  3. Einsteigerfragen
  4. Installation
  5. ioBroker nicht mehr erreichbar
82 Beiträge 9 Kommentatoren 5.8k Aufrufe 6 Beobachtet
  • hruH Offline
    hruH Offline
    hru
    iob diag wollte dass ich iobroker fix mache, habe ich gemacht.
    Jetzt liefert iob diag die folgende Ausgabe
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: pinas
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     14:33:02 up 58 min,  2 users,  load average: 1.53, 0.99, 0.69
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-12-30 14:33:02 CET
               Universal time: Tue 2025-12-30 13:33:02 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    hru
    HOME=/home/hru
    GROUPS=hru adm dialout cdrom sudo audio video plugdev games users input render netdev _ssh gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Display-Manager:        * lightdm.service - LSB: Light Display Manager
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.2G        1.9G        4.9G         12M        1.5G        6.3G
    Swap:           209M          0B        209M
    Total:          8.4G        1.9G        5.1G
    Active iob-Instances:   11
             7820 M total memory
             1773 M used memory
             2239 M active memory
              640 M inactive memory
             4685 M free memory
              128 M buffer memory
             1337 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 14:33:03 up 58 min,  2 users,  load average: 1.53, 0.99, 0.69
    Tasks: 254 total,   1 running, 251 sleeping,   0 stopped,   2 zombie
    %Cpu(s): 12.5 us, 12.5 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7820.8 total,   4685.0 free,   1773.7 used,   1466.3 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6047.1 avail Mem
    *** FAILED SERVICES ***
      UNIT                        LOAD   ACTIVE SUB    DESCRIPTION
    * lighttpd.service            loaded failed failed Lighttpd Daemon
    * syncthing@syncthing.service loaded failed failed Syncthing - Open Source Continuous File Synchronization for syncthing
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     1.6G  2.8M  1.6G   1% /run
    /dev/mmcblk0p2 ext4       29G   21G  6.7G  76% /
    tmpfs          tmpfs     3.9G   12K  3.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     3.9G     0  3.9G   0% /tmp
    /dev/mmcblk0p1 vfat      510M   92M  419M  18% /boot/firmware
    /dev/sda2      btrfs     932G  4.2G  926G   1% /srv/dev-disk-by-uuid-ba59a13b-32bb-4d41-9433-56afa044749a
    tmpfs          tmpfs     783M   24K  783M   1% /run/user/1000
    [Tue Dec 30 13:34:17 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:B6:1C:04 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=0a7247d3-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Dec 30 13:34:21 2025] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
    [Tue Dec 30 13:34:24 2025] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w.
    Show mounted filesystems:
    TARGET                                                       SOURCE         FSTYPE OPTIONS
    /                                                            /dev/mmcblk0p2 ext4   rw,noatime,nodiratime
    |-/boot/firmware                                             /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/srv/dev-disk-by-uuid-ba59a13b-32bb-4d41-9433-56afa044749a /dev/sda2      btrfs  rw,relatime,ssd,space_cache=v2,subvolid=5,subvol=/
    /var:
    3.8G    /var/
    2.8G    /var/log/journal/84b8404402f646beb6c9935ffbcaf1f2
    2.8G    /var/log
    669M    /var/lib
    Archived and active journals take up 2.7G in the file system.
