  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
2.5k Beiträge 164 Kommentatoren 1.4m Aufrufe 151 Beobachtet
  • arteckA arteck
    @earl80 zeigmal
    8840041a-3ada-44df-8a7f-f831ca2a1e44-1761893131548-5cd251e4-0b19-4478-b607-bf437c1027b4-grafik.png
    E
    E
    earl80
    schrieb am zuletzt editiert von earl80
    #2295
    @arteck Ich habe es mal von false auf true und zurück, daher ist "force update" rot...
    host.raspberrypi
    2025-11-04 14:05:25.931	error	instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    bluelink.0
    2025-11-04 14:05:25.275	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    bluelink.0
    2025-11-04 14:05:25.273	info	terminating
    bluelink.0
    2025-11-04 14:05:25.272	info	Adapter bluelink cleaned up everything...
    bluelink.0
    2025-11-04 14:05:25.268	error	Cannot read properties of null (reading 'val')
    bluelink.0
    2025-11-04 14:05:25.268	error	TypeError: Cannot read properties of null (reading 'val') at Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:353:63) at async _e.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:297:21)
    bluelink.0
    2025-11-04 14:05:25.267	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
    bluelink.0
    2025-11-04 14:05:25.267	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    bluelink.0
    2025-11-04 14:05:25.262	debug	Read new status from api for KMXXXXXXXXXXXX
    • E earl80
      host.raspberrypi
      bluelink.0
      bluelink.0
      bluelink.0
      bluelink.0
      bluelink.0
      bluelink.0
      bluelink.0
      bluelink.0
      arteckA
      arteckA
      arteck
      #2296
      @earl80 ich finde den Fehler aber kein plan warum der bei dir kommt...
      ich brauche die Logindaten..muss ich hier nachstellen
      E 1 Antwort Letzte Antwort
      • arteckA arteck
        E
        E
        earl80
        #2297
        @arteck Was brauchst du per PM? Token, oder Mail und PW?
        • E earl80
          arteckA
          arteckA
          arteck
          #2298
          @earl80 genau das gleiche was du im adapter eingibst,
          email token pin
          • arteckA arteck
            email token pin
            K
            K
            klausiob
            #2299
            @arteck
            Hallo, ich hänge mich mal hier rein. Habe einen IONIQ5. Bis 27.10.25 ging bei mir der Blulink-Adapter. Obwohl ich die Routine durchgeführt habe kommt immer noch:
            2025-11-07 14:54:58.339 - error: bluelink.0 (22388) HTTPError: Response code 400 (Bad Request)
            2025-11-07 14:54:58.340 - error: bluelink.0 (22388) Server is not available or login credentials are wrong
            2025-11-07 14:54:58.340 - error: bluelink.0 (22388) next auto login attempt in 1 hour or restart adapter manual
            Ich konnte mich bei Hyundai im Chrome anmelden und PowerShell hat mir auch einen Refresh-Token und Access-Token ausgespuckt. Habe von GIT den Adapter installiert und mich mit Mail, PW und Pin im Adapter eingetragen. Was ist mit dem Refresh-Token und Access Token noch zu machen? Oder muß ich jetzt den Chrome für den iobroker Admin verwenden?
            Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
            node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
            Meister MopperM F 2 Antworten Letzte Antwort
            • K klausiob
              @arteck
              Meister MopperM
              Meister MopperM
              Meister Mopper
              #2300
              @klausiob
              Der refresh token ist das PW.
              Proxmox und HA ...
              • K klausiob
                @arteck
                F
                F
                fichte_112
                schrieb am zuletzt editiert von fichte_112
                #2301
                @klausiob hast du zu erst den blulinky Ordner oder den kompletten Adapter gelöscht?
                  @klausiob
                  K
                  K
                  klausiob
                  #2302
                  @meister-mopper
                  Heureka. Jetzt funzt es. Hatte das PW immer von meinem Hyundai-Account genommen.😲
                  • F fichte_112
                    K
                    K
                    klausiob
                    #2303
                    @fichte_112
                    blulinky in der Console gelöscht. Wollte die Daten behalten.
