  3. Einsteigerfragen
  4. Installation
  5. ESPHome fordert neue Pillow Version
    6.8k
49 Beiträge 6 Kommentatoren 3.6k Aufrufe 5 Beobachtet
    bernd33-1
    Ok, hier die Kopie von iob diag:
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: raspi5
           Icon name: computer
              Kernel: Linux 6.12.75+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     16:38:24 up 5 days,  8:08,  2 users,  load average: 0.12, 0.08, 0.02
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2026-05-14 16:38:24 CEST
               Universal time: Thu 2026-05-14 14:38:24 UTC
                     RTC time: Thu 2026-05-14 14:38:24
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    bernd
    HOME=/home/bernd
    GROUPS=bernd adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.2G        385M        2.8G         23M        1.2G        3.9G
    Swap:           2.1G        2.1M        2.1G
    Total:          6.4G        387M        5.0G
    Active iob-Instances:   1
             4045 M total memory
              367 M used memory
              243 M active memory
              815 M inactive memory
             2716 M free memory
              147 M buffer memory
              972 M swap cache
             2047 M total swap
                2 M used swap
             2045 M free swap
    top - 16:38:25 up 5 days,  8:08,  2 users,  load average: 0.12, 0.08, 0.02
    Tasks: 188 total,   1 running, 187 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4045.7 total,   2715.3 free,    368.3 used,   1120.0 buff/cache
    MiB Swap:   2048.0 total,   2046.0 free,      2.0 used.   3677.4 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  2.0G     0  2.0G   0% /dev
    tmpfs          tmpfs     810M   15M  796M   2% /run
    /dev/sda2      ext4      229G  7.5G  213G   4% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     2.0G  9.3M  2.0G   1% /tmp
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     405M   32K  405M   1% /run/user/1000
    [Sat May  9 08:30:10 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Sat May  9 08:30:10 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
    [Sat May  9 08:30:11 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.5G    /var/
    245M    /var/cache
    240M    /var/cache/apt
    183M    /var/lib
    147M    /var/lib/apt
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    42M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    335M    /opt/iobroker/iobroker-data/
    166M    /opt/iobroker/iobroker-data/files
    107M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    4.4M    /opt/iobroker/iobroker-data/backup-objects/2026-05-14_16-30_objects.jsonl.gz
    4.4M    /opt/iobroker/iobroker-data/backup-objects/2026-05-14_14-30_objects.jsonl.gz
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** ZigBee Settings ***
    ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspi5              raspi5 (version: 7.0.7, hostname: raspi5        , alive, uptime: 461126)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
      system.adapter.cloud.0                  : cloud                 : raspi5                                   - disabled
      system.adapter.devices.0                : devices               : raspi5                                   -  enabled
      system.adapter.discovery.0              : discovery             : raspi5                                   - disabled
      system.adapter.echarts.0                : echarts               : raspi5                                   -  enabled
      system.adapter.esphome.0                : esphome               : raspi5                                   -  enabled
      system.adapter.feiertage.0              : feiertage             : raspi5                                   -  enabled
      system.adapter.history.0                : history               : raspi5                                   -  enabled
      system.adapter.hm-rega.0                : hm-rega               : raspi5                                   -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : raspi5                                   -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : raspi5                                   -  enabled, port: 0
      system.adapter.hmip.0                   : hmip                  : raspi5                                   -  enabled
      system.adapter.ical.0                   : ical                  : raspi5                                   -  enabled
      system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspi5                                   -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.ping.0                   : ping                  : raspi5                                   -  enabled
      system.adapter.telegram.0               : telegram              : raspi5                                   -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.trashschedule.0          : trashschedule         : raspi5                                   -  enabled
      system.adapter.vis.0                    : vis                   : raspi5                                   -  enabled
      system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 192.168.0.5, run as: admin
      system.adapter.zigbee.0                 : zigbee                : raspi5                                   -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.7.22 [Updatable]
