  4. [Aufruf] deConz Adapter Testen 1.1.2
zigbeedeconz
532 Beiträge 57 Kommentatoren 180.5k Aufrufe 24 Beobachtet
  • V Offline
    V Offline
    vtwo
    #79
    Habe vorhin die Osram GardenSpots hinzugefügt. Und jetzt kommt im Log File folgendes:
    host.ioBroker-Pi	2018-02-11 20:40:48.368	error	instance system.adapter.deconz.0 terminated with code 0 (OK)
    Caught	2018-02-11 20:40:48.368	error	by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    Caught	2018-02-11 20:40:48.368	error	by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    Caught	2018-02-11 20:40:48.368	error	by controller[0]: at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    Caught	2018-02-11 20:40:48.367	error	by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    Caught	2018-02-11 20:40:48.367	error	by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    Caught	2018-02-11 20:40:48.367	error	by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    Caught	2018-02-11 20:40:48.366	error	by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    Caught	2018-02-11 20:40:48.365	error	by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    Caught	2018-02-11 20:40:48.364	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:127:23)
    Caught	2018-02-11 20:40:48.363	error	by controller[0]: at defineProperty (native)
    Caught	2018-02-11 20:40:48.362	error	by controller[0]: RangeError: Maximum call stack size exceeded
    deconz.0	2018-02-11 20:40:48.308	info	terminating
    deconz.0	2018-02-11 20:40:47.801	error	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    deconz.0	2018-02-11 20:40:47.801	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    deconz.0	2018-02-11 20:40:47.801	error	at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    deconz.0	2018-02-11 20:40:47.801	error	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    deconz.0	2018-02-11 20:40:47.801	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    deconz.0	2018-02-11 20:40:47.801	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    deconz.0	2018-02-11 20:40:47.801	error	at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    deconz.0	2018-02-11 20:40:47.801	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    deconz.0	2018-02-11 20:40:47.801	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:127:23)
    deconz.0	2018-02-11 20:40:47.801	error	at defineProperty (native)
    deconz.0	2018-02-11 20:40:47.801	error	RangeError: Maximum call stack size exceeded
    deconz.0	2018-02-11 20:40:47.800	error	uncaught exception: Maximum call stack size exceeded
    <size size="85">ioBroker und Homebridge auf Mac OSX - Raspberry PI3 für RaspBee Premium und einen für unsere Fotobox - div. Hue, Tradfri, Osram, Wifilight, Tado, Netgear Arlo, Xiaomi und Sonoff krims krams - Sonos, Bose, Echo Show, e…</size>
    • V Offline
      V Offline
      vtwo
      #80
      gehen inzwischen die xiaomi Sensoren also zb der Temperatur Sensor? In Deconz bzw pwa bekomme ich die werte angezeigt Im Broker allerdings nicht hier steht nur type device Rolle sensor das wars?!
      Grüße aus dem Süden
      Clemens
      • Jey CeeJ Offline
        Jey CeeJ Offline
        Jey Cee
        #81
        @vtwo:
        gehen inzwischen die xiaomi Sensoren also zb der Temperatur Sensor? `
        Nope. Hab gerade erst meine eigene ioBroker installation in Betrieb genommen und kämpfe noch mit der Einrichtung.
        Davon abgesehen hab ich nicht einen Sensor oder sonst irgendwas zum Testen.
        Von wo aus dem Süden kommst?
        Persönlicher Support
        Spenden -> paypal.me/J3YC33
        • V Offline
          V Offline
          vtwo
          #82
          Aalen nähe Stuttgart. Ok - leider habe ich ihn verklebt sonst könnte ich dir einen senden :-S warte noch auf die weiteren. Wollte dir nicht jemand einen senden? Die weiteren sollten in den nächsten 1-2 Wochen da sein wenn dir das Helfen würde
          • Jey CeeJ Offline
            Jey CeeJ Offline
            Jey Cee
            #83
            Ja der hat so ziemlich alles an Sensoren geordnet die es gibt. Aber die sind noch nicht alle angekommen.
            Was für mich nicht so schlimm ist da ich eh erst ab nächster Woche wieder mehr Zeit hab mich damit zu beschäftigen.
