Adapter: SMA SEMP
Alles klar.
Hab nochmal auf debug umgestellt jetzt steht schon mehr im log:semp.0 2026-06-29 21:22:08.246 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:22:08.245 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:22:08.243 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:22:08.243 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:22:08.238 debug Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running semp.0 2026-06-29 21:22:08.238 debug Keba KeContact P30X: status detection time limit is 1 going to off semp.0 2026-06-29 21:22:08.238 debug Keba KeContact P30X: set status detection limit to 500 semp.0 2026-06-29 21:22:08.236 debug Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running semp.0 2026-06-29 21:22:08.236 debug Keba KeContact P30X: status detection time limit is 1 going to off semp.0 2026-06-29 21:22:08.236 debug Keba KeContact P30X: set status detection limit to 500 semp.0 2026-06-29 21:22:08.229 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:22:08.229 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:22:08.214 debug Keba KeContact P30X: set new charge power 0 number semp.0 2026-06-29 21:22:08.213 debug planning request: got energy used 0 semp.0 2026-06-29 21:22:08.213 debug Keba KeContact P30X: calc energy 0 1782760928211 = 0Wh semp.0 2026-06-29 21:22:08.212 debug Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off semp.0 2026-06-29 21:22:08.212 debug planning request: got energy used 0 semp.0 2026-06-29 21:22:08.212 debug Keba KeContact P30X: calc energy 0 1782760913215 = 0Wh semp.0 2026-06-29 21:22:08.211 debug Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off semp.0 2026-06-29 21:22:08.209 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:22:08.209 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:22:08.202 debug Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number semp.0 2026-06-29 21:22:08.202 debug Keba KeContact P30X: new recommendation power 0 number semp.0 2026-06-29 21:22:08.202 debug Keba KeContact P30X: wallbox charging false semp.0 2026-06-29 21:22:08.202 debug Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean semp.0 2026-06-29 21:22:08.201 debug Keba KeContact P30X: no switch configured semp.0 2026-06-29 21:22:08.201 debug Keba KeContact P30X: disconnect - timer fired semp.0 2026-06-29 21:22:08.201 debug planning request: Planningrequest all timeframes canceled semp.0 2026-06-29 21:22:08.201 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false semp.0 2026-06-29 21:22:08.200 debug Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean semp.0 2026-06-29 21:22:08.196 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:22:08.196 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:22:08.193 debug Keba KeContact P30X: wallbox error true semp.0 2026-06-29 21:22:08.193 debug Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number semp.0 2026-06-29 21:21:56.663 debug SempServer: response sent semp.0 2026-06-29 21:21:56.661 debug SempServer: response xml <?xml version="1.0" encoding="utf-8"?> <Device2EM xmlns="http://www.sma.de/communication/schema/SEMP/v1"> <DeviceInfo> <Identification> <DeviceId>F-00000000-000000000001-00</DeviceId> <DeviceName>Keba KeContact P30X</DeviceName> <DeviceType>EVCharger</DeviceType> <DeviceSerial>20296767</DeviceSerial> <DeviceVendor>Keba</DeviceVendor> </Identification> <Characteristics> <MaxPowerConsumption>11000</MaxPowerConsumption> <MinPowerConsumption>6000</MinPowerConsumption> </Characteristics> <Capabilities> <CurrentPower> <Method>Measurement</Method> </CurrentPower> <Timestamps> <AbsoluteTimestamps>false</AbsoluteTimestamps> </Timestamps> <Interruptions> <InterruptionsAllowed>false</InterruptionsAllowed> </Interruptions> <Requests> <OptionalEnergy>true</OptionalEnergy> </Requests> </Capabilities> </DeviceInfo> <DeviceStatus> <DeviceId>F-00000000-000000000001-00</DeviceId> <EMSignalsAccepted>false</EMSignalsAccepted> <Status>Off</Status> <PowerConsumption> <PowerInfo> <AveragePower>0</AveragePower> <Timestamp>0</Timestamp> <AveragingInterval>60</AveragingInterval> </PowerInfo> </PowerConsumption> </DeviceStatus> </Device2EM> semp.0 