  4. Nach Update auf Zigbee 3.5.5 läuft die Jalousie falsch herum
39 Beiträge 5 Kommentatoren 887 Aufrufe 5 Beobachtet
  • poppeleP poppele
    ist das jetzt ok?
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @poppele so ist es klasse. Bitte zusätzlich:
    • das gleiche für den vom Adapter gesendeten Befehl posten
    • das Thema invert_Cover anschauen - laut dem gepostet en Text ist in beiden Fällen invert_Cover auf false
    A.
    • poppeleP Offline
      poppeleP Offline
      poppele
      Messages from 08:03:47 for device 0xa4c13818f1b0022a
      I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":28,"tuyaMovingState":1},"linkquality":94,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,27,10,8,0,32,28,0,240,48,1]},"zclTransactionSequenceNumber":27,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
      I04: value generated '94' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality'
      I02: 3 converters available for 'SC500ZB-v4' 'SC500ZB-v4-Büro (a4c13818f1b0022a)' with cluster 'closuresWindowCovering' and type 'attributeReport'
      I02.1a: converter 1 : Cluster closuresWindowCovering
      I02.0b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":72,"state":"OPEN"}
      I02.2a: converter 2 : Cluster closuresWindowCovering
      I02.1b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"STOP"}
      I02.3a: converter 3 : Cluster closuresWindowCovering
      I02.2b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined
      I02.3d: candidates: [{"position":72,"state":"OPEN"},{"moving":"STOP"},{}] => payload {"position":72,"state":"OPEN","moving":"STOP"} => processed payload : {"position":72,"state":"OPEN","moving":"STOP"}
      I03: message received '{"position":72,"state":"OPEN","moving":"STOP"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4'
      I04-1: value generated 'OPEN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'state'
      I04-2: value generated '72' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover'
      I04-3: value generated 'STOP' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'moving'
      jetzt mit invert_cover true gleiches Verhalten
      • poppeleP Offline
        poppeleP Offline
        poppele
        Messages from 08:03:34 for device 0xa4c13818f1b0022a
        I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":28,"tuyaMovingState":2},"linkquality":98,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,26,10,8,0,32,28,0,240,48,2]},"zclTransactionSequenceNumber":26,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I04: value generated '98' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality'
        I02.0b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":72,"state":"OPEN"}
        I02.1b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"DOWN"}
        I02.2b: data: {"currentPositionLiftPercentage":28,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined
        I02.3d: candidates: [{"position":72,"state":"OPEN"},{"moving":"DOWN"},{}] => payload {"position":72,"state":"OPEN","moving":"DOWN"} => processed payload : {"position":72,"state":"OPEN","moving":"DOWN"}
        I03: message received '{"position":72,"state":"OPEN","moving":"DOWN"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4'
        I04-3: value generated 'DOWN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'moving'
        • AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @poppele danke für den Teil. Allerdings sind auch das Meldungen die entstehen wenn das Gerät die Position an den Adapter meldet.
          Was mir fehlt sind die Meldungen die entstehen wenn du die Position setzt. Dazu gibt es im Debug Tab einen eigenen Bereich der diese Anzeigt.
          A.
