  4. Adapter: DasWetter
Adapter: DasWetter
1.7k Beiträge 249 Kommentatoren 718.7k Aufrufe 133 Beobachtet
  • H Online
    H Online
    hm_krause
    #1383
    Bei mir ist genau die gleiche Problematik wie bei @jb_sullivan
    • H Online
      H Online
      hm_krause
      #1384
      2026-01-10 11:09:08.056 - info: host.test-iob stopInstance system.adapter.daswetter.0 (force=false, process=true)
      2026-01-10 11:09:08.074 - info: daswetter.0 (1455) Got terminate signal TERMINATE_YOURSELF
      2026-01-10 11:09:08.078 - info: daswetter.0 (1455) terminating
      2026-01-10 11:09:08.081 - debug: daswetter.0 (1455) Plugin sentry destroyed
      2026-01-10 11:09:08.083 - info: daswetter.0 (1455) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2026-01-10 11:09:08.108 - info: host.test-iob stopInstance system.adapter.daswetter.0 send kill signal
      2026-01-10 11:09:08.585 - info: daswetter.0 (1455) terminating
      2026-01-10 11:09:08.628 - info: host.test-iob instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2026-01-10 11:09:11.989 - info: host.test-iob instance system.adapter.daswetter.0 in version "4.3.0" started with pid 1557
      2026-01-10 11:09:13.647 - debug: daswetter.0 (1557) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2026-01-10 11:09:13.691 - debug: daswetter.0 (1557) Objects client ready ... initialize now
      2026-01-10 11:09:13.694 - debug: daswetter.0 (1557) Objects create System PubSub Client
      2026-01-10 11:09:13.695 - debug: daswetter.0 (1557) Objects create User PubSub Client
      2026-01-10 11:09:13.721 - debug: daswetter.0 (1557) Objects client initialize lua scripts
      2026-01-10 11:09:13.728 - debug: daswetter.0 (1557) Objects connected to redis: 127.0.0.1:9001
      2026-01-10 11:09:13.748 - debug: daswetter.0 (1557) Redis States: Use Redis connection: 127.0.0.1:9000
      2026-01-10 11:09:13.756 - debug: daswetter.0 (1557) States create System PubSub Client
      2026-01-10 11:09:13.758 - debug: daswetter.0 (1557) States create User PubSub Client
      2026-01-10 11:09:13.810 - debug: daswetter.0 (1557) States connected to redis: 127.0.0.1:9000
      2026-01-10 11:09:13.840 - debug: daswetter.0 (1557) Plugin sentry Do not initialize Plugin (enabled=false)
      2026-01-10 11:09:13.929 - info: daswetter.0 (1557) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.21.0, js-controller: 7.0.7
      2026-01-10 11:09:13.954 - debug: daswetter.0 (1557) config : {"ApiKey":"399b37e83cc4d55d755cc79586f9286f0aba12e0401cece684cb68a8fcbb75ef","locations":[{"IsActive":true,"postcode":"04924","city":"Bad Liebenwerda","useHourlyForecast":true,"bundesland":"Brandenburg","useDailyForecast":true}],"iconSet":1,"parseTimeout":10,"parseInterval":120,"UsePNGorOriginalSVG":false,"UseColorOrBW":true,"CustomPath":"","CustomPathExt":"png","WindCustomPath":"","WindCustomPathExt":"png","MoonCustomPath":"","MoonCustomPathExt":"png"}
      2026-01-10 11:09:13.955 - debug: daswetter.0 (1557) create instance of Meteored
      2026-01-10 11:09:13.955 - debug: daswetter.0 (1557) DasWetter_0: instance created
      2026-01-10 11:09:14.888 - debug: daswetter.0 (1557) DasWetter_0: GetLocation called
      2026-01-10 11:09:14.889 - debug: daswetter.0 (1557) DasWetter_0: GetLocationPostcode called
      2026-01-10 11:09:15.406 - debug: daswetter.0 (1557) DasWetter_0: Meteored GetLocationPostcode response: {"ok":true,"expiracion":1768039755318,"data":{"locations":[{"hash":"bc4f7e5f0f99dd6a255cae2a8c9c8d41","name":"Canaan","description":"Maine","country_name":"USA"},{"hash":"2facd966e9ebc1253e992d41ddcec1f6","name":"Bad Liebenwerda","description":"Brandenburg","country_name":"Deutschland"}]}}
      2026-01-10 11:09:15.406 - info: daswetter.0 (1557) DasWetter_0: Meteored GetLocationPostcode: found 2 locations:
      2026-01-10 11:09:15.407 - info: daswetter.0 (1557) DasWetter_0: Name: Canaan, Description: Maine, Country: USA
      2026-01-10 11:09:15.407 - info: daswetter.0 (1557) DasWetter_0: Name: Bad Liebenwerda, Description: Brandenburg, Country: Deutschland
      2026-01-10 11:09:15.407 - info: daswetter.0 (1557) DasWetter_0: Meteored GetLocationPostcode: matched city "Bad Liebenwerda" => hash=2facd966e9ebc1253e992d41ddcec1f6, description=Brandenburg, country=Deutschland
      2026-01-10 11:09:15.417 - debug: daswetter.0 (1557) DasWetter_0: GetSymbols called
      2026-01-10 11:09:15.554 - error: daswetter.0 (1557) DasWetter_0: axios error in GetSymbols: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1768039755540,"info":{"message":"Quota Exceeded"}}
      2026-01-10 11:09:15.555 - debug: daswetter.0 (1557) DasWetter_0: GetForecastDaily called
