  4. Matter-Controller (Matter Geräte in ioBroker einbinden)
145 Beiträge 27 Kommentatoren 30.2k Aufrufe 32 Beobachtet
  • FredFF Online
    FredFF Online
    FredF
    Most Active Forum Testing
    #102
    Ich habe mir den Presence Melder Meross MS605 mal beschafft: https://shop.meross.com/products/smart-presence-sensor-ms605
    Nach einigen Versuchen konnte ich den auch in Homekit einbinden und bekomme dort auch die Anwesenheit angezeigt.
    Leider bekomme ich den weder über die Visu App noch über den Matter Adapter als Controller hinzugefügt.
    Den Pairing mode habe ich natürlich aktiviert und den angezeigten Code dann auch eingegeben.
    Hier das log vom Matter Adapter:
    2026-01-11 19:56:33.223 - info: matter.0 (156421) Start the discovering...
    2026-01-11 19:56:43.919 - debug: matter.0 (156421) Discovered Device: {"addresses":[{"ip":"fd71:21eb:d0d:0:6830:c110:7883:ea7e","port":5540,"type":"udp"}],"discoveredAt":"undefined","ttl":"undefined","VP":"4933+16898","SII":17000,"SAI":2500,"SAT":2000,"D":3007,"CM":2,"PH":36,"PI":"","T":0,"ICD":0,"instanceId":"511156A615FCDCDF","deviceIdentifier":"511156A615FCDCDF","SD":11,"V":4933,"P":16898}
    2026-01-11 19:56:43.919 - debug: matter.0 (156421) Send to GUI: {"command":"discoveredDevice","device":{"addresses":[{"ip":"fd71:21eb:d0d:0:6830:c110:7883:ea7e","port":5540,"type":"udp"}],"VP":"4933+16898","SII":17000,"SAI":2500,"SAT":2000,"D":3007,"CM":2,"PH":36,"PI":"","T":0,"ICD":0,"instanceId":"511156A615FCDCDF","deviceIdentifier":"511156A615FCDCDF","SD":11,"V":4933,"P":16898}}
    2026-01-11 19:57:08.355 - debug: matter.0 (156421) Handle message controllerCommissionDevice {"command":"controllerCommissionDevice","message":{"device":{"addresses":[{"ip":"fd71:21eb:d0d:0:6830:c110:7883:ea7e","port":5540,"type":"udp"}],"VP":"4933+16898","SII":17000,"SAI":2500,"SAT":2000,"D":3007,"CM":2,"PH":36,"PI":"","T":0,"ICD":0,"instanceId":"511156A615FCDCDF","deviceIdentifier":"511156A615FCDCDF","SD":11,"V":4933,"P":16898},"qrCode":"","manualCode":"14656013318"},"from":"system.adapter.admin.0","callback":{"message":{"device":{"addresses":[{"ip":"fd71:21eb:d0d:0:6830:c110:7883:ea7e","port":5540,"type":"udp"}],"VP":"4933+16898","SII":17000,"SAI":2500,"SAT":2000,"D":3007,"CM":2,"PH":36,"PI":"","T":0,"ICD":0,"instanceId":"511156A615FCDCDF","deviceIdentifier":"511156A615FCDCDF","SD":11,"V":4933,"P":16898},"qrCode":"","manualCode":"14656013318"},"id":2912,"ack":false,"time":1768157828353},"_id":85665702}
    2026-01-11 19:57:08.357 - debug: matter.0 (156421) 2026-01-11 19:57:08.357 INFO PeerCommissioner Connecting to device with identifier {"instanceId":"511156A615FCDCDF"} and 1 scanners and knownAddress {"ip":"fd71:21eb:d0d:0:6830:c110:7883:ea7e","port":5540,"type":"udp"}
    2026-01-11 19:57:23.265 - debug: matter.0 (156421) 2026-01-11 19:57:23.265 INFO ControllerDiscovery Start Discovering devices using identifier {"instanceId":"511156A615FCDCDF"} ...