    /opt/iobroker/backups:
    23M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    197M    /opt/iobroker/iobroker-data/
    140M    /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-C_W7K-9p.js
    7.0M    /opt/iobroker/iobroker-data/objects.jsonl
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0012-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0014-if00-port0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.6
    /usr/bin/node           v20.19.6
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.34.1
    nodejs:
      Installed: 20.19.6-1nodesource1
      Candidate: 20.19.6-1nodesource1
      Version table:
     *** 20.19.6-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.19.5-1nodesource1 1001
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
            500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    pinas               pinas (version: 7.0.7, hostname: pinas         , alive, uptime: 94)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : pinas                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : pinas                                    -  enabled
      system.adapter.discovery.0              : discovery             : pinas                                    -  enabled
    + system.adapter.email.0                  : email                 : pinas                                    -  enabled
    + system.adapter.influxdb.0               : influxdb              : pinas                                    -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : pinas                                    -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : pinas                                    -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : pinas                                    -  enabled
    + system.adapter.modbus.0                 : modbus                : pinas                                    -  enabled
      system.adapter.shelly.0                 : shelly                : pinas                                    -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartmeter.0             : smartmeter            : pinas                                    -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : pinas                                    -  enabled
      system.adapter.wolf-smartset.0          : wolf-smartset         : pinas                                    - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "wolf-smartset": 2.1.2    , installed 2.1.2
    Objects and States
    Objects:        1167
    States:         839
    Get:1 file:/var/cache/openmediavault/archives ./ InRelease
    Ign:1 file:/var/cache/openmediavault/archives ./ InRelease
    Get:2 file:/var/cache/openmediavault/archives ./ Release
    Ign:2 file:/var/cache/openmediavault/archives ./ Release
    Get:3 file:/var/cache/openmediavault/archives ./ Packages
    Err:3 file:/var/cache/openmediavault/archives ./ Packages
      Method gave a blank filename
    Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:5 http://deb.debian.org/debian bookworm InRelease
    Hit:6 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:7 http://httpredir.debian.org/debian bookworm-backports InRelease
    Hit:8 http://packages.openmediavault.org/public sandworm InRelease
    Hit:9 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:10 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:11 https://repos.influxdata.com/debian stable InRelease
    Hit:12 https://openmediavault.github.io/packages sandworm InRelease
    Hit:13 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:14 https://packages.sury.org/php bookworm InRelease
    Hit:15 https://apt.grafana.com stable InRelease
    Get:16 https://apt.syncthing.net syncthing InRelease [24.2 kB]
    Fetched 24.2 kB in 2s (11.0 kB/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.72:5357     0.0.0.0:*               LISTEN      64757      9412       1306/python3
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      992        556        631/systemd-resolve
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          5055       852/connmand
    tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      992        558        631/systemd-resolve
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1004       53266      8711/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1004       53261      8711/iobroker.js-co
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7655       873/cupsd
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          8806       1486/smbd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      993        10599      1590/influxd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1003       898/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          7830       1389/nginx: master
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          8807       1486/smbd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1004       56030      9059/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      111        7637       894/mosquitto
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      992        544        631/systemd-resolve
    tcp6       0      0 fe80::dea6:32ff:fe:5357 :::*                    LISTEN      64757      9422       1306/python3
    tcp6       0      0 :::3000                 :::*                    LISTEN      115        9779       1759/grafana
    tcp6       0      0 :::8081                 :::*                    LISTEN      1004       53336      8738/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      993        10732      1590/influxd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7654       873/cupsd
    tcp6       0      0 ::1:53                  :::*                    LISTEN      0          5059       852/connmand
    tcp6       0      0 :::445                  :::*                    LISTEN      0          8804       1486/smbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1005       898/sshd: /usr/sbin
    tcp6       0      0 :::80                   :::*                    LISTEN      0          7832       1389/nginx: master
    tcp6       0      0 :::139                  :::*                    LISTEN      0          8805       1486/smbd
    tcp6       0      0 :::1883                 :::*                    LISTEN      111        7638       894/mosquitto
