Test Adapter TP-Link Tapo
apo.0 2026-04-01 17:47:22.173 error {"message":"Request failed with status code 400","name":"AxiosError","stack":"AxiosError: Request failed with status code 400\n at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:1931:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3176:11)\n at IncomingMessage.emit (node:events:531:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:89:21)\n at Axios.request (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:4236:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:103:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false,"legacyInterceptorReqResOrdering":true},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":5000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"*/*","Content-Type":"application/octet-stream","Connection":"Keep-Alive","Host":"192.168.30.23","User-Agent":"axios/1.14.0","Content-Length":"112","Accept-Encoding":"gzip, compress, deflate, br"},"responseType":"arraybuffer","params":{"seq":"-1433132439"},"method":"post","url":"http://192.168.30.23/app/request","data":{"type":"Buffer","data":[44,194,80,114,40,140,29,244,149,32,100,240,176,167,172,228,21,36,28,122,240,27,75,227,34,124,186,177,132,203,28,75,87,112,78,77,230,151,51,221,221,78,190,140,242,147,147,111,65,116,170,250,5,230,152,45,168,84,184,96,38,162,26,34,61,69,104,249,158,147,150,16,217,129,31,78,233,38,157,213,12,147,125,123,64,167,28,221,13,0,145,172,245,132,211,244,15,89,70,116,44,169,61,178,42,109,120,39,50,195,123,124]},"allowAbsoluteUrls":true},"code":"ERR_BAD_REQUEST","status":400} tapo.0 2026-04-01 17:47:22.173 error Malformed response sysinfo tapo.0 2026-04-01 17:47:22.159 error 276 Error: Request failed with status code 400 tapo.0 2026-04-01 17:47:22.146 error Local seed auth hash doesn't match server hash. Please check if the mail and password are correct. And E-Mail is in same Upper/Lowercase as in the Tapo App tapo.0 2026-04-01 17:47:22.146 error New Handshake 1 failed tapo.0 2026-04-01 17:47:19.497 error {"message":"Request failed with status code 400","name":"AxiosError","stack":"AxiosError: Request failed with status code 400\n at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:1931:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3176:11)\n at IncomingMessage.emit (node:events:531:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:89:21)\n at Axios.request (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:4236:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:103:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false,"legacyInterceptorReqResOrdering":true},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":5000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"*/*","Content-Type":"application/octet-stream","Connection":"Keep-Alive","Host":"192.168.30.22","User-Agent":"axios/1.14.0","Content-Length":"112","Accept-Encoding":"gzip, compress, deflate, br"},"responseType":"arraybuffer","params":{"seq":"-88156814"},"method":"post","url":"http://192.168.30.22/app/request","data":{"type":"Buffer","data":[111,53,112,59,146,11,223,63,87,153,234,90,171,70,196,204,67,132,96,197,102,141,214,118,164,149,222,46,224,127,163,113,199,7,126,42,99,239,0,237,152,172,140,133,88,233,155,47,248,77,168,103,11,75,44,218,133,50,92,169,238,34,113,178,83,106,90,17,117,75,84,57,238,219,233,214,95,15,5,46,43,10,53,247,21,57,20,234,136,19,119,218,154,71,249,133,96,24,246,5,26,170,55,171,141,216,206,219,176,36,180,131]},"allowAbsoluteUrls":true},"code":"ERR_BAD_REQUEST","status":400} tapo.0 2026-04-01 17:47:19.496 error Malformed response sysinfo tapo.0 2026-04-01 17:47:19.486 error 276 Error: Request failed with status code 400 tapo.0 2026-04-01 17:47:19.477 error Local seed auth hash doesn't match server hash. Please check if the mail and password are correct. And E-Mail is in same Upper/Lowercase as in the Tapo App tapo.0 2026-04-01 17:47:19.476 error New Handshake 1 failed tapo.0 2026-04-01 17:46:21.978 error Please set username and password in the instance settingsMOD-EDIT: Code in code-tags gesetzt!
