  4. Test Adapter PoolControl
    apollon77A
testerpoolpoolcontrolsolar
535 Beiträge 19 Kommentatoren 85.3k Aufrufe 18 Beobachtet
  • sigi234S sigi234
    @DasBo1975
    javascript.0
    2026-07-01 09:16:00.088	info	script.js.Test.chrunch: [Prozess-Monitor v4.6.7] E-Mail-Alert gesendet: flaky
    poolcontrol.0
    2026-07-01 09:13:46.321	info	[aiForecastHelper] initialization finished
    poolcontrol.0
    2026-07-01 09:13:46.321	info	[aiForecastHelper] forecast for tomorrow created
    poolcontrol.0
    2026-07-01 09:13:46.145	info	[aiForecastHelper] creating forecast for tomorrow ...
    poolcontrol.0
    2026-07-01 09:13:46.144	info	[aiForecastHelper] running one-time immediate forecast (adapter start)
    poolcontrol.0
    2026-07-01 09:13:44.987	warn	statisticsHelperMonth: Error during initialization: Timeout (2645475013) is larger than a 32-bit signed integer (2147483647)
    poolcontrol.0
    2026-07-01 09:13:44.973	info	[actuatorsHelper] initialized
    poolcontrol.0
    2026-07-01 09:13:44.726	info	[photovoltaicHelper] Pump OFF (mode_not_auto_pv, no afterrun)
    poolcontrol.0
    2026-07-01 09:13:44.687	info	[aiHelper] initialization finished
    poolcontrol.0
    2026-07-01 09:13:44.648	info	[aiChemistryHelpHelper] initialization finished
    poolcontrol.0
    2026-07-01 09:13:44.642	info	[pumpHelper2] Successfully initialized
    poolcontrol.0
    2026-07-01 09:13:44.633	info	[aiForecastHelper] forecast timer set for 20:06
    poolcontrol.0
    2026-07-01 09:13:44.610	info	[aiHelper] AI is enabled - setting timers
    poolcontrol.0
    2026-07-01 09:13:44.461	info	[controlHelper2] backwash reminder initialized (daily check at 12:00).
    poolcontrol.0
    2026-07-01 09:13:44.461	info	[controlHelper] initialized
    poolcontrol.0
    2026-07-01 09:13:44.455	info	[aiChemistryHelpHelper] initialization started
    poolcontrol.0
    2026-07-01 09:13:44.454	info	[aiForecastHelper] initialization started
    poolcontrol.0
    2026-07-01 09:13:44.454	info	[aiHelper] initialization started
    poolcontrol.0
    2026-07-01 09:13:44.453	info	[photovoltaicHelper] Initialization completed.
    poolcontrol.0
    2026-07-01 09:13:44.452	info	[photovoltaicHelper] Subscribed: PV="0_userdata.0.Pool.PV.Erzeugungsleistung", house="0_userdata.0.Pool.PV.Hausverbrauch"
    poolcontrol.0
    2026-07-01 09:13:44.452	info	[heatHelper] Initialization completed.
    poolcontrol.0
    2026-07-01 09:13:44.448	info	[pumpHelper4] Successfully initialized
    poolcontrol.0
    2026-07-01 09:13:44.447	info	[pumpHelper4] Initialization started (OID: 0_userdata.0.Pool.Drucksensor.Druck)
    poolcontrol.0
    2026-07-01 09:13:44.447	info	[pumpHelper3] Successfully initialized
    poolcontrol.0
    2026-07-01 09:13:44.446	info	[pumpHelper3] Initialization started
    poolcontrol.0
    2026-07-01 09:13:44.446	info	[pumpHelper2] Initialization started
    poolcontrol.0
    2026-07-01 09:13:44.440	info	[migrationHelper] Migration helper finished.
    poolcontrol.0
    2026-07-01 09:13:44.269	info	[migrationHelper] Starting migration check ...
    poolcontrol.0
    2026-07-01 09:13:43.871	info	[createPhotovoltaicStates] Initialization completed.
    poolcontrol.0
    2026-07-01 09:13:43.703	info	Adapter started
    poolcontrol.0
    2026-07-01 09:13:43.696	info	starting. Version 1.4.1 in C:/SmartHome/node_modules/iobroker.poolcontrol, node: v22.23.1, js-controller: 7.2.2
    DasBo1975D
    DasBo1975D
    DasBo1975
    #512
    @sigi234 sagte:
    @DasBo1975
    javascript.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    poolcontrol.0
    Kümmere ich mich drum. Vielen Dank fürs melden.
    • Entwickler des Adapters PoolControl / BertinSoft-Sprachassistent
    • Einfach macht aus einem Problem keine Lösung
    • universelle Gerätedatenstruktur mit kontextueller Funktionszuordnung. Oder einfach gesagt: Jedes Gerät spricht dieselbe Sprache - nur nicht jedes sagt alles!
    • DasBo1975D DasBo1975
      @sigi234 sagte:
      @DasBo1975
      javascript.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      poolcontrol.0
      sigi234S
      sigi234S
      #513
      @DasBo1975 sagte:
      Was Neues:
      poolcontrol.0
      2026-07-01 21:24:15.315	warn	[solarLogbookHelper] Day log was trimmed to keep JSON and text within 64 KB.
      DasBo1975D 1 Antwort Letzte Antwort
      • sigi234S sigi234
        @DasBo1975 sagte:
        Was Neues:
        poolcontrol.0
        DasBo1975D
        DasBo1975D
        DasBo1975
        #514
        @sigi234 sagte:
        @DasBo1975 sagte:
        Was Neues:
        poolcontrol.0
        Danke Dir und ist bereits erledigt. Wurde von warn auf debug umgestellt. wird in der Version 1.4.2 mit dem anderen das du mir vorhin gezeigt hattest behoben.
          heute gibt es mit der Version 1.4.0 wieder ein größeres Update für PoolControl. 🎉
          Dieses Mal standen vor allem die Themen Umwälzung, Pumpen-Learning und Zeitsteuerung im Mittelpunkt. Einige der neuen Funktionen sind direkt aus euren Anregungen und dem Feedback hier aus dem Forum entstanden. Vielen Dank dafür! 🙂
          🆕 Reset-Button für das Pumpen-Learning
          Nach einem Pumpenwechsel oder wenn das Learning einmal fehlerhafte Werte übernommen hat, mussten bisher die Lernwerte manuell zurückgesetzt werden.