      2026-01-10 11:09:15.688 - debug: daswetter.0 (1557) DasWetter_0: Meteored GetForecastDaily response: {"ok":true,"expiracion":1768081140000,"data":{"hash":"2facd966e9ebc1253e992d41ddcec1f6","name":"Bad Liebenwerda","url":"https://www.theweather.com/bad-liebenwerda.htm","days":[{"start":1767999600000,"symbol":24,"temperature_min":-11.27,"temperature_max":-3.87,"wind_speed":24,"wind_gust":45,"wind_direction":"E","rain":1.5,"rain_probability":90,"humidity":82,"pressure":1010,"snowline":0,"uv_index_max":0.4,"sun_in":1768028940000,"sun_mid":1768043636000,"sun_out":1768058353000,"moon_in":1767999911000,"moon_out":1768038946000,"moon_symbol":21,"moon_illumination":51.95},{"start":1768086000000,"symbol":3,"temperature_min":-14.22,"temperature_max":-4.53,"wind_speed":15,"wind_gust":28,"wind_direction":"W","rain":0,"rain_probability":0,"humidity":87,"pressure":1024,"snowline":0,"uv_index_max":0.4,"sun_in":1768115303000,"sun_mid":1768130060000,"sun_out":1768144839000,"moon_in":1768090680000,"moon_out":1768126070000,"moon_symbol":22,"moon_illumination":42.34},{"start":1768172400000,"symbol":20,"temperature_min":-14.36,"temperature_max":1.19,"wind_speed":13,"wind_gust":24,"wind_direction":"SE","rain":2.3,"rain_probability":80,"humidity":82,"pressure":1017,"snowline":0,"uv_index_max":0.5,"sun_in":1768201663000,"sun_mid":1768216484000,"sun_out":1768231326000,"moon_in":1768181463000,"moon_out":1768213348000,"moon_symbol":23,"moon_illumination":33.14},{"start":1768258800000,"symbol":12,"temperature_min":0.19,"temperature_max":3.23,"wind_speed":11,"wind_gust":20,"wind_direction":"W","rain":1.7,"rain_probability":80,"humidity":94,"pressure":1015,"snowline":1300,"uv_index_max":0.5,"sun_in":1768288020000,"sun_mid":1768302906000,"sun_out":1768317816000,"moon_in":1768272264000,"moon_out":1768300888000,"moon_symbol":23,"moon_illumination":24.6},{"start":1768345200000,"symbol":4,"temperature_min":0.77,"temperature_max":3.7,"wind_speed":16,"wind_gust":29,"wind_direction":"S","rain":0,"rain_probability":20,"humidity":93,"pressure":1015,"snowline":1900,"uv_index_max":0.5,"sun_in":1768374374000,"sun_mid":1768389328000,"sun_out":1768404307000,"moon_in":1768362991000,"moon_out":1768388848000,"moon_symbol":24,"moon_illumination":16.96}]}}
      2026-01-10 11:09:15.688 - debug: daswetter.0 (1557) DasWetter_0: Meteored GetForecastDaily: url=https://www.theweather.com/bad-liebenwerda.htm
      2026-01-10 11:09:15.689 - debug: daswetter.0 (1557) DasWetter_0: Meteored GetForecastDaily: parsed days_forecast count=5
      2026-01-10 11:09:15.775 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 24
      2026-01-10 11:09:15.886 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 3
      2026-01-10 11:09:15.994 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 20
      2026-01-10 11:09:16.092 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 12
      2026-01-10 11:09:16.198 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
      2026-01-10 11:09:16.275 - debug: daswetter.0 (1557) DasWetter_0: GetForecastHourly called
      2026-01-10 11:09:16.422 - debug: daswetter.0 (1557) DasWetter_0: Meteored GetForecastHourly response: {"ok":true,"expiracion":1768081140000,"data":{"hash":"2facd966e9ebc1253e992d41ddcec1f6","name":"Bad Liebenwerda","url":"https://www.theweather.com/bad-liebenwerda.htm","start":1767999600000,"hours":[{"end":1768003200000,"symbol":25,"night":true,"temperature":-4.85,"temperature_feels_like":-11.17,"wind_speed":22,"wind_gust":43,"wind_direction":"E","rain":0.2,"rain_probability":50,"humidity":89,"pressure":1000,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768006800000,"symbol":25,"night":true,"temperature":-5.58,"temperature_feels_like":-11.97,"wind_speed":21,"wind_gust":42,"wind_direction":"E","rain":0.5,"rain_probability":80,"humidity":87,"pressure":1001,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768010400000,"symbol":25,"night":true,"temperature":-5.94,"temperature_feels_like":-12.62,"wind_speed":22,"wind_gust":42,"wind_direction":"E","rain":0.4,"rain_probability":90,"humidity":84,"pressure":1002,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768014000000,"symbol":25,"night":true,"temperature":-6.81,"temperature_feels_like":-13.97,"wind_speed":24,"wind_gust":45,"wind_direction":"E","rain":0.2,"rain_probability":50,"humidity":82,"pressure":1003,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768017600000,"symbol":5,"night":true,"temperature":-7.14,"temperature_feels_like":-14.22,"wind_speed":23,"wind_gust":45,"wind_direction":"E","rain":0,"rain_probability":20,"humidity":82,"pressure":1004,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768021200000,"symbol":5,"night":true,"temperature":-7.41,"temperature_feels_like":-14.51,"wind_speed":23,"wind_gust":43,"wind_direction":"E","rain":0,"rain_probability":20,"humidity":83,"pressure":1004,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768024800000,"symbol":5,"night":true,"temperature":-7.62,"temperature_feels_like":-14.76,"wind_speed":23,"wind_gust":43,"wind_direction":"E","rain":0,"rain_probability":10,"humidity":83,"pressure":1005,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768028400000,"symbol":5,"night":false,"temperature":-7.79,"temperature_feels_like":-14.83,"wind_speed":22,"wind_gust":42,"wind_direction":"E","rain":0,"rain_probability":10,"humidity":81,"pressure":1007,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768032000000,"symbol":25,"night":false,"temperature":-7.65,"temperature_feels_like":-14.45,"wind_speed":21,"wind_gust":41,"wind_direction":"E","rain":0.1,"rain_probability":30,"humidity":79,"pressure":1008,"snowline":0,"uv_index_max":0.1,"clouds":100},{"end":1768035600000,"symbol":4,"night":false,"temperature":-7.47,"temperature_feels_like":-13.6,"wind_speed":17,"wind_gust":39,"wind_direction":"E","rain":0,"rain_probability":10,"humidity":77,"pressure":1009,"snowline":0,"uv_index_max":0.2,"clouds":90},{"end":1768039200000,"symbol":4,"night":false,"temperature":-7.4,"temperature_feels_like":-13.29,"wind_speed":16,"wind_gust":33,"wind_direction":"NE","rain":0,"rain_probability":0,"humidity":75,"pressure":1010,"snowline":0,"uv_index_max":0.3,"clouds":90},{"end":1768042800000,"symbol":4,"night":false,"temperature