  4. Adapter: SMA SEMP
    apollon77A
Adapter: SMA SEMP
264 Beiträge 30 Kommentatoren 84.8k Aufrufe 28 Beobachtet
  • Q
    Q
    Qlink
    #250
    @rene_hm
    Alles klar.
    Hab nochmal auf debug umgestellt jetzt steht schon mehr im log:
    semp.0
    2026-06-29 21:22:08.246	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:22:08.245	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:22:08.243	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:22:08.243	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:22:08.238	debug	Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
    semp.0
    2026-06-29 21:22:08.238	debug	Keba KeContact P30X: status detection time limit is 1 going to off
    semp.0
    2026-06-29 21:22:08.238	debug	Keba KeContact P30X: set status detection limit to 500
    semp.0
    2026-06-29 21:22:08.236	debug	Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
    semp.0
    2026-06-29 21:22:08.236	debug	Keba KeContact P30X: status detection time limit is 1 going to off
    semp.0
    2026-06-29 21:22:08.236	debug	Keba KeContact P30X: set status detection limit to 500
    semp.0
    2026-06-29 21:22:08.229	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:22:08.229	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:22:08.214	debug	Keba KeContact P30X: set new charge power 0 number
    semp.0
    2026-06-29 21:22:08.213	debug	planning request: got energy used 0
    semp.0
    2026-06-29 21:22:08.213	debug	Keba KeContact P30X: calc energy 0 1782760928211 = 0Wh
    semp.0
    2026-06-29 21:22:08.212	debug	Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
    semp.0
    2026-06-29 21:22:08.212	debug	planning request: got energy used 0
    semp.0
    2026-06-29 21:22:08.212	debug	Keba KeContact P30X: calc energy 0 1782760913215 = 0Wh
    semp.0
    2026-06-29 21:22:08.211	debug	Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
    semp.0
    2026-06-29 21:22:08.209	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:22:08.209	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:22:08.202	debug	Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
    semp.0
    2026-06-29 21:22:08.202	debug	Keba KeContact P30X: new recommendation power 0 number
    semp.0
    2026-06-29 21:22:08.202	debug	Keba KeContact P30X: wallbox charging false
    semp.0
    2026-06-29 21:22:08.202	debug	Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
    semp.0
    2026-06-29 21:22:08.201	debug	Keba KeContact P30X: no switch configured
    semp.0
    2026-06-29 21:22:08.201	debug	Keba KeContact P30X: disconnect - timer fired
    semp.0
    2026-06-29 21:22:08.201	debug	planning request: Planningrequest all timeframes canceled
    semp.0
    2026-06-29 21:22:08.201	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
    semp.0
    2026-06-29 21:22:08.200	debug	Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
    semp.0
    2026-06-29 21:22:08.196	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:22:08.196	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:22:08.193	debug	Keba KeContact P30X: wallbox error true
    semp.0
    2026-06-29 21:22:08.193	debug	Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
    semp.0
    2026-06-29 21:21:56.663	debug	SempServer: response sent
    semp.0
    2026-06-29 21:21:56.661	debug	SempServer: response xml <?xml version="1.0" encoding="utf-8"?> <Device2EM xmlns="http://www.sma.de/communication/schema/SEMP/v1"> <DeviceInfo> <Identification> <DeviceId>F-00000000-000000000001-00</DeviceId> <DeviceName>Keba KeContact P30X</DeviceName> <DeviceType>EVCharger</DeviceType> <DeviceSerial>20296767</DeviceSerial> <DeviceVendor>Keba</DeviceVendor> </Identification> <Characteristics> <MaxPowerConsumption>11000</MaxPowerConsumption> <MinPowerConsumption>6000</MinPowerConsumption> </Characteristics> <Capabilities> <CurrentPower> <Method>Measurement</Method> </CurrentPower> <Timestamps> <AbsoluteTimestamps>false</AbsoluteTimestamps> </Timestamps> <Interruptions> <InterruptionsAllowed>false</InterruptionsAllowed> </Interruptions> <Requests> <OptionalEnergy>true</OptionalEnergy> </Requests> </Capabilities> </DeviceInfo> <DeviceStatus> <DeviceId>F-00000000-000000000001-00</DeviceId> <EMSignalsAccepted>false</EMSignalsAccepted> <Status>Off</Status> <PowerConsumption> <PowerInfo> <AveragePower>0</AveragePower> <Timestamp>0</Timestamp> <AveragingInterval>60</AveragingInterval> </PowerInfo> </PowerConsumption> </DeviceStatus> </Device2EM>
    semp.0
    2026-06-29 21:21:56.658	debug	planning request: planningrequest data []
    semp.0
    2026-06-29 21:21:56.658	debug	Keba KeContact P30X: no switch configured
    semp.0
    2026-06-29 21:21:56.658	debug	Keba KeContact P30X: turn device off
    semp.0
    2026-06-29 21:21:56.658	debug	planning request: Planningrequest Check2Switch {"SwitchOff":true,"restart":false}
    semp.0
    2026-06-29 21:21:56.657	debug	Gateway: get all devices
    semp.0
    2026-06-29 21:21:56.656	debug	SempServer: SHM requested all devices. /semp/ ::ffff:192.168.30.2 http
    yamaha.0
    2026-06-29 21:21:55.770	info	State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string"
    yamaha.0
    2026-06-29 21:21:55.311	info	State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string"
    yamaha.0
    2026-06-29 21:21:54.687	info	State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string"
    yamaha.0
    2026-06-29 21:21:54.335	info	State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string"
    semp.0
    2026-06-29 21:21:53.233	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:53.232	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:53.231	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:53.231	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:53.227	debug	Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
    semp.0
    2026-06-29 21:21:53.226	debug	Keba KeContact P30X: status detection time limit is 1 going to off
    semp.0
    2026-06-29 21:21:53.226	debug	Keba KeContact P30X: set status detection limit to 500
    semp.0
    2026-06-29 21:21:53.225	debug	Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
    semp.0
    2026-06-29 21:21:53.225	debug	Keba KeContact P30X: status detection time limit is 1 going to off
    semp.0
    2026-06-29 21:21:53.224	debug	Keba KeContact P30X: set status detection limit to 500
    semp.0
    2026-06-29 21:21:53.219	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:53.219	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:53.215	debug	planning request: got energy used 0
    semp.0
    2026-06-29 21:21:53.215	debug	Keba KeContact P30X: calc energy 0 1782760913214 = 0Wh
    semp.0
    2026-06-29 21:21:53.215	debug	Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
    semp.0
    2026-06-29 21:21:53.214	debug	planning request: got energy used 0
    semp.0
    2026-06-29 21:21:53.214	debug	Keba KeContact P30X: calc energy 0 1782760898217 = 0Wh
    semp.0
    2026-06-29 21:21:53.214	debug	Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
    semp.0
    2026-06-29 21:21:53.211	debug	Keba KeContact P30X: set new charge power 0 number
    semp.0
    2026-06-29 21:21:53.210	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:53.210	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    yamaha.0
    2026-06-29 21:21:53.207	info	State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string"
    semp.0
    2026-06-29 21:21:53.203	debug	Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
    semp.0
    2026-06-29 21:21:53.203	debug	Keba KeContact P30X: new recommendation power 0 number
    semp.0
    2026-06-29 21:21:53.203	debug	Keba KeContact P30X: wallbox charging false
    semp.0
    2026-06-29 21:21:53.203	debug	Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
    semp.0
    2026-06-29 21:21:53.203	debug	Keba KeContact P30X: no switch configured
    semp.0
    2026-06-29 21:21:53.202	debug	Keba KeContact P30X: disconnect - timer fired
    semp.0
    2026-06-29 21:21:53.202	debug	planning request: Planningrequest all timeframes canceled
    semp.0
    2026-06-29 21:21:53.202	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
    semp.0
    2026-06-29 21:21:53.202	debug	Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
    semp.0
    2026-06-29 21:21:53.198	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:53.196	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:53.193	debug	Keba KeContact P30X: wallbox error true
    semp.0
    2026-06-29 21:21:53.192	debug	Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
    semp.0
    2026-06-29 21:21:52.984	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:52.966	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:52.949	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:52.928	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:52.879	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:52.863	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:52.823	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:52.808	debug	SempServer: SHM requested description
    yamaha.0
    2026-06-29 21:21:52.800	info	State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string"
    semp.0
    2026-06-29 21:21:52.793	debug	SempServer: SHM requested description
    yamaha.0
    2026-06-29 21:21:52.358	info	State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string"
    semp.0
    2026-06-29 21:21:52.169	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:52.120	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:52.103	debug	SempServer: SHM requested description
    yamaha.0
    2026-06-29 21:21:51.986	info	State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string"
    yamaha.0
    2026-06-29 21:21:51.650	info	State value to set for "yamaha.0.Realtime.MAIN.VOL" has to be type "number" but received type "string"
    semp.0
    2026-06-29 21:21:38.238	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:38.238	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:38.235	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:38.235	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:38.231	debug	Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
    semp.0
    2026-06-29 21:21:38.231	debug	Keba KeContact P30X: status detection time limit is 1 going to off
    semp.0
    2026-06-29 21:21:38.230	debug	Keba KeContact P30X: set status detection limit to 500
    semp.0
    2026-06-29 21:21:38.229	debug	Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
    semp.0
    2026-06-29 21:21:38.228	debug	Keba KeContact P30X: status detection time limit is 1 going to off
    semp.0
    2026-06-29 21:21:38.228	debug	Keba KeContact P30X: set status detection limit to 500
    semp.0
    2026-06-29 21:21:38.223	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:38.223	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:38.218	debug	planning request: got energy used 0
    semp.0
    2026-06-29 21:21:38.217	debug	Keba KeContact P30X: calc energy 0 1782760898215 = 0Wh
    semp.0
    2026-06-29 21:21:38.217	debug	Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
    semp.0
    2026-06-29 21:21:38.217	debug	planning request: got energy used 0
    semp.0
    2026-06-29 21:21:38.215	debug	Keba KeContact P30X: calc energy 0 1782760892188 = 0Wh
    semp.0
    2026-06-29 21:21:38.214	debug	Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
    semp.0
    2026-06-29 21:21:38.212	debug	Keba KeContact P30X: set new charge power 0 number
    semp.0
    2026-06-29 21:21:38.209	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:38.209	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:38.204	debug	Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
    semp.0
    2026-06-29 21:21:38.203	debug	Keba KeContact P30X: new recommendation power 0 number
    semp.0
    2026-06-29 21:21:38.203	debug	Keba KeContact P30X: wallbox charging false
    semp.0
    2026-06-29 21:21:38.202	debug	Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
    semp.0
    2026-06-29 21:21:38.202	debug	Keba KeContact P30X: no switch configured
    semp.0
