  4. Test Adapter TP-Link Tapo
    6.7k
885 Beiträge 123 Kommentatoren 404.1k Aufrufe 107 Beobachtet
  • D daniello
    ich suche nach einem Objekt für die Personenerkennung. Das beste was ich finde wäre "notifications" auszuwählen, da diese nur bei Personenerkennung gesendet werden .. gibt es was Konkreteres?
    tombox
    #803
    @daniello ist in der GitHub version drin.. die readme enthält alle infos
    • bautruppB Offline
      bautruppB Offline
      bautrupp
      #804
      apo.0
      	2026-04-01 17:14:53.506	error	671 Error Code: data.subarray is not a function, undefined 192.168.30.23
      tapo.0
      	2026-04-01 17:14:53.505	error	276 Error: Request failed with status code 400
      tapo.0
      	2026-04-01 17:14:44.414	error	333 Error Code: 0, Success 192.168.30.21
      tapo.0
      	2026-04-01 17:14:31.946	error	671 Error Code: data.subarray is not a function, undefined 192.168.30.23
      tapo.0
      	2026-04-01 17:14:31.946	error	276 Error: Request failed with status code 400
      tapo.0
      	2026-04-01 17:12:23.099	error	{"message":"Request failed with status code 400","name":"AxiosError","stack":"AxiosError: Request failed with status code 400\n at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:1931:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3176:11)\n at IncomingMessage.emit (node:events:531:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:89:21)\n at Axios.request (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:4236:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:103:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false,"legacyInterceptorReqResOrdering":true},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":5000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"*/*","Content-Type":"application/octet-stream","Connection":"Keep-Alive","Host":"192.168.30.23","User-Agent":"axios/1.14.0","Content-Length":"112","Accept-Encoding":"gzip, compress, deflate, br"},"responseType":"arraybuffer","params":{"seq":"1580293355"},"method":"post","url":"http://192.168.30.23/app/request","data":{"type":"Buffer","data":[39,118,142,172,1,40,189,30,47,130,127,233,15,251,206,137,118,142,13,254,58,22,170,52,124,124,63,2,83,223,149,118,184,204,225,200,89,237,142,64,209,85,140,154,181,161,190,42,84,152,27,39,157,142,222,145,81,29,5,153,112,0,159,230,152,228,107,162,16,67,164,68,49,219,10,12,239,108,245,200,157,82,159,32,199,154,82,26,243,164,250,14,135,251,170,254,24,58,61,56,116,242,188,128,9,246,242,225,222,189,225,241]},"allowAbsoluteUrls":true},"code":"ERR_BAD_REQUEST","status":400}
      tapo.0
      	2026-04-01 17:12:23.099	error	Malformed response sysinfo
      tapo.0
      	2026-04-01 17:12:23.092	error	276 Error: Request failed with status code 400
      tapo.0
      	2026-04-01 17:12:23.087	error	Local seed auth hash doesn't match server hash. Please check if the mail and password are correct. And E-Mail is in same Upper/Lowercase as in the Tapo App
      tapo.0
      	2026-04-01 17:12:23.087	error	New Handshake 1 failed
      tapo.0
      	2026-04-01 17:12:20.706	error	{"message":"Request failed with status code 400","name":"AxiosError","stack":"AxiosError: Request failed with status code 400\n at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:1931:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3176:11)\n at IncomingMessage.emit (node:events:531:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:89:21)\n at Axios.request (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:4236:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:103:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false,"legacyInterceptorReqResOrdering":true},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":5000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"*/*","Content-Type":"application/octet-stream","Connection":"Keep-Alive","Host":"192.168.30.22","User-Agent":"axios/1.14.0","Content-Length":"112","Accept-Encoding":"gzip, compress, deflate, br"},"responseType":"arraybuffer","params":{"seq":"-558411216"},"method":"post","url":"http://192.168.30.22/app/request","data":{"type":"Buffer","data":[100,70,216,51,66,205,161,196,185,10,192,86,201,110,152,166,184,192,158,30,144,133,161,67,63,33,6,44,184,23,47,172,169,30,18,203,100,68,133,26,74,73,97,242,254,174,56,122,67,4,196,255,180,165,38,65,242,199,53,35,61,198,188,243,25,203,19,255,218,120,183,65,31,35,102,99,183,191,0,86,70,255,209,242,1,249,189,182,92,52,76,167,34,81,83,35,94,140,51,169,217,17,10,126,28,195,13,38,7,255,42,47]},"allowAbsoluteUrls":true},"code":"ERR_BAD_REQUEST","status":400}
      tapo.0
      	2026-04-01 17:12:20.706	error	Malformed response sysinfo
      tapo.0
      	2026-04-01 17:12:20.695	error	276 Error: Request failed with status code 400
      tapo.0
      	2026-04-01 17:12:20.688	error	Local seed auth hash doesn't match server hash. Please check if the mail and password are correct. And E-Mail is in same Upper/Lowercase as in the Tapo App
      tapo.0
      	2026-04-01 17:12:20.687	error	New Handshake 1 failed
      • bautruppB Offline
        bautruppB Offline
        bautrupp
        schrieb am zuletzt editiert von bautrupp
        #805
        das ist vom github Adapter. Die Adressen 192.168.30.20-24 sind meine P100.