2026-06-29 21:21:56.658 debug planning request: planningrequest data [] semp.0 2026-06-29 21:21:56.658 debug Keba KeContact P30X: no switch configured semp.0 2026-06-29 21:21:56.658 debug Keba KeContact P30X: turn device off semp.0 2026-06-29 21:21:56.658 debug planning request: Planningrequest Check2Switch {"SwitchOff":true,"restart":false} semp.0 2026-06-29 21:21:56.657 debug Gateway: get all devices semp.0 2026-06-29 21:21:56.656 debug SempServer: SHM requested all devices. /semp/ ::ffff:192.168.30.2 http yamaha.0 2026-06-29 21:21:55.770 info State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string" yamaha.0 2026-06-29 21:21:55.311 info State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string" yamaha.0 2026-06-29 21:21:54.687 info State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string" yamaha.0 2026-06-29 21:21:54.335 info State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string" semp.0 2026-06-29 21:21:53.233 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:53.232 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:53.231 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:53.231 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:53.227 debug Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running semp.0 2026-06-29 21:21:53.226 debug Keba KeContact P30X: status detection time limit is 1 going to off semp.0 2026-06-29 21:21:53.226 debug Keba KeContact P30X: set status detection limit to 500 semp.0 2026-06-29 21:21:53.225 debug Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running semp.0 2026-06-29 21:21:53.225 debug Keba KeContact P30X: status detection time limit is 1 going to off semp.0 2026-06-29 21:21:53.224 debug Keba KeContact P30X: set status detection limit to 500 semp.0 2026-06-29 21:21:53.219 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:53.219 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:53.215 debug planning request: got energy used 0 semp.0 2026-06-29 21:21:53.215 debug Keba KeContact P30X: calc energy 0 1782760913214 = 0Wh semp.0 2026-06-29 21:21:53.215 debug Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off semp.0 2026-06-29 21:21:53.214 debug planning request: got energy used 0 semp.0 2026-06-29 21:21:53.214 debug Keba KeContact P30X: calc energy 0 1782760898217 = 0Wh semp.0 2026-06-29 21:21:53.214 debug Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off semp.0 2026-06-29 21:21:53.211 debug Keba KeContact P30X: set new charge power 0 number semp.0 2026-06-29 21:21:53.210 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:53.210 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State yamaha.0 2026-06-29 21:21:53.207 info State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string" semp.0 2026-06-29 21:21:53.203 debug Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number semp.0 2026-06-29 21:21:53.203 debug Keba KeContact P30X: new recommendation power 0 number semp.0 2026-06-29 21:21:53.203 debug Keba KeContact P30X: wallbox charging false semp.0 2026-06-29 21:21:53.203 debug Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean semp.0 2026-06-29 21:21:53.203 debug Keba KeContact P30X: no switch configured semp.0 2026-06-29 21:21:53.202 debug Keba KeContact P30X: disconnect - timer fired semp.0 2026-06-29 21:21:53.202 debug planning request: Planningrequest all timeframes canceled semp.0 2026-06-29 21:21:53.202 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false semp.0 2026-06-29 21:21:53.202 debug Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean semp.0 2026-06-29 21:21:53.198 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:53.196 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:53.193 debug Keba KeContact P30X: wallbox error true semp.0 2026-06-29 21:21:53.192 