  4. Zigbee Adapter v3.3.5 und Javascript Adapter und Cube
22 Beiträge 5 Kommentatoren 440 Aufrufe 4 Beobachtet
  • KusselinK Offline
    KusselinK Offline
    Kusselin
    Hallo Zusammen,
    ich bins nochmal....habe den Zigbee Adapter auf aktuelle Version geupdatet...soweit so gut....beim Cube war die Batterie leer...also habe ich mir eine neue Knopfzelle bestellt. Nun eingebaut und neu gepairt.....wenn ich jetzt die Gesten durchführe kommen diese Fehlermeldungen:
    096
    Log-Größe: 16.9 KB
    Zeit
    javascript.0
    	2026-08-11 19:50:28.207	warn	getState "zigbee.0.00158d00027cf30f.rotate_left" not found (3)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:3:9)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.210	warn	getState "zigbee.0.00158d00027cf30f.rotate_right" not found (3)
    javascript.0
    	2026-08-11 19:50:28.211	warn	getState "zigbee.0.00158d00027cf30f.flip90" not found (3)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:6:7)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:9:7)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.214	warn	getState "zigbee.0.00158d00027cf30f.flip180" not found (3)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:12:7)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:15:7)
    javascript.0
    javascript.0
    	2026-08-11 19:50:28.216	warn	getState "zigbee.0.00158d00027cf30f.slide" not found (3)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.216	warn	getState "zigbee.0.00158d00027cf30f.tap" not found (3) states[id]=null
    javascript.0
    	2026-08-11 19:50:28.219	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:24:7)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.646	warn	getState "zigbee.0.00158d00027cf30f.rotate_left" not found (3)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:3:9)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.648	warn	getState "zigbee.0.00158d00027cf30f.rotate_right" not found (3)
    javascript.0
    	2026-08-11 19:50:28.648	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:6:7)
    javascript.0
    	2026-08-11 19:50:28.648	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.648	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.648	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.648	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.649	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.649	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.649	warn	getState "zigbee.0.00158d00027cf30f.flip90" not found (3)
    javascript.0
    	2026-08-11 19:50:28.652	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:9:7)
    javascript.0
    	2026-08-11 19:50:28.652	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.653	warn	getState "zigbee.0.00158d00027cf30f.flip180" not found (3)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:12:7)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.654	warn	getState "zigbee.0.00158d00027cf30f.slide" not found (3)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:15:7)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.657	warn	getState "zigbee.0.00158d00027cf30f.tap" not found (3) states[id]=null
    javascript.0
    	2026-08-11 19:50:28.661	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:24:7)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    woebei die Fehlermeldungen ja vom Javascript Adapter kommen....aber die Datenpunkte habe ich ja nicht geändert..
    Könnt Ihr mir bitte helfen was hier faslch läuft?
    haselchenH S AsgothianA 3 Antworten Letzte Antwort
    • KusselinK Kusselin
      Hallo Zusammen,
      096
      Log-Größe: 16.9 KB
      Zeit
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      haselchenH Offline
      haselchenH Offline
      haselchen
      @Kusselin
      Wie in dem anderen Thread ...
      iob diag und andere Infos , Einstellungen, Screenshots zum Gerät, was helfen könnte.
      • KusselinK Offline
        KusselinK Offline
        Kusselin
        ```bash
        Script v.2026-06-06
        *** BASE SYSTEM ***
        Operating System: Ubuntu 24.04.4 LTS
         Static hostname: iobroker-live
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.8.12-20-pve
            Architecture: x86-64
        OS is similar to: debian
        model name      : Intel(R) Core(TM) i5-6260U CPU @ 1.80GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64bit
        System was installed 1635 days ago (on 2022-02-18).
        Systemuptime and Load:
         20:03:34 up 60 days,  1:21,  2 users,  load average: 1.25, 1.31, 1.36
        CPU threads     : 3
        *** LIFE CYCLE STATUS ***
        Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time!
        *** TIME AND TIMEZONES ***
                       Local time: Tue 2026-08-11 20:03:34 CEST
                   Universal time: Tue 2026-08-11 18:03:34 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        heisemer
        HOME=/home/heisemer
        GROUPS=heisemer sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         Unknown
        Display-Manager:        Not found
        Desktop:
        Session:                tty
        Boot Target:            multi-user.target
        *** MEMORY ***
        Mem:            6.7G        4.2G        2.1G         57K        393M        2.5G
        Swap:           3.1G        1.0G        2.1G
        Total:          9.9G        5.3G        4.2G
        Active iob-Instances:   44
                 6422 M total memory
                 4027 M used memory
                 1659 M active memory
                 2455 M inactive memory
                 2019 M free memory
                    0 M buffer memory
                  374 M swap cache
                 3000 M total swap
                  994 M used swap
                 2005 M free swap
        top - 20:03:34 up 60 days,  1:21,  2 users,  load average: 1.25, 1.31, 1.36
        Tasks:  81 total,   1 running,  80 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 16.7 us, 13.9 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  2.8 si,  0.0 st
        MiB Mem :   6422.0 total,   2017.1 free,   4029.9 used,    375.0 buff/cache
        MiB Swap:   3000.0 total,   2005.1 free,    994.9 used.   2392.1 avail Mem
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                SUB    -> The low-level unit activation state, values depend on unit type.
        2 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        dmesg: read kernel buffer failed: Operation not permitted
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--200--disk--0 ext4       25G   14G  9.7G  59% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        efivarfs                         efivarfs  128K  126K     0 100% /sys/firmware/efi/efivars
        tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
        tmpfs                            tmpfs     6.3G  160K  6.3G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                            tmpfs     3.2G  8.0K  3.2G   1% /run/user/0
        Messages concerning filesystems in dmesg:
        Show mounted filesystems:
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--200--disk--0 ext4   rw,relatime,stripe=16
        /var:
        2.7G    /var/
        1.4G    /var/cache/apt
        1.4G    /var/cache
        1.3G    /var/cache/apt/archives
        925M    /var/log
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        203M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.1G    /opt/iobroker/iobroker-data/
        590M    /opt/iobroker/iobroker-data/files
        252M    /opt/iobroker/iobroker-data/backup-objects
        81M     /opt/iobroker/iobroker-data/sonosCache
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        find: Failed to change directory: /root: Permission denied
        find: Failed to restore initial working directory: /root: Permission denied
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
        please always prefer the links 'by-id':
        No Devices found 'by-id'
        *** ZigBee Settings ***
        ⚠ HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'.