          • poppeleP Offline
            poppeleP Offline
            poppele
            O01: User state change of state zigbee.0.a4c13818f1b0022a.position with value 28 (ack: false) from system.adapter.web.0
            O02: Change state 'position' at device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' type 'SC500ZB-v4'
            O03: Publishing to 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' of model SC500ZB-v4 with position
            Os4.0: Setting' converter to converter with key(s)'["position","tilt"]}
            O04: convert position with value 28 and options {} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' without Endpoint
            O05: Attempt 1 at converting data for position with preparedValue 28, meta.state {}, meta.message {"position":28}
            SUCCESS: convert result {"state":{"position":28}} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)'
            Messages from 07:59:56 for device 0xa4c13818f1b0022a
            I01: Zigbee Event of Type readResponse from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"readResponse","data":{"zclVersion":3},"linkquality":94,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,28,1,0,0,0,32,3]},"zclTransactionSequenceNumber":28,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            I02: 0 converter available for 'SC500ZB-v4' 'SC500ZB-v4-Büro (a4c13818f1b0022a)' with cluster 'genBasic' and type 'readResponse'
            Messages from 08:00:00 for device 0xa4c13818f1b0022a
            I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":36,"tuyaMovingState":2},"linkquality":98,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,13,10,8,0,32,36,0,240,48,2]},"zclTransactionSequenceNumber":13,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
            I02.0b: data: {"currentPositionLiftPercentage":36,"tuyaMovingState":2} options: {"invert_cover":"false","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":64,"state":"OPEN"}
            I02.1b: data: {"currentPositionLiftPercentage":36,"tuyaMovingState":2} options: {"invert_cover":"false","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"DOWN"}
            I02.2b: data: {"currentPositionLiftPercentage":36,"tuyaMovingState":2} options: {"invert_cover":"false","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined
            I02.3d: candidates: [{"position":64,"state":"OPEN"},{"moving":"DOWN"},{}] => payload {"position":64,"state":"OPEN","moving":"DOWN"} => processed payload : {"position":64,"state":"OPEN","moving":"DOWN"}
            I03: message received '{"position":64,"state":"OPEN","moving":"DOWN"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4'
            I04-2: value generated '64' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover'
            • poppeleP Offline
              poppeleP Offline
              poppele
              Jetzt nochmals 2 Zyklen ich hoffe dies ist jetzt komplett
              Messages from 08:34:41 for device 0xa4c13818f1b0022a
              O01: User state change of state zigbee.0.a4c13818f1b0022a.position with value 56 (ack: false) from system.adapter.web.0
              O04: convert position with value 56 and options {} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' without Endpoint
              O05: Attempt 1 at converting data for position with preparedValue 56, meta.state {}, meta.message {"position":56}
              SUCCESS: convert result {"state":{"position":56}} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)'
              I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":56,"tuyaMovingState":0},"linkquality":91,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,33,10,8,0,32,56,0,240,48,0]},"zclTransactionSequenceNumber":33,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              I03: message received '{"available":true}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4'
              I04: value generated 'true' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Available'
              I04-1: value generated '91' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality'
              I02.0b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":0} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":44,"state":"OPEN"}
              I02.1b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":0} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"UP"}
              I02.2b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":0} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined
              I02.3d: candidates: [{"position":44,"state":"OPEN"},{"moving":"UP"},{}] => payload {"position":44,"state":"OPEN","moving":"UP"} => processed payload : {"position":44,"state":"OPEN","moving":"UP"}
              I03-1: message received '{"position":44,"state":"OPEN","moving":"UP"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4'
              I04-2: value generated 'OPEN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'state'
              I04-3: value generated '44' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover'
              I04-4: value generated 'UP' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'moving'
              Messages from 08:34:47 for device 0xa4c13818f1b0022a
              I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":56,"tuyaMovingState":1},"linkquality":94,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,34,10,8,0,32,56,0,240,48,1]},"zclTransactionSequenceNumber":34,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              I02.0b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":44,"state":"OPEN"}
              I02.1b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"STOP"}
