Nach Update auf Zigbee 3.5.5 läuft die Jalousie falsch herum
Messages from 08:03:47 for device 0xa4c13818f1b0022a
I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":28,"tuyaMovingState":1},"linkquality":94,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,27,10,8,0,32,28,0,240,48,1]},"zclTransactionSequenceNumber":27,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1} I04: value generated '94' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality' I02: 3 converters available for 'SC500ZB-v4' 'SC500ZB-v4-Büro (a4c13818f1b0022a)' with cluster 'closuresWindowCovering' and type 'attributeReport' I02.1a: converter 1 : Cluster closuresWindowCovering I02.0b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":72,"state":"OPEN"} I02.2a: converter 2 : Cluster closuresWindowCovering I02.1b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"STOP"} I02.3a: converter 3 : Cluster closuresWindowCovering I02.2b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined I02.3d: candidates: [{"position":72,"state":"OPEN"},{"moving":"STOP"},{}] => payload {"position":72,"state":"OPEN","moving":"STOP"} => processed payload : {"position":72,"state":"OPEN","moving":"STOP"} I03: message received '{"position":72,"state":"OPEN","moving":"STOP"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4' I04-1: value generated 'OPEN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'state' I04-2: value generated '72' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover' I04-3: value generated 'STOP' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'moving'jetzt mit invert_cover true gleiches Verhalten
Messages from 08:03:34 for device 0xa4c13818f1b0022a
I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":28,"tuyaMovingState":2},"linkquality":98,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,26,10,8,0,32,28,0,240,48,2]},"zclTransactionSequenceNumber":26,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1} I04: value generated '98' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality' I02: 3 converters available for 'SC500ZB-v4' 'SC500ZB-v4-Büro (a4c13818f1b0022a)' with cluster 'closuresWindowCovering' and type 'attributeReport' I02.1a: converter 1 : Cluster closuresWindowCovering I02.0b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":72,"state":"OPEN"} I02.2a: converter 2 : Cluster closuresWindowCovering I02.1b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"DOWN"} I02.3a: converter 3 : Cluster closuresWindowCovering I02.2b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined I02.3d: candidates: [{"position":72,"state":"OPEN"},{"moving":"DOWN"},{}] => payload {"position":72,"state":"OPEN","moving":"DOWN"} => processed payload : {"position":72,"state":"OPEN","moving":"DOWN"} I03: message received '{"position":72,"state":"OPEN","moving":"DOWN"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4' I04-1: value generated 'OPEN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'state' I04-2: value generated '72' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover' I04-3: value generated 'DOWN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'moving' -
@poppele danke für den Teil. Allerdings sind auch das Meldungen die entstehen wenn das Gerät die Position an den Adapter meldet.
Was mir fehlt sind die Meldungen die entstehen wenn du die Position setzt. Dazu gibt es im Debug Tab einen eigenen Bereich der diese Anzeigt.A.
O01: User state change of state zigbee.0.a4c13818f1b0022a.position with value 28 (ack: false) from system.adapter.web.0 O02: Change state 'position' at device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' type 'SC500ZB-v4' O03: Publishing to 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' of model SC500ZB-v4 with position Os4.0: Setting' converter to converter with key(s)'["position","tilt"]} O04: convert position with value 28 and options {} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' without Endpoint O05: Attempt 1 at converting data for position with preparedValue 28, meta.state {}, meta.message {"position":28} SUCCESS: convert result {"state":{"position":28}} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)'Messages from 07:59:56 for device 0xa4c13818f1b0022a
I01: Zigbee Event of Type readResponse from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"readResponse","data":{"zclVersion":3},"linkquality":94,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,28,1,0,0,0,32,3]},"zclTransactionSequenceNumber":28,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1} I04: value generated '94' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality' I02: 0 converter available for 'SC500ZB-v4' 'SC500ZB-v4-Büro (a4c13818f1b0022a)' with cluster 'genBasic' and type 'readResponse'Messages from 08:00:00 for device 0xa4c13818f1b0022a
