  4. Betatest ioBroker.icloud 0.2.x
copilotappleicloudadapter
151 Beiträge 21 Kommentatoren 9.5k Aufrufe 19 Beobachtet
  • T ticaki
    Ich hab besseres logging an der Stelle eingebaut um zu sehen wieso das leer ist - das hilft dann vielleicht dem Fehler auf die spur zu kommen
    v2.0.2
    Das sollte jetzt logeinträge erzeugen wenn da irgendein bis jetzt verworfener Fehlerstate von Apple kommt.
    maeb3M
    maeb3M
    maeb3
    #94
    Auszug des Log (mit v2.0.2):
    2026-09-05 23:01:48.783 - info: icloud.0 (29141) Available iCloud services (31): account, archivews, calendar, ckdatabasews, cksharews, contacts, contactsweb, developerapi, docws, drivews, findme, geows, iwmb, iworkexportws, iworkthumbnailws, keyvalue, mail, mcc, mccgateway, mpp, notes, photos, photosupload, premiummailsettings, push, reminders, settings, sharedlibrary, sharedstreams, ubiquity, uploadimagews
    2026-09-05 23:01:48.783 - debug: icloud.0 (29141) Inactive iCloud services: ckdeviceservice(?), schoolwork(?)
    2026-09-05 23:01:48.784 - debug: icloud.0 (29141) Geocoding: disabled
    2026-09-05 23:01:48.807 - debug: icloud.0 (29141) FindMy ID map loaded: 5 known device(s)
    2026-09-05 23:01:48.809 - debug: icloud.0 (29141) FindMy: calling API refresh...
    2026-09-05 23:01:49.200 - debug: icloud.0 (29141) FindMy: API returned 13 device(s)
    2026-09-05 22:31:51.984 - debug: icloud.0 (27550) [icloud.js] [calendar] GET https://p198-calendarws.icloud.com/ca/startup?startDate=2026-09-01&endDate=2026-09-30&dsid=xxxxxxxxxxx&lang=en-us&usertz=Europe%2FBerlin
    2026-09-05 22:31:53.612 - warn: icloud.0 (27550) Calendar refresh failed: GET /startup failed: HTTP 500 (empty response)
    2026-09-05 22:31:53.613 - debug: icloud.0 (27550) Calendar refresh scheduled every 60 min
    2026-09-05 22:31:54.344 - debug: icloud.0 (27550) Extending object account.storage.lastSync with {"type":"state","common":{"name":"Last Sync","type":"number","role":"value.time","read":true,"write":false},"native":{}} (previous: none)
    FindMy und Storage funktionieren ohne Probleme.
    Kann es eventuell damit zusammenhängen, dass in diesem Account auch Kalender sind, die von anderen mit mir geteilt wurden?
    • AsgothianA
      AsgothianA
      Asgothian
      #95
      Ich versuch auch gerade den adapter zum laufen zu bringen - leider ohne Erfolg. Folgendes passiert:
      • der Adapter fragt nach 2FA.
      • ich fordere eine SMS an - der Adapter wirft einen Fehler
      • ich bekomme eine SMS mit einem Code
      • der Code wird abgelehnt.
      Log:
      icloud.0 2026-09-05 23:49:32.779	error	Admin UI: failed to request SMS code: SMS request failed (500): { "phoneNumber" : { "numberWithDialCode" : "+49 •••• ••••••05", "nonFTEU" : true, "obfuscatedNumber" : "•••• ••••••05", "lastTwoDigits" : "05", "pushMode" : "sms", "id" : 3
      icloud.0 2026-09-05 23:49:28.771	info	Admin UI: requesting MFA code via SMS
      icloud.0 2026-09-05 23:48:24.081	error	Admin UI: failed to request SMS code: SMS request failed (500): { "phoneNumber" : { "obfuscatedNumber" : "•••• ••••••05", "lastTwoDigits" : "05", "nonFTEU" : true, "numberWithDialCode" : "+49 •••• ••••••05", "pushMode" : "sms", "id" : 3
      icloud.0 2026-09-05 23:48:19.927	info	Admin UI: requesting MFA code via SMS
      icloud.0 2026-09-05 23:48:07.836	warn	MFA required — enter the 6-digit Apple code into state mfa.code
      icloud.0 2026-09-05 23:47:52.134	info	starting. Version 2.0.1 (non-npm: ticaki/ioBroker.icloud#785bf5c0c317dcf602031f1a8f8b203098a92174) in /opt/iobroker/node_modules/iobroker.icloud, node: v24.20.0, js-controller: 7.2.2
      Gibt es noch irgend etwas das ich probieren kann ?
      A.
      • nograxN
        nograxN
        nograx
        #96
        2.0.2 sagt:
        • AsgothianA Asgothian
          Log:
          A.
          T
          T
          ticaki
          #97
          v2.0.3
          @Asgothian
          dazu gibt ne neue Version die auch nicht den Fehler behebt sondern das log so aufbohrt das man den wirklichen Fehler sieht.