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "cloud"        : 6.0.1    , installed 5.0.1  [Updatable]
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "ical"         : 1.20.0   , installed 1.20.0
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
    Objects and States
    Objects:        3385
    States:         2368
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 41
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6106       920/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4213       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6108       920/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          3774       1/init
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5178       1/init
    udp        0      0 0.0.0.0:35466           0.0.0.0:*                           101        6483       701/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        6481       701/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          4214       1/init
    udp6       0      0 :::5353                 :::*                                101        6482       701/avahi-daemon: r
    udp6       0      0 :::34049                :::*                                101        6484       701/avahi-daemon: r
    2026-05-14 16:35:51.819  - info: hmip.0 (1215) terminating
    2026-05-14 16:35:51.823  - info: telegram.0 (29290) terminating
    2026-05-14 16:35:51.824  - info: telegram.0 (29290) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-05-14 16:35:51.837  - info: trashschedule.0 (1295) terminating
    2026-05-14 16:35:51.844  - info: zigbee.0 (1142) Saved local configuration data
    2026-05-14 16:35:51.875  - info: host.raspi5 instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.920  - info: host.raspi5 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.920  - info: host.raspi5 instance system.adapter.hmip.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.945  - info: host.raspi5 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.945  - info: host.raspi5 instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.966  - info: host.raspi5 instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.997  - info: host.raspi5 instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:51.997  - info: host.raspi5 instance system.adapter.trashschedule.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:52.015  - info: host.raspi5 instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:52.062  - info: host.raspi5 instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:52.310  - info: host.raspi5 instance system.adapter.ping.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:52.314  - info: host.raspi5 stopInstance timeout system.adapter.telegram.0 killing pid 29290
    2026-05-14 16:35:52.334  - warn: host.raspi5 instance system.adapter.telegram.0 terminated due to SIGKILL
    2026-05-14 16:35:52.334  - info: host.raspi5 instance system.adapter.telegram.0 terminated with code null ()
    2026-05-14 16:35:52.345  - info: host.raspi5 instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:52.356  - info: host.raspi5 instance system.adapter.echarts.0 terminated with code 0 (NO_ERROR)
    2026-05-14 16:35:55.367  - info: zigbee.0 (1142) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-05-14 16:36:01.027  - info: host.raspi5 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-05-14 16:36:01.027  - info: host.raspi5 All instances are stopped.
    2026-05-14 16:36:01.101  - info: host.raspi5 terminated
    HomoranH Thomas BraunT 3 Antworten Letzte Antwort
    • B bernd33-1
      ```bash
      Script v.2026-01-31
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      bernd
      HOME=/home/bernd
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
               4045 M total memory
                367 M used memory
                243 M active memory
               2716 M free memory
                147 M buffer memory
                972 M swap cache
               2047 M total swap
                  2 M used swap
               2045 M free swap
      *** FILESYSTEM ***
      /var:
      2.5G    /var/
      245M    /var/cache
      240M    /var/cache/apt
      183M    /var/lib
      147M    /var/lib/apt
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.7
      /usr/bin/npx            10.9.7
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.22
      javascript:     9.0.18
      Adapter State
      + instance is alive
      Objects and States
      Objects:        3385
      States:         2368
      @bernd33-1 sagte:
      Das ist gut so!
      Aber darüber hättest du niemals wie von dir beschrieben installieren können.
        @mcm1957 sagte:
        Ergo ziemlich sicher manuell rumgeschoben statt den Workflow zu verwenden.
        Schon gar nicht im stable!
        @bernd33-1 sagte:
        Ich hab ESPHome unter den Adapter ausgewählt, Installiert und dann eine Instanz hinzugefügt. Also hier:
        Und nur da kommt die Meldung "nicht gewartet"
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @Homoran sagte:
        @mcm1957 sagte:
        @bernd33-1 sagte:
        Was meinst du mit stable?
        Der Adapter ist gar nicht im Stable. Natürlich kommt beim Adapter die Meldung "nicht gewartet" wenn du das stable Repository aktiv hast und einen Adapter verwendest der nicht als stabil eingestuft wurde - sprich nicht im stable ist. Das ist für alle Adapter so die oihre Maintainer noch nicht als stabil und für produktive Systeme geeignet eingestuft haben.
