  4. Zigbee Adapter v3.3.5 und Javascript Adapter und Cube
    6.3k
22 Beiträge 5 Kommentatoren 361 Aufrufe 4 Beobachtet
  • KusselinK Kusselin
    Hallo Zusammen,
    ich bins nochmal....habe den Zigbee Adapter auf aktuelle Version geupdatet...soweit so gut....beim Cube war die Batterie leer...also habe ich mir eine neue Knopfzelle bestellt. Nun eingebaut und neu gepairt.....wenn ich jetzt die Gesten durchführe kommen diese Fehlermeldungen:
    096
    Log-Größe: 16.9 KB
    Zeit
    javascript.0
    	2026-08-11 19:50:28.207	warn	getState "zigbee.0.00158d00027cf30f.rotate_left" not found (3)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:3:9)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.210	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.210	warn	getState "zigbee.0.00158d00027cf30f.rotate_right" not found (3)
    javascript.0
    	2026-08-11 19:50:28.211	warn	getState "zigbee.0.00158d00027cf30f.flip90" not found (3)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:6:7)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.211	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:9:7)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.214	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.214	warn	getState "zigbee.0.00158d00027cf30f.flip180" not found (3)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:12:7)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.215	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:15:7)
    javascript.0
    javascript.0
    	2026-08-11 19:50:28.216	warn	getState "zigbee.0.00158d00027cf30f.slide" not found (3)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.216	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.216	warn	getState "zigbee.0.00158d00027cf30f.tap" not found (3) states[id]=null
    javascript.0
    	2026-08-11 19:50:28.219	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:24:7)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.219	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.646	warn	getState "zigbee.0.00158d00027cf30f.rotate_left" not found (3)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:3:9)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.647	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.648	warn	getState "zigbee.0.00158d00027cf30f.rotate_right" not found (3)
    javascript.0
    	2026-08-11 19:50:28.648	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:6:7)
    javascript.0
    	2026-08-11 19:50:28.648	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.648	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.648	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.648	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.649	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.649	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.649	warn	getState "zigbee.0.00158d00027cf30f.flip90" not found (3)
    javascript.0
    	2026-08-11 19:50:28.652	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:9:7)
    javascript.0
    	2026-08-11 19:50:28.652	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.653	warn	getState "zigbee.0.00158d00027cf30f.flip180" not found (3)
    javascript.0
    	2026-08-11 19:50:28.653	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:12:7)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.654	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.654	warn	getState "zigbee.0.00158d00027cf30f.slide" not found (3)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:15:7)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.657	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    javascript.0
    	2026-08-11 19:50:28.657	warn	getState "zigbee.0.00158d00027cf30f.tap" not found (3) states[id]=null
    javascript.0
    	2026-08-11 19:50:28.661	warn	at Object.<anonymous> (script.js.Küche.Alexa_radio_starten_mit_Cube_Küche:24:7)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at JavaScript.emit (node:events:519:28)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at processImmediate (node:internal/timers:484:21)
    javascript.0
    	2026-08-11 19:50:28.661	warn	at process.callbackTrampoline (node:internal/async_hooks:130:17)
    woebei die Fehlermeldungen ja vom Javascript Adapter kommen....aber die Datenpunkte habe ich ja nicht geändert..
    Könnt Ihr mir bitte helfen was hier faslch läuft?
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @Kusselin sagte:
    zeig mal bitte die Datenpunkte des Cubes im Objektbaum. Es ist denkbar das sich die ID;s der Datenpunkte geändert haben.
    A.
    • KusselinK Offline
      KusselinK Offline
      Kusselin
      Hallo Zusammen, jetzt hekomm ich gleich Schelte...
      Wie magst du die Datenpunkte? Ein Screenshot
      Wenns die DPs sind müsste ich einfach die jetzigen
      Datenpunkte löschen und Adapter neu starten oder?
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @Kusselin
        Datenpunkte gerne als Screenshot. Und löschen und adapter neu starten wird nichts bringen - wenn die DP's sich ZHC zeitig geändert haben musst du entweder die Skripte anpassen oder über die ab 3.5.5 vorhandene Option modify_state die vom Adapter angelegten States ändern (riskant)
        A,
        • KusselinK Offline
          KusselinK Offline
          Kusselin
          • AsgothianA Offline
            AsgothianA Offline
            Asgothian
            Leider fehlt der entscheidende Teil - das device selber wo ich sehen kann ob der Name insgesamt passt. Offensichtlich gibt es ein .rotate_left, aber was ist mit dem zigbee.0.00158d0027cf30f ?