          Dafür gibt es jetzt einen eigenen pump.learning.reset-Button.
          Mit einem Klick werden alle gelernten Pumpenwerte zurückgesetzt und das Learning beginnt automatisch wieder von vorne. Persönliche Einstellungen wie z. B. die eingestellte Toleranz bleiben dabei selbstverständlich erhalten.
          🆕 Beschreibbarer Umwälzfaktor
          Der Datenpunkt
          general.min_circulation_per_day
          ist jetzt beschreibbar und persistent.
          Der in der Adapterkonfiguration eingestellte Wert dient künftig nur noch als Initialwert beim ersten Einrichten. Danach kann der Umwälzfaktor bequem direkt über VIS, HomePanel oder andere Automatisierungen angepasst werden, ohne jedes Mal die Instanz öffnen zu müssen.
          Änderungen werden sofort übernommen und die benötigte tägliche Umwälzmenge wird unmittelbar neu berechnet.
          🆕 Temperaturabhängiger Umwälzfaktor
          Eine weitere neue Funktion ist die temperaturabhängige Anpassung des täglichen Umwälzfaktors.
          Ihr könnt jetzt:
          einen beliebigen aktiven Temperatursensor auswählen,
          eine Temperaturschwelle festlegen,
          sowie einen zusätzlichen Umwälzfaktor definieren.
          Wird die eingestellte Temperatur überschritten, erhöht PoolControl automatisch den täglichen Umwälzbedarf.
          Der ursprünglich eingestellte Basiswert bleibt dabei immer erhalten und wird nicht verändert. Zusätzlich stehen neue Diagnose-Datenpunkte zur Verfügung, über die jederzeit nachvollzogen werden kann, welcher Umwälzfaktor aktuell verwendet wird und warum.
          🆕 Intervallbetrieb für die Zeitsteuerung
          Auch die bestehende Zeitsteuerung wurde erweitert.
          Jedes der drei vorhandenen Zeitfenster kann jetzt wahlweise:
          im bisherigen Dauerbetrieb oder
          im neuen Intervallbetrieb
          verwendet werden.
          Beispielsweise kann ein Zeitfenster von 08:00 bis 10:00 Uhr eingerichtet werden, wobei die Pumpe innerhalb dieses Zeitraums nur 15 Minuten pro Stunde oder 30 Minuten pro Stunde läuft.
          Dadurch lassen sich viele bisher über Blockly oder eigene Skripte realisierte Intervallsteuerungen jetzt direkt mit PoolControl umsetzen.
          Mehrere Zeitfenster können sich dabei auch überschneiden. PoolControl berücksichtigt dies automatisch, sodass sich die einzelnen Zeitfenster nicht gegenseitig abschalten.
          🔍 Verbesserte Diagnose
          Im Zuge dieser Erweiterungen wurden außerdem verschiedene neue Diagnose- und Statusmeldungen ergänzt.
          Dadurch lässt sich künftig deutlich einfacher nachvollziehen,
          warum ein bestimmter Umwälzfaktor aktiv ist,
          ob der temperaturabhängige Faktor gerade greift,
          oder welcher Status aktuell in der Zeitsteuerung vorliegt.
          🙏 Vielen Dank
          Ein besonderer Dank geht dieses Mal an @dennismenger und @rikdrs .
          Durch eure Ideen, Rückmeldungen und Diskussionen hier im Forum sind gleich mehrere dieser neuen Funktionen entstanden oder deutlich verbessert worden. Genau dieses Feedback hilft dabei, PoolControl Schritt für Schritt weiterzuentwickeln.
          Wie immer freue ich mich über eure Rückmeldungen, Tests und natürlich auch über weitere Ideen. 😊
          Viel Spaß mit der Version 1.4.0!
          R
          R
          RikDRS
          #515
          @DasBo1975 sagte:
          wurde soeben (1.4.2) installiert und geht bestenfalls gleich an den Start 🤘
          Wir / ich habe zu Danken!
          • R
            R
            RikDRS
            schrieb am zuletzt editiert von RikDRS
            #516
            Guten Morgen zusammen,
            seit dem letzen Update vor 14 Tagen habe ich nun meine Pumpe über die Zeiteinstellungen gesteuert.
            In der Zwischenzeit wenig Beachtung geschenkt, gestern aber feststellen müssen, das der Pumpenmodus von "time" sich auf "off" gestellt hatte bzw der Datenpunkt "leer" war. Somit lief nur Abends die Pumpe um die Mindestumwälzung noch zu erreichen.
            Ich meine das mir etwas ähnliches schonmal aufgefallen war als ich den Wartungsmodus aktiviert und dann wieder deaktviert hatte - da bin ich mir aber nicht zu 100% sicher ob ich das nicht selber war ;)
            Wie komme ich diesem Fehler auf die Schliche?
            schönes Wochenende Euch!
            • R RikDRS
              DasBo1975D
              DasBo1975D
              DasBo1975
              #517
              @RikDRS sagte:
              Moin,
              schaue ich mir auch mal an
              • DasBo1975D
                DasBo1975D
                DasBo1975
                #518
                Danke für die ausführliche Rückmeldung. Ich konnte das Verhalten inzwischen nachvollziehen und die Ursache eingrenzen.
                Die Zeitsteuerung selbst arbeitet grundsätzlich korrekt und stellt den Pumpenmodus nicht eigenständig um. Das Problem liegt vielmehr in einzelnen Abläufen, bei denen PoolControl die Pumpe vorübergehend übernimmt, zum Beispiel beim Wartungsmodus oder beim automatischen Nachpumpen zur Erreichung der Mindestumwälzung.
                Dabei wird der zuvor eingestellte Pumpenmodus zwischengespeichert, damit er anschließend wiederhergestellt werden kann. In bestimmten Situationen kann dieser Rücksprungwert jedoch verloren gehen oder überschrieben werden, insbesondere bei:
                • einem Adapterneustart während des Wartungsmodus
                • einer Überschneidung zwischen Wartungsmodus und automatischem Nachpumpen
                • einem Abbruch eines laufenden Nachpumpvorgangs
                Dadurch kann es passieren, dass anschließend nicht wieder sauber auf den vorherigen Modus, zum Beispiel time, zurückgeschaltet wird. In ungünstigen Fällen kann der Datenpunkt dann auch leer erscheinen.
