IOB im Docker Startet nicht mehr!!!
@Marc-Berg sagte in Multihost Fragen!:
/volume1/docker/iobroker-data ist komplett leer beim Start?
Das Verzeichnis ist leer
Setz mal noch die Umgebungvariable "debug" auf "true", dann sieht man noch mal mehr im Log.
----- PACKAGES: nano ----- ----- SETGID: 1000 ----- ----- SETUID: 1000 ----- -------------------------------------------------------------------------------- !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!! DEBUG LOG ACTIVE !!!! !!!! Environment variable DEBUG is set to true. !!!! !!!! This will extend the logging output and may slow down container start. !!!! !!!! Please make sure to deactivate if no longer needed. !!!! !!!! For more information see ioBroker Docker image documentation: !!!! !!!! https://docs.buanet.de/iobroker-docker-image/docs/ !!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! -------------------------------------------------------------------------------- ----- Step 1 of 5: Preparing Container ----- -------------------------------------------------------------------------------- This is not the first run of this container. Skipping first run preparation. -------------------------------------------------------------------------------- ----- Step 2 of 5: Detecting ioBroker Installation ----- -------------------------------------------------------------------------------- Existing installation of ioBroker detected in "/opt/iobroker". -------------------------------------------------------------------------------- ----- Step 3 of 5: Checking ioBroker Installation ----- -------------------------------------------------------------------------------- (Re)setting permissions (This might take a while! Please be patient!)... Done. [DEBUG] Checking multihost settings... [DEBUG] No multihost settings detected. [DEBUG] Done. [DEBUG] Checking custom objects db settings... [DEBUG] No custom objects db settings detected. [DEBUG] Done. [DEBUG] Checking custom states db settings... [DEBUG] No custom states db settings detected. [DEBUG] Done. Checking database connection... Done. [DEBUG] Detected admin instance is: system.adapter.admin.0 [DEBUG] Detected admin hostname is: OldNo7NAS Hostname in ioBroker matches the hostname of this container. No action required. [DEBUG] Collecting some more ioBroker debug information... [DEBUG] ##### iobroker list instances ##### system.adapter.admin.0 : admin : OldNo7NAS - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.backitup.0 : backitup : OldNo7NAS - enabled system.adapter.discovery.0 : discovery : OldNo7NAS - enabled + instance is alive [DEBUG] ##### iobroker repo list ##### ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none [DEBUG] ##### iobroker update ##### Used repository: stable Adapter "admin" : 7.7.22 , installed 7.7.22 Adapter "backitup" : 3.3.14 , installed 3.3.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Controller "js-controller": 7.0.7 , installed 7.0.7 -------------------------------------------------------------------------------- ----- Step 4 of 5: Applying Special Settings ----- -------------------------------------------------------------------------------- Some adapters have special requirements/ settings which can be activated by the use of environment variables. For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs/). -------------------------------------------------------------------------------- ----- Step 5 of 5: ioBroker Startup ----- -------------------------------------------------------------------------------- Starting ioBroker... ##### #### ### ## # iobroker.js-controller log output # ## ### #### ##### host.OldNo7NAS check instance "system.adapter.admin.0" for host "OldNo7NAS" host.OldNo7NAS check instance "system.adapter.backitup.0" for host "OldNo7NAS" host.OldNo7NAS check instance "system.adapter.discovery.0" for host "OldNo7NAS" Send diag info: {"uuid":"d0422790-1aff-4757-820e-a7f227e1a5cb","language":"de","country":"Germany","hosts":[{"version":"7.0.7","platform":"Javascript/Node.js","type":"linux"}],"node":"v22.22.1","arch":"x64","docker":true,"adapters":{"admin":{"version":"7.7.22","platform":"Javascript/Node.js"},"discovery":{"version":"5.0.0","platform":"Javascript/Node.js"},"backitup":{"version":"3.3.14","platform":"Javascript/Node.js","installedFrom":"iobroker.backitup@3.3.14"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":3,"compactMode":false,"noCompactInstances":0,"model":"Intel(R) Celeron(R) CPU J3355 @ 2.00GHz","cpus":2,"mem":16624197632,"ostype":"Linux","city":"Arrach"} ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging] Send diag info: {"uuid":"d0422790-1aff-4757-820e-a7f227e1a5cb","language":"de","country":"Germany","hosts":[{"version":"7.0.7","platform":"Javascript/Node.js","type":"linux"}],"node":"v22.22.1","arch":"x64","docker":true,"adapters":{"admin":{"version":"7.7.22","platform":"Javascript/Node.js"},"discovery":{"version":"5.0.0","platform":"Javascript/Node.js"},"backitup":{"version":"3.3.14","platform":"Javascript/Node.js","installedFrom":"iobroker.backitup@3.3.14"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":3,"compactMode":false,"noCompactInstances":0,"model":"Intel(R) Celeron(R) CPU J3355 @ 2.00GHz","cpus":2,"mem":16624197632,"ostype":"Linux","city":"Arrach"} ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped] ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]Ab hier ist der Container auf "unhealthy
@Happyuser20 sagte in Multihost Fragen!:
Du schreibst
Gleichzeitig sagt das Log
This is not the first run of this container. Skipping first run preparation.Das kann nicht passen. Bitte Verzeichnis leeren und dann den Container starten. Davon das Log posten, nachdem der Container auf unhealthy ging.