    2026-06-29 21:21:38.201	debug	Keba KeContact P30X: disconnect - timer fired
    semp.0
    2026-06-29 21:21:38.201	debug	planning request: Planningrequest all timeframes canceled
    semp.0
    2026-06-29 21:21:38.201	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
    semp.0
    2026-06-29 21:21:38.200	debug	Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
    semp.0
    2026-06-29 21:21:38.198	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:38.197	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:38.194	debug	Keba KeContact P30X: wallbox error true
    semp.0
    2026-06-29 21:21:38.193	debug	Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
    semp.0
    2026-06-29 21:21:35.197	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:35.181	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:35.126	info	SempServer: adapter discovered by SHM
    semp.0
    2026-06-29 21:21:35.126	debug	SempServer: SHM requested description
    semp.0
    2026-06-29 21:21:32.204	debug	result [{"ID":"F-00000000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}]
    semp.0
    2026-06-29 21:21:32.203	debug	device {"ID":"F-00000000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}
    semp.0
    2026-06-29 21:21:32.203	debug	UpdateData
    semp.0
    2026-06-29 21:21:32.203	debug	Gateway: set device
    semp.0
    2026-06-29 21:21:32.203	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:32.202	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:32.200	debug	planning request: planningrequest set minEnergy 0
    semp.0
    2026-06-29 21:21:32.195	debug	Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MaxEnergy
    semp.0
    2026-06-29 21:21:32.193	debug	Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MinEnergy
    semp.0
    2026-06-29 21:21:32.193	debug	Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
    semp.0
    2026-06-29 21:21:32.192	debug	Keba KeContact P30X: status detection time limit is 1 going to off
    semp.0
    2026-06-29 21:21:32.192	debug	Keba KeContact P30X: set status detection limit to 500
    semp.0
    2026-06-29 21:21:32.189	debug	planning request: got energy used 0
    semp.0
    2026-06-29 21:21:32.188	debug	Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
    semp.0
    2026-06-29 21:21:32.185	debug	Keba KeContact P30X: subscribe OID_Counter 0_userdata.0.Stromversorgung.Wallbox-PowerW
    semp.0
    2026-06-29 21:21:32.185	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:32.184	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:32.182	debug	Keba KeContact P30X: wallbox error true
    semp.0
    2026-06-29 21:21:32.182	debug	Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
    semp.0
    2026-06-29 21:21:32.179	debug	Keba KeContact P30X: subscribe OID_IsError kecontact.0.error1
    semp.0
    2026-06-29 21:21:32.179	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:32.179	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:32.177	debug	Keba KeContact P30X: wallbox charging false
    semp.0
    2026-06-29 21:21:32.176	debug	Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
    semp.0
    2026-06-29 21:21:32.174	debug	Keba KeContact P30X: subscribe OID_IsCharging 0_userdata.0.Stromversorgung.Wallbox-Plug
    semp.0
    2026-06-29 21:21:32.174	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:32.173	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:32.171	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:32.171	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:32.166	debug	Keba KeContact P30X: in SetState, no new state to set, is plug not connected
    semp.0
    2026-06-29 21:21:32.165	debug	Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1782738442633,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1782738442633} from Devices.Keba KeContact P30X.State
    semp.0
    2026-06-29 21:21:32.164	debug	Keba KeContact P30X: set new charge power 0 number
    semp.0
    2026-06-29 21:21:32.158	debug	Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
    semp.0
    2026-06-29 21:21:32.158	debug	Keba KeContact P30X: new recommendation power 0 number
    semp.0
    2026-06-29 21:21:32.157	debug	Keba KeContact P30X: no switch configured
    semp.0
    2026-06-29 21:21:32.157	debug	Keba KeContact P30X: disconnect - timer fired
    semp.0
    2026-06-29 21:21:32.157	debug	planning request: Planningrequest all timeframes canceled
    semp.0
    2026-06-29 21:21:32.156	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
    semp.0
    2026-06-29 21:21:32.156	debug	Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
    semp.0
    2026-06-29 21:21:32.151	debug	Keba KeContact P30X: subscribe OID_PlugConnected 0_userdata.0.Stromversorgung.Wallbox-Plug
    semp.0
    2026-06-29 21:21:32.106	info	Keba KeContact P30X: device created F-00000000-000000000001-00 Keba KeContact P30X
    semp.0
    2026-06-29 21:21:32.105	debug	Keba KeContact P30X: wallbox OID configuration (2) {"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"}}
    semp.0
    2026-06-29 21:21:32.105	debug	Keba KeContact P30X: wallbox OID configuration (1) [{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}] [{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}]
    semp.0
    2026-06-29 21:21:32.105	debug	Keba KeContact P30X: can use optional energy: true
    semp.0
    2026-06-29 21:21:32.105	debug	Keba KeContact P30X: BaseId 00000000 length 8
    semp.0
    2026-06-29 21:21:32.104	debug	Keba KeContact P30X: check DeviceID F-00000000-000000000001-00 type string
    semp.0
    2026-06-29 21:21:32.104	debug	planning request: planningrequest constructor {"DeviceName":"Keba KeContact P30X","DeviceType":"EVCharger","MaxEnergy":82000,"MinEnergy":8200,"MinPower":6000,"MaxPower":11000,"WallboxChargeTime":"3","DishwasherMode":false,"Type":"EVCharger","Name":"Keba KeContact P30X"}
    semp.0
    2026-06-29 21:21:32.104	debug	planning request: instance created
    semp.0
    2026-06-29 21:21:32.103	debug	Keba KeContact P30X: instance created
    semp.0
    2026-06-29 21:21:32.102	debug	Gateway: add device F-00000000-000000000001-00
    semp.0
    2026-06-29 21:21:32.102	debug	add device {"ID":"F-00000000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}
    semp.0
    2026-06-29 21:21:32.101	debug	Started all!
    semp.0
    2026-06-29 21:21:32.101	debug	Gateway: gateway started...
    semp.0
    2026-06-29 21:21:32.100	debug	Gateway: SSDPServer started
    semp.0
    2026-06-29 21:21:32.086	debug	SempServer: SEMP server listening on 9765
    semp.0
    2026-06-29 21:21:32.083	debug	Gateway: gateway created...
    semp.0
    2026-06-29 21:21:32.083	debug	SempServer: SEMPServer created
    semp.0
    2026-06-29 21:21:32.076	debug	SempServer: instance created
    semp.0
    2026-06-29 21:21:32.076	debug	Gateway: SSDPServer created: http://192.168.30.90:9765/description.xml F-00000000-000000000001-00
    semp.0
    2026-06-29 21:21:32.075	debug	SSDPServer: instance created
    semp.0
    2026-06-29 21:21:32.075	debug	Gateway: instance created
    semp.0
    2026-06-29 21:21:32.075	debug	BaseID: valid 8-digit number
    semp.0
    2026-06-29 21:21:32.074	debug	check BaseID 30380000 type string
    semp.0
    semp.0
    2026-06-29 21:21:32.074	debug	{"IPAddress":"192.168.30.90","UUID":"F-00000000-000000000001-00","SempPort":9765,"SempName":"ioBroker Gateway","SempManufacturer":"ioBroker","DeviceBaseID":"30380000","extendedLog":false,"LogToCSV":false,"LogToCSVPath":"/home/pi/semp.csv","devices":[{"ID":"F-00000000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}],"deviceSelector":"F-00000000-000000000001-00"}
    semp.0
    2026-06-29 21:21:32.063	info	starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.semp, node: v22.21.0, js-controller: 7.2.2
    semp.0
    2026-06-29 21:21:30.701	debug	Plugin sentry Initialize Plugin (enabled=true)
    semp.0
    2026-06-29 21:21:30.662	debug	States connected to redis: redis:6379
    semp.0
    2026-06-29 21:21:30.656	debug	States create User PubSub Client
    semp.0
    2026-06-29 21:21:30.655	debug	States create System PubSub Client
    semp.0
    2026-06-29 21:21:30.643	debug	Redis States: Use Redis connection: redis:6379
    semp.0
    2026-06-29 21:21:30.633	debug	Objects connected to redis: 172.18.0.5:6379
    semp.0
    2026-06-29 21:21:30.629	debug	Objects client initialize lua scripts
    semp.0
    2026-06-29 21:21:30.460	debug	Objects create User PubSub Client
    semp.0
    2026-06-29 21:21:30.459	debug	Objects create System PubSub Client
    semp.0
    2026-06-29 21:21:30.457	debug	Objects client ready ... initialize now
    semp.0
    2026-06-29 21:21:30.440	debug	Redis Objects: Use Redis connection: 172.18.0.5:6379
    und hier noch der output von der URL:
    F-00000000-000000000001-00 Keba KeContact P30X EVCharger 20296767 Keba 11000 6000 Measurement false false true F-00000000-000000000001-00 false Off 0 0 60
    Rene_HMR 1 Antwort Letzte Antwort
    • Q Qlink
      @rene_hm
      Alles klar.
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      yamaha.0
      yamaha.0
      yamaha.0
      yamaha.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      yamaha.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      yamaha.0
      semp.0
      yamaha.0
      semp.0
      semp.0
      semp.0
      yamaha.0
      yamaha.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      semp.0
      Rene_HMR
      Rene_HMR
      Rene_HM
      #251
      @Qlink Ich denke, mit der DeviceID = F-00000000-000000000001-00 wird das nicht funktionieren. Mindestens der erste Block nach dem F- sollte mit einer BaseID gefüllt werden (entweder mit der vom Adapter angezeigten oder einer eigenen) Die DeviceID muss bei SMA unique sein...
      • Q
        Q
        Qlink
        #252
        @rene_hm
        ich hab die DeviceID nun angepasst, hat aber leider am Verhalten nichts geändert:
        semp.0
        2026-07-02 15:12:05.273	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true
        semp.0
        2026-07-02 15:11:56.482	info	State value to set for "semp.0.Devices.Keba KeContact P30X.TimeFrames.1.RemainingMaxEnergy" has to be type "number" but received type "string"
        semp.0
        2026-07-02 15:11:50.272	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true
        admin.0
        2026-07-02 15:11:36.281	info	==> Connected system.user.admin from ::ffff:192.168.30.57
        semp.0
        2026-07-02 15:11:35.300	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true
        semp.0
        2026-07-02 15:11:20.268	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true
        semp.0
        2026-07-02 15:11:05.268	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true
        semp.0
        2026-07-02 15:10:56.297	info	State value to set for "semp.0.Devices.Keba KeContact P30X.TimeFrames.1.RemainingMaxEnergy" has to be type "number" but received type "string"
        semp.0
        2026-07-02 15:10:50.270	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true
        semp.0
        2026-07-02 15:10:35.271	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true
        semp.0
        2026-07-02 15:10:20.271	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true
        semp.0
        2026-07-02 15:10:16.693	info	SempServer: adapter discovered by SHM
        semp.0
        2026-07-02 15:10:13.718	info	Keba KeContact P30X: Keba KeContact P30X wallbox plug connected true
        semp.0
        2026-07-02 15:10:13.670	info	Keba KeContact P30X: device created F-30380000-000000000001-00 Keba KeContact P30X
        semp.0
        2026-07-02 15:10:13.623	info	starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.semp, node: v22.21.0, js-controller: 7.2.2
        • Q Qlink
          @rene_hm
          semp.0
          semp.0
          semp.0
          admin.0
          semp.0
          semp.0
          semp.0
          semp.0
          semp.0
          semp.0
          semp.0
          semp.0
          semp.0
          semp.0
          semp.0
          Rene_HMR
          Rene_HMR
          Rene_HM
          #253
          @Qlink sagte:
          ja und gleichzeitig wieder debug abgeschaltet...