              I02.2b: data: {"currentPositionLiftPercentage":56,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined
              I02.3d: candidates: [{"position":44,"state":"OPEN"},{"moving":"STOP"},{}] => payload {"position":44,"state":"OPEN","moving":"STOP"} => processed payload : {"position":44,"state":"OPEN","moving":"STOP"}
              I03: message received '{"position":44,"state":"OPEN","moving":"STOP"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4'
              I04-2: value generated '44' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover'
              Messages from 08:37:22 for device 0xa4c13818f1b0022a
              O01: User state change of state zigbee.0.a4c13818f1b0022a.position with value 46 (ack: false) from system.adapter.web.0
              O04: convert position with value 46 and options {} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)' without Endpoint
              O05: Attempt 1 at converting data for position with preparedValue 46, meta.state {}, meta.message {"position":46}
              SUCCESS: convert result {"state":{"position":46}} for device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)'
              Messages from 08:37:23 for device 0xa4c13818f1b0022a
              I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":46,"tuyaMovingState":2},"linkquality":98,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,35,10,8,0,32,46,0,240,48,2]},"zclTransactionSequenceNumber":35,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              I04-1: value generated '98' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality'
              I02.0b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":54,"state":"OPEN"}
              I02.1b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"DOWN"}
              I02.2b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":2} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined
              I02.3d: candidates: [{"position":54,"state":"OPEN"},{"moving":"DOWN"},{}] => payload {"position":54,"state":"OPEN","moving":"DOWN"} => processed payload : {"position":54,"state":"OPEN","moving":"DOWN"}
              I03-1: message received '{"position":54,"state":"OPEN","moving":"DOWN"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4'
              I04-3: value generated '54' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover'
              I04-4: value generated 'DOWN' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'moving'
              Messages from 08:37:25 for device 0xa4c13818f1b0022a
              I01: Zigbee Event of Type attributeReport from device 'SC500ZB-v4-Büro (0xa4c13818f1b0022a)', incoming event: {"type":"attributeReport","data":{"currentPositionLiftPercentage":46,"tuyaMovingState":1},"linkquality":91,"groupID":0,"cluster":"closuresWindowCovering","meta":{"rawData":{"type":"Buffer","data":[8,36,10,8,0,32,46,0,240,48,1]},"zclTransactionSequenceNumber":36,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              I04: value generated '91' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Link quality'
              I02.0b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"position":54,"state":"OPEN"}
              I02.1b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:{"moving":"STOP"}
              I02.2b: data: {"currentPositionLiftPercentage":46,"tuyaMovingState":1} options: {"invert_cover":"true","cover_position_tilt_disable_report":"false","resend_states":""} meta:{"deviceIEEE":"0xa4c13818f1b0022a","logger":"StatesController","state":{"state":""}} result:undefined
              I02.3d: candidates: [{"position":54,"state":"OPEN"},{"moving":"STOP"},{}] => payload {"position":54,"state":"OPEN","moving":"STOP"} => processed payload : {"position":54,"state":"OPEN","moving":"STOP"}
              I03: message received '{"position":54,"state":"OPEN","moving":"STOP"}' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' type 'SC500ZB-v4'
              I04-2: value generated '54' from device 'SC500ZB-v4-Büro (a4c13818f1b0022a)' for 'Position of this cover'
              • S Online
                S Online
                Skippy07
                @asgothian reichen Dir die Daten oder soll ich auch noch was schicken?
                • S Skippy07
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @Skippy07 Hast du die identischen Geräte wie @poppele / das gleiche Verhalten oder ist es bei Dir anders ?
                  Wenn alles gleich ist, dann brauche ich keine weiteren Daten. Wenn nicht, dann brauche ich weitere Daten.
                  A.
                  • poppeleP Offline
                    poppeleP Offline
                    poppele
                    https://forum.iobroker.net/user/asgothian Ich habe nochmals unter 3.3.5 getestet hier ist das Verhalten insfesamt korrekt. Auch unter zigbbe2mqtt mit Zigbee2MQTT-Version 2.13.0 commit: fcbb7ff4 Frontend-Version 2.14.0 zigbee-herdsman-converters Version 26.90.0 zigbee-herdsman Version arbeitet der device korrekt.
                    E.
                    • Pedder007P Offline
                      Pedder007P Offline
                      Pedder007
                      schrieb am zuletzt editiert von Pedder007
                      Hallo auch nochmal von mir. ich bin jetzt schonmal etwas weiter bei meiner Analyse hier.
                      Ich verwende folgende Geräte:
                      ALLE diese Geräte werden nach dem Update von 3.3.5 nach 3.5.5 verkehrt herum gesteuert.
                      Sprich, was vorher up war ist hinterher down. Die Ansteuerung erfolgt bei mir bei allen Devices über das Datenfeld 'state', mit dem Blockly-Befehl 'steuere...'