                Zusätzlich gibt es noch einen zweiten, davon unabhängigen Fall: Der Überlastschutz kann den Pumpenmodus bewusst auf off setzen, wenn die gemessene Pumpenleistung über der eingestellten Sicherheitsgrenze liegt. Dieses Verhalten ist gewollt und bleibt auch bestehen.
                Ich werde mit der nächsten Version gezielt die Rücksprunglogik für Wartungsmodus und automatisches Nachpumpen absichern. Dabei wird nichts an der grundsätzlichen Zeit-, Umwälz- oder Sicherheitslogik geändert. Es geht ausschließlich darum, den vorherigen gültigen Pumpenmodus zuverlässig wiederherzustellen und ungültige beziehungsweise leere Werte zu verhindern.
                Vielen Dank für den Hinweis. Solche Rückmeldungen helfen enorm dabei, gerade diese seltenen Überschneidungen sauber zu finden.
                • DasBo1975D
                  DasBo1975D
                  DasBo1975
                  #519
                  Version 1.4.3 ist online.
                    @DennisMenger sagte:
                    DennisMenger sagte:
                    Ganz hervorragend. Dann wollen wir morgen mal schauen, ob wir genügend Sonne für einen Test haben werden. Vielen Dank
                    Leider funktioniert der PV-Modus bei mir weiterhin nicht. Er schaltet nach ca. 30 Sekunden ab, obwohl weiterhin PV-Überschuss vorhanden ist. Und müsste er nicht aufgrund der Nachlaufzeit sowieso 15 Minuten länger laufen?
                    Was kann ich noch gucken wo der Fehler liegt bzw. was kann ich dir noch liefern?
                    Danke dir fürs schnelle Testen. 🙂
                    Schade, dass das Problem noch besteht. Dann sind wir der eigentlichen Ursache offenbar noch nicht ganz auf der Spur.
                    Ich möchte jetzt aber nicht weiter spekulieren, sondern gezielt herausfinden, welcher Teil von PoolControl die Pumpe tatsächlich abschaltet.
                    Könntest du mir deshalb bitte noch Folgendes liefern?
                    • Das Adapter-Log vom Einschalten der Pumpe bis etwa eine Minute nach der Abschaltung (wenn möglich einmal auf Debug stellen).
                    • Direkt nach der Abschaltung bitte einmal die folgenden Datenpunkte:
                      • photovoltaic.surplus_active
                      • photovoltaic.power_surplus_w
                      • photovoltaic.status_text
                      • pump.active_helper
                      • pump.reason
                      • pump.pump_switch
                      • pump.mode
                      • pump.error
                    • Und bitte noch einmal kurz nachsehen, ob photovoltaic.afterrun_min tatsächlich auf 15 Minuten steht.
                    Mit diesen Informationen sollten wir ziemlich genau nachvollziehen können, warum die Pumpe bereits nach rund 30 Sekunden abgeschaltet wird.
                    Vielen Dank schon einmal für deine Unterstützung und deine Geduld. Ich bin zuversichtlich, dass wir den Fehler gemeinsam noch finden. 💪
                    D
                    D
                    DennisMenger
                    #520
                    @DasBo1975 Moin Moin.
                    Aus verschiedensten Gründen hatte ich zuletzt leider keine Zeit das nochmal mit dem PV-Modus zu testen. Heute habe ich das dann tatsächlich mal geschafft.
                    Hier einmal die Datenpunkte und das Log auf Debug-Level
                    27.07.2026 10:19	info	State value to set for "poolcontrol.0.chemistry.orp.debug.last_update" has to be type "string" but received type "number"
                    27.07.2026 10:19	info	State value to set for "poolcontrol.0.chemistry.ph.debug.last_update" has to be type "string" but received type "number"
                    27.07.2026 10:19	debug	[runtimeHelper] Pump runtime stopped.
                    27.07.2026 10:19	debug	[runtimeHelper] Circulation values updated (Total=11181, Required=56000, Remaining=44819)
                    27.07.2026 10:19	debug	[statusHelper] updateSummary skipped (throttle)
                    27.07.2026 10:19	debug	state poolcontrol.0.circulation.daily_total changed: 11181 (ack = true)
                    27.07.2026 10:19	info	State value to set for "poolcontrol.0.chemistry.orp.input.last_valid_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:19	debug	state plenticore.0.devices.local.Home_P changed: 544 (ack = true)
                    27.07.2026 10:19	debug	[pumpHelper] Within stop grace period – skipping error check
                    27.07.2026 10:19	debug	[pumpHelper2] Actual flow updated: 5244.5 l/h (47.7%)
                    27.07.2026 10:19	debug	state poolcontrol.0.pump.current_power changed: 309.9 (ack = true)
                    27.07.2026 10:19	debug	state alias.0.PoolPoolpumpe.currentPowerConsumption changed: 309.9 (ack = true)
                    27.07.2026 10:19	debug	state alias.0.PoolPoolpumpe.energyCounter changed: 539.5092000000001 (ack = true)
                    27.07.2026 10:19	debug	[pumpHelper] Foreign state reported identical value – ignored.