          schon mal die logs auf dem SHM selbst angeschaut?
          https://github.com/rg-engineering/ioBroker.semp/blob/master/docu/connection_assist/connection_assist_de.md
          • Q
            Q
            Qlink
            #254
            @rene_hm
            Hier nochmal der Log Output mit debug aktiviert:
            2026-07-05 20:11:29.145 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
            2026-07-05 20:11:44.148 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
            2026-07-05 20:11:59.149 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
            2026-07-05 20:12:14.147 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
            2026-07-05 20:12:23.004 - info: javascript.0 (568) script.js.Beschattung.Sonnenstandsberechnung: Sonne: Azimut: 297° / Sonne: Elevation: 6.9° / Mond: Azimut: 51° / Mond: Elevation: -31.6°
            2026-07-05 20:12:29.147 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
            2026-07-05 20:12:44.149 - info: semp.0 (9778) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
            2026-07-05 20:12:48.182 - info: web.1 (1782) <== Disconnect system.user.admin from ::ffff:192.168.30.237
            2026-07-05 20:12:49.178 - info: web.1 (1782) ==> Connected system.user.admin from ::ffff:192.168.30.237
            2026-07-05 20:12:51.288 - info: host.iobroker stopInstance system.adapter.semp.0 (force=false, process=true)
            2026-07-05 20:12:51.293 - info: host.iobroker stopInstance system.adapter.semp.0 send kill signal
            2026-07-05 20:12:51.293 - info: semp.0 (9778) Got terminate signal TERMINATE_YOURSELF
            2026-07-05 20:12:51.297 - info: semp.0 (9778) terminating
            2026-07-05 20:12:51.299 - info: semp.0 (9778) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2026-07-05 20:12:51.795 - info: semp.0 (9778) terminating
            2026-07-05 20:12:51.796 - info: semp.0 (9778) terminating
            2026-07-05 20:12:51.974 - info: host.iobroker instance system.adapter.semp.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2026-07-05 20:12:55.239 - info: host.iobroker instance system.adapter.semp.0 in version "2.0.12" started with pid 29126
            2026-07-05 20:12:56.272 - debug: semp.0 (29126) Redis Objects: Use Redis connection: 172.18.0.5:6379
            2026-07-05 20:12:56.290 - debug: semp.0 (29126) Objects client ready ... initialize now
            2026-07-05 20:12:56.291 - debug: semp.0 (29126) Objects create System PubSub Client
            2026-07-05 20:12:56.292 - debug: semp.0 (29126) Objects create User PubSub Client
            2026-07-05 20:12:56.466 - debug: semp.0 (29126) Objects client initialize lua scripts
            2026-07-05 20:12:56.470 - debug: semp.0 (29126) Objects connected to redis: 172.18.0.5:6379
            2026-07-05 20:12:56.480 - debug: semp.0 (29126) Redis States: Use Redis connection: redis:6379
            2026-07-05 20:12:56.494 - debug: semp.0 (29126) States create System PubSub Client
            2026-07-05 20:12:56.495 - debug: semp.0 (29126) States create User PubSub Client
            2026-07-05 20:12:56.501 - debug: semp.0 (29126) States connected to redis: redis:6379
            2026-07-05 20:12:56.547 - debug: semp.0 (29126) Plugin sentry Initialize Plugin (enabled=true)
            2026-07-05 20:12:58.081 - info: semp.0 (29126) starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.semp, node: v22.21.0, js-controller: 7.2.2
            2026-07-05 20:12:58.093 - debug: semp.0 (29126) {"IPAddress":"192.168.30.90","UUID":"F-00000000-000000000001-00","SempPort":9765,"SempName":"ioBroker Gateway","SempManufacturer":"ioBroker","DeviceBaseID":"30380000","extendedLog":false,"LogToCSV":false,"LogToCSVPath":"/home/pi/semp.csv","devices":[{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}],"deviceSelector":"F-30380000-000000000001-00"}
            2026-07-05 20:12:58.093 - debug: semp.0 (29126) check BaseID 30380000 type string
            2026-07-05 20:12:58.093 - debug: semp.0 (29126) BaseID: valid 8-digit number
            2026-07-05 20:12:58.093 - debug: semp.0 (29126) Gateway: instance created
            2026-07-05 20:12:58.094 - debug: semp.0 (29126) SSDPServer: instance created
            2026-07-05 20:12:58.095 - debug: semp.0 (29126) Gateway: SSDPServer created: http://192.168.30.90:9765/description.xml F-00000000-000000000001-00
            2026-07-05 20:12:58.095 - debug: semp.0 (29126) SempServer: instance created
            2026-07-05 20:12:58.100 - debug: semp.0 (29126) SempServer: SEMPServer created
            2026-07-05 20:12:58.100 - debug: semp.0 (29126) Gateway: gateway created...
            2026-07-05 20:12:58.104 - debug: semp.0 (29126) SempServer: SEMP server listening on 9765
            2026-07-05 20:12:58.118 - debug: semp.0 (29126) Gateway: SSDPServer started
            2026-07-05 20:12:58.118 - debug: semp.0 (29126) Gateway: gateway started...
            2026-07-05 20:12:58.119 - debug: semp.0 (29126) Started all!
            2026-07-05 20:12:58.119 - debug: semp.0 (29126) add device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}
            2026-07-05 20:12:58.119 - debug: semp.0 (29126) Gateway: add device F-30380000-000000000001-00
            2026-07-05 20:12:58.120 - debug: semp.0 (29126) Keba KeContact P30X: instance created
            2026-07-05 20:12:58.121 - debug: semp.0 (29126) planning request: instance created
            2026-07-05 20:12:58.121 - debug: semp.0 (29126) planning request: planningrequest constructor {"DeviceName":"Keba KeContact P30X","DeviceType":"EVCharger","MaxEnergy":82000,"MinEnergy":8200,"MinPower":6000,"MaxPower":11000,"WallboxChargeTime":"3","DishwasherMode":false,"Type":"EVCharger","Name":"Keba KeContact P30X"}
            2026-07-05 20:12:58.121 - debug: semp.0 (29126) Keba KeContact P30X: check DeviceID F-30380000-000000000001-00 type string
            2026-07-05 20:12:58.121 - debug: semp.0 (29126) Keba KeContact P30X: BaseId 30380000 length 8
            2026-07-05 20:12:58.121 - debug: semp.0 (29126) Keba KeContact P30X: can use optional energy: true
            2026-07-05 20:12:58.121 - debug: semp.0 (29126) Keba KeContact P30X: wallbox OID configuration (1) [{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}] [{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}]
            2026-07-05 20:12:58.122 - debug: semp.0 (29126) Keba KeContact P30X: wallbox OID configuration (2) {"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"}}
            2026-07-05 20:12:58.122 - info: semp.0 (29126) Keba KeContact P30X: device created F-30380000-000000000001-00 Keba KeContact P30X
            2026-07-05 20:12:58.167 - debug: semp.0 (29126) Keba KeContact P30X: subscribe OID_PlugConnected 0_userdata.0.Stromversorgung.Wallbox-Plug
            2026-07-05 20:12:58.171 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
            2026-07-05 20:12:58.171 - info: semp.0 (29126) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
            2026-07-05 20:12:58.172 - debug: semp.0 (29126) planning request: Planningrequest all timeframes canceled
            2026-07-05 20:12:58.172 - debug: semp.0 (29126) Keba KeContact P30X: disconnect - timer fired
            2026-07-05 20:12:58.172 - debug: semp.0 (29126) Keba KeContact P30X: no switch configured
            2026-07-05 20:12:58.172 - debug: semp.0 (29126) Keba KeContact P30X: new recommendation power 0 number
            2026-07-05 20:12:58.173 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
            2026-07-05 20:12:58.177 - debug: semp.0 (29126) Keba KeContact P30X: set new charge power 0 number
            2026-07-05 20:12:58.179 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:12:58.179 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:12:58.184 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:12:58.184 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:12:58.186 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:12:58.186 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:12:58.186 - debug: semp.0 (29126) Keba KeContact P30X: subscribe OID_IsCharging 0_userdata.0.Stromversorgung.Wallbox-Plug
            2026-07-05 20:12:58.189 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
            2026-07-05 20:12:58.189 - debug: semp.0 (29126) Keba KeContact P30X: wallbox charging false
            2026-07-05 20:12:58.191 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:12:58.191 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:12:58.191 - debug: semp.0 (29126) Keba KeContact P30X: subscribe OID_IsError kecontact.0.error1
            2026-07-05 20:12:58.193 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
            2026-07-05 20:12:58.194 - debug: semp.0 (29126) Keba KeContact P30X: wallbox error true
            2026-07-05 20:12:58.195 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:12:58.195 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:12:58.196 - debug: semp.0 (29126) Keba KeContact P30X: subscribe OID_Counter 0_userdata.0.Stromversorgung.Wallbox-PowerW
            2026-07-05 20:12:58.197 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
            2026-07-05 20:12:58.198 - debug: semp.0 (29126) planning request: got energy used 0
            2026-07-05 20:12:58.201 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
            2026-07-05 20:12:58.202 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
            2026-07-05 20:12:58.202 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
            2026-07-05 20:12:58.203 - debug: semp.0 (29126) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MinEnergy
            2026-07-05 20:12:58.203 - debug: semp.0 (29126) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MaxEnergy
            2026-07-05 20:12:58.207 - debug: semp.0 (29126) planning request: planningrequest set minEnergy 0
            2026-07-05 20:12:58.209 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:12:58.209 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:12:58.209 - debug: semp.0 (29126) Gateway: set device
            2026-07-05 20:12:58.210 - debug: semp.0 (29126) UpdateData
            2026-07-05 20:12:58.210 - debug: semp.0 (29126) device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}
            2026-07-05 20:12:58.210 - debug: semp.0 (29126) result [{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}]
            2026-07-05 20:12:59.150 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
            2026-07-05 20:12:59.152 - debug: semp.0 (29126) Keba KeContact P30X: wallbox error true
            2026-07-05 20:12:59.158 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:12:59.159 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:12:59.164 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
            2026-07-05 20:12:59.164 - info: semp.0 (29126) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
            2026-07-05 20:12:59.164 - debug: semp.0 (29126) planning request: Planningrequest all timeframes canceled
            2026-07-05 20:12:59.165 - debug: semp.0 (29126) Keba KeContact P30X: disconnect - timer fired
            2026-07-05 20:12:59.165 - debug: semp.0 (29126) Keba KeContact P30X: no switch configured
            2026-07-05 20:12:59.165 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
            2026-07-05 20:12:59.165 - debug: semp.0 (29126) Keba KeContact P30X: wallbox charging false
            2026-07-05 20:12:59.166 - debug: semp.0 (29126) Keba KeContact P30X: new recommendation power 0 number
            2026-07-05 20:12:59.166 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
            2026-07-05 20:12:59.170 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:12:59.170 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:12:59.171 - debug: semp.0 (29126) Keba KeContact P30X: set new charge power 0 number
            2026-07-05 20:12:59.173 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
            2026-07-05 20:12:59.173 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275178198 = 0Wh