debug Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number semp.0 2026-06-29 21:21:52.984 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:52.966 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:52.949 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:52.928 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:52.879 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:52.863 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:52.823 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:52.808 debug SempServer: SHM requested description yamaha.0 2026-06-29 21:21:52.800 info State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string" semp.0 2026-06-29 21:21:52.793 debug SempServer: SHM requested description yamaha.0 2026-06-29 21:21:52.358 info State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string" semp.0 2026-06-29 21:21:52.169 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:52.120 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:52.103 debug SempServer: SHM requested description yamaha.0 2026-06-29 21:21:51.986 info State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string" yamaha.0 2026-06-29 21:21:51.650 info State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string" semp.0 2026-06-29 21:21:38.238 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:38.238 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:38.235 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:38.235 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:38.231 debug Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running semp.0 2026-06-29 21:21:38.231 debug Keba KeContact P30X: status detection time limit is 1 going to off semp.0 2026-06-29 21:21:38.230 debug Keba KeContact P30X: set status detection limit to 500 semp.0 2026-06-29 21:21:38.229 debug Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running semp.0 2026-06-29 21:21:38.228 debug Keba KeContact P30X: status detection time limit is 1 going to off semp.0 2026-06-29 21:21:38.228 debug Keba KeContact P30X: set status detection limit to 500 semp.0 2026-06-29 21:21:38.223 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:38.223 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:38.218 debug planning request: got energy used 0 semp.0 2026-06-29 21:21:38.217 debug Keba KeContact P30X: calc energy 0 1782760898215 = 0Wh semp.0 2026-06-29 21:21:38.217 debug Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off semp.0 2026-06-29 21:21:38.217 debug planning request: got energy used 0 semp.0 2026-06-29 21:21:38.215 debug Keba KeContact P30X: calc energy 0 1782760892188 = 0Wh semp.0 2026-06-29 21:21:38.214 debug Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off semp.0 2026-06-29 21:21:38.212 debug Keba KeContact P30X: set new charge power 0 number semp.0 2026-06-29 21:21:38.209 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:38.209 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:38.204 debug Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number semp.0 2026-06-29 21:21:38.203 debug Keba KeContact P30X: new recommendation power 0 number semp.0 2026-06-29 21:21:38.203 debug Keba KeContact P30X: wallbox charging false semp.0 2026-06-29 21:21:38.202 debug Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean semp.0 2026-06-29 21:21:38.202 debug Keba KeContact P30X: no switch configured semp.0 2026-06-29 21:21:38.201 debug Keba KeContact P30X: disconnect - timer fired semp.0 2026-06-29 21:21:38.201 debug planning request: Planningrequest all timeframes canceled semp.0 2026-06-29 21:21:38.201 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false semp.0 2026-06-29 21:21:38.200 debug Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean semp.0 2026-06-29 21:21:38.198 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:38.197 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:38.194 debug Keba KeContact P30X: wallbox error true semp.0 2026-06-29 21:21:38.193 debug Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number