) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics
                      2026-08-11 21:35:02.862 - info: ical.0 (2769831) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics
                      2026-08-11 21:35:07.943 - info: ical.0 (2769831) Terminated (NO_ERROR): Without reason
                      2026-08-11 21:35:08.459 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2769831 terminated with code 0 (NO_ERROR)
                      2026-08-11 21:35:53.134 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:35:53.435 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:36:04.088 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:36:06.352 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:36:11.999 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:36:22.199 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:43:10.955 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0}
                      2026-08-11 21:45:00.009 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2777706
                      2026-08-11 21:45:01.696 - info: ical.0 (2777706) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 21:45:02.251 - info: ical.0 (2777706) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics
                      2026-08-11 21:45:02.441 - info: ical.0 (2777706) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics
                      2026-08-11 21:45:02.520 - info: ical.0 (2777706) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics
                      2026-08-11 21:45:02.787 - info: ical.0 (2777706) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics
                      2026-08-11 21:45:07.870 - info: ical.0 (2777706) Terminated (NO_ERROR): Without reason
                      2026-08-11 21:45:08.385 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2777706 terminated with code 0 (NO_ERROR)
                      2026-08-11 21:46:13.150 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:46:13.436 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:46:24.014 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:46:26.179 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:46:32.699 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:46:41.498 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:46:54.435 - info: web.1 (2112) <== Disconnect system.user.admin from ::ffff:192.168.0.97 iqontrol.0
                      2026-08-11 21:49:37.116 - info: web.1 (2112) ==> Connected system.user.admin from ::ffff:192.168.0.97
                      2026-08-11 21:51:16.014 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2782683
                      2026-08-11 21:51:17.119 - info: netatmo-crawler.0 (2782683) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 21:51:17.181 - info: netatmo-crawler.0 (2782683) Getting data for stationid:70:ee:50:05:f2:d4
                      2026-08-11 21:51:24.537 - info: netatmo-crawler.0 (2782683) Getting data for stationid:70:ee:50:90:ce:ea
                      2026-08-11 21:51:26.548 - info: netatmo-crawler.0 (2782683) Getting data for stationid:70:ee:50:2e:f6:c0
                      2026-08-11 21:51:27.798 - info: netatmo-crawler.0 (2782683) Getting data for stationid:70:ee:50:90:e4:da
                      2026-08-11 21:51:28.551 - info: netatmo-crawler.0 (2782683) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value')
                      2026-08-11 21:51:28.948 - info: netatmo-crawler.0 (2782683) Getting data for stationid:70:ee:50:01:13:24
                      2026-08-11 21:51:30.281 - info: netatmo-crawler.0 (2782683) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
                      2026-08-11 21:51:30.794 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2782683 terminated with code 0 (NO_ERROR)
                      2026-08-11 21:52:13.917 - info: daikin.0 (842) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":1,"demandControl":0}
                      2026-08-11 21:55:00.008 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2785639
                      2026-08-11 21:55:01.631 - info: ical.0 (2785639) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 21:55:02.145 - info: ical.0 (2785639) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics
                      2026-08-11 21:55:02.292 - info: ical.0 (2785639) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics
                      2026-08-11 21:55:02.406 - info: ical.0 (2785639) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics
                      2026-08-11 21:55:02.634 - info: ical.0 (2785639) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics
                      2026-08-11 21:55:07.718 - info: ical.0 (2785639) Terminated (NO_ERROR): Without reason
                      2026-08-11 21:55:08.232 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2785639 terminated with code 0 (NO_ERROR)
                      2026-08-11 21:56:33.174 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:56:33.444 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:56:44.062 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:56:46.193 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 21:56:52.514 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 21:56:59.589 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 22:00:10.002 - info: javascript.0 (2499876) script.js.common.800-899_Energie.810_6_EPEX_Spot_Std_VIS: 23
                      2026-08-11 22:00:16.013 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2789293
                      2026-08-11 22:00:17.075 - info: netatmo-crawler.0 (2789293) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 22:00:17.140 - info: netatmo-crawler.0 (2789293) Getting data for stationid:70:ee:50:05:f2:d4
                      2026-08-11 22:00:18.980 - info: netatmo-crawler.0 (2789293) Getting data for stationid:70:ee:50:90:ce:ea
                      2026-08-11 22:00:21.856 - info: netatmo-crawler.0 (2789293) Getting data for stationid:70:ee:50:2e:f6:c0