                    • F fichte_112
                      @plchome-0 es muß ein Refresh Token erstellt werden. Dieser Refresh Token ist das Passwort für den Bluelink Adapter.
                      Hier sind weitere Infos
                      F
                      F
                      Fibricus
                      #2304
                      @fichte_112 Hallo Fichte_112!
                      Irgendwie begreife ich gerade gar nix.
                      Mein IOB läuft auf Linux (habe ich so fertig eingerichtet gebraucht gekauft).
                      Den IOB bediene ich über einen Windows-PC und Firefox.
                      Nun gibt es eine gute Anleitung für Windows um so einen Token zu generieren.
                      Kann ich diese benutzten, auch wenn mein IOB auf Linux läuft?
                      Tut mir leid, wenn ich so doof frage, aber ich möchte mir nix abschießen...
                      Tobias
                      F 1 Antwort Letzte Antwort
                      • F Fibricus
                        Tobias
                        F
                        F
                        fichte_112
                        #2305
                        @fibricus du kannst den Token mit Windows erstellen. Nur den bluelinky Ordner musst du in der Konsole des Linux deiner Iobroker Installation löschen oder du löschst den kompletten Bluelink Adapter. Die Datenpunkte werden wieder neu erstellt, wenn du die Befehle der Anleitung nacheinander abarbeitest.
                        • K
                          K
                          klausiob
                          #2306
                          @fichte_112 ich hatte den bluelinky mit REM in der Console gelöscht, sonst wenn du den Adapter löscht, sind die Datenpunkte weg und die Daten.
                          • K klausiob
                            F
                            F
                            fichte_112
                            #2307
                            @klausiob ja, die Datenpunkte werden aber bei der neuen Installation wieder erstellt. Historische Daten werden doch sowieso durch aktuelle ersetzt. Du musst jetzt beobachten, dass deine vorhandenen Datenpunkte auch aktualisiert werden. Die Ordnerstruktur hat sich geändert.
                            • F fichte_112
                              Anleitung zur Erstellung eines Tokens für Hyundai oder KIA mit Windows
                              Python Releases for Windows installieren.
                              Google Chrome installieren
                              In der Konsole folgenden Befehl ausführen. (oder den Adapter Bluelink löschen)
                              rm -r /opt/iobroker/node_modules/bluelinky/
                              Im Iobroker den Reiter Adapter anklicken. Dan den Expertenmodus aktivieren und die Katze anklicken.
                              Den Reiter Benutzerdefiniert auswählen und folgendes eintragen und installieren.
                              https://github.com/Newan/ioBroker.bluelink.git
                              Jetzt Windows PowerShell mit administrativen Rechten starten.
                              Jetzt folgende Befehle nacheinander ausführen.
                              Set-ExecutionPolicy Unrestricted
                              A eingeben und mit Enter bestätigen.
                              mkdir $env:TEMP\token 2>$null; cd $env:TEMP\token
                              $code = @"
                              import argparse
                              import logging
                              import os
                              import re
                              import sys
                              from dataclasses import dataclass
                              from typing import Final
                              from urllib.parse import parse_qs, urlparse
                              import requests
                              from selenium import webdriver
                              from selenium.common.exceptions import TimeoutException, WebDriverException
                              from selenium.webdriver.chrome.options import Options
                              from selenium.webdriver.common.by import By
                              from selenium.webdriver.support.ui import WebDriverWait
                              from selenium.webdriver.support import expected_conditions as EC
                              # Logging-Konfiguration
                              logging.basicConfig(
                                  level=logging.INFO,
                                  format="%(asctime)s %(levelname)s %(message)s",
                                  handlers=[logging.StreamHandler(sys.stdout)],
                              log: Final = logging.getLogger(__name__)
                              # Datenklassen für Hyundai/Kia
                              @dataclass(frozen=True)
                              class BrandConfig:
                                  brand: str
                                  client_id: str
                                  client_secret: str
                                  redirect_final: str
                                  success_selector: str
                                  login_url: str
                              def build_config(brand: str) -> BrandConfig:
                                  """Erzeugt die Konfiguration für Hyundai bzw. Kia."""