            2026-07-05 20:12:59.173 - debug: semp.0 (29126) planning request: got energy used 0
            2026-07-05 20:12:59.179 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
            2026-07-05 20:12:59.179 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275179173 = 0Wh
            2026-07-05 20:12:59.179 - debug: semp.0 (29126) planning request: got energy used 0
            2026-07-05 20:12:59.186 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:12:59.186 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:12:59.190 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
            2026-07-05 20:12:59.191 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
            2026-07-05 20:12:59.191 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
            2026-07-05 20:12:59.192 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
            2026-07-05 20:12:59.193 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
            2026-07-05 20:12:59.193 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
            2026-07-05 20:12:59.200 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:12:59.200 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:12:59.203 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:12:59.203 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:01.135 - debug: semp.0 (29126) SempServer: SHM requested description
            2026-07-05 20:13:01.135 - info: semp.0 (29126) SempServer: adapter discovered by SHM
            2026-07-05 20:13:01.176 - debug: semp.0 (29126) SempServer: SHM requested description
            2026-07-05 20:13:01.192 - debug: semp.0 (29126) SempServer: SHM requested description
            2026-07-05 20:13:14.142 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
            2026-07-05 20:13:14.143 - debug: semp.0 (29126) Keba KeContact P30X: wallbox error true
            2026-07-05 20:13:14.145 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:14.146 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:14.150 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
            2026-07-05 20:13:14.150 - info: semp.0 (29126) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
            2026-07-05 20:13:14.151 - debug: semp.0 (29126) planning request: Planningrequest all timeframes canceled
            2026-07-05 20:13:14.151 - debug: semp.0 (29126) Keba KeContact P30X: disconnect - timer fired
            2026-07-05 20:13:14.151 - debug: semp.0 (29126) Keba KeContact P30X: no switch configured
            2026-07-05 20:13:14.151 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
            2026-07-05 20:13:14.151 - debug: semp.0 (29126) Keba KeContact P30X: wallbox charging false
            2026-07-05 20:13:14.152 - debug: semp.0 (29126) Keba KeContact P30X: new recommendation power 0 number
            2026-07-05 20:13:14.152 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
            2026-07-05 20:13:14.164 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:14.164 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:14.166 - debug: semp.0 (29126) Keba KeContact P30X: set new charge power 0 number
            2026-07-05 20:13:14.168 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
            2026-07-05 20:13:14.168 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275179179 = 0Wh
            2026-07-05 20:13:14.168 - debug: semp.0 (29126) planning request: got energy used 0
            2026-07-05 20:13:14.169 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
            2026-07-05 20:13:14.169 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275194168 = 0Wh
            2026-07-05 20:13:14.169 - debug: semp.0 (29126) planning request: got energy used 0
            2026-07-05 20:13:14.178 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:14.178 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:14.185 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
            2026-07-05 20:13:14.185 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
            2026-07-05 20:13:14.186 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
            2026-07-05 20:13:14.186 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
            2026-07-05 20:13:14.186 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
            2026-07-05 20:13:14.189 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:14.189 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:14.191 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:14.191 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:18.127 - debug: semp.0 (29126) SempServer: SHM requested description
            2026-07-05 20:13:18.147 - debug: semp.0 (29126) SempServer: SHM requested description
            2026-07-05 20:13:18.165 - debug: semp.0 (29126) SempServer: SHM requested description
            2026-07-05 20:13:29.141 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
            2026-07-05 20:13:29.141 - debug: semp.0 (29126) Keba KeContact P30X: wallbox error true
            2026-07-05 20:13:29.144 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:29.144 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:29.147 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
            2026-07-05 20:13:29.148 - info: semp.0 (29126) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
            2026-07-05 20:13:29.148 - debug: semp.0 (29126) planning request: Planningrequest all timeframes canceled
            2026-07-05 20:13:29.148 - debug: semp.0 (29126) Keba KeContact P30X: disconnect - timer fired
            2026-07-05 20:13:29.148 - debug: semp.0 (29126) Keba KeContact P30X: no switch configured
            2026-07-05 20:13:29.148 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
            2026-07-05 20:13:29.149 - debug: semp.0 (29126) Keba KeContact P30X: wallbox charging false
            2026-07-05 20:13:29.152 - debug: semp.0 (29126) Keba KeContact P30X: new recommendation power 0 number
            2026-07-05 20:13:29.152 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
            2026-07-05 20:13:29.160 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:29.161 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:29.165 - debug: semp.0 (29126) Keba KeContact P30X: set new charge power 0 number
            2026-07-05 20:13:29.167 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
            2026-07-05 20:13:29.167 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275194169 = 0Wh
            2026-07-05 20:13:29.168 - debug: semp.0 (29126) planning request: got energy used 0
            2026-07-05 20:13:29.168 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
            2026-07-05 20:13:29.168 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275209167 = 0Wh
            2026-07-05 20:13:29.173 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:29.173 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:29.177 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
            2026-07-05 20:13:29.178 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
            2026-07-05 20:13:29.178 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
            2026-07-05 20:13:29.179 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
            2026-07-05 20:13:29.180 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
            2026-07-05 20:13:29.180 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
            2026-07-05 20:13:29.185 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:29.186 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:29.188 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:29.188 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:38.148 - debug: semp.0 (29126) SempServer: SHM requested description
            2026-07-05 20:13:38.164 - debug: semp.0 (29126) SempServer: SHM requested description
            2026-07-05 20:13:38.182 - debug: semp.0 (29126) SempServer: SHM requested description
            2026-07-05 20:13:44.148 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
            2026-07-05 20:13:44.148 - debug: semp.0 (29126) Keba KeContact P30X: wallbox error true
            2026-07-05 20:13:44.152 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:44.153 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:44.154 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
            2026-07-05 20:13:44.154 - info: semp.0 (29126) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
            2026-07-05 20:13:44.154 - debug: semp.0 (29126) planning request: Planningrequest all timeframes canceled
            2026-07-05 20:13:44.154 - debug: semp.0 (29126) Keba KeContact P30X: disconnect - timer fired
            2026-07-05 20:13:44.155 - debug: semp.0 (29126) Keba KeContact P30X: no switch configured
            2026-07-05 20:13:44.155 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
            2026-07-05 20:13:44.155 - debug: semp.0 (29126) Keba KeContact P30X: wallbox charging false
            2026-07-05 20:13:44.155 - debug: semp.0 (29126) Keba KeContact P30X: new recommendation power 0 number
            2026-07-05 20:13:44.155 - debug: semp.0 (29126) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
            2026-07-05 20:13:44.162 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:44.162 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:44.163 - debug: semp.0 (29126) Keba KeContact P30X: set new charge power 0 number
            2026-07-05 20:13:44.164 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
            2026-07-05 20:13:44.165 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275209168 = 0Wh
            2026-07-05 20:13:44.165 - debug: semp.0 (29126) planning request: got energy used 0
            2026-07-05 20:13:44.166 - debug: semp.0 (29126) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
            2026-07-05 20:13:44.166 - debug: semp.0 (29126) Keba KeContact P30X: calc energy 0 1783275224165 = 0Wh
            2026-07-05 20:13:44.167 - debug: semp.0 (29126) planning request: got energy used 0
            2026-07-05 20:13:44.181 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:44.181 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:44.184 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
            2026-07-05 20:13:44.184 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
            2026-07-05 20:13:44.185 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
            2026-07-05 20:13:44.189 - debug: semp.0 (29126) Keba KeContact P30X: set status detection limit to 500
            2026-07-05 20:13:44.189 - debug: semp.0 (29126) Keba KeContact P30X: status detection time limit is 1 going to off
            2026-07-05 20:13:44.189 - debug: semp.0 (29126) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
            2026-07-05 20:13:44.201 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:44.203 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            2026-07-05 20:13:44.207 - debug: semp.0 (29126) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
            2026-07-05 20:13:44.207 - debug: semp.0 (29126) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
            • Q Qlink
              @rene_hm
              Rene_HMR
              Rene_HMR
              Rene_HM
              #255
              @Qlink Du musst das log etwas länger laufen lassen. Der SHM fragt nur einmal pro Minute die Daten ab. Ich benötige den log-Eintrag, der mit "response xml " beginnt.
              Oder alternativ kannst du das auch im browser aufrufen (wie ich oben schon mal geschrieben hatte) :
              Du kannst auch http://xx.xx.xx.xx:9765/semp mit xx.xx.xx.xx als deine IP des iobroker Gateways (also nicht SHM) im Browser eingeben. Dann zeigt dein Browser an, was der SHM normalerweise als XML bekommen würde ... Im Idealfall schaltest du im Browser noch auf "Seiten-Quelltext" um, dann ist es besser lesbar...
              In einem anderen Fall musste man "InterruptionsAllowed" mal ein / ausschalten, damit die Daten gesendet werden...