          @maeb3
          die neue Version hat ne fix drin und etwas mehr log. Ist mist wenn man nicht klar erkennt was der fehler sein könnte :)
          Spenden
          • T ticaki
            v2.0.3
            @Asgothian
            @maeb3
            AsgothianA
            AsgothianA
            Asgothian
            #98
            @ticaki sagte:
            @Asgothian
            Prüf ich. Hatte ich aus den Commits so nicht erkannt. Danke für den Hinweis
            A.
            • T
              T
              ticaki
              #99
              • (ticaki) fixed: requesting a 2FA code by SMS could fail with SMS request failed (500) — the session is now refreshed directly before the request and a rejected request is retried once with the complete phone number payload
              • (ticaki) fixed: calendar requests now carry the clientBuildNumber / clientMasteringNumber / clientId parameters that Apple's own web client sends — without them stricter calendar servers answered with an empty HTTP 500
              • (ticaki) changed: failed SMS and calendar requests now report Apple's actual error (service errors, edge headers) instead of a truncated JSON fragment, and all adapter messages are English now
              Jedoch ist 1 und 2 nur ein versuch.
              Spenden
              • AsgothianA
                AsgothianA
                Asgothian
                #100
                My bad - hatte ich nicht darauf bezogen. Auffällig für mich war eher das unvollständige JSON im Log Eintrag. Ich teste.
                A.
                Nachtrag - durch die vorherigen Versuche hatte ich die Telefonnummer blockiert - er hat sie nicht mehr akzeptiert. Nun geht es wieder (neuer Tag, denk ich).. Jedenfalls konnte ich mich anmelden. Nun können die weiteren Tests folgen.
                • T
                  T
                  ticaki
                  #101
                  Der Adapter ist komplett von claude geschrieben - die AI meinte das sie im Fehlerfall mit dem debuglog jetzt deutlich mehr anfangen könnte.
                  Spenden
                  • maeb3M
                    maeb3M
                    maeb3
                    #102
                    Wir kommen der Sache näher.
                    Log mit v2.0.3:
                    2026-09-06 10:13:10.589 - debug: icloud.0 (1246) [icloud.js] [auth] authenticateWebService "calendar" → POST https://setup.icloud.com/setup/ws/1/accountLogin
                    2026-09-06 10:13:11.088 - debug: icloud.0 (1246) [icloud.js] [auth] authenticateWebService "calendar" response status: 421
                    2026-09-06 10:13:11.089 - debug: icloud.0 (1246) [icloud.js] [calendar] GET https://p198-calendarws.icloud.com/ca/events?clientBuildNumber=2534Project66&clientMasteringNumber=xxxxxxx&clientId=xxxxxxxxxxxxxxxxxx&dsid=xxxxxxxxxxx&startDate=2026-09-01&endDate=2026-09-30&lang=en-us&usertz=Europe%2FBerlin
                    2026-09-06 10:13:12.152 - warn: icloud.0 (1246) [icloud.js] [calendar] /startup failed but /events answered (54 event(s)) — Apple serves this account's events but not its calendar list. Please check whether Calendar is enabled for iCloud on your Apple devices and whether icloud.com/calendar works in a browser.
                    2026-09-06 10:13:12.153 - warn: icloud.0 (1246) Calendar refresh failed: WEBSERVICE_REAUTH_REQUIRED:calendar
                    2026-09-06 10:13:12.153 - debug: icloud.0 (1246) Calendar refresh scheduled every 60 min
                    Im Browser kann ich die im Log genannte URL (iCloud.com/calendar) erfolgreich aufrufen.
                    • T
                      T
                      ticaki
                      #103
                      v2.0.4 ist auf github - npm dauert noch einen paar minuten
                      Spenden
                      maeb3M 1 Antwort Letzte Antwort
                      • T ticaki
                        maeb3M
                        maeb3M
                        maeb3
                        #104
                        @ticaki
                        sieht gut aus: der Workaround (v2.0.4) scheint erst mal zu funktionieren. Die Calender werden jetzt bei mir erfolgreich gesynced:
                        2026-09-06 13:33:26.409 - info: host.iobroker "system.adapter.icloud.0" enabled
                        2026-09-06 13:33:27.587 - info: host.iobroker instance system.adapter.icloud.0 in version "2.0.4" (non-npm: ticaki/ioBroker.icloud#565c6094a470da57f1e4e8304d5af47ae6f8c61a) started with pid 12540
                        2026-09-06 13:33:29.514 - warn: icloud.0 (12540) This instance has 6669 objects, the limit for this instance is set to 5000.
