  3. Off Topic
  4. [gelöst] - Zabbix (FritzBox etc.)
    1.6k
    1.5k
42 Beiträge 7 Kommentatoren 7.9k Aufrufe 8 Beobachtet
  • CodierknechtC
    CodierknechtC
    Codierknecht
    @BananaJoe Der Tipp war Gold wert :-D
    Falls es jemanden interessiert:
    Ich hab's jetzt hinbekommen, über die TR-064 Schnittstelle der Fritte auch geschützte Daten auszulesen.
    const axios = require('axios');
    const crypto = require('crypto');
    const xml = require('xmldom');
    const parser = new xml.DOMParser();
    async function getForwardedPortsCount(username, password) {
        const requestHeader = {
            'Content-Type': 'text/xml; charset="utf-8"',
            'SoapAction': 'urn:dslforum-org:service:Layer3Forwarding:1' + '#' + 'GetForwardNumberOfEntries'
        var requestBody = '<?xml version="1.0" encoding="utf-8"?>' +
        '<s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/">' +
        '    <s:Header>' +
        '        <h:InitChallenge xmlns:h="http://soap-authentication.org/digest/2001/10/" s:mustUnderstand="1">' +
        '            <UserID>' + username + '</UserID>' +
        '        </h:InitChallenge>' +
        '    </s:Header>' +
        '    <s:Body>' +
        '        <u:' + 'GetForwardNumberOfEntries' + ' xmlns:u="' + 'urn:dslforum-org:service:Layer3Forwarding:1' + '" />' +
        '    </s:Body>' +
        '</s:Envelope>';
        // Initialize challenge with Fritz!Box
        var uri = 'http://' + '192.168.178.1' + ':49000' + '/upnp/control/layer3forwarding';
        var response = await axios.post(uri, requestBody, { headers: requestHeader });
        // Calculate authentication
        var doc = parser.parseFromString(response.data, 'text/xml');
        const nonce = doc.getElementsByTagName('Nonce')[0].childNodes[0].nodeValue;
        const realm = doc.getElementsByTagName('Realm')[0].childNodes[0].nodeValue;
        const secret = crypto.createHash('md5').update(username + ':' + realm + ':' + password).digest('hex');
        const auth = crypto.createHash('md5').update(secret + ':' + nonce).digest('hex');
        // Get values with authentication
        '    <s:Header>' +
        '        <h:ClientAuth xmlns:h="http://soap-authentication.org/digest/2001/10/" s:mustUnderstand="1">' +
        '            <Nonce>' + nonce + '</Nonce>' +
        '            <Auth>' + auth + '</Auth>' +
        '            <Realm>' + realm + '</Realm>' +
        '        </h:ClientAuth>' +
        '    </s:Header>' +
        '    <s:Body>' +
        '    </s:Body>' +
        '</s:Envelope>';
        // return result
        const ports = doc.getElementsByTagName('NewForwardNumberOfEntries')[0].childNodes[0].nodeValue;
        return(ports);
    Allerdings erst einmal nur direkt im ioBroker und nicht als Zabbix-Script-Item.
    Das liefert mir blöderweise beim POST-Request einen 404 :-(
    Alles was ich dort mit GET-Requests mache, funktioniert tadellos.
    Warum GET funktioniert und POST nicht, ist mir (noch) schleierhaft.
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    • CodierknechtC Codierknecht
          '    <s:Header>' +
          '    </s:Header>' +
          '    <s:Body>' +
          '    </s:Body>' +
          '</s:Envelope>';
          '    <s:Header>' +
          '    </s:Header>' +
          '    <s:Body>' +
          '    </s:Body>' +
          '</s:Envelope>';
          // return result
          return(ports);
      CodierknechtC
      CodierknechtC
      Codierknecht
      @codierknecht
      @Garfonso @fastfoot
      Ich hab' die Diskussion aus Discord mal hier weitergetrieben.
      Hier kriegen das mehr User mit ... falls es wen interessiert.
      Das "fehlerhafte" Script in Zabbix sieht so aus:
      const params = JSON.parse(value);
      const requestBody = '<?xml version="1.0" encoding="utf-8"?>' +
      '    <s:Header>' +
      '            <UserID>' + params.username + '</UserID>' +
      '    </s:Header>' +
      '    <s:Body>' +
      '        <u:' + params.action + ' xmlns:u="' + params.urn + '" />' +
      '    </s:Body>' +
      '</s:Envelope>';
      const action = params.urn + '#' + params.action;
      var url = 'http://' + params.ip + ':49000' + params.url;
      const request = new HttpRequest();
      request.addHeader('Content-Type', 'text/xml; charset="utf-8"');
      request.addHeader('SoapAction', action);
      var response = request.post(url, requestBody);
      return JSON.stringify(response);
      Der POST-Request liefert ein 404.
      Teste ich das mit einem GET gegen die Fritte (z.B. http://192.168.178.1:49000/tr64desc.xml), funktioniert das einwandfrei ... auch mit Port 49000.