        Please check your setting:
        tcp
        Zigbee Network Settings on your coordinator / in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        === ZigBee Port Overview ===
        Instance        Configured Port                     Available by-id Port                Status
        zigbee.0        tcp://192.168.200.75:6638           -                                   tcp
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.23.1
        /usr/bin/node           v22.23.1
        /usr/bin/npm            10.9.8
        /usr/bin/npx            10.9.8
        ✓ Node.js installation is correct
        nodejs:
          Installed: 22.23.1-1nodesource1
          Candidate: 22.23.1-1nodesource1
          Version table:
         *** 22.23.1-1nodesource1 600
             22.23.0-1nodesource1 600
             22.22.3-1nodesource1 600
             22.22.2-1nodesource1 600
             22.22.1-1nodesource1 600
             22.22.0-1nodesource1 600
             22.21.0-1nodesource1 600
             22.20.0-1nodesource1 600
             22.19.0-1nodesource1 600
             22.18.0-1nodesource1 600
             22.17.1-1nodesource1 600
             22.17.0-1nodesource1 600
             22.16.0-1nodesource1 600
             22.15.1-1nodesource1 600
             22.15.0-1nodesource1 600
             22.14.0-1nodesource1 600
             22.13.1-1nodesource1 600
             22.13.0-1nodesource1 600
             22.12.0-1nodesource1 600
             22.11.0-1nodesource1 600
             22.10.0-1nodesource1 600
             22.9.0-1nodesource1 600
             22.8.0-1nodesource1 600
             22.7.0-1nodesource1 600
             22.6.0-1nodesource1 600
             22.5.1-1nodesource1 600
             22.5.0-1nodesource1 600
             22.4.1-1nodesource1 600
             22.4.0-1nodesource1 600
             22.3.0-1nodesource1 600
             22.2.0-1nodesource1 600
             22.1.0-1nodesource1 600
             22.0.0-1nodesource1 600
             18.19.1+dfsg-6ubuntu5 500
                500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
        No problems detected
        Errors in npm tree: 0
        lease stretch the window of your terminal programm (puTTY) as wide as possible        or switch to full screen
        The following checks may give hints to potential malconfigurations or errors, pl        ease post them in our forum:
        https://forum.iobroker.net
        Just copy and paste the Summary Page, including the ``` characters at start and        end.
        It helps us to help you!
        No known Vulnerabilities detected!
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker-live       iobroker-live (version: 7.2.2, hostname: iobroker-live , alive, uptime: 3454333)
        raspi2-unterverteilung raspi2-unterverteilung (version: 7.2.2, hostname: raspi2-unterverteilung, alive, uptime: 3453600)
        Core adapters versions
        js-controller:  7.2.2
        admin:          7.8.23
        javascript:     9.0.18
        nodejs modules from github:     3
        +-- iobroker.enocean@0.5.4 (git+ssh://git@github.com/Jey-Cee/ioBroker.enocean.git#03c0578494f67d0ef7567ee7f83e74c18b8464d7)
        | +-- node-milight-promise@0.3.2 (git+ssh://git@github.com/Steiger04/node-milight-promise.git#f1089feac9b7990727adf2016891029436729d33)
        +-- iobroker.vis-materialdesign@0.5.61 (git+ssh://git@github.com/Scrounger/iobroker.vis-materialdesign.git#aad4a5635dc518caa7c457d87237cf6800ae70a7)
        Adapter State
        + system.adapter.adguard.0                : adguard               : iobroker-live                            -  enabled
        + system.adapter.admin.0                  : admin                 : iobroker-live                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker-live                            -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker-live                            -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker-live                            -  enabled
          system.adapter.birthdays.0              : birthdays             : iobroker-live                            -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker-live                            - disabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker-live                            -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker-live                            -  enabled
          system.adapter.dwd.0                    : dwd                   : iobroker-live                            -  enabled
        + system.adapter.echarts.0                : echarts               : iobroker-live                            -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-live                            -  enabled
          system.adapter.fahrplan.0               : fahrplan              : iobroker-live                            - disabled
        + system.adapter.fhem.0                   : fhem                  : iobroker-live                            -  enabled, port: 7072
        + system.adapter.fritzbox.0               : fritzbox              : iobroker-live                            -  enabled
        + system.adapter.g-homa.0                 : g-homa                : iobroker-live                            -  enabled
          system.adapter.habpanel.0               : habpanel              : iobroker-live                            -  enabled
        + system.adapter.heizoel.0                : heizoel               : iobroker-live                            -  enabled
          system.adapter.heos.0                   : heos                  : iobroker-live                            - disabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker-live                            -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-live                            -  enabled, port: 0
        + system.adapter.hue.0                    : hue                   : iobroker-live                            -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : iobroker-live                            -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-live                            -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-live                            -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker-live                            -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker-live                            -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker-live                            -  enabled
        + system.adapter.jarvis.0                 : jarvis                : iobroker-live                            -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker-live                            -  enabled
          system.adapter.material.0               : material              : iobroker-live                            - disabled
          system.adapter.meteoalarm.0             : meteoalarm            : iobroker-live                            -  enabled
        + system.adapter.milight-smart-light.0    : milight-smart-light   : iobroker-live                            -  enabled
        + system.adapter.netatmo.0                : netatmo               : iobroker-live                            -  enabled
        + system.adapter.notification-manager.0   : notification-manager  : iobroker-live                            -  enabled
        + system.adapter.opendtu.0                : opendtu               : iobroker-live                            -  enabled
        + system.adapter.openhab.0                : openhab               : iobroker-live                            -  enabled, port: 8080
        + system.adapter.paperless-ngx.0          : paperless-ngx         : iobroker-live                            -  enabled, port: 8080
        + system.adapter.pollenflug.0             : pollenflug            : iobroker-live                            -  enabled
        + system.adapter.proxmox.0                : proxmox               : iobroker-live                            -  enabled, port: 8006
