  4. Neuer Adapter für Roborock-Staubsauger
1.1k Beiträge 155 Kommentatoren 499.0k Aufrufe 137 Beobachtet
  • B breaksrmine
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Hardware Vendor : Synology Inc.
    Kernel          : x86_64
    Userland        : 64 bit
    Docker          : v11.0.0
    Virtualization  : docker
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     12:35:12 up 4 days, 15:49,  0 user,  load average: 1.03, 0.68, 0.52
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
    Wed Dec 17 11:35:12 UTC 2025
    Wed Dec 17 12:35:12 CET 2025
    CET +0100
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/opt/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    System has not been booted with systemd as init system (PID 1). Can't operate.
    Failed to connect to bus: Host is down
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:             33G         17G        1.3G         10G         29G         16G
    Swap:           2.1G        382M        1.8G
    Total:           35G         17G        3.1G
    Active iob-Instances:   12
            32072 M total memory
            16656 M used memory
             2328 M active memory
            16246 M inactive memory
             1257 M free memory
              596 M buffer memory
            27204 M swap cache
             2047 M total swap
              364 M used swap
             1683 M free swap
    top - 12:35:13 up 4 days, 15:49,  0 user,  load average: 1.03, 0.68, 0.52
    Tasks:  20 total,   1 running,  19 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  32072.3 total,   1256.0 free,  16658.6 used,  27801.6 buff/cache
    MiB Swap:   2047.9 total,   1683.6 free,    364.3 used.  15413.7 avail Mem
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem             Type   Size  Used Avail Use% Mounted on
    /dev/mapper/cachedev_0 btrfs  885G  179G  706G  21% /
    tmpfs                  tmpfs   64M     0   64M   0% /dev
    tmpfs                  tmpfs   16G     0   16G   0% /sys/fs/cgroup
    shm                    tmpfs   64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev_0 btrfs  885G  179G  706G  21% /opt/iobroker
    /dev/mapper/cachedev_0 btrfs  885G  179G  706G  21% /etc/hosts
    tmpfs                  tmpfs   16G     0   16G   0% /proc/acpi
    tmpfs                  tmpfs   16G     0   16G   0% /proc/scsi
    tmpfs                  tmpfs   16G     0   16G   0% /sys/firmware
    [Fri Dec 12 20:46:47 2025] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Fri Dec 12 20:46:47 2025] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Dec 12 20:46:47 2025] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: prjquota,rootprjquota,barrier=1
    [Fri Dec 12 20:46:47 2025] EXT4-fs (sata4p2): couldn't mount as ext3 due to feature incompatibilities
    [Fri Dec 12 20:46:47 2025] EXT4-fs (sata4p2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Dec 12 20:47:30 2025] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Fri Dec 12 20:47:30 2025] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Dec 12 20:47:31 2025] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Fri Dec 12 20:47:31 2025] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: prjquota,rootprjquota,barrier=1
    [Fri Dec 12 20:47:47 2025] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl
    [Fri Dec 12 20:48:18 2025] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Dec 12 20:48:19 2025] ext4: synoboot1 mounted, process=syno_bios_log_c
    [Fri Dec 12 20:49:05 2025] EXT4-fs (iscsi2): mounted filesystem with ordered data mode. Opts: (null)
    Show mounted filesystems:
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/82a6d3a2c890980107852312625dbf5eaef62247d8bdd021eebba4782f925861]       btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=1509,subvol=/@syno/@docker/btrfs/subvolumes/82a6d3a2c890980107852312625dbf5eaef62247d8bdd021eebba4782f925861
    |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker]        btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=330,subvol=/@syno/docker
    |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/b4082afc1ac9497e5c970e6bd491e53c93ac49c1791a99f3e8d5925170e5ccb8/resolv.conf] btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
    |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/b4082afc1ac9497e5c970e6bd491e53c93ac49c1791a99f3e8d5925170e5ccb8/hostname]    btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
    `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/b4082afc1ac9497e5c970e6bd491e53c93ac49c1791a99f3e8d5925170e5ccb8/hosts]       btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
    /var:
    16M     /var/
    14M     /var/lib/dpkg
    14M     /var/lib
    13M     /var/lib/dpkg/info
    1.9M    /var/cache
    /opt/iobroker/backups:
    316M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    243M    /opt/iobroker/iobroker-data/
    129M    /opt/iobroker/iobroker-data/backup-objects