                      2026-08-11 22:00:22.209 - info: netatmo-crawler.0 (2789293) Getting data for stationid:70:ee:50:90:e4:da
                      2026-08-11 22:00:25.878 - info: netatmo-crawler.0 (2789293) Could not get Rain Today for station 70:ee:50:90:e4:da: TypeError: Cannot read properties of undefined (reading 'value')
                      2026-08-11 22:00:26.285 - info: netatmo-crawler.0 (2789293) Getting data for stationid:70:ee:50:01:13:24
                      2026-08-11 22:00:30.455 - info: netatmo-crawler.0 (2789293) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
                      2026-08-11 22:00:30.966 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 having pid 2789293 terminated with code 0 (NO_ERROR)
                      2026-08-11 22:04:53.241 - info: web.1 (2112) <== Disconnect system.user.admin from ::ffff:192.168.0.97 iqontrol.0
                      2026-08-11 22:05:00.005 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2793194
                      2026-08-11 22:05:01.593 - info: ical.0 (2793194) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 22:05:02.042 - info: ical.0 (2793194) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics
                      2026-08-11 22:05:02.261 - info: ical.0 (2793194) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics
                      2026-08-11 22:05:02.271 - info: ical.0 (2793194) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics
                      2026-08-11 22:05:02.613 - info: ical.0 (2793194) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics
                      2026-08-11 22:05:07.698 - info: ical.0 (2793194) Terminated (NO_ERROR): Without reason
                      2026-08-11 22:05:08.215 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2793194 terminated with code 0 (NO_ERROR)
                      2026-08-11 22:06:53.236 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 22:06:53.515 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 22:07:04.096 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 22:07:06.316 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 22:07:12.733 - info: tapo.0 (2730550) Connection lost to undefined
                      2026-08-11 22:07:22.500 - info: tapo.0 (2730550) Reconnected to undefined
                      2026-08-11 22:07:32.239 - info: web.1 (2112) ==> Connected system.user.admin from ::ffff:192.168.0.97
                      2026-08-11 22:15:00.007 - info: host.iOProduktiv instance system.adapter.ical.0 in version "1.21.0" started with pid 2800300
                      2026-08-11 22:15:01.643 - info: ical.0 (2800300) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 22:15:02.151 - info: ical.0 (2800300) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics
                      2026-08-11 22:15:02.297 - info: ical.0 (2800300) processing URL: Geburtstage Cech https://calendar.google.com/calendar/ical/hd4b3rtin1f1qsvjbg64eg1jhc%40group.calendar.google.com/private-712abecefef0c24fe5521b59d2aade04/basic.ics
                      2026-08-11 22:15:02.532 - info: ical.0 (2800300) processing URL: Muell https://calendar.google.com/calendar/ical/tqloimait9lkmlutadl0t27a9s%40group.calendar.google.com/private-289a3b0f58d98779693d103d163962a1/basic.ics
                      2026-08-11 22:15:02.704 - info: ical.0 (2800300) processing URL: SonneMitHaus https://calendar.google.com/calendar/ical/sonnemithaus%40gmail.com/private-2575f3ee698831cfae2a0b7b1c348855/basic.ics
                      2026-08-11 22:15:07.791 - info: ical.0 (2800300) Terminated (NO_ERROR): Without reason
                      2026-08-11 22:15:08.305 - info: host.iOProduktiv instance system.adapter.ical.0 having pid 2800300 terminated with code 0 (NO_ERROR)
                      2026-08-11 22:15:40.633 - info: host.iOProduktiv "system.adapter.tapo.0" disabled
                      2026-08-11 22:15:40.633 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 (force=false, process=true)
                      2026-08-11 22:15:40.636 - info: tapo.0 (2730550) Got terminate signal TERMINATE_YOURSELF
                      2026-08-11 22:15:40.636 - info: tapo.0 (2730550) terminating
                      2026-08-11 22:15:40.636 - info: tapo.0 (2730550) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2026-08-11 22:15:40.716 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 send kill signal
                      2026-08-11 22:15:41.137 - info: tapo.0 (2730550) terminating
                      2026-08-11 22:15:41.279 - info: host.iOProduktiv instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2026-08-11 22:16:12.758 - info: admin.0 (664) ==> Connected system.user.admin from ::ffff:192.168.0.132
                      2026-08-11 22:16:33.890 - info: host.iOProduktiv "system.adapter.tapo.0" enabled
                      2026-08-11 22:16:34.925 - info: host.iOProduktiv instance system.adapter.tapo.0 in version "0.6.7" (non-npm: TA2k/ioBroker.tapo) started with pid 2801788
                      2026-08-11 22:16:35.772 - debug: tapo.0 (2801788) Redis Objects: Use Redis connection: 0.0.0.0:9001
                      2026-08-11 22:16:35.817 - debug: tapo.0 (2801788) Objects client ready ... initialize now
                      2026-08-11 22:16:35.817 - debug: tapo.0 (2801788) Objects create System PubSub Client
                      2026-08-11 22:16:35.818 - debug: tapo.0 (2801788) Objects create User PubSub Client
                      2026-08-11 22:16:35.947 - debug: tapo.0 (2801788) Objects client initialize lua scripts
                      2026-08-11 22:16:35.953 - debug: tapo.0 (2801788) Objects connected to redis: 0.0.0.0:9001
                      2026-08-11 22:16:36.020 - debug: tapo.0 (2801788) Redis States: Use Redis connection: 0.0.0.0:9000
                      2026-08-11 22:16:36.115 - debug: tapo.0 (2801788) States create System PubSub Client
                      2026-08-11 22:16:36.115 - debug: tapo.0 (2801788) States create User PubSub Client
                      2026-08-11 22:16:36.243 - debug: tapo.0 (2801788) States connected to redis: 0.0.0.0:9000
