  4. Hannah — Open Source Smart-Home-Sprachassistentin
118 Beiträge 20 Kommentatoren 9.7k Aufrufe 35 Beobachtet
  • L Leonie
    Es könnte sein das es für Python 3.14.4 noch nichts passendes gibt. Bitte führe das mal aus:
    /opt/hannah/voiceid/venv/bin/pip install -v pyyaml
    Bin gespannt was dabei rauskommt.
    Walter.O.W Online
    Walter.O.W Online
    Walter.O.
    #101
    @Leonie
    iob@iob:~$ /opt/hannah/voiceid/venv/bin/pip install -v pyyaml
    Using pip 26.2.1 from /opt/hannah/voiceid/venv/lib/python3.14/site-packages/pip (python 3.14)
    Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple/
    Collecting pyyaml
     Obtaining dependency information for pyyaml from https://files.pythonhosted.org/packages/88/f9/16491d7ed2a919954993e48aa941b200f38040928474c9e85ea9e64222c3/pyyaml-6.0.3-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata
     Downloading pyyaml-6.0.3-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (2.4 kB)
    Downloading pyyaml-6.0.3-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (794 kB)
      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 794.2/794.2 kB 30.2 MB/s  0:00:00
    Installing collected packages: pyyaml
    ERROR: Could not install packages due to an OSError.
    Check the permissions.
    Traceback (most recent call last):
     File "/opt/hannah/voiceid/venv/lib/python3.14/site-packages/pip/_internal/commands/install.py", line 556, in run
       installed = install_given_reqs(
           to_install,
       ...<6 lines>...
           progress_bar=options.progress_bar,
     File "/opt/hannah/voiceid/venv/lib/python3.14/site-packages/pip/_internal/req/__init__.py", line 85, in install_given_reqs
       requirement.install(
           root=root,
       ...<5 lines>...
           script_executable=script_executable,
     File "/opt/hannah/voiceid/venv/lib/python3.14/site-packages/pip/_internal/req/req_install.py", line 794, in install
       install_wheel(
           self.req.name,
       ...<7 lines>...
     File "/opt/hannah/voiceid/venv/lib/python3.14/site-packages/pip/_internal/operations/install/wheel.py", line 754, in install_wheel
       _install_wheel(
           name=name,
       ...<7 lines>...
     File "/opt/hannah/voiceid/venv/lib/python3.14/site-packages/pip/_internal/operations/install/wheel.py", line 603, in _install_wheel
       ensure_dir(parent_dir)
     File "/opt/hannah/voiceid/venv/lib/python3.14/site-packages/pip/_internal/utils/misc.py", line 133, in ensure_dir
       os.makedirs(path)
     File "<frozen os>", line 236, in makedirs
    PermissionError: [Errno 13] Permission denied: '/opt/hannah/voiceid/venv/lib/python3.14/site-packages/_yaml'
    iob@iob:~$
    • L Online
      L Online
      Leonie
      #102
      achja, das muss mit sudo ausgeführt werden, sorry.
      also
      sudo /opt/hannah/voiceid/venv/bin/pip install -v pyyaml
      Walter.O.W 1 Antwort Letzte Antwort
      • L Leonie
        also
        Walter.O.W Online
        Walter.O.W Online
        Walter.O.
        #103
        @Leonie
        ob@iob:~$ sudo /opt/hannah/voiceid/venv/bin/pip install -v pyyaml
        [sudo: authenticate] Password:
        Collecting pyyaml
          Using cached pyyaml-6.0.3-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (2.4 kB)
        Using cached pyyaml-6.0.3-cp314-cp314-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (794 kB)
        Successfully installed pyyaml-6.0.3
        iob@iob:~$
        • L Online
          L Online
          Leonie
          #104
          ok. dann war das vorhin wohl einfach ein Hänger bei der Abfrage von pypi und kein Paketfehler. Dann bitte nochmal die Installation versuchen.