    2026-01-11 19:57:23.266 - debug: matter.0 (156421) 2026-01-11 19:57:23.266 INFO ControllerDiscovery Found 1 devices using identifier {"instanceId":"511156A615FCDCDF"}
    2026-01-11 19:57:23.267 - debug: matter.0 (156421) 2026-01-11 19:57:23.267 INFO PeerCommissioner Establish PASE to device SII: 17000 SAI: 2500 SAT: 2000 T: 0 PH: 36 ICD: 0 VP: 4933+16898 PI:
    2026-01-11 19:57:33.920 - info: matter.0 (156421) Discovering stopped. Found 1 devices.
    2026-01-11 19:57:33.920 - info: matter.0 (156421) Sending result to "[{"addresses":[{"ip":"fd71:21eb:d0d:0:6830:c110:7883:ea7e","port":5540,"type":"udp"}],"VP":"4933+16898","SII":17000,"SAI":2500,"SAT":2000,"D":3007,"CM":2,"PH":36,"PI":"","T":0,"ICD":0,"instanceId":"511156A615FCDCDF","deviceIdentifier":"511156A615FCDCDF","SD":11,"V":4933,"P":16898}]"
    2026-01-11 19:59:39.015 - debug: matter.0 (156421) Client "1768157191741-system.adapter.admin.0-gui: disconnect
    2026-01-11 19:59:39.016 - debug: matter.0 (156421) Unsubscribe from 1768157191741-system.adapter.admin.0-gui
    Mir sieht es danach aus als ob das Device erkannt wird, allerdings dann nichts weiter passiert.
    Was kann hier das Problem sein?
    FabioF 1 Antwort Letzte Antwort
    • FredFF FredF
      FabioF Offline
      FabioF Offline
      Fabio
      schrieb am zuletzt editiert von Fabio
      #103
      @FredF gute Frage das sollte sich evtl.mal @apollon77 @feuersturm anschauen.
      Was hast du den für ein Setup, sprich wodrauf läuft ioBroker?
      Fabio
      Iobroker:
      • Matter over Thread Hilfe
      • FabioF Fabio
        Fabio
        FredFF Online
        FredFF Online
        FredF
        #104
        @Fabio Danke für deine Rückmeldung.
        Natürlich ist es ein Docker Container, der läuft auf einem Unraid Server.
        Da die Alexa über den Matter Adapter bei mir läuft, gehe ich davon aus, das es daran nicht liegt...
        • FredFF FredF
          FabioF Offline
          FabioF Offline
          Fabio
          #105
          @FredF bitte gehe das noch mal durch https://github.com/ioBroker/ioBroker.matter/wiki/Troubleshooting
          Fabio
          Iobroker:
          • FabioF Fabio
            Fabio
            FredFF Online
            FredFF Online
            FredF
            #106
            @Fabio Danke für den Link...
            Das hatte ich natürlich gelesen, hätte allerdings weiter runter scrollen... nach Einstellen einer ipv6 Route wie im WIKI beschrieben, konnte ich den Sensor mit der Visu App (anders nicht probiert) anlernen
            • K K_o_bold
              ich bräuchte nun auch mal Hilfe beim Einrichten meines ersten Matter Gerätes.
              Folgende Situation:
              Iobroker wird im Docker-Container im "host" Mode betrieben.
              In der FritzBox sollten die IPv6 EInstellungen korrekt sein.
              Mein Matter Hub ist: Switchbot Hub mini - matter enabled
              Das Gerät welches ich in Iobroker einbinden und steuern will ist: Switchbot lock pro
              Ich habe schon erfolgreich den Hub und das "lock" eingebunden, allerdings gibt es keine Datenpunkte. Woran könnte das liegen?