      Wenn ich den hier verwendeten Header und den URL in Postman einsetze, funktioniert das auch problemlos.
      • CodierknechtC
        CodierknechtC
        Codierknecht
        Ich habe mir mal einen kleinen Test-Service gebaut, der bei gleichem Endpunkt & Port sowohl auf GET als auch auf POST horcht.
        Ergebnis: Funktioniert einwandfrei.
        Es ist also nicht Zabbix, das hier das Problem verursacht, sondern die Fritte selbst.
        Irgend etwas fehlt bei meinem Request oder ist falsch.
        Bin für jede Idee zu haben ...
          arteckA
          arteckA
          arteck
          @codierknecht dann nimm doch den GET
          • arteckA arteck
            CodierknechtC
            CodierknechtC
            Codierknecht
            @arteck sagte in [gelöst] - Zabbix (FritzBox etc.):
            Das funktioniert nur bei meinem Test-Service.
            Die Fritte erwartet für TR-064 schon einen POST und einen entsprechenden body.
            • CodierknechtC
              CodierknechtC
              Codierknecht
              Des Rätsels Lösung:
              Die Header für den Request müssen so gesetzt werden:
              request.setHeader('Content-Type: text/xml');
              und nicht so:
              request.setHeader('Content-Type', 'text/xml');
              Dummerweise wirft die JS-Enginge von Zabbix hier keinen Fehler.
              Es kann jetzt also an der Ecke weitergehen.
              Als erstes soll ein Check auf die Portfreigaben eingerichtet werden.
              Das Abfragen der Fritte über TR-064 ist nämlich deutlich schneller als der Kram über .../xyz.lua.
              Was fällt euch so alles ein, was sich mit Zabbix an der Fritte monitoren lässt?
                Des Rätsels Lösung:
                und nicht so:
                BananaJoeB
                BananaJoeB
                BananaJoe
                @codierknecht das Problem mit Zabbix ist ja das man manchmal einfach in eine Sammelwut verfällt. Ist zwar schön was man alles abrufen kann, aber ob man das braucht ...
                Up- und Download Auslastung frage ich zum Beispiel meinen Switch hinter der Fritte per SNMP statt der Fritte selbst.
                Trotzdem nehme ich nur zu gerne dann dein fertiges Template, zum einen als schönes Beispiel, zum anderen weil man das dann auch schön zeigen kann und die Leute damit etwas anfangen können.
                Du kannst noch die DECT Geräte abfragen usw. Dann bist du irgendwann bei allem was der TR064 und/oder FritzDECT Adapter raussaugt, nur ohne steuern. Kannst dir ja bei den Adapter Inspiration holen.
                Statistiken zur Verbindung / Fehlerrate werden auch immer gerne genommen. Wobei es da ja DSL, Glasfaser und LTE gäbe.
                Das Muster-Template kann gerne alles herausholen was es gibt - man kann dann ja das deaktivieren was man nicht braucht bzw. das Template klonen und zusammenstreichen ...
                • CodierknechtC
                  CodierknechtC
                  Codierknecht
                  Der Vollständigkeit halber hier nun das komplette Script in Zabbix, um die Anzahl der Portweiterleitungen zu ermitteln:
                  '    <s:Header>' +
                  '    </s:Header>' +
                  '    <s:Body>' +
                  '    </s:Body>' +
                  '</s:Envelope>';
                  request.addHeader('Content-Type: text/xml; charset="utf-8"');
                  request.addHeader('User-Agent: AVM UPnP/1.0 Client 1.0');
                  request.addHeader('SoapAction: ' + action);
                  var statusCode = request.getStatus();
                  if (statusCode != 200) {
                      throw 'Error ' + statusCode + ' initializing authentication!';
                  } else {
                      const nonce = XML.query(response, '//Nonce/text()');
                      const realm = XML.query(response, '//Realm/text()');
                      const secret = md5(params.username + ':' + realm + ':' + params.password);
                      const auth = md5(secret + ':' + nonce);
                      '    <s:Header>' +
                      '    </s:Header>' +
                      '    <s:Body>' +
                      '    </s:Body>' +
                      '</s:Envelope>';
                          throw 'Error ' + statusCode + ' sending authenticated request!';
                      } else {
                          return(XML.query(response, 'number(//NewForwardNumberOfEntries/text())'));
                  Die Parameter "ip", "username" und "password" sollten klar sein.
                  Was zusätzlich noch benötigt wird:
                  "action" = "GetForwardNumberOfEntries"
                  "url" = "/upnp/control/layer3forwarding"
                  "urn" = "urn:dslforum-org:service:Layer3Forwarding:1"
                  Jetzt werde ich nach und nach die Doku von AVM durchgehen, und sehen was da sinnvoll nutzbar ist.
                  Das Ganze werde ich dann als Template für Zabbix veröffentlichen.
                  Wie gesagt: Wer Vorschläge hat, darf die gerne äußern.