EDIT:
Außerdem im Container ausführen und die Ergebnisse bereitstellen:
iob status iob stop admin.0 iob start admin.0 -
Du schreibst
EDIT:
iob status iob stop admin.0 iob start admin.0@Marc-Berg sagte in IOB im Docker Startet nicht mehr!!!:
- Bevor ich den Container mit dem Stack anlege, ist das Verzeichnis leer.
- wenn der Container angelegt wird, wird nach meiner Meinung nach das Verzeichnis gefüllt von der IOB Installation
- der erste Start funktioniert auch noch. Ich mach die ersten Schritte nach der Installation
- mache das Update vom Backitup-Adapter
- alles gut, bis im Reiter "Hosts" Neustarte
- ab da hängt es und der Container geht auf "unhealthy"
- IOB kann nur mit einem Neustart des Containers wieder zum leben erweckt werden
Kann es sein, dass wir aneinander Vorbeireden?
Objects type: jsonl States type: jsonl root@OldNo7NAS:/opt/iobroker# iob stop admin The adapter "admin.0" was stopped. root@OldNo7NAS:/opt/iobroker# iob start admin The adapter "admin.0" was started. root@OldNo7NAS:/opt/iobroker#Der Neustart über die Konsole scheint zu klappen.
Aber so
nicht.
Aber so
nicht.
@Happyuser20 sagte in IOB im Docker Startet nicht mehr!!!:
Ja.
Ich checke erst jetzt, dass dein "Problem" darin besteht, dass der Button "Host neu starten" im Admin nicht funktioniert.
Wenn ioBroker im Container läuft, funktioniert dies nicht (mehr). Wenn ich mich recht erinnere, war das eine Nebenwirkung des von André/Buanet eingeführten Mainenance Modus. Neustart des Containers also nur über die Portainer oder DS.
Ja.
Ja.
Wenn das so ist, mache ich an dieser mal weiter und spiele mein Backup ein.
Das bringt mich dann gleich zur nächsten Frage.
Macht es einen Unterschied ob ich IoBroker über den Admin neu starte oder über den Container Stoppe und wieder Starte?
Hintergrund meiner Frage: Ich habe gelesen man solle nach einrichten des Multihost den Master neu starten und dann erst den Slave. Evtl. ist dort ein Problem? -
Ja.
Hintergrund meiner Frage: Ich habe gelesen man solle nach einrichten des Multihost den Master neu starten und dann erst den Slave. Evtl. ist dort ein Problem?@Happyuser20 sagte in IOB im Docker Startet nicht mehr!!!:
Nein, kein relevanter Unterschied.
Ich frage mich: Was muss am Master eingerichtet werden? Sämtliche Konfigurationsarbeit (iob setup custom) findet am Slave statt. Der Master muss in deiner Konstellation lediglich erreichbar sein, und das ist er.
ich hab das ewig nicht mehr geprüft.
Ist das jetzt so? Früher musste auch am Master angepasst werden, da die default Einstellungen nicht Multihost fähig waren.
Ich wriss nicht mehr, ob es die IP oder die Ports, ggf. auch die Auswahl der Object/states db. -
Ich wriss nicht mehr, ob es die IP oder die Ports, ggf. auch die Auswahl der Object/states db.@Homoran sagte in IOB im Docker Startet nicht mehr!!!:
Stimmt natürlich, die IP-Adresse, auf der gehört wird, muss von "127.0.0.1" (default) auf "0.0.0.0" geändert werden. Aber das wars dann auch schon, denke ich.
System läuft jetzt wieder
Auch der Multihost hat jetzt funktioniert
Eingestellt habe ich es wie folgt
Master Konfiguration
iobroker setup custom Type of objects DB [(f)ile, (c)ouch, (r)edis], default [file]: j #anstatt f Host / Unix Socket of objects DB(file), default[0.0.0.0]:0.0.0.0 Port of objects DB(file), default[9001]:9001 Type of states DB [(f)file, (r)edis], default [file]: j #anstatt f Host / Unix Socket of states DB (redis), default[127.0.0.1]: 0.0.0.0 Port of states DB (redis), default[6379]:9000 Data directory (file), default[../../../iobroker-data/]: /opt/iobroker/iobroker-data/ Host name of this machine [ioBroker-RasPi]:<Name der Maschine> iobroker multihost enable enter pass phrase iobroker restartSlave Konfiguration
iobroker setup custom Type of objects DB [(f)ile, (c)ouch, (r)edis], default [file]: j Host / Unix Socket of objects DB(file), default[127.0.0.1]: <MASTER-IP> Port of objects DB(file), default[9001]:9001 Type of states DB [(f)file, (r)edis], default [file]: j Host / Unix Socket of states DB (redis), default[<MASTER-IP>]: Port of states DB (redis), default[6379]:9000 Host name of this machine [raspi-sub-1]:<Name der Maschine> iobroker multihost connect 1 | <MASTER-IP> | host | 192.168.86.42 | "authentication required" Please select host [1]: 1 Enter secret phrase for connection: ***** Config ok. Please restart ioBroker: "iobroker restart" iobroker restartDamit hat es endlich funktioniert.
