  4. Test Adapter eusec v2.0.x
    6.8k
eusecmcm1957
96 Beiträge 21 Kommentatoren 11.6k Aufrufe 20 Beobachtet
    @niiccooo1
    iobroker url iobroker.eusec@latest --debug
    N Offline
    N Offline
    niiccooo1
    @thomas-braun said in Test Adapter eusec 2.0.x:
    root@iobroker:/opt/iobroker# iobroker url iobroker.eusec@latest --debug
    install iobroker.eusec@latest
    NPM version: 10.9.4
    Installing iobroker.eusec@latest... (System call)
    npm error code EBADENGINE
    npm error engine Unsupported engine
    npm error engine Not compatible with your version of node/npm: ring-client-api@12.1.1
    npm error notsup Not compatible with your version of node/npm: ring-client-api@12.1.1
    npm error notsup Required: {"node":"^18 || ^20"}
    npm error notsup Actual:   {"npm":"10.9.4","node":"v22.21.0"}
    npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2025-11-02T15_31_44_513Z-debug-0.log
    upload [13] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/eusec.png eusec.png image/png
    upload [12] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [11] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [10] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [9] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [8] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [7] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [6] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [5] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [4] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [3] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [2] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [1] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/words.js words.js application/javascript
    Updating objects from io-package.json for adapter "eusec" with version "1.3.3"
    • N niiccooo1
      NPM version: 10.9.4
      @niiccooo1 sagte in Test Adapter eusec 2.0.x:
      root@iobroker
      Hampel da NICHT als root herum.
      N 1 Antwort Letzte Antwort
        root@iobroker
        N Offline
        N Offline
        niiccooo1
        Ist von Docker Container... Kann man das ändern?
        mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
        • N niiccooo1
          mcm1957M Online
          mcm1957M Online
          mcm1957
          Da die neue Release Probleme mit der empfohlenen node.js Version 22 löst und ich bisher kein negatives Feedback erhalten habe hab ich die Version nun prior auch ins stable Repo geschickt.
          2.0.3 sollte AB MORGEN auch im STABLE Repository verfügbar sein.
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          • N niiccooo1
            @niiccooo1
            Ach Docker-Gedönse...
            Jedenfalls klemmt es nicht am eusec, sondern daran:
            Hast du da noch weitere Updates ausstehen? Den ring-Adapter evtl? Bring die Kiste insgesamt auf Stand. Da scheint mir einiges nicht aktuell zu sein.
              @niiccooo1
              N Offline
              N Offline
              niiccooo1
              @thomas-braun @thomas-braun
              Okay...
              Soweit sind alle ausstehenden Updates ausgeführt. Auch das neuste Image (2 Tage alt) habe ich über Docker gezogen.
              Ich warte dann den morgigen Tag ab und schaue ob ich es dann updates kann.
              Den Ring-client schaue ich mir mal an.
              Danke erstmal für eure Hilfe.
              • N niiccooo1
                Okay...
                @niiccooo1
                Zeig mal die Ausgabe von
                iob diag
                  @niiccooo1
                  iob diag
                  N Offline
                  N Offline
                  niiccooo1
                  iob diag
                  root@iobroker:/opt/iobroker# iob diag
                  The ioBroker diag script is not specifically designed to run in Docker.
                  Although it is generally safe to use, use it at your own risk.
                  Do you want to continue? [yes/no]
                  • N niiccooo1
                    iob diag
                    @niiccooo1
                    Joh... Und was möchtest du nun tun?
                    N 2 Antworten Letzte Antwort
                      @niiccooo1
                      N Offline
                      N Offline
                      niiccooo1
                      Wenn es sicher auszuführen ist, mache ich es. Bin da kein Experte...
                        @niiccooo1
                        N Offline
                        N Offline
                        niiccooo1
                        Habe eine ziemlich lange Ausgabe erhalten.
                        Was möchtest du den sehen?
                        • N niiccooo1
                          @niiccooo1
                          Ja, ist sicher. Das liest nur Einstellungen aus.
                          Na alles...
                          iob upgrade ring@6.4.0 --debug
                          muss aber das Installationshindernis aus dem Weg räumen.
                            @niiccooo1
                            Na alles...