I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":36,"tuyaMovingState":2},"linkquality":98,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,13,10,8,0,32,36,0,240,48,2]},"zclTransactionSequenceNumber":13,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1} I04: value generated '98' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality' I02: 3 converters available for 'SC500ZB-v4' 'SC500ZB-v4-Büro (a4c13818f1b0022a)' with cluster 'closuresWindowCovering' and type 'attributeReport' I02.1a: converter 1 : Cluster closuresWindowCovering I02.0b: data: {"currentPositionLiftPercentage":36,"tuyaMovingState":2} options: {"invert_cover":"false","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":64,"state":"OPEN"} I02.2a: converter 2 : Cluster closuresWindowCovering I02.1b: data: {"currentPositionLiftPercentage":36,"tuyaMovingState":2} options: {"invert_cover":"false","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"DOWN"} I02.3a: converter 3 : Cluster closuresWindowCovering I02.2b: data: {"currentPositionLiftPercentage":36,"tuyaMovingState":2} options: {"invert_cover":"false","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined I02.3d: candidates: [{"position":64,"state":"OPEN"},{"moving":"DOWN"},{}] => payload {"position":64,"state":"OPEN","moving":"DOWN"} => processed payload : {"position":64,"state":"OPEN","moving":"DOWN"} I03: message received '{"position":64,"state":"OPEN","moving":"DOWN"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4' I04-1: value generated 'OPEN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'state' I04-2: value generated '64' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover' I04-3: value generated 'DOWN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'moving' -
Jetzt nochmals 2 Zyklen ich hoffe dies ist jetzt komplett
Messages from 08:34:41 for device 0xa4c13818f1b0022a
O01: User state change of state zigbee.0.a4c13818f1b0022a.position with value 56 (ack: false) from system.adapter.web.0 O02: Change state 'position' at device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' type 'SC500ZB-v4' O03: Publishing to 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' of model SC500ZB-v4 with position Os4.0: Setting' converter to converter with key(s)'["position","tilt"]} O04: convert position with value 56 and options {} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' without Endpoint O05: Attempt 1 at converting data for position with preparedValue 56, meta.state {}, meta.message {"position":56} SUCCESS: convert result {"state":{"position":56}} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)'Messages from 08:34:41 for device 0xa4c13818f1b0022a
I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":56,"tuyaMovingState":0},"linkquality":91,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,33,10,8,0,32,56,0,240,48,0]},"zclTransactionSequenceNumber":33,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1} I03: message received '{"available":true}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4' I04: value generated 'true' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Available' I04-1: value generated '91' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality' I02: 3 converters available for 'SC500ZB-v4' 'SC500ZB-v4-Büro (a4c13818f1b0022a)' with cluster 'closuresWindowCovering' and type 'attributeReport' I02.1a: converter 1 : Cluster closuresWindowCovering I02.0b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":0} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":44,"state":"OPEN"} I02.2a: converter 2 : Cluster closuresWindowCovering I02.1b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":0} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"UP"} I02.3a: converter 3 : Cluster closuresWindowCovering I02.2b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":0} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined I02.3d: candidates: [{"position":44,"state":"OPEN"},{"moving":"UP"},{}] => payload {"position":44,"state":"OPEN","moving":"UP"} => processed payload : {"position":44,"state":"OPEN","moving":"UP"} I03-1: message received '{"position":44,"state":"OPEN","moving":"UP"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4' I04-2: value generated 'OPEN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'state' I04-3: value generated '44' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover' I04-4: value generated 'UP' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'moving'Messages from 08:34:47 for device 0xa4c13818f1b0022a
I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":56,"tuyaMovingState":1},"linkquality":94,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,34,10,8,0,32,56,0,240,48,1]},"zclTransactionSequenceNumber":34,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1} I04: value generated '94' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality' I02: 3 converters available for 'SC500ZB-v4' 'SC500ZB-v4-Büro (a4c13818f1b0022a)' with cluster 'closuresWindowCovering' and type 'attributeReport' I02.1a: converter 1 : Cluster closuresWindowCovering I02.0b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":44,"state":"OPEN"} I02.2a: converter 2 : Cluster closuresWindowCovering I02.1b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"STOP"} I02.3a: converter 3 : Cluster closuresWindowCovering I02.2b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined I02.3d: candidates: [{"position":44,"state":"OPEN"},{"moving":"STOP"},{}] => payload {"position":44,"state":"OPEN","moving":"STOP"} => processed payload : {"position":44,"state":"OPEN","moving":"STOP"} I03: message received '{"position":44,"state":"OPEN","moving":"STOP"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4' I04-1: value generated 'OPEN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'state' I04-2: value generated '44' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover' I04-3: value generated 'STOP' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'moving'Messages from 08:37:22 for device 0xa4c13818f1b0022a