                    27.07.2026 10:19	debug	state alias.0.PoolPoolpumpe.on changed: false (ack = true)
                    27.07.2026 10:19	info	State value to set for "poolcontrol.0.chemistry.ph.input.last_valid_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:19	info	State value to set for "poolcontrol.0.chemistry.ph.input.previous_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:19	info	State value to set for "poolcontrol.0.chemistry.ph.input.last_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:19	debug	[photovoltaicInsightsHelper] Inputs, calculation and results updated
                    27.07.2026 10:19	debug	state poolcontrol.0.pump.active_helper changed: photovoltaicHelper (ack = true)
                    27.07.2026 10:19	debug	state tuya.0.bf2a5653fb1af77850ykut.106 changed: 7.45 (ack = true)
                    27.07.2026 10:19	info	State value to set for "poolcontrol.0.chemistry.orp.input.previous_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:19	info	State value to set for "poolcontrol.0.chemistry.orp.input.last_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:19	debug	[pumpHelper2] Actual flow updated: 0 l/h (0.0%)
                    27.07.2026 10:19	debug	state poolcontrol.0.pump.live.flow_current_lh changed: 0 (ack = true)
                    27.07.2026 10:19	debug	state poolcontrol.0.pump.live.current_power_w changed: 0 (ack = true)
                    27.07.2026 10:19	debug	state poolcontrol.0.pump.current_power changed: 0 (ack = true)
                    27.07.2026 10:19	debug	state alias.0.PoolPoolpumpe.currentPowerConsumption changed: 0 (ack = true)
                    27.07.2026 10:19	debug	state alias.0.PoolPoolpumpe.energyCounter changed: 539.5102 (ack = true)
                    27.07.2026 10:19	debug	[solarInsightsHelper] Block 7 updated successfully
                    27.07.2026 10:19	debug	state poolcontrol.0.analytics.insights.solar.results.pump_power_w_used changed: 0 (ack = true)
                    27.07.2026 10:19	debug	state poolcontrol.0.analytics.insights.solar.results.flow_lh_used changed: 0 (ack = true)
                    27.07.2026 10:19	debug	state poolcontrol.0.chemistry.ph.input.current_value changed: 7.44 (ack = true)
                    27.07.2026 10:19	debug	state tuya.0.bf2a5653fb1af77850ykut.106 changed: 7.44 (ack = true)
                    27.07.2026 10:19	debug	state plenticore.0.devices.local.Home_P changed: 494 (ack = true)
                    27.07.2026 10:19	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 1113.5331865103 (ack = true)
                    27.07.2026 10:19	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 2083.8883752674 (ack = true)
                    27.07.2026 10:20	info	State value to set for "poolcontrol.0.chemistry.ph.input.last_valid_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:20	info	State value to set for "poolcontrol.0.chemistry.ph.input.previous_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:20	debug	state poolcontrol.0.chemistry.ph.input.current_value changed: 7.46 (ack = true)
                    27.07.2026 10:20	info	State value to set for "poolcontrol.0.chemistry.ph.input.last_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:20	debug	state tuya.0.bf2a5653fb1af77850ykut.106 changed: 7.46 (ack = true)
                    27.07.2026 10:20	info	State value to set for "poolcontrol.0.chemistry.orp.debug.last_update" has to be type "string" but received type "number"
                    27.07.2026 10:20	info	State value to set for "poolcontrol.0.chemistry.orp.input.last_valid_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:20	info	State value to set for "poolcontrol.0.chemistry.orp.input.previous_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:20	info	State value to set for "poolcontrol.0.chemistry.orp.input.last_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:20	debug	[statusHelper] updateSummary skipped (throttle)
                    27.07.2026 10:20	info	State value to set for "poolcontrol.0.chemistry.ph.debug.last_update" has to be type "string" but received type "number"
                    27.07.2026 10:20	debug	[solarInsightsHelper] Block 7 updated successfully
                    27.07.2026 10:20	debug	statisticsHelperMonth: Overall summary updated successfully.
                    27.07.2026 10:20	debug	state poolcontrol.0.circulation.daily_required changed: 56000 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.control.circulation.temperature_factor.status changed: base (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.control.circulation.temperature_factor.active changed: false (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.temperature.outside.current changed: 17.28 (ack = true)
                    27.07.2026 10:20	debug	state hmip.0.homes.c292384f-c5e4-45ac-aa84-215911532910.weather.temperature changed: 17.28 (ack = true)
                    27.07.2026 10:20	debug	[photovoltaicInsightsHelper] Inputs, calculation and results updated
                    27.07.2026 10:20	debug	state poolcontrol.0.pump.active_helper changed: photovoltaicHelper (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 3439.5988244862 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 1107.5331865103 (ack = true)
                    27.07.2026 10:20	debug	state plenticore.0.devices.local.Pv_P changed: 3939.5988244862 (ack = true)
                    27.07.2026 10:20	debug	state plenticore.0.devices.local.Home_P changed: 500 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.chemistry.ph.input.current_value changed: 7.44 (ack = true)
                    27.07.2026 10:20	debug	state tuya.0.bf2a5653fb1af77850ykut.106 changed: 7.44 (ack = true)
                    27.07.2026 10:20	debug	state tuya.0.bf2a5653fb1af77850ykut.131 changed: 670 (ack = true)
                    27.07.2026 10:20	debug	[solarExtendedHelper] Extended solar skipped (pump_mode_not_auto)
                    27.07.2026 10:20	debug	[solarHelper] Solar control skipped (Solarmodus = extended)
                    27.07.2026 10:20	debug	[solarHelper] Standard solar paused because solar.control_mode = extended
                    27.07.2026 10:20	debug	state poolcontrol.0.analytics.insights.solar.results.collector_temp_used changed: 28.6 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.temperature.collector.current changed: 28.6 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.temperature.collector.current changed: 28.1 (ack = true)
                    27.07.2026 10:20	debug	state 0_userdata.0.poolsteuerung.temperatur_kollektor changed: 28.6 (ack = true)
                    27.07.2026 10:20	debug	state 0_userdata.0.poolsteuerung.temperatur_kollektor changed: 28.1 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.chemistry.ph.input.current_value changed: 7.45 (ack = true)
                    27.07.2026 10:20	debug	state tuya.0.bf2a5653fb1af77850ykut.106 changed: 7.45 (ack = true)
                    27.07.2026 10:20	debug	state plenticore.0.devices.local.Pv_P changed: 1328.6611161977 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 3454.5988244862 (ack = true)
                    27.07.2026 10:20	debug	state plenticore.0.devices.local.Home_P changed: 485 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.analytics.insights.solar.results.delta_t_used changed: -0.8 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.analytics.insights.solar.results.pool_reference_temp_used changed: 22.2 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.temperature.flow.current changed: 22.2 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.temperature.surface.current changed: 22.2 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.temperature.return.current changed: 21.4 (ack = true)
                    27.07.2026 10:20	debug	state alias.0.PoolPoolsensor.temperatureExternalTwo changed: 22.2 (ack = true)