              Spiecky
              #107
              @k_o_bold
              ich habe einen Switchbot Hub2 inkl. dem integrierten Temperaturmesser und Luftfeuchtigskeitsmesser in iobroker eingebunden. Dort musste ich bei allen Geräten aufs Zahnrad klicken und dann bei Knoten konfigurieren 2x "Ja" auswählen. Erst danach hatte ich jede Menge Datenpunkte. Unter anderem auch die Temperatur und Luftfeuchtigkeit. Mein Problem ist jetzt nur, dass sich die Werte nicht aktualisieren, sondern auf den Wert stehen bleiben, bei Einrichtung. Also wenn mir da jemand weiterhelfen kann.......
              FabioF S 2 Antworten Letzte Antwort
              • S Spiecky
                @k_o_bold
                FabioF Offline
                FabioF Offline
                Fabio
                #108
                @Spiecky ich denke das wird wohl nicht unterstüzt, wenn der Temperaturfühler und Feuchtigkeitsmesser Bestandteil des Hubs sind.
                Normalerweise kommen die Daten ja auch ohne das man 2x ja wählt. Ich empfehle dir das auf Github zu melden. Dann kann @apollon77 sich das mal anschauen, ein Log wäre da auch gut und alle vorhandenen Datenpunkte.
                Herzliche Grüße
                Fabio
                Iobroker:
                • FabioF Fabio
                  Herzliche Grüße
                  Fabio
                  Spiecky
                  #109
                  @Fabio Hi Fabio, Danke für den Tip mit Github. Ich bin ja total angetan von dem Switchbot Vision. Gerne würde ich diesen Standalone mit iobroker verwenden. Dies ist scheinbar (noch) nicht möglich. Deshalb hatte ich mit den Hub2 geholt, mit der Hoffnung, dass es darüber geht. Pustekuchen. Das Keypad Vision lässt sich leider nur mit dem Lock koppeln. Ich hoffe, dass ich darüber dann per Matter irgendwie zu iobroker komme. Mal schauen. Wenn ich hier mit den Geräten mehr Klarheit habe, werde ich dann alle Details sammeln und dann evtl. Wünsche bei Github beantragen.
                  Danke erstmal an alle, die das Projekt Matter in iobroker vorantreiben.
                  P.S. Ich schaue auch mal, wo ich clevere "Programmierer" auftreiben kann, die vielleicht die Standalone-Variante mit dem Switchbot Vision in iobroker an sich nehmen. Ich habe den jetzt schon etwas testen können und bin bis jetzt sehr begeistert - oh...sorry....gehört aber ja nicht hier her....ist ja ein anderes Thema.
                  • S Spiecky
                    @k_o_bold
                    Spiecky
                    #110
                    sagte in Matter-Controller (Matter Geräte in ioBroker einbinden):
                    @k_o_bold
                    Kleine aber vielleicht wichtige Ergänzung:
                    Ich habe unter den vielen Datenpunkten vom Switchbot-Hub2 jetzt doch noch Datenpunkte der Temperatur und Luftfeuchtigkeit gefunden, die auch aktualisiert werden. Also für alle, die Switchbot über den Matter-Adapter mit iobroker verbinden wollen - die o.g. Kombi funktioniert. Das Keypad Vision Standalone leider nicht. Dies kann man scheinbar aktuell nur mit dem Key-Lock verbinden. Ob und wie man dies dann über den Hub-2 in iobroker nutzen kann, werde ich testen, wenn mein Switchbot Lock Ultra geliefert wurde. Habe mir das jetzt extra nur gekauft, um es als "Vermittlungsstelle" einzusetzen. Meine Haustür hat bereits ein elektr. Schloss integriert und braucht das eigentlich nicht. Naja....irgendwas ist ja immer.....
                      manne01
                      schrieb am zuletzt editiert von manne01
                      #111
                      Hallo und zunächst vielen Dank für den tollen Adapter!
                      Ich habe eine Frage zum Thema Gerätefirmware-Aktualisierung für per Thread Border Router / Controller eingebundene Geräte:
                      Zunächst kurz mein Setup vom "Nutzen" her gedacht bis runter zur Infrastruktur:
                      • IKEA Kajplats LED Bulbs (unterstützen Matter over Thread). Noch auf Original Firmware v1.1.0.