              • Q
                Q
                Qlink
                #256
                @rene_hm
                Alles klar hier das längere log:
                2026-07-06 19:48:28.212 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:48:43.214 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:48:58.213 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:49:13.211 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:49:26.498 - info: web.1 (1448) ==> Connected system.user.admin from ::ffff:192.168.30.237
                2026-07-06 19:49:28.213 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:49:34.602 - info: web.1 (1448) ==> Connected system.user.admin from ::ffff:192.168.30.237
                2026-07-06 19:49:43.214 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:49:58.215 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:50:04.492 - error: semp.0 (1209) SempServer: Unmatched url... /favicon.ico {}
                2026-07-06 19:50:13.220 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:50:23.069 - error: semp.0 (1209) SempServer: Unmatched url... /favicon.ico {}
                2026-07-06 19:50:28.216 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:50:41.119 - info: admin.0 (170) ==> Connected system.user.admin from ::ffff:192.168.30.237
                2026-07-06 19:50:43.218 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:50:58.217 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:51:12.568 - info: host.iobroker stopInstance system.adapter.semp.0 (force=false, process=true)
                2026-07-06 19:51:12.570 - info: semp.0 (1209) Got terminate signal TERMINATE_YOURSELF
                2026-07-06 19:51:12.571 - info: host.iobroker stopInstance system.adapter.semp.0 send kill signal
                2026-07-06 19:51:13.073 - info: semp.0 (1209) terminating
                2026-07-06 19:51:13.074 - info: semp.0 (1209) terminating
                2026-07-06 19:51:13.074 - info: semp.0 (1209) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2026-07-06 19:51:13.572 - info: host.iobroker stopInstance timeout system.adapter.semp.0 killing pid 1209
                2026-07-06 19:51:13.683 - warn: host.iobroker instance system.adapter.semp.0 terminated due to SIGKILL
                2026-07-06 19:51:13.685 - info: host.iobroker instance system.adapter.semp.0 terminated with code null ()
                2026-07-06 19:51:17.043 - info: host.iobroker instance system.adapter.semp.0 in version "2.0.12" started with pid 24147
                2026-07-06 19:51:18.051 - debug: semp.0 (24147) Redis Objects: Use Redis connection: 172.18.0.5:6379
                2026-07-06 19:51:18.068 - debug: semp.0 (24147) Objects client ready ... initialize now
                2026-07-06 19:51:18.069 - debug: semp.0 (24147) Objects create System PubSub Client
                2026-07-06 19:51:18.070 - debug: semp.0 (24147) Objects create User PubSub Client
                2026-07-06 19:51:18.265 - debug: semp.0 (24147) Objects client initialize lua scripts
                2026-07-06 19:51:18.268 - debug: semp.0 (24147) Objects connected to redis: 172.18.0.5:6379
                2026-07-06 19:51:18.279 - debug: semp.0 (24147) Redis States: Use Redis connection: redis:6379
                2026-07-06 19:51:18.295 - debug: semp.0 (24147) States create System PubSub Client
                2026-07-06 19:51:18.296 - debug: semp.0 (24147) States create User PubSub Client
                2026-07-06 19:51:18.302 - debug: semp.0 (24147) States connected to redis: redis:6379
                2026-07-06 19:51:18.332 - debug: semp.0 (24147) Plugin sentry Initialize Plugin (enabled=true)
                2026-07-06 19:51:19.687 - info: semp.0 (24147) starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.semp, node: v22.21.0, js-controller: 7.2.2
                2026-07-06 19:51:19.698 - debug: semp.0 (24147) {"IPAddress":"192.168.30.90","UUID":"F-00000000-000000000001-00","SempPort":9765,"SempName":"ioBroker Gateway","SempManufacturer":"ioBroker","DeviceBaseID":"30380000","extendedLog":false,"LogToCSV":false,"LogToCSVPath":"/home/pi/semp.csv","devices":[{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}],"deviceSelector":"F-30380000-000000000001-00"}
                2026-07-06 19:51:19.698 - debug: semp.0 (24147) check BaseID 30380000 type string
                2026-07-06 19:51:19.699 - debug: semp.0 (24147) BaseID: valid 8-digit number
                2026-07-06 19:51:19.699 - debug: semp.0 (24147) Gateway: instance created
                2026-07-06 19:51:19.699 - debug: semp.0 (24147) SSDPServer: instance created
                2026-07-06 19:51:19.700 - debug: semp.0 (24147) Gateway: SSDPServer created: http://192.168.30.90:9765/description.xml F-00000000-000000000001-00
                2026-07-06 19:51:19.700 - debug: semp.0 (24147) SempServer: instance created
                2026-07-06 19:51:19.706 - debug: semp.0 (24147) SempServer: SEMPServer created
                2026-07-06 19:51:19.706 - debug: semp.0 (24147) Gateway: gateway created...
                2026-07-06 19:51:19.710 - debug: semp.0 (24147) SempServer: SEMP server listening on 9765
                2026-07-06 19:51:19.724 - debug: semp.0 (24147) Gateway: SSDPServer started
                2026-07-06 19:51:19.724 - debug: semp.0 (24147) Gateway: gateway started...
                2026-07-06 19:51:19.724 - debug: semp.0 (24147) Started all!
                2026-07-06 19:51:19.725 - debug: semp.0 (24147) add device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}
                2026-07-06 19:51:19.725 - debug: semp.0 (24147) Gateway: add device F-30380000-000000000001-00
                2026-07-06 19:51:19.726 - debug: semp.0 (24147) Keba KeContact P30X: instance created
                2026-07-06 19:51:19.727 - debug: semp.0 (24147) planning request: instance created
                2026-07-06 19:51:19.727 - debug: semp.0 (24147) planning request: planningrequest constructor {"DeviceName":"Keba KeContact P30X","DeviceType":"EVCharger","MaxEnergy":82000,"MinEnergy":8200,"MinPower":6000,"MaxPower":11000,"WallboxChargeTime":"3","DishwasherMode":false,"Type":"EVCharger","Name":"Keba KeContact P30X"}
                2026-07-06 19:51:19.727 - debug: semp.0 (24147) Keba KeContact P30X: check DeviceID F-30380000-000000000001-00 type string
                2026-07-06 19:51:19.727 - debug: semp.0 (24147) Keba KeContact P30X: BaseId 30380000 length 8
                2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: can use optional energy: true
                2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: wallbox OID configuration (1) [{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}] [{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}]
                2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: wallbox OID configuration (2) {"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"}}
                2026-07-06 19:51:19.729 - info: semp.0 (24147) Keba KeContact P30X: device created F-30380000-000000000001-00 Keba KeContact P30X
                2026-07-06 19:51:19.766 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_PlugConnected 0_userdata.0.Stromversorgung.Wallbox-Plug
                2026-07-06 19:51:19.769 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                2026-07-06 19:51:19.769 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:51:19.770 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                2026-07-06 19:51:19.771 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                2026-07-06 19:51:19.776 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                2026-07-06 19:51:19.777 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:19.778 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:19.785 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:19.786 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:19.787 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:19.787 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:19.788 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_IsCharging 0_userdata.0.Stromversorgung.Wallbox-Plug
                2026-07-06 19:51:19.790 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                2026-07-06 19:51:19.791 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                2026-07-06 19:51:19.792 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:19.793 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:19.793 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_IsError kecontact.0.error1
                2026-07-06 19:51:19.795 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                2026-07-06 19:51:19.796 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                2026-07-06 19:51:19.799 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:19.799 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:19.800 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_Counter 0_userdata.0.Stromversorgung.Wallbox-PowerW
                2026-07-06 19:51:19.801 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:51:19.802 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:51:19.804 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MinEnergy
                2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MaxEnergy
                2026-07-06 19:51:19.808 - debug: semp.0 (24147) planning request: planningrequest set minEnergy 0
                2026-07-06 19:51:19.809 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:19.810 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:19.810 - debug: semp.0 (24147) Gateway: set device
                2026-07-06 19:51:19.810 - debug: semp.0 (24147) UpdateData
                2026-07-06 19:51:19.810 - debug: semp.0 (24147) device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}
                2026-07-06 19:51:19.810 - debug: semp.0 (24147) result [{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}]
                2026-07-06 19:51:22.742 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:22.743 - info: semp.0 (24147) SempServer: adapter discovered by SHM
                2026-07-06 19:51:22.767 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:22.782 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:25.179 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:25.222 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:25.240 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:25.257 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:25.330 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:25.356 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:25.373 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:25.390 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:25.404 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:28.217 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                2026-07-06 19:51:28.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                2026-07-06 19:51:28.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:28.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:28.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                2026-07-06 19:51:28.222 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:51:28.223 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                2026-07-06 19:51:28.224 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                2026-07-06 19:51:28.226 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                2026-07-06 19:51:28.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                2026-07-06 19:51:28.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:28.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:28.233 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:51:28.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360279802 = 0Wh
                2026-07-06 19:51:28.234 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:51:28.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:51:28.235 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360288234 = 0Wh
                2026-07-06 19:51:28.235 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:51:28.235 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                2026-07-06 19:51:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:51:28.251 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:28.251 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:28.258 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:28.259 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:39.730 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:39.744 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:39.760 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:43.214 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                2026-07-06 19:51:43.215 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                2026-07-06 19:51:43.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:43.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:43.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                2026-07-06 19:51:43.223 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:51:43.223 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                2026-07-06 19:51:43.230 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:43.230 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:43.231 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                2026-07-06 19:51:43.232 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:51:43.232 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360288235 = 0Wh
                2026-07-06 19:51:43.233 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:51:43.233 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:51:43.233 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360303232 = 0Wh
                2026-07-06 19:51:43.240 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:43.240 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:51:43.246 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:51:43.247 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:51:43.247 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:51:43.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:43.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:43.252 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:43.252 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:56.780 - debug: semp.0 (24147) SempServer: SHM requested all devices. /semp/ ::ffff:192.168.30.2 http
                2026-07-06 19:51:56.781 - debug: semp.0 (24147) Gateway: get all devices
                2026-07-06 19:51:56.782 - debug: semp.0 (24147) planning request: Planningrequest Check2Switch {"SwitchOff":true,"restart":false}
                2026-07-06 19:51:56.782 - debug: semp.0 (24147) Keba KeContact P30X: turn device off
                2026-07-06 19:51:56.782 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                2026-07-06 19:51:56.782 - debug: semp.0 (24147) planning request: planningrequest data []
                2026-07-06 19:51:56.785 - debug: semp.0 (24147) SempServer: response xml
                Keba KeContact P30X
                EVCharger
                20296767
                Keba
                11000
                6000
                Measurement
                false
                false
                true
                false
                Off
                2026-07-06 19:51:56.786 - debug: semp.0 (24147) SempServer: response sent
                2026-07-06 19:51:58.215 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                2026-07-06 19:51:58.215 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                2026-07-06 19:51:58.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:58.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                2026-07-06 19:51:58.221 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:51:58.221 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                2026-07-06 19:51:58.226 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:58.227 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:58.230 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                2026-07-06 19:51:58.232 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:51:58.233 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360303233 = 0Wh
                2026-07-06 19:51:58.233 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:51:58.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:51:58.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360318233 = 0Wh