Wenn ich beim Master „f“ anstatt „j“ eingebe, schmiert die IoB Installation ab!
Wie vorher auch schon
Checking database connection... Failed. [ERROR] Cannot read system.config: null (OK when migrating or restoring) [ERROR] Error: no UUID foundHabe ich extra nochmal getestet.
Danke nochmal an alle Beteiligten für die Unterstützung.
ja, so muss es sein.
ich gehe davon aus dass deine <Eingaben> in Wirklichkeit anders aussehen 😉Multihost sollte nicht dein Problem gewesen sein.
Type of objects DB [(f)ile, (c)ouch, (r)edis], default [file]: jEs ist mir ein vollkommenes Rätsel, warum bei dir diese (für dich zurecht verwirrende) Auswahl erscheint. Bei mir kommt:
Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [redis]:Kann es sein, dass du auf dem pi eine alte ioBroker Version fährst?
@Marc-Berg
couch.db existierte mal vor 12 Jahren!
Damals war Installation noch ein Abenteuer.Das irritiert mich jetzt aber auch.
Aber ebenso warum bei Auswahl von file (=json) das System abschmieren sollte.
Der Slave PI ist auch ganz frisch aufgesetzt, nach dieser Anleitung
Der sollte aktuell sein. -
Der sollte aktuell sein.@Happyuser20 sagte in IOB im Docker Startet nicht mehr!!!:
Im gesamten aktuellen Quellcode des js-controllers findet sich kein "(c)ouch" mehr. Deine Installation bleibt eine Wundertüte. ;-)
kann André das eingebaut haben?
ich hab da ganz dunkel was in Erinnerung, dass irgendwann wieder von couch die Rede war. Da hab ich nur gedacht, dass wäre lang schon ad acta gelegt.dann könnte es aber nicht auch im Raspi sein.
was heisst das in Versionsnummern?
am besten die Ausgabe von
iob diag -
Dan zeig mal bitte für Master & Slave die Ausgabe von
iob diag -
iob diag@Homoran sagte in IOB im Docker Startet nicht mehr!!!:
Nein, das ist eine reine js-controller Funktionalität. Da wird im Container nicht dran rumgeschraubt.
Iob Diag vom Master
========== Start marking the full check here =========== ```bash Script v.2026-01-31 *** BASE SYSTEM *** Hardware Vendor : Synology Kernel : x86_64 Userland : 64 bit Docker : v11.1.0 Virtualization : docker Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 06:20:57 up 1 day, 13:20, 0 user, load average: 3.64, 2.94, 2.43 CPU threads: 2 *** LIFE CYCLE STATUS *** Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time! *** TIME AND TIMEZONES *** Thu Mar 26 05:20:57 UTC 2026 Thu Mar 26 06:20:57 CET 2026 CET +0100 Etc/UTC *** Users and Groups *** User that called 'iob diag': root HOME=/root GROUPS=root User that is running 'js-controller': iobroker HOME=/opt/iobroker GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: false System has not been booted with systemd as init system (PID 1). Can't operate. Failed to connect to bus: Host is down Display-Manager: Desktop: Session: *** MEMORY *** total used free shared buff/cache available Mem: 16G 5.1G 388M 179M 11G 11G Swap: 2.1G 0B 2.1G Total: 18G 5.1G 2.5G Active iob-Instances: 35 15854 M total memory 4842 M used memory 7501 M active memory 6739 M inactive memory 370 M free memory 863 M buffer memory 10276 M swap cache 2047 M total swap 0 M used swap 2047 M free swap *** top - Table Of Processes *** top - 06:20:57 up 1 day, 13:20, 0 user, load average: 3.75, 2.97, 2.44 Tasks: 42 total, 3 running, 39 sleeping, 0 stopped, 0 zombie %Cpu(s): 50.0 us, 50.0 sy, 0.0 ni, 0.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 15854.1 total, 368.3 free, 4844.0 used, 11140.3 buff/cache MiB Swap: 2047.9 total, 2047.9 free, 0.0 used. 11010.1 avail Mem *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on none aufs 3.6T 2.9T 734G 80% / tmpfs tmpfs 64M 0 64M 0% /dev tmpfs tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup shm tmpfs 64M 0 64M 0% /dev/shm /dev/md2 ext4 3.6T 2.9T 734G 80% /opt/iobroker tmpfs tmpfs 7.8G 0 7.8G 0% /proc/acpi tmpfs tmpfs 7.8G 0 7.8G 0% /proc/scsi tmpfs tmpfs 7.8G 0 7.8G 0% /sys/firmware Messages concerning ext4 filesystem in dmesg: [Tue Mar 24 17:01:21 2026] EXT4-fs (md0): mounting ext3 file system using the ext4 subsystem [Tue Mar 24 17:01:21 2026] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null) [Tue Mar 24 17:01:21 2026] EXT4-fs (md0): mounting ext3 file system using the ext4 subsystem [Tue Mar 24 17:01:21 2026] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1 [Tue Mar 24 17:01:28 2026] EXT4-fs (md0): mounting ext3 file system using the ext4 subsystem [Tue Mar 24 17:01:28 2026] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null) [Tue Mar 24 17:01:29 2026] EXT4-fs (md0): mounting ext3 file system using the