                                  base_url = f"https://idpconnect-eu.{brand}.com/auth/api/v2/user/oauth2/"
                                  if brand == "kia":
                                      return BrandConfig(
                                          brand=brand,
                                          client_id="fdc85c00-0a2f-4c64-bcb4-2cfb1500730a",
                                          client_secret=os.getenv("KIA_CLIENT_SECRET", "secret"),
                                          redirect_final="https://prd.eu-ccapi.kia.com:8080/api/v1/user/oauth2/redirect",
                                          success_selector="a.logout.user",
                                          login_url=(
                                              f"{base_url}authorize?"
                                              "ui_locales=de&"
                                              "scope=openid%20profile%20email%20phone&"
                                              "response_type=code&"
                                              "client_id=peukiaidm-online-sales&"
                                              "redirect_uri=https://www.kia.com/api/bin/oneid/login&"
                                              "state=default"
                                  # ---------- hyundai ----------
                                  return BrandConfig(
                                      brand=brand,
                                      client_id="6d477c38-3ca4-4cf3-9557-2a1929a94654",
                                          "HYUNDAI_CLIENT_SECRET",
                                          "KUy49XxPzLpLuoK0xhBC77W6VXhmtQR9iQhmIFjjoY4IpxsV",
                                      redirect_final="https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/token",
                                      success_selector="button.mail_check",
                                      login_url=(
                                          "client_id=peuhyundaiidm-ctb&"
                                          "redirect_uri=https://ctbapi.hyundai-europe.com/api/auth&"
                                          "scope=openid+profile+email+phone"
                              # Selenium‑Helper
                              def init_driver(user_agent: str | None = None) -> webdriver.Chrome:
                                  options = Options()
                                  if user_agent:
                                      options.add_argument(f"user-agent={user_agent}")
                                  # Für lokale Entwicklung ist ein sichtbarer Browser oft hilfreicher.
                                  # Entferne `--headless`, wenn du das UI sehen möchtest.
                                  # options.add_argument("--headless")
                                  options.add_argument("--disable-gpu")
                                  options.add_argument("--no-sandbox")
                                  try:
                                      driver = webdriver.Chrome(options=options)
                                      driver.maximize_window()
                                      return driver
                                  except WebDriverException as exc:
                                      log.error("Chromedriver konnte nicht gestartet werden: %s", exc)
                                      raise
                              def wait_for_success(driver: webdriver.Chrome, selector: str, timeout: int = 300) -> None:
                                  log.info("Warte bis das Erfolgs‑Element (%s) erscheint …", selector)
                                  wait = WebDriverWait(driver, timeout)
                                  wait.until(EC.presence_of_element_located((By.CSS_SELECTOR, selector)))
                                  log.info("Erfolgs‑Element gefunden.")
                              # Token‑Austausch
                              def exchange_code(
                                  token_url: str,
                                  code: str,
                                  cfg: BrandConfig,
                              ) -> dict[str, str]:
                                  payload = {
                                      "grant_type": "authorization_code",
                                      "code": code,
                                      "redirect_uri": cfg.redirect_final,
                                      "client_id": cfg.client_id,
                                      "client_secret": cfg.client_secret,
                                  log.debug("POST %s – payload=%s", token_url, payload)
                                  try:
                                      resp = requests.post(token_url, data=payload, timeout=30)
                                      resp.raise_for_status()
                                      data = resp.json()
                                      log.info("Token‑Austausch erfolgreich.")