                        2026-09-06 13:33:29.517 - info: icloud.0 (12540) starting. Version 2.0.4 (non-npm: ticaki/ioBroker.icloud#565c6094a470da57f1e4e8304d5af47ae6f8c61a) in /opt/iobroker/node_modules/iobroker.icloud, node: v22.23.2, js-controller: 7.2.2
                        2026-09-06 13:33:35.063 - info: icloud.0 (12540) Logged in as: xxxxxxxxxxxx
                        2026-09-06 13:33:35.063 - info: icloud.0 (12540) Country: DEU, Locale: de-de_DE
                        2026-09-06 13:33:35.064 - info: icloud.0 (12540) Available iCloud services (31): account, archivews, calendar, ckdatabasews, cksharews, contacts, contactsweb, developerapi, docws, drivews, findme, geows, iwmb, iworkexportws, iworkthumbnailws, keyvalue, mail, mcc, mccgateway, mpp, notes, photos, photosupload, premiummailsettings, push, reminders, settings, sharedlibrary, sharedstreams, ubiquity, uploadimagews
                        2026-09-06 13:33:38.437 - info: icloud.0 (12540) FindMy ready — 5 device(s): 2 own, 11 family, 0 accessories; 5/5 with location
                        2026-09-06 13:33:42.611 - warn: icloud.0 (12540) [icloud.js] [calendar] /startup failed but /events answered (54 event(s) in 4 calendar(s)) — Apple serves this account's events but not its calendar list. Continuing with a calendar list reconstructed from the events: calendars without events in the queried range are missing and no titles, colours or flags are available for the others.
                        2026-09-06 13:33:52.930 - info: icloud.0 (12540) Calendar ready — 4 calendar(s), 81 upcoming event(s) this month
                        2026-09-06 13:33:54.052 - info: icloud.0 (12540) Account storage ready — 80713 / 204800 MB used (39.4%)
                        2026-09-06 13:33:54.053 - info: icloud.0 (12540) iCloud connection established successfully
                        Vielen Dank dir schon mal.
                        Jetzt muss ich mich mal durch die dadurch entstandene Objekte-Struktur im ioBroker kämpfen, die ja, wie im Log auch erwähnt, nicht die Titel, Farben, etc. beinhalten. Aber das schaffe ich heute nicht mehr.
                        • T
                          T
                          ticaki
                          #105
                          dann ein weiterer versuch um die fehlenden daten von woanders zu bekommen (titel farbe etc)
                          v2.0.5
                          Spenden
                          • nograxN
                            nograxN
                            nograx
                            #106
                            Kalender bei mir jetzt vorhanden. Super! Danke!
                            • AsgothianA
                              AsgothianA
                              Asgothian
                              #107
                              Bei mir klappt der Kalender auch, schon mal Danke dafür. Jetzt muss ich mir nur noch eine Logik überlegen wie ich auf die Kalender-Events reagieren kann, ohne haufenweise Last zu erzeugen.
                              A.
                                A.
                                T
                                T
                                ticaki
                                #108
                                @Asgothian
                                vielleicht ist der teil der readme dann was für dich: https://github.com/ticaki/ioBroker.icloud/blob/main/README_GERMAN.md#kalender--sendto-api
                                hoffe da funktioniert noch alles, habs das am anfang alles durchgetestet bin aber noch dazu gekommen es auch wirklich zu nutzen.
                                Spenden
                                • T ticaki
                                  @Asgothian
                                  AsgothianA
                                  AsgothianA
                                  Asgothian
                                  #109
                                  @ticaki Danke, das hatte ich mir angeschaut - mit den Daten komm ich hin - das sieht gut aus. Was ich heraus finden muss wie ich mitbekomme wann der Kalender aktualisert wird, so das ich die Termine in Shedules umwandeln kann um Status-States zu setzen - und wieder weg zu machen. Und das ganze mit so wenig Last wie geht.
                                  A.
                                  • T ticaki
                                    v2.0.5
                                    maeb3M
                                    maeb3M
                                    maeb3
                                    #110
                                    @ticaki sagte:
                                    v2.0.5
                                    Bei mir funktioniert es jetzt auch. Danke dir vielmals.
                                    Werde mich jetzt mal daran machen, die Termine aus den diversen iCloud-Kalendern in eine Form zu bringen (json??), die man gut für eine Terminübersicht verwenden kann.
                                    • T
                                      T
                                      ticaki
                                      #111
                                      Die daten pro Ereignis bekommst du aus calendar.<name>.<slot>.json siehe Readme - kann da gerne noch was einbauen, wenn sie ein paar leute auf ein format einigen :)
                                      Spenden
                                      • AsgothianA
                                        AsgothianA
                                        Asgothian
                                        #112
                                        was ich gut finden würde ist ein 'klassisches' JSON, jeweils für konfigurierbare Anzahl von Tagen T ab einem Delta D:
                                        Heute - D: { [Uhrzeit, Kalender, Benennung, Dauer, Alarm], ...}
                                        Heute - D+1: { [Uhrzeit, Kalender, Benennung, Dauer, Alarm], ...}
                                        heute - D + T-1: { [Uhrzeit, Kalender, Benennung, Dauer, Alarm], ...}
                                        • OmnedonO
                                          OmnedonO
                                          Omnedon
                                          #113
                                          Leider werden die Kontakt-Einträge nicht aktualisiert.
                                          D.h wenn ich diese bei mir auf dem iPhone ändere, werden sie in den Kontakten-Ordner nicht geändert.
                                          84.1k