ext4 subsystem [Tue Mar 24 17:01:29 2026] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1 [Tue Mar 24 17:03:17 2026] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null) [Tue Mar 24 17:03:17 2026] EXT4-fs (md2): barriers disabled [Tue Mar 24 17:03:17 2026] EXT4-fs (md2): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / none aufs rw,relatime,si=6168b05b7ad59782,dio,dirperm1 |-/opt/iobroker /dev/md2[/@docker/volumes/f05afd1c2039f3f2420d44f864ea945a0032f09b91fd90766c6545cad187ae09/_data] ext4 rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group |-/etc/resolv.conf /dev/md2[/@docker/containers/66b2fc691407fa63e000f8a76629f87539d2b564d91a2f746448b266709f57cf/resolv.conf] ext4 rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group |-/etc/hostname /dev/md2[/@docker/containers/66b2fc691407fa63e000f8a76629f87539d2b564d91a2f746448b266709f57cf/hostname] ext4 rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group |-/etc/hosts /dev/md2[/@docker/containers/66b2fc691407fa63e000f8a76629f87539d2b564d91a2f746448b266709f57cf/hosts] ext4 rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group `-/volume1/docker/iobroker-data/opt/iobroker /dev/md2[/@docker/volumes/a065460fbdc6ce960ee3964c7901ac7fd163df98ea13d22185e2facd74a473aa/_data] ext4 rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group Files in neuralgic directories: /var: 16M /var/ 14M /var/lib/dpkg 14M /var/lib 13M /var/lib/dpkg/info 1.9M /var/cache /opt/iobroker/backups: 99M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 606M /opt/iobroker/iobroker-data/ 499M /opt/iobroker/iobroker-data/files 71M /opt/iobroker/iobroker-data/files/vis 67M /opt/iobroker/iobroker-data/files/echarts.admin 63M /opt/iobroker/iobroker-data/files/vis/widgets The five largest files in iobroker-data are: 38M /opt/iobroker/iobroker-data/objects.jsonl 29M /opt/iobroker/iobroker-data/states.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 26M /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map 26M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' No nvbackup.json found. *** NodeJS-Installation *** /usr/bin/nodejs v22.22.1 /usr/bin/node v22.22.1 /usr/bin/npm 10.9.4 /usr/bin/npx 10.9.4 ✓ Node.js installation is correct nodejs: Installed: 22.22.1-1nodesource1 Candidate: 22.22.1-1nodesource1 Version table: *** 22.22.1-1nodesource1 100 100 /var/lib/dpkg/status Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: █████ ██ ██ ██████ ██████ ██████ ██████ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ██ ██ ██ ███ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ███████ ██████ ██████ ██████ ██████ ██ *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: OldNo7NAS OldNo7NAS (version: 7.0.7, hostname: OldNo7NAS , alive, uptime: 51683) SlaveIOBroker SlaveIOBroker (version: 7.0.7, hostname: SlaveIOBroker , alive, uptime: 35409) Core adapters versions js-controller: 7.0.7 admin: 7.7.22 javascript: 9.0.18 nodejs modules from github: 8 +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#fd28f98d7ec46f36f4a2dae2d9ac740966453704) +-- iobroker.esphome@0.5.0-beta.10 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#8ca51cd0460c21c1a817acc18c774da1fcf4f5ff) +-- iobroker.fronius-solarweb@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.fronius-solarweb.git#ca2f1a4972992cbd0d14bb25f5f7546219dd5b9e) +-- iobroker.linkeddevices@1.5.5 (git+ssh://git@github.com/Scrounger/ioBroker.linkeddevices.git#b70f9d21eff8412656b053f93ddab42211900fdb) +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19) +-- iobroker.spritmonitor@0.0.2-beta.10 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#4059f9e2e3019b0a025fd7af850c259a84a797de) | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0) +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92) Adapter State + system.adapter.admin.0 : admin : OldNo7NAS - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : OldNo7NAS - enabled + system.adapter.backitup.0 : backitup : OldNo7NAS - enabled system.adapter.bambulab.0 : bambulab : OldNo7NAS - disabled, port: 8883 system.adapter.birthdays.0 : birthdays : OldNo7NAS - disabled + system.adapter.device-reminder.0 : device-reminder : OldNo7NAS - enabled system.adapter.devices.0 : devices : OldNo7NAS - disabled + system.adapter.discovery.0 : discovery : OldNo7NAS - enabled + system.adapter.ds18b20.0 : ds18b20 : SlaveIOBroker - enabled system.adapter.dwd.0 : dwd : OldNo7NAS - enabled system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: OldNo7NAS - disabled + system.adapter.energiefluss.0 : energiefluss : OldNo7NAS - enabled system.adapter.esphome.0 : esphome : OldNo7NAS - disabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : OldNo7NAS - enabled + system.adapter.fronius-solarweb.0 : fronius-solarweb : OldNo7NAS - enabled + system.adapter.fronius.0 : fronius : OldNo7NAS - enabled + system.adapter.fullybrowser.0 : fullybrowser : OldNo7NAS - enabled + system.adapter.hass.0 : hass : OldNo7NAS - enabled, port: 8123 system.adapter.heizoel.0 : heizoel : OldNo7NAS - disabled + system.adapter.history.0 : history : OldNo7NAS - enabled + system.adapter.hmip.0 : hmip : OldNo7NAS - enabled + system.adapter.homeconnect.0 : homeconnect : OldNo7NAS - enabled system.adapter.ical.0 : ical : OldNo7NAS - enabled system.adapter.ical.1 : ical : OldNo7NAS - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : OldNo7NAS - disabled system.adapter.influxdb.0 : influxdb : OldNo7NAS - disabled, port: 8086 + system.adapter.iot.0 : iot : OldNo7NAS - enabled + system.adapter.javascript.0 : javascript : OldNo7NAS - enabled + system.adapter.linkeddevices.0 : linkeddevices : OldNo7NAS - enabled system.adapter.modbus.0 : modbus : OldNo7NAS - disabled + system.adapter.mqtt.0 : mqtt : OldNo7NAS - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.pvforecast.0 : pvforecast : OldNo7NAS - enabled system.adapter.reolink.0 : reolink : OldNo7NAS - disabled system.adapter.sayit.0 : sayit : OldNo7NAS - disabled + system.adapter.shelly.0 : shelly : OldNo7NAS - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : OldNo7NAS - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : OldNo7NAS - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.smartgarden.0 : smartgarden : OldNo7NAS - enabled + system.adapter.smartmeter.1 : smartmeter : OldNo7NAS - enabled + system.adapter.snmp.0 : snmp : OldNo7NAS - enabled + system.adapter.sourceanalytix.0 : sourceanalytix : OldNo7NAS - enabled system.adapter.spritmonitor.0 : spritmonitor : OldNo7NAS - disabled + system.adapter.synology.0 : synology : OldNo7NAS - enabled, port: 5000 system.adapter.tankerkoenig.0 : tankerkoenig : OldNo7NAS - disabled system.adapter.text2command.0 : text2command : OldNo7NAS - disabled + system.adapter.tr-064.0 : tr-064 : OldNo7NAS - enabled + system.adapter.trashschedule.0 : trashschedule : OldNo7NAS - enabled system.adapter.trashschedule.1 : trashschedule : OldNo7NAS - disabled system.adapter.tuya.0 : tuya : OldNo7NAS - disabled + system.adapter.upnp.0 : upnp : OldNo7NAS - enabled system.adapter.viessmann.0 : viessmann : SlaveIOBroker - disabled, port: 3002 system.adapter.vis-2.0 : vis-2 : OldNo7NAS - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : OldNo7NAS - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : OldNo7NAS - disabled system.adapter.vis-google-fonts.0 : vis-google-fonts : OldNo7NAS - enabled system.adapter.vis-history.0 : vis-history : OldNo7NAS - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : OldNo7NAS - disabled system.adapter.vis-icontwo.0 : vis-icontwo : OldNo7NAS - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : OldNo7NAS - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : OldNo7NAS - disabled system.adapter.vis-justgage.0 : vis-justgage : OldNo7NAS - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : OldNo7NAS - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : OldNo7NAS - disabled system.adapter.vis-metro.0 : vis-metro : OldNo7NAS - disabled system.adapter.vis-plumb.0 : vis-plumb : OldNo7NAS - disabled system.adapter.vis-rgraph.0 : vis-rgraph : OldNo7NAS - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : OldNo7NAS - disabled system.adapter.vis.0 : vis : OldNo7NAS - enabled system.adapter.weatherunderground.0 : weatherunderground : OldNo7NAS - enabled + system.adapter.web.0 : web : OldNo7NAS - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.whatsapp-cmb.0 : whatsapp-cmb : OldNo7NAS - disabled + system.adapter.wled.0 : wled : OldNo7NAS - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : OldNo7NAS - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hass.0 : hass : OldNo7NAS - enabled, port: 8123 + system.adapter.mqtt.0 : mqtt : OldNo7NAS - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : OldNo7NAS - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : OldNo7NAS - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : OldNo7NAS - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.synology.0 : synology : OldNo7NAS - enabled, port: 5000 + system.adapter.web.0 : web : OldNo7NAS - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬────────────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼────────────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ │ 2 │ '' │ 'http://download.iobroker.net/sources-dist.json' │ false │ └─────────┴────────────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): Stable (default) Upgrade policy: none Installed ioBroker-Adapters Used repository: Stable (default) Adapter "admin" : 7.7.22 , installed 7.7.22 Adapter "alexa2" : 3.27.4 , installed 3.27.4 Adapter "backitup" : 3.3.14 , installed 3.3.14 Adapter "birthdays" : 5.0.0 , installed 5.0.0 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 1.9.2 , installed 1.9.2 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fronius" : 2.1.1 , installed 2.1.1 Adapter "fronius-solarweb": 0.0.3 , installed 0.1.0 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "hass" : 1.4.0 , installed 1.4.0 Adapter "heizoel" : 1.0.3 , installed 1.0.3 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hmip" : 1.27.0 , installed 1.27.0 Adapter "homeconnect" : 1.5.2 , installed 1.5.2 Adapter "ical" : 1.19.7 , installed 1.19.7 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 5.0.7 , installed 5.0.7 Adapter "javascript" : 9.0.18 , installed 9.0.18 Controller "js-controller": 7.0.7 , installed 7.0.7 Adapter "linkeddevices": 1.5.5 , installed 1.5.5 Adapter "modbus" : 7.0.6 , installed 7.0.6 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "pvforecast" : 5.1.0 , installed 5.1.0 Adapter "reolink" : 1.2.3 , installed 1.2.3 Adapter "sayit" : 5.0.0 , installed 5.0.0 Adapter "shelly" : 10.5.2 , installed 10.5.2 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "smartgarden" : 2.0.1 , installed 2.0.1 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "snmp" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 6.7.1 , installed 7.0.8 Adapter "synology" : 3.1.0 , installed 3.1.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 3.3.0 , installed 3.3.0 Adapter "tuya" : 3.16.0 , installed 3.16.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.4 , installed 2.13.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 2.11.1 , installed 2.11.1 Adapter "vis-inventwo" : 3.3.5 , installed 3.3.5 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.94 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 7.0.8 , installed 7.0.8 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "wled" : 0.7.3 , installed 0.7.3 Adapter "ws" : 2.6.2 , installed 3.0.19 Objects and States Please stand by - This may take a while Objects: 29048 States: 25926 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm-updates InRelease Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease Reading package lists... Pending systemupdates: 1 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:21 0.0.0.0:* LISTEN 0 47739 - tcp 0 0 0.0.0.0:662 0.0.0.0:* LISTEN 0 26284 - tcp 0 0 0.0.0.0:7000 0.0.0.0:* LISTEN 0 97364 - tcp 0 0 0.0.0.0:7000 0.0.0.0:* LISTEN 0 97362 - tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 55 67950 - tcp 0 0 127.0.0.1:33304 0.0.0.0:* LISTEN 0 32433 - tcp 0 0 0.0.0.0:88 0.0.0.0:* LISTEN 0 26824 - tcp 0 0 0.0.0.0:8889 0.0.0.0:* LISTEN 0 108212 - tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1000 7080753 - tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1000 7088043 - tcp 0 0 0.0.0.0:8123 0.0.0.0:* LISTEN 0 109355 - tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 0 39082 - tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 0 39074 - tcp 0 0 0.0.0.0:892 0.0.0.0:* LISTEN 0 25522 - tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 0 49096 - tcp 0 0 127.0.0.1:512 0.0.0.0:* LISTEN 0 117657 - tcp 0 0 0.0.0.0:2049 0.0.0.0:* LISTEN 0 48553 - tcp 0 0 0.0.0.0:161 0.0.0.0:* LISTEN 0 38143 - tcp 0 0 0.0.0.0:3493 0.0.0.0:* LISTEN 0 189966 - tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1000 7075212 - tcp 0 0 0.0.0.0:5000 0.0.0.0:* LISTEN 0 39076 - tcp 0 0 0.0.0.0:5000 0.0.0.0:* LISTEN 0 39068 - tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1000 7075879 - tcp 0 0 0.0.0.0:5001 0.0.0.0:* LISTEN 0 39078 - tcp 0 0 0.0.0.0:5001 0.0.0.0:* LISTEN 0 39070 - tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 0 49097 - tcp 0 0 0.0.0.0:4045 0.0.0.0:* LISTEN 0 48574 - tcp 0 0 0.0.0.0:5357 0.0.0.0:* LISTEN 0 40681 - tcp 0 0 0.0.0.0:5357 0.0.0.0:* LISTEN 0 40679 - tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 25035 - tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 39080 - tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 39072 - tcp 0 0 192.168.1.111:50001 0.0.0.0:* LISTEN 0 84183 - tcp 0 0 192.168.1.111:50002 0.0.0.0:* LISTEN 0 84869 - tcp6 0 0 :::21 :::* LISTEN 0 47740 - tcp6 0 0 :::8086 :::* LISTEN 1000 128083 - tcp6 0 0 :::662 :::* LISTEN 0 26288 - tcp6 0 0 :::8087 :::* LISTEN 1000 7090869 - tcp6 0 0 :::7000 :::* LISTEN 0 97365 - tcp6 0 0 :::7000 :::* LISTEN 0 97363 - tcp6 0 0 :::88 :::* LISTEN 0 26826 - tcp6 0 0 :::8889 :::* LISTEN 0 108217 - tcp6 0 0 :::8123 :::* LISTEN 0 108186 - tcp6 0 0 :::443 :::* LISTEN 0 39083 - tcp6 0 0 :::443 :::* LISTEN 0 39075 - tcp6 0 0 :::892 :::* LISTEN 0 25528 - tcp6 0 0 :::445 :::* LISTEN 0 49094 - tcp6 0 0 :::3261 :::* LISTEN 0 44566 - tcp6 0 0 :::5566 :::* LISTEN 0 73053 - tcp6 0 0 :::3263 :::* LISTEN 0 43877 - tcp6 0 0 :::3264 :::* LISTEN 0 44568 - tcp6 0 0 127.0.0.1:9665 :::* LISTEN 195763 91735 - tcp6 0 0 :::2049 :::* LISTEN 0 48564 - tcp6 0 0 :::3265 :::* LISTEN 0 46101 - tcp6 0 0 :::161 :::* LISTEN 0 38144 - tcp6 0 0 ::1:9666 :::* LISTEN 195763 118858 - tcp6 0 0 127.0.0.1:9666 :::* LISTEN 195763 118857 - tcp6 0 0 :::5000 :::* LISTEN 0 39077 - tcp6 0 0 :::5000 :::* LISTEN 0 39069 - tcp6 0 0 :::5001 :::* LISTEN 0 39079 - tcp6 0 0 :::5001 :::* LISTEN 0 39071 - tcp6 0 0 :::139 :::* LISTEN 0 49095 - tcp6 0 0 :::53325 :::* LISTEN 195763 117237 - tcp6 0 0 :::4045 :::* LISTEN 0 48576 - tcp6 0 0 :::5357 :::* LISTEN 0 40682 - tcp6 0 0 :::5357 :::* LISTEN 0 40680 - tcp6 0 0 :::111 :::* LISTEN 0 25038 - tcp6 0 0 :::80 :::* LISTEN 0 39081 - tcp6 0 0 :::80 :::* LISTEN 0 39073 - tcp6 0 0 :::8081 :::* LISTEN 1000 7076481 - tcp6 0 0 :::8082 :::* LISTEN 1000 7096300 - udp 0 0 0.0.0.0:111 0.0.0.0:* 0 24092 - udp 0 0 0.0.0.0:123 0.0.0.0:* 0 26012 - udp 0 0 192.168.1.255:137 0.0.0.0:* 0 14733345 - udp 0 0 192.168.1.111:137 0.0.0.0:* 0 14733344 - udp 0 0 0.0.0.0:137 0.0.0.0:* 0 14732280 - udp 0 0 192.168.1.255:138 0.0.0.0:* 0 14733347 - udp 0 0 192.168.1.111:138 0.0.0.0:* 0 14733346 - udp 0 0 0.0.0.0:138 0.0.0.0:* 0 14732281 - udp 0 0 0.0.0.0:161 0.0.0.0:* 0 38141 - udp 0 0 127.0.0.1:323 0.0.0.0:* 0 26010 - udp 0 0 127.0.0.1:601 0.0.0.0:* 0 26278 - udp 0 0 0.0.0.0:662 0.0.0.0:* 0 26282 - udp 0 0 0.0.0.0:892 0.0.0.0:* 0 25519 - udp 0 0 0.0.0.0:58638 0.0.0.0:* 1000 7086796 - udp 0 0 0.0.0.0:58733 0.0.0.0:* 0 14732463 - udp 0 0 0.0.0.0:9997 0.0.0.0:* 0 24125 - udp 0 0 0.0.0.0:9998 0.0.0.0:* 0 24124 - udp 0 0 0.0.0.0:9999 0.0.0.0:* 0 24123 - udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 7096189 - udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 7096188 - udp 0 0 0.0.0.0:1900 0.0.0.0:* 0 84186 - udp 0 0 0.0.0.0:1900 0.0.0.0:* 0 39477 - udp 0 0 0.0.0.0:2049 0.0.0.0:* 0 48563 - udp 0 0 127.0.0.1:60916 0.0.0.0:* 0 84184 - udp 0 0 0.0.0.0:3702 0.0.0.0:* 99 27789 - udp 0 0 0.0.0.0:4045 0.0.0.0:* 0 48573 - udp 0 0 0.0.0.0:5353 0.0.0.0:* 1000 7093271 - udp 0 0 0.0.0.0:5353 0.0.0.0:* 0 46415 - udp 0 0 0.0.0.0:46641 0.0.0.0:* 0 46417 - udp 0 0 0.0.0.0:5683 0.0.0.0:* 1000 7087882 - udp 0 0 0.0.0.0:63295 0.0.0.0:* 0 25034 - udp 0 0 192.168.1.111:55900 0.0.0.0:* 0 84185 - udp6 0 0 :::111 :::* 0 25036 - udp6 0 0 :::123 :::* 0 26013 - udp6 0 0 :::161 :::* 0 38142 - udp6 0 0 ::1:323 :::* 0 26011 - udp6 0 0 :::662 :::* 0 26286 - udp6 0 0 :::892 :::* 0 25525 - udp6 0 0 :::2049 :::* 0 48565 - udp6 0 0 :::3702 :::* 99 27791 - udp6 0 0 :::61372 :::* 0 25037 - udp6 0 0 :::4045 :::* 0 48575 - udp6 0 0 :::45044 :::* 0 46418 - udp6 0 0 :::5353 :::* 0 46416 - *** Log File - Last 25 Lines *** 2026-03-26 06:21:58.542 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.info.label:{"val":"Bewegungsmelder - Wohnzimmer","ack":true,"ts":1774502518352,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580899778} 2026-03-26 06:21:58.544 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.info.firmwareVersion:{"val":"3.2.48","ack":true,"ts":1774502518352,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675692922298} 2026-03-26 06:21:58.544 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.info.updateState:{"val":"UP_TO_DATE","ack":true,"ts":1774502518353,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675692922298} 2026-03-26 06:21:58.547 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.functionalChannelType:{"val":"DEVICE_SABOTAGE","ack":true,"ts":1774502518353,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865126} 2026-03-26 06:21:58.547 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.configPending:{"val":false,"ack":true,"ts":1774502518353,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1677685762380} 