":-7.12,"temperature_feels_like":-12.07,"wind_speed":13,"wind_gust":31,"wind_direction":"NE","rain":0,"rain_probability":0,"humidity":73,"pressure":1010,"snowline":0,"uv_index_max":0.4,"clouds":57},{"end":1768046400000,"symbol":4,"night":false,"temperature":-6.99,"temperature_feels_like":-10.41,"wind_speed":8,"wind_gust":25,"wind_direction":"NE","rain":0,"rain_probability":0,"humidity":72,"pressure":1011,"snowline":0,"uv_index_max":0.4,"clouds":93},{"end":1768050000000,"symbol":3,"night":false,"temperature":-7,"temperature_feels_like":-9.42,"wind_speed":6,"wind_gust":16,"wind_direction":"NE","rain":0,"rain_probability":0,"humidity":73,"pressure":1012,"snowline":0,"uv_index_max":0.3,"clouds":29},{"end":1768053600000,"symbol":1,"night":false,"temperature":-7.99,"temperature_feels_like":-10.55,"wind_speed":6,"wind_gust":12,"wind_direction":"N","rain":0,"rain_probability":0,"humidity":76,"pressure":1013,"snowline":0,"uv_index_max":0.1,"clouds":3},{"end":1768057200000,"symbol":1,"night":false,"temperature":-9.69,"temperature_feels_like":-12.83,"wind_speed":6,"wind_gust":10,"wind_direction":"N","rain":0,"rain_probability":0,"humidity":82,"pressure":1014,"snowline":0,"uv_index_max":0,"clouds":5},{"end":1768060800000,"symbol":3,"night":true,"temperature":-10.73,"temperature_feels_like":-14.71,"wind_speed":8,"wind_gust":11,"wind_direction":"NW","rain":0,"rain_probability":0,"humidity":85,"pressure":1015,"snowline":0,"uv_index_max":0,"clouds":27},{"end":1768064400000,"symbol":5,"night":true,"temperature":-10.8,"temperature_feels_like":-15.22,"wind_speed":9,"wind_gust":13,"wind_direction":"NW","rain":0,"rain_probability":0,"humidity":86,"pressure":1015,"snowline":0,"uv_index_max":0,"clouds":98},{"end":1768068000000,"symbol":5,"night":true,"temperature":-7.62,"temperature_feels_like":-11.96,"wind_speed":10,"wind_gust":18,"wind_direction":"W","rain":0,"rain_probability":0,"humidity":84,"pressure":1016,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768071600000,"symbol":4,"night":true,"temperature":-6.45,"temperature_feels_like":-10.84,"wind_speed":11,"wind_gust":20,"wind_direction":"NW","rain":0,"rain_probability":0,"humidity":86,"pressure":1016,"snowline":0,"uv_index_max":0,"clouds":95},{"end":1768075200000,"symbol":4,"night":true,"temperature":-5.45,"temperature_feels_like":-9.64,"wind_speed":11,"wind_gust":20,"wind_direction":"NW","rain":0,"rain_probability":0,"humidity":89,"pressure":1017,"snowline":0,"uv_index_max":0,"clouds":75},{"end":1768078800000,"symbol":24,"night":true,"temperature":-4.65,"temperature_feels_like":-8.87,"wind_speed":12,"wind_gust":20,"wind_direction":"NW","rain":0.1,"rain_probability":30,"humidity":91,"pressure":1017,"snowline":0,"uv_index_max":0,"clouds":64},{"end":1768082400000,"symbol":3,"night":true,"temperature":-4.34,"temperature_feels_like":-8.91,"wind_speed":13,"wind_gust":23,"wind_direction":"NW","rain":0,"rain_probability":10,"humidity":92,"pressure":1018,"snowline":0,"uv_index_max":0,"clouds":29},{"end":1768086000000,"symbol":3,"night":true,"temperature":-4.96,"temperature_feels_like":-9.77,"wind_speed":14,"wind_gust":25,"wind_direction":"NW","rain":0,"rain_probability":0,"humidity":93,"pressure":1019,"snowline":0,"uv_index_max":0,"clouds":53}]}}
      2026-01-10 11:09:16.423 - debug: daswetter.0 (1557) DasWetter_0: Meteored GetForecastHourly: parsed hours_forecast count=24
      2026-01-10 11:09:16.457 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
      2026-01-10 11:09:16.516 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
      2026-01-10 11:09:16.576 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
      2026-01-10 11:09:16.636 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
      2026-01-10 11:09:16.710 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
      2026-01-10 11:09:16.786 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
      2026-01-10 11:09:16.854 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
      2026-01-10 11:09:16.910 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
      2026-01-10 11:09:16.969 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
      2026-01-10 11:09:17.026 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
      2026-01-10 11:09:17.111 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
      2026-01-10 11:09:17.198 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
      2026-01-10 11:09:17.247 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
      2026-01-10 11:09:17.292 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 3
      2026-01-10 11:09:17.337 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 1
      2026-01-10 11:09:17.396 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 1
      2026-01-10 11:09:17.442 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 3
      2026-01-10 11:09:17.492 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
      2026-01-10 11:09:17.536 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
      2026-01-10 11:09:17.580 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
      2026-01-10 11:09:17.624 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
      2026-01-10 11:09:17.667 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 24
      2026-01-10 11:09:17.711 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 3
      2026-01-10 11:09:17.758 - debug: daswetter.0 (1557) DasWetter_0: getSymbolLongDescription: no matching symbol for id 3
      und...
