  3. Off Topic
  4. [gelöst] - Zabbix (FritzBox etc.)
    1.6k
    1.5k
42 Beiträge 7 Kommentatoren 8.0k Aufrufe 8 Beobachtet
  • CodierknechtC
    CodierknechtC
    Codierknecht
    Der Vollständigkeit halber hier nun das komplette Script in Zabbix, um die Anzahl der Portweiterleitungen zu ermitteln:
    const params = JSON.parse(value);
    var requestBody = '<?xml version="1.0" encoding="utf-8"?>' +
    '<s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/">' +
    '    <s:Header>' +
    '        <h:InitChallenge xmlns:h="http://soap-authentication.org/digest/2001/10/" s:mustUnderstand="1">' +
    '            <UserID>' + params.username + '</UserID>' +
    '        </h:InitChallenge>' +
    '    </s:Header>' +
    '    <s:Body>' +
    '        <u:' + params.action + ' xmlns:u="' + params.urn + '" />' +
    '    </s:Body>' +
    '</s:Envelope>';
    const action = params.urn + '#' + params.action;
    // Initialize challenge with Fritz!Box
    var url = 'http://' + params.ip + ':49000' + params.url;
    const request = new HttpRequest();
    request.addHeader('Content-Type: text/xml; charset="utf-8"');
    request.addHeader('User-Agent: AVM UPnP/1.0 Client 1.0');
    request.addHeader('SoapAction: ' + action);
    var response = request.post(url, requestBody);
    var statusCode = request.getStatus();
    if (statusCode != 200) {
        throw 'Error ' + statusCode + ' initializing authentication!';
    } else {
        // Calculate authentication
        const nonce = XML.query(response, '//Nonce/text()');
        const realm = XML.query(response, '//Realm/text()');
        const secret = md5(params.username + ':' + realm + ':' + params.password);
        const auth = md5(secret + ':' + nonce);
        // Get values with authentication
        '    <s:Header>' +
        '        <h:ClientAuth xmlns:h="http://soap-authentication.org/digest/2001/10/" s:mustUnderstand="1">' +
        '            <Nonce>' + nonce + '</Nonce>' +
        '            <Auth>' + auth + '</Auth>' +
        '            <Realm>' + realm + '</Realm>' +
        '        </h:ClientAuth>' +
        '    </s:Header>' +
        '    <s:Body>' +
        '    </s:Body>' +
        '</s:Envelope>';
            throw 'Error ' + statusCode + ' sending authenticated request!';
        } else {
            return(XML.query(response, 'number(//NewForwardNumberOfEntries/text())'));
    Die Parameter "ip", "username" und "password" sollten klar sein.
    Was zusätzlich noch benötigt wird:
    "action" = "GetForwardNumberOfEntries"
    "url" = "/upnp/control/layer3forwarding"
    "urn" = "urn:dslforum-org:service:Layer3Forwarding:1"
    Jetzt werde ich nach und nach die Doku von AVM durchgehen, und sehen was da sinnvoll nutzbar ist.
    Das Ganze werde ich dann als Template für Zabbix veröffentlichen.
    Wie gesagt: Wer Vorschläge hat, darf die gerne äußern.
    Aktueller Zwischenstand:
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    • CodierknechtC
      CodierknechtC
      Codierknecht
      Here it is:
      https://github.com/DEV2DEV-DE/zabbix-templates/blob/main/zbx_template_fritzbox.xml
      • CodierknechtC Codierknecht
        Here it is:
        BananaJoeB
        BananaJoeB
        BananaJoe
        @codierknecht argh, Version 6.4. Da müsste ich noch eben warten bis 7.0 raus ist ... ich setze in dem Bereich nur die LTS-Versionen ein.
        CodierknechtC 2 Antworten Letzte Antwort
        • BananaJoeB BananaJoe
          CodierknechtC
          CodierknechtC
          Codierknecht
          @bananajoe sagte in [gelöst] - Zabbix (FritzBox etc.):
          Version 6.4
          Lässt sich das unter 6.0 importieren, wenn man einfach im XML die Versionsnummer runterdreht?
          Oder hat sich zu 6.4 das Format maßgebend geändert?
