  4. Neuer Adapter für Roborock-Staubsauger
1.1k Beiträge 155 Kommentatoren 490.4k Aufrufe 137 Beobachtet
  • F fastfoot
    @karsten089 in den Objekten unter roborock.0.loginCode
    karsten089
    #1052
    @fastfoot sagte:
    Danke !
    • K karsten089
      @Thomas-Braun sagte:
      iob logs
      2026-05-30 19:22:53.271  - info: host.pi5 "system.adapter.roborock.0" disabled
      2026-05-30 19:22:53.271  - info: host.pi5 stopInstance system.adapter.roborock.0                                                  (force=false, process=true)
      2026-05-30 19:22:53.273  - info: roborock.0 (3660) Got terminate signal TERMINAT                                                 E_YOURSELF
      2026-05-30 19:22:53.275  - info: roborock.0 (3660) terminating
      2026-05-30 19:22:53.276  - info: roborock.0 (3660) Terminated (ADAPTER_REQUESTED                                                 _TERMINATION): Without reason
      2026-05-30 19:22:53.316  - info: host.pi5 stopInstance system.adapter.roborock.0                                                  send kill signal
      2026-05-30 19:22:53.777  - info: roborock.0 (3660) terminating
      2026-05-30 19:22:53.806  - info: host.pi5 instance system.adapter.roborock.0 ter                                                 minated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2026-05-30 19:22:56.166  - info: host.pi5 "system.adapter.roborock.0" enabled
      2026-05-30 19:22:56.370  - info: host.pi5 instance system.adapter.roborock.0 in                                                  version "0.6.18" started with pid 12300
      2026-05-30 19:22:57.233  - info: host.pi5 "system.adapter.roborock.0" disabled
      2026-05-30 19:22:57.233  - info: host.pi5 stopInstance system.adapter.roborock.0                                                  (force=false, process=true)
      2026-05-30 19:22:57.278  - info: host.pi5 stopInstance system.adapter.roborock.0                                                  send kill signal
      2026-05-30 19:22:57.489  - error: roborock.0 (12300) adapter disabled
      2026-05-30 19:22:57.534  - warn: roborock.0 (12300) Terminated (NO_ADAPTER_CONFI                                                 G_FOUND): Without reason
      2026-05-30 19:22:58.054  - info: host.pi5 instance system.adapter.roborock.0 ter                                                 minated with code 3 (NO_ADAPTER_CONFIG_FOUND)
      2026-05-30 19:23:02.119  - info: host.pi5 "system.adapter.roborock.0" enabled
      2026-05-30 19:23:02.325  - info: host.pi5 instance system.adapter.roborock.0 in                                                  version "0.6.18" started with pid 12316
      2026-05-30 19:23:03.674  - info: roborock.0 (12316) starting. Version 0.6.18 in                                                  /opt/iobroker/node_modules/iobroker.roborock, node: v22.22.2, js-controller: 6.0                                                 .11
      2026-05-30 19:23:03.683  - info: roborock.0 (12316) Starting adapter. This might                                                  take a few minutes depending on your setup. Please wait.
      2026-05-30 19:23:03.888  - error: roborock.0 (12316) Error in getUserData: Login                                                  returned empty userdata.. This is most likely due to too many reconnects.
      2026-05-30 19:23:03.895  - error: roborock.0 (12316) Error retrieving or setting                                                  clientID: Error: Login returned empty userdata.
          at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.j                                                 s:236:11)
          at processTicksAndRejections (node:internal/process/task_queues:103:5)
          at Roborock.initializeRoborockApi (/opt/iobroker/node_modules/iobroker.robor                                                 ock/main.js:103:21)
          at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:65                                                 :34)
      2026-05-30 19:23:04.278  - error: roborock.0 (12316) Failed to get home details:                                                  Error: loginApi is not initialized.
          at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.robor                                                 ock/main.js:144:25)
          at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:67                                                 :14)
      2026-05-30 19:23:12.561  - error: rpi2.0 (2366) Cannot evaluate: Filesystem                                                      1K-blocks    Used Available Use% Mounted on
      /dev/mmcblk0p2   7154480 6459940    311372  96% /
      /1024
      2026-05-30 19:23:12.562  - error: rpi2.0 (2366) Cannot evaluate: Filesystem                                                      1K-blocks    Used Available Use% Mounted on
      /1024
      #1053
      @karsten089
      Da scheinen mir aber auch noch andere Baustellen zu schlummern. Gib mal die Ausgabe von
      iob diag
      bekannt. Dein Terminal bitte zuvor auf Vollbild setzen.
      • R Offline
        Rushmed
        schrieb am zuletzt editiert von Rushmed
        #1054
        wird der S8+ (plus) wirklich nicht unterstützt oder fehlt der nur in der Liste?
        Was kann man hiermit anfangen:
        LG
        copystringC 1 Antwort Letzte Antwort
        • R Rushmed
          LG
          copystringC Offline
          copystringC Offline
          copystring
          #1055
          @Rushmed Doch, hat einfach nur in der Liste gefehlt. Ist jetzt aber drin.
          Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
          https://paypal.me/copystring
          • N Offline
            N Offline
            Nachtfuchs
            schrieb am zuletzt editiert von Nachtfuchs
            #1056
            Hallo Gemeinde,
            seit wenigen Tagen funktioniert mein Adapter / die Ansprache über den ioBroker nicht mehr. In den Objekten werden keine "Steuerungselemente" angezeigt.
            Die Authentifizierung erfolgt über email / Passwort, der Adapter zeigt "grün".
            Ich selber habe am setting nichts geändert, wurde der Adapter irgendwie angepasst? Hat jemand eine Idee?
            Dank euch
            • Ro75R Online
              Ro75R Online
              Ro75
              schrieb am zuletzt editiert von Ro75
              #1057
              Guten Morgen. Eine Frage. Mit dem letzten Update habe ich unter "floors" jetzt zusätzlich zum Ordner "0" (bisher) einen weiteren Ordner "-1".
              Beide haben den selben Inhalt. Bisher habe ich Im Ordner "0" die Räume auf true gesetzt die gereinigt werden sollten - wenn nicht alles.
              Frage nun. Für was ist der Ordner "-1"?
              Ro75.
              Dr. BakteriusD I 2 Antworten Letzte Antwort
              • Ro75R Ro75
                Ro75.
                Dr. BakteriusD Online
                Dr. Bakterius
                #1058
                @Ro75 sagte:
                Kann ich nicht sagen, aber bei mir haben die Floors eine 10-stellige Nummer vom Adapter bekommen.
                • Ro75R Online
                  Ro75R Online
                  Ro75
                  #1059
                  Das ist bei mir genauso. Mich interessiert was es mit dem Ordner "-1" auf sich hat. Also für was sind diese Datenpunkte da? Zur Steuerung? Zur Visualisierung?
                  Ro75.
                  • Ro75R Ro75
                    Ro75.
                    I Online
                    I Online
                    intruder7
                    schrieb zuletzt editiert von
                    #1060
                    @Ro75 ist bei mir auch so.
                    Hab aber ne Frage zu Steuerung. Du setzt den Raum den du einzeln reinigen willst auf true. Und wie startest du dann die Reinigung?
                    Ro75R 1 Antwort Letzte Antwort
                    • I intruder7
                      Ro75R Online
                      Ro75R Online
                      Ro75
                      schrieb zuletzt editiert von Ro75
                      #1061
                      @intruder7 sagte:
                      roborock.0.Devices.6oxxxxxxxxxxxX.commands.app_segment_clean und den setzt du auf true
                      Ro75.