            KusselinK 1 Antwort Letzte Antwort
            • AsgothianA Asgothian
              KusselinK Offline
              KusselinK Offline
              Kusselin
              @Asgothian sagte:
              Und wie kann ich Dir den entscheidende Teil liefern?
              Das hier?
                "type": "state",
                "common": {
                  "name": "rotate_left",
                  "type": "boolean",
                  "read": true,
                  "write": false,
                  "role": "button"
                "native": {},
                "from": "system.adapter.zigbee.0",
                "user": "system.user.admin",
                "ts": 1786463170345,
                "_id": "zigbee.0.00158d00027cf30f.rotate_left",
                "acl": {
                  "object": 1636,
                  "state": 1636,
                  "owner": "system.user.admin",
                AsgothianA Offline
                Asgothian
                Den Screenshot erweitern so das die 3 oder 4 Zeilen oberhalb von action auch sichtbar sind zeigt die entscheidende Info. Das was in _id steht ist ein Hinweis, aber nicht unbedingt entscheidend.
                A.
                  A.
                  arteckA Offline
                  arteckA Offline
                  arteck
                  der wird nicht aktualisier.. deshalb steht der rotate_left auch auf null
                  • KusselinK Offline
                    KusselinK Offline
                    Kusselin
                    schrieb am zuletzt editiert von Kusselin
                    Hi, da steht oberhalb von ACTION NICHTS MEHR NUR NOCHBDIE ID VOM CUBE die ich einklagen kann. Wenn ich den cube hochwerfe und dann geht die A. Auch an, gleichzeitig triggerd der javascript die Fehler??
                    Wie und was kann ich machen um dir die gewünschte Info zukommen zu lassen?
                    Aber man sieht ja an manchen Datenpunkten das "good".
                    Muss ich hier dann vielleicht erstmal alle "Gesten" durchgehen das da überall good steht?
                      AsgothianA Offline
                      Asgothian
                      Es geht gerade um die ID des Cube. Der datenpunkt den das Skript haben will scheint angeblich nicht da zu sein, aber dein Screenshot zeigt das er da ist. Also passt etwas mit der ID nicht. Der Eintrag _id im Objekt wird beim erstellen gesetzt, aber z.bsp. Nicht beim importieren aus json aktualisiert.
                      Das der DP einen Wert null hat kann die Fehler im Skript nicht erzeugen.
                      A.
                      Nachtrag: zeig auch mal bitte das Skript.
                      • KusselinK Offline
                        KusselinK Offline
                        Kusselin
                        Hi danke dir erstmal.. ich mach das heute nachmittag in Ruhe.
                        Wenn man doch aber im Script zb auf den Wert klickt, dann geht aber der datenpunkt zb rotate_left korrekt auf.. hoffe du verstehst was ich meine?
                          A.
                          KusselinK Offline
                          KusselinK Offline
                          Kusselin
                          @Asgothian sagte:
                          A.
                          Guten Morgen,
                          bringt dir das was....so? Wie kopiere ich ein komplettes Blockly?
