Zigbee Adapter v3.3.5 und Javascript Adapter und Cube
Hallo Zusammen,
ich bins nochmal....habe den Zigbee Adapter auf aktuelle Version geupdatet...soweit so gut....beim Cube war die Batterie leer...also habe ich mir eine neue Knopfzelle bestellt. Nun eingebaut und neu gepairt.....wenn ich jetzt die Gesten durchführe kommen diese Fehlermeldungen:096 Log-Größe: 16.9 KB Zeit javascript.0 2026-08-11 19:50:28.207 warn getState "zigbee.0.00158d00027cf30f.rotate_left" not found (3) javascript.0 2026-08-11 19:50:28.210 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:3:9) javascript.0 2026-08-11 19:50:28.210 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.210 warn at process.callbackTrampoline (node:internal/async_hooks:130:17) javascript.0 2026-08-11 19:50:28.210 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.210 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.210 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.210 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.210 warn getState "zigbee.0.00158d00027cf30f.rotate_right" not found (3) javascript.0 2026-08-11 19:50:28.211 warn getState "zigbee.0.00158d00027cf30f.flip90" not found (3) javascript.0 2026-08-11 19:50:28.211 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.211 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.211 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.211 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:6:7) javascript.0 2026-08-11 19:50:28.211 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.211 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.211 warn at process.callbackTrampoline (node:internal/async_hooks:130:17) javascript.0 2026-08-11 19:50:28.214 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:9:7) javascript.0 2026-08-11 19:50:28.214 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.214 warn at process.callbackTrampoline (node:internal/async_hooks:130:17) javascript.0 2026-08-11 19:50:28.214 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.214 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.214 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.214 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.214 warn getState "zigbee.0.00158d00027cf30f.flip180" not found (3) javascript.0 2026-08-11 19:50:28.215 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.215 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.215 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.215 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:12:7) javascript.0 2026-08-11 19:50:28.215 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.215 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.216 warn at process.callbackTrampoline (node:internal/async_hooks:130:17) javascript.0 2026-08-11 19:50:28.216 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.216 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.216 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:15:7) javascript.0 2026-08-11 19:50:28.216 warn at process.callbackTrampoline (node:internal/async_hooks:130:17) javascript.0 2026-08-11 19:50:28.216 warn getState "zigbee.0.00158d00027cf30f.slide" not found (3) javascript.0 2026-08-11 19:50:28.216 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.216 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.216 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.216 warn getState "zigbee.0.00158d00027cf30f.tap" not found (3) states[id]=null javascript.0 2026-08-11 19:50:28.219 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:24:7) javascript.0 2026-08-11 19:50:28.219 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.219 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.219 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.219 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.219 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.219 warn at process.callbackTrampoline (node:internal/async_hooks:130:17) javascript.0 2026-08-11 19:50:28.646 warn getState "zigbee.0.00158d00027cf30f.rotate_left" not found (3) javascript.0 2026-08-11 19:50:28.647 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:3:9) javascript.0 2026-08-11 19:50:28.647 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.647 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.647 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.647 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.647 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.647 warn at process.callbackTrampoline (node:internal/async_hooks:130:17) javascript.0 2026-08-11 19:50:28.648 warn getState "zigbee.0.00158d00027cf30f.rotate_right" not found (3) javascript.0 2026-08-11 19:50:28.648 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:6:7) javascript.0 2026-08-11 19:50:28.648 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.648 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.648 