                  Aktueller Zwischenstand:
                  • CodierknechtC
                    CodierknechtC
                    Codierknecht
                    Here it is:
                    https://github.com/DEV2DEV-DE/zabbix-templates/blob/main/zbx_template_fritzbox.xml
                      Here it is:
                      BananaJoeB
                      BananaJoeB
                      BananaJoe
                      @codierknecht argh, Version 6.4. Da müsste ich noch eben warten bis 7.0 raus ist ... ich setze in dem Bereich nur die LTS-Versionen ein.
                      CodierknechtC 2 Antworten Letzte Antwort
                      • BananaJoeB BananaJoe
                        CodierknechtC
                        CodierknechtC
                        Codierknecht
                        @bananajoe sagte in [gelöst] - Zabbix (FritzBox etc.):
                        Version 6.4
                        Lässt sich das unter 6.0 importieren, wenn man einfach im XML die Versionsnummer runterdreht?
                        Oder hat sich zu 6.4 das Format maßgebend geändert?
                          Version 6.4
                          BananaJoeB
                          BananaJoeB
                          BananaJoe
                          @codierknecht Kollege testet gerade :-) Könnte reichen, ansonsten sagt er einem was ihn stört
                          • CodierknechtC
                            CodierknechtC
                            Codierknecht
                            Wenn man einmal weiß wie es geht ... wer einen Hammer hat, sieht eine Welt voller Nägel 😀
                            Mittlerweile sind's > 80 Items ;-)
                            Obwohl so eine Fritte eigentlich recht "unkommunikativ" ist. Kein SNMP, kein Telnet, kein SSH.
                              CodierknechtC
                              CodierknechtC
                              Codierknecht
                              Just for info:
                              7.0 LTS ist draußen ... :-D
                              • BananaJoeB
                                BananaJoeB
                                BananaJoe
                                Was ist neu in Zabbix 7.0?
                                https://www.youtube.com/watch?v=60Zy3bw-wOs
                                • arteckA
                                  arteckA
                                  arteck
                                  die honeycomb find ich cool
                                  • S
                                    S
                                    schittl
                                    schrieb am zuletzt editiert von schittl
                                    @Codierknecht
                                    Vielen Dank für das Template funktioniert 1a. Nur eins was mir dabei aufgefallen ist. Hat man den PushService aktiviert bekommt man alle x-Sekunden eine Nachricht. Ich verwende upnp schon mit fritzinfluxdb (https://github.com/bb-Ricardo/fritzinfluxdb) auf die gleiche Weise nur da bekommt man nur 1x ne Mail bei der Erstanmeldung/Neustart. Sicherlich der Unterschied in der Programmiersprache ;)
                                    Soll nur als Hinweis dienen und vielen Dank für deine Mühe.
                                    HW: Lenovo M920q (Proxmox, ioBroker, RaspMatic & Z2M), QNAP (Docker, Influx), Arduino Mega 2560 R3 (I2C DS18B20 + LED)
                                    SW: CT IoBroker, VM RaspMatic(v3.79.6.20241122)
                                    • S schittl
                                      @Codierknecht
                                      CodierknechtC
                                      CodierknechtC
                                      Codierknecht
                                      @schittl sagte in [gelöst] - Zabbix (FritzBox etc.):
                                      Das dürfte an Deiner Einstellung "Bei Anmeldungen von Apps ..." liegen.
                                      Es wird ja - je nach eingestelltem Intervall der Items - immer wieder eine Anmeldung an der Fritte durchgeführt.
                                        S
                                        S
                                        schittl
                                        @codierknecht
                                        Kleine Idee/Verbesserung:
                                        Ist es möglich das man/Du im Template {HOST.IP} durch {HOST.HOST} ersetzt, dann würden im Dashboard nicht mehr "Unknown host" für die Fritte auftauchen ;)
                                        Siehe Beispiel am Video icmp (https://www.youtube.com/watch?v=sHMmwL1q3Gc)
                                        Ich habe das Template dahingehend schon angepasst. Falls gewünscht stelle ich es bereit. Wollte nur nicht einfach so reinstellen.
                                        Wie gesagt funktioniert super das Template und soll nur als Hinweis/Anregung dienen. Ich bedanke mich abermals für das zur Verfügung stellen 👍
                                        • S schittl
                                          @codierknecht
                                          BananaJoeB
                                          BananaJoeB
                                          BananaJoe
                                          @schittl Also eigentlich sollte man bei den Items {HOST.CONN} verwenden - das ist die eingestellte Hostverbindung, entweder der DNS-Name oder die IP, je nach Auswahl.
                                          Wenn der DNS dann konfiguriert und dessen Benutzung ausgewählt ist, nimmt er diesen
                                          {HOST.HOST} wäre der Hostname, also was oben im ersten Feld der Hostkonfiguration steht. Das kann ein gültiger Hostname (aka NetBIOS) oder DNS-Name sein, muss aber nicht