O01: User state change of state zigbee.0.a4c13818f1b0022a.position with value 46 (ack: false) from system.adapter.web.0 O02: Change state 'position' at device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' type 'SC500ZB-v4' O03: Publishing to 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' of model SC500ZB-v4 with position Os4.0: Setting' converter to converter with key(s)'["position","tilt"]} O04: convert position with value 46 and options {} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' without Endpoint O05: Attempt 1 at converting data for position with preparedValue 46, meta.state {}, meta.message {"position":46} SUCCESS: convert result {"state":{"position":46}} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)'Messages from 08:37:23 for device 0xa4c13818f1b0022a
I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":46,"tuyaMovingState":2},"linkquality":98,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,35,10,8,0,32,46,0,240,48,2]},"zclTransactionSequenceNumber":35,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1} I03: message received '{"available":true}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4' I04: value generated 'true' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Available' I04-1: value generated '98' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality' I02: 3 converters available for 'SC500ZB-v4' 'SC500ZB-v4-Büro (a4c13818f1b0022a)' with cluster 'closuresWindowCovering' and type 'attributeReport' I02.1a: converter 1 : Cluster closuresWindowCovering I02.0b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":54,"state":"OPEN"} I02.2a: converter 2 : Cluster closuresWindowCovering I02.1b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"DOWN"} I02.3a: converter 3 : Cluster closuresWindowCovering I02.2b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined I02.3d: candidates: [{"position":54,"state":"OPEN"},{"moving":"DOWN"},{}] => payload {"position":54,"state":"OPEN","moving":"DOWN"} => processed payload : {"position":54,"state":"OPEN","moving":"DOWN"} I03-1: message received '{"position":54,"state":"OPEN","moving":"DOWN"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4' I04-2: value generated 'OPEN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'state' I04-3: value generated '54' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover' I04-4: value generated 'DOWN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'moving'Messages from 08:37:25 for device 0xa4c13818f1b0022a
I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":46,"tuyaMovingState":1},"linkquality":91,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,36,10,8,0,32,46,0,240,48,1]},"zclTransactionSequenceNumber":36,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1} I04: value generated '91' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality' I02: 3 converters available for 'SC500ZB-v4' 'SC500ZB-v4-Büro (a4c13818f1b0022a)' with cluster 'closuresWindowCovering' and type 'attributeReport' I02.1a: converter 1 : Cluster closuresWindowCovering I02.0b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":54,"state":"OPEN"} I02.2a: converter 2 : Cluster closuresWindowCovering I02.1b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"STOP"} I02.3a: converter 3 : Cluster closuresWindowCovering I02.2b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined I02.3d: candidates: [{"position":54,"state":"OPEN"},{"moving":"STOP"},{}] => payload {"position":54,"state":"OPEN","moving":"STOP"} => processed payload : {"position":54,"state":"OPEN","moving":"STOP"} I03: message received '{"position":54,"state":"OPEN","moving":"STOP"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4' I04-1: value generated 'OPEN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'state' I04-2: value generated '54' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover' I04-3: value generated 'STOP' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'moving' -
@asgothian reichen Dir die Daten oder soll ich auch noch was schicken?
https://forum.iobroker.net/user/asgothian Ich habe nochmals unter 3.3.5 getestet hier ist das Verhalten insfesamt korrekt. Auch unter zigbbe2mqtt mit Zigbee2MQTT-Version 2.13.0 commit: fcbb7ff4 Frontend-Version 2.14.0 zigbee-herdsman-converters Version 26.90.0 zigbee-herdsman Version arbeitet der device korrekt.
E. -
Hallo auch nochmal von mir. ich bin jetzt schonmal etwas weiter bei meiner Analyse hier.
Ich verwende folgende Geräte:
ALLE diese Geräte werden nach dem Update von 3.3.5 nach 3.5.5 verkehrt herum gesteuert.
Sprich, was vorher up war ist hinterher down. Die Ansteuerung erfolgt bei mir bei allen Devices über das Datenfeld 'state', mit dem Blockly-Befehl 'steuere...'
Ausgelöst wird die Steuerung dabei aus 2 verschiedenen VIS-en und automatisiert (Zeit- oder Beschattungssteuerung) direkt aus Blockly. Deshalb geht es erst über eine Variable, welche dann jeweils den zugehörigen Alias des jeweiligen Device-Datenfeldes triggert.
Dort wird dann je nach gesendetem Befehl mit 'UP', 'STOP', oder 'DOWN' das Datenfeld 'state' gesteuert.
Der Grad der Öffnung, Datenfeld 'position', wird bei mir nach dem Update, trotz verdrehter Ansteuerung, weiterhin korrekt angezeigt. Ist ebenfalls über Alias eingebunden.Warum schreibe ich das bevor ich nun (pro Device-Typ, vorher/nachher) in die Logs einsteige?