        "nicht gewartet" heißt dass sie im einegstellten Repoistory keine Wartung und Updates erhalten. Und das timmt jedenfalls.
        Und was diese Anzeige betrifft - die ist (bekanntermaßen) fehlerhaft falls npm nicht richtig verwendet wird:
        esphome
        github: 0.7.0-beta.4
        latest: 0.7.0-beta.1 for 76 days
        stable: -.-.-
        Hier wid das npm Tag und nicht wie richtig die im Lates Repository angebitene Version (die auch im Admin angeziegt wird) verwendet.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • B bernd33-1
          ```bash
          Script v.2026-01-31
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                        NTP service: active
                    RTC in local TZ: no
          bernd
          HOME=/home/bernd
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
                   4045 M total memory
                    367 M used memory
                    243 M active memory
                   2716 M free memory
                    147 M buffer memory
                    972 M swap cache
                   2047 M total swap
                      2 M used swap
                   2045 M free swap
          *** FILESYSTEM ***
          /var:
          2.5G    /var/
          245M    /var/cache
          240M    /var/cache/apt
          183M    /var/lib
          147M    /var/lib/apt
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.7
          /usr/bin/npx            10.9.7
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.22
          javascript:     9.0.18
          Adapter State
          + instance is alive
          Objects and States
          Objects:        3385
          States:         2368
          @bernd33-1 sagte:
          Bring das Ding dringend auf Stand...
          iob stop
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          Die ioBroker-Adapter danch auch aktualisieren.
            @bernd33-1 sagte:
            Das ist gut so!
            bernd33-1
            @Homoran Sorry, ich hab so gut es geht versucht zu beschreiben, was ich getutet hab.
            Kleine Frage. Wenn meine ESPHome Installation wenig optimal ist. Kann/Soll ich dann den Adapter deinstallieren und nochmal installieren? Und dann prüfen ob alles gut ist?
              @bernd33-1 sagte:
              iob stop
              sudo apt update
              sudo reboot
              bernd33-1
              @Thomas-Braun Ich hab das Ding mit Dringlichkeit auf Stand gebracht und die Adapter aktualisiert.
              Die Frage über meinen ESPHome Adapter bleibt noch: Soll ich den deinstallieren und dann mit:
              iob add esphome --debug
              neu installieren?
              • B bernd33-1
                neu installieren?
                @bernd33-1 sagte:
                Im Moment ist der gar nicht installiert.
                Wenn deine Installation jetzt in Gänze auf Stand ist würde ich kurzzeitig das Beta-Repo aktivieren, den esphome von dort installieren und dann wieder auf das stable-Repository wechseln.
                  @bernd33-1 sagte:
                  bernd33-1
                  @Thomas-Braun mal so zwischen durch.... danke für deine Geduld :-)
                  Ok, also... der ESPHome Adapter ist aber installiert. Ich war auch verwundert in der IOB diag steht der nicht gell?
                  • B bernd33-1
                    @bernd33-1 sagte:
                    Dann ist zwar die Instanzenkonfiguration noch da, aber due Adapterinstallation schief.
                    Also einfach drüberinstallieren
                      @bernd33-1 sagte:
                      bernd33-1
                      @Homoran Auch danke an dich für deine Geduld :-)
                      Drüber installieren bedeutet das ausführen:
                      • B bernd33-1
                        ```bash
                        Script v.2026-01-31
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                        CPU threads: 4
                        Current issues:
                                      NTP service: active
                                  RTC in local TZ: no
                        bernd
                        HOME=/home/bernd
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                                 4045 M total memory
                                  367 M used memory
                                  243 M active memory
                                 2716 M free memory
                                  147 M buffer memory
                                  972 M swap cache
                                 2047 M total swap
                                    2 M used swap
                                 2045 M free swap
                        *** FILESYSTEM ***
                        /var:
                        2.5G    /var/
                        245M    /var/cache
                        240M    /var/cache/apt
                        183M    /var/lib
                        147M    /var/lib/apt
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.9.7
                        /usr/bin/npx            10.9.7
                        nodejs:
                          Version table:
                             20.19.2+dfsg-1 500
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.7.22
                        javascript:     9.0.18
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        3385
                        States:         2368
                        @bernd33-1 sagte:
                        iob repo unset stable
                        iob repo set beta
                        iob update
                        iob add esphome --host raspi5 --debug
                        iob repo unset beta
                        iob repo set stable
                        iob update
                        Und dann nochmal zeigen was danach im
                        iob diag
                        ausgespuckt wird.