                    27.07.2026 10:20	debug	state alias.0.PoolPoolsensor.temperatureExternalOne changed: 21.4 (ack = true)
                    27.07.2026 10:20	debug	[photovoltaicHelper] Afterrun started: 15 min (pv_ended_afterrun)
                    27.07.2026 10:20	debug	state poolcontrol.0.photovoltaic.surplus_active changed: false (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 599.8499589712001 (ack = true)
                    27.07.2026 10:20	debug	state plenticore.0.devices.local.Pv_P changed: 1076.8499589712 (ack = true)
                    27.07.2026 10:20	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 851.6611161977 (ack = true)
                    27.07.2026 10:20	debug	state plenticore.0.devices.local.Home_P changed: 477 (ack = true)
                    27.07.2026 10:21	debug	state tuya.0.bf2a5653fb1af77850ykut.131 changed: 670 (ack = true)
                    27.07.2026 10:21	info	State value to set for "poolcontrol.0.chemistry.ph.debug.last_update" has to be type "string" but received type "number"
                    27.07.2026 10:21	info	State value to set for "poolcontrol.0.chemistry.ph.input.last_valid_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:21	info	State value to set for "poolcontrol.0.chemistry.ph.input.previous_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:21	info	State value to set for "poolcontrol.0.chemistry.ph.input.last_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:21	debug	state tuya.0.bf2a5653fb1af77850ykut.106 changed: 7.45 (ack = true)
                    27.07.2026 10:21	debug	[statusHelper] updateSummary skipped (throttle)
                    27.07.2026 10:21	info	State value to set for "poolcontrol.0.chemistry.orp.debug.last_update" has to be type "string" but received type "number"
                    27.07.2026 10:21	info	State value to set for "poolcontrol.0.chemistry.orp.input.last_valid_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:21	info	State value to set for "poolcontrol.0.chemistry.orp.input.previous_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:21	debug	[photovoltaicInsightsHelper] Inputs, calculation and results updated
                    27.07.2026 10:21	debug	[photovoltaicHelper] Afterrun already active, timer not restarted (pv_ended_afterrun)
                    27.07.2026 10:21	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 597.8499589712001 (ack = true)
                    27.07.2026 10:21	debug	state plenticore.0.devices.local.Pv_P changed: 1261.0042558462 (ack = true)
                    27.07.2026 10:21	debug	state plenticore.0.devices.local.Home_P changed: 479 (ack = true)
                    27.07.2026 10:21	debug	[solarExtendedHelper] Extended solar skipped (pump_mode_not_auto)
                    27.07.2026 10:21	debug	[solarHelper] Solar control skipped (Solarmodus = extended)
                    27.07.2026 10:21	debug	[solarHelper] Standard solar paused because solar.control_mode = extended
                    27.07.2026 10:21	debug	state poolcontrol.0.pump.active_helper changed: photovoltaicHelper (ack = true)
                    27.07.2026 10:21	debug	state poolcontrol.0.photovoltaic.surplus_active changed: true (ack = true)
                    27.07.2026 10:21	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 3492.7739091665 (ack = true)
                    27.07.2026 10:21	debug	state plenticore.0.devices.local.Pv_P changed: 3985.7739091665 (ack = true)
                    27.07.2026 10:21	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 768.0042558462001 (ack = true)
                    27.07.2026 10:21	debug	state plenticore.0.devices.local.Home_P changed: 493 (ack = true)
                    27.07.2026 10:21	info	State value to set for "poolcontrol.0.chemistry.ph.trend.reference_24h_at" has to be type "string" but received type "number"
                    27.07.2026 10:21	debug	state plenticore.0.devices.local.Home_P changed: 486 (ack = true)
                    27.07.2026 10:22	info	State value to set for "poolcontrol.0.chemistry.ph.input.last_valid_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:22	info	State value to set for "poolcontrol.0.chemistry.ph.input.previous_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:22	info	State value to set for "poolcontrol.0.chemistry.ph.input.last_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:22	debug	state tuya.0.bf2a5653fb1af77850ykut.106 changed: 7.45 (ack = true)
                    27.07.2026 10:22	debug	[statusHelper] updateSummary skipped (throttle)
                    27.07.2026 10:22	info	State value to set for "poolcontrol.0.chemistry.orp.debug.last_update" has to be type "string" but received type "number"
                    27.07.2026 10:22	info	State value to set for "poolcontrol.0.chemistry.orp.input.last_valid_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:22	info	State value to set for "poolcontrol.0.chemistry.orp.input.previous_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:22	info	State value to set for "poolcontrol.0.chemistry.ph.debug.last_update" has to be type "string" but received type "number"
                    27.07.2026 10:22	debug	[photovoltaicInsightsHelper] Inputs, calculation and results updated
                    27.07.2026 10:22	debug	state poolcontrol.0.pump.active_helper changed: photovoltaicHelper (ack = true)
                    27.07.2026 10:22	debug	state plenticore.0.devices.local.Pv_P changed: 3488.7145829946 (ack = true)
                    27.07.2026 10:22	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 2400.5790849477 (ack = true)
                    27.07.2026 10:22	debug	[solarExtendedHelper] Extended solar skipped (pump_mode_not_auto)
                    27.07.2026 10:22	debug	[solarHelper] Solar control skipped (Solarmodus = extended)
                    27.07.2026 10:22	debug	[solarHelper] Standard solar paused because solar.control_mode = extended
                    27.07.2026 10:22	info	State value to set for "poolcontrol.0.chemistry.orp.trend.reference_7d_at" has to be type "string" but received type "number"
                    27.07.2026 10:22	info	State value to set for "poolcontrol.0.chemistry.orp.history.oldest_sample_at" has to be type "string" but received type "number"
                    27.07.2026 10:22	info	State value to set for "poolcontrol.0.chemistry.ph.trend.reference_7d_at" has to be type "string" but received type "number"
                    27.07.2026 10:22	info	State value to set for "poolcontrol.0.chemistry.orp.input.last_value_at" has to be type "string" but received type "number"
                    27.07.2026 10:22	debug	state tuya.0.bf2a5653fb1af77850ykut.131 changed: 670 (ack = true)
                    27.07.2026 10:22	debug	state plenticore.0.devices.local.Home_P changed: 494 (ack = true)
                    27.07.2026 10:22	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 3129.7079911977 (ack = true)
                    27.07.2026 10:22	debug	state poolcontrol.0.photovoltaic.power_surplus_w changed: 2994.7145829946 (ack = true)
                    27.07.2026 10:22	debug	state plenticore.0.devices.local.Pv_P changed: 3744.8757158071 (ack = true)
                    27.07.2026 10:22	debug	state plenticore.0.devices.local.Home_P changed: 489 (ack = true)
                    ![7a52a709-e7c5-4a71-9ca6-2f4d86d6ab74-image.jpeg](Die Bildabmessungen sind zu groß.)
                    • DasBo1975D
                      DasBo1975D
                      DasBo1975
                      #521
                      Schau ich mir an. Kann aber ein wenig dauern aktuell
                      • D
                        D
                        DennisMenger
                        #522
                        Alles klar, kein Problem. Vielen Dank schon mal.