        • bautruppB bautrupp
          tombox
          #806
          @bautrupp GitHub version erneut installieren
          • bautruppB Offline
            bautruppB Offline
            bautrupp
            #807
            apo.0
            	2026-04-01 17:47:22.173	error	{"message":"Request failed with status code 400","name":"AxiosError","stack":"AxiosError: Request failed with status code 400\n at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:1931:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3176:11)\n at IncomingMessage.emit (node:events:531:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:89:21)\n at Axios.request (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:4236:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:103:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false,"legacyInterceptorReqResOrdering":true},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":5000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"*/*","Content-Type":"application/octet-stream","Connection":"Keep-Alive","Host":"192.168.30.23","User-Agent":"axios/1.14.0","Content-Length":"112","Accept-Encoding":"gzip, compress, deflate, br"},"responseType":"arraybuffer","params":{"seq":"-1433132439"},"method":"post","url":"http://192.168.30.23/app/request","data":{"type":"Buffer","data":[44,194,80,114,40,140,29,244,149,32,100,240,176,167,172,228,21,36,28,122,240,27,75,227,34,124,186,177,132,203,28,75,87,112,78,77,230,151,51,221,221,78,190,140,242,147,147,111,65,116,170,250,5,230,152,45,168,84,184,96,38,162,26,34,61,69,104,249,158,147,150,16,217,129,31,78,233,38,157,213,12,147,125,123,64,167,28,221,13,0,145,172,245,132,211,244,15,89,70,116,44,169,61,178,42,109,120,39,50,195,123,124]},"allowAbsoluteUrls":true},"code":"ERR_BAD_REQUEST","status":400}
            tapo.0
            	2026-04-01 17:47:22.173	error	Malformed response sysinfo
            tapo.0
            	2026-04-01 17:47:22.159	error	276 Error: Request failed with status code 400
            tapo.0
            	2026-04-01 17:47:22.146	error	Local seed auth hash doesn't match server hash. Please check if the mail and password are correct. And E-Mail is in same Upper/Lowercase as in the Tapo App
            tapo.0
            	2026-04-01 17:47:22.146	error	New Handshake 1 failed
            tapo.0
            	2026-04-01 17:47:19.497	error	{"message":"Request failed with status code 400","name":"AxiosError","stack":"AxiosError: Request failed with status code 400\n at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:1931:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3176:11)\n at IncomingMessage.emit (node:events:531:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:89:21)\n at Axios.request (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:4236:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:103:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false,"legacyInterceptorReqResOrdering":true},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":5000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"*/*","Content-Type":"application/octet-stream","Connection":"Keep-Alive","Host":"192.168.30.22","User-Agent":"axios/1.14.0","Content-Length":"112","Accept-Encoding":"gzip, compress, deflate, br"},"responseType":"arraybuffer","params":{"seq":"-88156814"},"method":"post","url":"http://192.168.30.22/app/request","data":{"type":"Buffer","data":[111,53,112,59,146,11,223,63,87,153,234,90,171,70,196,204,67,132,96,197,102,141,214,118,164,149,222,46,224,127,163,113,199,7,126,42,99,239,0,237,152,172,140,133,88,233,155,47,248,77,168,103,11,75,44,218,133,50,92,169,238,34,113,178,83,106,90,17,117,75,84,57,238,219,233,214,95,15,5,46,43,10,53,247,21,57,20,234,136,19,119,218,154,71,249,133,96,24,246,5,26,170,55,171,141,216,206,219,176,36,180,131]},"allowAbsoluteUrls":true},"code":"ERR_BAD_REQUEST","status":400}
            tapo.0
            	2026-04-01 17:47:19.496	error	Malformed response sysinfo
            tapo.0
            	2026-04-01 17:47:19.486	error	276 Error: Request failed with status code 400
            tapo.0
            	2026-04-01 17:47:19.477	error	Local seed auth hash doesn't match server hash. Please check if the mail and password are correct. And E-Mail is in same Upper/Lowercase as in the Tapo App
            tapo.0
            	2026-04-01 17:47:19.476	error	New Handshake 1 failed
            tapo.0
            	2026-04-01 17:46:21.978	error	Please set username and password in the instance settings
              apo.0
              tapo.0
              tapo.0
              tapo.0
              tapo.0
              tapo.0
              tapo.0
              tapo.0
              tapo.0
              tapo.0
              tapo.0
              tombox
              #808
              @bautrupp
              nochmal installieren
              aber ads ist eigenartig kannst auch via mail schreiben ruhig mit debug log
              tombox2020@gmail.com
              wäre doch gut zu wissen ob es vorher ging mit dem alten adapter aber dazu müßtest du löschen und neuinstalleiren.