      • D3ltoroxpD D3ltoroxp
        Die Zeit stelle ich im Cron ein richtig ? Im Adapter selber gibts dazu ja nichts ? Hab jetzt mal auf 6h gestellt.
        Rene_HMR Offline
        Rene_HMR Offline
        Rene_HM
        schrieb am zuletzt editiert von Rene_HM
        #1385
        @D3ltoroxp wenn cron noch angeboten wird, ist das ein Zeichen, dass die Instanz NICHT wie beschrieben gelöscht wurde! Der Adapter wurde von "scheduled" auf "deamon" umgestellt, d.h. der Adapter läuft ständig. Mit Version 4 darf er nicht ständig neu starten...
        Der Adapter muss permanent "grün" anzeigen:
        Die einzige Einstellung ist im Adapter-admin hier zu tun:
        • Rene_HMR Offline
          Rene_HMR Offline
          Rene_HM
          #1386
          @hm_krause Ich denke, du hast das gleiche Problem! Auch hier stoppt der Adapter noch, was er mit Version 4, wenn sie richtig installiert ist, nicht mehr tut.
          • JB_SullivanJ Offline
            JB_Sullivan
            #1387
            Ich den Adapter eben auf DEBUG gestellt und nun auch 240 Minuten Abrufintervall eingestellt. Ferner habe ich als Symbole galaria7, Beaufort-White und original gewählt.
            Im DEBUG Modus bekomme ich nun noch die folgenden Meldungen dazu. Irgendwie matchen die Symbole und die Beschreibungen nicht - ?!?!?
            daswetter.0
            1056	2026-01-10 11:26:34.295	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
            daswetter.0
            1056	2026-01-10 11:26:34.083	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 1
            daswetter.0
            1056	2026-01-10 11:26:33.868	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 1
            daswetter.0
            1056	2026-01-10 11:26:33.489	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 3
            daswetter.0
            1056	2026-01-10 11:26:33.307	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
            daswetter.0
            1056	2026-01-10 11:26:33.136	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
            daswetter.0
            1056	2026-01-10 11:26:32.822	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
            daswetter.0
            1056	2026-01-10 11:26:32.353	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
            daswetter.0
            1056	2026-01-10 11:26:32.080	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
            daswetter.0
            1056	2026-01-10 11:26:31.751	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 3
            daswetter.0
            1056	2026-01-10 11:26:31.161	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
            daswetter.0
            1056	2026-01-10 11:26:30.686	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
            daswetter.0
            1056	2026-01-10 11:26:30.286	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
            daswetter.0
            1056	2026-01-10 11:26:28.458	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
            daswetter.0
            1056	2026-01-10 11:26:27.967	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
            daswetter.0
            1056	2026-01-10 11:26:26.268	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
            daswetter.0
            1056	2026-01-10 11:26:25.357	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
            daswetter.0
            1056	2026-01-10 11:26:23.957	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
            daswetter.0
            1056	2026-01-10 11:26:23.093	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
            daswetter.0
            1056	2026-01-10 11:26:22.639	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
            daswetter.0
            1056	2026-01-10 11:26:21.812	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
            daswetter.0
            1056	2026-01-10 11:26:20.916	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
            daswetter.0
            1056	2026-01-10 11:26:20.223	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
            daswetter.0
            1056	2026-01-10 11:26:19.663	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 25
            daswetter.0
            1056	2026-01-10 11:26:19.482	debug	DasWetter_0: Meteored GetForecastHourly: parsed hours_forecast count=24
            daswetter.0
