  4. Probleme mit deconz Adabter
72 Beiträge 7 Kommentatoren 1.4k Aufrufe 5 Beobachtet
  • D docsnyder7
    @Thomas-Braun
    sudo systemctl cat deconz.service
    # Warning: deconz.service changed on disk, the version systemd has loaded is outdated.
    # This output shows the current version of the unit's original fragment and drop-in files.
    # If fragments or drop-ins were added or removed, they are not properly reflected in this output.
    # Run 'systemctl daemon-reload' to reload units.
    # /lib/systemd/system/deconz.service
    [Unit]
    Description=deCONZ: ZigBee gateway -- REST API
    Wants=deconz-init.service
    StartLimitIntervalSec=0
    [Service]
    User=1000
    ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80
    Restart=on-failure
    RestartSec=30
    AmbientCapabilities=CAP_NET_BIND_SERVICE CAP_KILL CAP_SYS_BOOT CAP_SYS_TIME
    [Install]
    WantedBy=multi-user.target
    # /etc/systemd/system/deconz.service.d/override.conf
    [Service]
    ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80 --ws-port=441
    @docsnyder7 sagte:
    Starte die Kiste mal komplett durch.
    kann ich mit dem conbee2 auch auf den zigbee adapter gehen?
    Ja.
      @docsnyder7 sagte:
      Ja.
      docsnyder7
      schrieb am zuletzt editiert von docsnyder7
      @Thomas-Braun
      reboot läuft...
      keine Veränderung...
      sudo systemctl status deconz.service
      Warning: The unit file, source configuration file or drop-ins of deconz.service changed on disk. Run 'systemctl daemon-reload' to reload units.
      ○ deconz.service - deCONZ: ZigBee gateway -- REST API
           Loaded: bad-setting (Reason: Unit deconz.service has a bad unit file setting.)
          Drop-In: /etc/systemd/system/deconz.service.d
                   └─override.conf
           Active: inactive (dead)
      Jul 23 15:13:32 evccpi systemd[1]: /etc/systemd/system/deconz.service.d/override.conf:1: Assignment outside of section. Ignoring.
      Jul 23 15:13:32 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
      Jul 23 15:13:37 evccpi systemd[1]: /etc/systemd/system/deconz.service.d/override.conf:1: Assignment outside of section. Ignoring.
      Jul 23 15:13:53 evccpi systemd[1]: /etc/systemd/system/deconz.service.d/override.conf:1: Assignment outside of section. Ignoring.
      Jul 23 15:13:53 evccpi systemd[1]: deconz.service: Service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
      Jul 23 15:13:56 evccpi systemd[1]: /etc/systemd/system/deconz.service.d/override.conf:1: Assignment outside of section. Ignoring.
      • D docsnyder7
        @Thomas-Braun
        reboot läuft...
                     └─override.conf
        @docsnyder7 sagte:
        Was steht denn jetzt da drin?
          docsnyder7
          @thomas-braun sorry.. muss ich später machen, der PI startet grad nicht mehr und ich bin nicht zu Hause
          • Michael SchmittM Online
            Michael Schmitt
            schrieb am zuletzt editiert von Michael Schmitt
            gerade gefunden kann da was dran sein.
            sudo systemctl edit deconz.service
            [Service]
            ExecStart=
            ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80 --https-port=0 --ws-port=441
            Wichtig: Die erste leere Zeile ExecStart= ist notwendig, um den alten Startbefehl des Systems zu löschen, bevor dein neuer Befehl greift).
            Speichere die Datei im Editor ab (bei nano: Strg + O, Enter und danach Strg + X zum Beenden).
            Danach sollte die override.conf in
            erstellt werden.
            sudo systemctl daemon-reload
            sudo systemctl restart deconz
            Stimmt das so @thomas-braun ?
            • Michael SchmittM Michael Schmitt
              [Service]
              ExecStart=
              erstellt werden.
              @Michael-Schmitt
              Ja, das hatte ich ja oben auch schon so gefunden:
              How to Fix It:
              Clear the old value:
              Add an empty ExecStart= line before your new ExecStart= line in your override/drop-in file to wipe previous definitions.
              • D docsnyder7
                Mal ne Gegenfrage... kann ich mit dem conbee2 auch auf den zigbee adapter gehen?
                Ro75R Offline
                Ro75R Offline
                Ro75
                @docsnyder7 sagte:
                Ja, kannst du. Habe ich auch gemacht. Musst aber alle Service von Deconz zuvor komplett deaktivieren oder deinstallieren - sonst geht es mit dem Zigbee-Adapter nicht.
                Ro75.
                Michael SchmittM 1 Antwort Letzte Antwort
                • Ro75R Ro75
                  @docsnyder7 sagte:
                  Ro75.
                  Michael Schmitt
                  @Ro75 sagte:
                  @docsnyder7 sagte:
                  Ro75.
                  nicht zu vergessen = alle Geräte neu anlernen
                    docsnyder7
                    Kleiner Nachtrag… musste komplett neu einrichten den PI. Da wir in Urlaub wollten hab ,ich erstmal mit dem Zigbee Adapter beschäftigten die wichtigsten Sensoren dort angelernt…das klappte alles bestens … der Rest dann nach dem Urlaub
                      Michael Schmitt
                      @thomas-braun hab das nun mal gemacht
                      systemctl cat deconz=
                      marvman67@Raspberry:~ $ systemctl cat deconz
                      # /usr/lib/systemd/system/deconz.service
                      [Unit]
                      [Service]
                      User=1000
                      Restart=on-failure
                      RestartSec=30
                      [Install]
                      [Service]
                      ExecStart=
                      ich hoffe das stimmt so alles und das nun nach einem Deconz update die Werte nicht wieder nachträglich geändert werden müßen.
                        [Unit]
                        [Service]
                        User=1000
                        Restart=on-failure
                        RestartSec=30
                        [Install]
                        [Service]
                        ExecStart=
                        @Michael-Schmitt sagte:
                        Kannste ja ausprobieren. Einfach par apt eine der Vorversionen installieren und dann wieder upgraden.
                          Michael Schmitt
                          nenenene, da warte ich lieber
                            Warum?
                              Michael Schmitt
                              das downgrade mit deren Versionen ist voll der HickHack
                                @Michael-Schmitt
                                Das läuft doch ganz normal über apt?
                                apt upgrade deconz=VERSIONSNUMMER
                                fertig.
                                  Michael Schmitt
                                  ich bräuchte da zb schon
                                  sudo apt install deconz-qt6=VERSIONSNUMMER
                                  aber ich lass das bis zum nächsten kommenden update
                                    @Michael-Schmitt
                                    Wie auch immer das Paket konkret heißt...
                                      Michael Schmitt
                                      https://forum.phoscon.de/t/wrong-file-in-upload/6909
                                      da hatte ich das letzte mal Probleme. Ich werds beim nächsten update merken ;)
                                        @Michael-Schmitt
                                        Da machst du ja auch irgendwelche Harakiri-Aktionen.
                                        Wundert mich dann auch nicht weiter, wenn du da Quark im System hast.
                                          Michael Schmitt
                                          aber muß ich nicht erst die alte Version für das downgrde herunterladen ?