                        • DasBo1975D
                          DasBo1975D
                          DasBo1975
                          #523
                          Version 1.4.4 ist fertig und sollte in den nächsten Stunden über das Repository verfügbar sein.
                          Zunächst möchte ich mich diesmal dafür entschuldigen, dass dieser Bugfix etwas länger gedauert hat als sonst.
                          Der Grund war, dass ich den Fehler auf meiner eigenen Anlage einfach nicht nachstellen konnte. Ich nutze nur ein Balkonkraftwerk und dort trat dieses Verhalten nie auf. Deshalb hätte ich den Fehler auf meiner Hardware niemals zuverlässig reproduzieren können.
                          Dank der ausführlichen Rückmeldungen von Dennis und den bereitgestellten Logdateien konnte ich den Fehler aber Schritt für Schritt eingrenzen. Anschließend habe ich den kompletten Ablauf in einer Testumgebung mit einer virtuellen größeren PV-Anlage und den Werten aus Dennis' Log nachgestellt. Erst dadurch wurde die eigentliche Ursache sichtbar.
                          Kurz erklärt:
                          Bei schnellen Änderungen der PV-Erzeugung und des Hausverbrauchs konnte es in seltenen Fällen passieren, dass beide Werte intern nicht mehr als zusammengehöriges Wertepaar verarbeitet wurden. Dadurch konnte der Auto-PV-Modus kurzzeitig mit veralteten Zwischenwerten arbeiten und unter bestimmten Bedingungen einen Nachlauf oder sogar eine Abschaltung auslösen, obwohl eigentlich weiterhin ausreichend PV-Leistung vorhanden war.
                          Für die Version 1.4.4 habe ich den internen Ablauf deshalb überarbeitet. Die Berechnung wartet jetzt kurz auf zusammengehörige Messwerte und verarbeitet diese anschließend sauber und in der richtigen Reihenfolge. Gleichzeitig wurde sichergestellt, dass ältere Berechnungen keine neueren Ergebnisse mehr überschreiben können.
                          Für euch als Anwender ändert sich an der Bedienung nichts. Die Berechnung des PV-Überschusses und alle bisherigen Funktionen bleiben unverändert – lediglich der interne Ablauf wurde robuster gemacht.
                          Ich hoffe sehr, dass damit nun auch das von Dennis gemeldete Problem endgültig behoben ist.
                          Zum Schluss möchte ich mich noch einmal ganz herzlich bei Dennis bedanken. Ohne seine Geduld, die vielen Tests und die ausführlichen Logdateien wäre dieser Fehler vermutlich noch lange unentdeckt geblieben. Genau solche Rückmeldungen helfen mir dabei, PoolControl Schritt für Schritt weiter zu verbessern und robuster zu machen.
                          Vielen Dank an alle, die den Adapter testen, Ideen einbringen und mich bei der Weiterentwicklung unterstützen. Genau das macht dieses Projekt für mich so besonders. 😊
                            Kurz erklärt:
                            D
                            D
                            DennisMenger
                            #524
                            @DasBo1975 Heute erst wieder zum Testen gekommen. Leider kann ich bei mir noch keine Entwarnung bezüglich des PV-Modus geben.
                            Er schaltet noch immer nach ein paar Sekunden ab, obwohl weiter PV-Überschuss vorhanden ist.
                            Was ich beobachtet habe ist, dass zeitgleich zum Ausschalten der Pumpe die Werte
                            photovoltaic/last_update
                            photovoltaic/power_generated_w
                            photovoltaic/power_house_w
                            photovoltaic/power_surplus_w
                            photovoltaic/status_text
                            vom Zeitstempel her aktualisiert werden. Das macht ja auch eigentlich Sinn. Aber irgendwie scheint er sich da immer zu verschlucken. Ich habe keine Ahnung wo ich noch gucken kann.
                            Sag mir gerne wenn ich noch was testen, überprüfen oder bereitstellen kann.
                            Vielen Dank
                            • D DennisMenger
                              Vielen Dank
                              DasBo1975D
                              DasBo1975D
                              DasBo1975
                              #525
                              Vielen Dank
                              Schaue ich mir natürlich an. Gib mir ein bisschen.
                              Eine Frage noch. Deine Schalt-/Messsteckdose ist von HM?
                                Vielen Dank
                                D
                                D
                                DennisMenger
                                #526
                                Moin, ja HmIP
                                • D
                                  D
                                  DennisMenger
                                  #527
                                  Habe nochmal einen Test gemacht, dass ich die Datenpunkte der HmIP-Steckdose direkt ausgewählt habe und nicht über den Alias-Datenpunkt. Brachte aber keine Veränderung.
                                  • D DennisMenger
                                    DasBo1975D
                                    DasBo1975D
                                    DasBo1975
                                    #528
                                    Hallo Dennis,
                                    danke dir erst einmal, dass du weiterhin so geduldig mit testest.
                                    Da das Problem trotz der bisherigen Änderungen weiterhin auftritt, möchte ich jetzt bewusst nicht noch einmal auf Verdacht etwas an PoolControl ändern. Die bisherigen Analysen haben zwar tatsächlich zwei Fehler im Auto-PV-Bereich aufgedeckt, die inzwischen behoben sind, aber offensichtlich waren diese nicht die eigentliche Ursache für das von dir beobachtete Abschalten.
                                    Deshalb möchte ich jetzt einen anderen Weg gehen und den Ablauf auf deinem System wesentlich genauer protokollieren.
                                    Ich habe dafür ein kleines Diagnose-Skript vorbereitet, das du bitte temporär im ioBroker-JavaScript-Adapter laufen lässt.
                                    Wichtig: Das Skript steuert nichts. Es verändert weder PoolControl noch deine Pumpe oder irgendwelche anderen Datenpunkte. Es beobachtet ausschließlich die für den Auto-PV-Betrieb relevanten Zustände und schreibt das Ergebnis gesammelt in einen eigenen Diagnose-Datenpunkt unter 0_userdata.0.
                                    Du musst im Skript auch keine Datenpunkte anpassen. Es liest die von dir in PoolControl eingestellten Datenpunkte für Pumpenschalter, Pumpenleistung, PV-Erzeugung und Hausverbrauch automatisch aus der Konfiguration von poolcontrol.0 aus.