                        • B bernd33-1
                          @bernd33-1 sagte:
                          Umstellen auf beta
                          Repo neu laden
                          Installieren wie du es beschrieben hast
                            bernd33-1
                            schrieb am zuletzt editiert von bernd33-1
                            Ok, neu installiert:
                            iob repo set beta
                            iob update
                            iob repo unset beta
                            iob repo set stable
                            iob update
                            Hier das IOB DEBUG. Unter Adapter State ist der esphome aufgeführt aber unter Installed ioBroker-Adapters nicht.
                            ```bash
                            Script v.2026-01-31
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                      Kernel: Linux 6.18.29+rpt-rpi-2712
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             17:25:18 up 31 min,  1 user,  load average: 0.28, 0.30, 0.32
                            CPU threads: 4
                            Current issues:
                                           Local time: Thu 2026-05-14 17:25:18 CEST
                                       Universal time: Thu 2026-05-14 15:25:18 UTC
                                             RTC time: Thu 2026-05-14 15:25:18
                                          NTP service: active
                                      RTC in local TZ: no
                            bernd
                            HOME=/home/bernd
                            iobroker
                            HOME=/home/iobroker
                            SUDO_HOME=/home/bernd
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Mem:            4.2G        2.1G        1.2G         24M        1.2G        2.1G
                            Swap:           2.1G          0B        2.1G
                            Total:          6.4G        2.1G        3.3G
                            Active iob-Instances:   17
                                     4045 M total memory
                                     2007 M used memory
                                     1968 M active memory
                                      666 M inactive memory
                                     1101 M free memory
                                       99 M buffer memory
                                     1005 M swap cache
                                     2047 M total swap
                                        0 M used swap
                                     2047 M free swap
                            top - 17:25:18 up 31 min,  1 user,  load average: 0.28, 0.30, 0.32
                            Tasks: 184 total,   1 running, 183 sleeping,   0 stopped,   0 zombie
                            MiB Mem :   4045.1 total,   1099.2 free,   2009.8 used,   1105.9 buff/cache
                            MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   2035.3 avail Mem
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            tmpfs          tmpfs     810M   14M  796M   2% /run
                            /dev/sda2      ext4      229G  7.6G  212G   4% /
                            tmpfs          tmpfs     2.0G  9.2M  2.0G   1% /tmp
                            [Thu May 14 16:53:41 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
                            [Thu May 14 16:53:41 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
                            [Thu May 14 16:53:42 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
                            /var:
                            2.5G    /var/
                            245M    /var/cache
                            240M    /var/cache/apt
                            186M    /var/lib
                            146M    /var/lib/apt/lists
                            364M    /opt/iobroker/iobroker-data/
                            42M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.9.7
                            /usr/bin/npx            10.9.7
                            nodejs:
                              Version table:
                                 20.19.2+dfsg-1 500
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            raspi5              raspi5 (version: 7.0.7, hostname: raspi5        , alive, uptime: 1892)
                            admin:          7.8.23
                            javascript:     9.0.18
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
                            + system.adapter.echarts.0                : echarts               : raspi5                                   -  enabled
                            + system.adapter.esphome.0                : esphome               : raspi5                                   -  enabled
                            + system.adapter.history.0                : history               : raspi5                                   -  enabled
                            + system.adapter.hm-rega.0                : hm-rega               : raspi5                                   -  enabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : raspi5                                   -  enabled, port: 0
                            + system.adapter.hm-rpc.1                 : hm-rpc                : raspi5                                   -  enabled, port: 0
                            + system.adapter.hmip.0                   : hmip                  : raspi5                                   -  enabled
                            + system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
                            + system.adapter.mqtt.0                   : mqtt                  : raspi5                                   -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.ping.0                   : ping                  : raspi5                                   -  enabled