                          on({ id: [].concat(['zigbee.0.00158d00027cf30f.rotate_left']).concat(['zigbee.0.00158d00027cf30f.flip90']).concat(['zigbee.0.00158d00027cf30f.rotate_right']).concat(['zigbee.0.00158d00027cf30f.shake']).concat(['zigbee.0.00158d00027cf30f.tap']).concat(['zigbee.0.00158d00027cf30f.slide']).concat(['zigbee.0.00158d00027cf30f.flip180']).concat(['zigbee.0.00158d00027cf30f.fall']), change: 'ne' }, async (obj) => {
                            if (getState('zigbee.0.00158d00027cf30f.rotate_left').val == true) {
                              setStateDelayed('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume' /* volume */, (getState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume').val - 5), 100, false);
                            if (getState('zigbee.0.00158d00027cf30f.rotate_right').val == true) {
                              setStateDelayed('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume' /* volume */, (getState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume').val + 5), 100, false);
                            if (getState('zigbee.0.00158d00027cf30f.flip90').val == true) {
                              setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'FFH iTunes Top 40');
                            if (getState('zigbee.0.00158d00027cf30f.flip180').val == true) {
                              setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'YOU FM');
                            if (getState('zigbee.0.00158d00027cf30f.slide').val == true) {
                              setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'ANTENNE BAYERN');
                            if (getState('zigbee.0.00158d00027cf30f.fall').val == true) {
                              setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn' /* Phrase to play with TuneIn */, 'radio SAW-Party');
                            if (getState('zigbee.0.00158d00027cf30f.shake').val == true) {
                              setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPause' /* controlPause */, true);
                            if (getState('zigbee.0.00158d00027cf30f.tap').val == true) {
                              setState('alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPlay' /* controlPlay */, true);
                          oder
                            <block type="on_ext" id="#dU%bHFVm/~[XFv;e5M5" x="-287" y="-388">
                              <mutation xmlns="http://www.w3.org/1999/xhtml" items="8"></mutation>
                              <value name="OID0">
                                <shadow type="field_oid" id="luObs(yNi=oW98s~lUkF">
                                  <field name="oid">zigbee.0.00158d00027cf30f.rotate_left</field>
                                </shadow>
                              </value>
                              <value name="OID1">
                                <shadow type="field_oid" id="|X5zwhq%~Zkbz~1R0r1^">
                                  <field name="oid">zigbee.0.00158d00027cf30f.flip90</field>
                                </shadow>
                              </value>
                              <value name="OID2">
                                <shadow type="field_oid" id=":!;dbL6TpMMEGN+0WBIe">
                                  <field name="oid">zigbee.0.00158d00027cf30f.rotate_right</field>
                                </shadow>
                              </value>
                              <value name="OID3">
                                <shadow type="field_oid" id="Ig5d`gN3)^t%EXeY.S-Z">
                                  <field name="oid">zigbee.0.00158d00027cf30f.shake</field>
                                </shadow>
                              </value>
                              <value name="OID4">
                                <shadow type="field_oid" id="lkE{jhvkV[j=uBCI~?Qz">
                                  <field name="oid">zigbee.0.00158d00027cf30f.tap</field>
                                </shadow>
                              </value>
                              <value name="OID5">
                                <shadow type="field_oid" id="6Tv(MB{kY:1zhNR]B$X*">
                                  <field name="oid">zigbee.0.00158d00027cf30f.slide</field>
                                </shadow>
                              </value>
                              <value name="OID6">
                                <shadow type="field_oid" id="cL{yeW/ld7GDq$kIw.SC">
                                  <field name="oid">zigbee.0.00158d00027cf30f.flip180</field>
                                </shadow>
                              </value>
                              <value name="OID7">
                                <shadow type="field_oid" id="$B2-v8yXc{rE}@Vr*=~9">
                                  <field name="oid">zigbee.0.00158d00027cf30f.fall</field>
                                </shadow>
                              </value>
                              <statement name="STATEMENT">
                                <block type="controls_if" id=",9_Nr-P-{%Fd+Tc0-=Nu">
                                  <value name="IF0">
                                    <block type="logic_compare" id=";_i]cfZdrmL/qXWB6PuO">
                                      <field name="OP">EQ</field>
                                      <value name="A">
                                        <block type="get_value" id="05hB:}da}@CQX_^vBlC@">
                                          <field name="OID">zigbee.0.00158d00027cf30f.rotate_left</field>
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="logic_boolean" id="ZT5]2tgD5CM]Of-|;}#F">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <statement name="DO0">
                                    <block type="control" id="}6;6~]L4/!BY.JwxYt#d">
                                      <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                                      <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume</field>
                                      <field name="DELAY_MS">100</field>
                                      <field name="UNIT">ms</field>
                                      <value name="VALUE">
                                        <block type="math_arithmetic" id="?Jr}iv/yilVo.s[Yu?mx">
                                          <value name="A">
                                            <shadow type="math_number" id="M|^U,9}PJ?Ze7Tp:0l-[">
                                              <field name="NUM">1</field>
                                            </shadow>
                                            <block type="get_value" id="YwLlb+nx4qTOJFvljerY">
                                            </block>
                                          </value>
                                          <value name="B">
                                            <shadow type="math_number" id="HvU;CRog.Utv3?toGeqk">
                                              <field name="NUM">5</field>
                                            </shadow>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <next>
                                    <block type="controls_if" id="}CAVnkOHSlC0^OuF^Jgu">
                                      <value name="IF0">
                                        <block type="logic_compare" id="{H:^dKPD7}11B/qgk6JU">
                                          <value name="A">
                                            <block type="get_value" id="`O~YYmKWdN!Mw72DDncL">
                                              <field name="OID">zigbee.0.00158d00027cf30f.rotate_right</field>
