Offizielle Empfehlung: nodejs 24
sudo apt update && sudo apt full-upgrade
Ich habe gerade das Upgrade auf Node.js 24 durchgeführt. Beim folgenden sudo apt update && sudo apt full-upgrade bleibt das System stecken.
sudo apt update && sudo apt full-upgrade Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 http://archive.raspberrypi.com/debian trixie InRelease Hit:4 http://deb.debian.org/debian-security trixie-security InRelease Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease 8 packages can be upgraded. Run 'apt list --upgradable' to see them. Upgrading: libpcre2-16-0 libpcre2-32-0 libpcre2-8-0 libpcre2-dev libpcre2-posix3 rpi-eeprom rsync wpasupplicant Summary: Upgrading: 8, Installing: 0, Removing: 0, Not Upgrading: 0 Download size: 13.2 MB Space needed: 4,847 kB / 38.1 GB available Continue? [Y/n] y Get:1 http://deb.debian.org/debian-security trixie-security/main arm64 rsync arm64 3.5.0+ds1-0+deb13u1 [480 kB] Get:2 http://archive.raspberrypi.com/debian trixie/main arm64 rpi-eeprom all 28.33-1 [9,434 kB] Get:3 http://deb.debian.org/debian-security trixie-security/main arm64 libpcre2-dev arm64 10.46-1~deb13u3 [757 kB] Get:4 http://deb.debian.org/debian-security trixie-security/main arm64 libpcre2-16-0 arm64 10.46-1~deb13u3 [247 kB] Get:5 http://deb.debian.org/debian-security trixie-security/main arm64 libpcre2-32-0 arm64 10.46-1~deb13u3 [238 kB] Get:6 http://deb.debian.org/debian-security trixie-security/main arm64 libpcre2-posix3 arm64 10.46-1~deb13u3 [64.3 kB] Get:7 http://deb.debian.org/debian-security trixie-security/main arm64 libpcre2-8-0 arm64 10.46-1~deb13u3 [263 kB] Get:8 http://archive.raspberrypi.com/debian trixie/main arm64 wpasupplicant arm64 2:2.10-24+rpt3 [1,731 kB] Fetched 13.2 MB in 2s (5,595 kB/s) Reading changelogs... Done apt-listchanges: News --------------------- rsync (3.5.0+ds1-0+deb13u1) trixie-security; urgency=medium In order to fix 33 CVEs, I have decided to bump the package to 3.5.0 rather than backporting all patches individually. After analysing the extra changes from the bump, not included in the CVE fixes, I have concluded this approach carries the lower amount of risk compared to the alternative. This update contains behavior changes, all of which stems from the CVE fixes themselves, not exclusive to the version bump. The ones most likely to break an existing setup are listed here; /usr/share/doc/rsync/NEWS.md.gz has the full list. Operator-supplied paths are no longer followed through untrusted symlinks. The destination directory and the arguments to --backup-dir, --temp-dir, --partial-dir, --link-dest, --compare-dest, --copy-dest, --log-file, --password-file, --files-from, --include-from, --exclude-from, --write-batch, --read-batch and --filter merge files are now resolved one component at a time, following a symlink only when it is owned by root or by the user running rsync; one owned by anyone else is refused with "refusing to follow a symlink owned by an untrusted user". --insecure-links restores the old behaviour, but it is local only and a daemon never honours it. For a single trusted module, set "insecure links = yes" in that module instead. rrsync now refuses --debug on every invocation. When restricted to a subdirectory it additionally denies --copy-unsafe-links, passes the new --confine-root so the server will not resolve a client-named filter merge file outside that directory, and passes --drop-D when receiving, so an upload can no longer create devices or special files there ("skipping :Beim Abbruch mit Strg+C erscheint:
Error: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2. Error: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10iob diag (nach sudo reboot):
*** iob diag is starting up, please wait *** The state system.host.raspberrypi.versions.npmNewestNext was not found!Was läuft da falsch? Vorweg danke für die Unterstützung!
Das hat mit dem nodejs nix zu tun. Aus der Anzeige der apt-listchanges gehst du mit 'q' raus.
Nach dem Update von rpi-eeprom einen Neustart einlegen, erst dann wird die Firmware geladen. -
Danke, funktionierte super.
Musste nur 2x wegen Key ausführen.Bin aber wieder auf 22.x retour, da ein Adapter noch nicht 24.x mag.
Danke, Thomas! Hat funktioniert. Jetzt läuft Node.js 24.
Das lief auch davor schon. Die letzten Meldungen von apt hatten mit nodejs nichts zu tun. Die hättest du auch unahängig davon gesehen.
Ich habe auch auf Node.js 24 hoch gezogen.
Bekomme allerdings jetzt merkwürdige Meldungen beim aktualisieren von Adaptern.
Vielleich kann mir da einer weiter helfen?npm warn install-scripts cpu-features@0.0.10 (install: node-gyp rebuild)npm warn install-scripts diskusage@1.2.0 (install: node-gyp rebuild)npm warn install-scripts esbuild@0.11.23 (postinstall: node install.js)npm warn install-scripts @serialport/bindings-cpp@12.0.1 (install: node-gyp rebuild)npm warn install-scripts @stoprocent/bluetooth-hci-socket@1.5.2 (install: node-gyp rebuild)npm warn install-scripts @stoprocent/noble@1.19.1 (install: node-gyp rebuild)npm warn install-scripts iobroker.js-controller@7.2.3 (preinstall: node build/esm/lib/preinstallCheck.js; install: node iobroker.js setup first)npm warn install-scripts iobroker.vis@1.5.6 (install: node main.js --install)npm warn install-scripts protobufjs@7.6.5 (postinstall: node scripts/postinstall)npm warn install-scripts protobufjs@6.11.6 (postinstall: node scripts/postinstall)npm warn install-scripts sharp@0.32.6 (install: node-gyp rebuild)npm warn install-scripts ssh2@1.17.0 (install: node install.js)npm warn install-scripts unix-dgram@2.0.6 (install: node-gyp rebuild)npm warn install-scripts usb@2.18.0 (install: node-gyp rebuild)npm warn install-scripts @serialport/bindings-cpp@13.0.1 (install: node-gyp rebuild)npm warn install-scriptsnpm warn install-scripts Run `npm install-scripts ls` to review, or `npm install-scripts approve <pkg>` to allow.========== Start marking the full check here =========== bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: iobroker Icon name: computer-container Chassis: container ☐ Virtualization: lxc Kernel: Linux 7.0.14-19-pve Architecture: x86-64 OS is similar to: model name : Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : 64bit System was installed 50 days ago (on 2026-08-10). Systemuptime and Load: 18:59:19 up 2 days, 19:13, 1 user, load average: 1.21, 0.87, 0.85 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Wed 2026-09-30 18:59:19 CEST Universal time: Wed 2026-09-30 16:59:19 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': smarthome HOME=/home/smarthome GROUPS=smarthome adm tty dialout sudo audio video plugdev users ssh-users iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker adm tty dialout audio video plugdev bluetooth *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 12G 7.0G 3.4G 5.4M 2.6G 5.9G Swap: 1.1G 2.3M 1.1G Total: 13G 7.0G 4.4G Active iob-Instances: 49 12288 M total memory 6633 M used memory 3642 M active memory 5098 M inactive memory 3210 M free memory 0 M buffer memory 2449 M swap cache 1024 M total swap 2 M used swap 1021 M free swap *** top - Table Of Processes *** top - 18:59:20 up 2 days, 19:13, 1 user, load average: 1.21, 0.87, 0.85 Tasks: 84 total, 2 running, 82 sleeping, 0 stopped, 0 zombie %Cpu(s): 14.6 us, 0.0 sy, 0.0 ni, 85.4 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 12288.0 total, 3208.9 free, 6633.8 used, 2450.3 buff/cache MiB Swap: 1024.0 total, 1021.8 free, 2.2 used. 5654.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** dmesg: read kernel buffer failed: Operation not permitted No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/pve-vm--101--disk--0 ext4 25G 17G 6.3G 74% / none tmpfs 492K 4.0K 488K 1% /dev udev devtmpfs 15G 0 15G 0% /dev/tty tmpfs tmpfs 16G 0 16G 0% /dev/shm tmpfs tmpfs 6.2G 136K 6.2G 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 16G 5.2M 16G 1% /tmp tmpfs tmpfs 3.1G 8.0K 3.1G 1% /run/user/1001 Messages concerning filesystems in dmesg (Last 15 lines only): dmesg: read kernel buffer failed: Operation not permitted Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/pve-vm--101--disk--0 ext4 rw,relatime,stripe=128 Files in neuralgic directories: /var: 574M /var/ 207M /var/log/journal/6d3af4cac459428ab4e833a6d4a5ac24 207M /var/log/journal 207M /var/log 197M /var/lib Archived and active journals take up 206M in the file system. /opt/iobroker/backups: 6.2G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.2G /opt/iobroker/iobroker-data/ 498M /opt/iobroker/iobroker-data/files 265M /opt/iobroker/iobroker-data/backup-objects 218M /opt/iobroker/iobroker-data/history 200M /opt/iobroker/iobroker-data/files/aura The five largest files in iobroker-data are: 80M /opt/iobroker/iobroker-data/objects.jsonl 60M /opt/iobroker/iobroker-data/states.jsonl 30M /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map 16M /opt/iobroker/iobroker-data/files/matter.admin/assets/index-EdnNzxJx.js 12M /opt/iobroker/iobroker-data/jarvis/0/jarvis.0.devices.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ *** NodeJS-Installation *** /usr/bin/nodejs v24.21.0 /usr/bin/node v24.21.0 /usr/bin/npm 11.19.0 /usr/bin/npx 11.19.0 ✓ Node.js installation is correct nodejs: Installed: 24.21.0-1nodesource1 Candidate: 24.21.0-1nodesource1 Version table: *** 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u3 500 500 http://security.debian.org trixie-security/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker iobroker (version: 7.2.3, hostname: iobroker , alive, uptime: 241983) Core adapters versions js-controller: 7.2.3 admin: 8.0.20 javascript: 10.3.0 nodejs modules from github: 3 +-- iobroker.bambulab@0.4.3 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#b404a2395714df0ef34b13f0fd6c9309747ffead) +-- iobroker.device-watcher@2.15.17 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.device-watcher.git#6745c960560ea6f98ed8f69dc9c25e3aa006eb1c) +-- iobroker.fritzdect@2.6.4 (git+ssh://git@github.com/foxthefox/ioBroker.fritzdect.git#33c98148f41d4bdbc0472fe233e78fabc2c617d4) Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.100, run as: admin + system.adapter.alexa2.0 : alexa2 : iobroker - enabled system.adapter.aura.0 : aura : iobroker - disabled, port: 8095 + system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.bambulab.0 : bambulab : iobroker - enabled, port: 8883 + system.adapter.bluelink.0 : bluelink : iobroker - enabled + system.adapter.cloudless-homeconnect.0 : cloudless-homeconnect : iobroker - enabled + system.adapter.device-watcher.0 : device-watcher : iobroker - enabled system.adapter.devices.0 : devices : iobroker - disabled system.adapter.discovery.0 : discovery : iobroker - disabled + system.adapter.dreame.0 : dreame : iobroker - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : iobroker - enabled + system.adapter.fritzdect.0 : fritzdect : iobroker - enabled + system.adapter.govee-smart.0 : govee-smart : iobroker - enabled, port: 4002, bind: 192.168.178.100 system.adapter.harmony.0 : harmony : iobroker - disabled + system.adapter.history.0 : history : iobroker - enabled + system.adapter.homeconnect.0 : homeconnect : iobroker - enabled + system.adapter.homekit-controller.0 : homekit-controller : iobroker - enabled + system.adapter.hoymiles-ms.0 : hoymiles-ms : iobroker - enabled system.adapter.ical.0 : ical : iobroker - enabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.2 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.3 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.4 : influxdb : iobroker - enabled, port: 3001 + system.adapter.jarvis.0 : jarvis : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.matter.0 : matter : iobroker - enabled + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1888 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.notification-manager.0 : notification-manager : iobroker - enabled + system.adapter.octoprint.0 : octoprint : iobroker - enabled + system.adapter.opendtu.0 : opendtu : iobroker - enabled + system.adapter.proxmox.0 : proxmox : iobroker - enabled + system.adapter.samsungtv.0 : samsungtv : iobroker - enabled system.adapter.script-restore.0 : script-restore : iobroker - disabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1880, bind: 192.168.178.100 + system.adapter.smartthings.0 : smartthings : iobroker - enabled + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 192.168.178.100 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 192.168.178.100 + system.adapter.sonoff.2 : sonoff : iobroker - enabled, port: 1881, bind: 192.168.178.100 + system.adapter.sonoff.3 : sonoff : iobroker - enabled, port: 1884, bind: 192.168.178.100 + system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled + system.adapter.tr-064.0 : tr-064 : iobroker - enabled + system.adapter.tr-064.1 : tr-064 : iobroker - enabled + system.adapter.tr-064.2 : tr-064 : iobroker - enabled + system.adapter.tuya.0 : tuya : iobroker - enabled + system.adapter.upnp.0 : upnp : iobroker - enabled + system.adapter.vis-2.0 : vis-2 : iobroker - enabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - enabled + system.adapter.wled.0 : wled : iobroker - enabled + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.100, run as: admin + system.adapter.bambulab.0 : bambulab : iobroker - enabled, port: 8883 + system.adapter.govee-smart.0 : govee-smart : iobroker - enabled, port: 4002, bind: 192.168.178.100 + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.2 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.3 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.4 : influxdb : iobroker - enabled, port: 3001 + system.adapter.jarvis.0 : jarvis : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1888 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1880, bind: 192.168.178.100 + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 192.168.178.100 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 192.168.178.100 + system.adapter.sonoff.2 : sonoff : iobroker - enabled, port: 1881, bind: 192.168.178.100 + system.adapter.sonoff.3 : sonoff : iobroker - enabled, port: 1884, bind: 192.168.178.100 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB0 ioBroker-Repositories ┌─────────┬───────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼───────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ │ 2 │ 'live-Beta' │ 'http://iobroker.live/repo/sources-dist-latest.json' │ false │ │ 3 │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json' │ false │ └─────────┴───────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): beta Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬─────────────────────────────────────────┬──────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼─────────────────────────────────────────┼──────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '8.0.20' │ 'none' │ │ 1 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 2 │ 'system.adapter.aura' │ 'aura' │ '0.72.3' │ 'none' │ │ 3 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.4' │ 'none' │ │ 4 │ 'system.adapter.bambulab' │ 'bambulab' │ '0.4.3' │ 'none' │ │ 5 │ 'system.adapter.bluelink' │ 'bluelink' │ '3.1.34' │ 'none' │ │ 6 │ 'system.adapter.cloudless-homeconnect' │ 'cloudless-homeconnect' │ '1.7.0' │ 'none' │ │ 7 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 8 │ 'system.adapter.devices' │ 'devices' │ '4.2.2' │ 'none' │ │ 9 │ 'system.adapter.discovery' │ 'discovery' │ '5.1.1' │ 'none' │ │ 10 │ 'system.adapter.dreame' │ 'dreame' │ '0.4.12' │ 'none' │ │ 11 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.3' │ 'none' │ │ 12 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 13 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.4' │ 'none' │ │ 14 │ 'system.adapter.govee-smart' │ 'govee-smart' │ '3.0.1' │ 'none' │ │ 15 │ 'system.adapter.harmony' │ 'harmony' │ '3.0.0' │ 'none' │ │ 16 │ 'system.adapter.history' │ 'history' │ '5.0.1' │ 'none' │ │ 17 │ 'system.adapter.homeconnect' │ 'homeconnect' │ '1.6.1' │ 'none' │ │ 18 │ 'system.adapter.homekit-controller' │ 'homekit-controller' │ '0.5.11' │ 'none' │ │ 19 │ 'system.adapter.hoymiles-ms' │ 'hoymiles-ms' │ '0.2.2' │ 'none' │ │ 20 │ 'system.adapter.ical' │ 'ical' │ '1.21.1' │ 'none' │ │ 21 │ 'system.adapter.influxdb' │ 'influxdb' │ '5.0.3' │ 'none' │ │ 22 │ 'system.adapter.jarvis' │ 'jarvis' │ '3.1.8' │ 'none' │ │ 23 │ 'system.adapter.javascript' │ 'javascript' │ '10.3.0' │ 'none' │ │ 24 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 25 │ 'system.adapter.mcp' │ 'mcp' │ '1.1.0' │ 'none' │ │ 26 │ 'system.adapter.mqtt' │ 'mqtt' │ '8.1.0' │ 'none' │ │ 27 │ 'system.adapter.mqtt-client' │ 'mqtt-client' │ '4.1.0' │ 'none' │ │ 28 │ 'system.adapter.notification-manager' │ 'notification-manager' │ '1.3.0' │ 'none' │ │ 29 │ 'system.adapter.octoprint' │ 'octoprint' │ '7.0.0' │ 'none' │ │ 30 │ 'system.adapter.opendtu' │ 'opendtu' │ '3.1.0' │ 'none' │ │ 31 │ 'system.adapter.proxmox' │ 'proxmox' │ '2.6.3' │ 'none' │ │ 32 │ 'system.adapter.samsungtv' │ 'samsungtv' │ '0.0.28' │ 'none' │ │ 33 │ 'system.adapter.script-restore' │ 'script-restore' │ '0.1.13' │ 'none' │ │ 34 │ 'system.adapter.shelly' │ 'shelly' │ '12.0.0' │ 'none' │ │ 35 │ 'system.adapter.smartthings' │ 'smartthings' │ '0.3.0' │ 'none' │ │ 36 │ 'system.adapter.socketio' │ 'socketio' │ '8.0.1' │ 'none' │ │ 37 │ 'system.adapter.sonoff' │ 'sonoff' │ '4.2.1' │ 'none' │ │ 38 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.6.0' │ 'none' │ │ 39 │ 'system.adapter.tr-064' │ 'tr-064' │ '5.1.0' │ 'none' │ │ 40 │ 'system.adapter.tuya' │ 'tuya' │ '3.18.2' │ 'none' │ │ 41 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.10' │ 'none' │ │ 42 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 43 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.15.8' │ 'none' │ │ 44 │ 'system.adapter.web' │ 'web' │ '9.1.9' │ 'none' │ │ 45 │ 'system.adapter.whatsapp-cmb' │ 'whatsapp-cmb' │ '0.3.0' │ 'none' │ │ 46 │ 'system.adapter.wled' │ 'wled' │ '0.9.2' │ 'none' │ │ 47 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴─────────────────────────────────────────┴──────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: beta Adapter "admin" : 8.0.21 , installed 8.0.20 [Updatable] Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "aura" : 0.72.3 , installed 0.72.3 Adapter "backitup" : 4.0.4 , installed 4.0.4 Adapter "bambulab" : 0.4.3 , installed 0.4.3 Adapter "bluelink" : 3.1.34 , installed 3.1.34 Adapter "cloudless-homeconnect": 1.7.0, installed 1.7.0 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 4.2.2 , installed 4.2.2 Adapter "discovery" : 5.1.1 , installed 5.1.1 Adapter "dreame" : 0.4.12 , installed 0.4.12 Adapter "energiefluss-erweitert": 0.8.3, installed 0.8.3 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fritzdect" : 2.6.2 , installed 2.6.4 Adapter "govee-smart" : 3.0.1 , installed 3.0.1 Adapter "harmony" : 3.0.0 , installed 3.0.0 Adapter "history" : 5.0.1 , installed 5.0.1 Adapter "homeconnect" : 1.6.1 , installed 1.6.1 Adapter "homekit-controller": 0.5.11, installed 0.5.11 Adapter "hoymiles-ms" : 0.2.2 , installed 0.2.2 Adapter "ical" : 1.21.1 , installed 1.21.1 Adapter "influxdb" : 5.0.3 , installed 5.0.3 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 10.3.0 , installed 10.3.0 Controller "js-controller": 7.2.3 , installed 7.2.3 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 8.1.0 , installed 8.1.0 Adapter "mqtt-client" : 4.1.0 , installed 4.1.0 Adapter "notification-manager": 1.3.0, installed 1.3.0 Adapter "octoprint" : 7.0.0 , installed 7.0.0 Adapter "opendtu" : 3.1.0 , installed 3.1.0 Adapter "proxmox" : 2.6.3 , installed 2.6.3 Adapter "samsungtv" : 0.0.28 , installed 0.0.28 Adapter "script-restore": 0.1.13 , installed 0.1.13 Adapter "shelly" : 12.0.0 , installed 12.0.0 Adapter "smartthings" : 0.3.0 , installed 0.3.0 Adapter "sonoff" : 4.2.1 , installed 4.2.1 Adapter "sourceanalytix": 0.6.0 , installed 0.6.0 Adapter "tr-064" : 5.1.0 , installed 5.1.0 Adapter "tuya" : 3.18.2 , installed 3.18.2 Adapter "upnp" : 1.1.10 , installed 1.1.10 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.15.8 , installed 2.15.8 Adapter "web" : 9.1.9 , installed 9.1.9 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "wled" : 0.9.2 , installed 0.9.2 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 37571 States: 30965 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://security.debian.org trixie-security InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.178.100:43208 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=40)) udp UNCONN 0 0 192.168.178.100:45436 0.0.0.0:* users:(("io.samsungtv.0",pid=906,fd=30)) udp UNCONN 0 0 0.0.0.0:bootpc 0.0.0.0:* users:(("dhclient",pid=225,fd=7)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=93,fd=5),("systemd",pid=1,fd=35)) udp UNCONN 0 0 0.0.0.0:33652 0.0.0.0:* users:(("io.upnp.0",pid=1187,fd=30)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("io.upnp.0",pid=1187,fd=37)) udp UNCONN 0 0 192.168.178.100:4002 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=39)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.homekit-cont",pid=14823,fd=34)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.wled.0",pid=1090,fd=22)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=35)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=31)) udp UNCONN 0 0 0.0.0.0:5540 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=34)) udp UNCONN 0 0 0.0.0.0:6666 0.0.0.0:* users:(("io.tuya.0",pid=809,fd=32)) udp UNCONN 0 0 0.0.0.0:6667 0.0.0.0:* users:(("io.tuya.0",pid=809,fd=33)) udp UNCONN 0 0 192.168.178.100:56296 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=38)) udp UNCONN 0 0 0.0.0.0:57441 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=38)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=93,fd=7),("systemd",pid=1,fd=37)) udp UNCONN 0 0 *:50953 *:* users:(("io.bluelink.0",pid=11322,fd=36)) udp UNCONN 0 0 [::]:mdns [::]:* users:(("io.matter.0",pid=1042,fd=36)) udp UNCONN 0 0 [::]:mdns [::]:* users:(("io.matter.0",pid=1042,fd=32)) udp UNCONN 0 0 [::]:5540 [::]:* users:(("io.matter.0",pid=1042,fd=33)) udp UNCONN 0 0 [::]:57441 [::]:* users:(("io.matter.0",pid=1042,fd=37)) tcp LISTEN 0 511 192.168.178.100:1884 0.0.0.0:* users:(("io.sonoff.3",pid=777,fd=30)) tcp LISTEN 0 511 192.168.178.100:1880 0.0.0.0:* users:(("io.shelly.0",pid=10749,fd=77)) tcp LISTEN 0 511 192.168.178.100:1881 0.0.0.0:* users:(("io.sonoff.2",pid=753,fd=30)) tcp LISTEN 0 511 192.168.178.100:1882 0.0.0.0:* users:(("io.sonoff.1",pid=745,fd=30)) tcp LISTEN 0 511 192.168.178.100:1883 0.0.0.0:* users:(("io.sonoff.0",pid=712,fd=30)) tcp LISTEN 0 100 192.168.178.100:1888 0.0.0.0:* users:(("mosquitto",pid=927,fd=5)) tcp LISTEN 0 511 192.168.178.100:1890 0.0.0.0:* users:(("io.hoymiles-ms.",pid=1252,fd=30)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=93,fd=4),("systemd",pid=1,fd=34)) tcp LISTEN 0 511 192.168.178.100:tproxy 0.0.0.0:* users:(("io.admin.0",pid=341,fd=35)) tcp LISTEN 0 4096 127.0.0.1:omniorb 0.0.0.0:* users:(("influxd",pid=96,fd=3)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=97,fd=23)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=97,fd=29)) tcp LISTEN 0 100 127.0.0.1:smtp 0.0.0.0:* users:(("master",pid=303,fd=13)) tcp LISTEN 0 511 0.0.0.0:8400 0.0.0.0:* users:(("io.jarvis.0",pid=1023,fd=30)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=9949,fd=30)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=96,fd=20)) tcp LISTEN 0 4096 *:ssh *:* users:(("sshd",pid=123,fd=3),("systemd",pid=1,fd=58)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=93,fd=6),("systemd",pid=1,fd=36)) tcp LISTEN 0 100 [::1]:smtp [::]:* users:(("master",pid=303,fd=14)) tcp LISTEN 0 511 *:57441 *:* users:(("io.matter.0",pid=1042,fd=39)) *** Log File - Last 25 Lines *** 2026-09-30 18:58:02.158 - info: host.iobroker iobroker upload [7] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/react-dom-DrD5giaT.js assets/react-dom-DrD5giaT.js application/javascript 2026-09-30 18:58:02.164 - info: host.iobroker iobroker upload [6] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/react-okGu5lkI.js assets/react-okGu5lkI.js application/javascript 2026-09-30 18:58:02.172 - info: host.iobroker iobroker upload [5] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/recharts-DjhcjZm3.js assets/recharts-DjhcjZm3.js application/javascript 2026-09-30 18:58:02.180 - info: host.iobroker iobroker upload [4] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/router-CIdYoo77.js assets/router-CIdYoo77.js application/javascript 2026-09-30 18:58:02.186 - info: host.iobroker iobroker upload [3] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/sampleChartData-B8tY0lM6.js assets/sampleChartData-B8tY0lM6.js application/javascript 2026-09-30 18:58:02.196 - info: host.iobroker iobroker upload [2] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/useLayoutSetting-uK8wot69.js assets/useLayoutSetting-uK8wot69.js application/javascript 2026-09-30 18:58:02.207 - info: host.iobroker iobroker upload [1] aura /opt/iobroker/node_modules/iobroker.aura/www/favicon.svg favicon.svg image/svg+xml 2026-09-30 18:58:02.213 - info: host.iobroker iobroker upload [0] aura /opt/iobroker/node_modules/iobroker.aura/www/index.html index.html text/html 2026-09-30 18:58:02.221 - info: host.iobroker iobroker Updating objects from io-package.json for adapter "aura" with version "0.72.3" 2026-09-30 18:58:02.266 - info: host.iobroker iobroker Update "system.adapter.aura.0" 2026-09-30 18:58:02.274 - info: host.iobroker iobroker upload [13] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/aura.png aura.png image/png 2026-09-30 18:58:02.276 - info: host.iobroker iobroker upload [12] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/aura.svg aura.svg image/svg+xml 2026-09-30 18:58:02.279 - info: host.iobroker iobroker upload [11] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/de/translations.json i18n/de/translations.json application/json 2026-09-30 18:58:02.281 - info: host.iobroker iobroker upload [10] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/en/translations.json i18n/en/translations.json application/json 2026-09-30 18:58:02.284 - info: host.iobroker iobroker upload [9] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/es/translations.json i18n/es/translations.json application/json 2026-09-30 18:58:02.286 - info: host.iobroker iobroker upload [8] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/fr/translations.json i18n/fr/translations.json application/json 2026-09-30 18:58:02.289 - info: host.iobroker iobroker upload [7] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/it/translations.json i18n/it/translations.json application/json 2026-09-30 18:58:02.292 - info: host.iobroker iobroker upload [6] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/nl/translations.json i18n/nl/translations.json application/json 2026-09-30 18:58:02.294 - info: host.iobroker iobroker upload [5] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/pl/translations.json i18n/pl/translations.json application/json 2026-09-30 18:58:02.296 - info: host.iobroker iobroker upload [4] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/pt/translations.json i18n/pt/translations.json application/json 2026-09-30 18:58:02.297 - info: host.iobroker iobroker upload [3] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/ru/translations.json i18n/ru/translations.json application/json 2026-09-30 18:58:02.300 - info: host.iobroker iobroker upload [2] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/uk/translations.json i18n/uk/translations.json application/json 2026-09-30 18:58:02.302 - info: host.iobroker iobroker upload [1] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json 2026-09-30 18:58:02.304 - info: host.iobroker iobroker upload [0] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/jsonConfig.json jsonConfig.json application/json 2026-09-30 18:58:03.322 - info: host.iobroker iobroker exit 0 ============= Mark until here for C&P ============= -
Vielleich kann mir da einer weiter helfen?npm warn install-scripts cpu-features@0.0.10 (install: node-gyp rebuild)npm warn install-scripts diskusage@1.2.0 (install: node-gyp rebuild)npm warn install-scripts esbuild@0.11.23 (postinstall: node install.js)npm warn install-scripts @serialport/bindings-cpp@12.0.1 (install: node-gyp rebuild)npm warn install-scripts @stoprocent/bluetooth-hci-socket@1.5.2 (install: node-gyp rebuild)npm warn install-scripts @stoprocent/noble@1.19.1 (install: node-gyp rebuild)npm warn install-scripts iobroker.js-controller@7.2.3 (preinstall: node build/esm/lib/preinstallCheck.js; install: node iobroker.js setup first)npm warn install-scripts iobroker.vis@1.5.6 (install: node main.js --install)npm warn install-scripts protobufjs@7.6.5 (postinstall: node scripts/postinstall)npm warn install-scripts protobufjs@6.11.6 (postinstall: node scripts/postinstall)npm warn install-scripts sharp@0.32.6 (install: node-gyp rebuild)npm warn install-scripts ssh2@1.17.0 (install: node install.js)npm warn install-scripts unix-dgram@2.0.6 (install: node-gyp rebuild)npm warn install-scripts usb@2.18.0 (install: node-gyp rebuild)npm warn install-scripts @serialport/bindings-cpp@13.0.1 (install: node-gyp rebuild)npm warn install-scriptsnpm warn install-scripts Run `npm install-scripts ls` to review, or `npm install-scripts approve <pkg>` to allow.========== Start marking the full check here =========== bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: iobroker Icon name: computer-container Chassis: container ☐ Virtualization: lxc Kernel: Linux 7.0.14-19-pve Architecture: x86-64 OS is similar to: model name : Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : 64bit System was installed 50 days ago (on 2026-08-10). Systemuptime and Load: 18:59:19 up 2 days, 19:13, 1 user, load average: 1.21, 0.87, 0.85 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Wed 2026-09-30 18:59:19 CEST Universal time: Wed 2026-09-30 16:59:19 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': smarthome HOME=/home/smarthome GROUPS=smarthome adm tty dialout sudo audio video plugdev users ssh-users iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker adm tty dialout audio video plugdev bluetooth *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 12G 7.0G 3.4G 5.4M 2.6G 5.9G Swap: 1.1G 2.3M 1.1G Total: 13G 7.0G 4.4G Active iob-Instances: 49 12288 M total memory 6633 M used memory 3642 M active memory 5098 M inactive memory 3210 M free memory 0 M buffer memory 2449 M swap cache 1024 M total swap 2 M used swap 1021 M free swap *** top - Table Of Processes *** top - 18:59:20 up 2 days, 19:13, 1 user, load average: 1.21, 0.87, 0.85 Tasks: 84 total, 2 running, 82 sleeping, 0 stopped, 0 zombie %Cpu(s): 14.6 us, 0.0 sy, 0.0 ni, 85.4 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 12288.0 total, 3208.9 free, 6633.8 used, 2450.3 buff/cache MiB Swap: 1024.0 total, 1021.8 free, 2.2 used. 5654.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** dmesg: read kernel buffer failed: Operation not permitted No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/pve-vm--101--disk--0 ext4 25G 17G 6.3G 74% / none tmpfs 492K 4.0K 488K 1% /dev udev devtmpfs 15G 0 15G 0% /dev/tty tmpfs tmpfs 16G 0 16G 0% /dev/shm tmpfs tmpfs 6.2G 136K 6.2G 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 16G 5.2M 16G 1% /tmp tmpfs tmpfs 3.1G 8.0K 3.1G 1% /run/user/1001 Messages concerning filesystems in dmesg (Last 15 lines only): dmesg: read kernel buffer failed: Operation not permitted Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/pve-vm--101--disk--0 ext4 rw,relatime,stripe=128 Files in neuralgic directories: /var: 574M /var/ 207M /var/log/journal/6d3af4cac459428ab4e833a6d4a5ac24 207M /var/log/journal 207M /var/log 197M /var/lib Archived and active journals take up 206M in the file system. /opt/iobroker/backups: 6.2G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.2G /opt/iobroker/iobroker-data/ 498M /opt/iobroker/iobroker-data/files 265M /opt/iobroker/iobroker-data/backup-objects 218M /opt/iobroker/iobroker-data/history 200M /opt/iobroker/iobroker-data/files/aura The five largest files in iobroker-data are: 80M /opt/iobroker/iobroker-data/objects.jsonl 60M /opt/iobroker/iobroker-data/states.jsonl 30M /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map 16M /opt/iobroker/iobroker-data/files/matter.admin/assets/index-EdnNzxJx.js 12M /opt/iobroker/iobroker-data/jarvis/0/jarvis.0.devices.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ *** NodeJS-Installation *** /usr/bin/nodejs v24.21.0 /usr/bin/node v24.21.0 /usr/bin/npm 11.19.0 /usr/bin/npx 11.19.0 ✓ Node.js installation is correct nodejs: Installed: 24.21.0-1nodesource1 Candidate: 24.21.0-1nodesource1 Version table: *** 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u3 500 500 http://security.debian.org trixie-security/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker iobroker (version: 7.2.3, hostname: iobroker , alive, uptime: 241983) Core adapters versions js-controller: 7.2.3 admin: 8.0.20 javascript: 10.3.0 nodejs modules from github: 3 +-- iobroker.bambulab@0.4.3 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#b404a2395714df0ef34b13f0fd6c9309747ffead) +-- iobroker.device-watcher@2.15.17 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.device-watcher.git#6745c960560ea6f98ed8f69dc9c25e3aa006eb1c) +-- iobroker.fritzdect@2.6.4 (git+ssh://git@github.com/foxthefox/ioBroker.fritzdect.git#33c98148f41d4bdbc0472fe233e78fabc2c617d4) Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.100, run as: admin + system.adapter.alexa2.0 : alexa2 : iobroker - enabled system.adapter.aura.0 : aura : iobroker - disabled, port: 8095 + system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.bambulab.0 : bambulab : iobroker - enabled, port: 8883 + system.adapter.bluelink.0 : bluelink : iobroker - enabled + system.adapter.cloudless-homeconnect.0 : cloudless-homeconnect : iobroker - enabled + system.adapter.device-watcher.0 : device-watcher : iobroker - enabled system.adapter.devices.0 : devices : iobroker - disabled system.adapter.discovery.0 : discovery : iobroker - disabled + system.adapter.dreame.0 : dreame : iobroker - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : iobroker - enabled + system.adapter.fritzdect.0 : fritzdect : iobroker - enabled + system.adapter.govee-smart.0 : govee-smart : iobroker - enabled, port: 4002, bind: 192.168.178.100 system.adapter.harmony.0 : harmony : iobroker - disabled + system.adapter.history.0 : history : iobroker - enabled + system.adapter.homeconnect.0 : homeconnect : iobroker - enabled + system.adapter.homekit-controller.0 : homekit-controller : iobroker - enabled + system.adapter.hoymiles-ms.0 : hoymiles-ms : iobroker - enabled system.adapter.ical.0 : ical : iobroker - enabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.2 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.3 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.4 : influxdb : iobroker - enabled, port: 3001 + system.adapter.jarvis.0 : jarvis : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.matter.0 : matter : iobroker - enabled + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1888 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.notification-manager.0 : notification-manager : iobroker - enabled + system.adapter.octoprint.0 : octoprint : iobroker - enabled + system.adapter.opendtu.0 : opendtu : iobroker - enabled + system.adapter.proxmox.0 : proxmox : iobroker - enabled + system.adapter.samsungtv.0 : samsungtv : iobroker - enabled system.adapter.script-restore.0 : script-restore : iobroker - disabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1880, bind: 192.168.178.100 + system.adapter.smartthings.0 : smartthings : iobroker - enabled + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 192.168.178.100 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 192.168.178.100 + system.adapter.sonoff.2 : sonoff : iobroker - enabled, port: 1881, bind: 192.168.178.100 + system.adapter.sonoff.3 : sonoff : iobroker - enabled, port: 1884, bind: 192.168.178.100 + system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled + system.adapter.tr-064.0 : tr-064 : iobroker - enabled + system.adapter.tr-064.1 : tr-064 : iobroker - enabled + system.adapter.tr-064.2 : tr-064 : iobroker - enabled + system.adapter.tuya.0 : tuya : iobroker - enabled + system.adapter.upnp.0 : upnp : iobroker - enabled + system.adapter.vis-2.0 : vis-2 : iobroker - enabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - enabled + system.adapter.wled.0 : wled : iobroker - enabled + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.100, run as: admin + system.adapter.bambulab.0 : bambulab : iobroker - enabled, port: 8883 + system.adapter.govee-smart.0 : govee-smart : iobroker - enabled, port: 4002, bind: 192.168.178.100 + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.2 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.3 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.4 : influxdb : iobroker - enabled, port: 3001 + system.adapter.jarvis.0 : jarvis : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1888 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1880, bind: 192.168.178.100 + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 192.168.178.100 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 192.168.178.100 + system.adapter.sonoff.2 : sonoff : iobroker - enabled, port: 1881, bind: 192.168.178.100 + system.adapter.sonoff.3 : sonoff : iobroker - enabled, port: 1884, bind: 192.168.178.100 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB0 ioBroker-Repositories ┌─────────┬───────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼───────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ │ 2 │ 'live-Beta' │ 'http://iobroker.live/repo/sources-dist-latest.json' │ false │ │ 3 │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json' │ false │ └─────────┴───────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): beta Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬─────────────────────────────────────────┬──────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼─────────────────────────────────────────┼──────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '8.0.20' │ 'none' │ │ 1 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 2 │ 'system.adapter.aura' │ 'aura' │ '0.72.3' │ 'none' │ │ 3 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.4' │ 'none' │ │ 4 │ 'system.adapter.bambulab' │ 'bambulab' │ '0.4.3' │ 'none' │ │ 5 │ 'system.adapter.bluelink' │ 'bluelink' │ '3.1.34' │ 'none' │ │ 6 │ 'system.adapter.cloudless-homeconnect' │ 