                            + system.adapter.telegram.0               : telegram              : raspi5                                   -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.trashschedule.0          : trashschedule         : raspi5                                   -  enabled
                            + system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 192.168.0.5, run as: admin
                            + system.adapter.zigbee.0                 : zigbee                : raspi5                                   -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                            + instance is alive
                            Adapter    "admin"        : 7.8.23   , installed 7.8.23
                            Adapter    "cloud"        : 6.0.1    , installed 6.0.1
                            Objects and States
                            Objects:        3308
                            States:         2447
                            Pending systemupdates: 0
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       9227       1244/io.mqtt.0
                            tcp        0      0 192.168.0.5:2010        0.0.0.0:*               LISTEN      1001       6027       1096/io.hm-rpc.1
                            tcp        0      0 192.168.0.5:2001        0.0.0.0:*               LISTEN      1001       8497       1080/io.hm-rpc.0
                            tcp        0      0 192.168.0.5:8082        0.0.0.0:*               LISTEN      1001       8710       1260/io.web.0
                            tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       18746      3411/python3
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7681       900/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6846       900/iobroker.js-con
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4350       1/init
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5775       913/sshd: /usr/sbin
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8877       1404/io.admin.0
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          4351       1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          5777       913/sshd: /usr/sbin
                            udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       18752      3411/python3
                            udp        0      0 192.168.0.5:5353        0.0.0.0:*                           1001       18751      3411/python3
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18747      3411/python3
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        5022       699/avahi-daemon: r
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2573       1/init
                            udp        0      0 0.0.0.0:57922           0.0.0.0:*                           101        5024       699/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                101        5023       699/avahi-daemon: r
                            udp6       0      0 :::111                  :::*                                0          4352       1/init
                            udp6       0      0 :::48012                :::*                                101        5025       699/avahi-daemon: r
                            2026-05-14 17:22:16.520  - info: esphome.0 (3333) [ESPHome - Console] 2026-05-14 17:22:16,519 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /opt/iobroker/iobroker-data/esphome.0...
                            2026-05-14 17:22:42.946  - info: javascript.0 (996) script.js.common.Heizung.3_Heizbedarf: Es gibt kein Heizbedarf
                            2026-05-14 17:22:42.947  - info: javascript.0 (996) script.js.common.Heizung.ZweipunktregelungThermostate.NinaZimmer: Aktivität Nina Zimmer
                            2026-05-14 17:22:56.934  - info: admin.0 (1404) ==> Connected system.user.admin from ::ffff:192.168.0.79
                            2026-05-14 17:23:02.496  - info: admin.0 (1404) <== Disconnect system.user.admin from ::ffff:192.168.0.79 admin
                            2026-05-14 17:23:18.835  - info: admin.0 (1404) ==> Connected system.user.admin from ::ffff:192.168.0.79
                            2026-05-14 17:23:30.720  - info: admin.0 (1404) <== Disconnect system.user.admin from ::ffff:192.168.0.79 admin
                            2026-05-14 17:23:51.002  - info: host.raspi5 stopInstance system.adapter.esphome.0 (force=false, process=true)
                            2026-05-14 17:23:51.005  - info: esphome.0 (3333) Got terminate signal TERMINATE_YOURSELF
                            2026-05-14 17:23:51.006  - info: esphome.0 (3333) terminating
                            2026-05-14 17:23:51.007  - info: esphome.0 (3333) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2026-05-14 17:23:51.046  - info: host.raspi5 stopInstance system.adapter.esphome.0 send kill signal
                            2026-05-14 17:23:51.509  - info: esphome.0 (3333) terminating
                            2026-05-14 17:23:51.530  - info: host.raspi5 instance system.adapter.esphome.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2026-05-14 17:23:54.852  - info: host.raspi5 instance system.adapter.esphome.0 in version "0.6.3" started with pid 3390
                            2026-05-14 17:23:55.615  - info: esphome.0 (3390) starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.esphome, node: v22.22.2, js-controller: 7.0.7
                            2026-05-14 17:23:56.199  - info: esphome.0 (3390) Native Integration of ESPHome Dashboard enabled, making environment ready
                            2026-05-14 17:23:56.696  - info: esphome.0 (3390) Starting ESPHome Dashboard
                            2026-05-14 17:23:56.699  - warn: esphome.0 (3390) Auto Discovery disabled, new devices (or IP changes) will NOT be detected automatically!
