  3. Einsteigerfragen
  4. Installation
  5. ESPHome fordert neue Pillow Version
49 Beiträge 6 Kommentatoren 3.6k Aufrufe 5 Beobachtet
  • B bernd33-1
    Ok, hier die Kopie von iob diag:
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: raspi5
           Icon name: computer
              Kernel: Linux 6.12.75+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     16:38:24 up 5 days,  8:08,  2 users,  load average: 0.12, 0.08, 0.02
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2026-05-14 16:38:24 CEST
               Universal time: Thu 2026-05-14 14:38:24 UTC
                     RTC time: Thu 2026-05-14 14:38:24
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    bernd
    HOME=/home/bernd
    GROUPS=bernd adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.2G        385M        2.8G         23M        1.2G        3.9G
    Swap:           2.1G        2.1M        2.1G
    Total:          6.4G        387M        5.0G
    Active iob-Instances:   1
             4045 M total memory
              367 M used memory
              243 M active memory
              815 M inactive memory
             2716 M free memory
              147 M buffer memory
              972 M swap cache
             2047 M total swap
                2 M used swap
             2045 M free swap
    top - 16:38:25 up 5 days,  8:08,  2 users,  load average: 0.12, 0.08, 0.02
    Tasks: 188 total,   1 running, 187 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4045.7 total,   2715.3 free,    368.3 used,   1120.0 buff/cache
    MiB Swap:   2048.0 total,   2046.0 free,      2.0 used.   3677.4 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  2.0G     0  2.0G   0% /dev
    tmpfs          tmpfs     810M   15M  796M   2% /run
    /dev/sda2      ext4      229G  7.5G  213G   4% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     2.0G  9.3M  2.0G   1% /tmp
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     405M   32K  405M   1% /run/user/1000
    [Sat May  9 08:30:10 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Sat May  9 08:30:10 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
    [Sat May  9 08:30:11 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.5G    /var/
    245M    /var/cache
    240M    /var/cache/apt
    183M    /var/lib
    147M    /var/lib/apt
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    42M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    335M    /opt/iobroker/iobroker-data/
    166M    /opt/iobroker/iobroker-data/files
    107M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    4.4M    /opt/iobroker/iobroker-data/backup-objects/2026-05-14_16-30_objects.jsonl.gz
    4.4M    /opt/iobroker/iobroker-data/backup-objects/2026-05-14_14-30_objects.jsonl.gz
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** ZigBee Settings ***
    ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspi5              raspi5 (version: 7.0.7, hostname: raspi5        , alive, uptime: 461126)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
      system.adapter.cloud.0                  : cloud                 : raspi5                                   - disabled
      system.adapter.devices.0                : devices               : raspi5                                   -  enabled
      system.adapter.discovery.0              : discovery             : raspi5                                   - disabled
      system.adapter.echarts.0                : echarts               : raspi5                                   -  enabled
      system.adapter.esphome.0                : esphome               : raspi5                                   -  enabled
      system.adapter.feiertage.0              : feiertage             : raspi5                                   -  enabled
      system.adapter.history.0                : history               : raspi5                                   -  enabled
      system.adapter.hm-rega.0                : hm-rega               : raspi5                                   -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : raspi5                                   -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : raspi5                                   -  enabled, port: 0
      system.adapter.hmip.0                   : hmip                  : raspi5                                   -  enabled
      system.adapter.ical.0                   : ical                  : raspi5                                   -  enabled
      system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspi5                                   -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.ping.0                   : ping                  : raspi5                                   -  enabled
      system.adapter.telegram.0               : telegram              : raspi5                                   -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.trashschedule.0          : trashschedule         : raspi5                                   -  enabled