    tcp6       0      0 :::5355                 :::*                    LISTEN      992        552        631/systemd-resolve
    udp        0      0 192.168.178.72:3702     0.0.0.0:*                           64757      9408       1306/python3
    udp        0      0 239.255.255.250:3702    0.0.0.0:*                           64757      9406       1306/python3
    udp        0      0 0.0.0.0:49149           0.0.0.0:*                           0          10270      852/connmand
    udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          5047       852/connmand
    udp        0      0 127.0.0.54:53           0.0.0.0:*                           992        557        631/systemd-resolve
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           992        555        631/systemd-resolve
    udp        0      0 192.168.178.72:68       0.0.0.0:*                           998        5118       391/systemd-network
    udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          10403      1366/chronyd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        935        684/avahi-daemon: r
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           992        543        631/systemd-resolve
    udp        0      0 0.0.0.0:55208           0.0.0.0:*                           64757      9407       1306/python3
    udp        0      0 0.0.0.0:38890           0.0.0.0:*                           104        937        684/avahi-daemon: r
    udp6       0      0 :::48317                :::*                                64757      9417       1306/python3
    udp6       0      0 fe80::dea6:32ff:fe:3702 :::*                                64757      9418       1306/python3
    udp6       0      0 ff02::c:3702            :::*                                64757      9416       1306/python3
    udp6       0      0 ::1:53                  :::*                                0          5051       852/connmand
    udp6       0      0 ::1:323                 :::*                                0          10404      1366/chronyd
    udp6       0      0 :::546                  :::*                                0          9440       852/connmand
    udp6  101824      0 fe80::dea6:32ff:feb:546 :::*                                998        10462      391/systemd-network
    udp6       0      0 :::5353                 :::*                                104        936        684/avahi-daemon: r
    udp6       0      0 :::5355                 :::*                                992        551        631/systemd-resolve
    udp6       0      0 :::34378                :::*                                104        938        684/avahi-daemon: r
    2025-12-30 14:32:05.239  - info: influxdb.2 (8880) enabled logging of z1_2__1_8_0_bezug_tag, Alias=true, 7 points now activated
    2025-12-30 14:32:05.240  - info: influxdb.2 (8880) enabled logging of z1_2__2_8_0_einspeisung_tag, Alias=true, 8 points now activated
    2025-12-30 14:32:05.242  - info: influxdb.2 (8880) enabled logging of z3_4__2_8_0_einspeisung_oder_wallbox_tag, Alias=true, 9 points now activated
    2025-12-30 14:32:05.243  - info: influxdb.2 (8880) enabled logging of z3_4__1_8_0_bezug_haus_tag, Alias=true, 10 points now activated
    2025-12-30 14:32:05.248  - info: influxdb.2 (8880) enabled logging of diff_z3_z1__2_8_0_einspeisung_wallbox_tag, Alias=true, 11 points now activated
    2025-12-30 14:32:05.249  - info: influxdb.2 (8880) enabled logging of diff_z1_z3__1_8_0_bezug_wallbox_tag, Alias=true, 12 points now activated
    2025-12-30 14:32:05.325  - info: host.pinas instance system.adapter.email.0 in version "2.0.4" started with pid 8902
    2025-12-30 14:32:08.257  - info: email.0 (8902) starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v20.19.6, js-controller: 7.0.7
    2025-12-30 14:32:09.228  - info: host.pinas instance system.adapter.backitup.0 in version "3.3.10" started with pid 8922
    2025-12-30 14:32:11.973  - info: backitup.0 (8922) starting. Version 3.3.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.6, js-controller: 7.0.7
    2025-12-30 14:32:12.062  - info: backitup.0 (8922) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2025-12-30 14:32:13.153  - info: host.pinas instance system.adapter.modbus.0 in version "6.3.2" started with pid 8937
    2025-12-30 14:32:15.499  - info: modbus.0 (8937) starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.19.6, js-controller: 7.0.7
    2025-12-30 14:32:16.763  - info: modbus.0 (8937) Connected to slave 192.168.178.45
    2025-12-30 14:32:17.231  - info: host.pinas instance system.adapter.smartmeter.0 in version "3.4.0" started with pid 8989
    2025-12-30 14:32:20.418  - info: smartmeter.0 (8989) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v20.19.6, js-controller: 7.0.7
    2025-12-30 14:32:21.223  - info: host.pinas instance system.adapter.smartmeter.1 in version "3.4.0" started with pid 9028
    2025-12-30 14:32:22.519  - info: smartmeter.0 (8989) Received 26 values, 26 updated
    2025-12-30 14:32:24.669  - info: smartmeter.1 (9028) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v20.19.6, js-controller: 7.0.7
    2025-12-30 14:32:25.266  - info: host.pinas instance system.adapter.shelly.0 in version "10.4.1" started with pid 9059
    2025-12-30 14:32:26.054  - info: smartmeter.1 (9028) Received 26 values, 26 updated
    2025-12-30 14:32:28.716  - info: shelly.0 (9059) starting. Version 10.4.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.19.6, js-controller: 7.0.7
    2025-12-30 14:32:29.165  - info: host.pinas instance system.adapter.discovery.0 in version "5.0.0" started with pid 9085
    2025-12-30 14:32:29.659  - info: shelly.0 (9059) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 1)
    2025-12-30 14:32:32.437  - info: discovery.0 (9085) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.19.6, js-controller: 7.0.7
    PV-Anlage:
    13,5 kWp, WR: Sungrow SH10RT, Speicher: Sungrow SBR128, Heizstab: MyPV AC ELWA2
    Sonstige Geräte:
    ShellyPlusSmoke Rauchwarnmelder, Shelly Gas Warnmelder, Shelly Flood,
    IR-Leseköpfe für Stromzähler
    • hruH Offline
      hruH Offline
      hru
      ich habe doch noch eine Bitte;-)
      Kann mir bitte jemand erklären, was das für Fehlermeldungen sind und wie ich die abstellen kann?