                      • Diese sind erfolgreich eingebunden in einen Aqara Hub M100 (der kleinste) der als Thread Border Router fungiert. Aqara M100 Firmware V. 4.5.30_0013.0017 (aktuellste laut Aqara App)
                      • Matter Adapter V.0.5.6 (aktuellste). Hier sind die Bulbs ebenfalls erfolgreich eingebunden (im Reiter Controller und basierend auf den Pairing Codes die die Aqara App generiert hat). Ich kann sie also per ioBroker schalten und verwalten - absolut klasse!
                      • Last but not least: IoBroker Server v7.7.22 mit Note v22 (Docker-Based) auf einem NAS-System.
                      Grundsätzlich sieht das alles gut aus.
                      Nun habe ich beobachtet, dass sich die IKEA Bulbs (alle, in nicht erkennbarem Wechsel) regelmäßig einfach so einzeln mal anschalten. Ohne erkennbaren Grund.
                      Hintergrund: Im Netz wird beschrieben, dass das mit HomeKit Einstellungen zu tun haben soll. Allerdings habe ich kein HomeKit und wüßte auch nichts von Adaptive Lighning Komponenten in meinem Heimnetzwerk. Einen IKEA Digitera Hub habe ich auch nicht. Gehört habe ich, dass der Fehler durch ein IKEA Firmware Update beseitigt worden sein soll. So oder so wünsche ich mir natürlich aktuelle Firmwares auf den Matter/Thread-Geräten.
                      Nun zur Frage hier im Forum:
                      **Ist es in meinem Setup grundsätzlich unterstützt, dass ein Matter-Firmware update per OTA auf dem Device installiert wird? ** Grundsätzlich kann der iobroker-Matter-Adapter dies laut Dokumentation (Zitat "The Matter adapter supports firmware updates for devices connected via the Controller"). Warum klappt das in meinem Setup offenbar nicht? Wie sollte es laufen? Was muss ich ändern, damit es möglich wird?
                      (Die großen Ökosysteme wie Google und Apple etc. sollen dabei nicht eingesetzt werden!)
                      Was ich schon versucht habe:
                      1. im Distributed Compliance Ledger (DCL) "the official Matter certification database" (https://webui.dcl.csa-iot.org/) nachgeschaut ob die FW 1.2.0 überhaupt gelistet ist -> sieht für mich gut aus (Version 16908288)
                      2. im Matter Adapter an den Geräten nach Update Icons gesucht -> leider keine
                      3. Per Aqara App Firmware Update der Devices machen -> geht nicht, nichtmal Version wird angezeigt, geht vermutlich alles nur für Aqara Devices?!
                      4. im Matter Adapter "Erweitertes Debug-Logging" für das Matter-Protokoll aktivieren (nur sichtbar mit der Protokollebene „Debug“) --> bringt bisher keine weitere Logs/Erkenntnisse
                      5. im Matter Adapter, Reiter General tab eine "Custom OTA Updates" section gesucht, aber nicht gefunden. Dort hätte ich gerne "Enable Allow custom/unofficial OTA updates" eingeschaltet und es auf diesem Wege versucht
                      6. Überlegt ob ich eine IoBroker Pro Lizenz brauche -> so wie ich das lese für Controller-integrierte Geräte aber nicht
                      7. Überlegt ob es am Aqara-TBR liegt und mich gefragt was hier für Thread (und auch gleich Zigbee?) günstige und offenste Alternativen sind. In https://github.com/ioBroker/ioBroker.matter/wiki/Einleitung-und-wichtige-Hinweise#iobroker wird z.B. ein selber zu flashender USB-Stick beschrieben?! Hat das jemand gemacht? Es gibt zB Sonoff Sticks, aber die scheinen dann doch auch wieder einen TBR zu benötigen? Gibt es da inzwischen etwas komplettes fertiges was für ioBroker-User empfohlen wird?
                      Kann jemand meine Frage beantworten? Hat jemand Tipps für mich? Danke im Voraus für jede Unterstützung!