      system.adapter.vis.0                    : vis                   : raspi5                                   -  enabled
      system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 192.168.0.5, run as: admin
      system.adapter.zigbee.0                 : zigbee                : raspi5                                   -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.7.22 [Updatable]
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "cloud"        : 6.0.1    , installed 5.0.1  [Updatable]
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "ical"         : 1.20.0   , installed 1.20.0
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
    Objects and States
    Objects:        3385
    States:         2368
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 41
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6106       920/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4213       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6108       920/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          3774       1/init
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5178       1/init
    udp        0      0 0.0.0.0:35466           0.0.0.0:*                           101        6483       701/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        6481       701/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          4214       1/init
    udp6       0      0 :::5353                 :::*                                101        6482       701/avahi-daemon: r
    udp6       0      0 :::34049                :::*                                101        6484       701/avahi-daemon: r
    2026-05-14 16:35:51.819  - info: hmip.0 (1215) terminating
    2026-05-14 16:35:51.823  - info: telegram.0 (29290) terminating
    2026-05-14 16:35:51.824  - info: telegram.0 (29290) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-05-14 16:35:51.837  - info: trashschedule.0 (1295) terminating
    2026-05-14 16:35:51.844  - info: zigbee.0 (1142) Saved local configuration data
    2026-05-14 16:35:51.875  - info: host.raspi5 instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.920  - info: host.raspi5 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.920  - info: host.raspi5 instance system.adapter.hmip.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.945  - info: host.raspi5 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.945  - info: host.raspi5 instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.966  - info: host.raspi5 instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.997  - info: host.raspi5 instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.997  - info: host.raspi5 instance system.adapter.trashschedule.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:52.015  - info: host.raspi5 instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:52.062  - info: host.raspi5 instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:52.310  - info: host.raspi5 instance system.adapter.ping.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:52.314  - info: host.raspi5 stopInstance timeout system.adapter.telegram.0 killing pid 29290
    2026-05-14 16:35:52.334  - warn: host.raspi5 instance system.adapter.telegram.0 terminated due to SIGKILL
    2026-05-14 16:35:52.334  - info: host.raspi5 instance system.adapter.telegram.0 terminated with code null ()
    2026-05-14 16:35:52.345  - info: host.raspi5 instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:52.356  - info: host.raspi5 instance system.adapter.echarts.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:55.367  - info: zigbee.0 (1142) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-05-14 16:36:01.027  - info: host.raspi5 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-05-14 16:36:01.027  - info: host.raspi5 All instances are stopped.
    2026-05-14 16:36:01.101  - info: host.raspi5 terminated
    @bernd33-1 sagte:
    Das ist gut so!
    Aber darüber hättest du niemals wie von dir beschrieben installieren können.
      @mcm1957 sagte:
      Ergo ziemlich sicher manuell rumgeschoben statt den Workflow zu verwenden.
      Schon gar nicht im stable!
      @bernd33-1 sagte:
      Ich hab ESPHome unter den Adapter ausgewählt, Installiert und dann eine Instanz hinzugefügt. Also hier:
      Und nur da kommt die Meldung "nicht gewartet"
      mcm1957M Online
      mcm1957M Online
      mcm1957
      @Homoran sagte:
      @mcm1957 sagte:
      @bernd33-1 sagte:
      Was meinst du mit stable?
      Der Adapter ist gar nicht im Stable. Natürlich kommt beim Adapter die Meldung "nicht gewartet" wenn du das stable Repository aktiv hast und einen Adapter verwendest der nicht als stabil eingestuft wurde - sprich nicht im stable ist. Das ist für alle Adapter so die oihre Maintainer noch nicht als stabil und für produktive Systeme geeignet eingestuft haben.
      "nicht gewartet" heißt dass sie im einegstellten Repoistory keine Wartung und Updates erhalten. Und das timmt jedenfalls.