      hru@pinas:~ $ journalctl -p err -b
      Dec 30 14:39:00 pinas systemd[1]: syslog.socket: Socket service syslog.service not loaded, refusing.
      Dec 30 14:39:00 pinas systemd[1]: Failed to listen on syslog.socket - Syslog Socket.
      Dec 30 14:39:00 pinas systemd-modules-load[346]: Failed to find module 'softdog'
      Dec 30 14:39:03 pinas connmand[857]: The name net.connman.vpn was not provided by any .service files
      Dec 30 14:39:38 pinas connmand[857]: Failed to find URL:http://ipv4.connman.net/online/status.html
      Dec 30 14:39:41 pinas connmand[857]: Failed to find URL:http://ipv6.connman.net/online/status.html
      Dec 30 14:39:42 pinas connmand[857]: Failed to find URL:http://ipv6.connman.net/online/status.html
      Dec 30 14:39:42 pinas smbd[1535]: [2025/12/30 14:39:42.546725,  0] ../../source3/smbd/server.c:1741(main)
      Dec 30 14:39:42 pinas smbd[1535]:   smbd version 4.17.12-Debian started.
      Dec 30 14:39:42 pinas smbd[1535]:   Copyright Andrew Tridgell and the Samba Team 1992-2022
      Dec 30 14:39:45 pinas systemd[1]: Failed to start lighttpd.service - Lighttpd Daemon.
      Dec 30 14:39:46 pinas connmand[857]: Failed to find URL:http://ipv6.connman.net/online/status.html
      Dec 30 14:39:50 pinas systemd[1]: Failed to start syncthing@syncthing.service - Syncthing - Open Source Continuous File Synchronization for syncthing.
      hru@pinas:~ $
      Vielen Dank vorab für Eure Hilfe!
      Gruß Hartmut
      PV-Anlage:
      Sonstige Geräte:
      • hruH hru
        hru@pinas:~ $
        Gruß Hartmut
        @hru
        In deinen Paketquellen herrscht Chaos. Kommt wohl vom OMV. Keine Ahnung was der da treibt.
        Würde ich auch mal sauber in Version 8 installieren.
        Dein OS musst du auf Debian 13 'Trixie' heben.
        connman ist ein Netzwerkmanager. Schleppt vermutlich OMV an, auf einem Standard RaspberryOS wird der nicht verwendet.
        hruH 1 Antwort Letzte Antwort
        • hruH hru
          ich habe ioBroker auf einem Raspi als headless Installation am laufen.
          Ist seit mehreren Jahren super gelaufen.
          Seit heute ist er nicht mehr zu erreichen und auch nicht mehr in der Liste der Netzwerkgeräte in der Fritzbox aufgeführt.
          Aufgefallen ist mir das ganze, weil die über den ioBroker gesteuerte Weihnachtsbeleuchtung (shellys) heute Abend nicht angegangen ist.
          Ein ziehen des Netzsteckers und Neustart bringt keine Änderung.
          Die LED am Netzwerkkabel blinkt.
          Wie geht man hier am besten bei der Fehlersuche vor?
          Ich bin gerade etwas überfordert.
          Danke vorab für jeden Tipp.
          Gruß Hartmut
          AndreiosA Offline
          AndreiosA Offline
          Andreios
          Forum Testing
          @hru Ich habe mehrere Raspi laufen, dabei einer exklusiv für ioBroker.
          Es hat sich gezeigt, dass es gut ist, Monitor und Tastatur bei Bedarf zur Hand zu haben.
          Ich habe die Tage den Raspi nicht mehr erreicht, weil der durch einen (oder 2?) zusätzlich aktivierten Adapter auf einmal voll ausgelastet war und per SSH nicht mehr erreichbar.
