- ioBroker Community Home
- Deutsch
- ioBroker Allgemein
- Adapter: SMA SEMP
Adapter: SMA SEMP
Hier nochmal der Log Output mit debug aktiviert:
2026-07-05 20:11:29.145 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-05 20:11:44.148 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-05 20:11:59.149 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-05 20:12:14.147 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-05 20:12:23.004 - info: javascript.0 (568) script.js.Beschattung.Sonnenstandsberechnung: Sonne: Azimut: 297° / Sonne: Elevation: 6.9° / Mond: Azimut: 51° / Mond: Elevation: -31.6°
2026-07-05 20:12:29.147 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-05 20:12:44.149 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-05 20:12:48.182 - info: web.1 (1782) <== Disconnect system.user.admin from ::ffff:192.168.30.237
2026-07-05 20:12:49.178 - info: web.1 (1782) ==> Connected system.user.admin from ::ffff:192.168.30.237
2026-07-05 20:12:51.288 - info: host.iobroker stopInstance system.adapter.semp.0 (force=false, process=true)
2026-07-05 20:12:51.293 - info: host.iobroker stopInstance system.adapter.semp.0 send kill signal
2026-07-05 20:12:51.293 - info: semp.0 (9778) Got terminate signal TERMINATE_YOURSELF
2026-07-05 20:12:51.297 - info: semp.0 (9778) terminating
2026-07-05 20:12:51.299 - info: semp.0 (9778) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2026-07-05 20:12:51.795 - info: semp.0 (9778) terminating
2026-07-05 20:12:51.796 - info: semp.0 (9778) terminating
2026-07-05 20:12:51.974 - info: host.iobroker instance system.adapter.semp.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2026-07-05 20:12:55.239 - info: host.iobroker instance system.adapter.semp.0 in version "2.0.12" started with pid 29126
2026-07-05 20:12:56.272 - debug: semp.0 (29126) Redis Objects: Use Redis connection: 172.18.0.5:6379
2026-07-05 20:12:56.290 - debug: semp.0 (29126) Objects client ready ... initialize now
2026-07-05 20:12:56.291 - debug: semp.0 (29126) Objects create System PubSub Client
2026-07-05 20:12:56.292 - debug: semp.0 (29126) Objects create User PubSub Client
2026-07-05 20:12:56.466 - debug: semp.0 (29126) Objects client initialize lua scripts
2026-07-05 20:12:56.470 - debug: semp.0 (29126) Objects connected to redis: 172.18.0.5:6379
2026-07-05 20:12:56.480 - debug: semp.0 (29126) Redis States: Use Redis connection: redis:6379
2026-07-05 20:12:56.494 - debug: semp.0 (29126) States create System PubSub Client
2026-07-05 20:12:56.495 - debug: semp.0 (29126) States create User PubSub Client
2026-07-05 20:12:56.501 - debug: semp.0 (29126) States connected to redis: redis:6379
2026-07-05 20:12:56.547 - debug: semp.0 (29126) Plugin sentry Initialize Plugin (enabled=true)
2026-07-05 20:12:58.081 - info: semp.0 (29126) starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.semp, node: v22.21.0, js-controller: 7.2.2
2026-07-05 20:12:58.093 - debug: semp.0 (29126) {"IPAddress":"192.168.30.90","UUID":"F-00000000-000000000001-00","SempPort":9765,"SempName":"ioBroker Gateway","SempManufacturer":"ioBroker","DeviceBaseID":"30380000","extendedLog":false,"LogToCSV":false,"LogToCSVPath":"/home/pi/semp.csv","devices":[{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}],"deviceSelector":"F-30380000-000000000001-00"}
2026-07-05 20:12:58.093 - debug: semp.0 (29126) check BaseID 30380000 type string
2026-07-05 20:12:58.093 - debug: semp.0 (29126) BaseID: valid 8-digit number
2026-07-05 20:12:58.093 - debug: semp.0 (29126) Gateway: instance created
2026-07-05 20:12:58.094 - debug: semp.0 (29126) SSDPServer: instance created
2026-07-05 20:12:58.095 - debug: semp.0 (29126) Gateway: SSDPServer created: http://192.168.30.90:9765/description.xml F-00000000-000000000001-00
2026-07-05 20:12:58.095 - debug: semp.0 (29126) SempServer: instance created
2026-07-05 20:12:58.100 - debug: semp.0 (29126) SempServer: SEMPServer created
2026-07-05 20:12:58.100 - debug: semp.0 (29126) Gateway: gateway created...
2026-07-05 20:12:58.104 - debug: semp.0 (29126) SempServer: SEMP server listening on 9765
2026-07-05 20:12:58.118 - debug: semp.0 (29126) Gateway: SSDPServer started
2026-07-05 20:12:58.118 - debug: semp.0 (29126) Gateway: gateway started...
2026-07-05 20:12:58.119 - debug: semp.0 (29126) Started all!