      Und was diese Anzeige betrifft - die ist (bekanntermaßen) fehlerhaft falls npm nicht richtig verwendet wird:
      esphome
      github: 0.7.0-beta.4
      latest: 0.7.0-beta.1 for 76 days
      stable: -.-.-
      Hier wid das npm Tag und nicht wie richtig die im Lates Repository angebitene Version (die auch im Admin angeziegt wird) verwendet.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • B bernd33-1
        ```bash
        Script v.2026-01-31
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        bernd
        HOME=/home/bernd
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
                 4045 M total memory
                  367 M used memory
                  243 M active memory
                 2716 M free memory
                  147 M buffer memory
                  972 M swap cache
                 2047 M total swap
                    2 M used swap
                 2045 M free swap
        *** FILESYSTEM ***
        /var:
        2.5G    /var/
        245M    /var/cache
        240M    /var/cache/apt
        183M    /var/lib
        147M    /var/lib/apt
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.7
        /usr/bin/npx            10.9.7
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.22
        javascript:     9.0.18
        Adapter State
        + instance is alive
        Objects and States
        Objects:        3385
        States:         2368
        @bernd33-1 sagte:
        Bring das Ding dringend auf Stand...
        iob stop
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Die ioBroker-Adapter danch auch aktualisieren.
          @bernd33-1 sagte:
          Das ist gut so!
          bernd33-1
          @Homoran Sorry, ich hab so gut es geht versucht zu beschreiben, was ich getutet hab.
          Kleine Frage. Wenn meine ESPHome Installation wenig optimal ist. Kann/Soll ich dann den Adapter deinstallieren und nochmal installieren? Und dann prüfen ob alles gut ist?
            @bernd33-1 sagte:
            iob stop
            sudo apt update
            sudo reboot
            bernd33-1
            @Thomas-Braun Ich hab das Ding mit Dringlichkeit auf Stand gebracht und die Adapter aktualisiert.
            Die Frage über meinen ESPHome Adapter bleibt noch: Soll ich den deinstallieren und dann mit:
            iob add esphome --debug
            neu installieren?
            • B bernd33-1
              neu installieren?
              @bernd33-1 sagte:
              Im Moment ist der gar nicht installiert.
              Wenn deine Installation jetzt in Gänze auf Stand ist würde ich kurzzeitig das Beta-Repo aktivieren, den esphome von dort installieren und dann wieder auf das stable-Repository wechseln.
                @bernd33-1 sagte:
                bernd33-1
                @Thomas-Braun mal so zwischen durch.... danke für deine Geduld :-)
                Ok, also... der ESPHome Adapter ist aber installiert. Ich war auch verwundert in der IOB diag steht der nicht gell?
                • B bernd33-1
                  @bernd33-1 sagte:
                  Dann ist zwar die Instanzenkonfiguration noch da, aber due Adapterinstallation schief.
                  Also einfach drüberinstallieren
                    @bernd33-1 sagte:
                    bernd33-1
                    @Homoran Auch danke an dich für deine Geduld :-)
                    Drüber installieren bedeutet das ausführen:
                    • B bernd33-1
                      ```bash
                      Script v.2026-01-31
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                      CPU threads: 4
                      Current issues:
                                    NTP service: active
                                RTC in local TZ: no
                      bernd
                      HOME=/home/bernd
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                               4045 M total memory
                                367 M used memory
                                243 M active memory
                               2716 M free memory
                                147 M buffer memory
                                972 M swap cache
                               2047 M total swap
                                  2 M used swap
                               2045 M free swap
                      *** FILESYSTEM ***
                      /var:
                      2.5G    /var/
                      245M    /var/cache
                      240M    /var/cache/apt
                      183M    /var/lib
                      147M    /var/lib/apt
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.9.7
                      /usr/bin/npx            10.9.7
                      nodejs:
                        Version table:
                           20.19.2+dfsg-1 500
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.7.22
                      javascript:     9.0.18
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        3385
                      States:         2368
                      @bernd33-1 sagte:
                      iob repo unset stable
                      iob repo set beta
                      iob update
                      iob add esphome --host raspi5 --debug
                      iob repo unset beta
                      iob repo set stable
                      iob update
                      Und dann nochmal zeigen was danach im
                      iob diag
                      ausgespuckt wird.