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="logic_boolean" id="FoREtBH+=iZ6hv|p8Fd@">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        <block type="control" id="w(o*h=O4naq)R:K(V7BZ">
                                            <block type="math_arithmetic" id="!_r@b%{RRXbB78L@gy=Q">
                                              <field name="OP">ADD</field>
                                              <value name="A">
                                                </shadow>
                                                <block type="get_value" id="C({F@Kx^Xfa}LQ}:J.f?">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <shadow type="math_number" id="%l[aeB:EcnIHkKMA1VTC">
                                                </shadow>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                      <next>
                                        <block type="controls_if" id="T%b0W^#l-ZWU%w^7]WQ/">
                                          <value name="IF0">
                                            <block type="logic_compare" id="=(DbOS78=0MBQe=F%*.D">
                                              <value name="A">
                                                <block type="get_value" id="DpgzqNoWjD?gGY|.nPM_">
                                                  <field name="OID">zigbee.0.00158d00027cf30f.flip90</field>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_boolean" id="DkzF1(|Ey=3{V,DFkJfD">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                            <block type="control" id="XSX3p0d(aQb.=Q`_;!Pl">
                                              <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn</field>
                                                <block type="text" id="-4]H.r+U_}1USc-uhv}_">
                                                  <field name="TEXT">FFH iTunes Top 40</field>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <next>
                                            <block type="controls_if" id="3g/0(WCRy;oCL?_d8(.C">
                                              <value name="IF0">
                                                <block type="logic_compare" id="P-11~fV`Nv0~,i6Z]kfW">
                                                  <value name="A">
                                                    <block type="get_value" id="*FX)kI39Db7wYP5[:xl+">
                                                      <field name="OID">zigbee.0.00158d00027cf30f.flip180</field>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="logic_boolean" id="9ZzpRTsuv4C9x)%pr,Es">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                <block type="control" id="!NUVA~(c4QgG]+~(E|^i">
                                                    <block type="text" id="vqzCyqOR/s6Y7s21%;[F">
                                                      <field name="TEXT">YOU FM</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                              <next>
                                                <block type="controls_if" id=",Fq$U/,8:7stB7Z*~Xtv">
                                                  <value name="IF0">
                                                    <block type="logic_compare" id=".cop*h-}DoYl2o8E@%5{">
                                                      <value name="A">
                                                        <block type="get_value" id="tew,S#WRiF^%yTMOm,+h">
                                                          <field name="OID">zigbee.0.00158d00027cf30f.slide</field>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="logic_boolean" id="]]lBl9XbxKIb%5WJ$Ja/">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                    <block type="control" id="sOf=BcVH`:fZOEpzDS)-">
                                                        <block type="text" id="VN8FGL^,)9K;L|!rdwUS">
                                                          <field name="TEXT">ANTENNE BAYERN</field>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                    <block type="controls_if" id="L(VjI7c;qpbDvh5(w`.Y">
                                                      <value name="IF0">
                                                        <block type="logic_compare" id="M|9q*GjAQ9x`{[k}dca+">
                                                          <value name="A">
                                                            <block type="get_value" id="ro?b.ZMu3E=qk.NTo|l9">
                                                              <field name="OID">zigbee.0.00158d00027cf30f.fall</field>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="logic_boolean" id="s%[mn]65k*ugyLb_.=TL">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                        <block type="control" id="Db;0%17/~z}Bh%#w64wr">
                                                            <block type="text" id="6U$-BxPPddFN/,9!k]K$">
                                                              <field name="TEXT">radio SAW-Party</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                      <next>
                                                        <block type="controls_if" id="W|nOmNk7Ri}Fs|:3bNvo">
                                                          <value name="IF0">
                                                            <block type="logic_compare" id=".`5XJGz4u6:p[#j+uoBh">
                                                              <value name="A">
        <block type="get_value" id="Tc#Gzin|@s,p7.86ILp/">
        <field name="OID">zigbee.0.00158d00027cf30f.shake</field>
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="logic_boolean" id="sH3Sm+bH^3l}+?.kIlZ*">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                            <block type="control" id="E]3~1B]ZQQdBY9/459z[">
                                                              <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPause</field>
        <block type="logic_boolean" id="5t-IeJ[V[GI[`{3GfPg|">
        </block>
                                                              </value>
                                                            </block>
                                                          </statement>
                                                          <next>
                                                            <block type="controls_if" id="?jy5dedv*E!QXGSi|NNj">
                                                              <value name="IF0">
        <block type="logic_compare" id="Nq,pYQn=QZIL]h`|k!{R">
        <value name="A">
        <block type="get_value" id="VfAn.8Ks0/7;o3resSQV">
        <field name="OID">zigbee.0.00158d00027cf30f.tap</field>
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="|36:z7/2Lb=#qES!gYLY">
        </block>
        </value>
        </block>
                                                              </value>
        <block type="control" id="oJNg%*z]?4?HpsN(**@L">
        <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPlay</field>
        <block type="logic_boolean" id="A2(PP+y4,{@#nKdC)b:x">
        </block>
        </value>
        </block>
                                                              </statement>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                            </block>
                          </xml>
                            AsgothianA Offline
                            Asgothian
                            Mit beidem komme ich klar - allerdings ist das Skript ungünstig geschrieben, es verschwendet Ressourcen durch ‘Multi-trigger’ (ja, intern wird der eine trigger Baustein in 9 einzelne trigger aufgelöst.) - in jedem davon holst du von 9 DP den Wert.