          Da konnte ich zum Glück direkt beim Start an der Konsole den Adapter deaktivieren und damit hat sich das Problem erst einmal gelöst.
          Bei Gelegenheit muss ich jetzt einmal schauen, welcher von beiden da das Problem macht, roborock oder ring!
          Schöne Grüße
          Andreas
          ioBroker auf Raspberry 4 mit SSD. Homematik IP mit CCU 3. Shelly. MySQL. Arduino. ...
          Meine Posts sind subjektiv und manipulativ, erheben Anspruch auf Allwissenheit und können Spuren von Ironie oder Sarkasmus enthalten. ;-)
          • AndreiosA Andreios
            hruH Offline
            hruH Offline
            hru
            @Andreios sagte in ioBroker nicht mehr erreichbar:
            ja da hast Du Recht.
            Ich werde wohl den Monitor und die Tastatur am Raspi dran lassen, um schnell reagieren zu können.
            Gruß Hartmut
            PV-Anlage:
            Sonstige Geräte:
            AndreiosA 1 Antwort Letzte Antwort
              @hru
              hruH Offline
              hruH Offline
              hru
              @Thomas-Braun sagte in ioBroker nicht mehr erreichbar:
              ok das sieht mir nach mehreren einzeln durchzuführenden Steps.
              Wie genau mache ich denn das Update auf Debian 13?
              Macht man das über die Konsole?
              Läuft dann der ioBroker und das OMV auch noch?
              Danke und Gruß
              Hartmut
              PV-Anlage:
              Sonstige Geräte:
              • hruH hru
                Danke und Gruß
                Hartmut
                @hru
                https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
                Inwieweit da OMV wie genau zu berücksichtigen ist kann ich dir aber nicht sagen, da ich das nicht verwende.
                • hruH Offline
                  hruH Offline
                  hru
                  ich habe auf Debian 13 (Trixie) aktualisiert.
                  Jetzt habe ich die Folgenden Meldungen.
                  hru@pinas:~ $ lsb_release -a
                  No LSB modules are available.
                  Distributor ID: Debian
                  Description:    Debian GNU/Linux 13 (trixie)
                  Release:        13
                  Codename:       trixie
                  Dec 30 17:03:43 pinas systemd[1]: syslog.socket: Socket service syslog.service not loaded, refusing.
                  Dec 30 17:03:43 pinas systemd[1]: Failed to listen on syslog.socket - Syslog Socket.
                  Dec 30 17:03:43 pinas systemd-modules-load[312]: Failed to find module 'softdog'
                  Dec 30 17:03:44 pinas systemd-udevd[378]: /usr/lib/udev/rules.d/90-alsa-restore.rules:18 GOTO="alsa_restore_std" has no matching label, ignoring.
                  Dec 30 17:03:44 pinas systemd-udevd[378]: /usr/lib/udev/rules.d/90-alsa-restore.rules:22 GOTO="alsa_restore_std" has no matching label, ignoring.
                  Dec 30 17:03:44 pinas connmand[871]: The name net.connman.vpn was not provided by any .service files
                  Dec 30 17:04:29 pinas connmand[871]: Failed to find URL:http://ipv6.connman.net/online/status.html
                  Dec 30 17:04:29 pinas connmand[871]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for end0 [ ethernet ] online check URL http://ipv6.connman.net>
                  Dec 30 17:04:30 pinas connmand[871]: Failed to find URL:http://ipv6.connman.net/online/status.html
                  Dec 30 17:04:30 pinas connmand[871]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for end0 [ ethernet ] online check URL http://ipv6.connman.net>
                  Dec 30 17:04:31 pinas connmand[871]: Failed to find URL:http://ipv6.connman.net/online/status.html
                  Dec 30 17:04:31 pinas connmand[871]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for end0 [ ethernet ] online check URL http://ipv6.connman.net>
                  Dec 30 17:04:34 pinas systemd[1]: Failed to start lighttpd.service - Lighttpd Daemon.