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.648 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.649 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.649 warn at process.callbackTrampoline (node:internal/async_hooks:130:17) javascript.0 2026-08-11 19:50:28.649 warn getState "zigbee.0.00158d00027cf30f.flip90" not found (3) javascript.0 2026-08-11 19:50:28.652 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:9:7) javascript.0 2026-08-11 19:50:28.652 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.653 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.653 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.653 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.653 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.653 warn at process.callbackTrampoline (node:internal/async_hooks:130:17) javascript.0 2026-08-11 19:50:28.653 warn getState "zigbee.0.00158d00027cf30f.flip180" not found (3) javascript.0 2026-08-11 19:50:28.653 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:12:7) javascript.0 2026-08-11 19:50:28.654 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.654 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.654 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.654 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.654 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.654 warn at process.callbackTrampoline (node:internal/async_hooks:130:17) javascript.0 2026-08-11 19:50:28.654 warn getState "zigbee.0.00158d00027cf30f.slide" not found (3) javascript.0 2026-08-11 19:50:28.657 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:15:7) javascript.0 2026-08-11 19:50:28.657 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.657 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.657 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.657 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.657 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.657 warn at process.callbackTrampoline (node:internal/async_hooks:130:17) javascript.0 2026-08-11 19:50:28.657 warn getState "zigbee.0.00158d00027cf30f.tap" not found (3) states[id]=null javascript.0 2026-08-11 19:50:28.661 warn at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:24:7) javascript.0 2026-08-11 19:50:28.661 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38) javascript.0 2026-08-11 19:50:28.661 warn at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25) javascript.0 2026-08-11 19:50:28.661 warn at JavaScript.emit (node:events:519:28) javascript.0 2026-08-11 19:50:28.661 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) javascript.0 2026-08-11 19:50:28.661 warn at processImmediate (node:internal/timers:484:21) javascript.0 2026-08-11 19:50:28.661 warn at process.callbackTrampoline (node:internal/async_hooks:130:17)woebei die Fehlermeldungen ja vom Javascript Adapter kommen....aber die Datenpunkte habe ich ja nicht geändert..
Könnt Ihr mir bitte helfen was hier faslch läuft?
Hallo Zusammen,
Hallo Zusammen, jetzt hekomm ich gleich Schelte...
Wie magst du die Datenpunkte? Ein ScreenshotWenns die DPs sind müsste ich einfach die jetzigen
Datenpunkte löschen und Adapter neu starten oder?@Kusselin
Datenpunkte gerne als Screenshot. Und löschen und adapter neu starten wird nichts bringen - wenn die DP's sich ZHC zeitig geändert haben musst du entweder die Skripte anpassen oder über die ab 3.5.5 vorhandene Option modify_state die vom Adapter angelegten States ändern (riskant)A,
Leider fehlt der entscheidende Teil - das device selber wo ich sehen kann ob der Name insgesamt passt. Offensichtlich gibt es ein
.rotate_left, aber was ist mit demzigbee.0.00158d0027cf30f?Leider fehlt der entscheidende Teil - das device selber wo ich sehen kann ob der Name insgesamt passt. Offensichtlich gibt es ein
.rotate_left, aber was ist mit demzigbee.0.00158d0027cf30f?Und wie kann ich Dir den entscheidende Teil liefern?
Das hier?
{ "type": "state", "common": { "name": "rotate_left", "type": "boolean", "read": true, "write": false, "role": "button" }, "native": {}, "from": "system.adapter.zigbee.0", "user": "system.user.admin", "ts": 1786463170345, "_id": "zigbee.0.00158d00027cf30f.rotate_left", "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" } } -
Den Screenshot erweitern so das die 3 oder 4 Zeilen oberhalb von
actionauch sichtbar sind zeigt die entscheidende Info. Das was in_idsteht ist ein Hinweis, aber nicht unbedingt entscheidend.A.
@Asgothian da steht nix
der wird nicht aktualisier.. deshalb steht der rotate_left auch auf null
Hi, da steht oberhalb von ACTION NICHTS MEHR NUR NOCHBDIE ID VOM CUBE die ich einklagen kann. Wenn ich den cube hochwerfe und dann geht die A. Auch an, gleichzeitig triggerd der javascript die Fehler??
Wie und was kann ich machen um dir die gewünschte Info zukommen zu lassen?Aber man sieht ja an manchen Datenpunkten das "good".
Muss ich hier dann vielleicht erstmal alle "Gesten" durchgehen das da überall good steht?