        + system.adapter.pushover.0               : pushover              : iobroker-live                            -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker-live                            -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobroker-live                            -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.simple-api.0             : simple-api            : iobroker-live                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartmeter.0             : smartmeter            : raspi2-unterverteilung                   -  enabled
        + system.adapter.socketio.0               : socketio              : iobroker-live                            -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker-live                            -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : iobroker-live                            -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-live                            -  enabled
          system.adapter.spotify-premium.0        : spotify-premium       : iobroker-live                            - disabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-live                            -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker-live                            -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : iobroker-live                            -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.trashschedule.0          : trashschedule         : iobroker-live                            -  enabled
          system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker-live                            -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-live                            -  enabled
          system.adapter.vis.0                    : vis                   : iobroker-live                            -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker-live                            -  enabled
        + system.adapter.web.0                    : web                   : iobroker-live                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.wled.0                   : wled                  : iobroker-live                            - disabled
        + system.adapter.yahka.0                  : yahka                 : iobroker-live                            -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker-live                            -  enabled, port: tcp://192.168.200.75:6638
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name     │ url                                                      │ auto upgrade │
        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'         │ false        │
        │ 1       │ 'latest' │ 'http://download.iobroker.net/sources-dist-latest.json ' │ false        │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        │ (index) │ id                                           │ name                          │ version  │ upgrade policy │
        │ 0       │ 'system.adapter.adguard'                     │ 'adguard'                     │ '1.2.0'  │ 'none'         │
        │ 1       │ 'system.adapter.admin'                       │ 'admin'                       │ '7.8.23' │ 'none'         │
        │ 2       │ 'system.adapter.alexa2'                      │ 'alexa2'                      │ '3.28.3' │ 'none'         │
        │ 3       │ 'system.adapter.alias-manager'               │ 'alias-manager'               │ '2.1.0'  │ 'none'         │
        │ 4       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '3.3.17' │ 'none'         │
        │ 5       │ 'system.adapter.birthdays'                   │ 'birthdays'                   │ '6.1.0'  │ 'none'         │
        │ 6       │ 'system.adapter.coronavirus-statistics'      │ 'coronavirus-statistics'      │ '0.9.0'  │ 'none'         │
        │ 7       │ 'system.adapter.cul'                         │ 'cul'                         │ '2.2.0'  │ 'none'         │
        │ 8       │ 'system.adapter.daswetter'                   │ 'daswetter'                   │ '4.5.3'  │ 'none'         │
        │ 9       │ 'system.adapter.device-reminder'             │ 'device-reminder'             │ '3.1.2'  │ 'none'         │
        │ 10      │ 'system.adapter.discovery'                   │ 'discovery'                   │ '5.0.0'  │ 'none'         │
        │ 11      │ 'system.adapter.dwd'                         │ 'dwd'                         │ '2.8.5'  │ 'none'         │
        │ 12      │ 'system.adapter.echarts'                     │ 'echarts'                     │ '3.1.0'  │ 'none'         │
        │ 13      │ 'system.adapter.energiefluss'                │ 'energiefluss'                │ '3.6.2'  │ 'none'         │
        │ 14      │ 'system.adapter.energiefluss-erweitert'      │ 'energiefluss-erweitert'      │ '0.8.1'  │ 'none'         │
        │ 15      │ 'system.adapter.enocean'                     │ 'enocean'                     │ '0.5.4'  │ 'none'         │
        │ 16      │ 'system.adapter.exchangerates'               │ 'exchangerates'               │ '0.1.0'  │ 'none'         │
        │ 17      │ 'system.adapter.fahrplan'                    │ 'fahrplan'                    │ '1.4.1'  │ 'none'         │
        │ 18      │ 'system.adapter.fb-checkpresence'            │ 'fb-checkpresence'            │ '1.4.2'  │ 'none'         │
        │ 19      │ 'system.adapter.fhem'                        │ 'fhem'                        │ '3.0.0'  │ 'none'         │
        │ 20      │ 'system.adapter.fritzbox'                    │ 'fritzbox'                    │ '0.7.0'  │ 'none'         │
        │ 21      │ 'system.adapter.g-homa'                      │ 'g-homa'                      │ '0.5.3'  │ 'none'         │
        │ 22      │ 'system.adapter.habpanel'                    │ 'habpanel'                    │ '0.5.0'  │ 'none'         │
        │ 23      │ 'system.adapter.heizoel'                     │ 'heizoel'                     │ '1.0.3'  │ 'none'         │
        │ 24      │ 'system.adapter.heos'                        │ 'heos'                        │ '3.0.4'  │ 'none'         │
        │ 25      │ 'system.adapter.hm-rega'                     │ 'hm-rega'                     │ '5.1.0'  │ 'none'         │
        │ 26      │ 'system.adapter.hm-rpc'                      │ 'hm-rpc'                      │ '3.0.1'  │ 'none'         │
        │ 27      │ 'system.adapter.hue'                         │ 'hue'                         │ '3.16.2' │ 'none'         │
        │ 28      │ 'system.adapter.ical'                        │ 'ical'                        │ '1.21.0' │ 'none'         │
        │ 29      │ 'system.adapter.icons-mfd-png'               │ 'icons-mfd-png'               │ '1.2.1'  │ 'none'         │
        │ 30      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'  │ 'none'         │
        │ 31      │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.2'  │ 'none'         │
        │ 32      │ 'system.adapter.influxdb'                    │ 'influxdb'                    │ '4.0.2'  │ 'none'         │
        │ 33      │ 'system.adapter.info'                        │ 'info'                        │ '2.0.0'  │ 'none'         │
        │ 34      │ 'system.adapter.iot'                         │ 'iot'                         │ '6.0.3'  │ 'none'         │
        │ 35      │ 'system.adapter.jarvis'                      │ 'jarvis'                      │ '3.1.8'  │ 'none'         │
        │ 36      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '9.0.18' │ 'none'         │
        │ 37      │ 'system.adapter.luftdaten'                   │ 'luftdaten'                   │ '6.0.1'  │ 'none'         │
        │ 38      │ 'system.adapter.material'                    │ 'material'                    │ '1.3.1'  │ 'none'         │
        │ 39      │ 'system.adapter.meteoalarm'                  │ 'meteoalarm'                  │ '4.0.1'  │ 'none'         │
        │ 40      │ 'system.adapter.milight'                     │ 'milight'                     │ '0.4.0'  │ 'none'         │