                      2026-08-11 22:16:36.388 - info: tapo.0 (2801788) starting. Version 0.6.7 (non-npm: TA2k/ioBroker.tapo) in /opt/iobroker/node_modules/iobroker.tapo, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 22:16:36.408 - info: tapo.0 (2801788) Login tp TAPO App
                      2026-08-11 22:16:36.453 - debug: tapo.0 (2801788) xaYE4SMWpkdB/E8dxzgSWA==
                      2026-08-11 22:16:36.749 - debug: tapo.0 (2801788) {"error_code":0,"result":{"accountApiUrl":"https://euw1-account-api.i.tplinkcloud.com","lockedMinutes":0,"appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"38ee8e2b-BTzbC0DcrEtEfMVYIT6h2p0","accountId":"37806770","regionCode":"AT","regTime":"2021-06-23 14:33:54","nickname":"mxa","email":"mxa@gmx.at","appServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com","refreshToken":"38ee8e2b-BTQsPoCVASGPAYEwdb5gnGd"}}
                      2026-08-11 22:16:36.749 - info: tapo.0 (2801788) Login succesfull
                      2026-08-11 22:16:36.750 - debug: tapo.0 (2801788) 3tJNSNko5EAYJ06dPx9ulA==
                      2026-08-11 22:16:36.985 - debug: tapo.0 (2801788) {"error_code":0,"result":{"totalNum":5,"deviceList":[{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0","deviceName":"C310 2.0","lastBindTime":1784968460316,"deviceHwVer":"2.0","alias":"Postkasten","deviceMac":"005F67798FDD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.4 Build 250811 Rel.34127n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80219D887A52D32D03212C4C2DE37E4D21EC8028","deviceName":"C520WS 1.0","lastBindTime":1705169151588,"deviceHwVer":"1.0","alias":"Terrasse","deviceMac":"F0A731D87F97","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","deviceModel":"C520WS","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.4.4 Build 260527 Rel.28339n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802114698B0C4DB803277811859F5C6723111712","deviceName":"C200 5.0","lastBindTime":1785313977891,"deviceHwVer":"5.0","alias":"Beet","deviceMac":"B019213463BA","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","deviceModel":"C200","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.9.2 Build 260519 Rel.13997n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021314EFB57E17626EC16DBDB2A31A51E64292E","deviceName":"C310 2.0","lastBindTime":1632395306454,"deviceHwVer":"2.0","alias":"Haus Eingang vorne","deviceMac":"005F67798FBD","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0},{"deviceType":"SMART.IPCAMERA","accountApiUrl":"http://euw1-account-api-internal.tplinkcloud.com","role":0,"fwVer":"1.3.5 Build 260323 Rel.35521n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802173FB22D1FB8B96E616F599FE462C24EBEDA7","deviceName":"C530WS 2.0","lastBindTime":1782991868008,"deviceHwVer":"2.0","alias":"Einfahrt","deviceMac":"6C4CBC025F2C","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","deviceModel":"C530WS","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","isSameRegion":true,"appServerUrlV2":"https://n-euw1-wap-gw.i.tplinkcloud.com","status":0}],"currentIndex":4}}
                      2026-08-11 22:16:36.986 - info: tapo.0 (2801788) Found 5 devices
                      2026-08-11 22:16:36.986 - debug: tapo.0 (2801788) Found device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Postkasten
                      2026-08-11 22:16:37.491 - debug: tapo.0 (2801788) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"","mac":"005F67798FDD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.110","onboardingTime":1784968460,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                      2026-08-11 22:16:37.492 - info: tapo.0 (2801788) Init device 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 type C310 2.0 with ip 192.168.0.110
                      2026-08-11 22:16:37.492 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.110 on port 20002
                      2026-08-11 22:16:37.623 - info: tapo.0 (2801788) UDP discovery for 192.168.0.110: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-DD
                      2026-08-11 22:16:37.687 - info: tapo.0 (2801788) 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2}
                      2026-08-11 22:16:37.687 - debug: tapo.0 (2801788) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fdd","hardwareId":2}
                      2026-08-11 22:16:37.688 - debug: tapo.0 (2801788) Init event emitter for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0
                      2026-08-11 22:16:37.692 - debug: tapo.0 (2801788) Init event listener for "motion"
                      2026-08-11 22:16:37.693 - info: tapo.0 (2801788) Initialized 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0
                      2026-08-11 22:16:37.694 - debug: tapo.0 (2801788) initResult camera 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 undefined
                      2026-08-11 22:16:37.694 - debug: tapo.0 (2801788) Found device 80219D887A52D32D03212C4C2DE37E4D21EC8028 M��j�
                      2026-08-11 22:16:37.961 - debug: tapo.0 (2801788) {"hwVer":"1.0","category":"camera","model":"C520WS 1.0","ssid":"","mac":"F0A731D87F97","hwId":"69DCA23B0900A3B5524562A53D305CE1","fwId":"B27AD88F3666720417FB80C122382FBB","oemId":"E8FEA9BA6819C38AC33B5E4ABA8F592B","fwVer":"1.3.4 Build 250811 Rel.34127n","ip":"192.168.0.112","onboardingTime":1705169153,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                      2026-08-11 22:16:37.961 - info: tapo.0 (2801788) Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.112
                      2026-08-11 22:16:37.961 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.112 on port 20002
                      2026-08-11 22:16:38.014 - info: tapo.0 (2801788) UDP discovery for 192.168.0.112: port=80 https=true encrypt=undefined lv=3 mac=F0-A7-31-D8-7F-97
                      2026-08-11 22:16:38.474 - info: tapo.0 (2801788) 80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1}