Es geht gerade um die ID des Cube. Der datenpunkt den das Skript haben will scheint angeblich nicht da zu sein, aber dein Screenshot zeigt das er da ist. Also passt etwas mit der ID nicht. Der Eintrag
_idim Objekt wird beim erstellen gesetzt, aber z.bsp. Nicht beim importieren aus json aktualisiert.Das der DP einen Wert
nullhat kann die Fehler im Skript nicht erzeugen.A.
Nachtrag: zeig auch mal bitte das Skript.
Guten Morgen,
bringt dir das was....so? Wie kopiere ich ein komplettes Blockly?on({ id: [].concat(['zigbee.0.00158d00027cf30f.rotate_left']).concat(['zigbee.0.00158d00027cf30f.flip90']).concat(['zigbee.0.00158d00027cf30f.rotate_right']).concat(['zigbee.0.00158d00027cf30f.shake']).concat(['zigbee.0.00158d00027cf30f.tap']).concat(['zigbee.0.00158d00027cf30f.slide']).concat(['zigbee.0.00158d00027cf30f.flip180']).concat(['zigbee.0.00158d00027cf30f.fall']), change: 'ne' }, async (obj) => { if (getState('zigbee.0.00158d00027cf30f.rotate_left').val == true) { setStateDelayed('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume' /* volume */, (getState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume').val - 5), 100, false); } if (getState('zigbee.0.00158d00027cf30f.rotate_right').val == true) { setStateDelayed('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume' /* volume */, (getState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume').val + 5), 100, false); } if (getState('zigbee.0.00158d00027cf30f.flip90').val == true) { setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'FFH iTunes Top 40'); } if (getState('zigbee.0.00158d00027cf30f.flip180').val == true) { setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'YOU FM'); } if (getState('zigbee.0.00158d00027cf30f.slide').val == true) { setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'ANTENNE BAYERN'); } if (getState('zigbee.0.00158d00027cf30f.fall').val == true) { setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'radio SAW-Party'); } if (getState('zigbee.0.00158d00027cf30f.shake').val == true) { setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPause' /* controlPause */, true); } if (getState('zigbee.0.00158d00027cf30f.tap').val == true) { setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPlay' /* controlPlay */, true); } });oder
<xml xmlns="https://developers.google.com/blockly/xml"> <block type="on_ext" id="#dU%bHFVm/~[XFv;e5M5" x="-287" y="-388"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="8"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="luObs(yNi=oW98s~lUkF"> <field name="oid">zigbee.0.00158d00027cf30f.rotate_left</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id="|X5zwhq%~Zkbz~1R0r1^"> <field name="oid">zigbee.0.00158d00027cf30f.flip90</field> </shadow> </value> <value name="OID2"> <shadow type="field_oid" id=":!;dbL6TpMMEGN+0WBIe"> <field name="oid">zigbee.0.00158d00027cf30f.rotate_right</field> </shadow> </value> <value name="OID3"> <shadow type="field_oid" id="Ig5d`gN3)^t%EXeY.S-Z"> <field name="oid">zigbee.0.00158d00027cf30f.shake</field> </shadow> </value> <value name="OID4"> <shadow type="field_oid" id="lkE{jhvkV[j=uBCI~?Qz"> <field name="oid">zigbee.0.00158d00027cf30f.tap</field> </shadow> </value> <value name="OID5"> <shadow type="field_oid" id="6Tv(MB{kY:1zhNR]B$X*"> <field name="oid">zigbee.0.00158d00027cf30f.slide</field> </shadow> </value> <value name="OID6"> <shadow type="field_oid" id="cL{yeW/ld7GDq$kIw.SC"> <field name="oid">zigbee.0.00158d00027cf30f.flip180</field> </shadow> </value> <value name="OID7"> <shadow type="field_oid" id="$B2-v8yXc{rE}@Vr*=~9"> <field name="oid">zigbee.0.00158d00027cf30f.fall</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id=",9_Nr-P-{%Fd+Tc0-=Nu"> <value name="IF0"> <block type="logic_compare" id=";_i]cfZdrmL/qXWB6PuO"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="05hB:}da}@CQX_^vBlC@"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.rotate_left</field> </block> </value> <value