                  Dec 30 17:04:35 pinas connmand[871]: Failed to find URL:http://ipv6.connman.net/online/status.html
                  Dec 30 17:04:35 pinas connmand[871]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for end0 [ ethernet ] online check URL http://ipv6.connman.net>
                  Dec 30 17:04:36 pinas systemd[1]: Failed to start syncthing@syncthing.service - Syncthing - Open Source Continuous File Synchronization for syncthing.
                  Dec 30 17:04:44 pinas connmand[871]: Failed to find URL:http://ipv6.connman.net/online/status.html
                  Dec 30 17:04:44 pinas connmand[871]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for end0 [ ethernet ] online check URL http://ipv6.connman.net>
                  Dec 30 17:05:00 pinas connmand[871]: Failed to find URL:http://ipv6.connman.net/online/status.html
                  Dec 30 17:05:00 pinas connmand[871]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for end0 [ ethernet ] online check URL http://ipv6.connman.net>
                  Dec 30 17:05:25 pinas connmand[871]: Failed to find URL:http://ipv6.connman.net/online/status.html
                  Dec 30 17:05:25 pinas connmand[871]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for end0 [ ethernet ] online check URL http://ipv6.connman.net>
                  Dec 30 17:06:01 pinas connmand[871]: Failed to find URL:http://ipv6.connman.net/online/status.html
                  Dec 30 17:06:01 pinas connmand[871]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for end0 [ ethernet ] online check URL http://ipv6.connman.net>
                  Dec 30 17:06:50 pinas connmand[871]: Failed to find URL:http://ipv6.connman.net/online/status.html
                  Dec 30 17:06:50 pinas connmand[871]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for end0 [ ethernet ] online check URL http://ipv6.connman.net>
                  hru@pinas:~ $
                  Welche davon sind "böse" und müssen beseitigt werden?
                  Danke vorab für Eure Unterstützung.
                  Gruß Hartmut
                  PV-Anlage:
                  Sonstige Geräte:
                  • hruH hru
                    Release:        13
                    Codename:       trixie
                    hru@pinas:~ $
                    Gruß Hartmut
                    @hru sagte in ioBroker nicht mehr erreichbar:
                    Die kommen alle aus der OMV-Ecke. Frag da mal nach.
                    • hruH Offline
                      hruH Offline
                      hru
                      ok ich habe connman deinstalliert
                      sudo apt purge connman
                      (weil OMV den gar nicht verwendet, war vermutlich noch aus Zeiten von solaranzeige an Bord).
                      Jetzt sind die connman-Fehler weg.
                      Allerdings komme ich jetzt nicht mehr per ssh auf den Raspi;-(
                      Hölzchen- Stöckchen...
                      PV-Anlage:
                      Sonstige Geräte:
                      • hruH hru
                        noch ein Grund für einen clean install.
                        Dann verschwinden auch solche unnötigen Dateileichen.
                        das äußert sich wie?
                        hruH 2 Antworten Letzte Antwort
                          hruH Offline
                          hruH Offline
                          hru
                          schrieb am zuletzt editiert von hru
                          @Homoran sagte in ioBroker nicht mehr erreichbar:
                          Durch die Deinstallation von connman war die Netzwerkkonfiguration kaputt gegangen.
                          Eine manuell Reparatur auf der Konsole des Pi (sudo dhclient end0) und anschließende Neukonfiguration über die Weboberfläche von OMV und schon ist der Raspi wieder per ssh erreichbar;-)
                          PV-Anlage:
                          Sonstige Geräte:
                            hruH Offline
                            hruH Offline
                            hru
                            Ja da hast Du Recht.
                            Wenn ich alles wieder am Laufen habe und auch die Sicherung der Konfiguration des ioBroker sauber funktioniert (und auch wohin sichert wo ich dran komme wenn der Raspi ausgefallen ist) dann sollte ich diesen Schritt gehen.
                            Gruß Hartmut
                            PV-Anlage:
                            Sonstige Geräte:
                            • hruH Offline
                              hruH Offline
                              hru
                              diese Meldungen hätte ich gerne noch beseitigt:
                              Dec 30 18:51:59 pinas systemd[1]: syslog.socket: Socket service syslog.service not loaded, refusing.
                              Dec 30 18:51:59 pinas systemd[1]: Failed to listen on syslog.socket - Syslog Socket.