                            Ich würde dir empfehlen:
                            • Skript anpassen auf einen trigger auf den DP action, Änderung ist größer als vorher. Dessen Wert ist ein String, und der sollte aktiv werden bei jeder Aktion.
                            • statt dem get_state (im Blockly dem Wert von … Baustein) machst du einen Vergleich nach dem Muster wert == “rotate_left” (oder die anderen Aktionen). Wert ist dabei ein Baustein aus dem trigger Bereich und beinhaltet den Wert des DP der den trigger ausgelöst hat.
                              Beispiel Screenshot (auf englisch) kann ich später nachliefern.
                            Damit sollten wir den Fehler auch weg bekommen ohne weiter zu analysieren, da du den trigger DP neu auswählst.
                            Die Information zur ObjektID ist noch nicht gepostet, und das bei der Auswahl alles korrekt zu sein scheint ist leider normal - Das Auswahlfenster erkennt die nicht vorhandenen states nur wenn du versuchst sie neu auszuwählen.
                            A.
                              A.
                              KusselinK Offline
                              KusselinK Offline
                              Kusselin
                              @Asgothian sagte:
                              O.K. das habe ich verstanden...im Blockly sind die 9 DP zusammen in diesem einen Trigger drin...das ist nicht gut sagst du..ok.
                              Gibts ev. noch einen Screenshot von einem ähnlichen Blockly oder J-Script das ich es mal sehen kann?
                              @Asgothian sagte:
                              ja das wäre für mich echt gut...ich hole mir die Blocklys halt von anderen Nutzern und bastel bzw. flicke die dann zusammen...
                              schau mal @asgothian ..so besser? Könnte es aber erst heute nachmittag testen..
                              <block type="on" id="aA1action0Trigger0000" x="-287" y="-388">
                              <field name="OID">zigbee.0.00158d00027cf30f.action</field>
                              <field name="CONDITION">gt</field>
                              <value name="IF0">
                              <block type="logic_compare" id=";i]cfZdrmL/qXWB6PuO">
                              <value name="A">
                              ^vBlC@">
                              </block>
                              </value>
                              <value name="B">
                              <block type="text" id="txtRotL0000000000000">
                              <field name="TEXT">rotate_left</field>
                              </block>
                              </value>
                              </block>
                              </value>
                              <value name="A">
                              </shadow>
                              </block>
                              </value>
                              <value name="B">
                              </shadow>
                              </value>
                              </block>
                              </value>
                              </block>
                              </statement>
                              <next>
                              <value name="IF0">
                              <value name="A">
                              <block type="get_value" id="O~YYmKWdN!Mw72DDncL"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.action</field> </block> </value> <value name="B"> <block type="text" id="txtRotR0000000000000"> <field name="TEXT">rotate_right</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="w(o*h=O4naq)R:K(V7BZ"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">100</field> <field name="UNIT">ms</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="math_arithmetic" id="!_r@b%{RRXbB78L@gy=Q"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number" id="M|^U,9}PJ?Ze7Tp:0l-["> <field name="NUM">1</field> </shadow> <block type="get_value" id="C({F@Kx^Xfa}LQ}:J.f?"> <field name="ATTR">val</field> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.volume</field> </block> </value> <value name="B"> <shadow type="math_number" id="%l[aeB:EcnIHkKMA1VTC"> <field name="NUM">5</field> </shadow> </value> </block> </value> </block> </statement> <next> <block type="controls_if" id="T%b0W^#l-ZWU%w^7]WQ/"> <value name="IF0"> <block type="logic_compare" id="=(DbOS78=0MBQe=F%*.D"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="DpgzqNoWjD?gGY|.nPM_"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.action</field> </block> </value> <value name="B"> <block type="text" id="txtFlip9000000000000"> <field name="TEXT">flip90</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="XSX3p0d(aQb.=Q;!Pl">
                              }1USc-uhv}_">
                              </block>
                              </value>
                              </block>
                              </statement>
                              <next>
                              <value name="IF0">