                                      return {"access_token": data["access_token"], "refresh_token": data["refresh_token"]}
                                  except requests.RequestException as exc:
                                      log.error("Fehler beim Token‑Austausch: %s – Antwort: %s", exc, getattr(exc.response, "text", ""))
                                      raise
                              # Haupt‑Workflow
                              def main() -> None:
                                  parser = argparse.ArgumentParser(description="OAuth‑Login‑Automation für Hyundai/Kia")
                                  parser.add_argument(
                                      "--brand",
                                      required=True,
                                      choices=["hyundai", "kia"],
                                      type=str.lower,
                                      help="Marke des Fahrzeugs (hyundai/kia)",
                                  args = parser.parse_args()
                                  cfg = build_config(args.brand)
                                  token_url = f"https://idpconnect-eu.{cfg.brand}.com/auth/api/v2/user/oauth2/token"
                                  redirect_url = (
                                      f"https://idpconnect-eu.{cfg.brand}.com/auth/api/v2/user/oauth2/authorize?"
                                      f"response_type=code&client_id={cfg.client_id}"
                                      f"&redirect_uri={cfg.redirect_final}&lang=de&state=ccsp"
                                  driver = init_driver(
                                      user_agent="Mozilla/5.0 (Linux; Android 4.1.1; Galaxy Nexus Build/JRO03C)"
                                  try:
                                      log.info("Öffne Login‑Seite: %s", cfg.login_url)
                                      driver.get(cfg.login_url)
                                      log.info("Bitte melde dich im geöffneten Browser an …")
                                      wait_for_success(driver, cfg.success_selector)
                                      log.info("Navigiere zur Redirect‑URL, um den Autorisierungscode zu erhalten.")
                                      driver.get(redirect_url)
                                      # Code‑Extraktion
                                      parsed = urlparse(driver.current_url)
                                      qs = parse_qs(parsed.query)
                                      if "code" not in qs:
                                          raise ValueError("Autorisation‑Code nicht in der URL gefunden.")
                                      code = qs["code"][0]
                                      log.debug("Gefundener Code: %s", code)
                                      tokens = exchange_code(token_url, code, cfg)
                                      log.info("✅ Refresh‑Token: %s", tokens["refresh_token"])
                                      log.info("✅ Access‑Token : %s", tokens["access_token"])
                                  except TimeoutException:
                                      log.error("Timeout – Login nicht abgeschlossen oder Erfolgs‑Element nicht gefunden.")
                                  finally:
                                      driver.quit()
                              if __name__ == "__main__":
                                  main()
                              $code | Out-File -FilePath "$env:TEMP\token\ApiToken.py" -Encoding UTF8
                              py -m venv .venv
                              .\.venv\Scripts\Activate.ps1
                              pip install --upgrade pip
                              pip install selenium requests webdriver-manager
                              py -m pip install --upgrade pip selenium requests
                              Achtung jetzt nur den Befehl für Hyundai oder KIA verwenden!!!
                              für Hyundai
                              cls
                              py .\ApiToken.py --brand hyundai
                              für KIA
                              cls
                              py .\ApiToken.py --brand kia
                              Hier geht es für beide weiter.
                              Jetzt sollte sich Chrome öffnen. Dort mit den Benutzerdaten einloggen.
                              Nun sollte im Fenster von PowerShell ein Refresh Token und ein Access Token erscheinen.
                              Diese mit der Maus markieren und mit Strg-C kopieren und in eine leere Textdatei mit Strg-V einfügen.
                              Der Refresh Token ist das Passwort für den Bluelink Adapter
                              Als letztes kann nun noch die Ausführungsrichtlinien (Unrestricted) für PowerShell-Scripts entfernt und der temporäre Ordner gelöscht werden. Dazu in der Powershell die folgenden Befehle eingeben.
                              Set-ExecutionPolicy Undefined
                              cd..
                              Remove-item $env:TEMP\token
                              Viel Spass
                              K
                              K
                              Kumpelstilzchen
                              #2308
                              @fichte_112 Vielen Dank auch von mir für die gute Anleitung für Windows-Nutzer.
                              Ich hatte mir noch etwas mühsamer Anfang Oktober einen Token ausgelesen und dann hat der Adapter wieder funktioniert. Nach nicht mal einer Woche war dann wieder Schluss und ich hab hier gelesen, dass der Token wieder ungültig wurde. Danach hatte ich erst mal die Faxen dicke mit Kia und hab den Adapter deaktiviert. Nun habe ich ihn wieder aktiviert, mit einem neuen Token. Was mich jetzt interessiert: Gibt es Erfahrungen mit der Gültigkeit des Tokens? Muss ich den auf die beschriebene Weise regelmäßig neu holen? Ich habe einige Seiten hier durchforstet, aber keine Aussage dazu gefunden.