        │ 41      │ 'system.adapter.milight-smart-light'         │ 'milight-smart-light'         │ '1.2.2'  │ 'none'         │
        │ 42      │ 'system.adapter.netatmo'                     │ 'netatmo'                     │ '3.1.0'  │ 'none'         │
        │ 43      │ 'system.adapter.netatmo-crawler'             │ 'netatmo-crawler'             │ '1.2.0'  │ 'none'         │
        │ 44      │ 'system.adapter.notification-manager'        │ 'notification-manager'        │ '1.3.0'  │ 'none'         │
        │ 45      │ 'system.adapter.opendtu'                     │ 'opendtu'                     │ '3.1.0'  │ 'none'         │
        │ 46      │ 'system.adapter.openhab'                     │ 'openhab'                     │ '1.2.0'  │ 'none'         │
        │ 47      │ 'system.adapter.openligadb'                  │ 'openligadb'                  │ '1.9.3'  │ 'none'         │
        │ 48      │ 'system.adapter.openweathermap'              │ 'openweathermap'              │ '1.4.0'  │ 'none'         │
        │ 49      │ 'system.adapter.paperless-ngx'               │ 'paperless-ngx'               │ '1.0.0'  │ 'none'         │
        │ 50      │ 'system.adapter.pollenflug'                  │ 'pollenflug'                  │ '2.0.0'  │ 'none'         │
        │ 51      │ 'system.adapter.proxmox'                     │ 'proxmox'                     │ '2.6.1'  │ 'none'         │
        │ 52      │ 'system.adapter.pushover'                    │ 'pushover'                    │ '5.0.0'  │ 'none'         │
        │ 53      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '10.6.1' │ 'none'         │
        │ 54      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'  │ 'none'         │
        │ 55      │ 'system.adapter.smartmeter'                  │ 'smartmeter'                  │ '3.4.0'  │ 'none'         │
        │ 56      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'  │ 'none'         │
        │ 57      │ 'system.adapter.sonoff'                      │ 'sonoff'                      │ '3.3.0'  │ 'none'         │
        │ 58      │ 'system.adapter.sonos'                       │ 'sonos'                       │ '3.0.0'  │ 'none'         │
        │ 59      │ 'system.adapter.sourceanalytix'              │ 'sourceanalytix'              │ '0.4.14' │ 'none'         │
        │ 60      │ 'system.adapter.spotify-premium'             │ 'spotify-premium'             │ '2.0.3'  │ 'none'         │
        │ 61      │ 'system.adapter.squeezebox'                  │ 'squeezebox'                  │ '1.0.0'  │ 'none'         │
        │ 62      │ 'system.adapter.stockmarket'                 │ 'stockmarket'                 │ '0.0.2'  │ 'none'         │
        │ 63      │ 'system.adapter.tankerkoenig'                │ 'tankerkoenig'                │ '3.4.0'  │ 'none'         │
        │ 64      │ 'system.adapter.telegram'                    │ 'telegram'                    │ '4.1.0'  │ 'none'         │
        │ 65      │ 'system.adapter.trashschedule'               │ 'trashschedule'               │ '5.3.0'  │ 'none'         │
        │ 66      │ 'system.adapter.tuya'                        │ 'tuya'                        │ '3.17.0' │ 'none'         │
        │ 67      │ 'system.adapter.tvspielfilm'                 │ 'tvspielfilm'                 │ '2.1.0'  │ 'none'         │
        │ 68      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'  │ 'none'         │
        │ 69      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.61' │ 'none'         │
        │ 70      │ 'system.adapter.weatherunderground'          │ 'weatherunderground'          │ '3.7.0'  │ 'none'         │
        │ 71      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'  │ 'none'         │
        │ 72      │ 'system.adapter.web-speedy'                  │ 'web-speedy'                  │ '0.2.0'  │ 'none'         │
        │ 73      │ 'system.adapter.wled'                        │ 'wled'                        │ '0.7.3'  │ 'none'         │
        │ 74      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.1.0'  │ 'none'         │
        │ 75      │ 'system.adapter.yahka'                       │ 'yahka'                       │ '1.1.5'  │ 'none'         │
        │ 76      │ 'system.adapter.zigbee'                      │ 'zigbee'                      │ '3.3.5'  │ 'none'         │
        ioBroker-Adapter Versions and update status
        Used repository: stable
        Adapter    "adguard"      : 1.2.0    , installed 1.2.0
        Adapter    "admin"        : 7.8.23   , installed 7.8.23
        Adapter    "alexa2"       : 3.28.3   , installed 3.28.3
        Adapter    "alias-manager": 2.1.0    , installed 2.1.0
        Adapter    "backitup"     : 3.3.17   , installed 3.3.17
        Adapter    "birthdays"    : 6.1.0    , installed 6.1.0
        Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
        Adapter    "cul"          : 2.2.0    , installed 2.2.0
        Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "echarts"      : 3.1.0    , installed 3.1.0
        Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
        Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
        Adapter    "exchangerates": 0.1.0    , installed 0.1.0
        Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
        Adapter    "fhem"         : 3.0.0    , installed 3.0.0
        Adapter    "fritzbox"     : 0.7.0    , installed 0.7.0
        Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
        Adapter    "heos"         : 3.0.4    , installed 3.0.4
        Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
        Adapter    "hue"          : 3.16.2   , installed 3.16.2
        Adapter    "ical"         : 1.21.0   , installed 1.21.0
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "iot"          : 6.0.3    , installed 6.0.3
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 9.0.18   , installed 9.0.18
        Controller "js-controller": 7.2.2    , installed 7.2.2
        Adapter    "luftdaten"    : 6.0.1    , installed 6.0.1
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "meteoalarm"   : 4.0.1    , installed 4.0.1
        Adapter    "milight"      : 0.4.0    , installed 0.4.0
        Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "netatmo-crawler": 1.2.0  , installed 1.2.0
        Adapter    "notification-manager": 1.3.0, installed 1.3.0
        Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
        Adapter    "openhab"      : 1.2.0    , installed 1.2.0
        Adapter    "openligadb"   : 1.9.3    , installed 1.9.3
        Adapter    "openweathermap": 1.4.0   , installed 1.4.0
        Adapter    "paperless-ngx": 1.0.0    , installed 1.0.0
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "proxmox"      : 2.6.1    , installed 2.6.1
        Adapter    "pushover"     : 5.0.0    , installed 5.0.0
        Adapter    "shelly"       : 10.6.1   , installed 10.6.1
        Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
        Adapter    "socketio"     : 7.1.3    , installed 7.1.3
        Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "spotify-premium": 2.0.3  , installed 2.0.3
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "trashschedule": 5.3.0    , installed 5.3.0
        Adapter    "tuya"         : 3.17.0   , installed 3.17.0
        Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.61
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "web"          : 8.0.0    , installed 8.0.0
        Adapter    "wled"         : 0.7.3    , installed 0.7.3
        Adapter    "ws"           : 4.1.0    , installed 4.1.0
        Adapter    "yahka"        : 1.1.5    , installed 1.1.5
        Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
        Objects and States
        Objects:        37308
        States:         32857
        Hit:1 http://security.ubuntu.com/ubuntu noble-security InRelease
        Hit:2 https://deb.nodesource.com/node_22.x nodistro InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu noble-updates InRelease
        Reading package lists...