            1056	2026-01-10 11:26:19.480	debug	DasWetter_0: Meteored GetForecastHourly response: {"ok":true,"expiracion":1768081140000,"data":{"hash":"57950c8d38e0ff5288039546a7a3462b","name":"Desconocido","url":"https://www.theweather.com/gn/2829221.htm","start":1767999600000,"hours":[{"end":1768003200000,"symbol":25,"night":true,"temperature":-5.14,"temperature_feels_like":-12.18,"wind_speed":26,"wind_gust":47,"wind_direction":"E","rain":0.1,"rain_probability":50,"humidity":88,"pressure":999,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768006800000,"symbol":25,"night":true,"temperature":-5.46,"temperature_feels_like":-12.49,"wind_speed":26,"wind_gust":45,"wind_direction":"E","rain":0.2,"rain_probability":30,"humidity":88,"pressure":1001,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768010400000,"symbol":25,"night":true,"temperature":-5.55,"temperature_feels_like":-12.79,"wind_speed":27,"wind_gust":48,"wind_direction":"E","rain":0.3,"rain_probability":90,"humidity":86,"pressure":1001,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768014000000,"symbol":25,"night":true,"temperature":-5.77,"temperature_feels_like":-13.08,"wind_speed":27,"wind_gust":49,"wind_direction":"E","rain":0.2,"rain_probability":40,"humidity":84,"pressure":1003,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768017600000,"symbol":25,"night":true,"temperature":-6.05,"temperature_feels_like":-13.35,"wind_speed":26,"wind_gust":48,"wind_direction":"E","rain":0.2,"rain_probability":40,"humidity":84,"pressure":1004,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768021200000,"symbol":25,"night":true,"temperature":-6.14,"temperature_feels_like":-13.34,"wind_speed":25,"wind_gust":47,"wind_direction":"E","rain":0.2,"rain_probability":50,"humidity":83,"pressure":1005,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768024800000,"symbol":25,"night":true,"temperature":-6.27,"temperature_feels_like":-13.37,"wind_speed":25,"wind_gust":45,"wind_direction":"E","rain":0.1,"rain_probability":40,"humidity":82,"pressure":1006,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768028400000,"symbol":5,"night":false,"temperature":-6.3,"temperature_feels_like":-13.42,"wind_speed":25,"wind_gust":44,"wind_direction":"E","rain":0,"rain_probability":10,"humidity":80,"pressure":1007,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768032000000,"symbol":5,"night":false,"temperature":-6.12,"temperature_feels_like":-13.12,"wind_speed":24,"wind_gust":44,"wind_direction":"E","rain":0,"rain_probability":0,"humidity":81,"pressure":1009,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768035600000,"symbol":5,"night":false,"temperature":-5.79,"temperature_feels_like":-12.69,"wind_speed":24,"wind_gust":43,"wind_direction":"E","rain":0,"rain_probability":0,"humidity":81,"pressure":1010,"snowline":0,"uv_index_max":0.2,"clouds":100},{"end":1768039200000,"symbol":4,"night":false,"temperature":-5.6,"temperature_feels_like":-12.37,"wind_speed":24,"wind_gust":43,"wind_direction":"E","rain":0,"rain_probability":0,"humidity":81,"pressure":1011,"snowline":0,"uv_index_max":0.3,"clouds":90},{"end":1768042800000,"symbol":4,"night":false,"temperature":-5.67,"temperature_feels_like":-11.97,"wind_speed":21,"wind_gust":42,"wind_direction":"E","rain":0,"rain_probability":0,"humidity":80,"pressure":1012,"snowline":0,"uv_index_max":0.4,"clouds":78},{"end":1768046400000,"symbol":5,"night":false,"temperature":-5.38,"temperature_feels_like":-10.93,"wind_speed":17,"wind_gust":36,"wind_direction":"E","rain":0,"rain_probability":0,"humidity":79,"pressure":1013,"snowline":0,"uv_index_max":0.4,"clouds":100},{"end":1768050000000,"symbol":4,"night":false,"temperature":-5.22,"temperature_feels_like":-9.6,"wind_speed":12,"wind_gust":29,"wind_direction":"E","rain":0,"rain_probability":0,"humidity":79,"pressure":1014,"snowline":0,"uv_index_max":0.3,"clouds":84},{"end":1768053600000,"symbol":3,"night":false,"temperature":-5.97,"temperature_feels_like":-9.69,"wind_speed":9,"wind_gust":20,"wind_direction":"NE","rain":0,"rain_probability":0,"humidity":81,"pressure":1015,"snowline":0,"uv_index_max":0.1,"clouds":29},{"end":1768057200000,"symbol":4,"night":false,"temperature":-7.47,"temperature_feels_like":-10.97,"wind_speed":8,"wind_gust":15,"wind_direction":"NE","rain":0,"rain_probability":0,"humidity":83,"pressure":1016,"snowline":0,"uv_index_max":0,"clouds":84},{"end":1768060800000,"symbol":5,"night":false,"temperature":-7.77,"temperature_feels_like":-10.71,"wind_speed":6,"wind_gust":12,"wind_direction":"NE","rain":0,"rain_probability":0,"humidity":84,"pressure":1017,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768064400000,"symbol":5,"night":true,"temperature":-5.4,"temperature_feels_like":-8.04,"wind_speed":6,"wind_gust":11,"wind_direction":"N","rain":0,"rain_probability":0,"humidity":85,"pressure":1018,"snowline":0,"uv_index_max":0,"clouds":100},{"end":1768068000000,"symbol":4,"night":true,"temperature":-4.74,"temperature_feels_like":-7.77,"wind_speed":8,"wind_gust":12,"wind_direction":"N","rain":0,"rain_probability":0,"humidity":87,"pressure":1019,"snowline":0,"uv_index_max":0,"clouds":89},{"end":1768071600000,"symbol":4,"night":true,"temperature":-4.91,"temperature_feels_like":-8.41,"wind_speed":9,"wind_gust":15,"wind_direction":"N","rain":0,"rain_probability":0,"humidity":90,"pressure":1019,"snowline":0,"uv_index_max":0,"clouds":69},{"end":1768075200000,"symbol":3,"night":true,"temperature":-5.85,"temperature_feels_like":-9.21,"wind_speed":8,"wind_gust":15,"wind_direction":"N","rain":0,"rain_probability":0,"humidity":91,"pressure":1020,"snowline":0,"uv_index_max":0,"clouds":24},{"end":1768078800000,"symbol":1,"night":true,"temperature":-8.06,"temperature_feels_like":-11.19,"wind_speed":7,"wind_gust":13,"wind_direction":"N","rain":0,"rain_probability":0,"humidity":93,"pressure":1021,"snowline":0,"uv_index_max":0,"clouds":1},{"end":1768082400000,"symbol":1,"night":true,"temperature":-10.18,"temperature_feels_like":-13.2,"wind_speed":6,"wind_gust":9,"wind_direction":"NW","rain":0,"rain_probability":0,"humidity":97,"pressure":1022,"snowline":0,"uv_index_max":0,"clouds":2},{"end":1768086000000,"symbol":4,"night":true,"temperature":-10.72,"temperature_feels_like":-14.87,"wind_speed":8,"wind_gust":12,"wind_direction":"NW","rain":0,"rain_probability":0,"humidity":94,"pressure":1023,"snowline":0,"uv_index_max":0,"clouds":60}]}}