          Walter.O.W 2 Antworten Letzte Antwort
          • L Leonie
            Walter.O.W Online
            Walter.O.W Online
            Walter.O.
            #105
            @Leonie sagte:
            Okay, keine Fehlermeldung.
            • L Leonie
              Walter.O.W Online
              Walter.O.W Online
              Walter.O.
              schrieb zuletzt editiert von
              #106
              @Leonie
              Würde man die Scripte Irgendwo finden oder würdest du sie hier zur Verfügung stellen?
              " Für die Pi-Sats habe ich mir zwei "Bau"-Skripte erstellt. Das eine nimmt das normale Raspberry Pi OS (Debian) und baut daraus eine Satellite-Version. "
              • L Online
                L Online
                Leonie
                #107
                Die liegen generell im Git:
                https://github.com/NurPech/Hannah/blob/master/create_satellite-base-pi.sh
                https://github.com/NurPech/Hannah/blob/master/configure_satellite-pi.sh
                Allerdings werden die Pi-Satelliten nicht mehr an einer aktuellen Core-Version funktionieren. Mit dem Einzug der ESP-Satelliten habe ich mich von den PIs verabschiedet.
                • Walter.O.W Online
                  Walter.O.W Online
                  Walter.O.
                  #108
                  Och schade.
                  • L Offline
                    Luxi
                    #109
                    Ich habe mal eine Bestellung bei PCBway für einen Prototyp angefragt. Bauteil und Sample Kosten sind schon bei 92 $. Dazu kommt noch die Platine für etwa 26. Aktuell ist der Review noch nicht durch. Beim Endpreis melde ich mich noch mal.
                    • L Online
                      L Online
                      Leonie
                      #110
                      Ja, für ein Board sind die Preise quasi immer astronomisch. Da schlagen vor allem die Rüstkosten der Arbeiter und für die Maschinen rein. Die sind übrigens immer gleich, der Fabrik ist relativ egal ob sie ein Board oder hundert baut, die Maschinen müssen sie dafür nur einmal programmieren und bestücken.
                      Generell sind die Hardwarekosten derzeit aber echt für nix zu gebrauchen. Briefe deswegen gehen gerne an die weltweiten Politiker dieser Zeit. So schlägt die RAM-Knappheit durch die KI-Blase auch hier rein, schließlich braucht der ESP auch RAM.
                      Was auch dazu kommt, die meisten Distributoren verkaufen nicht 1 Widerstand, sondern eher 1000 am Stück. Wenn auf dem Board nun einer installiert ist, muss man dennoch 1000 kaufen. Gut, das ist jetzt bei Widerständen weniger tragisch, weil die Fabriken das auch oft abfangen und ihr eigenes Lager nutzen können, aber diese Mindestbestellmengen gibt es bei jedem Teil. Wenn man nun weniger Bauteile eines Types verbaut, als mindestens gekauft werden müssen, schmeißt die Fabrik die zu viel gekauften Teile einfach weg, bezahlen musst du sie trotzdem.
                      Auch das relativiert sich bei größeren Stückzahlen wieder, ist ja klar.
                      Alles in allem ist der Hardwaremarkt echt untragbar gruselig geworden.
                      • L Leonie
                        Walter.O.W Online
                        Walter.O.W Online
                        Walter.O.
                        #111
                        @Leonie sagte:
                        geht es jetzt noch oder zukünftig nicht mehr
                        • L Online
                          L Online
                          Leonie
                          #112
                          ehrlich gesagt, weiß ich es gar nicht. Ich bin mir aber zu 98% sicher, das die Pi-Satellite jetzt nicht mehr funktionieren. Ich denke die können seit Version 0.31.0 vom 18.06.2026 (Changelog)
                          Damals wurde die Art und Weise geändert wie sich die Satelliten registrieren. Das wurde auf den Pi-Satelliten aber nie nachgezogen, die sind noch auf dem Stand von davor.