    93M     /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/backup-objects/2025-12-15_12-49_states.jsonl.gz
    15M     /opt/iobroker/iobroker-data/backup-objects/2025-12-15_10-49_states.jsonl.gz
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-C_W7K-9p.js
    4.7M    /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 100
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    d7b9f08fe3af        d7b9f08fe3af (version: 7.0.7, hostname: d7b9f08fe3af  , alive, uptime: 43038)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     1
    +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#521621b88729012446785ec3c8248501a560eb53)
    Adapter State
    + system.adapter.admin.0                  : admin                 : d7b9f08fe3af                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : d7b9f08fe3af                             -  enabled, port: 8443, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : d7b9f08fe3af                             -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : d7b9f08fe3af                             -  enabled
      system.adapter.dwd.0                    : dwd                   : d7b9f08fe3af                             -  enabled
    + system.adapter.javascript.0             : javascript            : d7b9f08fe3af                             -  enabled
      system.adapter.linktap.0                : linktap               : d7b9f08fe3af                             - disabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : d7b9f08fe3af                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : d7b9f08fe3af                             -  enabled, port: 11111, bind: 0.0.0.0
    + system.adapter.openweathermap.0         : openweathermap        : d7b9f08fe3af                             -  enabled
    + system.adapter.philips-tv.0             : philips-tv            : d7b9f08fe3af                             -  enabled
    + system.adapter.plenticore.0             : plenticore            : d7b9f08fe3af                             -  enabled, port: 80
      system.adapter.roborock.0               : roborock              : d7b9f08fe3af                             -  enabled
    + system.adapter.simple-api.0             : simple-api            : d7b9f08fe3af                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.weatherunderground.0     : weatherunderground    : d7b9f08fe3af                             -  enabled
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    │ 2       │ '__'     │ ''                                                      │ false        │
    Active repo(s): stable
    Upgrade policy: minor
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linktap"      : 1.0.3    , installed 1.0.3
    Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
    Adapter    "plenticore"   : 2.2.0    , installed 2.3.1
    Adapter    "roborock"     : 0.6.18   , installed 0.6.19
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Objects and States
    Objects:        3621
    States:         3266
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    #957
    @breaksrmine
    Mit Docker kenn ich mich zwar nicht aus, da gibt es einige 'komische' Meldungen.
    Der web-Adapter fehlt aber in der Tat.
    Installier den halt nach. Geht wie bei jedem anderen Adapter auch.
      @breaksrmine
      breaksrmine
      #958
      @Thomas-Braun sagte in Neuer Adapter für Roborock-Staubsauger:
      @breaksrmine
      das problem das wollte ich schon machen aber über suche im reposi gibt es keinen web adapter
      • B breaksrmine
        @breaksrmine
        #959
        @breaksrmine
        iob add web --debug
          @breaksrmine
          iob add web --debug
          breaksrmine
          #960
          @breaksrmine
          iob add web --debug
          Thomas was soll ich sagen. DER GEHT !!! ich werd verrückt der geht !!! danke !!
          B CroxxiC 2 Antworten Letzte Antwort
          • B breaksrmine
            @breaksrmine
            iob add web --debug
            breaksrmine
            #961
            @breaksrmine
            iob add web --debug
            S7 und QV35a sind wieder steuerbar :-)
            • N Offline
              N Offline
              Nachtfuchs
              schrieb am zuletzt editiert von Nachtfuchs
              #962
              Hallo Gemeinde,
              ich hatte den Roborock Qrevo Slim erfolgreich im Einsatz mit dem Adapter. Das Gerät musste zurück zur Inspektion, hat da ein neues Mainboard bekommen (Navigation war fehlerhaft). Jetzt wollte ich den "neuen" alten wieder in den Adapter bringen, aber der Adapterstatus bleibt bei "gelb".
              Die login-Daten sind mehrfach geprüft, es sind die richtigen; in der App kann ich den Roboter problemlos steuern.
              Den Adapter habe ich auch schon de- und neuinstalliert.
              Das Protokoll wirft für mich unklare Meldungen aus; hat jemand eine Idee, wie ich ihn wieder "ans Netz" kriege?