            daswetter.0
            1056	2026-01-10 11:26:19.324	debug	DasWetter_0: GetForecastHourly called
            daswetter.0
            1056	2026-01-10 11:26:18.764	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 12
            daswetter.0
            1056	2026-01-10 11:26:17.662	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 5
            daswetter.0
            1056	2026-01-10 11:26:16.540	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 37
            daswetter.0
            1056	2026-01-10 11:26:15.655	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 4
            daswetter.0
            1056	2026-01-10 11:26:14.724	debug	DasWetter_0: getSymbolLongDescription: no matching symbol for id 24
            daswetter.0
            1056	2026-01-10 11:26:13.973	debug	DasWetter_0: Meteored GetForecastDaily: parsed days_forecast count=5
            daswetter.0
            1056	2026-01-10 11:26:13.972	debug	DasWetter_0: Meteored GetForecastDaily: url=https://www.theweather.com/gn/2829221.htm
            daswetter.0
            1056	2026-01-10 11:26:13.971	debug	DasWetter_0: Meteored GetForecastDaily response: {"ok":true,"expiracion":1768081140000,"data":{"hash":"57950c8d38e0ff5288039546a7a3462b","name":"Desconocido","url":"https://www.theweather.com/gn/2829221.htm","days":[{"start":1767999600000,"symbol":24,"temperature_min":-11.28,"temperature_max":-4.23,"wind_speed":27,"wind_gust":49,"wind_direction":"E","rain":1.3,"rain_probability":90,"humidity":85,"pressure":1012,"snowline":0,"uv_index_max":0.4,"sun_in":1768029931000,"sun_mid":1768044392000,"sun_out":1768058874000,"moon_in":1768000776000,"moon_out":1768039613000,"moon_symbol":21,"moon_illumination":51.95},{"start":1768086000000,"symbol":4,"temperature_min":-12.91,"temperature_max":-6.67,"wind_speed":13,"wind_gust":21,"wind_direction":"S","rain":0,"rain_probability":0,"humidity":91,"pressure":1026,"snowline":0,"uv_index_max":0.4,"sun_in":1768116291000,"sun_mid":1768130816000,"sun_out":1768145362000,"moon_in":1768091608000,"moon_out":1768126680000,"moon_symbol":22,"moon_illumination":42.34},{"start":1768172400000,"symbol":37,"temperature_min":-9.34,"temperature_max":3,"wind_speed":18,"wind_gust":32,"wind_direction":"S","rain":5.3,"rain_probability":80,"humidity":84,"pressure":1013,"snowline":100,"uv_index_max":0.5,"sun_in":1768202649000,"sun_mid":1768217239000,"sun_out":1768231852000,"moon_in":1768182457000,"moon_out":1768213897000,"moon_symbol":23,"moon_illumination":33.14},{"start":1768258800000,"symbol":5,"temperature_min":1.69,"temperature_max":3.43,"wind_speed":15,"wind_gust":25,"wind_direction":"SW","rain":0,"rain_probability":20,"humidity":95,"pressure":1013,"snowline":1600,"uv_index_max":0.5,"sun_in":1768289003000,"sun_mid":1768303662000,"sun_out":1768318344000,"moon_in":1768273326000,"moon_out":1768301375000,"moon_symbol":23,"moon_illumination":24.6},{"start":1768345200000,"symbol":12,"temperature_min":1.4,"temperature_max":6.6,"wind_speed":17,"wind_gust":33,"wind_direction":"S","rain":0.4,"rain_probability":70,"humidity":87,"pressure":1011,"snowline":1500,"uv_index_max":0.4,"sun_in":1768375354000,"sun_mid":1768390084000,"sun_out":1768404838000,"moon_in":1768364120000,"moon_out":1768389274000,"moon_symbol":24,"moon_illumination":16.96}]}}
            daswetter.0
            1056	2026-01-10 11:26:13.859	debug	DasWetter_0: GetForecastDaily called
            daswetter.0
            1056	2026-01-10 11:26:13.858	error	DasWetter_0: axios error in GetSymbols: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1768040793657,"info":{"message":"Quota Exceeded"}}
            daswetter.0
            1056	2026-01-10 11:26:13.515	debug	DasWetter_0: GetSymbols called
            daswetter.0
            1056	2026-01-10 11:26:13.408	info	DasWetter_0: Meteored GetLocationPostcode: matched city "meine Stadt" => hash=57950cxxxxxxxxxxxxxxxxx7a3462b, description=Niedersachsen, country=Bundesrepublik Deutschland
            daswetter.0
            1056	2026-01-10 11:26:13.408	info	DasWetter_0: Name: Stederdorf, Description: Niedersachsen, Country: Bundesrepublik Deutschland
            daswetter.0
            1056	2026-01-10 11:26:13.407	info	DasWetter_0: Name: Vöhrum, Description: Niedersachsen, Country: Bundesrepublik Deutschland
            daswetter.0
            1056	2026-01-10 11:26:13.407	info	DasWetter_0: Name: Röhrse, Description: Niedersachsen, Country: Bundesrepublik Deutschland
            daswetter.0
            1056	2026-01-10 11:26:13.407	info	DasWetter_0: Name: Peine, Description: Niedersachsen, Country: Deutschland
