  4. Probleme mit deconz Adabter
72 Beiträge 7 Kommentatoren 1.4k Aufrufe 5 Beobachtet
    @docsnyder7 sagte:
    Kann man die Änderung dann in der Usr/lib/systemd/system/deconz.service kontrollieren?
    Da siehst du keine individuellen Einträge, da stehen immer die defaults drin.
    docsnyder7
    @Thomas-Braun
    ### Editing /etc/systemd/system/deconz.service.d/override.conf
    ### Anything between here and the comment below will become the new contents of the file
    [Service]
    ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80 --https-port=0 --ws-port=441
    ### Lines below this comment will be discarded
    ### /lib/systemd/system/deconz.service
    # [Unit]
    # Description=deCONZ: ZigBee gateway -- REST API
    # Wants=deconz-init.service
    # StartLimitIntervalSec=0
    # [Service]
    # User=1000
    # ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80
    # Restart=on-failure
    # RestartSec=30
    # AmbientCapabilities=CAP_NET_BIND_SERVICE CAP_KILL CAP_SYS_BOOT CAP_SYS_TIME
    # [Install]
    # WantedBy=multi-user.target
    sudo systemctl restart deconz
    Failed to restart deconz.service: Unit deconz.service has a bad unit file setting.
    See system logs and 'systemctl status deconz.service' for details.
    Warning: The unit file, source configuration file or drop-ins of deconz.service changed on disk. Run 'systemctl daemon-reload' to reload units.
    × deconz.service - deCONZ: ZigBee gateway -- REST API
         Loaded: bad-setting (Reason: Unit deconz.service has a bad unit file setting.)
        Drop-In: /etc/systemd/system/deconz.service.d
                 └─override.conf
         Active: failed (Result: exit-code) since Thu 2026-07-23 13:51:20 CEST; 2min 50s ago
       Duration: 4ms
       Main PID: 25186 (code=exited, status=203/EXEC)
            CPU: 3ms
    Jul 23 13:51:02 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
    Jul 23 13:51:20 evccpi systemd[1]: deconz.service: Failed to schedule restart job: Unit deconz.service has a bad unit file setting.
    Jul 23 13:51:20 evccpi systemd[1]: deconz.service: Failed with result 'exit-code'.
    Jul 23 13:52:49 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
    Jul 23 13:53:44 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
    • D docsnyder7
      @Thomas-Braun
      [Service]
      # [Unit]
      # [Service]
      # User=1000
      # RestartSec=30
      # [Install]
                   └─override.conf
         Duration: 4ms
              CPU: 3ms
      @docsnyder7 sagte:
      • Michael SchmittM Online
        Michael Schmitt
        Vielleicht das --https-port=0 rausnehmen. Das hab ich bei mir mal eingetragen da es mit dem Https port 443 Probleme gab
          docsnyder7
          schrieb am zuletzt editiert von docsnyder7
          Sorry @thomas-braun und @michael-schmitt
          ich bin wohl zu doof für diese Welt...
          nach dem daemon-reload
          see system logs an ´systemctl status deconz.service´
          sudo systemctl status deconz.service
                       └─override.conf
               Active: failed (Result: exit-code) since Thu 2026-07-23 13:51:20 CEST; 42min ago
             Duration: 4ms
                  CPU: 3ms
          Jul 23 13:55:00 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
          Jul 23 13:55:14 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
          Jul 23 14:11:56 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
          Jul 23 14:17:22 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
          Jul 23 14:17:35 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
          dazukommt nach dem edit
          sudo systemctl edit deconz.service
          Editing "/etc/systemd/system/deconz.service.d/override.conf" canceled: temporary file is empty.
          • D docsnyder7
                         └─override.conf
               Duration: 4ms
                    CPU: 3ms
            @docsnyder7 sagte:
            Musste ich jetzt auch extern nachschauen:
            How to Fix It:
            Clear the old value:
            Add an empty ExecStart= line before your new ExecStart= line in your override/drop-in file to wipe previous definitions.
            Inspect the unit file: Run systemctl cat <service-name> to see the combined configuration and find where the extra line is coming from.
            Check drop-in overrides: Look inside /etc/systemd/system/<service-name>.service.d/ for conflicting override files.
            Reload systemd: Run sudo systemctl daemon-reload and then restart your service with sudo systemctl restart <service-name>.
              @docsnyder7 sagte:
              How to Fix It:
              docsnyder7
              @Thomas-Braun
              sudo systemctl cat deconz.service
              # Warning: deconz.service changed on disk, the version systemd has loaded is outdated.
              # This output shows the current version of the unit's original fragment and drop-in files.
              # If fragments or drop-ins were added or removed, they are not properly reflected in this output.
              # Run 'systemctl daemon-reload' to reload units.
              [Unit]
              [Service]
              User=1000
              Restart=on-failure
              RestartSec=30
              [Install]
              # /etc/systemd/system/deconz.service.d/override.conf
              [Service]
              ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80 --ws-port=441
                docsnyder7
                Mal ne Gegenfrage... kann ich mit dem conbee2 auch auf den zigbee adapter gehen?