2026-03-26 06:21:58.565 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.dutyCycle:{"val":false,"ack":true,"ts":1774502518353,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774332279481} 2026-03-26 06:21:58.573 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.lowBat:{"val":false,"ack":true,"ts":1774502518365,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774332279481} 2026-03-26 06:21:58.581 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.routerModuleEnabled:{"val":false,"ack":true,"ts":1774502518365,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865126} 2026-03-26 06:21:58.581 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.routerModuleSupported:{"val":false,"ack":true,"ts":1774502518365,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865126} 2026-03-26 06:21:58.581 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.rssiDeviceValue:{"val":-66,"ack":true,"ts":1774502518365,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774502340738} 2026-03-26 06:21:58.581 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.rssiPeerValue:{"val":null,"ack":true,"ts":1774502518365,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865129} 2026-03-26 06:21:58.581 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.unreach:{"val":false,"ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774332279482} 2026-03-26 06:21:58.581 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.sabotage:{"val":false,"ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774332389693} 2026-03-26 06:21:58.588 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.functionalChannelType:{"val":"MOTION_DETECTION_CHANNEL","ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865129} 2026-03-26 06:21:58.595 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.motionDetected:{"val":true,"ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774502487756} 2026-03-26 06:21:58.595 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.illumination:{"val":0.97,"ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774502146009} 2026-03-26 06:21:58.595 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.currentIllumination:{"val":null,"ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865129} 2026-03-26 06:21:58.603 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.motionDetectionSendInterval:{"val":"SECONDS_30","ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1676438900733} 2026-03-26 06:21:58.603 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.motionBufferActive:{"val":false,"ack":true,"ts":1774502518367,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1677685760800} 2026-03-26 06:21:58.611 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.numberOfBrightnessMeasurements:{"val":1,"ack":true,"ts":1774502518367,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675600928761} 2026-03-26 06:21:58.612 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.groups.fe32a10b-4c65-47a4-819a-fc6ca7d5350b.info.type:{"val":"SWITCHING","ack":true,"ts":1774502518367,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580927555} 2026-03-26 06:21:58.612 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.groups.fe32a10b-4c65-47a4-819a-fc6ca7d5350b.info.label:{"val":"Bewegungsmelder Wohnzimmer","ack":true,"ts":1774502518367,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580927556} 2026-03-26 06:21:58.612 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.groups.fe32a10b-4c65-47a4-819a-fc6ca7d5350b.on:{"val":null,"ack":true,"ts":1774502518369,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580927556} 2026-03-26 06:21:58.618 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.groups.303a65f8-dedc-40ef-83a0-9ab477437fd5.info.type:{"val":"META","ack":true,"ts":1774502518370,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580902315} 2026-03-26 06:21:58.620 - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.groups.303a65f8-dedc-40ef-83a0-9ab477437fd5.info.label:{"val":"Bewegungsmelder Wohnzimmer","ack":true,"ts":1774502518371,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580902315}============ Mark until here for C&P =============
iob diag has finished.
Beim Slave
pi@SlaveIOBroker:~ $ iob diag /usr/bin/iob: line 21: /home/iobroker/iob_diag.log: Permission denied pi@SlaveIOBroker:~ $Da passt wohl was nicht den Rechten!?!
Iob Diag vom Master
Beim Slave
Führ den
iob fixaus.
Und stell das logging auf was gescheites ein, silly ist halt 'silly'.