                                    Bitte geh folgendermaßen vor:
                                    Im JavaScript-Adapter ein neues Skript anlegen.
                                    Den folgenden Code vollständig hineinkopieren.
                                    Skript starten.
                                    Danach den Auto-PV-Modus so testen, wie du es bisher gemacht hast.
                                    Warten, bis die Pumpe wieder unerwartet ausgeht.
                                    Anschließend bitte den Inhalt dieses Datenpunktes kopieren:
                                    0_userdata.0.PoolControlDebug.AutoPVTrace
                                    Dort werden die letzten 400 relevanten Ereignisse mit Zeitstempeln im Millisekundenbereich gesammelt.
                                    Mich interessiert dabei vor allem die genaue Reihenfolge: Kommt zuerst der Ausschaltzustand von der HmIP-Steckdose? Setzt PoolControl zuerst seinen internen Pumpenschalter auf AUS? Ändert sich vorher die PV-Berechnung? Oder passiert noch etwas ganz anderes?
                                    Zusätzlich werden unter anderem ack, die Quelle der Stateänderung, Pumpenmodus, aktiver Helper, Pumpenleistung, PV-Erzeugung, Hausverbrauch, Überschuss und der aktuelle Auto-PV-Status festgehalten.
                                    Damit sollten wir beim nächsten Auftreten wesentlich genauer erkennen können, was tatsächlich die Ursache und was nur die Folge des Abschaltens ist.
                                    Hier das Skript:
                                    // PoolControl Auto-PV Diagnose-Trace fuer ioBroker JavaScript-Adapter
                                    // Read-only gegenueber PoolControl und Hardware.
                                    // Schreibt nur nach 0_userdata.0.PoolControlDebug.AutoPVTrace.
                                    const PC = 'poolcontrol.0';
                                    const TRACE_ID = '0_userdata.0.PoolControlDebug.AutoPVTrace';
                                    const MAX_EVENTS = 400;
                                    let trace = [];
                                    let ids = {
                                      pumpSwitch: '',
                                      pumpPower: '',
                                      pvPower: '',
                                      housePower: ''
                                    const pcStates = [
                                      `${PC}.pump.mode`,
                                      `${PC}.pump.active_helper`,
                                      `${PC}.pump.pump_switch`,
                                      `${PC}.pump.current_power`,
                                      `${PC}.pump.pump_max_watt`,
                                      `${PC}.pump.error`,
                                      `${PC}.photovoltaic.power_generated_w`,
                                      `${PC}.photovoltaic.power_house_w`,
                                      `${PC}.photovoltaic.power_surplus_w`,
                                      `${PC}.photovoltaic.surplus_active`,
                                      `${PC}.photovoltaic.status_text`,
                                      `${PC}.photovoltaic.afterrun_min`,
                                      `${PC}.photovoltaic.last_update`,
                                      `${PC}.circulation.daily_remaining`,
                                      `${PC}.status.season_active`
                                    function v(id) {
                                      if (!id) return null;
                                      const s = getState(id);
                                      return s ? s.val : null;
                                    function nowMs() {
                                      const d = new Date();
                                      return d.toTimeString().slice(0, 8) + '.' + String(d.getMilliseconds()).padStart(3, '0');
                                    function short(id) {
                                      return String(id || '').replace(`${PC}.`, '');
                                    function add(src, s) {
                                      const ev = {
                                        rt: nowMs(),
                                        src: short(src),
                                        v: s ? s.val : null,
                                        ack: s ? s.ack : null,
                                        ts: s ? s.ts : null,
                                        lc: s ? s.lc : null,
                                        q: s && s.q !== undefined ? s.q : null,
                                        mode: v(`${PC}.pump.mode`),
                                        owner: v(`${PC}.pump.active_helper`),
                                        pump: v(`${PC}.pump.pump_switch`),
                                        hwPump: v(ids.pumpSwitch),
                                        pumpW: v(`${PC}.pump.current_power`),
                                        hwPumpW: v(ids.pumpPower),
                                        maxW: v(`${PC}.pump.pump_max_watt`),
                                        pv: v(`${PC}.photovoltaic.power_generated_w`),
                                        house: v(`${PC}.photovoltaic.power_house_w`),
                                        surplus: v(`${PC}.photovoltaic.power_surplus_w`),
                                        surplusActive: v(`${PC}.photovoltaic.surplus_active`),
                                        pvText: v(`${PC}.photovoltaic.status_text`),
                                        afterrun: v(`${PC}.photovoltaic.afterrun_min`),
                                        error: v(`${PC}.pump.error`),
                                        dailyRemaining: v(`${PC}.circulation.daily_remaining`),
                                        season: v(`${PC}.status.season_active`)
                                      if (ids.pvPower) ev.hwPv = v(ids.pvPower);
                                      if (ids.housePower) ev.hwHouse = v(ids.housePower);
                                      trace.push(ev);
                                      while (trace.length > MAX_EVENTS) trace.shift();
                                      setState(TRACE_ID, JSON.stringify(trace), true);
                                    createState(TRACE_ID, '[]', {
                                      name: 'PoolControl Auto-PV Trace',
                                      type: 'string',
                                      role: 'json',
                                      read: true,
                                      write: true
                                      setState(TRACE_ID, '[]', true);
                                      getObject(`system.adapter.${PC}`, (err, obj) => {
                                        const cfg = obj && obj.native ? obj.native : {};
                                        ids.pumpSwitch = String(cfg.pump_switch || '').trim();
                                        ids.pumpPower = String(cfg.pump_current_power_id || '').trim();
                                        ids.pvPower = String(cfg.power_generated_id || '').trim();
                                        ids.housePower = String(cfg.power_house_id || '').trim();
                                        const watchIds = Array.from(new Set([
                                          ...pcStates,
                                          ids.pumpSwitch,
                                          ids.pumpPower,
                                          ids.pvPower,
                                          ids.housePower
                                        ].filter(Boolean)));
                                        add('script.start', {
                                          val: {
                                            pumpSwitch: ids.pumpSwitch || null,
                                            pumpPower: ids.pumpPower || null,
                                            pvPower: ids.pvPower || null,
                                            housePower: ids.housePower || null
                                          ack: true,
                                          ts: Date.now(),
                                          lc: Date.now(),
                                          q: 0
                                        watchIds.forEach(id => {
                                          on({ id, change: 'any' }, obj => add(id, obj.state));
                                        log(
                                          `PoolControl Auto-PV Trace gestartet. Beobachte ${watchIds.length} States. Ausgabe: ${TRACE_ID}`,
                                          'info'
                                    Wenn die Pumpe ausgegangen ist, brauchst du mir anschließend nur den kompletten Inhalt von
                                    zu schicken.
