  3. Off Topic
  4. Pflege des Betriebssystems
  5. Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
265 Beiträge 50 Kommentatoren 78.5k Aufrufe 56 Beobachtet
  • C Cumulus 0
    @thomas-braun said in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
    sudo apt full-upgrade
    257 upgraded, 159 newly installed, 53 to remove and 0 not upgraded.
    2 not fully installed or removed.
    Need to get 444 MB of archives.
    After this operation, 359 MB of additional disk space will be used.
    Do you want to continue? [Y/n]
    Y oder n?
    #178
    @cumulus-0
    yes
    C 1 Antwort Letzte Antwort
      @cumulus-0
      yes
      Cumulus 0
      #179
      Es kommen hunderte von Fehlermeldungen und der Abschluss:
      dpkg: warning: unable to delete old directory '/lib/modules/6.12.34+rpt-rpi-v8/kernel/arch': Directory not empty
      dpkg: warning: unable to delete old directory '/lib/modules/6.12.34+rpt-rpi-v8/kernel': Directory not empty
      dpkg: warning: unable to delete old directory '/lib/modules/6.12.34+rpt-rpi-v8': Directory not empty
      (Reading database ... 113047 files and directories currently installed.)
      Removing linux-headers-6.12.25+rpt-rpi-v8 (1:6.12.25-1+rpt1) ...
      Removing linux-image-6.12.25+rpt-rpi-v8 (1:6.12.25-1+rpt1) ...
      /etc/kernel/postrm.d/initramfs-tools:
      update-initramfs: Deleting /boot/initrd.img-6.12.25+rpt-rpi-v8
      /etc/kernel/postrm.d/z50-raspi-firmware:
      raspi-firmware: missing /boot/firmware, did you forget to mount it?
      run-parts: /etc/kernel/postrm.d/z50-raspi-firmware exited with return code 1
      dpkg: error processing package linux-image-6.12.25+rpt-rpi-v8 (--remove):
       installed linux-image-6.12.25+rpt-rpi-v8 package post-removal script subprocess returned error exit status 1
      dpkg: too many errors, stopping
      Errors were encountered while processing:
      Processing was halted because there were too many errors.
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      • C Cumulus 0
        #180
        @cumulus-0
        Da stimmt was mit der boot_partition nicht.
        Was war das Ausgangssystem? Debian12?
        mount | sort
        sagt?
          @cumulus-0
          mount | sort
          sagt?
          Cumulus 0
          #181
          mount | sort
          Ja, im Juni neu installiert.
           mount | sort
          //192.168.xxx/fritz.nas/rout_bak/RaspSys on /media/nas type cifs (rw,relatime,vers=3.1.1,sec=ntlmv2,cache=strict,upcall_target=app,username=,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.,file_mode=0755,dir_mode=0755,soft,nounix,mapposix,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1,user=xxx)
          binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
          bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
          cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
          configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
          debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
          /dev/mmcblk0p2 on / type ext4 (rw,noatime)
          devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
          fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
          mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
          proc on /proc type proc (rw,relatime)
          pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
          ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
          ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
          ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
          ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
          securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
          sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
          sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
          systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=3534)
          tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
          tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
          tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=800856k,mode=755)
          tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=800852k,nr_inodes=200213,mode=700,uid=1000,gid=1000)
          tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
          udev on /dev type devtmpfs (rw,nosuid,relatime,size=3736304k,nr_inodes=934076,mode=755)
          • C Cumulus 0
            mount | sort
             mount | sort
            #182
            @cumulus-0
            Da fehlt tatsächlich der mount von
            /dev/mmcblk0p2 auf /boot/firmware
            Wie bootest du das Ding denn??
              @cumulus-0
              Cumulus 0
              schrieb am zuletzt editiert von Cumulus 0
              #183
               sudo parted -l
              Model: SD Y032V (sd/mmc)
              Disk /dev/mmcblk0: 31.0GB
              Sector size (logical/physical): 512B/512B
              Partition Table: msdos
              Disk Flags:
              Number  Start   End     Size    Type     File system  Flags
               1      8389kB  545MB   537MB   primary  fat32        lba
               2      545MB   31.0GB  30.5GB  primary  ext4
              Das hat bisher nie gestört. Vermutlich ist das nicht das einzige Problem.
              Ist eine Neuinstallation evtl. besser? Im Juni von Debian 11 auf 12. Dann hab ich noch 2-3 Jahre Zeit, oder?