                      2026-08-11 22:16:38.475 - debug: tapo.0 (2801788) {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.3.4 Build 250811 Rel.34127n","serialNumber":"74617f97","hardwareId":1}
                      2026-08-11 22:16:38.475 - debug: tapo.0 (2801788) Init event emitter for 80219D887A52D32D03212C4C2DE37E4D21EC8028
                      2026-08-11 22:16:38.478 - debug: tapo.0 (2801788) Init event listener for "motion"
                      2026-08-11 22:16:38.478 - info: tapo.0 (2801788) Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
                      2026-08-11 22:16:38.478 - debug: tapo.0 (2801788) initResult camera 80219D887A52D32D03212C4C2DE37E4D21EC8028 undefined
                      2026-08-11 22:16:38.479 - debug: tapo.0 (2801788) Found device 802114698B0C4DB803277811859F5C6723111712 �
                      2026-08-11 22:16:38.777 - debug: tapo.0 (2801788) {"hwVer":"5.0","category":"camera","model":"C200 5.0","ssid":"videosun","mac":"B019213463BA","hwId":"01C6C3DBADBB4123DA27732B1953F196","fwId":"D97388D4F5F21B256BC4338513D9C9FE","oemId":"FB037E466EE0FEB5F7EB7BA0293CB622","fwVer":"1.4.4 Build 260527 Rel.28339n","ip":"192.168.0.114","onboardingTime":1785313979,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                      2026-08-11 22:16:38.777 - info: tapo.0 (2801788) Init device 802114698B0C4DB803277811859F5C6723111712 type C200 5.0 with ip 192.168.0.114
                      2026-08-11 22:16:38.777 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.114 on port 20002
                      2026-08-11 22:16:38.878 - info: tapo.0 (2801788) UDP discovery for 192.168.0.114: port=80 https=true encrypt=undefined lv=4 mac=B0-19-21-34-63-BA
                      2026-08-11 22:16:39.231 - info: tapo.0 (2801788) 802114698B0C4DB803277811859F5C6723111712 Received device info {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5}
                      2026-08-11 22:16:39.231 - debug: tapo.0 (2801788) {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.4.4 Build 260527 Rel.28339n","serialNumber":"746163ba","hardwareId":5}
                      2026-08-11 22:16:39.232 - debug: tapo.0 (2801788) Init event emitter for 802114698B0C4DB803277811859F5C6723111712
                      2026-08-11 22:16:39.234 - debug: tapo.0 (2801788) Init event listener for "motion"
                      2026-08-11 22:16:39.234 - info: tapo.0 (2801788) Initialized 802114698B0C4DB803277811859F5C6723111712
                      2026-08-11 22:16:39.234 - debug: tapo.0 (2801788) initResult camera 802114698B0C4DB803277811859F5C6723111712 undefined
                      2026-08-11 22:16:39.234 - debug: tapo.0 (2801788) Found device 8021314EFB57E17626EC16DBDB2A31A51E64292E Haus Eingang vorne
                      2026-08-11 22:16:39.565 - debug: tapo.0 (2801788) {"hwVer":"2.0","category":"camera","model":"C310 2.0","ssid":"Sun 2.4","mac":"005F67798FBD","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"15BBE6F7E311508D84928C810DC35188","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.9.2 Build 260519 Rel.13997n","ip":"192.168.0.113","onboardingTime":0,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                      2026-08-11 22:16:39.565 - info: tapo.0 (2801788) Init device 8021314EFB57E17626EC16DBDB2A31A51E64292E type C310 2.0 with ip 192.168.0.113
                      2026-08-11 22:16:39.565 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.113 on port 20002
                      2026-08-11 22:16:39.625 - info: tapo.0 (2801788) UDP discovery for 192.168.0.113: port=80 https=true encrypt=undefined lv=4 mac=00-5F-67-79-8F-BD
                      2026-08-11 22:16:39.909 - info: tapo.0 (2801788) 8021314EFB57E17626EC16DBDB2A31A51E64292E Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2}
                      2026-08-11 22:16:39.909 - debug: tapo.0 (2801788) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.9.2 Build 260519 Rel.13997n","serialNumber":"74618fbd","hardwareId":2}
                      2026-08-11 22:16:39.909 - debug: tapo.0 (2801788) Init event emitter for 8021314EFB57E17626EC16DBDB2A31A51E64292E
                      2026-08-11 22:16:39.914 - debug: tapo.0 (2801788) Init event listener for "motion"
                      2026-08-11 22:16:39.914 - info: tapo.0 (2801788) Initialized 8021314EFB57E17626EC16DBDB2A31A51E64292E
                      2026-08-11 22:16:39.914 - debug: tapo.0 (2801788) initResult camera 8021314EFB57E17626EC16DBDB2A31A51E64292E undefined
                      2026-08-11 22:16:39.914 - debug: tapo.0 (2801788) Found device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 )�j�
                      2026-08-11 22:16:40.202 - debug: tapo.0 (2801788) {"hwVer":"2.0","category":"camera","model":"C530WS 2.0","ssid":"","mac":"6C4CBC025F2C","hwId":"4592DB83AA4AC1D90E84E13FA4032A50","fwId":"81C99E2409075FD8EBB827CCAED55129","oemId":"B44ACA91AA10BE60C86AC1CA494AB394","fwVer":"1.3.5 Build 260323 Rel.35521n","ip":"192.168.0.115","onboardingTime":1782991869,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com","pcAppServerUrlV2":"https://n-euw1-wap.i.tplinkcloud.com"}
                      2026-08-11 22:16:40.202 - info: tapo.0 (2801788) Init device 802173FB22D1FB8B96E616F599FE462C24EBEDA7 type C530WS 2.0 with ip 192.168.0.115
                      2026-08-11 22:16:40.202 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.115 on port 20002
                      2026-08-11 22:16:43.202 - debug: tapo.0 (2801788) UDP discovery for 192.168.0.115: no response (will use default port 80)
                      2026-08-11 22:16:53.452 - info: tapo.0 (2801788) Camera 802173FB22D1FB8B96E616F599FE462C24EBEDA7 device info unavailable (connect EHOSTUNREACH 192.168.0.115:2020). Continuing (battery/hub doorbells are not locally reachable).
                      2026-08-11 22:16:53.452 - debug: tapo.0 (2801788) Init event emitter for 802173FB22D1FB8B96E616F599FE462C24EBEDA7
                      2026-08-11 22:16:56.523 - info: tapo.0 (2801788) ONVIF port 2020 not reachable for 192.168.0.115. Enable ONVIF in the Tapo app under camera settings to use motion events.