        Pending systemupdates: 69
        *** Listening Ports ***
        Netid State  Recv-Q Send-Q  Local Address:Port   Peer Address:PortProcess
        udp   UNCONN 0      0          127.0.0.54:domain      0.0.0.0:*    users:(("systemd-resolve",pid=230,fd=16))
        udp   UNCONN 0      0       127.0.0.53%lo:domain      0.0.0.0:*    users:(("systemd-resolve",pid=230,fd=14))
        udp   UNCONN 0      0             0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=229,fd=5),("systemd",pid=1,fd=64))
        udp   UNCONN 0      0             0.0.0.0:mdns        0.0.0.0:*    users:(("io.yahka.0",pid=504720,fd=30))
        udp   UNCONN 0      0             0.0.0.0:mdns        0.0.0.0:*    users:(("io.yahka.0",pid=504720,fd=29))
        udp   UNCONN 0      0             0.0.0.0:5683        0.0.0.0:*    users:(("io.shelly.0",pid=504489,fd=42))
        udp   UNCONN 0      0                [::]:sunrpc         [::]:*    users:(("rpcbind",pid=229,fd=7),("systemd",pid=1,fd=66))
        tcp   LISTEN 0      511           0.0.0.0:8400        0.0.0.0:*    users:(("io.jarvis.0",pid=505685,fd=30))
        tcp   LISTEN 0      511           0.0.0.0:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=504158,fd=30))
        tcp   LISTEN 0      511           0.0.0.0:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=504158,fd=23))
        tcp   LISTEN 0      100         127.0.0.1:smtp        0.0.0.0:*    users:(("master",pid=450,fd=13))
        tcp   LISTEN 0      511           0.0.0.0:44875       0.0.0.0:*    users:(("io.yahka.0",pid=504720,fd=37))
        tcp   LISTEN 0      511    192.168.200.38:2001        0.0.0.0:*    users:(("io.hm-rpc.0",pid=504550,fd=35))
        tcp   LISTEN 0      4096          0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=229,fd=4),("systemd",pid=1,fd=63))
        tcp   LISTEN 0      4096          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=4829,fd=3),("systemd",pid=1,fd=58))
        tcp   LISTEN 0      511           0.0.0.0:1882        0.0.0.0:*    users:(("io.shelly.1",pid=504770,fd=35))
        tcp   LISTEN 0      511           0.0.0.0:1883        0.0.0.0:*    users:(("io.sonoff.0",pid=504787,fd=40))
        tcp   LISTEN 0      4096    127.0.0.53%lo:domain      0.0.0.0:*    users:(("systemd-resolve",pid=230,fd=15))
        tcp   LISTEN 0      4096       127.0.0.54:domain      0.0.0.0:*    users:(("systemd-resolve",pid=230,fd=17))
        tcp   LISTEN 0      100             [::1]:smtp           [::]:*    users:(("master",pid=450,fd=14))
        tcp   LISTEN 0      511                 *:8084              *:*    users:(("io.socketio.0",pid=505466,fd=34))
        tcp   LISTEN 0      511                 *:8082              *:*    users:(("io.web.0",pid=505314,fd=35))
        tcp   LISTEN 0      511                 *:tproxy            *:*    users:(("io.admin.0",pid=504179,fd=40))
        tcp   LISTEN 0      4096             [::]:sunrpc         [::]:*    users:(("rpcbind",pid=229,fd=6),("systemd",pid=1,fd=65))
        tcp   LISTEN 0      4096             [::]:ssh            [::]:*    users:(("sshd",pid=4829,fd=4),("systemd",pid=1,fd=59))
        tcp   LISTEN 0      511                 *:50000             *:*    users:(("io.g-homa.0",pid=505922,fd=30))
        tcp   LISTEN 0      511                 *:3500              *:*    users:(("io.sonos.0",pid=1247790,fd=31))
        2026-08-11 20:00:00.436  - info: javascript.0 (504209) script.js.Keller.Einspeisung-PV: [Einspeisung] Heute: 41.06 kWh | A: 13.82 | B: 14.7 | C: 12.54 | Vergütung: 2.79 €
        2026-08-11 20:00:03.502  - info: ical.0 (1506188) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.23.1, js-controller: 7.2.2
        2026-08-11 20:00:04.074  - info: ical.0 (1506188) processing URL: Abfall **entfernt**
        2026-08-11 20:00:09.154  - info: ical.0 (1506188) Terminated (NO_ERROR): Without reason
        2026-08-11 20:00:09.680  - info: host.iobroker-live instance system.adapter.ical.0 having pid 1506188 terminated with code 0 (NO_ERROR)
        2026-08-11 20:00:38.016  - info: host.iobroker-live instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 1506211
        2026-08-11 20:00:39.696  - info: tvspielfilm.0 (1506211) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v22.23.1, js-controller: 7.2.2
        2026-08-11 20:00:41.733  - info: tvspielfilm.0 (1506211) objects written
        2026-08-11 20:00:42.027  - info: host.iobroker-live instance system.adapter.meteoalarm.0 in version "4.0.1" started with pid 1506229
        2026-08-11 20:00:44.317  - info: meteoalarm.0 (1506229) starting. Version 4.0.1 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v22.23.1, js-controller: 7.2.2
        2026-08-11 20:00:45.137  - info: meteoalarm.0 (1506229) 15.1: Updated Weather Alarms for Rhein-Neckar-Kreis und Stadt Heidelberg -> 0 alarm(s) found
        2026-08-11 20:00:45.138  - info: meteoalarm.0 (1506229) Terminated (ADAPTER_REQUESTED_TERMINATION): All data processed. Adapter stopped until next scheduled process.
        2026-08-11 20:00:45.669  - info: host.iobroker-live instance system.adapter.meteoalarm.0 having pid 1506229 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2026-08-11 20:00:46.041  - info: host.iobroker-live instance system.adapter.dwd.0 in version "2.8.5" started with pid 1506246
        2026-08-11 20:00:48.951  - info: dwd.0 (1506246) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.23.1, js-controller: 7.2.2
        2026-08-11 20:00:49.334  - info: dwd.0 (1506246) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2026-08-11 20:00:49.858  - info: host.iobroker-live instance system.adapter.dwd.0 having pid 1506246 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2026-08-11 20:00:52.236  - info: tvspielfilm.0 (1506211) Terminated (NO_ERROR): Without reason
        2026-08-11 20:00:52.757  - info: host.iobroker-live instance system.adapter.tvspielfilm.0 having pid 1506211 terminated with code 0 (NO_ERROR)
        2026-08-11 20:01:01.409  - info: javascript.0 (504209) script.js.Keller.Einspeisung-PV: [Einspeisung] Heute: 41.06 kWh | A: 13.82 | B: 14.7 | C: 12.54 | Vergütung: 2.79 €
        2026-08-11 20:01:10.171  - info: admin.0 (504179) ==> Connected system.user.admin from ::ffff:192.168.200.106
        2026-08-11 20:01:17.330  - info: fhem.0 (577076) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2026-08-11 20:02:00.385  - info: javascript.0 (504209) script.js.Keller.Einspeisung-PV: [Einspeisung] Heute: 41.06 kWh | A: 13.82 | B: 14.7 | C: 12.54 | Vergütung: 2.79 €
        2026-08-11 20:03:00.341  - info: javascript.0 (504209) script.js.Keller.Einspeisung-PV: [Einspeisung] Heute: 41.07 kWh | A: 13.82 | B: 14.71 | C: 12.54 | Vergütung: 2.79 €
        2026-08-11 20:04:00.325  - info: javascript.0 (504209) script.js.Keller.Einspeisung-PV: [Einspeisung] Heute: 41.07 kWh | A: 13.82 | B: 14.71 | C: 12.54 | Vergütung: 2.79 €
        MOD-EDIT: private Daten entfernt
        ============= Mark until here for C&P =============
        iob diag has finished.
          Hallo Zusammen,
          096
          Log-Größe: 16.9 KB
          Zeit
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          S Abwesend
          S Abwesend
          Shadowhunter23
          @Kusselin sagte:
          Haben sich die Datenpunkte geändert?
          Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
          ioBroker Backup Analyzer
            Hallo Zusammen,
            096
            Log-Größe: 16.9 KB
            Zeit
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @Kusselin sagte:
            zeig mal bitte die Datenpunkte des Cubes im Objektbaum. Es ist denkbar das sich die ID;s der Datenpunkte geändert haben.
            A.
            • KusselinK Offline
              KusselinK Offline
              Kusselin
              Hallo Zusammen, jetzt hekomm ich gleich Schelte...
              Wie magst du die Datenpunkte? Ein Screenshot
              Wenns die DPs sind müsste ich einfach die jetzigen
              Datenpunkte löschen und Adapter neu starten oder?
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @Kusselin
                Datenpunkte gerne als Screenshot. Und löschen und adapter neu starten wird nichts bringen - wenn die DP's sich ZHC zeitig geändert haben musst du entweder die Skripte anpassen oder über die ab 3.5.5 vorhandene Option modify_state die vom Adapter angelegten States ändern (riskant)
                A,
                • KusselinK Offline
                  KusselinK Offline
                  Kusselin
                  • AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    Leider fehlt der entscheidende Teil - das device selber wo ich sehen kann ob der Name insgesamt passt. Offensichtlich gibt es ein .rotate_left, aber was ist mit dem zigbee.0.00158d0027cf30f ?