                            2026-05-14 17:23:56.994  - info: esphome.0 (3390) [ESPHome - Console] 2026-05-14 17:23:56,994 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /opt/iobroker/iobroker-data/esphome.0...
                            2026-05-14 17:24:30.989  - info: admin.0 (1404) ==> Connected system.user.admin from ::ffff:192.168.0.79
                            2026-05-14 17:25:19.698  - info: javascript.0 (996) script.js.common.Heizung.3_Heizbedarf: Es gibt kein Heizbedarf
                            2026-05-14 17:25:19.698  - info: javascript.0 (996) script.js.common.Heizung.ZweipunktregelungThermostate.NinaZimmer: Aktivität Nina Zimmer
                              Was kommt beiiob install esphome@0.6.3 --debug?
                              Wenn etwas wie "ist bereits installiert kommt:
                              iob upgrade esphome@0.6.3 --debug
                                bernd33-1
                                @Homoran sagte:
                                adapter "esphome" already installed. Use "upgrade" to upgrade to a newer version.
                                und
                                Adapter "esphome" is not in the repository and cannot be updated.
                                Ok, ich muss auf beta umstellen? Gemacht. Und dann der Ablauf:
                                bernd@raspi5:~ $ iob repo unset stable
                                Repository "stable" deactivated.
                                Active repo(s):
                                bernd@raspi5:~ $ iob repo set beta
                                Repository "beta" set as active.
                                Active repo(s): beta
                                bernd@raspi5:~ $ iob update
                                Used repository: beta
                                Adapter    "admin"        : 7.8.24   , installed 7.8.23 [Updatable]
                                Adapter    "backitup"     : 3.3.17   , installed 3.3.14 [Updatable]
                                Adapter    "devices"      : 2.0.12   , installed 1.2.14 [Updatable]
                                Adapter    "esphome"      : 0.6.3    , installed 0.6.3
                                Adapter    "feiertage"    : 1.4.0    , installed 1.3.0  [Updatable]
                                Adapter    "hm-rpc"       : 3.0.2    , installed 3.0.1  [Updatable]
                                Adapter    "ical"         : 1.20.1   , installed 1.20.0 [Updatable]
                                Adapter    "javascript"   : 9.2.2    , installed 9.0.18 [Updatable]
                                Controller "js-controller": 7.1.2    , installed 7.0.7  [Updatable]
                                Adapter    "ping"         : 2.2.2    , installed 1.7.9  [Updatable]
                                Adapter    "trashschedule": 5.3.0    , installed 3.3.0  [Updatable]
                                Adapter    "web"          : 8.1.0    , installed 8.0.0  [Updatable]
                                Adapter    "ws"           : 4.1.0    , installed 4.0.0  [Updatable]
                                Adapter    "zigbee"       : 3.4.3    , installed 3.3.5  [Updatable]
                                bernd@raspi5:~ $ iob upgrade esphome@0.6.3 --debug
                                Would you like to reinstall version 0.6.3 of esphome now? [(y)es, (n)o]: y
                                Update esphome from @0.6.3 to @0.6.3
                                Uninstall npm packet "iobroker.esphome" for a clean re-installation
                                removed 106 packages in 2s
                                190 packages are looking for funding
                                  run `npm fund` for details
                                NPM version: 10.9.7
                                Installing iobroker.esphome@0.6.3... (System call)
                                npm warn deprecated @mongodb-js/zstd@1.2.2: 1.x versions of this package are deprecated, please use 2.x instead
                                npm warn deprecated @mongodb-js/zstd-linux-arm64-gnu@1.2.2: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
                                added 105 packages in 7s
                                198 packages are looking for funding
                                Updating objects from io-package.json for adapter "esphome" with version "0.6.3"
                                upload [26] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
                                upload [20] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [19] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [18] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [17] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [16] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [15] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                upload [14] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [13] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/ESPHomeDashboardUrl.png img/ESPHomeDashboardUrl.png image/png