                          • duemchenD Offline
                            duemchenD Offline
                            duemchen
                            #113
                            @luxi
                            Review ist durch. Ich wollte 2 bestellen. (Leiterplatte sind wohl 5er Stückzahl) Wollen wir gemeinsam bestellen?
                            • L Offline
                              Luxi
                              schrieb zuletzt editiert von Luxi
                              #114
                              Hi all,
                              Zur Info für alle interessierten hier ist der aktuelle Preis bei einem Stück:
                              "Thanks for your inquiry #T-5D2W1132151A-1unit-Hannah_Satellite.kicad_pcb_bom(2026-09-02).
                              Please check the attached quotation for 1 unit of assembled boards.
                              Price Details
                              Component Cost $62.85
                              Assembly Cost $29.00
                              PCB Cost $25.97
                              All Total 1 Units $117.82
                              Delivery Time 22-25 days
                              @duemchen gute Idee vielleicht schließt sich noch jemand an.
                              Ich frage direkt mal bei PCBway an ab welcher Stückzahl sich die Kosten senken.
                              • L Online
                                L Online
                                Leonie
                                #115
                                Theoretisch schon ab Stückzahl = 2, nur wird das PCBWay auch nicht bauen wollen, bzw. teuer machen.
                                Die Component Costs von 62,85$, kommt zum Größtenteil von den MOQs der Bauteile und dem Fakt das die Maschinen auch gerne mal 10 Bauteile "fressen" und erst das 11. Bauteil auf der Rolle dann auf die Platine kommt.
                                Die Assembly Costs sind ziemlich fix, das ist quasi der One Time Fee damit sie es bauen.
                                Die PCB Costs werden mit steigender Stückzahl immer kleiner werden. Die Fabrik kann keine runde Platine mit 88mm Durchmesser bauen, die müssen das auf Panels bringen. Die Standard Panelgröße ist so 400x500mm. Auf das Panel können sie auch die Hardware von anderen Kunden packen, aber der Verschnitt ist riesig, hier zahlt man quasi auch den Müll. Je weniger Verschnitt, desto günstiger.
                                • R Offline
                                  Rogni
                                  schrieb zuletzt editiert von Rogni
                                  #116
                                  mal noch eine Frage, funktioniert das auch mit ali esp32-s3 Satelliten zum testen ?
                                  Sammelbestellung bei pcb würde ich mitmachen
                                  Erik :mrgreen: :mrgreen:
                                  • L Online
                                    L Online
                                    Leonie
                                    schrieb zuletzt editiert von Leonie
                                    #117
                                    Hi!
                                    Schau am besten mal oben in Beitrag #43 rein – da hatte ich genau zu dem Thema schon mal ein paar Details aufgeschrieben. 😉
                                    Die Kurzversion:
                                    Ein nacktes AliExpress-DevKit läuft out-of-the-box nicht, weil die Firmware zwingend zwei Mikrofone und einen I2S-Verstärker erwartet.
                                    Du kannst dir das Ganze zum Testen mit einem ESP32-S3-DevKitC-1 und den passenden Breakouts auf einem Breadboard zusammenstecken (Dafür gibt's im Repo sogar ein eigenes Kconfig-Profil).
                                    Wenn du aber eine saubere, kompakte Lösung ohne fliegende Kabel und Rauschen willst, fährst du mit der PCBWay-Sammelbestellung für die Rev 5 definitiv am besten!
                                    Liebe Grüße
                                    • L Leonie
                                      Hi!
                                      Die Kurzversion:
                                      Liebe Grüße
                                      Jey CeeJ Online
                                      Jey CeeJ Online
                                      Jey Cee
                                      #118
                                      @Leonie sagte:
                                      Was ist den mit dem hier: https://www.waveshare.com/esp32-S3-audio-board.htm
                                      Das sieht für mich so aus als wären Mikrofone und Verstärker per I2S angebunden. Das ist vom Preis auch sehr interessant.
                                      Persönlicher Support
                                      Spenden -> paypal.me/J3YC33