                      2026-08-11 22:16:56.523 - info: tapo.0 (2801788) Initialized 802173FB22D1FB8B96E616F599FE462C24EBEDA7
                      2026-08-11 22:16:56.523 - debug: tapo.0 (2801788) initResult camera 802173FB22D1FB8B96E616F599FE462C24EBEDA7 undefined
                      2026-08-11 22:16:56.526 - info: tapo.0 (2801788) Wait for connections for non camera devices
                      2026-08-11 22:17:06.204 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:06.204 - debug: tapo.0 (2801788) isSecureConnection: Checking secure connection...
                      2026-08-11 22:17:06.524 - debug: tapo.0 (2801788) isSecureConnection response status=200 data={"result":{"data":{"code":-40401,"time":9,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"B7738EE72E2FB59B","device_confirm":"7D409664A4EF44787D7751BFFB72D14CEC36E0AAB7C04484A3ACE16BB97B202EB7738EE72E2FB59B5B1099EB805EC3D9"}},"error_code":-40413}
                      2026-08-11 22:17:06.524 - debug: tapo.0 (2801788) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                      2026-08-11 22:17:06.525 - debug: tapo.0 (2801788) refreshStok: Refreshing stok...
                      2026-08-11 22:17:06.525 - debug: tapo.0 (2801788) refreshStok: isSecureConnection=true username=admin cnonce=4899BBB77DCC7277
                      2026-08-11 22:17:06.529 - info: tapo.0 (2801788) Start first Update
                      2026-08-11 22:17:06.529 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:06.530 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:06.530 - debug: tapo.0 (2801788) isSecureConnection: Checking secure connection...
                      2026-08-11 22:17:06.710 - debug: tapo.0 (2801788) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"B648B02C8FBAA0AD","device_confirm":"49AEE82480ECAFD44EA9164A9C45BFB6EAEF5605B8174D70310979A4DFC6E99AB648B02C8FBAA0ADEFB4B4484F877200"}}}
                      2026-08-11 22:17:06.710 - debug: tapo.0 (2801788) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                      2026-08-11 22:17:06.710 - debug: tapo.0 (2801788) refreshStok: Refreshing stok...
                      2026-08-11 22:17:06.711 - debug: tapo.0 (2801788) refreshStok: isSecureConnection=true username=admin cnonce=8738F327933DC1E9
                      2026-08-11 22:17:06.807 - debug: tapo.0 (2801788) refreshStok: Login response status=200 data={"result":{"data":{"code":-40401,"time":8,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAL9Vt+Sa1P/+1YuPsdM3DJWYXIKprrCbvYUtgeqsg5kYCU/Z/kMAWH/v59wrCw83Gtd7A8TiRZGutHXWXRmGq2sCAwEAAQ==","nonce":"EF4AAE02BF4F4C05","device_confirm":"F8672F1EF8664548C229634CB5FCAE6D419BFF07357241D1875D774284512226EF4AAE02BF4F4C054899BBB77DCC7277"}},"error_code":-40413}
                      2026-08-11 22:17:06.807 - debug: tapo.0 (2801788) refreshStok: nonce=EF4AAE02BF4F4C05... deviceConfirm=F8672F1EF8664548...
                      2026-08-11 22:17:06.807 - debug: tapo.0 (2801788) validateDeviceConfirm: matched candidate #1 via sha256
                      2026-08-11 22:17:06.807 - debug: tapo.0 (2801788) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                      2026-08-11 22:17:06.807 - debug: tapo.0 (2801788) refreshStok: sending start_seq request
                      2026-08-11 22:17:06.926 - debug: tapo.0 (2801788) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAMOmJmypcfZ1bsdiOpXxBAIFyXPPxXBA28QqVybU87kkk7nhVw3Z5MCGDGZ5WOr0hJAKVGdZgDgwat2eNVzuY6UCAwEAAQ==","nonce":"9635A1EF7E960BE1","device_confirm":"E4187BE06E88CF0E2E000A85F93687A78257A9778F91AB098BE9CE73B1ADF6969635A1EF7E960BE18738F327933DC1E9"}}}
                      2026-08-11 22:17:06.926 - debug: tapo.0 (2801788) refreshStok: nonce=9635A1EF7E960BE1... deviceConfirm=E4187BE06E88CF0E...
                      2026-08-11 22:17:06.926 - debug: tapo.0 (2801788) validateDeviceConfirm: matched candidate #1 via sha256
                      2026-08-11 22:17:06.926 - debug: tapo.0 (2801788) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                      2026-08-11 22:17:06.926 - debug: tapo.0 (2801788) refreshStok: sending start_seq request
                      2026-08-11 22:17:07.027 - debug: tapo.0 (2801788) refreshStok: start_seq response
                      2026-08-11 22:17:07.027 - debug: tapo.0 (2801788) refreshStok: start_seq=476 user_group=root stok=present
                      2026-08-11 22:17:07.027 - debug: tapo.0 (2801788) refreshStok: Success in obtaining STOK
                      2026-08-11 22:17:07.127 - debug: tapo.0 (2801788) refreshStok: start_seq response
                      2026-08-11 22:17:07.127 - debug: tapo.0 (2801788) refreshStok: start_seq=96210518 user_group=root stok=present
                      2026-08-11 22:17:07.127 - debug: tapo.0 (2801788) refreshStok: Success in obtaining STOK
                      2026-08-11 22:17:07.314 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:07.314 - info: tapo.0 (2801788) moveToPreset was set to : Terrasse for device 80219D887A52D32D03212C4C2DE37E4D21EC8028 was successful: false
                      2026-08-11 22:17:07.465 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:07.465 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                      2026-08-11 22:17:07.465 - info: tapo.0 (2801788) Reconnected to undefined
                      2026-08-11 22:17:07.465 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:07.683 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:07.683 - debug: tapo.0 (2801788) searchDetectionList raw: {}
                      2026-08-11 22:17:07.784 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:07.980 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:07.980 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                      2026-08-11 22:17:08.301 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:08.513 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:08.535 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:08.535 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:08.875 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:08.875 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                      2026-08-11 22:17:08.875 - info: tapo.0 (2801788) Reconnected to undefined
                      2026-08-11 22:17:08.875 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:09.206 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:09.206 - debug: tapo.0 (2801788) searchDetectionList raw: {}
                      2026-08-11 22:17:09.314 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:09.315 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:09.364 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:09.604 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:09.605 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                      2026-08-11 22:17:09.722 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:09.723 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                      2026-08-11 22:17:09.723 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:09.938 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:09.938 - debug: tapo.0 (2801788) searchDetectionList raw: {}
                      2026-08-11 22:17:09.949 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:09.996 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:10.150 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:10.150 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                      2026-08-11 22:17:10.171 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:10.295 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:10.315 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:10.315 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:10.315 - debug: tapo.0 (2801788) isSecureConnection: Checking secure connection...