                2026-07-06 19:51:58.234 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:51:58.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:58.238 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:51:58.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:58.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:58.255 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:51:58.255 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:51:59.730 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:59.746 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:51:59.761 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:13.218 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                2026-07-06 19:52:13.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                2026-07-06 19:52:13.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:13.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:13.225 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                2026-07-06 19:52:13.225 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:52:13.226 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                2026-07-06 19:52:13.227 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                2026-07-06 19:52:13.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                2026-07-06 19:52:13.233 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:13.234 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:13.237 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                2026-07-06 19:52:13.238 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:52:13.239 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360318234 = 0Wh
                2026-07-06 19:52:13.239 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:52:13.239 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:52:13.240 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360333239 = 0Wh
                2026-07-06 19:52:13.240 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:52:13.243 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:13.244 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:13.252 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:52:13.254 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:52:13.254 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:52:13.260 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:13.260 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:13.263 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:13.263 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:19.731 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:19.746 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:19.762 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:23.002 - info: javascript.0 (218) script.js.Beschattung.Sonnenstandsberechnung: Sonne: Azimut: 293° / Sonne: Elevation: 9.8° / Mond: Azimut: 31° / Mond: Elevation: -32.9°
                2026-07-06 19:52:27.219 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:27.234 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:27.251 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:27.269 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:27.292 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:27.390 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:27.419 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:27.433 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:27.446 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:28.217 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                2026-07-06 19:52:28.217 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                2026-07-06 19:52:28.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:28.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:28.230 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                2026-07-06 19:52:28.231 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:52:28.231 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                2026-07-06 19:52:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:28.240 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                2026-07-06 19:52:28.245 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:52:28.245 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360333240 = 0Wh
                2026-07-06 19:52:28.247 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:52:28.247 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:52:28.247 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360348245 = 0Wh
                2026-07-06 19:52:28.248 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:52:28.254 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:28.254 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:28.258 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:52:28.259 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:52:28.259 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:52:28.269 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:28.270 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:28.271 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:28.272 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:39.729 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:39.746 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:39.759 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:43.216 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                2026-07-06 19:52:43.217 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                2026-07-06 19:52:43.218 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:43.218 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:43.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                2026-07-06 19:52:43.222 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:52:43.222 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                2026-07-06 19:52:43.226 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:43.227 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:43.229 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360348247 = 0Wh
                2026-07-06 19:52:43.230 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360363230 = 0Wh
                2026-07-06 19:52:43.231 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                2026-07-06 19:52:43.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:43.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:52:43.239 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:52:43.240 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:52:43.240 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:52:43.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:43.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:43.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:43.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:56.992 - debug: semp.0 (24147) SempServer: SHM requested all devices. /semp/ ::ffff:192.168.30.2 http
                2026-07-06 19:52:56.992 - debug: semp.0 (24147) Gateway: get all devices
                2026-07-06 19:52:56.993 - debug: semp.0 (24147) planning request: Planningrequest Check2Switch {"SwitchOff":true,"restart":false}
                2026-07-06 19:52:56.993 - debug: semp.0 (24147) Keba KeContact P30X: turn device off
                2026-07-06 19:52:56.993 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                2026-07-06 19:52:56.993 - debug: semp.0 (24147) planning request: planningrequest data []
                2026-07-06 19:52:56.994 - debug: semp.0 (24147) SempServer: response xml
                Keba KeContact P30X
                EVCharger
                20296767
                Keba
                11000
                6000
                Measurement
                false
                false
                true
                false
                Off
                2026-07-06 19:52:56.995 - debug: semp.0 (24147) SempServer: response sent
                2026-07-06 19:52:58.218 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                2026-07-06 19:52:58.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                2026-07-06 19:52:58.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:58.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:58.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                2026-07-06 19:52:58.226 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                2026-07-06 19:52:58.226 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                2026-07-06 19:52:58.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:58.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:58.233 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                2026-07-06 19:52:58.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:52:58.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360363230 = 0Wh
                2026-07-06 19:52:58.234 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:52:58.235 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                2026-07-06 19:52:58.235 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360378234 = 0Wh
                2026-07-06 19:52:58.235 - debug: semp.0 (24147) planning request: got energy used 0
                2026-07-06 19:52:58.238 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:58.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:58.241 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                2026-07-06 19:52:58.247 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:58.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:58.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                2026-07-06 19:52:58.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                2026-07-06 19:52:59.725 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:59.744 - debug: semp.0 (24147) SempServer: SHM requested description
                2026-07-06 19:52:59.761 - debug: semp.0 (24147) SempServer: SHM requested description
                Und hier der Seiten Quelltext Output:
                <?xml version="1.0" encoding="utf-8"?>
                <Device2EM xmlns="http://www.sma.de/communication/schema/SEMP/v1">
                <DeviceInfo>
                <Identification>
                <DeviceId>F-30380000-000000000001-00</DeviceId>
                <DeviceName>Keba KeContact P30X</DeviceName>
                <DeviceType>EVCharger</DeviceType>
                <DeviceSerial>20296767</DeviceSerial>
                <DeviceVendor>Keba</DeviceVendor>
                </Identification>
                <Characteristics>
                <MaxPowerConsumption>11000</MaxPowerConsumption>
                <MinPowerConsumption>6000</MinPowerConsumption>
                </Characteristics>
                <Capabilities>
                <CurrentPower>
                <Method>Measurement</Method>
                </CurrentPower>
                <Timestamps>
                <AbsoluteTimestamps>false</AbsoluteTimestamps>
                </Timestamps>
                <Interruptions>
                <InterruptionsAllowed>false</InterruptionsAllowed>
                </Interruptions>
                <Requests>
                <OptionalEnergy>true</OptionalEnergy>
                </Requests>
                </Capabilities>
                </DeviceInfo>
                <DeviceStatus>
                <EMSignalsAccepted>false</EMSignalsAccepted>
                <Status>Off</Status>
                <PowerConsumption>
                <PowerInfo>
                <AveragePower>0</AveragePower>
                <Timestamp>0</Timestamp>
                <AveragingInterval>60</AveragingInterval>
                </PowerInfo>
                </PowerConsumption>
                </DeviceStatus>
                </Device2EM>
                Rene_HMR 1 Antwort Letzte Antwort
                • Q Qlink
                  @rene_hm
                  Alles klar hier das längere log:
                  2026-07-06 19:48:28.212 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:48:43.214 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:48:58.213 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:49:13.211 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:49:26.498 - info: web.1 (1448) ==> Connected system.user.admin from ::ffff:192.168.30.237
                  2026-07-06 19:49:28.213 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:49:34.602 - info: web.1 (1448) ==> Connected system.user.admin from ::ffff:192.168.30.237
                  2026-07-06 19:49:43.214 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:49:58.215 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:50:04.492 - error: semp.0 (1209) SempServer: Unmatched url... /favicon.ico {}
                  2026-07-06 19:50:13.220 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:50:23.069 - error: semp.0 (1209) SempServer: Unmatched url... /favicon.ico {}
                  2026-07-06 19:50:28.216 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:50:41.119 - info: admin.0 (170) ==> Connected system.user.admin from ::ffff:192.168.30.237
                  2026-07-06 19:50:43.218 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:50:58.217 - info: semp.0 (1209) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:51:12.568 - info: host.iobroker stopInstance system.adapter.semp.0 (force=false, process=true)
                  2026-07-06 19:51:12.570 - info: semp.0 (1209) Got terminate signal TERMINATE_YOURSELF
                  2026-07-06 19:51:12.571 - info: host.iobroker stopInstance system.adapter.semp.0 send kill signal
                  2026-07-06 19:51:13.073 - info: semp.0 (1209) terminating
                  2026-07-06 19:51:13.074 - info: semp.0 (1209) terminating
                  2026-07-06 19:51:13.074 - info: semp.0 (1209) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2026-07-06 19:51:13.572 - info: host.iobroker stopInstance timeout system.adapter.semp.0 killing pid 1209
                  2026-07-06 19:51:13.683 - warn: host.iobroker instance system.adapter.semp.0 terminated due to SIGKILL
                  2026-07-06 19:51:13.685 - info: host.iobroker instance system.adapter.semp.0 terminated with code null ()
                  2026-07-06 19:51:17.043 - info: host.iobroker instance system.adapter.semp.0 in version "2.0.12" started with pid 24147
                  2026-07-06 19:51:18.051 - debug: semp.0 (24147) Redis Objects: Use Redis connection: 172.18.0.5:6379
                  2026-07-06 19:51:18.068 - debug: semp.0 (24147) Objects client ready ... initialize now
                  2026-07-06 19:51:18.069 - debug: semp.0 (24147) Objects create System PubSub Client
                  2026-07-06 19:51:18.070 - debug: semp.0 (24147) Objects create User PubSub Client
                  2026-07-06 19:51:18.265 - debug: semp.0 (24147) Objects client initialize lua scripts
                  2026-07-06 19:51:18.268 - debug: semp.0 (24147) Objects connected to redis: 172.18.0.5:6379
                  2026-07-06 19:51:18.279 - debug: semp.0 (24147) Redis States: Use Redis connection: redis:6379
                  2026-07-06 19:51:18.295 - debug: semp.0 (24147) States create System PubSub Client
                  2026-07-06 19:51:18.296 - debug: semp.0 (24147) States create User PubSub Client
                  2026-07-06 19:51:18.302 - debug: semp.0 (24147) States connected to redis: redis:6379
                  2026-07-06 19:51:18.332 - debug: semp.0 (24147) Plugin sentry Initialize Plugin (enabled=true)
                  2026-07-06 19:51:19.687 - info: semp.0 (24147) starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.semp, node: v22.21.0, js-controller: 7.2.2
                  2026-07-06 19:51:19.698 - debug: semp.0 (24147) {"IPAddress":"192.168.30.90","UUID":"F-00000000-000000000001-00","SempPort":9765,"SempName":"ioBroker Gateway","SempManufacturer":"ioBroker","DeviceBaseID":"30380000","extendedLog":false,"LogToCSV":false,"LogToCSVPath":"/home/pi/semp.csv","devices":[{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}],"deviceSelector":"F-30380000-000000000001-00"}
                  2026-07-06 19:51:19.698 - debug: semp.0 (24147) check BaseID 30380000 type string
                  2026-07-06 19:51:19.699 - debug: semp.0 (24147) BaseID: valid 8-digit number
                  2026-07-06 19:51:19.699 - debug: semp.0 (24147) Gateway: instance created
                  2026-07-06 19:51:19.699 - debug: semp.0 (24147) SSDPServer: instance created
                  2026-07-06 19:51:19.700 - debug: semp.0 (24147) Gateway: SSDPServer created: http://192.168.30.90:9765/description.xml F-00000000-000000000001-00
                  2026-07-06 19:51:19.700 - debug: semp.0 (24147) SempServer: instance created
                  2026-07-06 19:51:19.706 - debug: semp.0 (24147) SempServer: SEMPServer created
                  2026-07-06 19:51:19.706 - debug: semp.0 (24147) Gateway: gateway created...
                  2026-07-06 19:51:19.710 - debug: semp.0 (24147) SempServer: SEMP server listening on 9765
                  2026-07-06 19:51:19.724 - debug: semp.0 (24147) Gateway: SSDPServer started
                  2026-07-06 19:51:19.724 - debug: semp.0 (24147) Gateway: gateway started...
                  2026-07-06 19:51:19.724 - debug: semp.0 (24147) Started all!