            Gesendet von Unterwegs
              Kugelkopf
              #84
              Ich habe folgendes Problem:
              Seit heute besitze ich ein Tradfri e14 Leuchtmittel. Ich konnte es via deconz WebApp hinzufügen und es taucht auch bei den Objekten in iobroker auf. Jedoch verändert es keine Werte in iobroker. Sprich, wenn ich via yahnka homekit auf meinem iPhone das Licht ein und ausschalte, tut sie dies auch, jedoch ändert sich der Wert des Objektes Tradfri nicht. Ebenso verhält es sich mit den Color und Dimmer Wert.
              Bei den Osram Smart+ Plugs erkennt er das ein und ausschalten zuverlässig und ändert den Wert der Objekte in IObroker.
              Habt ihr einen Tipp?
              • Jey CeeJ Offline
                Jey CeeJ Offline
                Jey Cee
                #85
                Hatte endlich mal wieder etwas Zeit zum Programmieren und hab 2 Fehler/Probleme behoben.
                Bitte installiert die überarbeitet Version von Github, es handelt sich um die Version 0.1.3.
                Löscht vorher den Installierten Adapter
                @vtwo:
                Ich bekomme seid heute Mittag ungewöhnlich viele Meldungen vom deconz
                deconz.0	2018-02-02 14:35:18.700	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:18.679	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:18.677	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:18.676	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:18.674	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:18.672	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.739	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.734	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.733	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.723	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.721	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.720	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.719	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.679	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.678	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.677	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.661	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.660	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.659	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.658	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.657	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.656	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.655	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.654	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.630	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.629	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.627	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.626	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.625	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.624	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.623	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.622	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.621	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.620	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.619	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.618	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                deconz.0	2018-02-02 14:35:17.617	info	getLightState: {"ctmax":500,"ctmin":151,"etag":"e59be140e15ec33075ca85e8a4ee7b7c","hascolor":true,"manufacturername":"OSRAM","modelid":"Classic A60 RGBW","name":"Schlafzimmer","state":{"alert":"none"
                Ignorieren oder ist das normal?? Die Liste ist noch länger :-D aber dann kommt keiner mehr aus dem Scrollen raus `
                Den Fehler konnte ich finden und beheben.
                2. Wenn im Namen ein Punkt vorgekommen ist wurden Unterordner angelegt und eine Steuerung war unmöglich. Das sollte jetzt nicht mehr vorkommen, außerdem werden weitere Zeichen gefiltert die Problematisch sind.
                • Jey CeeJ Offline
                  Jey CeeJ Offline
                  Jey Cee
                  #86
                  @vtwo:
                  Noch ein Fehler.
                  Über VIS lassen sich die lampen nicht schalten. Wenn ich auf den schalter gehe und dort den ON suche zeigt er mir als wert 0 oder 1 an. Gehe ich aber unter Objekte rein steht dort True oder false. In Vis lassen sich die Lampen weder an noch ausschalten. Dimmen hingegen geht. `
                  Besteht das Problem noch? Ich kann es nicht nachvollziehen, bei mir wird true/false in VIS angezeigt.
                  • Jey CeeJ Offline
                    Jey CeeJ Offline
                    Jey Cee
                    #87
                    @Kugelkopf:
                    Habt ihr einen Tipp? `
                    Besteht das Problem noch? Wenn ja teste bitte auch die neue Version.
                    • V Offline
                      V Offline
                      vtwo
                      #88
                      Hi, habe die neue Version installiert. Jedoch habe ich nun garkein Werte mehr (S. Screen) habe den alten gelöscht und über Git neu installiert. Fehlermeldungen sind derzeit keine gekommen aber eben auch keine Statuseinformationen.
                      Hast du die Sensoren eingebunden? Zumindest zeigt er mir jetzt etwas bei Sensoren an (ausser den Status)
                      • V Offline
                        V Offline
                        vtwo
                        #89
                        Hab mal versucht den Wert Manuell zu setzen aber geht nicht kommt 0. Wenn ich den Wert aufrufe kommt nur ein Leerzeichen.
                        • Jey CeeJ Offline
                          Jey CeeJ Offline
                          Jey Cee
                          #90
                          Bist du professioneller Fehler Sucher? ;-)
                          Du machst mich noch fertig.
                          Am Handy kann ich auf den Screenshots nix erkennen. Das mussich mir daheim anschauen.
                          • AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            #91
                            @Jey Cee:
                            Bist du professioneller Fehler Sucher? ;-) `
                            So Leute kenne ich… Die finden die dollsten Sachen.