                      2026-08-11 22:17:10.381 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:10.388 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:10.388 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:10.641 - debug: tapo.0 (2801788) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"2FAFBFED5C8B54B6","device_confirm":"907C6AE839829304B93CD128781343F82D3D5426EBD2D180255108F34E51625A2FAFBFED5C8B54B6E2A185D2F8527D28"}}}
                      2026-08-11 22:17:10.641 - debug: tapo.0 (2801788) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                      2026-08-11 22:17:10.641 - debug: tapo.0 (2801788) refreshStok: Refreshing stok...
                      2026-08-11 22:17:10.642 - debug: tapo.0 (2801788) refreshStok: isSecureConnection=true username=admin cnonce=072CCDD98547C673
                      2026-08-11 22:17:10.675 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:10.675 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                      2026-08-11 22:17:10.675 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:10.949 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:10.949 - debug: tapo.0 (2801788) searchDetectionList raw: {}
                      2026-08-11 22:17:10.952 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:11.121 - debug: tapo.0 (2801788) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBAK6RahuVNHZCRFTZxVxDTmTQe99H3QZPnMv6Dg8b3ug6e5gtuW7vbGMpBCyZGcCvIv6ZXpaJiuiOy09VwkMY7McCAwEAAQ==","nonce":"A284ADE22178AD11","device_confirm":"C64A7FCB68CFD3E3766132395254E3993A9D4899F7B3D7026A29B9841522759DA284ADE22178AD11072CCDD98547C673"}}}
                      2026-08-11 22:17:11.122 - debug: tapo.0 (2801788) refreshStok: nonce=A284ADE22178AD11... deviceConfirm=C64A7FCB68CFD3E3...
                      2026-08-11 22:17:11.122 - debug: tapo.0 (2801788) validateDeviceConfirm: matched candidate #1 via sha256
                      2026-08-11 22:17:11.122 - debug: tapo.0 (2801788) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                      2026-08-11 22:17:11.122 - debug: tapo.0 (2801788) refreshStok: sending start_seq request
                      2026-08-11 22:17:11.285 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:11.285 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                      2026-08-11 22:17:11.303 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:11.468 - debug: tapo.0 (2801788) refreshStok: start_seq response
                      2026-08-11 22:17:11.469 - debug: tapo.0 (2801788) refreshStok: start_seq=3564538 user_group=root stok=present
                      2026-08-11 22:17:11.469 - debug: tapo.0 (2801788) refreshStok: Success in obtaining STOK
                      2026-08-11 22:17:11.606 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:11.627 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:11.627 - debug: tapo.0 (2801788) API request already pending
                      2026-08-11 22:17:11.903 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:11.904 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                      2026-08-11 22:17:11.904 - info: tapo.0 (2801788) Reconnected to undefined
                      2026-08-11 22:17:11.904 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:11.904 - debug: tapo.0 (2801788) API request already pending
                      2026-08-11 22:17:12.257 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:12.257 - debug: tapo.0 (2801788) searchDetectionList raw: {}
                      2026-08-11 22:17:12.323 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:12.371 - debug: tapo.0 (2801788) API request already pending
                      2026-08-11 22:17:12.701 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:12.701 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                      2026-08-11 22:17:12.789 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:12.833 - debug: tapo.0 (2801788) API request already pending
                      2026-08-11 22:17:13.181 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:13.203 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:13.203 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:13.203 - debug: tapo.0 (2801788) isSecureConnection: Checking secure connection...
                      2026-08-11 22:17:13.299 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:13.300 - debug: tapo.0 (2801788) API request already pending
                      2026-08-11 22:17:13.516 - debug: tapo.0 (2801788) isSecureConnection response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"7DAAD745586EBA88","device_confirm":"21FE946BF70DC4CF1D9B21F6B9B570F9EF138DAE34CE1D04FD9D35A67263E1197DAAD745586EBA885A233A46DB9EB4DC"}}}
                      2026-08-11 22:17:13.516 - debug: tapo.0 (2801788) isSecureConnection result=true errorCode=-40413 encryptType=3 hasNonce=true
                      2026-08-11 22:17:13.516 - debug: tapo.0 (2801788) refreshStok: Refreshing stok...