                      • B bernd33-1
                        @bernd33-1 sagte:
                        Umstellen auf beta
                        Repo neu laden
                        Installieren wie du es beschrieben hast
                          bernd33-1
                          schrieb am zuletzt editiert von bernd33-1
                          Ok, neu installiert:
                          iob repo set beta
                          iob update
                          iob repo unset beta
                          iob repo set stable
                          iob update
                          Hier das IOB DEBUG. Unter Adapter State ist der esphome aufgeführt aber unter Installed ioBroker-Adapters nicht.
                          ```bash
                          Script v.2026-01-31
                          *** BASE SYSTEM ***
                                 Icon name: computer
                                    Kernel: Linux 6.18.29+rpt-rpi-2712
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                           17:25:18 up 31 min,  1 user,  load average: 0.28, 0.30, 0.32
                          CPU threads: 4
                          Current issues:
                                         Local time: Thu 2026-05-14 17:25:18 CEST
                                     Universal time: Thu 2026-05-14 15:25:18 UTC
                                           RTC time: Thu 2026-05-14 15:25:18
                                        NTP service: active
                                    RTC in local TZ: no
                          bernd
                          HOME=/home/bernd
                          iobroker
                          HOME=/home/iobroker
                          SUDO_HOME=/home/bernd
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Mem:            4.2G        2.1G        1.2G         24M        1.2G        2.1G
                          Swap:           2.1G          0B        2.1G
                          Total:          6.4G        2.1G        3.3G
                          Active iob-Instances:   17
                                   4045 M total memory
                                   2007 M used memory
                                   1968 M active memory
                                    666 M inactive memory
                                   1101 M free memory
                                     99 M buffer memory
                                   1005 M swap cache
                                   2047 M total swap
                                      0 M used swap
                                   2047 M free swap
                          top - 17:25:18 up 31 min,  1 user,  load average: 0.28, 0.30, 0.32
                          Tasks: 184 total,   1 running, 183 sleeping,   0 stopped,   0 zombie
                          MiB Mem :   4045.1 total,   1099.2 free,   2009.8 used,   1105.9 buff/cache
                          MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   2035.3 avail Mem
                          0 loaded units listed.
                          *** FILESYSTEM ***
                          tmpfs          tmpfs     810M   14M  796M   2% /run
                          /dev/sda2      ext4      229G  7.6G  212G   4% /
                          tmpfs          tmpfs     2.0G  9.2M  2.0G   1% /tmp
                          [Thu May 14 16:53:41 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
                          [Thu May 14 16:53:41 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
                          [Thu May 14 16:53:42 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
                          /var:
                          2.5G    /var/
                          245M    /var/cache
                          240M    /var/cache/apt
                          186M    /var/lib
                          146M    /var/lib/apt/lists
                          364M    /opt/iobroker/iobroker-data/
                          42M     /opt/iobroker/iobroker-data/objects.jsonl
                          USB-Devices by-id:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.9.7
                          /usr/bin/npx            10.9.7
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          raspi5              raspi5 (version: 7.0.7, hostname: raspi5        , alive, uptime: 1892)
                          admin:          7.8.23
                          javascript:     9.0.18
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
                          + system.adapter.echarts.0                : echarts               : raspi5                                   -  enabled
                          + system.adapter.esphome.0                : esphome               : raspi5                                   -  enabled
                          + system.adapter.history.0                : history               : raspi5                                   -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : raspi5                                   -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : raspi5                                   -  enabled, port: 0
                          + system.adapter.hm-rpc.1                 : hm-rpc                : raspi5                                   -  enabled, port: 0
                          + system.adapter.hmip.0                   : hmip                  : raspi5                                   -  enabled
                          + system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
                          + system.adapter.mqtt.0                   : mqtt                  : raspi5                                   -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.ping.0                   : ping                  : raspi5                                   -  enabled