                            Da testet man tagelang, gibt Software frei und keine Stunde später haben sie durch "normale" Benutzung was gefunden. :lol:
                            • V Offline
                              V Offline
                              vtwo
                              #92
                              Höööö ich suche die Fehler nicht :-D Nur bringt mir der Adapter nix wenn ich damit nix machen kann :-D :-D also wirklich garnix :-D nichtmal ne Lampe anschalten
                                Kugelkopf
                                #93
                                @Jey Cee:
                                @Kugelkopf:
                                Besteht das Problem noch? Wenn ja teste bitte auch die neue Version. `
                                Habe wie von dir vorgeschlagen den Adapter erst deinstalliert, von Github geupdated und wieder hinzugefügt (0.1.3.).
                                Leider verhielt es sich zur Anfang noch genau wie vorher. Die Werte leuchteten zwar grün auf wenn ich sie via homekit app veränderte, der Wert selbst veränderte sich jedoch nicht.
                                Wegen der von dir genannten Probleme mit den Sonderzeichen im Namen, änderte ich den bisherigen Namen der Lampe: "Tradfri e14" in "TradfriE14". Ich löschte also das Leerzeichen. Seit dem funktioniert es wie es sein soll!!
                                Top! Danke für deine Arbeit!
                                • Jey CeeJ Offline
                                  Jey CeeJ Offline
                                  Jey Cee
                                  #94
                                  @Kugelkopf:
                                  Wegen der von dir genannten Probleme mit den Sonderzeichen im Namen, änderte ich den bisherigen Namen der Lampe: "Tradfri e14" in "TradfriE14". Ich löschte also das Leerzeichen. Seit dem funktioniert es wie es sein soll!! `
                                  Danke für den Hinweis, ich hab Leerzeichen jetzt in den Filter eingebaut. Bei mir haben Leerzeichen im Namen kein Problem verursacht.
                                  @vtwo:
                                  Hast du die Sensoren eingebunden? Zumindest zeigt er mir jetzt etwas bei Sensoren an (ausser den Status) `
                                  Ja schon vor längerem, aber das hat noch nicht funktioniert. Seit dem hab ich nichts weiter daran geändert.
                                  @vtwo:
                                  Jedoch habe ich nun gar kein Werte mehr `
                                  Das erste was mir dazu einfällt, das hab ich schon öfter erlebt die Objekte werden nicht mehr Aktualisiert und es ist nötig den Admin neu zu laden.
                                  Ich hab versucht dein Setup nach zu stellen um den Fehler zu finden. Hast du noch node v 6.12.3 installiert?
                                  Welchen Browser verwendest du? Und welche npm Version verwendest du?
                                  • V Offline
                                    V Offline
                                    vtwo
                                    #95
                                    Nur damit ich bescheid weis weil du sagst du hast an den Sensoren nichts gemacht. Die gehen noch nicht? Ich will nur keinen aus xiaomi löschen und reseten wenn ich es vorher schon weis?
                                    Nein mein Node ist Aktuell 8.9.4v da ich alles auf einen Mac umgezogen habe d deconz den IO dermassen in die Knie gezwungen hat. Habe den Adapter gelöscht neu gestartet nochmal installiert neugestartet und nun sehe ich die zustände.
                                    • Jey CeeJ Offline
                                      Jey CeeJ Offline
                                      Jey Cee
                                      #96
                                      @vtwo:
                                      Die gehen noch nicht? `
                                      Das ist meine letzte info, ich konnte es ja selbst noch nicht testen.
                                      @vtwo:
                                      nun sehe ich die zustände `
                                      Nur die der Lampen? Kannst du die Lampen jetzt auch steuern?
                                      • V Offline
                                        V Offline
                                        vtwo
                                        #97
                                        Hi, ja ich kann die Lampen Steuern. Weitere Testings mache ich heute bzw am Sonntag.
                                        • Jey CeeJ Offline
                                          Jey CeeJ Offline
                                          Jey Cee
                                          #98
                                          So wer lust hat kann die version 0.1.5 Testen. Die Version ist ziemlich "Dirty" und muss ich nachhinein noch aufgeräumt werden.
                                          Ziel der Version ist es zu sehen welche sensoren jetzt funktionieren und welche nicht.
                                          Bisher getestet:
                                          • Tradfri Bewegungsmelder
                                          Github Link: https://github.com/Jey-Cee/ioBroker.deconz