semp.0 2026-06-29 21:21:35.197 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:35.181 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:35.126 info SempServer: adapter discovered by SHM semp.0 2026-06-29 21:21:35.126 debug SempServer: SHM requested description semp.0 2026-06-29 21:21:32.204 debug result [{"ID":"F-00000000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}] semp.0 2026-06-29 21:21:32.203 debug device {"ID":"F-00000000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true} semp.0 2026-06-29 21:21:32.203 debug UpdateData semp.0 2026-06-29 21:21:32.203 debug Gateway: set device semp.0 2026-06-29 21:21:32.203 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:32.202 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:32.200 debug planning request: planningrequest set minEnergy 0 semp.0 2026-06-29 21:21:32.195 debug Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MaxEnergy semp.0 2026-06-29 21:21:32.193 debug Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MinEnergy semp.0 2026-06-29 21:21:32.193 debug Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running semp.0 2026-06-29 21:21:32.192 debug Keba KeContact P30X: status detection time limit is 1 going to off semp.0 2026-06-29 21:21:32.192 debug Keba KeContact P30X: set status detection limit to 500 semp.0 2026-06-29 21:21:32.189 debug planning request: got energy used 0 semp.0 2026-06-29 21:21:32.188 debug Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off semp.0 2026-06-29 21:21:32.185 debug Keba KeContact P30X: subscribe OID_Counter 0_userdata.0.Stromversorgung.Wallbox-PowerW semp.0 2026-06-29 21:21:32.185 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:32.184 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:32.182 debug Keba KeContact P30X: wallbox error true semp.0 2026-06-29 21:21:32.182 debug Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number semp.0 2026-06-29 21:21:32.179 debug Keba KeContact P30X: subscribe OID_IsError kecontact.0.error1 semp.0 2026-06-29 21:21:32.179 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:32.179 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:32.177 debug Keba KeContact P30X: wallbox charging false semp.0 2026-06-29 21:21:32.176 debug Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean semp.0 2026-06-29 21:21:32.174 debug Keba KeContact P30X: subscribe OID_IsCharging 0_userdata.0.Stromversorgung.Wallbox-Plug semp.0 2026-06-29 21:21:32.174 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:32.173 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:32.171 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:32.171 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:32.166 debug Keba KeContact P30X: in SetState, no new state to set, is plug not connected semp.0 2026-06-29 21:21:32.165 debug Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State semp.0 2026-06-29 21:21:32.164 debug Keba KeContact P30X: set new charge power 0 number semp.0 2026-06-29 21:21:32.158 debug Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number semp.0 2026-06-29 21:21:32.158 debug Keba KeContact P30X: new recommendation power 0 number semp.0 2026-06-29 21:21:32.157 debug Keba KeContact P30X: no switch configured semp.0 2026-06-29 21:21:32.157 debug Keba KeContact P30X: disconnect - timer fired semp.0 2026-06-29 21:21:32.157 debug planning request: Planningrequest all timeframes canceled semp.0 2026-06-29 21:21:32.156 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false semp.0 2026-06-29 21:21:32.156 debug Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean semp.0 2026-06-29 21:21:32.151 debug Keba KeContact P30X: subscribe OID_PlugConnected 0_userdata.0.Stromversorgung.Wallbox-Plug semp.0 2026-06-29 21:21:32.106 info Keba KeContact P30X: device created F-00000000-000000000001-00 Keba KeContact P30X semp.0 2026-06-29 21:21:32.105 debug Keba KeContact P30X: wallbox OID configuration (2) {"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"}} semp.0 2026-06-29 21:21:32.105 debug Keba KeContact P30X: wallbox OID configuration (1) [{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}] [{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}] semp.0 2026-06-29 21:21:32.105 debug Keba KeContact P30X: can use optional energy: true semp.0 2026-06-29 21:21:32.105 debug Keba KeContact P30X: BaseId 00000000 length 8 semp.0 2026-06-29 21:21:32.104 debug Keba KeContact P30X: check DeviceID F-00000000-000000000001-00 type string semp.0 2026-06-29 21:21:32.104 debug planning request: planningrequest constructor {"DeviceName":"Keba KeContact P30X","DeviceType":"EVCharger","MaxEnergy":82000,"MinEnergy":8200,"MinPower":6000,"MaxPower":11000,"WallboxChargeTime":"3","DishwasherMode":false,"Type":"EVCharger","Name":"Keba KeContact P30X"} semp.0 2026-06-29 21:21:32.104 debug planning request: instance created semp.0 2026-06-29 21:21:32.103 debug Keba KeContact P30X: instance created semp.0 2026-06-29 21:21:32.102 debug Gateway: add device F-00000000-000000000001-00 semp.0 2026-06-29 21:21:32.102 debug add device {"ID":"F-00000000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false} semp.0 2026-06-29 21:21:32.101 debug Started all! semp.0 2026-06-29 21:21:32.101 debug Gateway: gateway started... semp.0 2026-06-29 21:21:32.100 debug Gateway: SSDPServer started semp.0 2026-06-29 21:21:32.086 debug SempServer: SEMP server listening on 9765 semp.0 2026-06-29 21:21:32.083 debug Gateway: gateway created... semp.0 2026-06-29 21:21:32.083 debug SempServer: SEMPServer created semp.0 2026-06-29 21:21:32.076 debug SempServer: instance created semp.0 2026-06-29 21:21:32.076 debug Gateway: SSDPServer created: http://192.168.30.90:9765/description.xml F-00000000-000000000001-00 semp.0 2026-06-29 21:21:32.075 debug SSDPServer: instance created semp.0 2026-06-29 21:21:32.075 debug Gateway: instance created semp.0 2026-06-29 21:21:32.075 debug BaseID: valid 8-digit number semp.0 2026-06-29 21:21:32.074 debug check BaseID 30380000 type string semp.0 2026-06-29 21:21:32.074 debug check BaseID 30380000 type string semp.0 2026-06-29 21:21:32.074 debug {"IPAddress":"192.168.30.90","UUID":"F-00000000-000000000001-00","SempPort":9765,"SempName":"ioBroker Gateway","SempManufacturer":"ioBroker","DeviceBaseID":"30380000","extendedLog":false,"LogToCSV":false,"LogToCSVPath":"/home/pi/semp.csv","devices":[{"ID":"F-00000000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}],"deviceSelector":"F-00000000-000000000001-00"} semp.0 2026-06-29 21:21:32.063 info starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.semp, node: v22.21.0, js-controller: 7.2.2 semp.0 2026-06-29 21:21:30.701 debug Plugin sentry Initialize Plugin (enabled=true) semp.0 2026-06-29 21:21:30.662 debug States connected to redis: redis:6379 semp.0 2026-06-29 21:21:30.656 debug States create User PubSub Client semp.0 2026-06-29 21:21:30.655 debug States create System PubSub Client semp.0 2026-06-29 21:21:30.643 debug Redis States: Use Redis connection: redis:6379 semp.0 2026-06-29 21:21:30.633 debug Objects connected to redis: 172.18.0.5:6379 semp.0 2026-06-29 21:21:30.629 debug Objects client initialize lua scripts semp.0 2026-06-29 21:21:30.460 debug Objects create User PubSub Client semp.0 2026-06-29 21:21:30.459 debug Objects create System PubSub Client semp.0 2026-06-29 21:21:30.457 debug Objects client ready ... initialize now semp.0 2026-06-29 21:21:30.440 debug Redis Objects: Use Redis connection: 172.18.0.5:6379und hier noch der output von der URL:
F-00000000-000000000001-00 Keba KeContact P30X EVCharger 20296767 Keba 11000 6000 Measurement false false true F-00000000-000000000001-00 false Off 0 0 60@Qlink Ich denke, mit der DeviceID = F-00000000-000000000001-00 wird das nicht funktionieren. Mindestens der erste Block nach dem F- sollte mit einer BaseID gefüllt werden (entweder mit der vom Adapter angezeigten oder einer eigenen) Die DeviceID muss bei SMA unique sein...