                              <block type="logic_compare" id="P-11~fVNv0~,i6Z]kfW"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="*FX)kI39Db7wYP5[:xl+"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.action</field> </block> </value> <value name="B"> <block type="text" id="txtFlip180000000000"> <field name="TEXT">flip180</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="!NUVA~(c4QgG]+~(E|^i"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Music-Provider.TuneIn</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="vqzCyqOR/s6Y7s21%;[F"> <field name="TEXT">YOU FM</field> </block> </value> </block> </statement> <next> <block type="controls_if" id=",Fq$U/,8:7stB7Z*~Xtv"> <value name="IF0"> <block type="logic_compare" id=".cop*h-}DoYl2o8E@%5{"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="tew,S#WRiF^%yTMOm,+h"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.action</field> </block> </value> <value name="B"> <block type="text" id="txtSlide00000000000"> <field name="TEXT">slide</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="sOf=BcVH:fZOEpzDS)-">
                              </block>
                              </value>
                              </block>
                              </statement>
                              <next>
                              <block type="controls_if" id="L(VjI7c;qpbDvh5(w.Y"> <value name="IF0"> <block type="logic_compare" id="M|9q*GjAQ9x{[k}dca+">
                              <value name="A">
                              </block>
                              </value>
                              <value name="B">
                              <block type="text" id="txtFall00000000000000">
                              <field name="TEXT">fall</field>
                              </block>
                              </value>
                              </block>
                              </value>
                              </block>
                              </value>
                              </block>
                              </statement>
                              <next>
                              <value name="IF0">
                              <block type="logic_compare" id=".5XJGz4u6:p[#j+uoBh"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="Tc#Gzin|@s,p7.86ILp/"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d00027cf30f.action</field> </block> </value> <value name="B"> <block type="text" id="txtShake0000000000000"> <field name="TEXT">shake</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="E]3~1B]ZQQdBY9/459z["> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G090XG0894360DF9.Player.controlPause</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="5t-IeJ[V[GI[{3GfPg|">
                              </block>
                              </value>
                              </block>
                              </statement>
                              <next>
                              <value name="IF0">
                              <value name="A">
                              </block>
                              </value>
                              <value name="B">
                              <block type="text" id="txtTap00000000000000">
                              <field name="TEXT">tap</field>
                              </block>
                              </value>
                              </block>
                              </value>
                              </block>
                              </value>
                              </block>
                              </statement>
                              </block>
                              </next>
                              </block>
                              </next>
                              </block>
                              </next>
                              </block>
                              </next>
                              </block>
                              </next>
                              </block>
                              </next>
                              </block>
                              </next>
                              </block>
                              </statement>
                              </block>
                                AsgothianA Offline
                                Asgothian
                                Durch diesen
                                Ersetzen.
                                  Durch diesen
                                  Ersetzen.
                                  KusselinK Offline
                                  KusselinK Offline
                                  Kusselin
                                  @Asgothian sagte:
                                  Durch diesen
                                  Ersetzen.
                                  Kannst du bitte das zweite bild komplett in der länge posten und das erste auch bitte.
                                    @Asgothian sagte:
                                    Durch diesen
                                    Ersetzen.
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @Kusselin beide Bilder sind aus dem Skript welche du gepostet hast. Dahinter steht in beiden fällen das gleiche. Es geht darum den Baustein “Wert von …” gegen den Baustein “Wert” aus dem trigger Bereich auszutauschen.
                                    Längere Screenshots kann ich erst heute Abend machen.
                                    • KusselinK Offline
                                      KusselinK Offline
                                      Kusselin
                                      Hab nun die Gesten nochmal nachgemacht und dann wurde aus dem „null“ ein „good“ und das script geändert ..nun kommen keine Fehlermeldungen mehr beim Gesten machen mit dem Cube..danke @asgothian