                              Dec 30 18:51:59 pinas systemd-modules-load[313]: Failed to find module 'softdog'
                              Dec 30 18:52:00 pinas systemd-udevd[371]: /usr/lib/udev/rules.d/90-alsa-restore.rules:18 GOTO="alsa_restore_std" has no matching label, ignoring.
                              Dec 30 18:52:00 pinas systemd-udevd[371]: /usr/lib/udev/rules.d/90-alsa-restore.rules:22 GOTO="alsa_restore_std" has no matching label, ignoring.
                              Dec 30 18:52:51 pinas systemd[1]: Failed to start lighttpd.service - Lighttpd Daemon.
                              Dec 30 18:52:53 pinas systemd[1]: Failed to start syncthing@syncthing.service - Syncthing - Open Source Continuous File Synchronization for syncthing.
                              hru@pinas:~ $
                              Habt Ihr dazu Vorschläge?
                              Danke vorab für Eure Unterstützung!
                              Gruß Hartmut
                              PV-Anlage:
                              Sonstige Geräte:
                              • hruH Offline
                                hruH Offline
                                hru
                                kurzes Update:
                                Die Meldung von syncthing habe ich beseitigt bekommen, da war in der Konfiguration noch die alte IP-Adresse vom Raspi drin.
                                Jetzt habe ich nur noch diese Meldungen
                                Dec 30 20:01:38 pinas systemd[1]: syslog.socket: Socket service syslog.service not loaded, refusing.
                                Dec 30 20:01:38 pinas systemd[1]: Failed to listen on syslog.socket - Syslog Socket.
                                Dec 30 20:01:38 pinas systemd-modules-load[311]: Failed to find module 'softdog'
                                Dec 30 20:01:38 pinas systemd-udevd[369]: /usr/lib/udev/rules.d/90-alsa-restore.rules:18 GOTO="alsa_restore_std" has no matching label, ignoring.
                                Dec 30 20:01:38 pinas systemd-udevd[369]: /usr/lib/udev/rules.d/90-alsa-restore.rules:22 GOTO="alsa_restore_std" has no matching label, ignoring.
                                Dec 30 20:02:30 pinas systemd[1]: Failed to start lighttpd.service - Lighttpd Daemon.
                                hru@pinas:~ $
                                PV-Anlage:
                                Sonstige Geräte:
                                • hruH hru
                                  kurzes Update:
                                  hru@pinas:~ $
                                  @hru
                                  Egal.
                                  • hruH Offline
                                    hruH Offline
                                    hru
                                    ja ich höre jetzt auch auf;-)
                                    Ich habe noch lighttpd entfernt:
                                    sudo apt purge lighttpd
                                    Aktueller Stand:
                                    Dec 30 20:58:37 pinas systemd[1]: syslog.socket: Socket service syslog.service not loaded, refusing.
                                    Dec 30 20:58:37 pinas systemd[1]: Failed to listen on syslog.socket - Syslog Socket.
                                    Dec 30 20:58:37 pinas systemd-modules-load[313]: Failed to find module 'softdog'
                                    Dec 30 20:58:38 pinas systemd-udevd[374]: /usr/lib/udev/rules.d/90-alsa-restore.rules:18 GOTO="alsa_restore_std" has no matching label, ignoring.
                                    Dec 30 20:58:38 pinas systemd-udevd[374]: /usr/lib/udev/rules.d/90-alsa-restore.rules:22 GOTO="alsa_restore_std" has no matching label, ignoring.
                                    hru@pinas:~ $
                                    PV-Anlage:
                                    Sonstige Geräte:
                                    • hruH Offline
                                      hruH Offline
                                      hru
                                      Jetzt möchte ich gerne, dass der Backup-Adapter die Sicherung auf meine an der Fritzbox angeschlossene Festplatte sichert.
                                      Dazu habe ich in der Fritzbox/Fritz.nas einen User iobroker angelegt und diesem die Berechtigung auf "seinen" Backup-Ordner gegeben.
                                      In den Einstellungen der Instanz des Backup-Adapters habe ich das soweit ich konnte eingegeben, aber ich finde die Stelle nicht, an der ich den zu verwendenden Usernamen und das zugehörige Kennwort für den Zugriff auf das Fritz.nas eingeben kann:
                                      Im TotalCommander lautet der Windows-Pfad
                                      \\fritz.nas\FRITZ.NAS\TOSHIBA_EXT\BACKUP\iobroker\
                                      Wo gebe ich den Usernamen und das Kennwort für den Zugriff auf das Fritz.nas an?