ich hab die DeviceID nun angepasst, hat aber leider am Verhalten nichts geändert:
semp.0 2026-07-02 15:12:05.273 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:11:56.482 info State value to set for "semp.0.Devices.Keba KeContact P30X.TimeFrames.1.RemainingMaxEnergy" has to be type "number" but received type "string" semp.0 2026-07-02 15:11:50.272 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true admin.0 2026-07-02 15:11:36.281 info ==> Connected system.user.admin from ::ffff:192.168.30.57 semp.0 2026-07-02 15:11:35.300 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:11:20.268 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:11:05.268 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:10:56.297 info State value to set for "semp.0.Devices.Keba KeContact P30X.TimeFrames.1.RemainingMaxEnergy" has to be type "number" but received type "string" semp.0 2026-07-02 15:10:50.270 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:10:35.271 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:10:20.271 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:10:16.693 info SempServer: adapter discovered by SHM semp.0 2026-07-02 15:10:13.718 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:10:13.670 info Keba KeContact P30X: device created F-30380000-000000000001-00 Keba KeContact P30X semp.0 2026-07-02 15:10:13.623 info starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.semp, node: v22.21.0, js-controller: 7.2.2 -
semp.0 2026-07-02 15:12:05.273 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:11:56.482 info State value to set for "semp.0.Devices.Keba KeContact P30X.TimeFrames.1.RemainingMaxEnergy" has to be type "number" but received type "string" semp.0 2026-07-02 15:11:50.272 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true admin.0 2026-07-02 15:11:36.281 info ==> Connected system.user.admin from ::ffff:192.168.30.57 semp.0 2026-07-02 15:11:35.300 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:11:20.268 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:11:05.268 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:10:56.297 info State value to set for "semp.0.Devices.Keba KeContact P30X.TimeFrames.1.RemainingMaxEnergy" has to be type "number" but received type "string" semp.0 2026-07-02 15:10:50.270 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:10:35.271 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:10:20.271 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:10:16.693 info SempServer: adapter discovered by SHM semp.0 2026-07-02 15:10:13.718 info Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true semp.0 2026-07-02 15:10:13.670 info Keba KeContact P30X: device created F-30380000-000000000001-00 Keba KeContact P30X semp.0 2026-07-02 15:10:13.623 info starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.semp, node: v22.21.0, js-controller: 7.2.2ich hab die DeviceID nun angepasst, hat aber leider am Verhalten nichts geändert:
ja und gleichzeitig wieder debug abgeschaltet...
schon mal die logs auf dem SHM selbst angeschaut?
@Qlink Du musst das log etwas länger laufen lassen. Der SHM fragt nur einmal pro Minute die Daten ab. Ich benötige den log-Eintrag, der mit "response xml " beginnt.
Oder alternativ kannst du das auch im browser aufrufen (wie ich oben schon mal geschrieben hatte) :Du kannst auch http://xx.xx.xx.xx:9765/semp mit xx.xx.xx.xx als deine IP des iobroker Gateways (also nicht SHM) im Browser eingeben. Dann zeigt dein Browser an, was der SHM normalerweise als XML bekommen würde ... Im Idealfall schaltest du im Browser noch auf "Seiten-Quelltext" um, dann ist es besser lesbar...
In einem anderen Fall musste man "InterruptionsAllowed" mal ein / ausschalten, damit die Daten gesendet werden...
@Qlink eigentlich sieht jetzt das xml gut aus. Ich sehe keinen offensichtlichen Fehler mehr.
Hast du schon mal versucht, das log vom SHM selbst anzuschauen?
Ich hatte das unter
https://github.com/rg-engineering/ioBroker.semp/blob/master/docu/connection_assist/connection_assist_de.md
beschrieben... -
Der findet gar keine Geräte bei mir im Netzwerk, obwohl ich den SHM vom selben Rechner aus pingen kann
@Qlink du bist per Kabel und nicht per WLAN verbunden? Hast du weitere Router oder switche zwischen deinem PC und dem SHM? Ideal ist, den PC an den switch zu verbinden, an dem auch der SHM angeschlossen ist. Jeder switch oder Router zwischen PC und SHM kann die discover-Messages im Netzwerk verwerfen, so dass sie nicht am Ziel ankommen. Ping hat nichts zu bedeuten, die discover-Messages verwenden ein anderes Protokoll...
@rene_hm auch per Kabel am selben Switch wo der SHM hängt findet der Connection Assist keine SMA Geräte, obwohl selbes Subnet. IGMP Snooping am Unifi UCG deaktiviert... Keine Ahnung was ich noch probieren kann...
@Qlink Ich hatte jetzt endlich die chance, das auch hier in einem setup auszuprobieren, wo connection_assist nichts findet. Bist du vertraut mit wireshark? Dann könnten wir es darüber analysieren.