            daswetter.0
            1056	2026-01-10 11:26:13.406	info	DasWetter_0: Name: Aguilar de Codés, Description: Navarra, Country: Spanien
            daswetter.0
            1056	2026-01-10 11:26:13.406	info	DasWetter_0: Name: Espronceda, Description: Navarra, Country: Spanien
            daswetter.0
            1056	2026-01-10 11:26:13.406	info	DasWetter_0: Name: Otiñano, Description: Navarra, Country: Spanien
            daswetter.0
            1056	2026-01-10 11:26:13.405	info	DasWetter_0: Name: Armañanzas, Description: Navarra, Country: Spanien
            daswetter.0
            1056	2026-01-10 11:26:13.405	info	DasWetter_0: Name: Azuelo, Description: Navarra, Country: Spanien
            daswetter.0
            1056	2026-01-10 11:26:13.404	info	DasWetter_0: Meteored GetLocationPostcode: found 9 locations:
            daswetter.0
            1056	2026-01-10 11:26:13.403	debug	DasWetter_0: Meteored GetLocationPostcode response: {"ok":true,"expiracion":1768040793337,"data":{"locations":[{"hash":"0eb8095d60e292e2426df0d138bd6557","name":"Azuelo","description":"Navarra","country_name":"Spanien"},{"hash":"f5f51bff4a7153102b3b519cb7a713d3","name":"Armañanzas","description":"Navarra","country_name":"Spanien"},{"hash":"70ae1fc7b4022d29ec5e029cd87052b7","name":"Otiñano","description":"Navarra","country_name":"Spanien"},{"hash":"11abdced0c3f3ec0009f52830764b07a","name":"Espronceda","description":"Navarra","country_name":"Spanien"},{"hash":"0cabcbc9fe063a72c686bf16ef428bcf","name":"Aguilar de Codés","description":"Navarra","country_name":"Spanien"},{"hash":"2838d0064cf484223a7be36dece086b1","name":"Peine","description":"Niedersachsen","country_name":"Deutschland"},{"hash":"71eb92d03cf95361a5fa432dbfdd192b","name":"Röhrse","description":"Niedersachsen","country_name":"Bundesrepublik Deutschland"},{"hash":"02b3e0d998a017021a96eaa527881cec","name":"Vöhrum","description":"Niedersachsen","country_name":"Bundesrepublik Deutschland"},{"hash":"57950c8d38e0ff5288039546a7a3462b","name":"Stederdorf","description":"Niedersachsen","country_name":"Bundesrepublik Deutschland"}]}}
            daswetter.0
            1056	2026-01-10 11:26:12.733	debug	DasWetter_0: GetLocationPostcode called
            daswetter.0
            1056	2026-01-10 11:26:12.731	debug	DasWetter_0: GetLocation called
            daswetter.0
            1056	2026-01-10 11:25:56.941	debug	DasWetter_0: instance created
            daswetter.0
            1056	2026-01-10 11:25:56.941	debug	create instance of Meteored
            daswetter.0
            1056	2026-01-10 11:25:56.940	debug	config : {"ApiKey":"1fdfb12fxxxxxxxxxxxxxxxxxxxxx972feef7e5fedd896b11d76a9908cc","locations":[{"IsActive":true,"postcode":"31228","city":"meine stadt","useHourlyForecast":true,"useDailyForecast":true,"bundesland":"Niedersachsen"}],"iconSet":7,"parseTimeout":10,"parseInterval":240,"UsePNGorOriginalSVG":false,"UseColorOrBW":true,"CustomPath":"","CustomPathExt":"png","WindCustomPath":"","WindCustomPathExt":"png","MoonCustomPath":"","MoonCustomPathExt":"png","windiconSet":1,"mooniconSet":1}
            daswetter.0
            1056	2026-01-10 11:25:56.919	info	starting. Version 4.3.0 in C:/ioBroker/GLT/node_modules/iobroker.daswetter, node: v20.19.2, js-controller: 7.1.0
            daswetter.0
            1056	2026-01-10 11:25:42.866	debug	Plugin sentry Initialize Plugin (enabled=true)
            daswetter.0
            7816	2026-01-10 11:25:28.226	info	terminating
            daswetter.0
            7816	2026-01-10 11:25:28.225	info	terminating
            daswetter.0
            7816	2026-01-10 11:25:27.724	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            daswetter.0
            7816	2026-01-10 11:25:27.722	info	terminating
            daswetter.0
            7816	2026-01-10 11:25:27.720	info	Got terminate signal TERMINATE_YOURSELF
            Rene_HMR 1 Antwort Letzte Antwort
            • JB_SullivanJ JB_Sullivan
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              daswetter.0
              Rene_HMR Offline
              Rene_HMR Offline
              Rene_HM
              #1388
              @JB_Sullivan laut log
              • wird der richtige Ort gefunden
              • beim Abruf der Symbol-Beschreibungen bekommst du wieder der 429-Fehler
              • trotzdem bekommst du dann Daten für daily und hourly ohne Fehler
              • da der Adapter aber die Symbolbeschreibung (also die englischen Texte zu den Symbol-Id's) nicht downloaden kann, kann er auch die Übersetzung von ID zu (englischem) Text nicht durchführen. Erst im nächsten Schritt wäre dann noch die Übersetzung des englischen Textes nach deutsch dran, was nicht funktionieren kann, da es keinen englischen Text gibt.
              Damit sind wir wieder bei dem 429-Problem....
              • nik82N Offline
                nik82N Offline
                nik82
                #1389
                So ich habe jetzt auch mal den Adapter komplett gelöscht und die v4.3.0 installiert.
                Irgendwann muss man ja ran...
                Erstmal vielen Dank für deine Mühe.