                      Ausgelöst wird die Steuerung dabei aus 2 verschiedenen VIS-en und automatisiert (Zeit- oder Beschattungssteuerung) direkt aus Blockly. Deshalb geht es erst über eine Variable, welche dann jeweils den zugehörigen Alias des jeweiligen Device-Datenfeldes triggert.
                      Dort wird dann je nach gesendetem Befehl mit 'UP', 'STOP', oder 'DOWN' das Datenfeld 'state' gesteuert.
                      Der Grad der Öffnung, Datenfeld 'position', wird bei mir nach dem Update, trotz verdrehter Ansteuerung, weiterhin korrekt angezeigt. Ist ebenfalls über Alias eingebunden.
                      Warum schreibe ich das bevor ich nun (pro Device-Typ, vorher/nachher) in die Logs einsteige?
                      Mich wundert das es wohl keine anderen Nutzer mit genau diesem Problem gibt und frage mich deshalb, ob ich evtl. bei der Ansteuerung einen Denkfehler gemacht habe? Weil wenn das so wäre, müsste ich wohl eher da ran gehen.
                      zigbee2MQTT habe ich bei Zigbee übrigens nicht im Einsatz, sondern nur den Zigbee-Adapter.
                      Evtl noch ein Aspekt:
                      Ich bin gerade per Admin mal zurück bis auf die Vers. 3.4.1. gegangen und habe festgestellt, dass das Problem (bei mir) schon mit dieser Version auftritt. Es ist also (bei mir) definitiv nicht erst ab Vers. 3.5.5.
                      Auf GIT finde ich dazu an Änderungen:
                      • new Binding UI
                      • new model specific option meta_state - accepts a list of states (.ie. 'state,brightness')
                      • adapter defined default-options
                      Hat sich da evtl. durch den 2.ten Bullet etwas im Umgang mit dem 'state' DP geändert?
                      Pedder
                      All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
                      Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
                      Under construction: Smart-WoMo auf Raspi4
                      • Pedder007P Pedder007
                        • new Binding UI
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @Pedder007 sagte:
                        Danke für die Info. Damit kann ich arbeiten.
                        Auch das ist schon einmal hilfreich.
                        Ich denke das du keinen Denkfehler gemacht hast. Ich denke eher das die Änderungen im ZHC Dich da treffen.
                        Ich habe auch noch gute Nachrichten - soweit ich den Code überblicken kann laufen die 3 TuYa alle über den gleichen Konverter - sprich logs reichen von genau einem davon, während der Lonsonho anders angesprochen wird.
                        • new Binding UI
                        Nein, das ist nicht die relevante Anpassung. Entscheidend ist der Sprung von ZHC 25 (Zigbee Adapter 3.3.x) auf ZHC 26 (Zigbee Adapter 3.4.x oder neuer)
                        Insgesamt ist genau das auch das Problem - der Adapter hat genau keinen Device-Spezifischen Code für diese Geräte. Die Veränderung des Verhaltens liegt an einer Veränderung der Anforderungen der ZHC, so das ich dafür entsprechend 'optionen' einbauen muss. Nur muss ich erst einmal heraus finden an welchen Stellen da Anpassungen notwendig sind.
                        A.
                        Edit - Schreibfehler korrigiert
                        Pedder007P 1 Antwort Letzte Antwort
                        • AsgothianA Asgothian
                          @Pedder007 sagte:
                          • new Binding UI
                          A.
                          Pedder007P Offline
                          Pedder007P Offline
                          Pedder007
                          @Asgothian danke für Deine Rückmeldung 👍
                          Verständnisfrage zu Deinem letzten Satz:
                          Benötigst Du dazu von mir entsprechende Logs als Input oder gehts Du bei Deiner Suche zunächst anderweitig vor?
                          Ich bin mir nicht sicher wie Du das genau meist 😊
                          PS.
                          Werde frühestens Mitte nächster Woche dazu kommen Logs zu ziehen.
                          Pedder