Moien,
ich habe 4x C520 + eine C560. ich kann hier leider nichts steuern bis auf die Bewegung, kann man mit diesen Befehl hier nicht die Lampe einschalten ? Auch Bewegungen bekomme ich nicht angezeigt. Fehlt hier noch eine einstellung das dieses funktioniert ?
ich suche nach einem Objekt für die Personenerkennung. Das beste was ich finde wäre "notifications" auszuwählen, da diese nur bei Personenerkennung gesendet werden .. gibt es was Konkreteres?
@daniello ich habe 3x C212 und 3x C310 und keine hat das Objekt "PersonDetection" ich kann nur "MotionDetection" verwenden, deshalb verwende ich iSpy Agent, die Kameras sind mit ONVIF installiert, mit Bewegungserkennung die wiederum an CodeProject.AI der einen USB single core TPU (schnelle AI Objekterkennung) hat, bei Bewegungserkennung wird ein Bild gesendet das mit der KI ausgewertet wird ob mindestens eine Person erkannt wurde. Diese Erkennung benötigt ca mit API request 50ms und die Information wird mittels MQTT an den IOBroker gesendet, in Kombination mit dem TAPO Adapter habe ich einen Bewegungsmelder / Alarmanlage die entweder das Licht (shelly plugs) einschaltet oder ein paar 120 db Sirenen aktiviert. Bilder und Alarmmeldungen bekomme ich mit PushOver aufs Handy. iSpy und IObroker (Vis) können am Handy über OpenVPN geöffnet werden. Läuft seit ca 6 Monaten ohne Probleme auf VMs mit VirtualBox (Host Debian: IObroker Debian, iSyp Debian und CodeProject.AI auf Ubuntu).
iSpy nimmt auch 5min Videos auf. -
@swagner Danke für die Infos .. meine hat PersonDetection .. es gibt dafür nur kein isoliertes Objekt im ioBroker für die Auslösung. Man kann die Bedingung steuern aktiv/inaktiv .. und dann gibt entsprechend dieser Bedingung Alarme. Ich suchte nach einem isolierten Alarm für die Personenerkennung .. ist aber vielleicht auch gar nicht notwendig. Beste Grüße
@tombox
diese stati hatte ich alle gesehen .. was aber suche ist ein true, wenn eine person erkannt ist.
Es scheint keine Differenzierung zu geben zwischen Bewegungsalarm und Personenerkennung. Aktive/Inaktive ist klar .. aber das bezieht sich ja nur auf die Funktion.
Wie gesagt .. mit low priority. -
@tombox
@daniello
gibt es tapo.0.<id>.detection.events.0.alarm_type
tapo.0.<id>.alarmInfo.last_alarm_type -
@tombox klappt nicht .. bekomme jede Menge Nullen. Bin vor die Kamera gelaufen .. app meldet Person erkannt .. trotzdem nur Nullen.
@daniello dann mal ein debug log per mail tombox2020@gmail.com
debug angeworfen .. runter vor die cam und wieder hoch .. und in eine mail kopiert.
Geht das so?@daniello @tombox ich habe den Adapter gelöscht und neu installiert (0.5.2), jetzt werden auch events0x erzeugt, siehe a.) b.)
a.) tapo.0.8021737BF7902100F40F450CBA35854721C4CEAA -> detection -> events0x -> alarm_type habe ich je nach Erkennung 2 oder 6 mit dem start_time und end_time informationen, diese Werte ändern sich mit der default Polltime von 10s, d.h. alle events sind 10s verzögert.
b.) tapo.0.8021737BF7902100F40F450CBA35854721C4CE7F -> alarmInfo -> alarm_type ist immer 0 dieser Wert ändert sich nicht (der Timestamp ändert sich alle 10s), kann das überhaupt funktionieren wenn die Polltime 10s ist, da ist der alarm_type ja bereits schon wieder auf 0 wenn er abgerufen wird.
Die Werte sind Poll Werte mit einem Updateintervall, welcher in den Instanzeinstellungen auf 10s (Standardwert) eingestellt ist. Das heißt, alle aktuellen Werte werden im 10s Intervall geliefert.
Wenn die Polltime auf 1s gesetzt wird, dann ist das Realtime + 1s.
Hat jemand die Polltime auf 1s gesetzt und funktioniert das, oder hängt sich die Kamera auf ?
Welcher Wert ist die geringste Polltime ?