                Leider hat sich ja doch die komplette Struktur geändert, somit muss ich mein VIS komplett neu aufbauen, aber das ist nicht so wild, ich habe eh das meiste mit dem Wetter-Widget-Bild gemacht:
                Aber die Sachen was ich dann noch hinzugefügt habe, finde ich nicht mehr:
                1. Sonnescheindauer:
                  Das war immer unter "daswetter.0.NextHours.Location_1.Day_1.sunshineDuration"
                  Ich finde jetzt nur noch den Datenpunkt "daswetter.0.location_1.ForecastDaily.Day_1.sunshineduration" und dieser scheint aber die Tagesdauer an Helligkeit zu sein und nicht die direkte Sonneneinstrahlung.
                  Wie du ja in Post #1308 schon angemerkt hast, aber hier muss ich anmerken das beim früheren Adapter zu 100% die direkte Sonneneinstrahlung in dem Objekt drin war, ich habe das jeden Tag verwendet :-)
                  --> Aber hier hast du ja geschrieben, das du da noch was machen möchtest.
                2. Windrichtungssymbol:
                  Hat auch @harling schon im Post #1370 angemerkt:
                  Das Windrichtungssymbol was immer unter "daswetter.0.NextDays.Location_1.Day_1.windIconURL"
                  Das finde ich jetzt leider gar nirgends mehr, gibt's das nicht mehr?
                Vielen Dank im Voraus.
                -1
                • nik82N nik82
                  Rene_HMR Offline
                  Rene_HMR Offline
                  Rene_HM
                  #1390
                  @nik82 danke für das feedback.
                  1. Sonnenscheindauer: ja, da baue ich eine Berechnung zumindest für den aktuellen Tag ein. Mehr Daten stehen mir (zumindest in der freien Version) nicht in der API zur Verfügung
                  1. Windrichtung: in der freien Version der API wird die Windrichtung nicht nur in Text (als S für Süd, N für Nord usw) geliefert. Ein allgemeines Windsymbol (mit Stärke und Windrichtung) liefert die API nicht. Auch hier muss ich im Adapter aus den vorhandenen Daten eine Symbol ableiten und als "URL" zur Verfügung stellen. Das kommt in einer der nächsten Versionen....
                  Wetter-Widget-Bild
                  Genau, wenn man nur eine Anzeige in der vis benötigt, reicht das i.d.R. vollkommen aus.
                  Für vis-2 gibt es dafür auch ein widget
                  • L leonundjulie
                    @negalein , Deine Anzeige sieht super aus. Die meisten Sachen habe ich heraus gekitzelt (habe Deine View in VIS2 importiert). Mit welchem WIDGET hast Du die Vorhersage erstellt (mir scheint der passende Adapter zu fehlen)?
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #1391
                    @leonundjulie sagte in Adapter: DasWetter:
                    basic string
                    basic number
                    ° Fixer ---> iob fix
                    • H Online
                      H Online
                      hm_krause
                      #1392
                      @jb_sullivan
                      erstelle Dir mal in der API einen neuen Nutzer und nimm dann diese API, hat bei mir sofort funktioniert.
                      • H hm_krause
                        @jb_sullivan
                        JB_Sullivan
                        #1393
                        @hm_krause sagte in Adapter: DasWetter:
                        @jb_sullivan
                        DANKE für den sehr guten Hinweis - hat auch bei mir mit einem neuen API Nutzer sofort funktioniert 👍👍👍👍
                        • stefu87_CHS Offline
                          stefu87_CHS Offline
                          stefu87_CH
                          #1394
                          @rene_hm trotz neu Starten des Systems, habe ich jeden Tag diese Meldungen im Log:
                          Cores: 1 × 8 = 8 cores
                          Threads: 16
                          mit Proxmox
                          LXC Container mit Iobroker
                          • KnallochseK Nicht stören
                            Knallochse
                            #1395
                            @rene_hm wäre es möglich, die Nachkommastellen bei den Temperaturen zu begrenzen? Zwei Stellen nach dem Komma finde ich bisschen unübersichtlich. Vielleicht kann man das ja konfigurierbar machen?
                            • stefu87_CHS stefu87_CH
                              Meister MopperM Online
                              Meister Mopper
                              #1396
                              @stefu87_CH sagte in Adapter: DasWetter:
                              Da läuft schon eine Instanz und ioBroker möchte eine weitere starten. Wie sieht der cronjob der Instanz aus?
                              Proxmox und HA ...
                              stefu87_CHS HomoranH Rene_HMR 3 Antworten Letzte Antwort
                                stefu87_CHS Offline
                                stefu87_CHS Offline
                                stefu87_CH
                                #1397
                                @Meister-Mopper sagte in Adapter: DasWetter:
                                Meinst du hier?
                                Threads: 16
                                mit Proxmox
                                  #1398
                                  nicht ganz. Es geht nur um die Instanz.0
                                  Davon scheint aber schon ein Prozess zu laufen.
                                  Warum aber auch
                                  und warum immer die selbe PID, erklärt sich mir nicht.
                                    Meinst du hier?
                                    #1399
                                    Meinst du hier?
                                    das würde immerhin die 15 Minuten Intervall erklären.
                                      Warum aber auch
                                      Meister Mopper
                                      #1400
                                      @Homoran sagte in Adapter: DasWetter:
                                      Natürlich, ich meinte Prozess.
                                      Proxmox und HA ...
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        #1401
                                        @Meister-Mopper Hast du die alte Instanz vom Adapter gelöscht?
                                        Wie oben schon mal geschrieben: Der Adapter verwendet keinen cron mehr und darf das auch nicht anbieten! Im worst case den ganzen Adapter löschen und neu installieren.
                                        https://forum.iobroker.net/topic/5347/adapter-daswetter/1385
                                        • KnallochseK Knallochse
                                          Rene_HMR Offline
                                          Rene_HMR Offline
                                          Rene_HM
                                          #1402
                                          @Knallochse Wie zeigst du die Werte an? Normalerweise würde ich erwarten, dass man im vis widget die Anzahl der Nachkommastellen konfiguriert.