                          + system.adapter.telegram.0               : telegram              : raspi5                                   -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.trashschedule.0          : trashschedule         : raspi5                                   -  enabled
                          + system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 192.168.0.5, run as: admin
                          + system.adapter.zigbee.0                 : zigbee                : raspi5                                   -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                          + instance is alive
                          Adapter    "admin"        : 7.8.23   , installed 7.8.23
                          Adapter    "cloud"        : 6.0.1    , installed 6.0.1
                          Objects and States
                          Objects:        3308
                          States:         2447
                          Pending systemupdates: 0
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       9227       1244/io.mqtt.0
                          tcp        0      0 192.168.0.5:2010        0.0.0.0:*               LISTEN      1001       6027       1096/io.hm-rpc.1
                          tcp        0      0 192.168.0.5:2001        0.0.0.0:*               LISTEN      1001       8497       1080/io.hm-rpc.0
                          tcp        0      0 192.168.0.5:8082        0.0.0.0:*               LISTEN      1001       8710       1260/io.web.0
                          tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       18746      3411/python3
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7681       900/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6846       900/iobroker.js-con
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4350       1/init
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5775       913/sshd: /usr/sbin
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8877       1404/io.admin.0
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          4351       1/init
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          5777       913/sshd: /usr/sbin
                          udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       18752      3411/python3
                          udp        0      0 192.168.0.5:5353        0.0.0.0:*                           1001       18751      3411/python3
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18747      3411/python3
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        5022       699/avahi-daemon: r
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2573       1/init
                          udp        0      0 0.0.0.0:57922           0.0.0.0:*                           101        5024       699/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                101        5023       699/avahi-daemon: r
                          udp6       0      0 :::111                  :::*                                0          4352       1/init
                          udp6       0      0 :::48012                :::*                                101        5025       699/avahi-daemon: r
                          2026-05-14 17:22:16.520  - info: esphome.0 (3333) [ESPHome - Console] 2026-05-14 17:22:16,519 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /opt/iobroker/iobroker-data/esphome.0...
                          2026-05-14 17:22:42.946  - info: javascript.0 (996) script.js.common.Heizung.3_Heizbedarf: Es gibt kein Heizbedarf
                          2026-05-14 17:22:42.947  - info: javascript.0 (996) script.js.common.Heizung.ZweipunktregelungThermostate.NinaZimmer: Aktivität Nina Zimmer
                          2026-05-14 17:22:56.934  - info: admin.0 (1404) ==> Connected system.user.admin from ::ffff:192.168.0.79
                          2026-05-14 17:23:02.496  - info: admin.0 (1404) <== Disconnect system.user.admin from ::ffff:192.168.0.79 admin
                          2026-05-14 17:23:18.835  - info: admin.0 (1404) ==> Connected system.user.admin from ::ffff:192.168.0.79
                          2026-05-14 17:23:30.720  - info: admin.0 (1404) <== Disconnect system.user.admin from ::ffff:192.168.0.79 admin
                          2026-05-14 17:23:51.002  - info: host.raspi5 stopInstance system.adapter.esphome.0 (force=false, process=true)
                          2026-05-14 17:23:51.005  - info: esphome.0 (3333) Got terminate signal TERMINATE_YOURSELF
                          2026-05-14 17:23:51.006  - info: esphome.0 (3333) terminating
                          2026-05-14 17:23:51.007  - info: esphome.0 (3333) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2026-05-14 17:23:51.046  - info: host.raspi5 stopInstance system.adapter.esphome.0 send kill signal
                          2026-05-14 17:23:51.509  - info: esphome.0 (3333) terminating
                          2026-05-14 17:23:51.530  - info: host.raspi5 instance system.adapter.esphome.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2026-05-14 17:23:54.852  - info: host.raspi5 instance system.adapter.esphome.0 in version "0.6.3" started with pid 3390
                          2026-05-14 17:23:55.615  - info: esphome.0 (3390) starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.esphome, node: v22.22.2, js-controller: 7.0.7
                          2026-05-14 17:23:56.199  - info: esphome.0 (3390) Native Integration of ESPHome Dashboard enabled, making environment ready
                          2026-05-14 17:23:56.696  - info: esphome.0 (3390) Starting ESPHome Dashboard
                          2026-05-14 17:23:56.699  - warn: esphome.0 (3390) Auto Discovery disabled, new devices (or IP changes) will NOT be detected automatically!