'cloudless-homeconnect' │ '1.7.0' │ 'none' │ │ 7 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 8 │ 'system.adapter.devices' │ 'devices' │ '4.2.2' │ 'none' │ │ 9 │ 'system.adapter.discovery' │ 'discovery' │ '5.1.1' │ 'none' │ │ 10 │ 'system.adapter.dreame' │ 'dreame' │ '0.4.12' │ 'none' │ │ 11 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.3' │ 'none' │ │ 12 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 13 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.4' │ 'none' │ │ 14 │ 'system.adapter.govee-smart' │ 'govee-smart' │ '3.0.1' │ 'none' │ │ 15 │ 'system.adapter.harmony' │ 'harmony' │ '3.0.0' │ 'none' │ │ 16 │ 'system.adapter.history' │ 'history' │ '5.0.1' │ 'none' │ │ 17 │ 'system.adapter.homeconnect' │ 'homeconnect' │ '1.6.1' │ 'none' │ │ 18 │ 'system.adapter.homekit-controller' │ 'homekit-controller' │ '0.5.11' │ 'none' │ │ 19 │ 'system.adapter.hoymiles-ms' │ 'hoymiles-ms' │ '0.2.2' │ 'none' │ │ 20 │ 'system.adapter.ical' │ 'ical' │ '1.21.1' │ 'none' │ │ 21 │ 'system.adapter.influxdb' │ 'influxdb' │ '5.0.3' │ 'none' │ │ 22 │ 'system.adapter.jarvis' │ 'jarvis' │ '3.1.8' │ 'none' │ │ 23 │ 'system.adapter.javascript' │ 'javascript' │ '10.3.0' │ 'none' │ │ 24 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 25 │ 'system.adapter.mcp' │ 'mcp' │ '1.1.0' │ 'none' │ │ 26 │ 'system.adapter.mqtt' │ 'mqtt' │ '8.1.0' │ 'none' │ │ 27 │ 'system.adapter.mqtt-client' │ 'mqtt-client' │ '4.1.0' │ 'none' │ │ 28 │ 'system.adapter.notification-manager' │ 'notification-manager' │ '1.3.0' │ 'none' │ │ 29 │ 'system.adapter.octoprint' │ 'octoprint' │ '7.0.0' │ 'none' │ │ 30 │ 'system.adapter.opendtu' │ 'opendtu' │ '3.1.0' │ 'none' │ │ 31 │ 'system.adapter.proxmox' │ 'proxmox' │ '2.6.3' │ 'none' │ │ 32 │ 'system.adapter.samsungtv' │ 'samsungtv' │ '0.0.28' │ 'none' │ │ 33 │ 'system.adapter.script-restore' │ 'script-restore' │ '0.1.13' │ 'none' │ │ 34 │ 'system.adapter.shelly' │ 'shelly' │ '12.0.0' │ 'none' │ │ 35 │ 'system.adapter.smartthings' │ 'smartthings' │ '0.3.0' │ 'none' │ │ 36 │ 'system.adapter.socketio' │ 'socketio' │ '8.0.1' │ 'none' │ │ 37 │ 'system.adapter.sonoff' │ 'sonoff' │ '4.2.1' │ 'none' │ │ 38 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.6.0' │ 'none' │ │ 39 │ 'system.adapter.tr-064' │ 'tr-064' │ '5.1.0' │ 'none' │ │ 40 │ 'system.adapter.tuya' │ 'tuya' │ '3.18.2' │ 'none' │ │ 41 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.10' │ 'none' │ │ 42 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 43 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.15.8' │ 'none' │ │ 44 │ 'system.adapter.web' │ 'web' │ '9.1.9' │ 'none' │ │ 45 │ 'system.adapter.whatsapp-cmb' │ 'whatsapp-cmb' │ '0.3.0' │ 'none' │ │ 46 │ 'system.adapter.wled' │ 'wled' │ '0.9.2' │ 'none' │ │ 47 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴─────────────────────────────────────────┴──────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: beta Adapter "admin" : 8.0.21 , installed 8.0.20 [Updatable] Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "aura" : 0.72.3 , installed 0.72.3 Adapter "backitup" : 4.0.4 , installed 4.0.4 Adapter "bambulab" : 0.4.3 , installed 0.4.3 Adapter "bluelink" : 3.1.34 , installed 3.1.34 Adapter "cloudless-homeconnect": 1.7.0, installed 1.7.0 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 4.2.2 , installed 4.2.2 Adapter "discovery" : 5.1.1 , installed 5.1.1 Adapter "dreame" : 0.4.12 , installed 0.4.12 Adapter "energiefluss-erweitert": 0.8.3, installed 0.8.3 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fritzdect" : 2.6.2 , installed 2.6.4 Adapter "govee-smart" : 3.0.1 , installed 3.0.1 Adapter "harmony" : 3.0.0 , installed 3.0.0 Adapter "history" : 5.0.1 , installed 5.0.1 Adapter "homeconnect" : 1.6.1 , installed 1.6.1 Adapter "homekit-controller": 0.5.11, installed 0.5.11 Adapter "hoymiles-ms" : 0.2.2 , installed 0.2.2 Adapter "ical" : 1.21.1 , installed 1.21.1 Adapter "influxdb" : 5.0.3 , installed 5.0.3 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 10.3.0 , installed 10.3.0 Controller "js-controller": 7.2.3 , installed 7.2.3 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 8.1.0 , installed 8.1.0 Adapter "mqtt-client" : 4.1.0 , installed 4.1.0 Adapter "notification-manager": 1.3.0, installed 1.3.0 Adapter "octoprint" : 7.0.0 , installed 7.0.0 Adapter "opendtu" : 3.1.0 , installed 3.1.0 Adapter "proxmox" : 2.6.3 , installed 2.6.3 Adapter "samsungtv" : 0.0.28 , installed 0.0.28 Adapter "script-restore": 0.1.13 , installed 0.1.13 Adapter "shelly" : 12.0.0 , installed 12.0.0 Adapter "smartthings" : 0.3.0 , installed 0.3.0 Adapter "sonoff" : 4.2.1 , installed 4.2.1 Adapter "sourceanalytix": 0.6.0 , installed 0.6.0 Adapter "tr-064" : 5.1.0 , installed 5.1.0 Adapter "tuya" : 3.18.2 , installed 3.18.2 Adapter "upnp" : 1.1.10 , installed 1.1.10 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.15.8 , installed 2.15.8 Adapter "web" : 9.1.9 , installed 9.1.9 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "wled" : 0.9.2 , installed 0.9.2 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 37571 States: 30965 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://security.debian.org trixie-security InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.178.100:43208 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=40)) udp UNCONN 0 0 192.168.178.100:45436 0.0.0.0:* users:(("io.samsungtv.0",pid=906,fd=30)) udp UNCONN 0 0 0.0.0.0:bootpc 0.0.0.0:* users:(("dhclient",pid=225,fd=7)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=93,fd=5),("systemd",pid=1,fd=35)) udp UNCONN 0 0 0.0.0.0:33652 0.0.0.0:* users:(("io.upnp.0",pid=1187,fd=30)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("io.upnp.0",pid=1187,fd=37)) udp UNCONN 0 0 192.168.178.100:4002 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=39)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.homekit-cont",pid=14823,fd=34)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.wled.0",pid=1090,fd=22)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=35)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=31)) udp UNCONN 0 0 0.0.0.0:5540 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=34)) udp UNCONN 0 0 0.0.0.0:6666 0.0.0.0:* users:(("io.tuya.0",pid=809,fd=32)) udp UNCONN 0 0 0.0.0.0:6667 0.0.0.0:* users:(("io.tuya.0",pid=809,fd=33)) udp UNCONN 0 0 192.168.178.100:56296 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=38)) udp UNCONN 0 0 0.0.0.0:57441 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=38)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=93,fd=7),("systemd",pid=1,fd=37)) udp UNCONN 0 0 *:50953 *:* users:(("io.bluelink.0",pid=11322,fd=36)) udp UNCONN 0 0 [::]:mdns [::]:* users:(("io.matter.0",pid=1042,fd=36)) udp UNCONN 0 0 [::]:mdns [::]:* users:(("io.matter.0",pid=1042,fd=32)) udp UNCONN 0 0 [::]:5540 [::]:* users:(("io.matter.0",pid=1042,fd=33)) udp UNCONN 0 0 [::]:57441 [::]:* users:(("io.matter.0",pid=1042,fd=37)) tcp LISTEN 0 511 192.168.178.100:1884 0.0.0.0:* users:(("io.sonoff.3",pid=777,fd=30)) tcp LISTEN 0 511 192.168.178.100:1880 0.0.0.0:* users:(("io.shelly.0",pid=10749,fd=77)) tcp LISTEN 0 511 192.168.178.100:1881 0.0.0.0:* users:(("io.sonoff.2",pid=753,fd=30)) tcp LISTEN 0 511 192.168.178.100:1882 0.0.0.0:* users:(("io.sonoff.1",pid=745,fd=30)) tcp LISTEN 0 511 192.168.178.100:1883 0.0.0.0:* users:(("io.sonoff.0",pid=712,fd=30)) tcp LISTEN 0 100 192.168.178.100:1888 0.0.0.0:* users:(("mosquitto",pid=927,fd=5)) tcp LISTEN 0 511 192.168.178.100:1890 0.0.0.0:* users:(("io.hoymiles-ms.",pid=1252,fd=30)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=93,fd=4),("systemd",pid=1,fd=34)) tcp LISTEN 0 511 192.168.178.100:tproxy 0.0.0.0:* users:(("io.admin.0",pid=341,fd=35)) tcp LISTEN 0 4096 127.0.0.1:omniorb 0.0.0.0:* users:(("influxd",pid=96,fd=3)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=97,fd=23)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=97,fd=29)) tcp LISTEN 0 100 127.0.0.1:smtp 0.0.0.0:* users:(("master",pid=303,fd=13)) tcp LISTEN 0 511 0.0.0.0:8400 0.0.0.0:* users:(("io.jarvis.0",pid=1023,fd=30)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=9949,fd=30)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=96,fd=20)) tcp LISTEN 0 4096 *:ssh *:* users:(("sshd",pid=123,fd=3),("systemd",pid=1,fd=58)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=93,fd=6),("systemd",pid=1,fd=36)) tcp LISTEN 0 100 [::1]:smtp [::]:* users:(("master",pid=303,fd=14)) tcp LISTEN 0 511 *:57441 *:* users:(("io.matter.0",pid=1042,fd=39)) *** Log File - Last 25 Lines *** 2026-09-30 18:58:02.158 - info: host.iobroker iobroker upload [7] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/react-dom-DrD5giaT.js assets/react-dom-DrD5giaT.js application/javascript 2026-09-30 18:58:02.164 - info: host.iobroker iobroker upload [6] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/react-okGu5lkI.js assets/react-okGu5lkI.js application/javascript 2026-09-30 18:58:02.172 - info: host.iobroker iobroker upload [5] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/recharts-DjhcjZm3.js assets/recharts-DjhcjZm3.js application/javascript 2026-09-30 18:58:02.180 - info: host.iobroker iobroker upload [4] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/router-CIdYoo77.js assets/router-CIdYoo77.js application/javascript 2026-09-30 18:58:02.186 - info: host.iobroker iobroker upload [3] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/sampleChartData-B8tY0lM6.js assets/sampleChartData-B8tY0lM6.js application/javascript 2026-09-30 18:58:02.196 - info: host.iobroker iobroker upload [2] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/useLayoutSetting-uK8wot69.js assets/useLayoutSetting-uK8wot69.js application/javascript 2026-09-30 18:58:02.207 - info: host.iobroker iobroker upload [1] aura /opt/iobroker/node_modules/iobroker.aura/www/favicon.svg favicon.svg image/svg+xml 2026-09-30 18:58:02.213 - info: host.iobroker iobroker upload [0] aura /opt/iobroker/node_modules/iobroker.aura/www/index.html index.html text/html 2026-09-30 18:58:02.221 - info: host.iobroker iobroker Updating objects from io-package.json for adapter "aura" with version "0.72.3" 2026-09-30 18:58:02.266 - info: host.iobroker iobroker Update "system.adapter.aura.0" 2026-09-30 18:58:02.274 - info: host.iobroker iobroker upload [13] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/aura.png aura.png image/png 2026-09-30 18:58:02.276 - info: host.iobroker iobroker upload [12] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/aura.svg aura.svg image/svg+xml 2026-09-30 18:58:02.279 - info: host.iobroker iobroker upload [11] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/de/translations.json i18n/de/translations.json application/json 2026-09-30 18:58:02.281 - info: host.iobroker iobroker upload [10] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/en/translations.json i18n/en/translations.json application/json 2026-09-30 18:58:02.284 - info: host.iobroker iobroker upload [9] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/es/translations.json i18n/es/translations.json application/json 2026-09-30 18:58:02.286 - info: host.iobroker iobroker upload [8] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/fr/translations.json i18n/fr/translations.json application/json 2026-09-30 18:58:02.289 - info: host.iobroker iobroker upload [7] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/it/translations.json i18n/it/translations.json application/json 2026-09-30 18:58:02.292 - info: host.iobroker iobroker upload [6] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/nl/translations.json i18n/nl/translations.json application/json 2026-09-30 18:58:02.294 - info: host.iobroker iobroker upload [5] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/pl/translations.json i18n/pl/translations.json application/json 2026-09-30 18:58:02.296 - info: host.iobroker iobroker upload [4] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/pt/translations.json i18n/pt/translations.json application/json 2026-09-30 18:58:02.297 - info: host.iobroker iobroker upload [3] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/ru/translations.json i18n/ru/translations.json application/json 2026-09-30 18:58:02.300 - info: host.iobroker iobroker upload [2] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/uk/translations.json i18n/uk/translations.json application/json 2026-09-30 18:58:02.302 - info: host.iobroker iobroker upload [1] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json 2026-09-30 18:58:02.304 - info: host.iobroker iobroker upload [0] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/jsonConfig.json jsonConfig.json application/json 2026-09-30 18:58:03.322 - info: host.iobroker iobroker exit 0 ============= Mark until here for C&P =============@Peter-V. Die habe ich auch, allerdings bei mir im docker
Ich habe auch auf Node.js 24 hoch gezogen.