              • C Cumulus 0
                 sudo parted -l
                Disk Flags:
                #184
                @cumulus-0 sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                Joh, und dabei geht das System an genau der Stelle kaputt.
                Das funktioniert nämlich nicht sauber. Installier es neu. Und zwar nicht in zwei Jahren sondern in zwei Wochen.
                  Cumulus 0
                  #185
                  Super! Das war aber eine Neuinstallation auf neuer Karte.
                  Dann werde ich wohl den einfachen Weg gehen müssen. Ein paar Systemanwendungen wie email, open SSH mit Root und Backup sind dann wieder ein Problem.
                  Aber erstmal vielen Dank für die schnelle und tolle Hilfe!
                  • C Cumulus 0
                    #186
                    open SSH mit Root
                    Macht man NICHT.
                      open SSH mit Root
                      Macht man NICHT.
                      Cumulus 0
                      #187
                      Ist aber sehr praktisch, wenn man das braucht. Aber ich räume ein, root hab ich noch nie gebraucht. Aber ich habe immer ein schlechtes Gefühl, wenn ich irgendwo ausgesperrt bin.
                      Aber mein Vollbackup war gestern sehr praktisch. Das hatte ich vorher gezogen. Nach missglücktem Versuch einfach die Karte wechseln, und alles läuft wieder. Licht im Haus, Auto laden, PV und die ganzen Erfassungen dazu sind schon praktisch.
                      Also nochmals vielen Dank an Thomas!
                      • C Cumulus 0
                        #188
                        Man braucht es ja eben NIE. Meld dich mit dem default user an und verwende dann innerhalb des Systems sudo.
                        • CodierknechtC Codierknecht
                          @codierknecht sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                          Die mysqldump.cnf sieht wie folgt aus:
                          Ich hab's hinbekommen :-D
                          Die config muss (auf der ioBroker-Seite) so aussehen:
                          [mysqldump]
                          quick
                          quote-names
                          max_allowed_packet = 16M
                          ssl = 0
                          Siggi0904S Offline
                          Siggi0904S Offline
                          Siggi0904
                          schrieb am zuletzt editiert von Siggi0904
                          #189
                          @codierknecht ich lauf bei meiner Synology seit dem Upgrade auf Trixie in den gleichen Fehler.
                          Wo finde ich denn die mysqldump.cnf ?
                          Dank dir.
                          Edit: gefunden, Datei liegt in /etc/mysql/conf.d
                          Danke für den super Hinweis, ich hatte nämlich keine Meldung erhalten, die erschien nur nach dem Neustart heute beim node-js update.
                            Debian 13 'Trixie' ist am 09.08.2025 in einer stabilen Version veröffentlicht worden!
                            Upgrades sind nur von der direkten Vorversion und nur von der gleichen CPU-Architektur aus möglich.
                            Also Debian 12 'Bookworm' und z.B. arch64. CrossUpgrades von 32Bit 'armhf' auf 'arm64' sind nicht möglich (nur für echte Pinguine!) und bedingen eine Neuinstallation.
                            Hier hat es folgendermaßen auf einem Raspberry 4 funktioniert.
                            Natürlich ohne Desktop oder sowas, nur per SSH direkt mit einem Terminal verbunden. Mit laufender GUI und aus einer lokalen Konsole heraus ist das alles komplizierter, weil es passieren kann, dass die Verbindung abreißt und das ganze schwer in die Hose geht. Aber wir betreiben ja Server alle immer grundsätzlich ohne graphische Oberfläche...
                            Das bisherige System muss auf dem allerletzten Stand sein.
                            Also per
                            sudo apt update
                            sudo reboot
                            zunächst mal sicherstellen, das man auf dem neusten PointRelease agiert. Stand 09. August 2025 ist das:
                            echad@chet:~ $ cat /etc/debian_version
                            12.11
                            echad@chet:~ $
                            APT pinning:
                            Schauen, ob in einer Datei wie /etc/apt/preferences oder im Verzeichnis /etc/apt/preferences.d Pakete (außer nodejs / nodesource) gepinnt wurden. Diese müssen entfernt werden.
                            Mit
                            apt-mark showhold
                            schaut man noch, ob Pakete auf 'Halten' gesetzt wurden. Auch dies muss möglichst Rückgängig gemacht werden.