                      2026-08-11 22:17:13.516 - debug: tapo.0 (2801788) refreshStok: isSecureConnection=true username=admin cnonce=7C8E9FB345EEB39E
                      2026-08-11 22:17:13.839 - debug: tapo.0 (2801788) refreshStok: Login response status=200 data={"error_code":-40413,"result":{"data":{"code":-40101,"time":0,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALTtcxduRKYkPskFTJlJ8XmEF6y6hWGlpMidsX5itHeU9J5VBIpnmFvW0bJdaQkTydb/BNDokh4dT1eHCErM0UMCAwEAAQ==","nonce":"A99ECDBE04E20F94","device_confirm":"CE2DFC8ACD8E90B2679280F8485E75CD1686769B29270D0A1AD39E4933FC2FE8A99ECDBE04E20F947C8E9FB345EEB39E"}}}
                      2026-08-11 22:17:13.839 - debug: tapo.0 (2801788) refreshStok: nonce=A99ECDBE04E20F94... deviceConfirm=CE2DFC8ACD8E90B2...
                      2026-08-11 22:17:13.840 - debug: tapo.0 (2801788) validateDeviceConfirm: matched candidate #1 via sha256
                      2026-08-11 22:17:13.840 - debug: tapo.0 (2801788) refreshStok: deviceConfirm validated, encryptionMethod=sha256
                      2026-08-11 22:17:13.840 - debug: tapo.0 (2801788) refreshStok: sending start_seq request
                      2026-08-11 22:17:14.141 - debug: tapo.0 (2801788) refreshStok: start_seq response
                      2026-08-11 22:17:14.141 - debug: tapo.0 (2801788) refreshStok: start_seq=6210465 user_group=root stok=present
                      2026-08-11 22:17:14.141 - debug: tapo.0 (2801788) refreshStok: Success in obtaining STOK
                      2026-08-11 22:17:14.508 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:14.508 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                      2026-08-11 22:17:14.508 - info: tapo.0 (2801788) Reconnected to undefined
                      2026-08-11 22:17:14.509 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:14.509 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                      2026-08-11 22:17:14.509 - debug: tapo.0 (2801788) API request already pending
                      2026-08-11 22:17:14.829 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:14.829 - debug: tapo.0 (2801788) searchDetectionList raw: {}
                      2026-08-11 22:17:14.857 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:14.864 - debug: tapo.0 (2801788) API request already pending
                      2026-08-11 22:17:15.165 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:15.165 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                      2026-08-11 22:17:15.245 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:15.288 - debug: tapo.0 (2801788) API request already pending
                      2026-08-11 22:17:15.571 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:15.612 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:15.613 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:15.613 - debug: tapo.0 (2801788) isSecureConnection: Checking secure connection...
                      2026-08-11 22:17:15.699 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:15.700 - debug: tapo.0 (2801788) API request already pending
                      2026-08-11 22:17:16.006 - info: host.iOProduktiv instance system.adapter.netatmo-crawler.0 in version "1.2.0" started with pid 2802654
                      2026-08-11 22:17:16.530 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:16.531 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:16.955 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:16.955 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":true,"autoUpgrade":true}
                      2026-08-11 22:17:16.956 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:17.176 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:17.176 - debug: tapo.0 (2801788) searchDetectionList raw: {}
                      2026-08-11 22:17:17.250 - info: netatmo-crawler.0 (2802654) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.23.0, js-controller: 7.2.2
                      2026-08-11 22:17:17.264 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:17.313 - info: netatmo-crawler.0 (2802654) Getting data for stationid:70:ee:50:05:f2:d4
                      2026-08-11 22:17:17.470 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:17.470 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                      2026-08-11 22:17:17.485 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:17.674 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:17.681 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:17.681 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:17.952 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:17.953 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":true,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                      2026-08-11 22:17:17.953 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:18.286 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:18.286 - debug: tapo.0 (2801788) searchDetectionList raw: {}
                      2026-08-11 22:17:18.288 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:18.584 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:18.584 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                      2026-08-11 22:17:18.614 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:18.876 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:18.886 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:18.886 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:19.392 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:19.392 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":false,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":true,"ldc":false,"recordAudio":true,"autoUpgrade":false}
                      2026-08-11 22:17:19.393 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:19.808 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:19.808 - debug: tapo.0 (2801788) searchDetectionList raw: {}
                      2026-08-11 22:17:19.811 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:20.169 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:20.169 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                      2026-08-11 22:17:20.190 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:20.265 - info: netatmo-crawler.0 (2802654) Getting data for stationid:70:ee:50:90:ce:ea
                      2026-08-11 22:17:20.539 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:20.548 - debug: tapo.0 (2801788) Receive camera status
                      2026-08-11 22:17:20.548 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:20.864 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:20.864 - debug: tapo.0 (2801788) {"alarm":false,"eyes":true,"notifications":false,"motionDetection":true,"led":true,"autoTrack":false,"personDetection":false,"vehicleDetection":false,"petDetection":false,"babyCryDetection":false,"barkDetection":false,"meowDetection":false,"glassBreakDetection":false,"tamperDetection":false,"lineCrossingDetection":false,"imageFlip":false,"ldc":false,"recordAudio":false,"autoUpgrade":false}
                      2026-08-11 22:17:20.864 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:20.889 - debug: tapo.0 (2801788) Get camera Status failed: fetch failed
                      2026-08-11 22:17:20.889 - debug: tapo.0 (2801788) undefined
                      2026-08-11 22:17:20.889 - debug: tapo.0 (2801788) Update done
                      2026-08-11 22:17:21.057 - info: host.iOProduktiv "system.adapter.tapo.0" disabled
                      2026-08-11 22:17:21.057 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 (force=false, process=true)
                      2026-08-11 22:17:21.062 - info: tapo.0 (2801788) Got terminate signal TERMINATE_YOURSELF
                      2026-08-11 22:17:21.063 - info: tapo.0 (2801788) terminating
                      2026-08-11 22:17:21.063 - info: tapo.0 (2801788) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2026-08-11 22:17:21.165 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:21.165 - debug: tapo.0 (2801788) searchDetectionList raw: {}
                      2026-08-11 22:17:21.217 - info: host.iOProduktiv stopInstance system.adapter.tapo.0 send kill signal
                      2026-08-11 22:17:21.248 - info: netatmo-crawler.0 (2802654) Getting data for stationid:70:ee:50:2e:f6:c0
                      2026-08-11 22:17:21.276 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:21.563 - info: tapo.0 (2801788) terminating
                      2026-08-11 22:17:21.593 - debug: tapo.0 (2801788) API response
                      2026-08-11 22:17:21.593 - debug: tapo.0 (2801788) getLastAlarmInfo raw: {"result":{"responses":[{"method":"getLastAlarmInfo","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0}]},"error_code":0}
                      2026-08-11 22:17:21.594 - debug: tapo.0 (2801788) redis get tapo.0.8021314EFB57E17626EC16DBDB2A31A51E64292E.alarmInfo.enabled, error - Connection is closed.