                          2026-05-14 17:23:56.994  - info: esphome.0 (3390) [ESPHome - Console] 2026-05-14 17:23:56,994 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /opt/iobroker/iobroker-data/esphome.0...
                          2026-05-14 17:24:30.989  - info: admin.0 (1404) ==> Connected system.user.admin from ::ffff:192.168.0.79
                          2026-05-14 17:25:19.698  - info: javascript.0 (996) script.js.common.Heizung.3_Heizbedarf: Es gibt kein Heizbedarf
                          2026-05-14 17:25:19.698  - info: javascript.0 (996) script.js.common.Heizung.ZweipunktregelungThermostate.NinaZimmer: Aktivität Nina Zimmer
                            Was kommt beiiob install esphome@0.6.3 --debug?
                            Wenn etwas wie "ist bereits installiert kommt:
                            iob upgrade esphome@0.6.3 --debug
                              bernd33-1
                              @Homoran sagte:
                              adapter "esphome" already installed. Use "upgrade" to upgrade to a newer version.
                              und
                              Adapter "esphome" is not in the repository and cannot be updated.
                              Ok, ich muss auf beta umstellen? Gemacht. Und dann der Ablauf:
                              bernd@raspi5:~ $ iob repo unset stable
                              Repository "stable" deactivated.
                              Active repo(s):
                              bernd@raspi5:~ $ iob repo set beta
                              Repository "beta" set as active.
                              Active repo(s): beta
                              bernd@raspi5:~ $ iob update
                              Used repository: beta
                              Adapter    "admin"        : 7.8.24   , installed 7.8.23 [Updatable]
                              Adapter    "backitup"     : 3.3.17   , installed 3.3.14 [Updatable]
                              Adapter    "devices"      : 2.0.12   , installed 1.2.14 [Updatable]
                              Adapter    "esphome"      : 0.6.3    , installed 0.6.3
                              Adapter    "feiertage"    : 1.4.0    , installed 1.3.0  [Updatable]
                              Adapter    "hm-rpc"       : 3.0.2    , installed 3.0.1  [Updatable]
                              Adapter    "ical"         : 1.20.1   , installed 1.20.0 [Updatable]
                              Adapter    "javascript"   : 9.2.2    , installed 9.0.18 [Updatable]
                              Controller "js-controller": 7.1.2    , installed 7.0.7  [Updatable]
                              Adapter    "ping"         : 2.2.2    , installed 1.7.9  [Updatable]
                              Adapter    "trashschedule": 5.3.0    , installed 3.3.0  [Updatable]
                              Adapter    "web"          : 8.1.0    , installed 8.0.0  [Updatable]
                              Adapter    "ws"           : 4.1.0    , installed 4.0.0  [Updatable]
                              Adapter    "zigbee"       : 3.4.3    , installed 3.3.5  [Updatable]
                              bernd@raspi5:~ $ iob upgrade esphome@0.6.3 --debug
                              Would you like to reinstall version 0.6.3 of esphome now? [(y)es, (n)o]: y
                              Update esphome from @0.6.3 to @0.6.3
                              Uninstall npm packet "iobroker.esphome" for a clean re-installation
                              removed 106 packages in 2s
                              190 packages are looking for funding
                                run `npm fund` for details
                              NPM version: 10.9.7
                              Installing iobroker.esphome@0.6.3... (System call)
                              npm warn deprecated @mongodb-js/zstd@1.2.2: 1.x versions of this package are deprecated, please use 2.x instead
                              npm warn deprecated @mongodb-js/zstd-linux-arm64-gnu@1.2.2: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
                              added 105 packages in 7s
                              198 packages are looking for funding
                              Updating objects from io-package.json for adapter "esphome" with version "0.6.3"
                              upload [26] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
                              upload [20] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [19] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [18] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [17] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [16] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [15] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                              upload [14] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [13] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/ESPHomeDashboardUrl.png img/ESPHomeDashboardUrl.png image/png