                  2026-07-06 19:51:19.725 - debug: semp.0 (24147) add device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false}
                  2026-07-06 19:51:19.725 - debug: semp.0 (24147) Gateway: add device F-30380000-000000000001-00
                  2026-07-06 19:51:19.726 - debug: semp.0 (24147) Keba KeContact P30X: instance created
                  2026-07-06 19:51:19.727 - debug: semp.0 (24147) planning request: instance created
                  2026-07-06 19:51:19.727 - debug: semp.0 (24147) planning request: planningrequest constructor {"DeviceName":"Keba KeContact P30X","DeviceType":"EVCharger","MaxEnergy":82000,"MinEnergy":8200,"MinPower":6000,"MaxPower":11000,"WallboxChargeTime":"3","DishwasherMode":false,"Type":"EVCharger","Name":"Keba KeContact P30X"}
                  2026-07-06 19:51:19.727 - debug: semp.0 (24147) Keba KeContact P30X: check DeviceID F-30380000-000000000001-00 type string
                  2026-07-06 19:51:19.727 - debug: semp.0 (24147) Keba KeContact P30X: BaseId 30380000 length 8
                  2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: can use optional energy: true
                  2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: wallbox OID configuration (1) [{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}] [{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}]
                  2026-07-06 19:51:19.728 - debug: semp.0 (24147) Keba KeContact P30X: wallbox OID configuration (2) {"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"","Path2Check":"nicht genutzt"}}
                  2026-07-06 19:51:19.729 - info: semp.0 (24147) Keba KeContact P30X: device created F-30380000-000000000001-00 Keba KeContact P30X
                  2026-07-06 19:51:19.766 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_PlugConnected 0_userdata.0.Stromversorgung.Wallbox-Plug
                  2026-07-06 19:51:19.769 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:51:19.769 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:51:19.770 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                  2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                  2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                  2026-07-06 19:51:19.770 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                  2026-07-06 19:51:19.771 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                  2026-07-06 19:51:19.776 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                  2026-07-06 19:51:19.777 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:19.778 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:19.785 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:19.786 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:19.787 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:19.787 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:19.788 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_IsCharging 0_userdata.0.Stromversorgung.Wallbox-Plug
                  2026-07-06 19:51:19.790 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:51:19.791 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                  2026-07-06 19:51:19.792 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:19.793 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:19.793 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_IsError kecontact.0.error1
                  2026-07-06 19:51:19.795 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                  2026-07-06 19:51:19.796 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                  2026-07-06 19:51:19.799 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:19.799 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:19.800 - debug: semp.0 (24147) Keba KeContact P30X: subscribe OID_Counter 0_userdata.0.Stromversorgung.Wallbox-PowerW
                  2026-07-06 19:51:19.801 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:51:19.802 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:51:19.804 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MinEnergy
                  2026-07-06 19:51:19.805 - debug: semp.0 (24147) Keba KeContact P30X: subscribe Devices.Keba KeContact P30X.MaxEnergy
                  2026-07-06 19:51:19.808 - debug: semp.0 (24147) planning request: planningrequest set minEnergy 0
                  2026-07-06 19:51:19.809 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:19.810 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:19.810 - debug: semp.0 (24147) Gateway: set device
                  2026-07-06 19:51:19.810 - debug: semp.0 (24147) UpdateData
                  2026-07-06 19:51:19.810 - debug: semp.0 (24147) device {"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}
                  2026-07-06 19:51:19.810 - debug: semp.0 (24147) result [{"ID":"F-30380000-000000000001-00","Name":"Keba KeContact P30X","IsActive":true,"Type":"EVCharger","MeasurementMethod":"Measurement","StatusDetectionType":"FromPowerValue","MeasurementUnit":"W","wallbox_oid_read":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStatus","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"wallbox_oid_write":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"kecontact.0.start","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"kecontact.0.stop","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeEnable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOID3PhaseChargeDisable","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},{"active":false,"must":"optional","Name":"DeviceOIDSwitch","OID":"","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"}],"Vendor":"Keba","SerialNr":"20296767","MinPower":6000,"MaxPower":11000,"InterruptionsAllowed":false,"OID_Power":"0_userdata.0.Stromversorgung.Wallbox-PowerW","StatusDetectionLimit":500,"StatusDetectionLimitTimeOn":1,"StatusDetectionLimitTimeOff":1,"StatusDetectionMinRunTime":1,"WallboxPhases":"2","TimerActive":false,"BatteryCapacity":82000,"WallboxChargeTime":"3","WallboxNeedCurrentRecommendation":false,"HasOIDSwitch":false,"WallboxOID":{"DeviceOIDPlugConnected":{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsCharging":{"active":true,"must":"optional","Name":"DeviceOIDIsCharging","OID":"0_userdata.0.Stromversorgung.Wallbox-Plug","Type":"Boolean","SetValue":"true","Path2Check":"nicht genutzt"},"DeviceOIDIsError":{"active":true,"must":"optional","Name":"DeviceOIDIsError","OID":"kecontact.0.error1","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDCounter":{"active":true,"must":"optional","Name":"DeviceOIDCounter","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":"0","Path2Check":"nicht genutzt"},"DeviceOIDChargePower":{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"0_userdata.0.Stromversorgung.Wallbox-PowerW","Type":"Number","SetValue":0,"Path2Check":"nicht genutzt"}},"OptionalEnergy":true}]
                  2026-07-06 19:51:22.742 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:22.743 - info: semp.0 (24147) SempServer: adapter discovered by SHM
                  2026-07-06 19:51:22.767 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:22.782 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:25.179 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:25.222 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:25.240 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:25.257 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:25.330 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:25.356 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:25.373 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:25.390 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:25.404 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:28.217 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                  2026-07-06 19:51:28.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                  2026-07-06 19:51:28.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:28.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:28.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:51:28.222 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:51:28.223 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                  2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                  2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                  2026-07-06 19:51:28.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:51:28.224 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                  2026-07-06 19:51:28.226 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                  2026-07-06 19:51:28.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                  2026-07-06 19:51:28.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:28.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:28.233 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:51:28.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360279802 = 0Wh
                  2026-07-06 19:51:28.234 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:51:28.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:51:28.235 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360288234 = 0Wh
                  2026-07-06 19:51:28.235 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:51:28.235 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                  2026-07-06 19:51:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:51:28.245 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:51:28.246 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:51:28.251 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:28.251 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:28.258 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:28.259 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:39.730 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:39.744 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:39.760 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:43.214 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                  2026-07-06 19:51:43.215 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                  2026-07-06 19:51:43.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:43.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:43.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:51:43.223 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:51:43.223 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                  2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                  2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                  2026-07-06 19:51:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                  2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                  2026-07-06 19:51:43.224 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                  2026-07-06 19:51:43.230 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:43.230 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:43.231 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                  2026-07-06 19:51:43.232 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:51:43.232 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360288235 = 0Wh
                  2026-07-06 19:51:43.233 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:51:43.233 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:51:43.233 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360303232 = 0Wh
                  2026-07-06 19:51:43.240 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:43.240 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:51:43.243 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:51:43.246 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:51:43.247 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:51:43.247 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:51:43.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:43.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:43.252 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:43.252 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:56.780 - debug: semp.0 (24147) SempServer: SHM requested all devices. /semp/ ::ffff:192.168.30.2 http
                  2026-07-06 19:51:56.781 - debug: semp.0 (24147) Gateway: get all devices
                  2026-07-06 19:51:56.782 - debug: semp.0 (24147) planning request: Planningrequest Check2Switch {"SwitchOff":true,"restart":false}
                  2026-07-06 19:51:56.782 - debug: semp.0 (24147) Keba KeContact P30X: turn device off
                  2026-07-06 19:51:56.782 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                  2026-07-06 19:51:56.782 - debug: semp.0 (24147) planning request: planningrequest data []
                  2026-07-06 19:51:56.785 - debug: semp.0 (24147) SempServer: response xml
                  Keba KeContact P30X
                  EVCharger
                  20296767
                  Keba
                  11000
                  6000
                  Measurement
                  false
                  false
                  true
                  false
                  Off
                  2026-07-06 19:51:56.786 - debug: semp.0 (24147) SempServer: response sent
                  2026-07-06 19:51:58.215 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                  2026-07-06 19:51:58.215 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                  2026-07-06 19:51:58.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:58.217 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:51:58.221 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:51:58.221 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                  2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                  2026-07-06 19:51:58.221 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                  2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                  2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                  2026-07-06 19:51:58.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                  2026-07-06 19:51:58.226 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:58.227 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:58.230 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                  2026-07-06 19:51:58.232 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:51:58.233 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360303233 = 0Wh
                  2026-07-06 19:51:58.233 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:51:58.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:51:58.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360318233 = 0Wh
                  2026-07-06 19:51:58.234 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:51:58.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:58.238 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:51:58.243 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:51:58.248 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:51:58.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:58.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:58.255 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:51:58.255 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:51:59.730 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:59.746 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:51:59.761 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:13.218 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                  2026-07-06 19:52:13.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                  2026-07-06 19:52:13.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:13.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:13.225 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:52:13.225 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:52:13.226 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                  2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                  2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                  2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:52:13.226 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                  2026-07-06 19:52:13.227 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                  2026-07-06 19:52:13.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                  2026-07-06 19:52:13.233 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:13.234 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:13.237 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                  2026-07-06 19:52:13.238 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:52:13.239 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360318234 = 0Wh
                  2026-07-06 19:52:13.239 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:52:13.239 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:52:13.240 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360333239 = 0Wh
                  2026-07-06 19:52:13.240 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:52:13.243 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:13.244 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:13.252 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:52:13.253 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:52:13.254 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:52:13.254 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:52:13.260 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:13.260 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:13.263 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:13.263 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:19.731 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:19.746 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:19.762 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:23.002 - info: javascript.0 (218) script.js.Beschattung.Sonnenstandsberechnung: Sonne: Azimut: 293° / Sonne: Elevation: 9.8° / Mond: Azimut: 31° / Mond: Elevation: -32.9°