                      2026-08-11 22:17:21.594 - error: tapo.0 (2801788) Error extract keys: 8021314EFB57E17626EC16DBDB2A31A51E64292E.alarmInfo {"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"0","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}
                      2026-08-11 22:17:21.596 - error: tapo.0 (2801788) Error: DB closed
                      2026-08-11 22:17:21.596 - debug: tapo.0 (2801788) New API request
                      2026-08-11 22:17:21.718 - info: host.iOProduktiv instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      An dieser Stelle, noch einmal Danke für deinen vielen Aufwand mit meinem Problem.
                      LG
                      • metaxaM
                        metaxaM
                        metaxa
                        #882
                        @tombox bist du eventuell einen Schritt weitergekommen?
                        • metaxaM metaxa
                          T
                          T
                          tombox
                          #883
                          @metaxa eigentlich ja check GitHub version
                          metaxaM 1 Antwort Letzte Antwort
                          • T tombox
                            metaxaM
                            metaxaM
                            metaxa
                            #884
                            @tombox sagte:
                            Bingo! Alles in bester Ordnung!!! Perfekte Arbeit, großes Danke! Jetzt brauche ich diesen Resourcenfressenden Umweg über HA nicht mehr gehen!
                            LG, mxa
                            • M
                              M
                              ManiacKill
                              schrieb am zuletzt editiert von ManiacKill
                              #885
                              Moien,
                              ich hab mehrere CW520 und auch eine CW560 hier werden mir keine Bewegungen angezeigt oder bin ich hier falsch ? Der Adapter ist der Aktuelle 0.6.12 und der Login ergab auch keine Fehler im Log !
                              unter
                              zeigt er mir immer wieder mal eine Bewegung an !
                              aber diese Ordner finde ich unter keiner Kamera,
                              • D
                                D
                                Dan_Ce
                                #886
                                Nach etwas Nutzen des Adapters mit meinen Kameras habe ich gemerkt, dass ich die batteriebetriebenen Geräte (C425) lieber nicht standardmäßig aktiviere, da der Akkuverbrauch zu groß ist.
                                Dennoch würde ich gerne den Privatsphärenmodus schalten können.
                                Mögliche Ideen wären:
                                • Das Polling-Interval für Batterie-Geräte separat einzustellen und auf einen sehr hohen Wert zu stellen oder auszuschalten
                                • die Option "Batteriegeräte aktivieren" als Datenpunkt (?) mit anzusteuern, wenn man einen remote Befehl senden möchte und dann wieder ausschaltet.
                                  Ist das irgendwie möglich oder hat jemand eine Idee für einen Workaround?
                                • D Dan_Ce
                                  D
                                  D
                                  Dan_Ce
                                  #887
                                  Ich antworte mir mal selbst, aber vielleicht ist das Vorgehen auch für den Adapter nutzbar oder für andere Nutzer von Interesse:
                                  ich habe mir ein pythonskript erstellt:
                                  import sys
                                  import time
                                  from pytapo import Tapo
                                  if len(sys.argv) < 5:
                                      print("Fehler: Zu wenige Argumente.")
                                      print("Nutzung: python tapo_privacy.py <IP> <USER> <PASS> <TRUE/FALSE>")
                                      sys.exit(1)
                                  ip = sys.argv[1]
                                  user = sys.argv[2]
                                  password = sys.argv[3]
                                  # Akzeptiert 'true', '1', 'on' als Aktivierung
                                  state = sys.argv[4].lower() in ['true', '1', 'on']
                                  max_retries = 3
                                  retry_delay = 2  # Sekunden Pause zwischen Versuchen
                                  for attempt in range(1, max_retries + 1):
                                      try:
                                          tapo = Tapo(ip, user, password)
                                          tapo.setPrivacyMode(state)
                                          print(f"Erfolg: Privatsphäre-Modus auf {state} gesetzt (Versuch {attempt}).")
                                          sys.exit(0)
                                      except Exception as e:
                                          print(f"Versuch {attempt} fehlgeschlagen: {e}")
                                          if attempt < max_retries:
                                              time.sleep(retry_delay)
                                  print("Fehler: Privatsphäre-Modus konnte nicht geschaltet werden.")
                                  sys.exit(1)
                                  schalten kann ich dann mit
                                  /opt/iobroker/scripts/venv/bin/python /opt/iobroker/scripts/tapo_privacy.py 192.168.x.x "DeinUser" "DeinPasswort" true/false
                                  83.8k