name="B"> <block type="logic_boolean" id="ZT5]2tgD5CM]Of-|;}#F"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="}6;6~]L4/!BY.JwxYt#d"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">100</field> <field name="UNIT">ms</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="math_arithmetic" id="?Jr}iv/yilVo.s[Yu?mx"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="M|^U,9}PJ?Ze7Tp:0l-["> <field name="NUM">1</field> </shadow> <block type="get_value" id="YwLlb+nx4qTOJFvljerY"> <field name="ATTR">val</field> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume</field> </block> </value> <value name="B"> <shadow type="math_number" id="HvU;CRog.Utv3?toGeqk"> <field name="NUM">5</field> </shadow> </value> </block> </value> </block> </statement> <next> <block type="controls_if" id="}CAVnkOHSlC0^OuF^Jgu"> <value name="IF0"> <block type="logic_compare" id="{H:^dKPD7}11B/qgk6JU"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="`O~YYmKWdN!Mw72DDncL"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.rotate_right</field> </block> </value> <value name="B"> <block type="logic_boolean" id="FoREtBH+=iZ6hv|p8Fd@"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="w(o*h=O4naq)R:K(V7BZ"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">100</field> <field name="UNIT">ms</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="math_arithmetic" id="!_r@b%{RRXbB78L@gy=Q"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number" id="M|^U,9}PJ?Ze7Tp:0l-["> <field name="NUM">1</field> </shadow> <block type="get_value" id="C({F@Kx^Xfa}LQ}:J.f?"> <field name="ATTR">val</field> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume</field> </block> </value> <value name="B"> <shadow type="math_number" id="%l[aeB:EcnIHkKMA1VTC"> <field name="NUM">5</field> </shadow> </value> </block> </value> </block> </statement> <next> <block type="controls_if" id="T%b0W^#l-ZWU%w^7]WQ/"> <value name="IF0"> <block type="logic_compare" id="=(DbOS78=0MBQe=F%*.D"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="DpgzqNoWjD?gGY|.nPM_"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.flip90</field> </block> </value> <value name="B"> <block type="logic_boolean" id="DkzF1(|Ey=3{V,DFkJfD"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="XSX3p0d(aQb.=Q`_;!Pl"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="-4]H.r+U_}1USc-uhv}_"> <field name="TEXT">FFH iTunes Top 40</field> </block> </value> </block> </statement> <next> <block type="controls_if" id="3g/0(WCRy;oCL?_d8(.C"> <value name="IF0"> <block type="logic_compare" id="P-11~fV`Nv0~,i6Z]kfW"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="*FX)kI39Db7wYP5[:xl+"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.flip180</field> </block> </value> <value name="B"> <block type="logic_boolean" id="9ZzpRTsuv4C9x)%pr,Es"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="!NUVA~(c4QgG]+~(E|^i"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="vqzCyqOR/s6Y7s21%;[F"> <field name="TEXT">YOU FM</field> </block> </value> </block> </statement> <next> <block type="controls_if" id=",Fq$U/,8:7stB7Z*~Xtv"> <value name="IF0"> <block type="logic_compare" id=".cop*h-}DoYl2o8E@%5{"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="tew,S#WRiF^%yTMOm,+h"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.slide</field> </block> </value> <value name="B"> <block type="logic_boolean" id="]]lBl9XbxKIb%5WJ$Ja/"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="sOf=BcVH`:fZOEpzDS)-"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="VN8FGL^,)9K;L|!rdwUS"> <field name="TEXT">ANTENNE BAYERN</field> </block> </value> </block> </statement> <next> <block type="controls_if" id="L(VjI7c;qpbDvh5(w`.Y"> <value name="IF0"> <block type="logic_compare" id="M|9q*GjAQ9x`{[k}dca+"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="ro?b.ZMu3E=qk.NTo|l9"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.fall</field> </block> </value> <value name="B"> <block type="logic_boolean" id="s%[mn]65k*ugyLb_.