                    KusselinK 1 Antwort Letzte Antwort
                    • AsgothianA Asgothian
                      KusselinK Offline
                      KusselinK Offline
                      Kusselin
                      @Asgothian sagte:
                      Und wie kann ich Dir den entscheidende Teil liefern?
                      Das hier?
                        "type": "state",
                        "common": {
                          "name": "rotate_left",
                          "type": "boolean",
                          "read": true,
                          "write": false,
                          "role": "button"
                        "native": {},
                        "from": "system.adapter.zigbee.0",
                        "user": "system.user.admin",
                        "ts": 1786463170345,
                        "_id": "zigbee.0.00158d00027cf30f.rotate_left",
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                          "owner": "system.user.admin",
                        AsgothianA Offline
                        Asgothian
                        Den Screenshot erweitern so das die 3 oder 4 Zeilen oberhalb von action auch sichtbar sind zeigt die entscheidende Info. Das was in _id steht ist ein Hinweis, aber nicht unbedingt entscheidend.
                        A.
                          A.
                          arteckA Offline
                          arteckA Offline
                          arteck
                          der wird nicht aktualisier.. deshalb steht der rotate_left auch auf null
                          • KusselinK Offline
                            KusselinK Offline
                            Kusselin
                            schrieb am zuletzt editiert von Kusselin
                            Hi, da steht oberhalb von ACTION NICHTS MEHR NUR NOCHBDIE ID VOM CUBE die ich einklagen kann. Wenn ich den cube hochwerfe und dann geht die A. Auch an, gleichzeitig triggerd der javascript die Fehler??
                            Wie und was kann ich machen um dir die gewünschte Info zukommen zu lassen?
                            Aber man sieht ja an manchen Datenpunkten das "good".
                            Muss ich hier dann vielleicht erstmal alle "Gesten" durchgehen das da überall good steht?
                              AsgothianA Offline
                              Asgothian
                              Es geht gerade um die ID des Cube. Der datenpunkt den das Skript haben will scheint angeblich nicht da zu sein, aber dein Screenshot zeigt das er da ist. Also passt etwas mit der ID nicht. Der Eintrag _id im Objekt wird beim erstellen gesetzt, aber z.bsp. Nicht beim importieren aus json aktualisiert.
                              Das der DP einen Wert null hat kann die Fehler im Skript nicht erzeugen.
                              A.
                              Nachtrag: zeig auch mal bitte das Skript.
                              • KusselinK Offline
                                KusselinK Offline
                                Kusselin
                                Hi danke dir erstmal.. ich mach das heute nachmittag in Ruhe.
                                Wenn man doch aber im Script zb auf den Wert klickt, dann geht aber der datenpunkt zb rotate_left korrekt auf.. hoffe du verstehst was ich meine?
                                  A.
                                  KusselinK Offline
                                  KusselinK Offline
                                  Kusselin
                                  @Asgothian sagte:
                                  A.
                                  Guten Morgen,
                                  bringt dir das was....so? Wie kopiere ich ein komplettes Blockly?
                                  on({ id: [].concat(['zigbee.0.00158d00027cf30f.rotate_left']).concat(['zigbee.0.00158d00027cf30f.flip90']).concat(['zigbee.0.00158d00027cf30f.rotate_right']).concat(['zigbee.0.00158d00027cf30f.shake']).concat(['zigbee.0.00158d00027cf30f.tap']).concat(['zigbee.0.00158d00027cf30f.slide']).concat(['zigbee.0.00158d00027cf30f.flip180']).concat(['zigbee.0.00158d00027cf30f.fall']), change: 'ne' }, async (obj) => {
                                    if (getState('zigbee.0.00158d00027cf30f.rotate_left').val == true) {
                                      setStateDelayed('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume' /* volume */, (getState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume').val - 5), 100, false);
                                    if (getState('zigbee.0.00158d00027cf30f.rotate_right').val == true) {
                                      setStateDelayed('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume' /* volume */, (getState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume').val + 5), 100, false);
                                    if (getState('zigbee.0.00158d00027cf30f.flip90').val == true) {
                                      setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'FFH iTunes Top 40');
                                    if (getState('zigbee.0.00158d00027cf30f.flip180').val == true) {
                                      setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'YOU FM');
                                    if (getState('zigbee.0.00158d00027cf30f.slide').val == true) {
                                      setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'ANTENNE BAYERN');
                                    if (getState('zigbee.0.00158d00027cf30f.fall').val == true) {
                                      setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'radio SAW-Party');
                                    if (getState('zigbee.0.00158d00027cf30f.shake').val == true) {
                                      setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPause' /* controlPause */, true);
                                    if (getState('zigbee.0.00158d00027cf30f.tap').val == true) {
                                      setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPlay' /* controlPlay */, true);
                                  oder
                                    <block type="on_ext" id="#dU%bHFVm/~[XFv;e5M5" x="-287" y="-388">
                                      <mutation xmlns="http://www.w3.org/1999/xhtml" items="8"></mutation>
                                      <value name="OID0">
                                        <shadow type="field_oid" id="luObs(yNi=oW98s~lUkF">
                                          <field name="oid">zigbee.0.00158d00027cf30f.rotate_left</field>
                                        </shadow>
                                      </value>
                                      <value name="OID1">
                                        <shadow type="field_oid" id="|X5zwhq%~Zkbz~1R0r1^">
                                          <field name="oid">zigbee.0.00158d00027cf30f.flip90</field>
                                        </shadow>
                                      </value>
                                      <value name="OID2">
                                        <shadow type="field_oid" id=":!;dbL6TpMMEGN+0WBIe">
                                          <field name="oid">zigbee.0.00158d00027cf30f.rotate_right</field>
                                        </shadow>
                                      </value>
                                      <value name="OID3">
                                        <shadow type="field_oid" id="Ig5d`gN3)^t%EXeY.S-Z">
                                          <field name="oid">zigbee.0.00158d00027cf30f.shake</field>
                                        </shadow>
                                      </value>
                                      <value name="OID4">
                                        <shadow type="field_oid" id="lkE{jhvkV[j=uBCI~?Qz">
                                          <field name="oid">zigbee.0.00158d00027cf30f.tap</field>
                                        </shadow>
                                      </value>
                                      <value name="OID5">
                                        <shadow type="field_oid" id="6Tv(MB{kY:1zhNR]B$X*">
                                          <field name="oid">zigbee.0.00158d00027cf30f.slide</field>
                                        </shadow>
                                      </value>
                                      <value name="OID6">
                                        <shadow type="field_oid" id="cL{yeW/ld7GDq$kIw.SC">
                                          <field name="oid">zigbee.0.00158d00027cf30f.flip180</field>
                                        </shadow>
                                      </value>
                                      <value name="OID7">
                                        <shadow type="field_oid" id="$B2-v8yXc{rE}@Vr*=~9">
                                          <field name="oid">zigbee.0.00158d00027cf30f.fall</field>
                                        </shadow>
                                      </value>
                                      <statement name="STATEMENT">
                                        <block type="controls_if" id=",9_Nr-P-{%Fd+Tc0-=Nu">