2026-07-05 20:12:58.119 - debug: semp.0 (29126) add device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}
2026-07-05 20:12:58.119 - debug: semp.0 (29126) Gateway: add device F-30380000-000000000001-00
2026-07-05 20:12:58.120 - debug: semp.0 (29126) Keba KeContact P30X: instance created
2026-07-05 20:12:58.121 - debug: semp.0 (29126) planning request: instance created
2026-07-05 20:12:58.121 - debug: semp.0 (29126) planning request: planningrequest constructor {"DeviceName":"Keba KeContact P30X","DeviceType":"EVCharger","MaxEnergy":82000,"MinEnergy":8200,"MinPower":6000,"MaxPower":11000,"WallboxChargeTime":"3","DishwasherMode":false,"Type":"EVCharger","Name":"Keba KeContact P30X"}
2026-07-05 20:12:58.121 - debug: semp.0 (29126) Keba KeContact P30X: check DeviceID F-30380000-000000000001-00 type string
2026-07-05 20:12:58.121 - debug: semp.0 (29126) Keba KeContact P30X: BaseId 30380000 length 8
2026-07-05 20:12:58.121 - debug: semp.0 (29126) Keba KeContact P30X: can use optional energy: true
2026-07-05 20:12:58.121 - debug: semp.0 (29126) Keba KeContact P30X: wallbox OID configuration (1) [{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}] [{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}]
2026-07-05 20:12:58.122 - debug: semp.0 (29126) Keba KeContact P30X: wallbox OID configuration (2) {"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"}}
2026-07-05 20:12:58.122 - info: semp.0 (29126) Keba KeContact P30X: device created F-30380000-000000000001-00 Keba KeContact P30X
2026-07-05 20:12:58.167 - debug: semp.0 (29126) Keba KeContact P30X: subscribe OID_PlugConnected 0_userdata.0.Stromversorgung.Wallbox-Plug
2026-07-05 20:12:58.171 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-05 20:12:58.171 - info: semp.0 (29126) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-05 20:12:58.172 - debug: semp.0 (29126) planning request: Planningrequest all timeframes canceled
2026-07-05 20:12:58.172 - debug: semp.0 (29126) Keba KeContact P30X: disconnect - timer fired
2026-07-05 20:12:58.172 - debug: semp.0 (29126) Keba KeContact P30X: no switch configured
2026-07-05 20:12:58.172 - debug: semp.0 (29126) Keba KeContact P30X: new recommendation power 0 number
2026-07-05 20:12:58.173 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-05 20:12:58.177 - debug: semp.0 (29126) Keba KeContact P30X: set new charge power 0 number
2026-07-05 20:12:58.179 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:12:58.179 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:12:58.184 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:12:58.184 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:12:58.186 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:12:58.186 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:12:58.186 - debug: semp.0 (29126) Keba KeContact P30X: subscribe OID_IsCharging 0_userdata.0.Stromversorgung.Wallbox-Plug
2026-07-05 20:12:58.189 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-05 20:12:58.189 - debug: semp.0 (29126) Keba KeContact P30X: wallbox charging false
2026-07-05 20:12:58.191 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:12:58.191 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:12:58.191 - debug: semp.0 (29126) Keba KeContact P30X: subscribe OID_IsError kecontact.0.error1
2026-07-05 20:12:58.193 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-05 20:12:58.194 - debug: semp.0 (29126) Keba KeContact P30X: wallbox error true
2026-07-05 20:12:58.195 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:12:58.195 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:12:58.196 - debug: semp.0 (29126) Keba KeContact P30X: subscribe OID_Counter 0_userdata.0.Stromversorgung.Wallbox-PowerW
2026-07-05 20:12:58.197 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-05 20:12:58.198 - debug: semp.0 (29126) planning request: got energy used 0
2026-07-05 20:12:58.201 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
2026-07-05 20:12:58.202 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-05 20:12:58.202 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-05 20:12:58.203 - debug: semp.0 (29126) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MinEnergy
2026-07-05 20:12:58.203 - debug: semp.0 (29126) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MaxEnergy
2026-07-05 20:12:58.207 - debug: semp.0 (29126) planning request: planningrequest set minEnergy 0
2026-07-05 20:12:58.209 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:12:58.209 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:12:58.209 - debug: semp.0 (29126) Gateway: set device
2026-07-05 20:12:58.210 - debug: semp.0 (29126) UpdateData
2026-07-05 20:12:58.210 - debug: semp.0 (29126) device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}
2026-07-05 20:12:58.210 - debug: semp.0 (29126) result [{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}]
2026-07-05 20:12:59.150 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-05 20:12:59.152 - debug: semp.0 (29126) Keba KeContact P30X: wallbox error true
2026-07-05 20:12:59.158 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:12:59.159 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:12:59.164 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-05 20:12:59.164 - info: semp.0 (29126) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-05 20:12:59.164 - debug: semp.0 (29126) planning request: Planningrequest all timeframes canceled
2026-07-05 20:12:59.165 - debug: semp.0 (29126) Keba KeContact P30X: disconnect - timer fired
2026-07-05 20:12:59.165 - debug: semp.0 (29126) Keba KeContact P30X: no switch configured
2026-07-05 20:12:59.165 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-05 20:12:59.165 - debug: semp.0 (29126) Keba KeContact P30X: wallbox charging false
2026-07-05 20:12:59.166 - debug: semp.0 (29126) Keba KeContact P30X: new recommendation power 0 number
2026-07-05 20:12:59.166 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-05 20:12:59.170 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:12:59.170 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:12:59.171 - debug: semp.0 (29126) Keba KeContact P30X: set new charge power 0 number
2026-07-05 20:12:59.173 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-05 20:12:59.173 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275178198 = 0Wh
2026-07-05 20:12:59.173 - debug: semp.0 (29126) planning request: got energy used 0
2026-07-05 20:12:59.179 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-05 20:12:59.179 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275179173 = 0Wh
2026-07-05 20:12:59.179 - debug: semp.0 (29126) planning request: got energy used 0
2026-07-05 20:12:59.186 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:12:59.186 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:12:59.190 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
2026-07-05 20:12:59.191 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-05 20:12:59.191 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-05 20:12:59.192 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
2026-07-05 20:12:59.193 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-05 20:12:59.193 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-05 20:12:59.200 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:12:59.200 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:12:59.203 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:12:59.203 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:01.135 - debug: semp.0 (29126) SempServer: SHM requested description
2026-07-05 20:13:01.135 - info: semp.0 (29126) SempServer: adapter discovered by SHM
2026-07-05 20:13:01.176 - debug: semp.0 (29126) SempServer: SHM requested description
2026-07-05 20:13:01.192 - debug: semp.0 (29126) SempServer: SHM requested description
2026-07-05 20:13:14.142 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-05 20:13:14.143 - debug: semp.0 (29126) Keba KeContact P30X: wallbox error true
2026-07-05 20:13:14.145 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:14.146 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:14.150 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-05 20:13:14.150 - info: semp.0 (29126) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-05 20:13:14.151 - debug: semp.0 (29126) planning request: Planningrequest all timeframes canceled
2026-07-05 20:13:14.151 - debug: semp.0 (29126) Keba KeContact P30X: disconnect - timer fired
2026-07-05 20:13:14.151 - debug: semp.0 (29126) Keba KeContact P30X: no switch configured
2026-07-05 20:13:14.151 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-05 20:13:14.151 - debug: semp.0 (29126) Keba KeContact P30X: wallbox charging false
2026-07-05 20:13:14.152 - debug: semp.0 (29126) Keba KeContact P30X: new recommendation power 0 number
2026-07-05 20:13:14.152 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-05 20:13:14.164 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:14.164 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:14.166 - debug: semp.0 (29126) Keba KeContact P30X: set new charge power 0 number
2026-07-05 20:13:14.168 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-05 20:13:14.168 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275179179 = 0Wh
2026-07-05 20:13:14.168 - debug: semp.0 (29126) planning request: got energy used 0
2026-07-05 20:13:14.169 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-05 20:13:14.169 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275194168 = 0Wh
2026-07-05 20:13:14.169 - debug: semp.0 (29126) planning request: got energy used 0
2026-07-05 20:13:14.178 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:14.178 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:14.185 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
2026-07-05 20:13:14.185 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-05 20:13:14.186 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-05 20:13:14.186 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
2026-07-05 20:13:14.186 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-05 20:13:14.189 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:14.189 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:14.191 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:14.191 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:18.127 - debug: semp.0 (29126) SempServer: SHM requested description
2026-07-05 20:13:18.147 - debug: semp.0 (29126) SempServer: SHM requested description
2026-07-05 20:13:18.165 - debug: semp.0 (29126) SempServer: SHM requested description
2026-07-05 20:13:29.141 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-05 20:13:29.141 - debug: semp.0 (29126) Keba KeContact P30X: wallbox error true
2026-07-05 20:13:29.144 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:29.144 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:29.147 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-05 20:13:29.148 - info: semp.0 (29126) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-05 20:13:29.148 - debug: semp.0 (29126) planning request: Planningrequest all timeframes canceled
2026-07-05 20:13:29.148 - debug: semp.0 (29126) Keba KeContact P30X: disconnect - timer fired
2026-07-05 20:13:29.148 - debug: semp.0 (29126) Keba KeContact P30X: no switch configured
2026-07-05 20:13:29.148 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-05 20:13:29.149 - debug: semp.0 (29126) Keba KeContact P30X: wallbox charging false
2026-07-05 20:13:29.152 - debug: semp.0 (29126) Keba KeContact P30X: new recommendation power 0 number
2026-07-05 20:13:29.152 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-05 20:13:29.160 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:29.161 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:29.165 - debug: semp.0 (29126) Keba KeContact P30X: set new charge power 0 number
2026-07-05 20:13:29.167 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-05 20:13:29.167 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275194169 = 0Wh
2026-07-05 20:13:29.168 - debug: semp.0 (29126) planning request: got energy used 0
2026-07-05 20:13:29.168 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-05 20:13:29.168 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275209167 = 0Wh
2026-07-05 20:13:29.173 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:29.173 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:29.177 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
2026-07-05 20:13:29.178 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-05 20:13:29.178 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-05 20:13:29.179 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
2026-07-05 20:13:29.180 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-05 20:13:29.180 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-05 20:13:29.185 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:29.186 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:29.188 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:29.188 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:38.148 - debug: semp.0 (29126) SempServer: SHM requested description
2026-07-05 20:13:38.164 - debug: semp.0 (29126) SempServer: SHM requested description
2026-07-05 20:13:38.182 - debug: semp.0 (29126) SempServer: SHM requested description
2026-07-05 20:13:44.148 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-05 20:13:44.148 - debug: semp.0 (29126) Keba KeContact P30X: wallbox error true
2026-07-05 20:13:44.152 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:44.153 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:44.154 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-05 20:13:44.154 - info: semp.0 (29126) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-05 20:13:44.154 - debug: semp.0 (29126) planning request: Planningrequest all timeframes canceled
2026-07-05 20:13:44.154 - debug: semp.0 (29126) Keba KeContact P30X: disconnect - timer fired
2026-07-05 20:13:44.155 - debug: semp.0 (29126) Keba KeContact P30X: no switch configured
2026-07-05 20:13:44.155 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-05 20:13:44.155 - debug: semp.0 (29126) Keba KeContact P30X: wallbox charging false
2026-07-05 20:13:44.155 - debug: semp.0 (29126) Keba KeContact P30X: new recommendation power 0 number
2026-07-05 20:13:44.155 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-05 20:13:44.162 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:44.162 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:44.163 - debug: semp.0 (29126) Keba KeContact P30X: set new charge power 0 number
2026-07-05 20:13:44.164 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-05 20:13:44.165 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275209168 = 0Wh
2026-07-05 20:13:44.165 - debug: semp.0 (29126) planning request: got energy used 0
2026-07-05 20:13:44.166 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-05 20:13:44.166 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275224165 = 0Wh
2026-07-05 20:13:44.167 - debug: semp.0 (29126) planning request: got energy used 0
2026-07-05 20:13:44.181 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:44.181 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:44.184 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
2026-07-05 20:13:44.184 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-05 20:13:44.185 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-05 20:13:44.189 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
2026-07-05 20:13:44.189 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-05 20:13:44.189 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-05 20:13:44.201 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:44.203 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-05 20:13:44.207 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-05 20:13:44.207 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
@Qlink Du musst das log etwas länger laufen lassen. Der SHM fragt nur einmal pro Minute die Daten ab. Ich benötige den log-Eintrag, der mit "response xml " beginnt.
Oder alternativ kannst du das auch im browser aufrufen (wie ich oben schon mal geschrieben hatte) :Du kannst auch http://xx.xx.xx.xx:9765/semp mit xx.xx.xx.xx als deine IP des iobroker Gateways (also nicht SHM) im Browser eingeben. Dann zeigt dein Browser an, was der SHM normalerweise als XML bekommen würde ... Im Idealfall schaltest du im Browser noch auf "Seiten-Quelltext" um, dann ist es besser lesbar...
In einem anderen Fall musste man "InterruptionsAllowed" mal ein / ausschalten, damit die Daten gesendet werden...
Alles klar hier das längere log:
2026-07-06 19:48:28.212 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:48:43.214 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:48:58.213 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:49:13.211 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:49:26.498 - info: web.1 (1448) ==> Connected system.user.admin from ::ffff:192.168.30.237
2026-07-06 19:49:28.213 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:49:34.602 - info: web.1 (1448) ==> Connected system.user.admin from ::ffff:192.168.30.237
2026-07-06 19:49:43.214 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:49:58.215 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:50:04.492 - error: semp.0 (1209) SempServer: Unmatched url... /favicon.ico {}
2026-07-06 19:50:13.220 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:50:23.069 - error: semp.0 (1209) SempServer: Unmatched url... /favicon.ico {}
2026-07-06 19:50:28.216 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:50:41.119 - info: admin.0 (170) ==> Connected system.user.admin from ::ffff:192.168.30.237
2026-07-06 19:50:43.218 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:50:58.217 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:51:12.568 - info: host.iobroker stopInstance system.adapter.semp.0 (force=false, process=true)
2026-07-06 19:51:12.570 - info: semp.0 (1209) Got terminate signal TERMINATE_YOURSELF
2026-07-06 19:51:12.571 - info: host.iobroker stopInstance system.adapter.semp.0 send kill signal
2026-07-06 19:51:13.073 - info: semp.0 (1209) terminating
2026-07-06 19:51:13.074 - info: semp.0 (1209) terminating
2026-07-06 19:51:13.074 - info: semp.0 (1209) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2026-07-06 19:51:13.572 - info: host.iobroker stopInstance timeout system.adapter.semp.0 killing pid 1209
2026-07-06 19:51:13.683 - warn: host.iobroker instance system.adapter.semp.0 terminated due to SIGKILL
2026-07-06 19:51:13.685 - info: host.iobroker instance system.adapter.semp.0 terminated with code null ()
2026-07-06 19:51:17.043 - info: host.iobroker instance system.adapter.semp.0 in version "2.0.12" started with pid 24147
2026-07-06 19:51:18.051 - debug: semp.0 (24147) Redis Objects: Use Redis connection: 172.18.0.5:6379
2026-07-06 19:51:18.068 - debug: semp.0 (24147) Objects client ready ... initialize now
2026-07-06 19:51:18.069 - debug: semp.0 (24147) Objects create System PubSub Client
2026-07-06 19:51:18.070 - debug: semp.0 (24147) Objects create User PubSub Client
2026-07-06 19:51:18.265 - debug: semp.0 (24147) Objects client initialize lua scripts
2026-07-06 19:51:18.268 - debug: semp.0 (24147) Objects connected to redis: 172.18.0.5:6379
2026-07-06 19:51:18.279 - debug: semp.0 (24147) Redis States: Use Redis connection: redis:6379
2026-07-06 19:51:18.295 - debug: semp.0 (24147) States create System PubSub Client
2026-07-06 19:51:18.296 - debug: semp.0 (24147) States create User PubSub Client
2026-07-06 19:51:18.302 - debug: semp.0 (24147) States connected to redis: redis:6379
2026-07-06 19:51:18.332 - debug: semp.0 (24147) Plugin sentry Initialize Plugin (enabled=true)
2026-07-06 19:51:19.687 - info: semp.0 (24147) starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.semp, node: v22.21.0, js-controller: 7.2.2
2026-07-06 19:51:19.698 - debug: semp.0 (24147) {"IPAddress":"192.168.30.90","UUID":"F-00000000-000000000001-00","SempPort":9765,"SempName":"ioBroker Gateway","SempManufacturer":"ioBroker","DeviceBaseID":"30380000","extendedLog":false,"LogToCSV":false,"LogToCSVPath":"/home/pi/semp.csv","devices":[{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}],"deviceSelector":"F-30380000-000000000001-00"}
2026-07-06 19:51:19.698 - debug: semp.0 (24147) check BaseID 30380000 type string
2026-07-06 19:51:19.699 - debug: semp.0 (24147) BaseID: valid 8-digit number
2026-07-06 19:51:19.699 - debug: semp.0 (24147) Gateway: instance created
2026-07-06 19:51:19.699 - debug: semp.0 (24147) SSDPServer: instance created
2026-07-06 19:51:19.700 - debug: semp.0 (24147) Gateway: SSDPServer created: http://192.168.30.90:9765/description.xml F-00000000-000000000001-00
2026-07-06 19:51:19.700 - debug: semp.0 (24147) SempServer: instance created
2026-07-06 19:51:19.706 - debug: semp.0 (24147) SempServer: SEMPServer created
2026-07-06 19:51:19.706 - debug: semp.0 (24147) Gateway: gateway created...
2026-07-06 19:51:19.710 - debug: semp.0 (24147) SempServer: SEMP server listening on 9765
2026-07-06 19:51:19.724 - debug: semp.0 (24147) Gateway: SSDPServer started
2026-07-06 19:51:19.724 - debug: semp.0 (24147) Gateway: gateway started...
2026-07-06 19:51:19.724 - debug: semp.0 (24147) Started all!
2026-07-06 19:51:19.725 - debug: semp.0 (24147) add device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}
2026-07-06 19:51:19.725 - debug: semp.0 (24147) Gateway: add device F-30380000-000000000001-00
2026-07-06 19:51:19.726 - debug: semp.0 (24147) Keba KeContact P30X: instance created
2026-07-06 19:51:19.727 - debug: semp.0 (24147) planning request: instance created