                                    Danach kannst du das Diagnose-Skript wieder stoppen oder löschen.
                                    Ich möchte diesmal wirklich erst sehen, was beim Abschalten auf deinem System genau passiert, bevor ich noch einmal etwas an PoolControl ändere.
                                    Vielen Dank nochmals für deine Geduld und vor allem fürs Testen und Bereitstellen der Informationen. Das hilft mir wirklich sehr bei der Fehlersuche. 🙂
                                      Hallo Dennis,
                                      Skript starten.
                                      Hier das Skript:
                                      let trace = [];
                                      let ids = {
                                        pumpSwitch: '',
                                        pumpPower: '',
                                        pvPower: '',
                                        housePower: ''
                                      const pcStates = [
                                        `${PC}.pump.mode`,
                                        `${PC}.pump.error`,
                                      function v(id) {
                                      function nowMs() {
                                        const ev = {
                                          rt: nowMs(),
                                          src: short(src),
                                        trace.push(ev);
                                        type: 'string',
                                        role: 'json',
                                        read: true,
                                        write: true
                                            ...pcStates,
                                            ids.pumpSwitch,
                                            ids.pumpPower,
                                            ids.pvPower,
                                            ids.housePower
                                            val: {
                                            ack: true,
                                            ts: Date.now(),
                                            lc: Date.now(),
                                            q: 0
                                          log(
                                            'info'
                                      zu schicken.
                                      D
                                      D
                                      DennisMenger
                                      schrieb am zuletzt editiert von DennisMenger
                                      #529
                                      @DasBo1975 Moin und vielen Dank.
                                      Wie soll ich dir den Inhalt schicken? Hier für das Forum sind es zu viele Zeichen.
                                      EDIT: habe dir eine Nachricht mit der Datei geschickt
                                      • DasBo1975D
                                        DasBo1975D
                                        DasBo1975
                                        #530
                                        Hallo Dennis,
                                        erst einmal vielen Dank, dass du das kleine Diagnose-Skript so schnell ausprobiert und mir die Aufzeichnung zur Verfügung gestellt hast.
                                        Die Daten daraus waren für mich mehr als hilfreich. Ohne diesen detaillierten Mitschnitt hätte ich diesen Fehler vermutlich noch sehr lange gesucht – oder vielleicht überhaupt nicht gefunden. Im normalen Log waren Ursache und Folge einfach nicht eindeutig genug voneinander zu unterscheiden.
                                        Mit dem Diagnose-Skript konnte ich zum ersten Mal ganz genau sehen, was beim Abschalten passiert: Auto-PV hatte die Pumpe korrekt gestartet, ausreichend PV-Überschuss war vorhanden und auch die Haltebedingung war erfüllt. Trotzdem kam der Ausschaltbefehl direkt aus PoolControl. Die HmIP-Steckdose war damit endgültig aus dem Verdacht raus – sie hat nur brav das gemacht, was PoolControl ihr gesagt hat.
                                        Danach ließ sich der eigentliche Übeltäter finden. 😉
                                        PoolControl besitzt für seine verschiedenen Helper bewusst eine Art Zuständigkeits- und Vorrangsteuerung. Vereinfacht gesagt soll jeder Helper wissen, wann er die Pumpe steuern darf und – mindestens genauso wichtig – wann er die Finger davon lassen muss.
                                        Einer hat sich dabei allerdings ein wenig danebenbenommen: Solar Extended.
                                        Solar Extended hat vollkommen richtig erkannt, dass im Modus Auto-PV gerade nicht seine Stunde geschlagen hat. Anstatt sich danach aber einfach zurückzulehnen und Auto-PV seine Arbeit machen zu lassen, hat er sinngemäß gesagt:
                                        „Ich soll die Pumpe gerade nicht einschalten? Na gut, dann mache ich sie eben aus.“ 😄
                                        Genau das war der Fehler.
                                        Dadurch konnte Solar Extended bei seinem nächsten Durchlauf eine von Auto-PV korrekt laufende Pumpe wieder ausschalten – obwohl Auto-PV weiterhin ausreichend Überschuss erkannt hatte und die Pumpe ausdrücklich weiterlaufen lassen wollte.
                                        Das erklärt auch, warum ich das Problem auf meinem eigenen System nicht reproduzieren konnte: Ich verwende die normale Solarsteuerung. Du verwendest Solar Extended – und genau in dieser Kombination mit Auto-PV lag der Fehler.
                                        Ich habe das Verhalten inzwischen gezielt in einer Testumgebung mit deinen Werten nachgestellt und konnte die Abschaltung reproduzieren. Anschließend wurde die Zuständigkeit von Solar Extended korrigiert und derselbe Test erneut durchgeführt. Auto-PV bleibt jetzt unangetastet. Gleichzeitig wurde geprüft, dass Solar Extended im normalen Automatikmodus weiterhin wie vorgesehen die Pumpe ein- und ausschalten kann.
                                        Die Version 1.4.5 mit dieser Korrektur sollte in den nächsten Stunden verfügbar sein.
                                        Und an dieser Stelle auch noch einmal ein großes Dankeschön an dich und natürlich an alle anderen, die PoolControl testen, Rückmeldungen geben, Logs bereitstellen und auch bei solchen hartnäckigen Fehlern dranbleiben.
                                        Gerade dieser Fall zeigt ziemlich schön, wie wertvoll solche Rückmeldungen sind. Ohne deinen Test mit dem Diagnose-Skript hätten wir zwar einige andere echte Schwachstellen gefunden und behoben – aber der eigentliche Fehler, wegen dem wir ursprünglich angefangen hatten zu suchen, hätte sich weiterhin sehr erfolgreich vor uns versteckt. 😉
                                        Vielen Dank für deine Unterstützung!
                                          Hallo Dennis,
                                          D
                                          D
                                          DennisMenger
                                          #531
                                          @DasBo1975 Super, vielen Dank. Es sieht tatsächlich so aus, dass es aktuell so funktioniert wie es soll. Ich werde das weiter beobachten und Info geben.
                                          Vielen Dank für die immer weitere Entwicklung des Adapters.
                                          83.9k