                                      Danke und Gruß
                                      Hartmut
                                      PV-Anlage:
                                      Sonstige Geräte:
                                      • hruH Offline
                                        hruH Offline
                                        hru
                                        ok habe das Thema mit der Verbindung zum Fritz.nas hinbekommen.
                                        Jetzt klemmt es noch woanders:
                                        22:00:57.670INFOguiBackup gestartet ...
                                        22:01:07.936DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //fritz.nas/FRITZ.NAS/TOSHIBA_EXT/BACKUP/iobroker/ /opt/iobroker/backups"
                                        22:01:07.998DEBUGmountmount successfully completed
                                        22:01:08.048DEBUGmountdone
                                        22:01:11.818DEBUGiobrokerhost.pinas 1169 objects saved
                                        22:01:11.928DEBUGiobrokerhost.pinas 826 states saved
                                        22:01:11.938DEBUGiobrokerhost.pinas Validating backup ...
                                        host.pinas "config.json" is valid
                                        22:01:11.950DEBUGiobrokerhost.pinas "objects.jsonl" exists
                                        host.pinas "states.jsonl" exists
                                        22:01:12.228DEBUGiobrokerhost.pinas The backup is valid!
                                        22:01:15.412DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                                        22:01:16.437DEBUGiobrokerdone
                                        22:01:16.586DEBUGinfluxDBInfluxDB-Backup started ...
                                        22:01:16.591DEBUGinfluxDBStart InfluxDB Backup ...
                                        22:01:16.652DEBUGinfluxDBInfluxDB Backup tmp directory created
                                        22:01:17.062DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_12_30-22_01_11_backupiobroker"
                                        22:01:17.070DEBUGinfluxDBInfluxDB-Backup for is finish
                                        22:01:17.105DEBUGinfluxDBdone
                                        22:01:17.113DEBUGinfluxDBInfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_12_30-22_01_11_backupiobroker" successfully deleted
                                        22:01:18.790DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                                        22:01:18.849DEBUGjavascriptsfound Script: AC-ELWA-2
                                        22:01:19.030DEBUGjavascriptsfound Script: Stromzaehler_Tageswerte
                                        22:01:19.199DEBUGjavascriptsfound Script: Test_HRU
                                        22:01:19.350DEBUGjavascriptsfound Script: AlarmShellyPlusSmokeHZK
                                        22:01:19.460DEBUGjavascriptsfound Script: AlarmShellyPlusSmokeHS
                                        22:01:19.613DEBUGjavascriptsfound Script: AlarmShellyPlusSmokeG
                                        22:01:19.814DEBUGjavascriptsfound Script: AlarmShellyPlusSmokeFK
                                        22:01:19.919DEBUGjavascriptsfound Script: AlarmShellyPlusSmokeFEG
                                        22:01:20.103DEBUGjavascriptsfound Script: AlarmShellyPlusSmokeFOG
                                        22:01:20.222DEBUGjavascriptsfound Script: ShellyPlusSmoke_Batteriestand
                                        22:01:20.374DEBUGjavascriptsfound Script: AlarmShellyGasHZK
                                        22:01:20.566DEBUGjavascriptsfound Script: UptimeShellyGasHZK
                                        22:01:20.678DEBUGjavascriptsfound Script: Weihnachtsbeleuchtung_schalten
                                        22:01:20.830DEBUGjavascriptsfound Script: AlarmShellyFloodKuecheEG
                                        22:01:21.147DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                                        22:01:21.164ERRORjavascriptsError: Unknown system error -116: Unknown system error -116, open '/opt/iobroker/backups/tmpScripts/script.json'
                                        22:01:21.168DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                                        22:01:21.173DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                                        Irgendwelche Ideen?
                                        Danke und Gruß
                                        Hartmut
                                        PV-Anlage:
                                        Sonstige Geräte:
                                        • hruH hru
                                          Irgendwelche Ideen?
                                          Danke und Gruß
                                          Hartmut
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          @hru option noserverino Haken setzen
                                          bin ich mir nicht sicher ob das so stimmt