              Dank euch
              • N Nachtfuchs
                Hallo Gemeinde,
                Dank euch
                #963
                @Nachtfuchs
                Losgelöst vom Problem:
                nodeJS@22 ist angesagt. Updaten.
                • R Offline
                  RISSN
                  #964
                  bei mir geht auch nichts mehr, aktuell bin ich, aber es geht dennoch nicht
                  • E Offline
                    Elitepain77
                    #965
                    Bei mir funktioniert leider auch nix... hab einen QRevo S5 Edge. Selbe Fehlermeldungen wie bei Nachtfuchs
                    • Ro75R Offline
                      Ro75R Offline
                      Ro75
                      #966
                      Seit ihr @rissn @elitepain77 auf NodeJS 22.x? und Adapter 0.6.19?
                      Ro75.
                      • R Offline
                        RISSN
                        #967
                        bei mir ist das so
                        • N Offline
                          N Offline
                          Nachtfuchs
                          #968
                          Ich habe eben mal hochgescrollt - manchmal hilft das ;-)
                          @copystring hat eine URL für die Katze hoch geladen; wirft bei mir aber Fehler aus .. https://forum.iobroker.net/post/1314593
                          nodejs Version ist 22.15.0
                          Thomas BraunT wolfi913W 2 Antworten Letzte Antwort
                          • N Nachtfuchs
                            #969
                            @Nachtfuchs
                            Bitte keine Bildchen von Text.
                            Haste die Meldung auch gelesen?
                            Du hast einen falschen Link angegeben.
                            • N Nachtfuchs
                              wolfi913W Offline
                              wolfi913W Offline
                              wolfi913
                              #970
                              @Nachtfuchs
                              Du hast es mit der alten dev versucht. Die ist in der Zwischenzeit in die main mit eingeflossen.
                              Wenn Du also über die Katze (immer auf eigene Gefahr) installieren willst solltest Du die https://github.com/copystring/ioBroker.roborock verwenden.
                              Bei mir läuft das jetzt mit einem Qrevo Slim wieder, sowohl im Test- als auch im Produktivsystem.
                              Musste bei mir auch den vorhandenen Objektbaum für roborock vorher einmal komplett löschen. Dann die neue Version starten und wie im Log beschrieben den per Mail zugesandten 2FA-Code in den entsprechenden Datenpunkt (unbestätigt) eintragen. Dann startet der Adapter automatisch einen neuen Versuch und hat sich wieder komplett verbunden. Nur ein paar Datenpunkte liegen jetzt etwas anders gegenüber der früheren Version. Der überwiegende Objektbaum ist aber unverändert.
                              • N Offline
                                N Offline
                                Nidoello
                                #971
                                In welchen Datenpunkt muss der Verfizierungscode eingetragen werden?
                                Bei mir wird der Adapter nicht grün.
                                wolfi913W 1 Antwort Letzte Antwort
                                • N Nidoello
                                  wolfi913W Offline
                                  wolfi913W Offline
                                  wolfi913
                                  #972
                                  @Nidoello
                                  Steht in der Anleitung
                                  https://github.com/copystring/ioBroker.roborock#two-factor-authentication-2fa
                                  und außerdem im Log
                                  • N Offline
                                    N Offline
                                    Nidoello
                                    #973
                                    Es gibt in der Distanz keinen Datenpunkt roborock.0.loginCode.
                                    E 1 Antwort Letzte Antwort
                                    • N Offline
                                      N Offline
                                      Nachtfuchs
                                      #974
                                      Klappt wunderbar - DANKE euch!
                                      @thomas-braun ich hatte den link 1:1 aus dem posting kopiert
                                      • N Nidoello
                                        Elsa
                                        schrieb am zuletzt editiert von Elsa
                                        #975
                                        @Nidoello so muss das aussehen unter Objekten, falls nicht hast Du vieleicht nicht die richtige Adapter version installiert.
                                        Eingabe Verifizierungscode in der Zeile logincode 2FA in Spalte Wert
                                        N 1 Antwort Letzte Antwort
                                        • E Elsa
                                          N Offline
                                          N Offline
                                          Nidoello
                                          schrieb am zuletzt editiert von Nidoello
                                          #976
                                          Sieht bei mir so aus