                  2026-07-06 19:52:27.219 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:27.234 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:27.251 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:27.269 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:27.292 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:27.390 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:27.419 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:27.433 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:27.446 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:28.217 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                  2026-07-06 19:52:28.217 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                  2026-07-06 19:52:28.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:28.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:28.230 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:52:28.231 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:52:28.231 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                  2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                  2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                  2026-07-06 19:52:28.231 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                  2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                  2026-07-06 19:52:28.232 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                  2026-07-06 19:52:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:28.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:28.240 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                  2026-07-06 19:52:28.245 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:52:28.245 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360333240 = 0Wh
                  2026-07-06 19:52:28.247 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:52:28.247 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:52:28.247 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360348245 = 0Wh
                  2026-07-06 19:52:28.248 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:52:28.254 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:28.254 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:28.258 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:52:28.259 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:52:28.259 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:52:28.260 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:52:28.269 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:28.270 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:28.271 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:28.272 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:39.729 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:39.746 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:39.759 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:43.216 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                  2026-07-06 19:52:43.217 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                  2026-07-06 19:52:43.218 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:43.218 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:43.222 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:52:43.222 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:52:43.222 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                  2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                  2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                  2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                  2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                  2026-07-06 19:52:43.223 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                  2026-07-06 19:52:43.226 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:43.227 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:43.229 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360348247 = 0Wh
                  2026-07-06 19:52:43.230 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:52:43.230 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360363230 = 0Wh
                  2026-07-06 19:52:43.231 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                  2026-07-06 19:52:43.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:43.237 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:52:43.238 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:52:43.239 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:52:43.240 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:52:43.240 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:52:43.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:43.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:43.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:43.253 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:56.992 - debug: semp.0 (24147) SempServer: SHM requested all devices. /semp/ ::ffff:192.168.30.2 http
                  2026-07-06 19:52:56.992 - debug: semp.0 (24147) Gateway: get all devices
                  2026-07-06 19:52:56.993 - debug: semp.0 (24147) planning request: Planningrequest Check2Switch {"SwitchOff":true,"restart":false}
                  2026-07-06 19:52:56.993 - debug: semp.0 (24147) Keba KeContact P30X: turn device off
                  2026-07-06 19:52:56.993 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                  2026-07-06 19:52:56.993 - debug: semp.0 (24147) planning request: planningrequest data []
                  2026-07-06 19:52:56.994 - debug: semp.0 (24147) SempServer: response xml
                  Keba KeContact P30X
                  EVCharger
                  20296767
                  Keba
                  11000
                  6000
                  Measurement
                  false
                  false
                  true
                  false
                  Off
                  2026-07-06 19:52:56.995 - debug: semp.0 (24147) SempServer: response sent
                  2026-07-06 19:52:58.218 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsError sensor type Number setValue 0 value 0 string number
                  2026-07-06 19:52:58.218 - debug: semp.0 (24147) Keba KeContact P30X: wallbox error true
                  2026-07-06 19:52:58.220 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:58.221 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:58.226 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDPlugConnected sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:52:58.226 - info: semp.0 (24147) Keba KeContact P30X: Keba KeContact P30X wallbox plug connected false
                  2026-07-06 19:52:58.226 - debug: semp.0 (24147) planning request: Planningrequest all timeframes canceled
                  2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: disconnect - timer fired
                  2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: no switch configured
                  2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDIsCharging sensor type Boolean setValue true value false string boolean
                  2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: wallbox charging false
                  2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: new recommendation power 0 number
                  2026-07-06 19:52:58.227 - debug: semp.0 (24147) Keba KeContact P30X: DeviceOIDChargePower actor type Number setValue 0 number
                  2026-07-06 19:52:58.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:58.231 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:58.233 - debug: semp.0 (24147) Keba KeContact P30X: set new charge power 0 number
                  2026-07-06 19:52:58.234 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:52:58.234 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360363230 = 0Wh
                  2026-07-06 19:52:58.234 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:52:58.235 - debug: semp.0 (24147) Keba KeContact P30X: setLastPower 0 number FromPowerValue W Off
                  2026-07-06 19:52:58.235 - debug: semp.0 (24147) Keba KeContact P30X: calc energy 0 1783360378234 = 0Wh
                  2026-07-06 19:52:58.235 - debug: semp.0 (24147) planning request: got energy used 0
                  2026-07-06 19:52:58.238 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:58.239 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:58.241 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: status detection time limit is 1 going to off
                  2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: already off, no timer start Off StatusDetectionOffTimerID not running
                  2026-07-06 19:52:58.242 - debug: semp.0 (24147) Keba KeContact P30X: set status detection limit to 500
                  2026-07-06 19:52:58.247 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:58.248 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:58.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState got {"val":"plug not connected","ack":true,"ts":1783265264205,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1783265264205} from Devices.Keba KeContact P30X.State
                  2026-07-06 19:52:58.250 - debug: semp.0 (24147) Keba KeContact P30X: in SetState, no new state to set, is plug not connected
                  2026-07-06 19:52:59.725 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:59.744 - debug: semp.0 (24147) SempServer: SHM requested description
                  2026-07-06 19:52:59.761 - debug: semp.0 (24147) SempServer: SHM requested description
                  Und hier der Seiten Quelltext Output:
                  <?xml version="1.0" encoding="utf-8"?>
                  <Device2EM xmlns="http://www.sma.de/communication/schema/SEMP/v1">
                  <DeviceInfo>
                  <Identification>
                  <DeviceId>F-30380000-000000000001-00</DeviceId>
                  <DeviceName>Keba KeContact P30X</DeviceName>
                  <DeviceType>EVCharger</DeviceType>
                  <DeviceSerial>20296767</DeviceSerial>
                  <DeviceVendor>Keba</DeviceVendor>
                  </Identification>
                  <Characteristics>
                  <MaxPowerConsumption>11000</MaxPowerConsumption>
                  <MinPowerConsumption>6000</MinPowerConsumption>
                  </Characteristics>
                  <Capabilities>
                  <CurrentPower>
                  <Method>Measurement</Method>
                  </CurrentPower>
                  <Timestamps>
                  <AbsoluteTimestamps>false</AbsoluteTimestamps>
                  </Timestamps>
                  <Interruptions>
                  <InterruptionsAllowed>false</InterruptionsAllowed>
                  </Interruptions>
                  <Requests>
                  <OptionalEnergy>true</OptionalEnergy>
                  </Requests>
                  </Capabilities>
                  </DeviceInfo>
                  <DeviceStatus>
                  <EMSignalsAccepted>false</EMSignalsAccepted>
                  <Status>Off</Status>
                  <PowerConsumption>
                  <PowerInfo>
                  <AveragePower>0</AveragePower>
                  <Timestamp>0</Timestamp>
                  <AveragingInterval>60</AveragingInterval>
                  </PowerInfo>
                  </PowerConsumption>
                  </DeviceStatus>
                  </Device2EM>
                  Rene_HMR
                  Rene_HMR
                  Rene_HM
                  #257
                  @Qlink eigentlich sieht jetzt das xml gut aus. Ich sehe keinen offensichtlichen Fehler mehr.
                  Hast du schon mal versucht, das log vom SHM selbst anzuschauen?
                  Ich hatte das unter
                  https://github.com/rg-engineering/ioBroker.semp/blob/master/docu/connection_assist/connection_assist_de.md
                  beschrieben...
                  • Q
                    Q
                    Qlink
                    #258
                    @rene_hm
                    Der findet gar keine Geräte bei mir im Netzwerk, obwohl ich den SHM vom selben Rechner aus pingen kann
                    Rene_HMR 1 Antwort Letzte Antwort
                    • Q Qlink
                      @rene_hm
                      Rene_HMR
                      Rene_HMR
                      Rene_HM
                      schrieb am zuletzt editiert von Rene_HM
                      #259
                      @Qlink du bist per Kabel und nicht per WLAN verbunden? Hast du weitere Router oder switche zwischen deinem PC und dem SHM? Ideal ist, den PC an den switch zu verbinden, an dem auch der SHM angeschlossen ist. Jeder switch oder Router zwischen PC und SHM kann die discover-Messages im Netzwerk verwerfen, so dass sie nicht am Ziel ankommen. Ping hat nichts zu bedeuten, die discover-Messages verwenden ein anderes Protokoll...
                      • Q
                        Q
                        Qlink
                        #260
                        @rene_hm auch per Kabel am selben Switch wo der SHM hängt findet der Connection Assist keine SMA Geräte, obwohl selbes Subnet. IGMP Snooping am Unifi UCG deaktiviert... Keine Ahnung was ich noch probieren kann...
                        • Q Qlink
                          Rene_HMR
                          Rene_HMR
                          Rene_HM
                          #261
                          @Qlink Ich hatte jetzt endlich die chance, das auch hier in einem setup auszuprobieren, wo connection_assist nichts findet. Bist du vertraut mit wireshark? Dann könnten wir es darüber analysieren.
                          Ein Thema bei mir war, dass ich weitere Netzwerk-Adapter verfügbar aber inaktiv hatte. Ich habe alle unter Systemsteuerung\Netzwerk und Internet\Netzwerkverbindungen deaktiviert, nur den Ethernet Adapter aktiv gelassen, wo das Netzwerkkabel angesteckt war. Damit hat connection_assist schon mal die Wechselrichter gefunden. Ich habe dann in der Firewall auf dem Windows-Laptop den Port 9522 für UDP eingehend geöffnet. Damit kam dann auch der SHM durch...
                          • Q
                            Q
                            Qlink
                            #262
                            @rene_hm
                            Deine Hinweise und Tipps hätte ich nun auch alles probiert, aber leider ohne Erfolg. Egal was ich anstelle, WR + SHM lassen sich pingen, aber per Connection Assist werden sie nicht gefunden. Lässt sich ohne dem SHM Log dem Problem nicht auch anders auf die Spur kommen ?
                            • M
                              M
                              mmeine
                              schrieb am zuletzt editiert von mmeine
                              #263
                              Hallo Rene_HM, ich habe den aktuellen Adapter in Nutzung, dieser funktioniert für meine Begriffe nicht ganz zuverlässig. Ich kann aber nicht sagen ob das am Adapter, am SHM2.0 oder am enoxOS liegt. Zumindest tauchen immer wieder Karteileichen von früheren Versuchen mit der älteren Version im Portal bei der Gerätesuche auf. Den Adapter habe ich komplett neu installiert und wieder neu konfiguriert, den SHM2.0 habe ich auf Werkseinstellungen zurückgesetzt und neu eingebunden. Ich vermute es liegt am ennoxOS.
                              Aber nun erst einmal einige bugs, welche ich festgestellt habe:
                              • sobald ich ein Gerät neu erstelle, werden bei sämtlichen Objekteinträgen die Datenpunkte falsch konfiguriert. Hier scheint eine Verwechslung zwischen "type" und "name" drin zu sein. Iobroker bringt dabei folgende Warnung:
                              semp.0	2026-08-18 11:21:37.687	warn	Object semp.0.Devices.Geschirrspueler.State is invalid: obj.type has an invalid value (current State) but has to be one of state, channel, device, enum, host, adapter, instance, meta, config, script, user, group, chart, folder, schedule, design This will throw an error up from js-controller version 7.0.0!
                              hier die Objekteigenschaften:
                                "type": "current State",
                                "common": {
                                  "name": "state",
                                  "role": "state",
                                  "type": "string",
                                  "unit": "",
                              richtig müsste vermutlich sein:
                                "type": "state",
                                "common": {
                                  "name": "current State",
                                  "role": "state",
                                  "type": "string",
                                  "unit": "",
                              • Dann habe ich noch entdeckt, das der Punkt "Unterbrechung erlaubt" erst einmal aktiviert und dann wieder deaktiviert werden muß, damit das Protokoll richtig erstellt wird. Andernfalls ist bei der WEB-Analyse (http://<IP>:9765/semp) der Übergabewert <interruptionsallowed> LEER und nicht FALSE.
                              <deviceinfo>
                                      <capabilities>
                                          <interruptions>
                                              <interruptionsallowed></interruptionsallowed>
                                          </interruptions>
                                      </capabilities>
                                  </deviceinfo>
                              ob das allerdings negative Auswirkungen hat weis ich nicht.
                              Prinzipiell danke ich Dir vielmals, für deine hervorragende Leistung, bei der Erstellung des Adapters. Es macht immer wieder Freude auf solche konstruktiven und hilfreichen Arbeiten zurückgreifen zu können.
                              • M mmeine
                                  "common": {
                                    "name": "state",
                                    "role": "state",
                                    "type": "string",
                                    "unit": "",
                                  "type": "state",
                                  "common": {
                                    "role": "state",
                                    "type": "string",
                                    "unit": "",
                                <deviceinfo>
                                        <capabilities>
                                            <interruptions>
                                            </interruptions>
                                        </capabilities>
                                    </deviceinfo>
                                Rene_HMR
                                Rene_HMR
                                Rene_HM
                                #264
                                @mmeine sagte:
                                Danke für dein feedback.
                                Bzgl. der Karteileichen: Eigentlich sollte es reichen, die alten Geräte im Portal zu löschen. Das ging jedenfalls mal, ob das aktuell noch geht, habe ich nicht probiert. Der Adapter sendet die Gerätebeschreibung an den SHM und der an's Portal. Wenn es das Gerät im Adapter nicht mehr gibt, schickt der nichts mehr. Das Portal hingegen muss sich die Geräte merken, da das Gerät ja nur temporär ausgefallen sein könnte...
                                Das mit den Datenpunkten schaue ich mir an. Habe mir dazu ein Ticket gemacht
                                https://github.com/rg-engineering/ioBroker.semp/issues/494
                                Für das Theme mit den Unterbrechungen habe ich mir ebenfalls ein Ticket gemacht, obwohl ich das schon kenne. Ich dachte, ich hätte das schon behoben...
                                84.0k