                                upload [12] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/ESPhomeDashboardIP.png img/ESPhomeDashboardIP.png image/png
                                upload [11] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/connectionIssue.png img/connectionIssue.png image/png
                                upload [10] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/connectionOK.png img/connectionOK.png image/png
                                upload [9] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
                                upload [8] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/deviceTabEmpty.png img/deviceTabEmpty.png image/png
                                upload [7] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/deviceTree.png img/deviceTree.png image/png
                                upload [6] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/flashFromThisComputer.png img/flashFromThisComputer.png image/png
                                upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/proxy.png img/proxy.png image/png
                                upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
                                upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
                                upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/tsconfig.json tsconfig.json application/json
                                upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
                                bernd@raspi5:~ $
                                bernd@raspi5:~ $
                                bernd@raspi5:~ $ iob repo unset beta
                                Repository "beta" deactivated.
                                Active repo(s):
                                bernd@raspi5:~ $ iob repo set stable
                                Repository "stable" set as active.
                                • B bernd33-1
                                  @Homoran sagte:
                                  und
                                  Active repo(s):
                                  NPM version: 10.9.7
                                  bernd@raspi5:~ $
                                  bernd@raspi5:~ $
                                  Active repo(s):
                                  @bernd33-1 und wie läuft es jetzt?
                                    bernd33-1
                                    @Homoran Es Läuft. Hab den Adapter jetzt ja 2 mal deinstalliert und dann neu installiert.
                                    Es kommen nun nach der Installation auch nichtmehr die Fehlermeldungen die ich am Anfang dieses Threads gepostet hab. Scheint zu passen :-)
                                    • B bernd33-1
                                      Dann lass es jetzt so.
                                      Auf meinem Testsystem wird die Version allerdings ausgegeben:
                                      thomas@testpi:~ $ iob list adapters
                                      │ (index) │ id                          │ name         │ version  │ upgrade policy │
                                      │ 0       │ 'system.adapter.admin'      │ 'admin'      │ '7.8.23' │ 'none'         │
                                      │ 1       │ 'system.adapter.backitup'   │ 'backitup'   │ '3.3.14' │ 'none'         │
                                      │ 2       │ 'system.adapter.discovery'  │ 'discovery'  │ '5.0.0'  │ 'none'         │
                                      │ 3       │ 'system.adapter.esphome'    │ 'esphome'    │ '0.6.3'  │ 'none'         │
                                      │ 4       │ 'system.adapter.javascript' │ 'javascript' │ '9.0.18' │ 'none'         │
                                      │ 5       │ 'system.adapter.rpi2'       │ 'rpi2'       │ '3.0.2'  │ 'none'         │
                                      │ 6       │ 'system.adapter.web'        │ 'web'        │ '8.0.0'  │ 'none'         │
                                      │ 7       │ 'system.adapter.ws'         │ 'ws'         │ '4.0.0'  │ 'none'         │
                                      thomas@testpi:~ $
                                        thomas@testpi:~ $
                                        @Thomas-Braun sagte:
                                        Vielleicht hilft bei @bernd33-1 noch ein iob upload esphome
                                          bernd33-1
                                          Ich lass es mal jetzt so laufen und beobachte das ganze. Ausschauen tut es jetzt jedenfalls gut.
                                          Danke für die tatkräftige Unterstützung! :-)