                                          <value name="IF0">
                                            <block type="logic_compare" id=";_i]cfZdrmL/qXWB6PuO">
                                              <field name="OP">EQ</field>
                                              <value name="A">
                                                <block type="get_value" id="05hB:}da}@CQX_^vBlC@">
                                                  <field name="OID">zigbee.0.00158d00027cf30f.rotate_left</field>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_boolean" id="ZT5]2tgD5CM]Of-|;}#F">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <statement name="DO0">
                                            <block type="control" id="}6;6~]L4/!BY.JwxYt#d">
                                              <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                                              <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume</field>
                                              <field name="DELAY_MS">100</field>
                                              <field name="UNIT">ms</field>
                                              <value name="VALUE">
                                                <block type="math_arithmetic" id="?Jr}iv/yilVo.s[Yu?mx">
                                                  <value name="A">
                                                    <shadow type="math_number" id="M|^U,9}PJ?Ze7Tp:0l-[">
                                                      <field name="NUM">1</field>
                                                    </shadow>
                                                    <block type="get_value" id="YwLlb+nx4qTOJFvljerY">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <shadow type="math_number" id="HvU;CRog.Utv3?toGeqk">
                                                      <field name="NUM">5</field>
                                                    </shadow>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <next>
                                            <block type="controls_if" id="}CAVnkOHSlC0^OuF^Jgu">
                                              <value name="IF0">
                                                <block type="logic_compare" id="{H:^dKPD7}11B/qgk6JU">
                                                  <value name="A">
                                                    <block type="get_value" id="`O~YYmKWdN!Mw72DDncL">
                                                      <field name="OID">zigbee.0.00158d00027cf30f.rotate_right</field>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="logic_boolean" id="FoREtBH+=iZ6hv|p8Fd@">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                <block type="control" id="w(o*h=O4naq)R:K(V7BZ">
                                                    <block type="math_arithmetic" id="!_r@b%{RRXbB78L@gy=Q">
                                                      <field name="OP">ADD</field>
                                                      <value name="A">
                                                        </shadow>
                                                        <block type="get_value" id="C({F@Kx^Xfa}LQ}:J.f?">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <shadow type="math_number" id="%l[aeB:EcnIHkKMA1VTC">
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                              <next>
                                                <block type="controls_if" id="T%b0W^#l-ZWU%w^7]WQ/">
                                                  <value name="IF0">
                                                    <block type="logic_compare" id="=(DbOS78=0MBQe=F%*.D">
                                                      <value name="A">
                                                        <block type="get_value" id="DpgzqNoWjD?gGY|.nPM_">
                                                          <field name="OID">zigbee.0.00158d00027cf30f.flip90</field>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="logic_boolean" id="DkzF1(|Ey=3{V,DFkJfD">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                    <block type="control" id="XSX3p0d(aQb.=Q`_;!Pl">
                                                      <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn</field>
                                                        <block type="text" id="-4]H.r+U_}1USc-uhv}_">
                                                          <field name="TEXT">FFH iTunes Top 40</field>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                    <block type="controls_if" id="3g/0(WCRy;oCL?_d8(.C">
                                                      <value name="IF0">
                                                        <block type="logic_compare" id="P-11~fV`Nv0~,i6Z]kfW">
                                                          <value name="A">
                                                            <block type="get_value" id="*FX)kI39Db7wYP5[:xl+">
                                                              <field name="OID">zigbee.0.00158d00027cf30f.flip180</field>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="logic_boolean" id="9ZzpRTsuv4C9x)%pr,Es">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                        <block type="control" id="!NUVA~(c4QgG]+~(E|^i">
                                                            <block type="text" id="vqzCyqOR/s6Y7s21%;[F">
                                                              <field name="TEXT">YOU FM</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                      <next>
                                                        <block type="controls_if" id=",Fq$U/,8:7stB7Z*~Xtv">
                                                          <value name="IF0">
                                                            <block type="logic_compare" id=".cop*h-}DoYl2o8E@%5{">
                                                              <value name="A">
        <block type="get_value" id="tew,S#WRiF^%yTMOm,+h">
        <field name="OID">zigbee.0.00158d00027cf30f.slide</field>
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="logic_boolean" id="]]lBl9XbxKIb%5WJ$Ja/">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                            <block type="control" id="sOf=BcVH`:fZOEpzDS)-">
        <block type="text" id="VN8FGL^,)9K;L|!rdwUS">
        <field name="TEXT">ANTENNE BAYERN</field>
        </block>
                                                              </value>
                                                            </block>
                                                          </statement>
                                                          <next>
                                                            <block type="controls_if" id="L(VjI7c;qpbDvh5(w`.Y">
                                                              <value name="IF0">
        <block type="logic_compare" id="M|9q*GjAQ9x`{[k}dca+">
        <value name="A">
        <block type="get_value" id="ro?b.ZMu3E=qk.NTo|l9">
        <field name="OID">zigbee.0.00158d00027cf30f.fall</field>
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="s%[mn]65k*ugyLb_.=TL">
        </block>
        </value>
        </block>
                                                              </value>
        <block type="control" id="Db;0%17/~z}Bh%#w64wr">
        <block type="text" id="6U$-BxPPddFN/,9!k]K$">
        <field name="TEXT">radio SAW-Party</field>
        </block>
        </value>
        </block>
                                                              </statement>
                                                              <next>
        <block type="controls_if" id="W|nOmNk7Ri}Fs|:3bNvo">
        <value name="IF0">
        <block type="logic_compare" id=".`5XJGz4u6:p[#j+uoBh">
        <value name="A">
        <block type="get_value" id="Tc#Gzin|@s,p7.86ILp/">
        <field name="OID">zigbee.0.00158d00027cf30f.shake</field>
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="sH3Sm+bH^3l}+?.kIlZ*">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="E]3~1B]ZQQdBY9/459z[">
        <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPause</field>
        <block type="logic_boolean" id="5t-IeJ[V[GI[`{3GfPg|">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="?jy5dedv*E!QXGSi|NNj">
        <value name="IF0">
        <block type="logic_compare" id="Nq,pYQn=QZIL]h`|k!{R">
        <value name="A">
        <block type="get_value" id="VfAn.8Ks0/7;o3resSQV">
        <field name="OID">zigbee.0.00158d00027cf30f.tap</field>
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="|36:z7/2Lb=#qES!gYLY">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="oJNg%*z]?4?HpsN(**@L">
        <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPlay</field>
        <block type="logic_boolean" id="A2(PP+y4,{@#nKdC)b:x">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </xml>
                                    AsgothianA Offline
                                    Asgothian
                                    Mit beidem komme ich klar - allerdings ist das Skript ungünstig geschrieben, es verschwendet Ressourcen durch ‘Multi-trigger’ (ja, intern wird der eine trigger Baustein in 9 einzelne trigger aufgelöst.) - in jedem davon holst du von 9 DP den Wert.