            Version 6.4
            BananaJoeB
            BananaJoeB
            BananaJoe
            @codierknecht Kollege testet gerade :-) Könnte reichen, ansonsten sagt er einem was ihn stört
            • CodierknechtC
              CodierknechtC
              Codierknecht
              Wenn man einmal weiß wie es geht ... wer einen Hammer hat, sieht eine Welt voller Nägel 😀
              Mittlerweile sind's > 80 Items ;-)
              Obwohl so eine Fritte eigentlich recht "unkommunikativ" ist. Kein SNMP, kein Telnet, kein SSH.
                CodierknechtC
                CodierknechtC
                Codierknecht
                Just for info:
                7.0 LTS ist draußen ... :-D
                • BananaJoeB
                  BananaJoeB
                  BananaJoe
                  Was ist neu in Zabbix 7.0?
                  https://www.youtube.com/watch?v=60Zy3bw-wOs
                  • arteckA
                    arteckA
                    arteck
                    die honeycomb find ich cool
                    • S
                      S
                      schittl
                      schrieb am zuletzt editiert von schittl
                      @Codierknecht
                      Vielen Dank für das Template funktioniert 1a. Nur eins was mir dabei aufgefallen ist. Hat man den PushService aktiviert bekommt man alle x-Sekunden eine Nachricht. Ich verwende upnp schon mit fritzinfluxdb (https://github.com/bb-Ricardo/fritzinfluxdb) auf die gleiche Weise nur da bekommt man nur 1x ne Mail bei der Erstanmeldung/Neustart. Sicherlich der Unterschied in der Programmiersprache ;)
                      Soll nur als Hinweis dienen und vielen Dank für deine Mühe.
                      HW: Lenovo M920q (Proxmox, ioBroker, RaspMatic & Z2M), QNAP (Docker, Influx), Arduino Mega 2560 R3 (I2C DS18B20 + LED)
                      SW: CT IoBroker, VM RaspMatic(v3.79.6.20241122)
                      • S schittl
                        @Codierknecht
                        CodierknechtC
                        CodierknechtC
                        Codierknecht
                        @schittl sagte in [gelöst] - Zabbix (FritzBox etc.):
                        Das dürfte an Deiner Einstellung "Bei Anmeldungen von Apps ..." liegen.
                        Es wird ja - je nach eingestelltem Intervall der Items - immer wieder eine Anmeldung an der Fritte durchgeführt.
                          S
                          S
                          schittl
                          @codierknecht
                          Kleine Idee/Verbesserung:
                          Ist es möglich das man/Du im Template {HOST.IP} durch {HOST.HOST} ersetzt, dann würden im Dashboard nicht mehr "Unknown host" für die Fritte auftauchen ;)
                          Siehe Beispiel am Video icmp (https://www.youtube.com/watch?v=sHMmwL1q3Gc)
                          Ich habe das Template dahingehend schon angepasst. Falls gewünscht stelle ich es bereit. Wollte nur nicht einfach so reinstellen.
                          Wie gesagt funktioniert super das Template und soll nur als Hinweis/Anregung dienen. Ich bedanke mich abermals für das zur Verfügung stellen 👍
                          • S schittl
                            @codierknecht
                            BananaJoeB
                            BananaJoeB
                            BananaJoe
                            @schittl Also eigentlich sollte man bei den Items {HOST.CONN} verwenden - das ist die eingestellte Hostverbindung, entweder der DNS-Name oder die IP, je nach Auswahl.
                            Wenn der DNS dann konfiguriert und dessen Benutzung ausgewählt ist, nimmt er diesen
                            {HOST.HOST} wäre der Hostname, also was oben im ersten Feld der Hostkonfiguration steht. Das kann ein gültiger Hostname (aka NetBIOS) oder DNS-Name sein, muss aber nicht
                            • CodierknechtC
                              CodierknechtC
                              Codierknecht
                              Wenn Du das schon fertig hast ... mach einfach einen PullRequest.
                              Alternativ wäre es auch möglich, die IP statt aus einem Interface (das ja zwangsläufig "not available" wird) über ein Host-Macro zu füttern.
                              Die Idee mit {HOST.HOST} ist nicht verkehrt, könnte aber ebenfalls zu Verwirrungen führen, da ja am Host dann mit "Visible name" gearbeitet werden muss.