                            N Offline
                            N Offline
                            niiccooo1
                            schrieb am zuletzt editiert von niiccooo1
                            Die Ausgabe bei iob upgrade ring ergibt folgendes:
                            root@iobroker:/opt/iobroker# iob upgrade ring@6.4.0 --debug
                            Would you like to reinstall version 6.4.0 of ring now? [(y)es, (n)o]: yes
                            Update ring from @6.4.0 to @6.4.0
                            Uninstall npm packet "iobroker.ring" for a clean re-installation
                            npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2025-11-02T15_56_54_334Z-debug-0.log
                            NPM version: 10.9.4
                            Installing iobroker.ring@6.4.0... (System call)
                            npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2025-11-02T15_56_57_775Z-debug-0.log
                            Updating objects from io-package.json for adapter "ring" with version "6.4.0"
                            upload [25] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/admin.d.ts admin.d.ts video/mp2t
                            upload [20] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/de.json i18n/de.json application/json
                            upload [19] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/en.json i18n/en.json application/json
                            upload [18] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/es.json i18n/es.json application/json
                            upload [17] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/fr.json i18n/fr.json application/json
                            upload [16] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/it.json i18n/it.json application/json
                            upload [15] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/nl.json i18n/nl.json application/json
                            upload [14] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/pl.json i18n/pl.json application/json
                            upload [13] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/pt.json i18n/pt.json application/json
                            upload [12] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/ru.json i18n/ru.json application/json
                            upload [11] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/uk.json i18n/uk.json application/json
                            upload [10] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                            upload [9] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/index_m.html index_m.html text/html
                            upload [8] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/jsonConfig.json jsonConfig.json application/json
                            upload [7] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/preferences-desktop-notification-bell-3.png preferences-desktop-notification-bell-3.png image/png
                            upload [6] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/preferences-system-login.png preferences-system-login.png image/png
                            upload [5] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/ring.png ring.png image/png
                            upload [4] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/style.css style.css text/css
                            upload [3] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tab_m.html tab_m.html text/html
                            upload [2] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tab_m.js tab_m.js application/javascript
                            upload [1] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tsconfig.json tsconfig.json application/json
                            upload [0] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/words.js words.js application/javascript
                            • N niiccooo1
                              NPM version: 10.9.4
                              @niiccooo1
                              Dann lösch den ring-Adapter mal komplett aus dem System und installier den dann nochmal neu.
                              Denn eigentlich muss da die ring-client-api 14.1.0 gezogen werden (und die passt zu nodejs@22):
                              echad@chet:/opt/iobroker $ iob add ring --debug
                              NPM version: 11.6.2
                              npm error engine Not compatible with your version of node/npm: ring-client-api@14.1.0
                              npm error notsup Not compatible with your version of node/npm: ring-client-api@14.1.0
                              npm error notsup Required: {"node":"^20 || ^22 || ^24"}
                              npm error notsup Actual:   {"npm":"11.6.2","node":"v25.1.0"}
                              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-02T15_47_04_628Z-debug-0.log
                                @niiccooo1
                                NPM version: 11.6.2
                                N Offline
                                N Offline
                                niiccooo1
                                @thomas-braun Alles klar.
                                Zum löschen über die admin Oberfläche reicht oder lieber über die Konsole?
                                • N niiccooo1
                                  @niiccooo1
                                  Ich bevorzuge in jedem Fall das Terminal.
                                  iob del ring --debug
                                  iob update
                                  Und fertig.
                                    @niiccooo1
                                    iob update
                                    Und fertig.
                                    N Offline
                                    N Offline
                                    niiccooo1
                                    root@iobroker:~# iob del ring --debug
                                    Delete adapter "ring"
                                    host.iobroker Counted 1 instances of ring
                                    host.iobroker Counted 2 meta of ring
                                    host.iobroker Counted 1 adapter for ring
                                    host.iobroker Counted 2 devices of ring
                                    host.iobroker Counted 6 channels of ring
                                    host.iobroker Counted 44 states of ring
                                    host.iobroker Counted 14 states of system.adapter.ring
                                    host.iobroker Counted 44 states (io.ring.*) from states
                                    host.iobroker Counted 15 states (system.adapter.ring.*) from states
                                    host.iobroker file ring.admin deleted
                                    host.iobroker file ring.0 deleted
                                    host.iobroker object ring deleted
                                    host.iobroker object ring.admin deleted
                                    host.iobroker Deleting 71 object(s).
                                    host.iobroker Deleting 59 state(s).
                                    Error deleting adapter ring from disk: host.iobroker: Cannot uninstall iobroker.ring: 1
                                    You might have to delete it yourself!
                                    Die Instanz ist weg, jedoch der Adapter lässt sich nicht deinstallieren
                                    • N niiccooo1
                                      @niiccooo1
                                      iob list adapters | grep ring
                                        @niiccooo1
                                        N Offline
                                        N Offline
                                        niiccooo1
                                        root@iobroker:~# iob list adapters | grep ring
                                        host.iobroker Deleting 1 object(s).
                                        • N niiccooo1
                                          @niiccooo1
                                          iob update