Bekomme allerdings jetzt merkwürdige Meldungen beim aktualisieren von Adaptern.
Vielleich kann mir da einer weiter helfen?npm warn install-scripts cpu-features@0.0.10 (install: node-gyp rebuild)npm warn install-scripts diskusage@1.2.0 (install: node-gyp rebuild)npm warn install-scripts esbuild@0.11.23 (postinstall: node install.js)npm warn install-scripts @serialport/bindings-cpp@12.0.1 (install: node-gyp rebuild)npm warn install-scripts @stoprocent/bluetooth-hci-socket@1.5.2 (install: node-gyp rebuild)npm warn install-scripts @stoprocent/noble@1.19.1 (install: node-gyp rebuild)npm warn install-scripts iobroker.js-controller@7.2.3 (preinstall: node build/esm/lib/preinstallCheck.js; install: node iobroker.js setup first)npm warn install-scripts iobroker.vis@1.5.6 (install: node main.js --install)npm warn install-scripts protobufjs@7.6.5 (postinstall: node scripts/postinstall)npm warn install-scripts protobufjs@6.11.6 (postinstall: node scripts/postinstall)npm warn install-scripts sharp@0.32.6 (install: node-gyp rebuild)npm warn install-scripts ssh2@1.17.0 (install: node install.js)npm warn install-scripts unix-dgram@2.0.6 (install: node-gyp rebuild)npm warn install-scripts usb@2.18.0 (install: node-gyp rebuild)npm warn install-scripts @serialport/bindings-cpp@13.0.1 (install: node-gyp rebuild)npm warn install-scriptsnpm warn install-scripts Run `npm install-scripts ls` to review, or `npm install-scripts approve <pkg>` to allow.========== Start marking the full check here =========== bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: iobroker Icon name: computer-container Chassis: container ☐ Virtualization: lxc Kernel: Linux 7.0.14-19-pve Architecture: x86-64 OS is similar to: model name : Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : 64bit System was installed 50 days ago (on 2026-08-10). Systemuptime and Load: 18:59:19 up 2 days, 19:13, 1 user, load average: 1.21, 0.87, 0.85 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Wed 2026-09-30 18:59:19 CEST Universal time: Wed 2026-09-30 16:59:19 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': smarthome HOME=/home/smarthome GROUPS=smarthome adm tty dialout sudo audio video plugdev users ssh-users iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker adm tty dialout audio video plugdev bluetooth *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 12G 7.0G 3.4G 5.4M 2.6G 5.9G Swap: 1.1G 2.3M 1.1G Total: 13G 7.0G 4.4G Active iob-Instances: 49 12288 M total memory 6633 M used memory 3642 M active memory 5098 M inactive memory 3210 M free memory 0 M buffer memory 2449 M swap cache 1024 M total swap 2 M used swap 1021 M free swap *** top - Table Of Processes *** top - 18:59:20 up 2 days, 19:13, 1 user, load average: 1.21, 0.87, 0.85 Tasks: 84 total, 2 running, 82 sleeping, 0 stopped, 0 zombie %Cpu(s): 14.6 us, 0.0 sy, 0.0 ni, 85.4 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 12288.0 total, 3208.9 free, 6633.8 used, 2450.3 buff/cache MiB Swap: 1024.0 total, 1021.8 free, 2.2 used. 5654.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** dmesg: read kernel buffer failed: Operation not permitted No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/pve-vm--101--disk--0 ext4 25G 17G 6.3G 74% / none tmpfs 492K 4.0K 488K 1% /dev udev devtmpfs 15G 0 15G 0% /dev/tty tmpfs tmpfs 16G 0 16G 0% /dev/shm tmpfs tmpfs 6.2G 136K 6.2G 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 16G 5.2M 16G 1% /tmp tmpfs tmpfs 3.1G 8.0K 3.1G 1% /run/user/1001 Messages concerning filesystems in dmesg (Last 15 lines only): dmesg: read kernel buffer failed: Operation not permitted Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/pve-vm--101--disk--0 ext4 rw,relatime,stripe=128 Files in neuralgic directories: /var: 574M /var/ 207M /var/log/journal/6d3af4cac459428ab4e833a6d4a5ac24 207M /var/log/journal 207M /var/log 197M /var/lib Archived and active journals take up 206M in the file system. /opt/iobroker/backups: 6.2G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.2G /opt/iobroker/iobroker-data/ 498M /opt/iobroker/iobroker-data/files 265M /opt/iobroker/iobroker-data/backup-objects 218M /opt/iobroker/iobroker-data/history 200M /opt/iobroker/iobroker-data/files/aura The five largest files in iobroker-data are: 80M /opt/iobroker/iobroker-data/objects.jsonl 60M /opt/iobroker/iobroker-data/states.jsonl 30M /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map 16M /opt/iobroker/iobroker-data/files/matter.admin/assets/index-EdnNzxJx.js 12M /opt/iobroker/iobroker-data/jarvis/0/jarvis.0.devices.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ *** NodeJS-Installation *** /usr/bin/nodejs v24.21.0 /usr/bin/node v24.21.0 /usr/bin/npm 11.19.0 /usr/bin/npx 11.19.0 ✓ Node.js installation is correct nodejs: Installed: 24.21.0-1nodesource1 Candidate: 24.21.0-1nodesource1 Version table: *** 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u3 500 500 http://security.debian.org trixie-security/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker iobroker (version: 7.2.3, hostname: iobroker , alive, uptime: 241983) Core adapters versions js-controller: 7.2.3 admin: 8.0.20 javascript: 10.3.0 nodejs modules from github: 3 +-- iobroker.bambulab@0.4.3 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#b404a2395714df0ef34b13f0fd6c9309747ffead) +-- iobroker.device-watcher@2.15.17 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.device-watcher.git#6745c960560ea6f98ed8f69dc9c25e3aa006eb1c) +-- iobroker.fritzdect@2.6.4 (git+ssh://git@github.com/foxthefox/ioBroker.fritzdect.git#33c98148f41d4bdbc0472fe233e78fabc2c617d4) Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.100, run as: admin + system.adapter.alexa2.0 : alexa2 : iobroker - enabled system.adapter.aura.0 : aura : iobroker - disabled, port: 8095 + system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.bambulab.0 : bambulab : iobroker - enabled, port: 8883 + system.adapter.bluelink.0 : bluelink : iobroker - enabled + system.adapter.cloudless-homeconnect.0 : cloudless-homeconnect : iobroker - enabled + system.adapter.device-watcher.0 : device-watcher : iobroker - enabled system.adapter.devices.0 : devices : iobroker - disabled system.adapter.discovery.0 : discovery : iobroker - disabled + system.adapter.dreame.0 : dreame : iobroker - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : iobroker - enabled + system.adapter.fritzdect.0 : fritzdect : iobroker - enabled + system.adapter.govee-smart.0 : govee-smart : iobroker - enabled, port: 4002, bind: 192.168.178.100 system.adapter.harmony.0 : harmony : iobroker - disabled + system.adapter.history.0 : history : iobroker - enabled + system.adapter.homeconnect.0 : homeconnect : iobroker - enabled + system.adapter.homekit-controller.0 : homekit-controller : iobroker - enabled + system.adapter.hoymiles-ms.0 : hoymiles-ms : iobroker - enabled system.adapter.ical.0 : ical : iobroker - enabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.2 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.3 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.4 : influxdb : iobroker - enabled, port: 3001 + system.adapter.jarvis.0 : jarvis : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.matter.0 : matter : iobroker - enabled + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1888 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.notification-manager.0 : notification-manager : iobroker - enabled + system.adapter.octoprint.0 : octoprint : iobroker - enabled + system.adapter.opendtu.0 : opendtu : iobroker - enabled + system.adapter.proxmox.0 : proxmox : iobroker - enabled + system.adapter.samsungtv.0 : samsungtv : iobroker - enabled system.adapter.script-restore.0 : script-restore : iobroker - disabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1880, bind: 192.168.178.100 + system.adapter.smartthings.0 : smartthings : iobroker - enabled + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 192.168.178.100 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 192.168.178.100 + system.adapter.sonoff.2 : sonoff : iobroker - enabled, port: 1881, bind: 192.168.178.100 + system.adapter.sonoff.3 : sonoff : iobroker - enabled, port: 1884, bind: 192.168.178.100 + system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled + system.adapter.tr-064.0 : tr-064 : iobroker - enabled + system.adapter.tr-064.1 : tr-064 : iobroker - enabled + system.adapter.tr-064.2 : tr-064 : iobroker - enabled + system.adapter.tuya.0 : tuya : iobroker - enabled + system.adapter.upnp.0 : upnp : iobroker - enabled + system.adapter.vis-2.0 : vis-2 : iobroker - enabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - enabled + system.adapter.wled.0 : wled : iobroker - enabled + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.100, run as: admin + system.adapter.bambulab.0 : bambulab : iobroker - enabled, port: 8883 + system.adapter.govee-smart.0 : govee-smart : iobroker - enabled, port: 4002, bind: 192.168.178.100 + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.2 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.3 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.4 : influxdb : iobroker - enabled, port: 3001 + system.adapter.jarvis.0 : jarvis : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1888 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1880, bind: 192.168.178.100 + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 192.168.178.100 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 192.168.178.100 + system.adapter.sonoff.2 : sonoff : iobroker - enabled, port: 1881, bind: 192.168.178.100 + system.adapter.sonoff.3 : sonoff : iobroker - enabled, port: 1884, bind: 192.168.178.100 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB0 ioBroker-Repositories ┌─────────┬───────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼───────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ │ 2 │ 'live-Beta' │ 'http://iobroker.live/repo/sources-dist-latest.json' │ false │ │ 3 │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json' │ false │ └─────────┴───────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): beta Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬─────────────────────────────────────────┬──────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼─────────────────────────────────────────┼──────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '8.0.20' │ 'none' │ │ 1 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 2 │ 'system.adapter.aura' │ 'aura' │ '0.72.3' │ 'none' │ │ 3 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.4' │ 'none' │ │ 4 │ 'system.adapter.bambulab' │ 'bambulab' │ '0.4.3' │ 'none' │ │ 5 │ 'system.adapter.bluelink' │ 'bluelink' │ '3.1.34' │ 'none' │ │ 6 │ 'system.adapter.cloudless-homeconnect' │ 'cloudless-homeconnect' │ '1.7.0' │ 'none' │ │ 7 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 8 │ 'system.adapter.devices' │ 'devices' │ '4.2.2' │ 'none' │ │ 9 │ 'system.adapter.discovery' │ 'discovery' │ '5.1.1' │ 'none' │ │ 10 │ 'system.adapter.dreame' │ 'dreame' │ '0.4.12' │ 'none' │ │ 11 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.3' │ 'none' │ │ 12 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 13 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.4' │ 'none' │ │ 14 │ 'system.adapter.govee-smart' │ 'govee-smart' │ '3.0.1' │ 'none' │ │ 15 │ 'system.adapter.harmony' │ 'harmony' │ '3.0.0' │ 'none' │ │ 16 │ 'system.adapter.history' │ 'history' │ '5.0.1' │ 'none' │ │ 17 │ 'system.adapter.homeconnect' │ 'homeconnect' │ '1.6.1' │ 'none' │ │ 18 │ 'system.adapter.homekit-controller' │ 'homekit-controller' │ '0.5.11' │ 'none' │ │ 19 │ 'system.adapter.hoymiles-ms' │ 'hoymiles-ms' │ '0.2.2' │ 'none' │ │ 20 │ 'system.adapter.ical' │ 'ical' │ '1.21.1' │ 'none' │ │ 21 │ 'system.adapter.influxdb' │ 'influxdb' │ '5.0.3' │ 'none' │ │ 22 │ 'system.adapter.jarvis' │ 'jarvis' │ '3.1.8' │ 'none' │ │ 23 │ 'system.adapter.javascript' │ 'javascript' │ '10.3.0' │ 'none' │ │ 24 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 25 │ 'system.adapter.mcp' │ 'mcp' │ '1.1.0' │ 'none' │ │ 26 │ 'system.adapter.mqtt' │ 'mqtt' │ '8.1.0' │ 'none' │ │ 27 │ 'system.adapter.mqtt-client' │ 'mqtt-client' │ '4.1.0' │ 'none' │ │ 28 │ 'system.adapter.notification-manager' │ 'notification-manager' │ '1.3.0' │ 'none' │ │ 29 │ 'system.adapter.octoprint' │ 'octoprint' │ '7.0.0' │ 'none' │ │ 30 │ 'system.adapter.opendtu' │ 'opendtu' │ '3.1.0' │ 'none' │ │ 31 │ 'system.adapter.proxmox' │ 'proxmox' │ '2.6.3' │ 'none' │ │ 32 │ 'system.adapter.samsungtv' │ 'samsungtv' │ '0.0.28' │ 'none' │ │ 33 │ 'system.adapter.script-restore' │ 'script-restore' │ '0.1.13' │ 'none' │ │ 34 │ 'system.adapter.shelly' │ 'shelly' │ '12.0.0' │ 'none' │ │ 35 │ 'system.adapter.smartthings' │ 'smartthings' │ '0.3.0' │ 'none' │ │ 36 │ 'system.adapter.socketio' │ 'socketio' │ '8.0.1' │ 'none' │ │ 37 │ 'system.adapter.sonoff' │ 'sonoff' │ '4.2.1' │ 'none' │ │ 38 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.6.0' │ 'none' │ │ 39 │ 'system.adapter.tr-064' │ 'tr-064' │ '5.1.0' │ 'none' │ │ 40 │ 'system.adapter.tuya' │ 'tuya' │ '3.18.2' │ 'none' │ │ 41 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.10' │ 'none' │ │ 42 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 43 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.15.8' │ 'none' │ │ 44 │ 'system.adapter.web' │ 'web' │ '9.1.9' │ 'none' │ │ 45 │ 'system.adapter.whatsapp-cmb' │ 'whatsapp-cmb' │ '0.3.0' │ 'none' │ │ 46 │ 'system.adapter.wled' │ 'wled' │ '0.9.2' │ 'none' │ │ 47 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴─────────────────────────────────────────┴──────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: beta Adapter "admin" : 8.0.21 , installed 8.0.20 [Updatable] Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "aura" : 0.72.3 , installed 0.72.3 Adapter "backitup" : 4.0.4 , installed 4.0.4 Adapter "bambulab" : 0.4.3 , installed 0.4.3 Adapter "bluelink" : 3.1.34 , installed 3.1.34 Adapter "cloudless-homeconnect": 1.7.0, installed 1.7.0 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 4.2.2 , installed 4.2.2 Adapter "discovery" : 5.1.1 , installed 5.1.1 Adapter "dreame" : 0.4.12 , installed 0.4.12 Adapter "energiefluss-erweitert": 0.8.3, installed 0.8.3 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fritzdect" : 2.6.2 , installed 2.6.4 Adapter "govee-smart" : 3.0.1 , installed 3.0.1 Adapter "harmony" : 3.0.0 , installed 3.0.0 Adapter "history" : 5.0.1 , installed 5.0.1 Adapter "homeconnect" : 1.6.1 , installed 1.6.1 Adapter "homekit-controller": 0.5.11, installed 0.5.11 Adapter "hoymiles-ms" : 0.2.2 , installed 0.2.2 Adapter "ical" : 1.21.1 , installed 1.21.1 Adapter "influxdb" : 5.0.3 , installed 5.0.3 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 10.3.0 , installed 10.3.0 Controller "js-controller": 7.2.3 , installed 7.2.3 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 8.1.0 , installed 8.1.0 Adapter "mqtt-client" : 4.1.0 , installed 4.1.0 Adapter "notification-manager": 1.3.0, installed 1.3.0 Adapter "octoprint" : 7.0.0 , installed 7.0.0 Adapter "opendtu" : 3.1.0 , installed 3.1.0 Adapter "proxmox" : 2.6.3 , installed 2.6.3 Adapter "samsungtv" : 0.0.28 , installed 0.0.28 Adapter "script-restore": 0.1.13 , installed 0.1.13 Adapter "shelly" : 12.0.0 , installed 12.0.0 Adapter "smartthings" : 0.3.0 , installed 0.3.0 Adapter "sonoff" : 4.2.1 , installed 4.2.1 Adapter "sourceanalytix": 0.6.0 , installed 0.6.0 Adapter "tr-064" : 5.1.0 , installed 5.1.0 Adapter "tuya" : 3.18.2 , installed 3.18.2 Adapter "upnp" : 1.1.10 , installed 1.1.10 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.15.8 , installed 2.15.8 Adapter "web" : 9.1.9 , installed 9.1.9 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "wled" : 0.9.2 , installed 0.9.2 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 37571 States: 30965 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://security.debian.org trixie-security InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.178.100:43208 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=40)) udp UNCONN 0 0 192.168.178.100:45436 0.0.0.0:* users:(("io.samsungtv.0",pid=906,fd=30)) udp UNCONN 0 0 0.0.0.0:bootpc 0.0.0.0:* users:(("dhclient",pid=225,fd=7)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=93,fd=5),("systemd",pid=1,fd=35)) udp UNCONN 0 0 0.0.0.0:33652 0.0.0.0:* users:(("io.upnp.0",pid=1187,fd=30)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("io.upnp.0",pid=1187,fd=37)) udp UNCONN 0 0 192.168.178.100:4002 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=39)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.homekit-cont",pid=14823,fd=34)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.wled.0",pid=1090,fd=22)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=35)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=31)) udp UNCONN 0 0 0.0.0.0:5540 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=34)) udp UNCONN 0 0 0.0.0.0:6666 0.0.0.0:* users:(("io.tuya.0",pid=809,fd=32)) udp UNCONN 0 0 0.0.0.0:6667 0.0.0.0:* users:(("io.tuya.0",pid=809,fd=33)) udp UNCONN 0 0 192.168.178.100:56296 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=38)) udp UNCONN 0 0 0.0.0.0:57441 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=38)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=93,fd=7),("systemd",pid=1,fd=37)) udp UNCONN 0 0 *:50953 *:* users:(("io.bluelink.0",pid=11322,fd=36)) udp UNCONN 0 0 [::]:mdns [::]:* users:(("io.matter.0",pid=1042,fd=36)) udp UNCONN 0 0 [::]:mdns [::]:* users:(("io.matter.0",pid=1042,fd=32)) udp UNCONN 0 0 [::]:5540 [::]:* users:(("io.matter.0",pid=1042,fd=33)) udp UNCONN 0 0 [::]:57441 [::]:* users:(("io.matter.0",pid=1042,fd=37)) tcp LISTEN 0 511 192.168.178.100:1884 0.0.0.0:* users:(("io.sonoff.3",pid=777,fd=30)) tcp LISTEN 0 511 192.168.178.100:1880 0.0.0.0:* users:(("io.shelly.0",pid=10749,fd=77)) tcp LISTEN 0 511 192.168.178.100:1881 0.0.0.0:* users:(("io.sonoff.2",pid=753,fd=30)) tcp LISTEN 0 511 192.168.178.100:1882 0.0.0.0:* users:(("io.sonoff.1",pid=745,fd=30)) tcp LISTEN 0 511 192.168.178.100:1883 0.0.0.0:* users:(("io.sonoff.0",pid=712,fd=30)) tcp LISTEN 0 100 192.168.178.100:1888 0.0.0.0:* users:(("mosquitto",pid=927,fd=5)) tcp LISTEN 0 511 192.168.178.100:1890 0.0.0.0:* users:(("io.hoymiles-ms.",pid=1252,fd=30)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=93,fd=4),("systemd",pid=1,fd=34)) tcp LISTEN 0 511 192.168.178.100:tproxy 0.0.0.0:* users:(("io.admin.0",pid=341,fd=35)) tcp LISTEN 0 4096 127.0.0.1:omniorb 0.0.0.0:* users:(("influxd",pid=96,fd=3)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=97,fd=23)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=97,fd=29)) tcp LISTEN 0 100 127.0.0.1:smtp 0.0.0.0:* users:(("master",pid=303,fd=13)) tcp LISTEN 0 511 0.0.0.0:8400 0.0.0.0:* users:(("io.jarvis.0",pid=1023,fd=30)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=9949,fd=30)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=96,fd=20)) tcp LISTEN 0 4096 *:ssh *:* users:(("sshd",pid=123,fd=3),("systemd",pid=1,fd=58)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=93,fd=6),("systemd",pid=1,fd=36)) tcp LISTEN 0 100 [::1]:smtp [::]:* users:(("master",pid=303,fd=14)) tcp LISTEN 0 511 *:57441 *:* users:(("io.matter.0",pid=1042,fd=39)) *** Log File - Last 25 Lines *** 2026-09-30 18:58:02.158 - info: host.iobroker iobroker upload [7] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/react-dom-DrD5giaT.js assets/react-dom-DrD5giaT.js application/javascript 2026-09-30 18:58:02.164 - info: host.iobroker iobroker upload [6] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/react-okGu5lkI.js assets/react-okGu5lkI.js application/javascript 2026-09-30 18:58:02.172 - info: host.iobroker iobroker upload [5] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/recharts-DjhcjZm3.js assets/recharts-DjhcjZm3.js application/javascript 2026-09-30 18:58:02.180 - info: host.iobroker iobroker upload [4] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/router-CIdYoo77.js assets/router-CIdYoo77.js application/javascript 2026-09-30 18:58:02.186 - info: host.iobroker iobroker upload [3] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/sampleChartData-B8tY0lM6.js assets/sampleChartData-B8tY0lM6.js application/javascript 2026-09-30 18:58:02.196 - info: host.iobroker iobroker upload [2] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/useLayoutSetting-uK8wot69.js assets/useLayoutSetting-uK8wot69.js application/javascript 2026-09-30 18:58:02.207 - info: host.iobroker iobroker upload [1] aura /opt/iobroker/node_modules/iobroker.aura/www/favicon.svg favicon.svg image/svg+xml 2026-09-30 18:58:02.213 - info: host.iobroker iobroker upload [0] aura /opt/iobroker/node_modules/iobroker.aura/www/index.html index.html text/html 2026-09-30 18:58:02.221 - info: host.iobroker iobroker Updating objects from io-package.json for adapter "aura" with version "0.72.3" 2026-09-30 18:58:02.266 - info: host.iobroker iobroker Update "system.adapter.aura.0" 2026-09-30 18:58:02.274 - info: host.iobroker iobroker upload [13] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/aura.png aura.png image/png 2026-09-30 18:58:02.276 - info: host.iobroker iobroker upload [12] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/aura.svg aura.svg image/svg+xml 2026-09-30 18:58:02.279 - info: host.iobroker iobroker upload [11] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/de/translations.json i18n/de/translations.json application/json 2026-09-30 18:58:02.281 - info: host.iobroker iobroker upload [10] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/en/translations.json i18n/en/translations.json application/json 2026-09-30 18:58:02.284 - info: host.iobroker iobroker upload [9] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/es/translations.json i18n/es/translations.json application/json 2026-09-30 18:58:02.286 - info: host.iobroker iobroker upload [8] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/fr/translations.json i18n/fr/translations.json application/json 2026-09-30 18:58:02.289 - info: host.iobroker iobroker upload [7] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/it/translations.json i18n/it/translations.json application/json 2026-09-30 18:58:02.292 - info: host.iobroker iobroker upload [6] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/nl/translations.json i18n/nl/translations.json application/json 2026-09-30 18:58:02.294 - info: host.iobroker iobroker upload [5] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/pl/translations.json i18n/pl/translations.json application/json 2026-09-30 18:58:02.296 - info: host.iobroker iobroker upload [4] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/pt/translations.json i18n/pt/translations.json application/json 2026-09-30 18:58:02.297 - info: host.iobroker iobroker upload [3] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/ru/translations.json i18n/ru/translations.json application/json 2026-09-30 18:58:02.300 - info: host.iobroker iobroker upload [2] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/uk/translations.json i18n/uk/translations.json application/json 2026-09-30 18:58:02.302 - info: host.iobroker iobroker upload [1] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json 2026-09-30 18:58:02.304 - info: host.iobroker iobroker upload [0] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/jsonConfig.json jsonConfig.json application/json 2026-09-30 18:58:03.322 - info: host.iobroker iobroker exit 0 ============= Mark until here for C&P =============Vielleich kann mir da einer weiter helfen?
Ja, das hängt mit einem neuen Sicherheitsfeature von npm zusammen. Es werden erstmal keine Skripte mehr von node-Modulen zur Laufzeit geladen.
Schau dir per
cd /opt/iobroker && npm install-scripts lsan was da einer Freigabe harrt. Das Paket muss dann damit behandelt werden:
npm install-scripts approve <pkg><pkg> dann halt durch das entsprechende Paket ersetzen.
Edit: Soweit ich das verstanden habe wird das aber erst mit npm12 'scharf geschaltet', bei npm 11 ist es zur Zeit nur eine Anzeige und dient zum testen.
oh, danke, da steht einiges...