              • bautruppB Offline
                bautruppB Offline
                bautrupp
                #809
                Ob die P100 vorher gingen weiß ich leider nicht. Die habe ich erst jetzt getestet. Im wesentlichen bin ich am Privacymode meiner Kameras interessiert. Ich teste aber was Du möchtest. Ich habe übrigens ein paar C100, C210, C310 und P100 in Betrieb.
                  ManiacKill
                  schrieb am zuletzt editiert von ManiacKill
                  #810
                  Moien,
                  ich habe 4x C520 + eine C560. ich kann hier leider nichts steuern bis auf die Bewegung, kann man mit diesen Befehl hier nicht die Lampe einschalten ? Auch Bewegungen bekomme ich nicht angezeigt. Fehlt hier noch eine einstellung das dieses funktioniert ?
                  • D daniello
                    swagner
                    #811
                    @daniello ich habe 3x C212 und 3x C310 und keine hat das Objekt "PersonDetection" ich kann nur "MotionDetection" verwenden, deshalb verwende ich iSpy Agent, die Kameras sind mit ONVIF installiert, mit Bewegungserkennung die wiederum an CodeProject.AI der einen USB single core TPU (schnelle AI Objekterkennung) hat, bei Bewegungserkennung wird ein Bild gesendet das mit der KI ausgewertet wird ob mindestens eine Person erkannt wurde. Diese Erkennung benötigt ca mit API request 50ms und die Information wird mittels MQTT an den IOBroker gesendet, in Kombination mit dem TAPO Adapter habe ich einen Bewegungsmelder / Alarmanlage die entweder das Licht (shelly plugs) einschaltet oder ein paar 120 db Sirenen aktiviert. Bilder und Alarmmeldungen bekomme ich mit PushOver aufs Handy. iSpy und IObroker (Vis) können am Handy über OpenVPN geöffnet werden. Läuft seit ca 6 Monaten ohne Probleme auf VMs mit VirtualBox (Host Debian: IObroker Debian, iSyp Debian und CodeProject.AI auf Ubuntu).
                    iSpy nimmt auch 5min Videos auf.
                      daniello
                      #812
                      @swagner Danke für die Infos .. meine hat PersonDetection .. es gibt dafür nur kein isoliertes Objekt im ioBroker für die Auslösung. Man kann die Bedingung steuern aktiv/inaktiv .. und dann gibt entsprechend dieser Bedingung Alarme. Ich suchte nach einem isolierten Alarm für die Personenerkennung .. ist aber vielleicht auch gar nicht notwendig. Beste Grüße
                      • D daniello
                        tombox
                        #813
                        @daniello sollte es in der GitHub version geben
                        Bitte testen ob es geht
                          daniello
                          #814
                          @tombox ich las was von 0.5.0 .. ich bekomme 0.4.8. Korrekt so?
                          • D daniello
                            tombox
                            #815
                            @daniello korrekt die versions immer ist noch alt
                            • T tombox
                              daniello
                              #816
                              @tombox sagte:
                              Würdest Du mir sagen auf welches Objekt ich genau achten soll? für einen Personenerkennungsalarm?
                              • D daniello
                                @tombox sagte:
                                tombox
                                #817
                                @daniello https://github.com/TA2k/ioBroker.tapo?tab=readme-ov-file#kamera-erkennungsereignisse
                                  daniello
                                  #818
                                  @tombox
                                  diese stati hatte ich alle gesehen .. was aber suche ist ein true, wenn eine person erkannt ist.
                                  Es scheint keine Differenzierung zu geben zwischen Bewegungsalarm und Personenerkennung. Aktive/Inaktive ist klar .. aber das bezieht sich ja nur auf die Funktion.
                                  Wie gesagt .. mit low priority.
                                  • D daniello
                                    @tombox
                                    tombox
                                    #819
                                    @daniello
                                    gibt es tapo.0.<id>.detection.events.0.alarm_type
                                    tapo.0.<id>.alarmInfo.last_alarm_type
                                    • bautruppB Offline
                                      bautruppB Offline
                                      bautrupp
                                      #820
                                      Die aktuelle Version läuft bei mir jetzt absolut ohne Probleme.
                                      Vielen Dank an @tombox für die Zeit, Arbeit und Geduld!
                                      • T tombox
                                        @daniello
                                        daniello
                                        #821
                                        @tombox sagte:
                                        @daniello
                                        Ja .. es ist eine Nummer .. muss ich mal schauen was dabei raus kommt .. finde keine Liste.
                                        • D daniello
                                          @tombox sagte:
                                          @daniello
                                          tombox
                                          #822
                                          @daniello Liste ist jetzt in der Readme