                                    Ich würde dir empfehlen:
                                    • Skript anpassen auf einen trigger auf den DP action, Änderung ist größer als vorher. Dessen Wert ist ein String, und der sollte aktiv werden bei jeder Aktion.
                                    • statt dem get_state (im Blockly dem Wert von … Baustein) machst du einen Vergleich nach dem Muster wert == “rotate_left” (oder die anderen Aktionen). Wert ist dabei ein Baustein aus dem trigger Bereich und beinhaltet den Wert des DP der den trigger ausgelöst hat.
                                      Beispiel Screenshot (auf englisch) kann ich später nachliefern.
                                    Damit sollten wir den Fehler auch weg bekommen ohne weiter zu analysieren, da du den trigger DP neu auswählst.
                                    Die Information zur ObjektID ist noch nicht gepostet, und das bei der Auswahl alles korrekt zu sein scheint ist leider normal - Das Auswahlfenster erkennt die nicht vorhandenen states nur wenn du versuchst sie neu auszuwählen.
                                    A.
                                      A.
                                      KusselinK Offline
                                      KusselinK Offline
                                      Kusselin
                                      @Asgothian sagte:
                                      O.K. das habe ich verstanden...im Blockly sind die 9 DP zusammen in diesem einen Trigger drin...das ist nicht gut sagst du..ok.
                                      Gibts ev. noch einen Screenshot von einem ähnlichen Blockly oder J-Script das ich es mal sehen kann?
                                      @Asgothian sagte:
                                      ja das wäre für mich echt gut...ich hole mir die Blocklys halt von anderen Nutzern und bastel bzw. flicke die dann zusammen...
                                      schau mal @asgothian ..so besser? Könnte es aber erst heute nachmittag testen..
                                      <block type="on" id="aA1action0Trigger0000" x="-287" y="-388">
                                      <field name="OID">zigbee.0.00158d00027cf30f.action</field>
                                      <field name="CONDITION">gt</field>
                                      <value name="IF0">
                                      <block type="logic_compare" id=";i]cfZdrmL/qXWB6PuO">
                                      <value name="A">
                                      ^vBlC@">
                                      </block>
                                      </value>
                                      <value name="B">
                                      <block type="text" id="txtRotL0000000000000">
                                      <field name="TEXT">rotate_left</field>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      <value name="A">
                                      </shadow>
                                      </block>
                                      </value>
                                      <value name="B">
                                      </shadow>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </statement>
                                      <next>
                                      <value name="IF0">
                                      <value name="A">
                                      <block type="get_value" id="O~YYmKWdN!Mw72DDncL"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.action</field> </block> </value> <value name="B"> <block type="text" id="txtRotR0000000000000"> <field name="TEXT">rotate_right</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="w(o*h=O4naq)R:K(V7BZ"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">100</field> <field name="UNIT">ms</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="math_arithmetic" id="!_r@b%{RRXbB78L@gy=Q"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number" id="M|^U,9}PJ?Ze7Tp:0l-["> <field name="NUM">1</field> </shadow> <block type="get_value" id="C({F@Kx^Xfa}LQ}:J.f?"> <field name="ATTR">val</field> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume</field> </block> </value> <value name="B"> <shadow type="math_number" id="%l[aeB:EcnIHkKMA1VTC"> <field name="NUM">5</field> </shadow> </value> </block> </value> </block> </statement> <next> <block type="controls_if" id="T%b0W^#l-ZWU%w^7]WQ/"> <value name="IF0"> <block type="logic_compare" id="=(DbOS78=0MBQe=F%*.D"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="DpgzqNoWjD?gGY|.nPM_"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.action</field> </block> </value> <value name="B"> <block type="text" id="txtFlip9000000000000"> <field name="TEXT">flip90</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="XSX3p0d(aQb.=Q;!Pl">
                                      }1USc-uhv}_">
                                      </block>
                                      </value>
                                      </block>
                                      </statement>
                                      <next>
                                      <value name="IF0">
                                      <block type="logic_compare" id="P-11~fVNv0~,i6Z]kfW"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="*FX)kI39Db7wYP5[:xl+"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.action</field> </block> </value> <value name="B"> <block type="text" id="txtFlip180000000000"> <field name="TEXT">flip180</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="!NUVA~(c4QgG]+~(E|^i"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="vqzCyqOR/s6Y7s21%;[F"> <field name="TEXT">YOU FM</field> </block> </value> </block> </statement> <next> <block type="controls_if" id=",Fq$U/,8:7stB7Z*~Xtv"> <value name="IF0"> <block type="logic_compare" id=".cop*h-}DoYl2o8E@%5{"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="tew,S#WRiF^%yTMOm,+h"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.action</field> </block> </value> <value name="B"> <block type="text" id="txtSlide00000000000"> <field name="TEXT">slide</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="sOf=BcVH:fZOEpzDS)-">
                                      </block>
                                      </value>
                                      </block>
                                      </statement>
                                      <next>
                                      <block type="controls_if" id="L(VjI7c;qpbDvh5(w.Y"> <value name="IF0"> <block type="logic_compare" id="M|9q*GjAQ9x{[k}dca+">
                                      <value name="A">
                                      </block>
                                      </value>
                                      <value name="B">
                                      <block type="text" id="txtFall00000000000000">
                                      <field name="TEXT">fall</field>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </statement>
                                      <next>
                                      <value name="IF0">
                                      <block type="logic_compare" id=".5XJGz4u6:p[#j+uoBh"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="Tc#Gzin|@s,p7.86ILp/"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.action</field> </block> </value> <value name="B"> <block type="text" id="txtShake0000000000000"> <field name="TEXT">shake</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="E]3~1B]ZQQdBY9/459z["> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPause</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="5t-IeJ[V[GI[{3GfPg|">
                                      </block>
                                      </value>
                                      </block>
                                      </statement>
                                      <next>
                                      <value name="IF0">
                                      <value name="A">
                                      </block>
                                      </value>
                                      <value name="B">
                                      <block type="text" id="txtTap00000000000000">
                                      <field name="TEXT">tap</field>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </value>
                                      </block>
                                      </statement>
                                      </block>
                                      </next>
                                      </block>
                                      </next>
                                      </block>
                                      </next>
                                      </block>
                                      </next>
                                      </block>
                                      </next>
                                      </block>
                                      </next>
                                      </block>
                                      </next>
                                      </block>
                                      </statement>
                                      </block>
                                        AsgothianA Offline
                                        Asgothian
                                        Durch diesen
                                        Ersetzen.
                                          Durch diesen
                                          Ersetzen.
                                          KusselinK Offline
                                          KusselinK Offline
                                          Kusselin
                                          @Asgothian sagte:
                                          Durch diesen
                                          Ersetzen.
                                          Kannst du bitte das zweite bild komplett in der länge posten und das erste auch bitte.