21 packages have install scripts not yet covered by allowScripts: @serialport/bindings-cpp@13.0.0 (install: node-gyp rebuild) @stoprocent/bleno@0.12.5 (install: node-gyp rebuild) @stoprocent/bluetooth-hci-socket@2.3.0 (install: node-gyp rebuild) @serialport/bindings-cpp@12.0.1 (install: node-gyp rebuild) @stoprocent/noble@2.8.0 (install: node-gyp rebuild) canvas@3.2.3 (install: node-gyp rebuild) cpu-features@0.0.10 (install: node-gyp rebuild) diskusage@1.2.0 (install: node-gyp rebuild) esbuild@0.11.23 (postinstall: node install.js) @serialport/bindings-cpp@12.0.1 (install: node-gyp rebuild) @stoprocent/bluetooth-hci-socket@1.5.2 (install: node-gyp rebuild) @stoprocent/noble@1.19.1 (install: node-gyp rebuild) iobroker.js-controller@7.2.3 (preinstall: node build/esm/lib/preinstallCheck.js; install: node iobroker.js setup first) iobroker.vis@1.5.6 (install: node main.js --install) protobufjs@7.6.5 (postinstall: node scripts/postinstall) protobufjs@6.11.6 (postinstall: node scripts/postinstall) sharp@0.32.6 (install: node-gyp rebuild) ssh2@1.17.0 (install: node install.js) unix-dgram@2.0.6 (install: node-gyp rebuild) usb@2.18.0 (install: node-gyp rebuild) @serialport/bindings-cpp@13.0.1 (install: node-gyp rebuild) -
Vielleich kann mir da einer weiter helfen?npm warn install-scripts cpu-features@0.0.10 (install: node-gyp rebuild)npm warn install-scripts diskusage@1.2.0 (install: node-gyp rebuild)npm warn install-scripts esbuild@0.11.23 (postinstall: node install.js)npm warn install-scripts @serialport/bindings-cpp@12.0.1 (install: node-gyp rebuild)npm warn install-scripts @stoprocent/bluetooth-hci-socket@1.5.2 (install: node-gyp rebuild)npm warn install-scripts @stoprocent/noble@1.19.1 (install: node-gyp rebuild)npm warn install-scripts iobroker.js-controller@7.2.3 (preinstall: node build/esm/lib/preinstallCheck.js; install: node iobroker.js setup first)npm warn install-scripts iobroker.vis@1.5.6 (install: node main.js --install)npm warn install-scripts protobufjs@7.6.5 (postinstall: node scripts/postinstall)npm warn install-scripts protobufjs@6.11.6 (postinstall: node scripts/postinstall)npm warn install-scripts sharp@0.32.6 (install: node-gyp rebuild)npm warn install-scripts ssh2@1.17.0 (install: node install.js)npm warn install-scripts unix-dgram@2.0.6 (install: node-gyp rebuild)npm warn install-scripts usb@2.18.0 (install: node-gyp rebuild)npm warn install-scripts @serialport/bindings-cpp@13.0.1 (install: node-gyp rebuild)npm warn install-scriptsnpm warn install-scripts Run `npm install-scripts ls` to review, or `npm install-scripts approve <pkg>` to allow.========== Start marking the full check here =========== bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: iobroker Icon name: computer-container Chassis: container ☐ Virtualization: lxc Kernel: Linux 7.0.14-19-pve Architecture: x86-64 OS is similar to: model name : Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : 64bit System was installed 50 days ago (on 2026-08-10). Systemuptime and Load: 18:59:19 up 2 days, 19:13, 1 user, load average: 1.21, 0.87, 0.85 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Wed 2026-09-30 18:59:19 CEST Universal time: Wed 2026-09-30 16:59:19 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': smarthome HOME=/home/smarthome GROUPS=smarthome adm tty dialout sudo audio video plugdev users ssh-users iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker adm tty dialout audio video plugdev bluetooth *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 12G 7.0G 3.4G 5.4M 2.6G 5.9G Swap: 1.1G 2.3M 1.1G Total: 13G 7.0G 4.4G Active iob-Instances: 49 12288 M total memory 6633 M used memory 3642 M active memory 5098 M inactive memory 3210 M free memory 0 M buffer memory 2449 M swap cache 1024 M total swap 2 M used swap 1021 M free swap *** top - Table Of Processes *** top - 18:59:20 up 2 days, 19:13, 1 user, load average: 1.21, 0.87, 0.85 Tasks: 84 total, 2 running, 82 sleeping, 0 stopped, 0 zombie %Cpu(s): 14.6 us, 0.0 sy, 0.0 ni, 85.4 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 12288.0 total, 3208.9 free, 6633.8 used, 2450.3 buff/cache MiB Swap: 1024.0 total, 1021.8 free, 2.2 used. 5654.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** dmesg: read kernel buffer failed: Operation not permitted No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/pve-vm--101--disk--0 ext4 25G 17G 6.3G 74% / none tmpfs 492K 4.0K 488K 1% /dev udev devtmpfs 15G 0 15G 0% /dev/tty tmpfs tmpfs 16G 0 16G 0% /dev/shm tmpfs tmpfs 6.2G 136K 6.2G 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 16G 5.2M 16G 1% /tmp tmpfs tmpfs 3.1G 8.0K 3.1G 1% /run/user/1001 Messages concerning filesystems in dmesg (Last 15 lines only): dmesg: read kernel buffer failed: Operation not permitted Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/pve-vm--101--disk--0 ext4 rw,relatime,stripe=128 Files in neuralgic directories: /var: 574M /var/ 207M /var/log/journal/6d3af4cac459428ab4e833a6d4a5ac24 207M /var/log/journal 207M /var/log 197M /var/lib Archived and active journals take up 206M in the file system. /opt/iobroker/backups: 6.2G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.2G /opt/iobroker/iobroker-data/ 498M /opt/iobroker/iobroker-data/files 265M /opt/iobroker/iobroker-data/backup-objects 218M /opt/iobroker/iobroker-data/history 200M /opt/iobroker/iobroker-data/files/aura The five largest files in iobroker-data are: 80M /opt/iobroker/iobroker-data/objects.jsonl 60M /opt/iobroker/iobroker-data/states.jsonl 30M /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map 16M /opt/iobroker/iobroker-data/files/matter.admin/assets/index-EdnNzxJx.js 12M /opt/iobroker/iobroker-data/jarvis/0/jarvis.0.devices.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ *** NodeJS-Installation *** /usr/bin/nodejs v24.21.0 /usr/bin/node v24.21.0 /usr/bin/npm 11.19.0 /usr/bin/npx 11.19.0 ✓ Node.js installation is correct nodejs: Installed: 24.21.0-1nodesource1 Candidate: 24.21.0-1nodesource1 Version table: *** 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u3 500 500 http://security.debian.org trixie-security/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker iobroker (version: 7.2.3, hostname: iobroker , alive, uptime: 241983) Core adapters versions js-controller: 7.2.3 admin: 8.0.20 javascript: 10.3.0 nodejs modules from github: 3 +-- iobroker.bambulab@0.4.3 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#b404a2395714df0ef34b13f0fd6c9309747ffead) +-- iobroker.device-watcher@2.15.17 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.device-watcher.git#6745c960560ea6f98ed8f69dc9c25e3aa006eb1c) +-- iobroker.fritzdect@2.6.4 (git+ssh://git@github.com/foxthefox/ioBroker.fritzdect.git#33c98148f41d4bdbc0472fe233e78fabc2c617d4) Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.100, run as: admin + system.adapter.alexa2.0 : alexa2 : iobroker - enabled system.adapter.aura.0 : aura : iobroker - disabled, port: 8095 + system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.bambulab.0 : bambulab : iobroker - enabled, port: 8883 + system.adapter.bluelink.0 : bluelink : iobroker - enabled + system.adapter.cloudless-homeconnect.0 : cloudless-homeconnect : iobroker - enabled + system.adapter.device-watcher.0 : device-watcher : iobroker - enabled system.adapter.devices.0 : devices : iobroker - disabled system.adapter.discovery.0 : discovery : iobroker - disabled + system.adapter.dreame.0 : dreame : iobroker - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : iobroker - enabled + system.adapter.fritzdect.0 : fritzdect : iobroker - enabled + system.adapter.govee-smart.0 : govee-smart : iobroker - enabled, port: 4002, bind: 192.168.178.100 system.adapter.harmony.0 : harmony : iobroker - disabled + system.adapter.history.0 : history : iobroker - enabled + system.adapter.homeconnect.0 : homeconnect : iobroker - enabled + system.adapter.homekit-controller.0 : homekit-controller : iobroker - enabled + system.adapter.hoymiles-ms.0 : hoymiles-ms : iobroker - enabled system.adapter.ical.0 : ical : iobroker - enabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.2 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.3 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.4 : influxdb : iobroker - enabled, port: 3001 + system.adapter.jarvis.0 : jarvis : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.matter.0 : matter : iobroker - enabled + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1888 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.notification-manager.0 : notification-manager : iobroker - enabled + system.adapter.octoprint.0 : octoprint : iobroker - enabled + system.adapter.opendtu.0 : opendtu : iobroker - enabled + system.adapter.proxmox.0 : proxmox : iobroker - enabled + system.adapter.samsungtv.0 : samsungtv : iobroker - enabled system.adapter.script-restore.0 : script-restore : iobroker - disabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1880, bind: 192.168.178.100 + system.adapter.smartthings.0 : smartthings : iobroker - enabled + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 192.168.178.100 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 192.168.178.100 + system.adapter.sonoff.2 : sonoff : iobroker - enabled, port: 1881, bind: 192.168.178.100 + system.adapter.sonoff.3 : sonoff : iobroker - enabled, port: 1884, bind: 192.168.178.100 + system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled + system.adapter.tr-064.0 : tr-064 : iobroker - enabled + system.adapter.tr-064.1 : tr-064 : iobroker - enabled + system.adapter.tr-064.2 : tr-064 : iobroker - enabled + system.adapter.tuya.0 : tuya : iobroker - enabled + system.adapter.upnp.0 : upnp : iobroker - enabled + system.adapter.vis-2.0 : vis-2 : iobroker - enabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - enabled + system.adapter.wled.0 : wled : iobroker - enabled + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.100, run as: admin + system.adapter.bambulab.0 : bambulab : iobroker - enabled, port: 8883 + system.adapter.govee-smart.0 : govee-smart : iobroker - enabled, port: 4002, bind: 192.168.178.100 + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.2 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.3 : influxdb : iobroker - enabled, port: 3001 + system.adapter.influxdb.4 : influxdb : iobroker - enabled, port: 3001 + system.adapter.jarvis.0 : jarvis : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1888 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1880, bind: 192.168.178.100 + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 192.168.178.100 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 192.168.178.100 + system.adapter.sonoff.2 : sonoff : iobroker - enabled, port: 1881, bind: 192.168.178.100 + system.adapter.sonoff.3 : sonoff : iobroker - enabled, port: 1884, bind: 192.168.178.100 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB0 ioBroker-Repositories ┌─────────┬───────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼───────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ │ 2 │ 'live-Beta' │ 'http://iobroker.live/repo/sources-dist-latest.json' │ false │ │ 3 │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json' │ false │ └─────────┴───────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): beta Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬─────────────────────────────────────────┬──────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼─────────────────────────────────────────┼──────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '8.0.20' │ 'none' │ │ 1 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 2 │ 'system.adapter.aura' │ 'aura' │ '0.72.3' │ 'none' │ │ 3 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.4' │ 'none' │ │ 4 │ 'system.adapter.bambulab' │ 'bambulab' │ '0.4.3' │ 'none' │ │ 5 │ 'system.adapter.bluelink' │ 'bluelink' │ '3.1.34' │ 'none' │ │ 6 │ 'system.adapter.cloudless-homeconnect' │ 'cloudless-homeconnect' │ '1.7.0' │ 'none' │ │ 7 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 8 │ 'system.adapter.devices' │ 'devices' │ '4.2.2' │ 'none' │ │ 9 │ 'system.adapter.discovery' │ 'discovery' │ '5.1.1' │ 'none' │ │ 10 │ 'system.adapter.dreame' │ 'dreame' │ '0.4.12' │ 'none' │ │ 11 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.3' │ 'none' │ │ 12 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 13 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.4' │ 'none' │ │ 14 │ 'system.adapter.govee-smart' │ 'govee-smart' │ '3.0.1' │ 'none' │ │ 15 │ 'system.adapter.harmony' │ 'harmony' │ '3.0.0' │ 'none' │ │ 16 │ 'system.adapter.history' │ 'history' │ '5.0.1' │ 'none' │ │ 17 │ 'system.adapter.homeconnect' │ 'homeconnect' │ '1.6.1' │ 'none' │ │ 18 │ 'system.adapter.homekit-controller' │ 'homekit-controller' │ '0.5.11' │ 'none' │ │ 19 │ 'system.adapter.hoymiles-ms' │ 'hoymiles-ms' │ '0.2.2' │ 'none' │ │ 20 │ 'system.adapter.ical' │ 'ical' │ '1.21.1' │ 'none' │ │ 21 │ 'system.adapter.influxdb' │ 'influxdb' │ '5.0.3' │ 'none' │ │ 22 │ 'system.adapter.jarvis' │ 'jarvis' │ '3.1.8' │ 'none' │ │ 23 │ 'system.adapter.javascript' │ 'javascript' │ '10.3.0' │ 'none' │ │ 24 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 25 │ 'system.adapter.mcp' │ 'mcp' │ '1.1.0' │ 'none' │ │ 26 │ 'system.adapter.mqtt' │ 'mqtt' │ '8.1.0' │ 'none' │ │ 27 │ 'system.adapter.mqtt-client' │ 'mqtt-client' │ '4.1.0' │ 'none' │ │ 28 │ 'system.adapter.notification-manager' │ 'notification-manager' │ '1.3.0' │ 'none' │ │ 29 │ 'system.adapter.octoprint' │ 'octoprint' │ '7.0.0' │ 'none' │ │ 30 │ 'system.adapter.opendtu' │ 'opendtu' │ '3.1.0' │ 'none' │ │ 31 │ 'system.adapter.proxmox' │ 'proxmox' │ '2.6.3' │ 'none' │ │ 32 │ 'system.adapter.samsungtv' │ 'samsungtv' │ '0.0.28' │ 'none' │ │ 33 │ 'system.adapter.script-restore' │ 'script-restore' │ '0.1.13' │ 'none' │ │ 34 │ 'system.adapter.shelly' │ 'shelly' │ '12.0.0' │ 'none' │ │ 35 │ 'system.adapter.smartthings' │ 'smartthings' │ '0.3.0' │ 'none' │ │ 36 │ 'system.adapter.socketio' │ 'socketio' │ '8.0.1' │ 'none' │ │ 37 │ 'system.adapter.sonoff' │ 'sonoff' │ '4.2.1' │ 'none' │ │ 38 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.6.0' │ 'none' │ │ 39 │ 'system.adapter.tr-064' │ 'tr-064' │ '5.1.0' │ 'none' │ │ 40 │ 'system.adapter.tuya' │ 'tuya' │ '3.18.2' │ 'none' │ │ 41 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.10' │ 'none' │ │ 42 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 43 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.15.8' │ 'none' │ │ 44 │ 'system.adapter.web' │ 'web' │ '9.1.9' │ 'none' │ │ 45 │ 'system.adapter.whatsapp-cmb' │ 'whatsapp-cmb' │ '0.3.0' │ 'none' │ │ 46 │ 'system.adapter.wled' │ 'wled' │ '0.9.2' │ 'none' │ │ 47 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴─────────────────────────────────────────┴──────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: beta Adapter "admin" : 8.0.21 , installed 8.0.20 [Updatable] Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "aura" : 0.72.3 , installed 0.72.3 Adapter "backitup" : 4.0.4 , installed 4.0.4 Adapter "bambulab" : 0.4.3 , installed 0.4.3 Adapter "bluelink" : 3.1.34 , installed 3.1.34 Adapter "cloudless-homeconnect": 1.7.0, installed 1.7.0 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 4.2.2 , installed 4.2.2 Adapter "discovery" : 5.1.1 , installed 5.1.1 Adapter "dreame" : 0.4.12 , installed 0.4.12 Adapter "energiefluss-erweitert": 0.8.3, installed 0.8.3 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fritzdect" : 2.6.2 , installed 2.6.4 Adapter "govee-smart" : 3.0.1 , installed 3.0.1 Adapter "harmony" : 3.0.0 , installed 3.0.0 Adapter "history" : 5.0.1 , installed 5.0.1 Adapter "homeconnect" : 1.6.1 , installed 1.6.1 Adapter "homekit-controller": 0.5.11, installed 0.5.11 Adapter "hoymiles-ms" : 0.2.2 , installed 0.2.2 Adapter "ical" : 1.21.1 , installed 1.21.1 Adapter "influxdb" : 5.0.3 , installed 5.0.3 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 10.3.0 , installed 10.3.0 Controller "js-controller": 7.2.3 , installed 7.2.3 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 8.1.0 , installed 8.1.0 Adapter "mqtt-client" : 4.1.0 , installed 4.1.0 Adapter "notification-manager": 1.3.0, installed 1.3.0 Adapter "octoprint" : 7.0.0 , installed 7.0.0 Adapter "opendtu" : 3.1.0 , installed 3.1.0 Adapter "proxmox" : 2.6.3 , installed 2.6.3 Adapter "samsungtv" : 0.0.28 , installed 0.0.28 Adapter "script-restore": 0.1.13 , installed 0.1.13 Adapter "shelly" : 12.0.0 , installed 12.0.0 Adapter "smartthings" : 0.3.0 , installed 0.3.0 Adapter "sonoff" : 4.2.1 , installed 4.2.1 Adapter "sourceanalytix": 0.6.0 , installed 0.6.0 Adapter "tr-064" : 5.1.0 , installed 5.1.0 Adapter "tuya" : 3.18.2 , installed 3.18.2 Adapter "upnp" : 1.1.10 , installed 1.1.10 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.15.8 , installed 2.15.8 Adapter "web" : 9.1.9 , installed 9.1.9 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "wled" : 0.9.2 , installed 0.9.2 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 37571 States: 30965 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://security.debian.org trixie-security InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.178.100:43208 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=40)) udp UNCONN 0 0 192.168.178.100:45436 0.0.0.0:* users:(("io.samsungtv.0",pid=906,fd=30)) udp UNCONN 0 0 0.0.0.0:bootpc 0.0.0.0:* users:(("dhclient",pid=225,fd=7)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=93,fd=5),("systemd",pid=1,fd=35)) udp UNCONN 0 0 0.0.0.0:33652 0.0.0.0:* users:(("io.upnp.0",pid=1187,fd=30)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("io.upnp.0",pid=1187,fd=37)) udp UNCONN 0 0 192.168.178.100:4002 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=39)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.homekit-cont",pid=14823,fd=34)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.wled.0",pid=1090,fd=22)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=35)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=31)) udp UNCONN 0 0 0.0.0.0:5540 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=34)) udp UNCONN 0 0 0.0.0.0:6666 0.0.0.0:* users:(("io.tuya.0",pid=809,fd=32)) udp UNCONN 0 0 0.0.0.0:6667 0.0.0.0:* users:(("io.tuya.0",pid=809,fd=33)) udp UNCONN 0 0 192.168.178.100:56296 0.0.0.0:* users:(("io.govee-smart.",pid=9861,fd=38)) udp UNCONN 0 0 0.0.0.0:57441 0.0.0.0:* users:(("io.matter.0",pid=1042,fd=38)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=93,fd=7),("systemd",pid=1,fd=37)) udp UNCONN 0 0 *:50953 *:* users:(("io.bluelink.0",pid=11322,fd=36)) udp UNCONN 0 0 [::]:mdns [::]:* users:(("io.matter.0",pid=1042,fd=36)) udp UNCONN 0 0 [::]:mdns [::]:* users:(("io.matter.0",pid=1042,fd=32)) udp UNCONN 0 0 [::]:5540 [::]:* users:(("io.matter.0",pid=1042,fd=33)) udp UNCONN 0 0 [::]:57441 [::]:* users:(("io.matter.0",pid=1042,fd=37)) tcp LISTEN 0 511 192.168.178.100:1884 0.0.0.0:* users:(("io.sonoff.3",pid=777,fd=30)) tcp LISTEN 0 511 192.168.178.100:1880 0.0.0.0:* users:(("io.shelly.0",pid=10749,fd=77)) tcp LISTEN 0 511 192.168.178.100:1881 0.0.0.0:* users:(("io.sonoff.2",pid=753,fd=30)) tcp LISTEN 0 511 192.168.178.100:1882 0.0.0.0:* users:(("io.sonoff.1",pid=745,fd=30)) tcp LISTEN 0 511 192.168.178.100:1883 0.0.0.0:* users:(("io.sonoff.0",pid=712,fd=30)) tcp LISTEN 0 100 192.168.178.100:1888 0.0.0.0:* users:(("mosquitto",pid=927,fd=5)) tcp LISTEN 0 511 192.168.178.100:1890 0.0.0.0:* users:(("io.hoymiles-ms.",pid=1252,fd=30)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=93,fd=4),("systemd",pid=1,fd=34)) tcp LISTEN 0 511 192.168.178.100:tproxy 0.0.0.0:* users:(("io.admin.0",pid=341,fd=35)) tcp LISTEN 0 4096 127.0.0.1:omniorb 0.0.0.0:* users:(("influxd",pid=96,fd=3)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=97,fd=23)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=97,fd=29)) tcp LISTEN 0 100 127.0.0.1:smtp 0.0.0.0:* users:(("master",pid=303,fd=13)) tcp LISTEN 0 511 0.0.0.0:8400 0.0.0.0:* users:(("io.jarvis.0",pid=1023,fd=30)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=9949,fd=30)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=96,fd=20)) tcp LISTEN 0 4096 *:ssh *:* users:(("sshd",pid=123,fd=3),("systemd",pid=1,fd=58)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=93,fd=6),("systemd",pid=1,fd=36)) tcp LISTEN 0 100 [::1]:smtp [::]:* users:(("master",pid=303,fd=14)) tcp LISTEN 0 511 *:57441 *:* users:(("io.matter.0",pid=1042,fd=39)) *** Log File - Last 25 Lines *** 2026-09-30 18:58:02.158 - info: host.iobroker iobroker upload [7] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/react-dom-DrD5giaT.js assets/react-dom-DrD5giaT.js application/javascript 2026-09-30 18:58:02.164 - info: host.iobroker iobroker upload [6] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/react-okGu5lkI.js assets/react-okGu5lkI.js application/javascript 2026-09-30 18:58:02.172 - info: host.iobroker iobroker upload [5] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/recharts-DjhcjZm3.js assets/recharts-DjhcjZm3.js application/javascript 2026-09-30 18:58:02.180 - info: host.iobroker iobroker upload [4] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/router-CIdYoo77.js assets/router-CIdYoo77.js application/javascript 2026-09-30 18:58:02.186 - info: host.iobroker iobroker upload [3] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/sampleChartData-B8tY0lM6.js assets/sampleChartData-B8tY0lM6.js application/javascript 2026-09-30 18:58:02.196 - info: host.iobroker iobroker upload [2] aura /opt/iobroker/node_modules/iobroker.aura/www/assets/useLayoutSetting-uK8wot69.js assets/useLayoutSetting-uK8wot69.js application/javascript 2026-09-30 18:58:02.207 - info: host.iobroker iobroker upload [1] aura /opt/iobroker/node_modules/iobroker.aura/www/favicon.svg favicon.svg image/svg+xml 2026-09-30 18:58:02.213 - info: host.iobroker iobroker upload [0] aura /opt/iobroker/node_modules/iobroker.aura/www/index.html index.html text/html 2026-09-30 18:58:02.221 - info: host.iobroker iobroker Updating objects from io-package.json for adapter "aura" with version "0.72.3" 2026-09-30 18:58:02.266 - info: host.iobroker iobroker Update "system.adapter.aura.0" 2026-09-30 18:58:02.274 - info: host.iobroker iobroker upload [13] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/aura.png aura.png image/png 2026-09-30 18:58:02.276 - info: host.iobroker iobroker upload [12] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/aura.svg aura.svg image/svg+xml 2026-09-30 18:58:02.279 - info: host.iobroker iobroker upload [11] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/de/translations.json i18n/de/translations.json application/json 2026-09-30 18:58:02.281 - info: host.iobroker iobroker upload [10] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/en/translations.json i18n/en/translations.json application/json 2026-09-30 18:58:02.284 - info: host.iobroker iobroker upload [9] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/es/translations.json i18n/es/translations.json application/json 2026-09-30 18:58:02.286 - info: host.iobroker iobroker upload [8] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/fr/translations.json i18n/fr/translations.json application/json 2026-09-30 18:58:02.289 - info: host.iobroker iobroker upload [7] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/it/translations.json i18n/it/translations.json application/json 2026-09-30 18:58:02.292 - info: host.iobroker iobroker upload [6] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/nl/translations.json i18n/nl/translations.json application/json 2026-09-30 18:58:02.294 - info: host.iobroker iobroker upload [5] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/pl/translations.json i18n/pl/translations.json application/json 2026-09-30 18:58:02.296 - info: host.iobroker iobroker upload [4] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/pt/translations.json i18n/pt/translations.json application/json 2026-09-30 18:58:02.297 - info: host.iobroker iobroker upload [3] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/ru/translations.json i18n/ru/translations.json application/json 2026-09-30 18:58:02.300 - info: host.iobroker iobroker upload [2] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/uk/translations.json i18n/uk/translations.json application/json 2026-09-30 18:58:02.302 - info: host.iobroker iobroker upload [1] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json 2026-09-30 18:58:02.304 - info: host.iobroker iobroker upload [0] aura.admin /opt/iobroker/node_modules/iobroker.aura/admin/jsonConfig.json jsonConfig.json application/json 2026-09-30 18:58:03.322 - info: host.iobroker iobroker exit 0 ============= Mark until here for C&P ============= -
Bei Containern normal, du kannst da nicht auf den Host durchgreifen.
der container hat doch den Kernel vom Host
Habe mal die Scripts installiert, allerdings sind da ein paar ältere Versionen mit gelistet, Beispiel:
@serialport/bindings-cpp@13.0.0 / 12.0.1 -> installiert ist jetzt 13.0.1
@stoprocent/bluetooth-hci-socket@1.5.2 -> installiert ist jetzt 2.3.0
@stoprocent/noble@1.19.1 -> installiert ist jetzt 2.8.0
protobufjs@6.11.6 -> installiert ist jetzt 7.6.5Kann man die anderen löschen? Oder sind die nötig?
npm install-scripts approve xxxxx
sorry, hab mich wohl falsch ausgedrückt.
Wie kann ich sie freigeben?
Ich weiß immer noch nicht, was du genau mit
meinst. Du sollst da nix installieren.
Mit node 24 / npm 11 wird NICHTS geblockt. Da brauchst auch nix freizugeben.
Das sind alles nur npm WARNINGs und die notwendigen Freigaben werden vor node 27 (da wird das Ganze mit npm 12 dann scharf) geeignet erfolgen.Die Warnings können derzeit einfach ignoriert werden. Und einfach mal alles Scripts ohne Abklärung freizugeben schaltet den sinnvollen zufünftigen nmp Sicherheitsmechanismus aus. Die letzten npm security Vorfälle basierten oft auf eingeschleusten scripts.
Kann man das dann als Maintainer des Pakets mitgeben? Ich meine ich hätte da sowas gelesen.
oder anders gesagt - sorry wenn ich Thomas widerspreche -
USERn wird von der Verwendung von 'npm install-scripts approve <pkg>' o.ä. dringen ABGERATEN.
Allfällige Anpassungen müssen und werden in den jeweiligen Adaptern vorgenommen. Derzeit wird nichts geblcokt.