Ein Thema bei mir war, dass ich weitere Netzwerk-Adapter verfügbar aber inaktiv hatte. Ich habe alle unter Systemsteuerung\Netzwerk und Internet\Netzwerkverbindungen deaktiviert, nur den Ethernet Adapter aktiv gelassen, wo das Netzwerkkabel angesteckt war. Damit hat connection_assist schon mal die Wechselrichter gefunden. Ich habe dann in der Firewall auf dem Windows-Laptop den Port 9522 für UDP eingehend geöffnet. Damit kam dann auch der SHM durch... -
Deine Hinweise und Tipps hätte ich nun auch alles probiert, aber leider ohne Erfolg. Egal was ich anstelle, WR + SHM lassen sich pingen, aber per Connection Assist werden sie nicht gefunden. Lässt sich ohne dem SHM Log dem Problem nicht auch anders auf die Spur kommen ?
Hallo Rene_HM, ich habe den aktuellen Adapter in Nutzung, dieser funktioniert für meine Begriffe nicht ganz zuverlässig. Ich kann aber nicht sagen ob das am Adapter, am SHM2.0 oder am enoxOS liegt. Zumindest tauchen immer wieder Karteileichen von früheren Versuchen mit der älteren Version im Portal bei der Gerätesuche auf. Den Adapter habe ich komplett neu installiert und wieder neu konfiguriert, den SHM2.0 habe ich auf Werkseinstellungen zurückgesetzt und neu eingebunden. Ich vermute es liegt am ennoxOS.
Aber nun erst einmal einige bugs, welche ich festgestellt habe:
- sobald ich ein Gerät neu erstelle, werden bei sämtlichen Objekteinträgen die Datenpunkte falsch konfiguriert. Hier scheint eine Verwechslung zwischen "type" und "name" drin zu sein. Iobroker bringt dabei folgende Warnung:
semp.0 2026-08-18 11:21:37.687 warn Object semp.0.Devices.Geschirrspueler.State is invalid: obj.type has an invalid value (current State) but has to be one of state, channel, device, enum, host, adapter, instance, meta, config, script, user, group, chart, folder, schedule, design This will throw an error up from js-controller version 7.0.0!hier die Objekteigenschaften:
{ "type": "current State", "common": { "name": "state", "role": "state", "type": "string", "unit": "", ........richtig müsste vermutlich sein:
{ "type": "state", "common": { "name": "current State", "role": "state", "type": "string", "unit": "", ........- Dann habe ich noch entdeckt, das der Punkt "Unterbrechung erlaubt" erst einmal aktiviert und dann wieder deaktiviert werden muß, damit das Protokoll richtig erstellt wird. Andernfalls ist bei der WEB-Analyse (http://<IP>:9765/semp) der Übergabewert <interruptionsallowed> LEER und nicht FALSE.
<deviceinfo> <capabilities> <interruptions> <interruptionsallowed></interruptionsallowed> </interruptions> </capabilities> </deviceinfo>ob das allerdings negative Auswirkungen hat weis ich nicht.
Prinzipiell danke ich Dir vielmals, für deine hervorragende Leistung, bei der Erstellung des Adapters. Es macht immer wieder Freude auf solche konstruktiven und hilfreichen Arbeiten zurückgreifen zu können.
Danke für dein feedback.
Bzgl. der Karteileichen: Eigentlich sollte es reichen, die alten Geräte im Portal zu löschen. Das ging jedenfalls mal, ob das aktuell noch geht, habe ich nicht probiert. Der Adapter sendet die Gerätebeschreibung an den SHM und der an's Portal. Wenn es das Gerät im Adapter nicht mehr gibt, schickt der nichts mehr. Das Portal hingegen muss sich die Geräte merken, da das Gerät ja nur temporär ausgefallen sein könnte...Das mit den Datenpunkten schaue ich mir an. Habe mir dazu ein Ticket gemacht
https://github.com/rg-engineering/ioBroker.semp/issues/494
Für das Theme mit den Unterbrechungen habe ich mir ebenfalls ein Ticket gemacht, obwohl ich das schon kenne. Ich dachte, ich hätte das schon behoben...