                Ro75R 1 Antwort Letzte Antwort
                • D docsnyder7
                  @Thomas-Braun
                  [Unit]
                  [Service]
                  User=1000
                  Restart=on-failure
                  RestartSec=30
                  [Install]
                  [Service]
                  @docsnyder7 sagte:
                  Starte die Kiste mal komplett durch.
                  Ja.
                    @docsnyder7 sagte:
                    Ja.
                    docsnyder7
                    @Thomas-Braun
                    reboot läuft...
                    keine Veränderung...
                    ○ deconz.service - deCONZ: ZigBee gateway -- REST API
                                 └─override.conf
                         Active: inactive (dead)
                    Jul 23 15:13:32 evccpi systemd[1]: /etc/systemd/system/deconz.service.d/override.conf:1: Assignment outside of section. Ignoring.
                    Jul 23 15:13:32 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
                    Jul 23 15:13:37 evccpi systemd[1]: /etc/systemd/system/deconz.service.d/override.conf:1: Assignment outside of section. Ignoring.
                    Jul 23 15:13:53 evccpi systemd[1]: /etc/systemd/system/deconz.service.d/override.conf:1: Assignment outside of section. Ignoring.
                    Jul 23 15:13:53 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
                    Jul 23 15:13:56 evccpi systemd[1]: /etc/systemd/system/deconz.service.d/override.conf:1: Assignment outside of section. Ignoring.
                    • D docsnyder7
                      @Thomas-Braun
                      reboot läuft...
                                   └─override.conf
                      @docsnyder7 sagte:
                      Was steht denn jetzt da drin?
                        docsnyder7
                        @thomas-braun sorry.. muss ich später machen, der PI startet grad nicht mehr und ich bin nicht zu Hause
                          Michael Schmitt
                          schrieb am zuletzt editiert von Michael Schmitt
                          gerade gefunden kann da was dran sein.
                          [Service]
                          ExecStart=
                          Wichtig: Die erste leere Zeile ExecStart= ist notwendig, um den alten Startbefehl des Systems zu löschen, bevor dein neuer Befehl greift).
                          Speichere die Datei im Editor ab (bei nano: Strg + O, Enter und danach Strg + X zum Beenden).
                          Danach sollte die override.conf in
                          erstellt werden.
                          Stimmt das so @thomas-braun ?
                          • Michael SchmittM Michael Schmitt
                            [Service]
                            ExecStart=
                            erstellt werden.
                            @Michael-Schmitt
                            Ja, das hatte ich ja oben auch schon so gefunden:
                            How to Fix It:
                            • D docsnyder7
                              Ro75R Offline
                              Ro75R Offline
                              Ro75
                              @docsnyder7 sagte:
                              Ja, kannst du. Habe ich auch gemacht. Musst aber alle Service von Deconz zuvor komplett deaktivieren oder deinstallieren - sonst geht es mit dem Zigbee-Adapter nicht.
                              Ro75.
                              Michael SchmittM 1 Antwort Letzte Antwort
                              • Ro75R Ro75
                                @docsnyder7 sagte:
                                Ro75.
                                Michael Schmitt
                                @Ro75 sagte:
                                @docsnyder7 sagte:
                                Ro75.
                                nicht zu vergessen = alle Geräte neu anlernen
                                  docsnyder7
                                  Kleiner Nachtrag… musste komplett neu einrichten den PI. Da wir in Urlaub wollten hab ,ich erstmal mit dem Zigbee Adapter beschäftigten die wichtigsten Sensoren dort angelernt…das klappte alles bestens … der Rest dann nach dem Urlaub
                                    Michael Schmitt
                                    @thomas-braun hab das nun mal gemacht
                                    systemctl cat deconz=
                                    marvman67@Raspberry:~ $ systemctl cat deconz
                                    # /usr/lib/systemd/system/deconz.service
                                    [Unit]
                                    [Service]
                                    User=1000
                                    Restart=on-failure
                                    RestartSec=30
                                    [Install]
                                    [Service]
                                    ExecStart=
                                    ich hoffe das stimmt so alles und das nun nach einem Deconz update die Werte nicht wieder nachträglich geändert werden müßen.
                                      [Unit]
                                      [Service]
                                      User=1000
                                      Restart=on-failure
                                      RestartSec=30
                                      [Install]
                                      [Service]
                                      ExecStart=
                                      @Michael-Schmitt sagte:
                                      Kannste ja ausprobieren. Einfach par apt eine der Vorversionen installieren und dann wieder upgraden.
                                        Michael Schmitt
                                        nenenene, da warte ich lieber
                                          Warum?