                              upload [12] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/ESPhomeDashboardIP.png img/ESPhomeDashboardIP.png image/png
                              upload [11] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/connectionIssue.png img/connectionIssue.png image/png
                              upload [10] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/connectionOK.png img/connectionOK.png image/png
                              upload [9] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
                              upload [8] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/deviceTabEmpty.png img/deviceTabEmpty.png image/png
                              upload [7] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/deviceTree.png img/deviceTree.png image/png
                              upload [6] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/flashFromThisComputer.png img/flashFromThisComputer.png image/png
                              upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/proxy.png img/proxy.png image/png
                              upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
                              upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                              upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
                              upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/tsconfig.json tsconfig.json application/json
                              upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
                              bernd@raspi5:~ $
                              bernd@raspi5:~ $
                              bernd@raspi5:~ $ iob repo unset beta
                              Repository "beta" deactivated.
                              Active repo(s):
                              bernd@raspi5:~ $ iob repo set stable
                              Repository "stable" set as active.
                              • B bernd33-1
                                @Homoran sagte:
                                und
                                Active repo(s):
                                NPM version: 10.9.7
                                bernd@raspi5:~ $
                                bernd@raspi5:~ $
                                Active repo(s):
                                @bernd33-1 und wie läuft es jetzt?
                                  bernd33-1
                                  @Homoran Es Läuft. Hab den Adapter jetzt ja 2 mal deinstalliert und dann neu installiert.
                                  Es kommen nun nach der Installation auch nichtmehr die Fehlermeldungen die ich am Anfang dieses Threads gepostet hab. Scheint zu passen :-)
                                  • B bernd33-1
                                    Dann lass es jetzt so.
                                    Auf meinem Testsystem wird die Version allerdings ausgegeben:
                                    thomas@testpi:~ $ iob list adapters
                                    │ (index) │ id                          │ name         │ version  │ upgrade policy │
                                    │ 0       │ 'system.adapter.admin'      │ 'admin'      │ '7.8.23' │ 'none'         │
                                    │ 1       │ 'system.adapter.backitup'   │ 'backitup'   │ '3.3.14' │ 'none'         │
                                    │ 2       │ 'system.adapter.discovery'  │ 'discovery'  │ '5.0.0'  │ 'none'         │
                                    │ 3       │ 'system.adapter.esphome'    │ 'esphome'    │ '0.6.3'  │ 'none'         │
                                    │ 4       │ 'system.adapter.javascript' │ 'javascript' │ '9.0.18' │ 'none'         │
                                    │ 5       │ 'system.adapter.rpi2'       │ 'rpi2'       │ '3.0.2'  │ 'none'         │
                                    │ 6       │ 'system.adapter.web'        │ 'web'        │ '8.0.0'  │ 'none'         │
                                    │ 7       │ 'system.adapter.ws'         │ 'ws'         │ '4.0.0'  │ 'none'         │
                                    thomas@testpi:~ $
                                      thomas@testpi:~ $
                                      @Thomas-Braun sagte:
                                      Vielleicht hilft bei @bernd33-1 noch ein iob upload esphome
                                        bernd33-1
                                        Ich lass es mal jetzt so laufen und beobachte das ganze. Ausschauen tut es jetzt jedenfalls gut.
                                        Danke für die tatkräftige Unterstützung! :-)
                                          michelm16
                                          heute gab es das offizielle Update auf die V0.7.0.
                                          Damit war bei mir der gleiche Fehler wie hier oben beschrieben gelöst.
                                          VG, Michael