2026-07-06 19:51:19.727 - debug: semp.0 (24147) planning request: planningrequest constructor {"DeviceName":"Keba KeContact P30X","DeviceType":"EVCharger","MaxEnergy":82000,"MinEnergy":8200,"MinPower":6000,"MaxPower":11000,"WallboxChargeTime":"3","DishwasherMode":false,"Type":"EVCharger","Name":"Keba KeContact P30X"}
2026-07-06 19:51:19.727 - debug: semp.0 (24147) Keba KeContact P30X: check DeviceID F-30380000-000000000001-00 type string
2026-07-06 19:51:19.727 - debug: semp.0 (24147) Keba KeContact P30X: BaseId 30380000 length 8
2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: can use optional energy: true
2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: wallbox OID configuration (1) [{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}] [{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}]
2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: wallbox OID configuration (2) {"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"}}
2026-07-06 19:51:19.729 - info: semp.0 (24147) Keba KeContact P30X: device created F-30380000-000000000001-00 Keba KeContact P30X
2026-07-06 19:51:19.766 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_PlugConnected 0_userdata.0.Stromversorgung.Wallbox-Plug
2026-07-06 19:51:19.769 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:19.769 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:51:19.770 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:51:19.771 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:51:19.776 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:51:19.777 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.778 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.785 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.786 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.787 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.787 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.788 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_IsCharging 0_userdata.0.Stromversorgung.Wallbox-Plug
2026-07-06 19:51:19.790 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:19.791 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:51:19.792 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.793 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.793 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_IsError kecontact.0.error1
2026-07-06 19:51:19.795 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:51:19.796 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:51:19.799 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.799 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.800 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_Counter 0_userdata.0.Stromversorgung.Wallbox-PowerW
2026-07-06 19:51:19.801 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:19.802 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:19.804 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MinEnergy
2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MaxEnergy
2026-07-06 19:51:19.808 - debug: semp.0 (24147) planning request: planningrequest set minEnergy 0
2026-07-06 19:51:19.809 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.810 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.810 - debug: semp.0 (24147) Gateway: set device
2026-07-06 19:51:19.810 - debug: semp.0 (24147) UpdateData
2026-07-06 19:51:19.810 - debug: semp.0 (24147) device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}
2026-07-06 19:51:19.810 - debug: semp.0 (24147) result [{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}]
2026-07-06 19:51:22.742 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:22.743 - info: semp.0 (24147) SempServer: adapter discovered by SHM
2026-07-06 19:51:22.767 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:22.782 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.179 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.222 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.240 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.257 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.330 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.356 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.373 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.390 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.404 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:28.217 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:51:28.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:51:28.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:28.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:28.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:28.222 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:51:28.223 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:28.224 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:51:28.226 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:51:28.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:51:28.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:28.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:28.233 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:28.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360279802 = 0Wh
2026-07-06 19:51:28.234 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:28.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:28.235 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360288234 = 0Wh
2026-07-06 19:51:28.235 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:28.235 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:51:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:28.251 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:28.251 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:28.258 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:28.259 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:39.730 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:39.744 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:39.760 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:43.214 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:51:43.215 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:51:43.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:43.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:43.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:43.223 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:51:43.223 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:51:43.230 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:43.230 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:43.231 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:51:43.232 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:43.232 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360288235 = 0Wh
2026-07-06 19:51:43.233 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:43.233 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:43.233 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360303232 = 0Wh
2026-07-06 19:51:43.240 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:43.240 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:43.246 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:43.247 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:43.247 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:43.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:43.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:43.252 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:43.252 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:56.780 - debug: semp.0 (24147) SempServer: SHM requested all devices. /semp/ ::ffff:192.168.30.2 http
2026-07-06 19:51:56.781 - debug: semp.0 (24147) Gateway: get all devices
2026-07-06 19:51:56.782 - debug: semp.0 (24147) planning request: Planningrequest Check2Switch {"SwitchOff":true,"restart":false}
2026-07-06 19:51:56.782 - debug: semp.0 (24147) Keba KeContact P30X: turn device off
2026-07-06 19:51:56.782 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:51:56.782 - debug: semp.0 (24147) planning request: planningrequest data []
2026-07-06 19:51:56.785 - debug: semp.0 (24147) SempServer: response xml
Keba KeContact P30X
EVCharger
20296767
Keba
11000
6000
Measurement
false
false
true
false
Off
2026-07-06 19:51:56.786 - debug: semp.0 (24147) SempServer: response sent
2026-07-06 19:51:58.215 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:51:58.215 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:51:58.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:58.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:58.221 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:51:58.221 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:51:58.226 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:58.227 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:58.230 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:51:58.232 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:58.233 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360303233 = 0Wh
2026-07-06 19:51:58.233 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:58.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:58.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360318233 = 0Wh
2026-07-06 19:51:58.234 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:58.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:58.238 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:58.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:58.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:58.255 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:58.255 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:59.730 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:59.746 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:59.761 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:13.218 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:52:13.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:52:13.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:13.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:13.225 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:13.225 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:52:13.226 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:52:13.227 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:52:13.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:52:13.233 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:13.234 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:13.237 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:52:13.238 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:13.239 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360318234 = 0Wh
2026-07-06 19:52:13.239 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:13.239 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:13.240 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360333239 = 0Wh
2026-07-06 19:52:13.240 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:13.243 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:13.244 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:13.252 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:13.254 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:13.254 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:13.260 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:13.260 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:13.263 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:13.263 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:19.731 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:19.746 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:19.762 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:23.002 - info: javascript.0 (218) script.js.Beschattung.Sonnenstandsberechnung: Sonne: Azimut: 293° / Sonne: Elevation: 9.8° / Mond: Azimut: 31° / Mond: Elevation: -32.9°
2026-07-06 19:52:27.219 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.234 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.251 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.269 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.292 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.390 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.419 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.433 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.446 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:28.217 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:52:28.217 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:52:28.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:28.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:28.230 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:28.231 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:52:28.231 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:52:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:28.240 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:52:28.245 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:28.245 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360333240 = 0Wh
2026-07-06 19:52:28.247 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:28.247 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:28.247 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360348245 = 0Wh
2026-07-06 19:52:28.248 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:28.254 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:28.254 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:28.258 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:28.259 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:28.259 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:28.269 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:28.270 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:28.271 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:28.272 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:39.729 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:39.746 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:39.759 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:43.216 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:52:43.217 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:52:43.218 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:43.218 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:43.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:43.222 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:52:43.222 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:52:43.226 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:43.227 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:43.229 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360348247 = 0Wh
2026-07-06 19:52:43.230 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360363230 = 0Wh
2026-07-06 19:52:43.231 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:52:43.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:43.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:43.239 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:43.240 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:43.240 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:43.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:43.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:43.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:43.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:56.992 - debug: semp.0 (24147) SempServer: SHM requested all devices. /semp/ ::ffff:192.168.30.2 http
2026-07-06 19:52:56.992 - debug: semp.0 (24147) Gateway: get all devices
2026-07-06 19:52:56.993 - debug: semp.0 (24147) planning request: Planningrequest Check2Switch {"SwitchOff":true,"restart":false}
2026-07-06 19:52:56.993 - debug: semp.0 (24147) Keba KeContact P30X: turn device off
2026-07-06 19:52:56.993 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:52:56.993 - debug: semp.0 (24147) planning request: planningrequest data []
2026-07-06 19:52:56.994 - debug: semp.0 (24147) SempServer: response xml
Keba KeContact P30X
EVCharger
20296767
Keba
11000
6000
Measurement
false
false
true
false
Off
2026-07-06 19:52:56.995 - debug: semp.0 (24147) SempServer: response sent
2026-07-06 19:52:58.218 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:52:58.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:52:58.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:58.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:58.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:58.226 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:52:58.226 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:52:58.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:58.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:58.233 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:52:58.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:58.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360363230 = 0Wh
2026-07-06 19:52:58.234 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:58.235 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:58.235 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360378234 = 0Wh
2026-07-06 19:52:58.235 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:58.238 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:58.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:58.241 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:58.247 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:58.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:58.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:58.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:59.725 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:59.744 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:59.761 - debug: semp.0 (24147) SempServer: SHM requested description
Und hier der Seiten Quelltext Output:
<?xml version="1.0" encoding="utf-8"?>
<Device2EM xmlns="http://www.sma.de/communication/schema/SEMP/v1">
<DeviceInfo>
<Identification>
<DeviceId>F-30380000-000000000001-00</DeviceId>
<DeviceName>Keba KeContact P30X</DeviceName>
<DeviceType>EVCharger</DeviceType>
<DeviceSerial>20296767</DeviceSerial>
<DeviceVendor>Keba</DeviceVendor>
</Identification>
<Characteristics>
<MaxPowerConsumption>11000</MaxPowerConsumption>
<MinPowerConsumption>6000</MinPowerConsumption>
</Characteristics>
<Capabilities>
<CurrentPower>
<Method>Measurement</Method>
</CurrentPower>
<Timestamps>
<AbsoluteTimestamps>false</AbsoluteTimestamps>
</Timestamps>
<Interruptions>
<InterruptionsAllowed>false</InterruptionsAllowed>
</Interruptions>
<Requests>
<OptionalEnergy>true</OptionalEnergy>
</Requests>
</Capabilities>
</DeviceInfo>
<DeviceStatus>
<EMSignalsAccepted>false</EMSignalsAccepted>
<Status>Off</Status>
<PowerConsumption>
<PowerInfo>
<AveragePower>0</AveragePower>
<Timestamp>0</Timestamp>
<AveragingInterval>60</AveragingInterval>
</PowerInfo>
</PowerConsumption>
</DeviceStatus>
</Device2EM>
Alles klar hier das längere log:
2026-07-06 19:48:28.212 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:48:43.214 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:48:58.213 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:49:13.211 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:49:26.498 - info: web.1 (1448) ==> Connected system.user.admin from ::ffff:192.168.30.237
2026-07-06 19:49:28.213 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:49:34.602 - info: web.1 (1448) ==> Connected system.user.admin from ::ffff:192.168.30.237
2026-07-06 19:49:43.214 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:49:58.215 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:50:04.492 - error: semp.0 (1209) SempServer: Unmatched url... /favicon.ico {}
2026-07-06 19:50:13.220 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:50:23.069 - error: semp.0 (1209) SempServer: Unmatched url... /favicon.ico {}
2026-07-06 19:50:28.216 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:50:41.119 - info: admin.0 (170) ==> Connected system.user.admin from ::ffff:192.168.30.237
2026-07-06 19:50:43.218 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:50:58.217 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:51:12.568 - info: host.iobroker stopInstance system.adapter.semp.0 (force=false, process=true)
2026-07-06 19:51:12.570 - info: semp.0 (1209) Got terminate signal TERMINATE_YOURSELF
2026-07-06 19:51:12.571 - info: host.iobroker stopInstance system.adapter.semp.0 send kill signal
2026-07-06 19:51:13.073 - info: semp.0 (1209) terminating
2026-07-06 19:51:13.074 - info: semp.0 (1209) terminating
2026-07-06 19:51:13.074 - info: semp.0 (1209) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2026-07-06 19:51:13.572 - info: host.iobroker stopInstance timeout system.adapter.semp.0 killing pid 1209
2026-07-06 19:51:13.683 - warn: host.iobroker instance system.adapter.semp.0 terminated due to SIGKILL
2026-07-06 19:51:13.685 - info: host.iobroker instance system.adapter.semp.0 terminated with code null ()
2026-07-06 19:51:17.043 - info: host.iobroker instance system.adapter.semp.0 in version "2.0.12" started with pid 24147
2026-07-06 19:51:18.051 - debug: semp.0 (24147) Redis Objects: Use Redis connection: 172.18.0.5:6379
2026-07-06 19:51:18.068 - debug: semp.0 (24147) Objects client ready ... initialize now
2026-07-06 19:51:18.069 - debug: semp.0 (24147) Objects create System PubSub Client
2026-07-06 19:51:18.070 - debug: semp.0 (24147) Objects create User PubSub Client
2026-07-06 19:51:18.265 - debug: semp.0 (24147) Objects client initialize lua scripts
2026-07-06 19:51:18.268 - debug: semp.0 (24147) Objects connected to redis: 172.18.0.5:6379
2026-07-06 19:51:18.279 - debug: semp.0 (24147) Redis States: Use Redis connection: redis:6379
2026-07-06 19:51:18.295 - debug: semp.0 (24147) States create System PubSub Client
2026-07-06 19:51:18.296 - debug: semp.0 (24147) States create User PubSub Client
2026-07-06 19:51:18.302 - debug: semp.0 (24147) States connected to redis: redis:6379
2026-07-06 19:51:18.332 - debug: semp.0 (24147) Plugin sentry Initialize Plugin (enabled=true)
2026-07-06 19:51:19.687 - info: semp.0 (24147) starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.semp, node: v22.21.0, js-controller: 7.2.2
2026-07-06 19:51:19.698 - debug: semp.0 (24147) {"IPAddress":"192.168.30.90","UUID":"F-00000000-000000000001-00","SempPort":9765,"SempName":"ioBroker Gateway","SempManufacturer":"ioBroker","DeviceBaseID":"30380000","extendedLog":false,"LogToCSV":false,"LogToCSVPath":"/home/pi/semp.csv","devices":[{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}],"deviceSelector":"F-30380000-000000000001-00"}
2026-07-06 19:51:19.698 - debug: semp.0 (24147) check BaseID 30380000 type string
2026-07-06 19:51:19.699 - debug: semp.0 (24147) BaseID: valid 8-digit number
2026-07-06 19:51:19.699 - debug: semp.0 (24147) Gateway: instance created
2026-07-06 19:51:19.699 - debug: semp.0 (24147) SSDPServer: instance created
2026-07-06 19:51:19.700 - debug: semp.0 (24147) Gateway: SSDPServer created: http://192.168.30.90:9765/description.xml F-00000000-000000000001-00
2026-07-06 19:51:19.700 - debug: semp.0 (24147) SempServer: instance created
2026-07-06 19:51:19.706 - debug: semp.0 (24147) SempServer: SEMPServer created
2026-07-06 19:51:19.706 - debug: semp.0 (24147) Gateway: gateway created...
2026-07-06 19:51:19.710 - debug: semp.0 (24147) SempServer: SEMP server listening on 9765
2026-07-06 19:51:19.724 - debug: semp.0 (24147) Gateway: SSDPServer started
2026-07-06 19:51:19.724 - debug: semp.0 (24147) Gateway: gateway started...
2026-07-06 19:51:19.724 - debug: semp.0 (24147) Started all!
2026-07-06 19:51:19.725 - debug: semp.0 (24147) add device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}
2026-07-06 19:51:19.725 - debug: semp.0 (24147) Gateway: add device F-30380000-000000000001-00
2026-07-06 19:51:19.726 - debug: semp.0 (24147) Keba KeContact P30X: instance created
2026-07-06 19:51:19.727 - debug: semp.0 (24147) planning request: instance created
2026-07-06 19:51:19.727 - debug: semp.0 (24147) planning request: planningrequest constructor {"DeviceName":"Keba KeContact P30X","DeviceType":"EVCharger","MaxEnergy":82000,"MinEnergy":8200,"MinPower":6000,"MaxPower":11000,"WallboxChargeTime":"3","DishwasherMode":false,"Type":"EVCharger","Name":"Keba KeContact P30X"}
2026-07-06 19:51:19.727 - debug: semp.0 (24147) Keba KeContact P30X: check DeviceID F-30380000-000000000001-00 type string
2026-07-06 19:51:19.727 - debug: semp.0 (24147) Keba KeContact P30X: BaseId 30380000 length 8
2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: can use optional energy: true
2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: wallbox OID configuration (1) [{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}] [{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}]
2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: wallbox OID configuration (2) {"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"}}
2026-07-06 19:51:19.729 - info: semp.0 (24147) Keba KeContact P30X: device created F-30380000-000000000001-00 Keba KeContact P30X
2026-07-06 19:51:19.766 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_PlugConnected 0_userdata.0.Stromversorgung.Wallbox-Plug
2026-07-06 19:51:19.769 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:19.769 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:51:19.770 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:51:19.771 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:51:19.776 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:51:19.777 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.778 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.785 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.786 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.787 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.787 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.788 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_IsCharging 0_userdata.0.Stromversorgung.Wallbox-Plug
2026-07-06 19:51:19.790 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:19.791 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:51:19.792 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.793 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.793 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_IsError kecontact.0.error1
2026-07-06 19:51:19.795 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:51:19.796 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:51:19.799 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.799 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.800 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_Counter 0_userdata.0.Stromversorgung.Wallbox-PowerW
2026-07-06 19:51:19.801 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:19.802 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:19.804 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MinEnergy
2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MaxEnergy
2026-07-06 19:51:19.808 - debug: semp.0 (24147) planning request: planningrequest set minEnergy 0
2026-07-06 19:51:19.809 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:19.810 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:19.810 - debug: semp.0 (24147) Gateway: set device
2026-07-06 19:51:19.810 - debug: semp.0 (24147) UpdateData
2026-07-06 19:51:19.810 - debug: semp.0 (24147) device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}
2026-07-06 19:51:19.810 - debug: semp.0 (24147) result [{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}]
2026-07-06 19:51:22.742 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:22.743 - info: semp.0 (24147) SempServer: adapter discovered by SHM
2026-07-06 19:51:22.767 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:22.782 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.179 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.222 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.240 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.257 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.330 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.356 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.373 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.390 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:25.404 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:28.217 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:51:28.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:51:28.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:28.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:28.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:28.222 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:51:28.223 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:28.224 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:51:28.226 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:51:28.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:51:28.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:28.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:28.233 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:28.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360279802 = 0Wh
2026-07-06 19:51:28.234 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:28.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:28.235 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360288234 = 0Wh
2026-07-06 19:51:28.235 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:28.235 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:51:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:28.251 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:28.251 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:28.258 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:28.259 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:39.730 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:39.744 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:39.760 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:43.214 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:51:43.215 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:51:43.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:43.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:43.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:43.223 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:51:43.223 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:51:43.230 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:43.230 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:43.231 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:51:43.232 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:43.232 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360288235 = 0Wh
2026-07-06 19:51:43.233 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:43.233 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:43.233 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360303232 = 0Wh
2026-07-06 19:51:43.240 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:43.240 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:43.246 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:43.247 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:43.247 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:43.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:43.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:43.252 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:43.252 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:56.780 - debug: semp.0 (24147) SempServer: SHM requested all devices. /semp/ ::ffff:192.168.30.2 http
2026-07-06 19:51:56.781 - debug: semp.0 (24147) Gateway: get all devices
2026-07-06 19:51:56.782 - debug: semp.0 (24147) planning request: Planningrequest Check2Switch {"SwitchOff":true,"restart":false}
2026-07-06 19:51:56.782 - debug: semp.0 (24147) Keba KeContact P30X: turn device off
2026-07-06 19:51:56.782 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:51:56.782 - debug: semp.0 (24147) planning request: planningrequest data []
2026-07-06 19:51:56.785 - debug: semp.0 (24147) SempServer: response xml
Keba KeContact P30X
EVCharger
20296767
Keba
11000
6000
Measurement
false
false
true
false
Off
2026-07-06 19:51:56.786 - debug: semp.0 (24147) SempServer: response sent
2026-07-06 19:51:58.215 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:51:58.215 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:51:58.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:58.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:58.221 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:51:58.221 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:51:58.226 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:58.227 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:58.230 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:51:58.232 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:58.233 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360303233 = 0Wh
2026-07-06 19:51:58.233 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:58.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:51:58.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360318233 = 0Wh
2026-07-06 19:51:58.234 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:51:58.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:58.238 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:51:58.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:58.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:58.255 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:51:58.255 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:51:59.730 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:59.746 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:51:59.761 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:13.218 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:52:13.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:52:13.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:13.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:13.225 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:13.225 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:52:13.226 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:52:13.227 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:52:13.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:52:13.233 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:13.234 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:13.237 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:52:13.238 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:13.239 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360318234 = 0Wh
2026-07-06 19:52:13.239 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:13.239 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:13.240 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360333239 = 0Wh
2026-07-06 19:52:13.240 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:13.243 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:13.244 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:13.252 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:13.254 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:13.254 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:13.260 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:13.260 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:13.263 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:13.263 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:19.731 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:19.746 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:19.762 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:23.002 - info: javascript.0 (218) script.js.Beschattung.Sonnenstandsberechnung: Sonne: Azimut: 293° / Sonne: Elevation: 9.8° / Mond: Azimut: 31° / Mond: Elevation: -32.9°
2026-07-06 19:52:27.219 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.234 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.251 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.269 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.292 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.390 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.419 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.433 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:27.446 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:28.217 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:52:28.217 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:52:28.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:28.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:28.230 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:28.231 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:52:28.231 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:52:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:28.240 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:52:28.245 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:28.245 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360333240 = 0Wh
2026-07-06 19:52:28.247 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:28.247 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:28.247 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360348245 = 0Wh
2026-07-06 19:52:28.248 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:28.254 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:28.254 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:28.258 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:28.259 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:28.259 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:28.269 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:28.270 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:28.271 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:28.272 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:39.729 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:39.746 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:39.759 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:43.216 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:52:43.217 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:52:43.218 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:43.218 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:43.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:43.222 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:52:43.222 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:52:43.226 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:43.227 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:43.229 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360348247 = 0Wh
2026-07-06 19:52:43.230 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360363230 = 0Wh
2026-07-06 19:52:43.231 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:52:43.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:43.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:43.239 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:43.240 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:43.240 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:43.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:43.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:43.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:43.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:56.992 - debug: semp.0 (24147) SempServer: SHM requested all devices. /semp/ ::ffff:192.168.30.2 http
2026-07-06 19:52:56.992 - debug: semp.0 (24147) Gateway: get all devices
2026-07-06 19:52:56.993 - debug: semp.0 (24147) planning request: Planningrequest Check2Switch {"SwitchOff":true,"restart":false}
2026-07-06 19:52:56.993 - debug: semp.0 (24147) Keba KeContact P30X: turn device off
2026-07-06 19:52:56.993 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:52:56.993 - debug: semp.0 (24147) planning request: planningrequest data []
2026-07-06 19:52:56.994 - debug: semp.0 (24147) SempServer: response xml
Keba KeContact P30X
EVCharger
20296767
Keba
11000
6000
Measurement
false
false
true
false
Off
2026-07-06 19:52:56.995 - debug: semp.0 (24147) SempServer: response sent
2026-07-06 19:52:58.218 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
2026-07-06 19:52:58.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
2026-07-06 19:52:58.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:58.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:58.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:58.226 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
2026-07-06 19:52:58.226 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
2026-07-06 19:52:58.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:58.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:58.233 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
2026-07-06 19:52:58.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:58.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360363230 = 0Wh
2026-07-06 19:52:58.234 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:58.235 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
2026-07-06 19:52:58.235 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360378234 = 0Wh
2026-07-06 19:52:58.235 - debug: semp.0 (24147) planning request: got energy used 0
2026-07-06 19:52:58.238 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:58.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:58.241 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
2026-07-06 19:52:58.247 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:58.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:58.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
2026-07-06 19:52:58.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
2026-07-06 19:52:59.725 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:59.744 - debug: semp.0 (24147) SempServer: SHM requested description
2026-07-06 19:52:59.761 - debug: semp.0 (24147) SempServer: SHM requested description
Und hier der Seiten Quelltext Output:
<?xml version="1.0" encoding="utf-8"?>
<Device2EM xmlns="http://www.sma.de/communication/schema/SEMP/v1">
<DeviceInfo>
<Identification>
<DeviceId>F-30380000-000000000001-00</DeviceId>
<DeviceName>Keba KeContact P30X</DeviceName>
<DeviceType>EVCharger</DeviceType>
<DeviceSerial>20296767</DeviceSerial>
<DeviceVendor>Keba</DeviceVendor>
</Identification>
<Characteristics>
<MaxPowerConsumption>11000</MaxPowerConsumption>
<MinPowerConsumption>6000</MinPowerConsumption>
</Characteristics>
<Capabilities>
<CurrentPower>
<Method>Measurement</Method>
</CurrentPower>
<Timestamps>
<AbsoluteTimestamps>false</AbsoluteTimestamps>
</Timestamps>
<Interruptions>
<InterruptionsAllowed>false</InterruptionsAllowed>
</Interruptions>
<Requests>
<OptionalEnergy>true</OptionalEnergy>
</Requests>
</Capabilities>
</DeviceInfo>
<DeviceStatus>
<EMSignalsAccepted>false</EMSignalsAccepted>
<Status>Off</Status>
<PowerConsumption>
<PowerInfo>
<AveragePower>0</AveragePower>
<Timestamp>0</Timestamp>
<AveragingInterval>60</AveragingInterval>
</PowerInfo>
</PowerConsumption>
</DeviceStatus>
</Device2EM>
@Qlink eigentlich sieht jetzt das xml gut aus. Ich sehe keinen offensichtlichen Fehler mehr.
Hast du schon mal versucht, das log vom SHM selbst anzuschauen?
Ich hatte das unter
https://github.com/rg-engineering/ioBroker.semp/blob/master/docu/connection_assist/connection_assist_de.md
beschrieben... -
Der findet gar keine Geräte bei mir im Netzwerk, obwohl ich den SHM vom selben Rechner aus pingen kann
@Qlink du bist per Kabel und nicht per WLAN verbunden? Hast du weitere Router oder switche zwischen deinem PC und dem SHM? Ideal ist, den PC an den switch zu verbinden, an dem auch der SHM angeschlossen ist. Jeder switch oder Router zwischen PC und SHM kann die discover-Messages im Netzwerk verwerfen, so dass sie nicht am Ziel ankommen. Ping hat nichts zu bedeuten, die discover-Messages verwenden ein anderes Protokoll...
@rene_hm auch per Kabel am selben Switch wo der SHM hängt findet der Connection Assist keine SMA Geräte, obwohl selbes Subnet. IGMP Snooping am Unifi UCG deaktiviert... Keine Ahnung was ich noch probieren kann...
@Qlink Ich hatte jetzt endlich die chance, das auch hier in einem setup auszuprobieren, wo connection_assist nichts findet. Bist du vertraut mit wireshark? Dann könnten wir es darüber analysieren.
Ein Thema bei mir war, dass ich weitere Netzwerk-Adapter verfügbar aber inaktiv hatte. Ich habe alle unter Systemsteuerung\Netzwerk und Internet\Netzwerkverbindungen deaktiviert, nur den Ethernet Adapter aktiv gelassen, wo das Netzwerkkabel angesteckt war. Damit hat connection_assist schon mal die Wechselrichter gefunden. Ich habe dann in der Firewall auf dem Windows-Laptop den Port 9522 für UDP eingehend geöffnet. Damit kam dann auch der SHM durch... -
Deine Hinweise und Tipps hätte ich nun auch alles probiert, aber leider ohne Erfolg. Egal was ich anstelle, WR + SHM lassen sich pingen, aber per Connection Assist werden sie nicht gefunden. Lässt sich ohne dem SHM Log dem Problem nicht auch anders auf die Spur kommen ?
Hallo Rene_HM, ich habe den aktuellen Adapter in Nutzung, dieser funktioniert für meine Begriffe nicht ganz zuverlässig. Ich kann aber nicht sagen ob das am Adapter, am SHM2.0 oder am enoxOS liegt. Zumindest tauchen immer wieder Karteileichen von früheren Versuchen mit der älteren Version im Portal bei der Gerätesuche auf. Den Adapter habe ich komplett neu installiert und wieder neu konfiguriert, den SHM2.0 habe ich auf Werkseinstellungen zurückgesetzt und neu eingebunden. Ich vermute es liegt am ennoxOS.
Aber nun erst einmal einige bugs, welche ich festgestellt habe:
- sobald ich ein Gerät neu erstelle, werden bei sämtlichen Objekteinträgen die Datenpunkte falsch konfiguriert. Hier scheint eine Verwechslung zwischen "type" und "name" drin zu sein. Iobroker bringt dabei folgende Warnung:
semp.0 2026-08-18 11:21:37.687 warn Object semp.0.Devices.Geschirrspueler.State is invalid: obj.type has an invalid value (current State) but has to be one of state, channel, device, enum, host, adapter, instance, meta, config, script, user, group, chart, folder, schedule, design This will throw an error up from js-controller version 7.0.0!hier die Objekteigenschaften:
{ "type": "current State", "common": { "name": "state", "role": "state", "type": "string", "unit": "", ........richtig müsste vermutlich sein:
{ "type": "state", "common": { "name": "current State", "role": "state", "type": "string", "unit": "", ........- Dann habe ich noch entdeckt, das der Punkt "Unterbrechung erlaubt" erst einmal aktiviert und dann wieder deaktiviert werden muß, damit das Protokoll richtig erstellt wird. Andernfalls ist bei der WEB-Analyse (http://<IP>:9765/semp) der Übergabewert <interruptionsallowed> LEER und nicht FALSE.
<deviceinfo> <capabilities> <interruptions> <interruptionsallowed></interruptionsallowed> </interruptions> </capabilities> </deviceinfo>ob das allerdings negative Auswirkungen hat weis ich nicht.
Prinzipiell danke ich Dir vielmals, für deine hervorragende Leistung, bei der Erstellung des Adapters. Es macht immer wieder Freude auf solche konstruktiven und hilfreichen Arbeiten zurückgreifen zu können.
Danke für dein feedback.
Bzgl. der Karteileichen: Eigentlich sollte es reichen, die alten Geräte im Portal zu löschen. Das ging jedenfalls mal, ob das aktuell noch geht, habe ich nicht probiert. Der Adapter sendet die Gerätebeschreibung an den SHM und der an's Portal. Wenn es das Gerät im Adapter nicht mehr gibt, schickt der nichts mehr. Das Portal hingegen muss sich die Geräte merken, da das Gerät ja nur temporär ausgefallen sein könnte...Das mit den Datenpunkten schaue ich mir an. Habe mir dazu ein Ticket gemacht
https://github.com/rg-engineering/ioBroker.semp/issues/494
Für das Theme mit den Unterbrechungen habe ich mir ebenfalls ein Ticket gemacht, obwohl ich das schon kenne. Ich dachte, ich hätte das schon behoben...