                      Schöne Grüße
                      Manne
                      • M manne01
                        Schöne Grüße
                        Manne
                        #112
                        @manne01 sagte:
                        Doch
                        Bitte Formatierung deines Posts prüfen!
                          manne01
                          #113
                          Hallo und danke für die super schnelle Rückmeldung - dieser Knopf existiert bei mir allerdings nicht. Ebenso nicht die beiden blauen Topologie-Buttons.
                          • M manne01
                            FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #114
                            @manne01 Das Feature für OTA Update kam mit der Adapter Version 1.0.0 , welche aktuell im Beta Repository zur Verfügung steht. Du bist auf der Stable Version.
                            Changelog 1.0.0
                            https://github.com/ioBroker/ioBroker.matter#100-2026-02-25
                              manne01
                              #115
                              Ah, Danke @feuersturm ! 🙈 Jetzt macht alles Sinn. Das habe ich einfach übersehen, tut mir leid. Jetzt sieht es besser aus und alle Knöpfe und Updates laufen! Spitze!
                                deta
                                schrieb am zuletzt editiert von deta
                                #116
                                ich habe mir heute von Ikea den
                                Timmerflotte für Themperatur etc. mitgenommen.
                                Er ist ja komplett Matter.
                                Ich wollte den direkt ohne Hub in den Matter Adapter einbringen, aber auch wenn ich den Code eingebe, wird er nicht erkannt.
                                Wie bekomme ich den in den Matter Adapter?
                                cu Deta
                                • D deta
                                  cu Deta
                                  FabioF Offline
                                  FabioF Offline
                                  Fabio
                                  #117
                                  @deta sagte:
                                  Lies dir das mal bittte alles durch
                                  https://forum.iobroker.net/post/1322416
                                  Iobroker:
                                  • FabioF Fabio
                                    @deta sagte:
                                    deta
                                    #118
                                    @Fabio Hatte ich bereits.
                                    Ich hab aber keinen IKEA Digitera Hub.
                                    Ich habe eine Alexa Echo 5, dort habe ich z.b. den Timmerflotte drinnen.
                                    Wie bekomme ich aber die Daten jetzt in den Matter Controller?
                                    Der Matter Controller ist mit der Alexa App via Matter eingebunden.
                                    • D deta
                                      FabioF Offline
                                      FabioF Offline
                                      Fabio
                                      #119
                                      @deta sagte:
                                      ... du musst ihn in der Alexa App teilen zum pairing freigeben dann den Code in den Matter Adapter eintragen.
                                      Du hast nicht geschrieben das du in an dem Alexa Hub hattest.
                                      Im übrigen glaube ich nicht das der ein Thread Border Router ist.
                                      Zitat**
                                      Ich wollte den direkt ohne Hub in den Matter Adapter einbringen, aber auch wenn ich den Code eingebe, wird er nicht erkannt.**
                                      Iobroker:
                                      • FabioF Fabio
                                        @deta sagte:
                                        deta
                                        #120
                                        @Fabio sagte:
                                        Wo finde ich das?
                                        Ich habe den QR Code im Matter Adapter eingerichtet. In der Alexa App gescannt, wo er es verbunden hat. Somit geht die Brigde.
                                        Es geht ja jetzt um die Matter Geräte, es wird immer von einen Border Router gepsprochen und das sollte doch die Alexa machen. Diese hatte ja sofort den Timmerflotte erkannt.
                                        Also braucht man um Geräte in den Matter Adapter zu bringen, doch noch einen Hub??
                                        Irgendwie gerade auf der Leitung stehen.
                                        • D deta
                                          @Fabio sagte:
                                          Wo finde ich das?
                                          FabioF Offline
                                          FabioF Offline
                                          Fabio
                                          #121
                                          @deta sagte:
                                          Hier lesen https://github.com/ioBroker/ioBroker.matter/wiki/Einbindung-von-Matter-Geräten-in-ioBroker-(Tab-"Controller")
                                          Iobroker:
