  4. Neuer Adapter für Roborock-Staubsauger
    1.5k
1.1k Beiträge 155 Kommentatoren 515.7k Aufrufe 137 Beobachtet
  • lebeARTL
    lebeARTL
    lebeART
    #946
    Dann erhalte ich 2025-12-17 00:25:12.920 - info: host.raspberrypi5 "system.adapter.roborock.0" enabled
    2025-12-17 00:25:13.284 - info: host.raspberrypi5 instance system.adapter.roborock.0 in version "0.6.18" started with pid 5651
    2025-12-17 00:25:15.176 - info: roborock.0 (5651) starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.19.6, js-controller: 7.0.7
    2025-12-17 00:25:15.186 - info: roborock.0 (5651) Starting adapter. This might take a few minutes depending on your setup. Please wait.
    2025-12-17 00:25:15.602 - error: roborock.0 (5651) Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects.
    2025-12-17 00:25:15.611 - error: roborock.0 (5651) Error retrieving or setting clientID: Error: Login returned empty userdata.
    at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11)
    at processTicksAndRejections (node:internal/process/task_queues:95:5)
    at Roborock.initializeRoborockApi (/opt/iobroker/node_modules/iobroker.roborock/main.js:103:21)
    at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:65:34)
    2025-12-17 00:25:15.788 - info: tuya.0 (2997) bf9f48824c14c6677ec5va: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.46:6668
    2025-12-17 00:25:16.036 - error: roborock.0 (5651) Failed to get home details: Error: loginApi is not initialized.
    at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.roborock/main.js:144:25)
    at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:67:14)
    2025-12-17 00:25:56.764 - info: admin.0 (2857) Adapter rating updated
    • lebeARTL lebeART
      Thomas BraunT
      Thomas BraunT
      #947
      @lebeART sagte in Neuer Adapter für Roborock-Staubsauger:
      node: v20.19.6
      Bring es auf nodejs v22...
      iob nodejs-update
      Fertig.
      • copystringC
        copystringC
        copystring
        #948
        Es gibt aktuell keinen funktionierenden Release. Wer mag, kann https://github.com/copystring/ioBroker.roborock über die GitHub Katze in ioBroker installieren und testen. Bugs aber nicht hier posten, sondern als Issue auf GitHub. Danke!
        Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
        https://paypal.me/copystring
        ste_gleiS 1 Antwort Letzte Antwort
        • B
          B
          breaksrmine
          #949
          Bei mir kommt über die katze schon beim start der Fehler
          startInstance system.adapter.roborock.0 Adapter dependency not fulfilled on "d7b9f08fe3af": required adapter "web" not found!
          roborock 0.6.19
          node v22
          • copystringC copystring
            ste_gleiS
            ste_gleiS
            ste_glei
            #950
            @copystring
            gerade das Release über GitHub installiert und funktioniert mit S8 Pro Ultra und Saros 10.
            Ich musste aber den Adapter komplett löschen und neu installieren.
            Danke für die Bemühungen!
            • R
              R
              RISSN
              #951
              bei mir geht es nicht, muss ich mir hier irgendwie einen neuen Token besorgen?
              roborock.0
              2025-12-17 09:54:32.386	error	MQTT connection error: Connection refused: Not authorized. Broker: ssl://mqtt-eu.roborock.com:8883
              roborock.0
              2025-12-17 09:54:32.299	error	No homeId found
              roborock.0
              2025-12-17 09:54:32.245	error	failed to get getHomeDetail: invalid token
              • B breaksrmine
                roborock 0.6.19
                node v22
                Thomas BraunT
                Thomas BraunT
                #952
                @breaksrmine sagte in Neuer Adapter für Roborock-Staubsauger:
                Ist der web-Adapter installiert und läuft?
                  B
                  B
                  breaksrmine
                  #953
                  @Thomas-Braun sagte in Neuer Adapter für Roborock-Staubsauger:
                  woher bekomme ich diesen ? bzw. wie muss dieser installiert werden ?
                  • B breaksrmine
                    B
                    B
                    breaksrmine
                    #954
                    sry bin kein profi
                    • B breaksrmine
                      sry bin kein profi
                      Thomas BraunT
                      Thomas BraunT
                      #955
                      @breaksrmine
                      Gib mal die Ausgabe von
                      iob diag
                      zum Besten. Da kann man das (neben anderen Dingen) sehen.
                      • B
                        B
                        breaksrmine
                        #956
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                        Hardware Vendor : Synology Inc.
                        Kernel          : x86_64
                        Userland        : 64 bit
                        Docker          : v11.0.0
                        Virtualization  : docker
                        Kernel          : x86_64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         12:35:12 up 4 days, 15:49,  0 user,  load average: 1.03, 0.68, 0.52
                        CPU threads: 4
                        *** LIFE CYCLE STATUS ***
                        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                        *** TIME AND TIMEZONES ***
                        Wed Dec 17 11:35:12 UTC 2025
                        Wed Dec 17 12:35:12 CET 2025
                        CET +0100
                        Etc/UTC
                        *** Users and Groups ***
                        User that called 'iob diag':
                        root
                        HOME=/root
                        GROUPS=root
                        iobroker
                        HOME=/opt/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev
                        *** DISPLAY-SERVER SETUP ***
                        Display-Server:         false
                        System has not been booted with systemd as init system (PID 1). Can't operate.
                        Failed to connect to bus: Host is down
                        Display-Manager:
                        Desktop:
                        Session:
                        *** MEMORY ***
                        Mem:             33G         17G        1.3G         10G         29G         16G
                        Swap:           2.1G        382M        1.8G
                        Total:           35G         17G        3.1G
                        Active iob-Instances:   12
                                32072 M total memory
                                16656 M used memory
                                 2328 M active memory
                                16246 M inactive memory
                                 1257 M free memory
                                  596 M buffer memory
                                27204 M swap cache
                                 2047 M total swap
                                  364 M used swap
                                 1683 M free swap
                        top - 12:35:13 up 4 days, 15:49,  0 user,  load average: 1.03, 0.68, 0.52
                        Tasks:  20 total,   1 running,  19 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :  32072.3 total,   1256.0 free,  16658.6 used,  27801.6 buff/cache
                        MiB Swap:   2047.9 total,   1683.6 free,    364.3 used.  15413.7 avail Mem
                        *** DMESG CRITICAL ERRORS ***
                        No critical errors detected
                        *** FILESYSTEM ***
                        Filesystem             Type   Size  Used Avail Use% Mounted on
                        /dev/mapper/cachedev_0 btrfs  885G  179G  706G  21% /
                        tmpfs                  tmpfs   64M     0   64M   0% /dev
                        tmpfs                  tmpfs   16G     0   16G   0% /sys/fs/cgroup
                        shm                    tmpfs   64M     0   64M   0% /dev/shm
                        /dev/mapper/cachedev_0 btrfs  885G  179G  706G  21% /opt/iobroker
                        /dev/mapper/cachedev_0 btrfs  885G  179G  706G  21% /etc/hosts
                        tmpfs                  tmpfs   16G     0   16G   0% /proc/acpi
                        tmpfs                  tmpfs   16G     0   16G   0% /proc/scsi
                        tmpfs                  tmpfs   16G     0   16G   0% /sys/firmware
                        [Fri Dec 12 20:46:47 2025] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
                        [Fri Dec 12 20:46:47 2025] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
                        [Fri Dec 12 20:46:47 2025] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: prjquota,rootprjquota,barrier=1
                        [Fri Dec 12 20:46:47 2025] EXT4-fs (sata4p2): couldn't mount as ext3 due to feature incompatibilities
                        [Fri Dec 12 20:46:47 2025] EXT4-fs (sata4p2): mounted filesystem with ordered data mode. Opts: (null)
                        [Fri Dec 12 20:47:30 2025] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
                        [Fri Dec 12 20:47:30 2025] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
                        [Fri Dec 12 20:47:31 2025] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
                        [Fri Dec 12 20:47:31 2025] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: prjquota,rootprjquota,barrier=1
                        [Fri Dec 12 20:47:47 2025] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl
                        [Fri Dec 12 20:48:18 2025] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
                        [Fri Dec 12 20:48:19 2025] ext4: synoboot1 mounted, process=syno_bios_log_c
                        [Fri Dec 12 20:49:05 2025] EXT4-fs (iscsi2): mounted filesystem with ordered data mode. Opts: (null)
                        Show mounted filesystems:
                        TARGET             SOURCE        FSTYPE OPTIONS
                        /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/82a6d3a2c890980107852312625dbf5eaef62247d8bdd021eebba4782f925861]       btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=1509,subvol=/@syno/@docker/btrfs/subvolumes/82a6d3a2c890980107852312625dbf5eaef62247d8bdd021eebba4782f925861
                        |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker]        btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=330,subvol=/@syno/docker
                        |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/b4082afc1ac9497e5c970e6bd491e53c93ac49c1791a99f3e8d5925170e5ccb8/resolv.conf] btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
                        |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/b4082afc1ac9497e5c970e6bd491e53c93ac49c1791a99f3e8d5925170e5ccb8/hostname]    btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
                        `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/b4082afc1ac9497e5c970e6bd491e53c93ac49c1791a99f3e8d5925170e5ccb8/hosts]       btrfs  rw,nodev,noatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
                        /var:
                        16M     /var/
                        14M     /var/lib/dpkg
                        14M     /var/lib
                        13M     /var/lib/dpkg/info
                        1.9M    /var/cache
                        /opt/iobroker/backups:
                        316M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        243M    /opt/iobroker/iobroker-data/
                        129M    /opt/iobroker/iobroker-data/backup-objects
                        93M     /opt/iobroker/iobroker-data/files
                        47M     /opt/iobroker/iobroker-data/files/admin.admin
                        46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                        16M     /opt/iobroker/iobroker-data/objects.jsonl
                        15M     /opt/iobroker/iobroker-data/backup-objects/2025-12-15_12-49_states.jsonl.gz
                        15M     /opt/iobroker/iobroker-data/backup-objects/2025-12-15_10-49_states.jsonl.gz
                        8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-C_W7K-9p.js
                        4.7M    /opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        No Devices found 'by-id'
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v22.21.0
                        /usr/bin/node           v22.21.0
                        /usr/bin/npm            10.9.4
                        /usr/bin/npx            10.9.4
                        /usr/bin/corepack       0.34.0
                        nodejs:
                          Installed: 22.21.0-1nodesource1
                          Candidate: 22.21.0-1nodesource1
                          Version table:
                         *** 22.21.0-1nodesource1 100
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        d7b9f08fe3af        d7b9f08fe3af (version: 7.0.7, hostname: d7b9f08fe3af  , alive, uptime: 43038)
                        Core adapters versions
                        admin:          7.7.19
                        javascript:     9.0.11
                        nodejs modules from github:     1
                        +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#521621b88729012446785ec3c8248501a560eb53)
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : d7b9f08fe3af                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.admin.1                  : admin                 : d7b9f08fe3af                             -  enabled, port: 8443, bind: 0.0.0.0 (SSL), run as: admin
                        + system.adapter.backitup.0               : backitup              : d7b9f08fe3af                             -  enabled
                        + system.adapter.daikin-cloud.0           : daikin-cloud          : d7b9f08fe3af                             -  enabled
                          system.adapter.dwd.0                    : dwd                   : d7b9f08fe3af                             -  enabled
                        + system.adapter.javascript.0             : javascript            : d7b9f08fe3af                             -  enabled
                          system.adapter.linktap.0                : linktap               : d7b9f08fe3af                             - disabled
                        + system.adapter.mielecloudservice.0      : mielecloudservice     : d7b9f08fe3af                             -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : d7b9f08fe3af                             -  enabled, port: 11111, bind: 0.0.0.0
                        + system.adapter.openweathermap.0         : openweathermap        : d7b9f08fe3af                             -  enabled
                        + system.adapter.philips-tv.0             : philips-tv            : d7b9f08fe3af                             -  enabled
                        + system.adapter.plenticore.0             : plenticore            : d7b9f08fe3af                             -  enabled, port: 80
                          system.adapter.roborock.0               : roborock              : d7b9f08fe3af                             -  enabled
                        + system.adapter.simple-api.0             : simple-api            : d7b9f08fe3af                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          system.adapter.weatherunderground.0     : weatherunderground    : d7b9f08fe3af                             -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                        │ 2       │ '__'     │ ''                                                      │ false        │
                        Active repo(s): stable
                        Upgrade policy: minor
                        Installed ioBroker-Adapters
                        Used repository: stable
                        Adapter    "admin"        : 7.7.19   , installed 7.7.19
                        Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                        Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
                        Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                        Controller "js-controller": 7.0.7    , installed 7.0.7
                        Adapter    "linktap"      : 1.0.3    , installed 1.0.3
                        Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
                        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                        Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
                        Adapter    "plenticore"   : 2.2.0    , installed 2.3.1
                        Adapter    "roborock"     : 0.6.18   , installed 0.6.19
                        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                        Objects and States
                        Objects:        3621
                        States:         3266
                        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        • B breaksrmine
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                          Kernel          : x86_64
                          Userland        : 64 bit
                          Docker          : v11.0.0
                          Kernel          : x86_64
                          Userland        : 64 bit
                          CPU threads: 4
                          CET +0100
                          Etc/UTC
                          root
                          HOME=/root
                          GROUPS=root
                          iobroker
                          HOME=/opt/iobroker
                          Display-Manager:
                          Desktop:
                          Session:
                          *** MEMORY ***
                          Total:           35G         17G        3.1G
                                  16656 M used memory
                                   1257 M free memory
                                    596 M buffer memory
                                  27204 M swap cache
                                   2047 M total swap
                                    364 M used swap
                                   1683 M free swap
                          *** FILESYSTEM ***
                          /var:
                          16M     /var/
                          14M     /var/lib/dpkg
                          14M     /var/lib
                          1.9M    /var/cache
                          USB-Devices by-id:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.9.4
                          /usr/bin/npx            10.9.4
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.7.19
                          javascript:     9.0.11
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        3621
                          States:         3266
                          Pending Updates: 0
                          Thomas BraunT
                          Thomas BraunT
                          #957
                          @breaksrmine
                          Mit Docker kenn ich mich zwar nicht aus, da gibt es einige 'komische' Meldungen.
                          Der web-Adapter fehlt aber in der Tat.
                          Installier den halt nach. Geht wie bei jedem anderen Adapter auch.
                            @breaksrmine
                            B
                            B
                            breaksrmine
                            #958
                            @breaksrmine
                            das problem das wollte ich schon machen aber über suche im reposi gibt es keinen web adapter
                            • B breaksrmine
                              @breaksrmine
                              Thomas BraunT
                              Thomas BraunT
                              #959
                              @breaksrmine
                              iob add web --debug
                                @breaksrmine
                                iob add web --debug
                                B
                                B
                                breaksrmine
                                #960
                                @breaksrmine
                                iob add web --debug
                                Thomas was soll ich sagen. DER GEHT !!! ich werd verrückt der geht !!! danke !!
                                B CroxxiC 2 Antworten Letzte Antwort
                                • B breaksrmine
                                  @breaksrmine
                                  iob add web --debug
                                  B
                                  B
                                  breaksrmine
                                  #961
                                  @breaksrmine
                                  iob add web --debug
                                  S7 und QV35a sind wieder steuerbar :-)
                                  • N
                                    N
                                    Nachtfuchs
                                    schrieb am zuletzt editiert von Nachtfuchs
                                    #962
                                    Hallo Gemeinde,
                                    ich hatte den Roborock Qrevo Slim erfolgreich im Einsatz mit dem Adapter. Das Gerät musste zurück zur Inspektion, hat da ein neues Mainboard bekommen (Navigation war fehlerhaft). Jetzt wollte ich den "neuen" alten wieder in den Adapter bringen, aber der Adapterstatus bleibt bei "gelb".
                                    Die login-Daten sind mehrfach geprüft, es sind die richtigen; in der App kann ich den Roboter problemlos steuern.
                                    Den Adapter habe ich auch schon de- und neuinstalliert.
                                    Das Protokoll wirft für mich unklare Meldungen aus; hat jemand eine Idee, wie ich ihn wieder "ans Netz" kriege?
                                    Dank euch
                                    • N Nachtfuchs
                                      Hallo Gemeinde,
                                      Dank euch
                                      Thomas BraunT
                                      Thomas BraunT
                                      #963
                                      @Nachtfuchs
                                      Losgelöst vom Problem:
                                      nodeJS@22 ist angesagt. Updaten.
                                      • R
                                        R
                                        RISSN
                                        #964
                                        bei mir geht auch nichts mehr, aktuell bin ich, aber es geht dennoch nicht
                                        • E
                                          E
                                          Elitepain77
                                          #965
                                          Bei mir funktioniert leider auch nix... hab einen QRevo S5 Edge. Selbe Fehlermeldungen wie bei Nachtfuchs