=TL"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="Db;0%17/~z}Bh%#w64wr"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="6U$-BxPPddFN/,9!k]K$"> <field name="TEXT">radio SAW-Party</field> </block> </value> </block> </statement> <next> <block type="controls_if" id="W|nOmNk7Ri}Fs|:3bNvo"> <value name="IF0"> <block type="logic_compare" id=".`5XJGz4u6:p[#j+uoBh"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="Tc#Gzin|@s,p7.86ILp/"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.shake</field> </block> </value> <value name="B"> <block type="logic_boolean" id="sH3Sm+bH^3l}+?.kIlZ*"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="E]3~1B]ZQQdBY9/459z["> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPause</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="5t-IeJ[V[GI[`{3GfPg|"> <field name="BOOL">TRUE</field> </block> </value> </block> </statement> <next> <block type="controls_if" id="?jy5dedv*E!QXGSi|NNj"> <value name="IF0"> <block type="logic_compare" id="Nq,pYQn=QZIL]h`|k!{R"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="VfAn.8Ks0/7;o3resSQV"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.tap</field> </block> </value> <value name="B"> <block type="logic_boolean" id="|36:z7/2Lb=#qES!gYLY"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="oJNg%*z]?4?HpsN(**@L"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPlay</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="A2(PP+y4,{@#nKdC)b:x"> <field name="BOOL">TRUE</field> </block> </value> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </xml> -
Mit beidem komme ich klar - allerdings ist das Skript ungünstig geschrieben, es verschwendet Ressourcen durch ‘Multi-trigger’ (ja, intern wird der eine trigger Baustein in 9 einzelne trigger aufgelöst.) - in jedem davon holst du von 9 DP den Wert.
Ich würde dir empfehlen:
- Skript anpassen auf einen trigger auf den DP
action, Änderungist größer als vorher. Dessen Wert ist ein String, und der sollte aktiv werden bei jeder Aktion. - statt dem
get_state(im Blockly demWert von …Baustein) machst du einen Vergleich nach dem Musterwert== “rotate_left” (oder die anderen Aktionen).Wertist dabei ein Baustein aus dem trigger Bereich und beinhaltet den Wert des DP der den trigger ausgelöst hat.
Beispiel Screenshot (auf englisch) kann ich später nachliefern.
Damit sollten wir den Fehler auch weg bekommen ohne weiter zu analysieren, da du den trigger DP neu auswählst.
Die Information zur ObjektID ist noch nicht gepostet, und das bei der Auswahl alles korrekt zu sein scheint ist leider normal - Das Auswahlfenster erkennt die nicht vorhandenen states nur wenn du versuchst sie neu auszuwählen.
A.
A.
O.K. das habe ich verstanden...im Blockly sind die 9 DP zusammen in diesem einen Trigger drin...das ist nicht gut sagst du..ok.
Gibts ev. noch einen Screenshot von einem ähnlichen Blockly oder J-Script das ich es mal sehen kann?
@Asgothian sagte:
Beispiel Screenshot (auf englisch) kann ich später nachliefern.ja das wäre für mich echt gut...ich hole mir die Blocklys halt von anderen Nutzern und bastel bzw. flicke die dann zusammen...
schau mal @asgothian ..so besser? Könnte es aber erst heute nachmittag testen..
Bedingt. Bitte jedes auftreten dieses blocks
Durch diesen
Ersetzen.
Kannst du bitte das zweite bild komplett in der länge posten und das erste auch bitte.
@Kusselin beide Bilder sind aus dem Skript welche du gepostet hast. Dahinter steht in beiden fällen das gleiche. Es geht darum den Baustein “Wert von …” gegen den Baustein “Wert” aus dem trigger Bereich auszutauschen.
Längere Screenshots kann ich erst heute Abend machen.
Hab nun die Gesten nochmal nachgemacht und dann wurde aus dem „null“ ein „good“ und das script geändert ..nun kommen keine Fehlermeldungen mehr beim Gesten machen mit dem Cube..danke @asgothian