                              • F fichte_112
                                F
                                F
                                Fibricus
                                #2309
                                @fichte_112 said in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                @fibricus du kannst den Token mit Windows erstellen. Nur den bluelinky Ordner musst du...
                                Vielen Dan für die Schnelle Antwort.
                                Dann werde ich das heute Abend mal angehen.
                                Wirklich toll wie das hier im Formum mit Hilfe funktioniert!
                                DANKE!!!
                                • F fichte_112
                                  K
                                  K
                                  klausiob
                                  #2310
                                  @fichte_112
                                  war nur Vorsichtsmaßnahme, wegen den Daten. Also REM sollte remove heißen:
                                  • F fichte_112
                                    $code = @"
                                    import argparse
                                    import logging
                                    import os
                                    import re
                                    import sys
                                    import requests
                                        level=logging.INFO,
                                    class BrandConfig:
                                        brand: str
                                        client_id: str
                                        client_secret: str
                                        redirect_final: str
                                        login_url: str
                                        if brand == "kia":
                                            return BrandConfig(
                                                brand=brand,
                                                login_url=(
                                                    "ui_locales=de&"
                                                    "state=default"
                                        return BrandConfig(
                                            brand=brand,
                                            login_url=(
                                    # Selenium‑Helper
                                        options = Options()
                                        if user_agent:
                                        try:
                                            return driver
                                            raise
                                    # Token‑Austausch
                                    def exchange_code(
                                        token_url: str,
                                        code: str,
                                        cfg: BrandConfig,
                                        payload = {
                                            "code": code,
                                        try:
                                            data = resp.json()
                                            raise
                                    # Haupt‑Workflow
                                    def main() -> None:
                                            "--brand",
                                            required=True,
                                            type=str.lower,
                                        redirect_url = (
                                        try:
                                            # Code‑Extraktion
                                        finally:
                                            driver.quit()
                                        main()
                                    py -m venv .venv
                                    für Hyundai
                                    cls
                                    für KIA
                                    cls
                                    cd..
                                    Viel Spass
                                    E
                                    E
                                    erickuttruff
                                    #2311
                                    @fichte_112
                                    Vielen Dank für die sehr gute Anletung :-)
                                    Jedoch bekomme ich folgenden Fehler:
                                    ✅ Login successful! Element found.
                                    An unexpected error occurred: HTTPSConnectionPool(host='idpconnect-eu.hyundai.com', port=443): Max retries exceeded with url: /auth/api/v2/user/oauth2/token (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1032)')))
                                    Cleaning up and closing the browser.
                                    • E erickuttruff
                                      @fichte_112
                                      F
                                      F
                                      fichte_112
                                      #2312
                                      @erickuttruff das ist ein Problem mit dem ssl Zertifikat des Browsers.
                                      Vielleicht hilft ein Neustart oder in der Konsole iob fix.
                                      Welche node.js Version hast du installiert?
                                      • arteckA
                                        arteckA
                                        arteck
                                        #2313
                                        @fichte_112 was hat ein Zertifikat problem aus dem KIA/Hyundai Umfeld mit iobroker zu tun... ??? vor allem auf Betriebsystemebene
                                        oder mit Nodejs..
                                        genau NIX
                                        die lösung steht im Text..
                                        @erickuttruff mach bitte den Browser in Privaten Modus auf.. dann klappt das auch..
                                        • arteckA arteck
                                          oder mit Nodejs..
                                          genau NIX
                                          E
                                          E
                                          erickuttruff
                                          #2314
                                          @arteck
                                          Das Browser Fenster öffnet sich ja aus dem Script heraus...
                                          Hier bringt es auch nichts wenn ich ein Fenster im Privaten Modus vorher öffne?
                                          83.8k