Mich wundert das es wohl keine anderen Nutzer mit genau diesem Problem gibt und frage mich deshalb, ob ich evtl. bei der Ansteuerung einen Denkfehler gemacht habe? Weil wenn das so wäre, müsste ich wohl eher da ran gehen.zigbee2MQTT habe ich bei Zigbee übrigens nicht im Einsatz, sondern nur den Zigbee-Adapter.
Evtl noch ein Aspekt:
Ich bin gerade per Admin mal zurück bis auf die Vers. 3.4.1. gegangen und habe festgestellt, dass das Problem (bei mir) schon mit dieser Version auftritt. Es ist also (bei mir) definitiv nicht erst ab Vers. 3.5.5.Auf GIT finde ich dazu an Änderungen:
- new Binding UI
- new model specific option meta_state - accepts a list of states (.ie. 'state,brightness')
- adapter defined default-options
Hat sich da evtl. durch den 2.ten Bullet etwas im Umgang mit dem 'state' DP geändert?
- new Binding UI
Ich verwende folgende Geräte:Danke für die Info. Damit kann ich arbeiten.
Der Grad der Öffnung, Datenfeld 'position', wird bei mir nach dem Update, trotz verdrehter Ansteuerung, weiterhin korrekt angezeigt. Ist ebenfalls über Alias eingebunden.Auch das ist schon einmal hilfreich.
Mich wundert das es wohl keine anderen Nutzer mit genau diesem Problem gibt und frage mich deshalb, ob ich evtl. bei der Ansteuerung einen Denkfehler gemacht habe? Weil wenn das so wäre, müsste ich wohl eher da ran gehen.Ich denke das du keinen Denkfehler gemacht hast. Ich denke eher das die Änderungen im ZHC Dich da treffen.
Ich habe auch noch gute Nachrichten - soweit ich den Code überblicken kann laufen die 3 TuYa alle über den gleichen Konverter - sprich logs reichen von genau einem davon, während der Lonsonho anders angesprochen wird.
- new Binding UI
Nein, das ist nicht die relevante Anpassung. Entscheidend ist der Sprung von ZHC 25 (Zigbee Adapter 3.3.x) auf ZHC 26 (Zigbee Adapter 3.4.x oder neuer)
Insgesamt ist genau das auch das Problem - der Adapter hat genau keinen Device-Spezifischen Code für diese Geräte. Die Veränderung des Verhaltens liegt an einer Veränderung der Anforderungen der ZHC, so das ich dafür entsprechend 'optionen' einbauen muss. Nur muss ich erst einmal heraus finden an welchen Stellen da Anpassungen notwendig sind.
A.
Edit - Schreibfehler korrigiert
- new Binding UI
A.
@Asgothian danke für Deine Rückmeldung
Verständnisfrage zu Deinem letzten Satz:
Benötigst Du dazu von mir entsprechende Logs als Input oder gehts Du bei Deiner Suche zunächst anderweitig vor?
Ich bin mir nicht sicher wie Du das genau meist
PS.
Werde frühestens Mitte nächster Woche dazu kommen Logs zu ziehen. -
PS.
Werde frühestens Mitte nächster Woche dazu kommen Logs zu ziehen.@Asgothian danke für Deine Rückmeldung
PS.
Werde frühestens Mitte nächster Woche dazu kommen Logs zu ziehen.Ja, es würde helfen wenn ich die Logs von zumindest einem Lonsonho und einem Tuya Gerät bekomme.
Auch - welche Node Version nutzt du, und wenn es noch Node 22 ist, was passiert wenn du auf Node 24 hoch gehst ?
@poppele @skippy07 @falkomfs - Die Frage zur Node Version gilt auch für euch.
A.
Entschuldige das ich noch keine neuen Logs geliefert habe, bin im Moment wirklich voll mit Arbeit und kriege das irgendwie nicht fertig. Nächste Woche wird es wohl ruhiger, hoffe das klappt dann.
Nur Info: Node.js: v22.23.2
Alles gut - gibt es einen Grund für dich nicht auf Node 24 zu aktualisieren ? Wenn nein wäre es gut das zu testen - ich sehe da eine Chance das damit die Effekte weg sind.
A.
A.
A.
Weil Node 22 empfohlen wird oder ist mir da was entgangen?
A.
Stand heute ist nodejs@22 die empfohlene Version für den ioBroker.
Wenn es sich aber anbietet kann man auch schon mit 24 experimentieren. Wird vermutlich in nächster Zeit ohnehin zur neuen Empfehlung werden.
Mitiob nodejs-update 24bzw.
iob nodejs-updatekommst du ja auch ganz easy auf die gewünschte Version.
also noch nicht auf dem Produktivsysten laufen lassen ?
Musst du selber wissen.