                            Geht dann per
                            sudo apt-mark unhold PAKETNAME
                            ODER in Bausch und Bogen
                            per
                            sudo apt-mark unhold `apt-mark showhold`
                            Jetzt wird geschaut, ob die Ausganglage sauber ist. Sollte ungefähr so aussehen:
                            echad@chet:~ $ sudo apt update
                            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                            Hit:3 https://repos.influxdata.com/debian stable InRelease
                            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                            Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                            Hit:6 http://phoscon.de/apt/deconz bookworm InRelease
                            Hit:7 http://phoscon.de/apt/deconz bookworm-beta InRelease
                            Hit:8 https://apt.grafana.com stable InRelease
                            Hit:9 https://cli.github.com/packages stable InRelease
                            Hit:10 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Hit:11 https://repo.mosquitto.org/debian bookworm InRelease
                            Hit:12 https://packages.redis.io/deb bookworm InRelease
                            Get:13 https://pkgs.tailscale.com/stable/debian bookworm InRelease
                            Hit:14 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                            Fetched 6,581 B in 3s (1,994 B/s)
                            Reading package lists... Done
                            All packages are up to date.
                            echad@chet:~ $
                            Also alle bisherigen Quellen sind erreichbar und deren Schlüssel liegen sauber an Ort und Stelle und es werden auch keine sonstigen Fehler gemeldet.
                            Jetzt kann man hingehen, und das Ruder in Richtung Debian 13 'Trixie' drehen:
                            sudo sed -i 's/bookworm/trixie/g' /etc/apt/sources.list
                            sudo sed -i 's/bookworm/trixie/g' /etc/apt/sources.list.d/*
                            Mit
                            sudo apt update
                            ziehen wir die neuen Quellen heran. Sollte dann wie zuvor aussehen, nur das nur statt wie bisher bookworm halt der neue Releasename trixie auftaucht:
                            Hit:1 http://deb.debian.org/debian trixie InRelease
                            Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
                            Hit:3 https://cli.github.com/packages stable InRelease
                            Hit:4 http://deb.debian.org/debian trixie-updates InRelease
                            Hit:5 https://apt.grafana.com stable InRelease
                            Hit:6 https://repos.influxdata.com/debian stable InRelease
                            Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Hit:8 http://archive.raspberrypi.com/debian trixie InRelease
                            Get:9 https://pkgs.tailscale.com/stable/debian trixie InRelease
                            Hit:10 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
                            Fetched 6,579 B in 2s (2,850 B/s)
                            721 packages can be upgraded. Run 'apt list --upgradable' to see them.
                            (Einige Quellen von Dritten waren noch nicht auf trixie umgestellt, weswegen ich diese für dieses HowTo 'auf Eis gelegt' habe. Das sollte aber bis zum offiziellen Release im Sommer 2025 auch für diese Repos erfolgt sein)
                            Wenn da noch was anderes als 'trixie', 'stable' oder im Fall von nodesource 'nodistro' auftaucht muss man diese Quelle noch anpassen oder auch deaktivieren. Die zugehörige .list-Datei wird im Verzeichnis /etc/apt/sources.list.d/ liegen.
                            Nach dem erfolgten Update kann eine Meldung wie
                            Warning: https://deb.nodesource.com/node_20.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details auftauchen. Die kann momentan ignoriert werden.
                            Mit
                            sudo apt -o APT::Get::Trivial-Only=true full-upgrade
                            macht man einen Trockenlauf und schaut, wie viel Platz das neue System zusätzlich braucht und ob auf dem Datenträger noch genügend vorhanden ist. Bei mir ist alles in Ordnung:
                            721 upgraded, 173 newly installed, 56 to remove and 0 not upgraded.
                            Need to get 757 MB of archives.
                            After this operation, 770 MB of additional disk space will be used.
                            Wenn zu wenig Platz vorhanden ist meldet sich das System:
                            E: You don't have enough free space in /var/cache/apt/archives/.
                            Zuvor ist es eine gute Idee, alles unnötige zu beenden. Den ioBroker würde ich also schon mal per
                            iob stop
                            aus dem Verkehr ziehen. Gleiches gilt auch unbedingt für mariadb. Auch stoppen!
                            sudo service mariadb stop
                            Das Update macht man in zwei Schritten. Zunächst nur die bereits installierten Pakete:
                            sudo apt upgrade --without-new-pkgs
                            Wenn das durchgelaufen ist zieht man den Rest dann per
                            nach.
                            Irgendwann wird eine ChangeList erscheinen, die kann man mit q verlassen.
                            Die darauf folgende Frage, ob Services ungefragt neugestartet werden sollen beantworte ich auf meinem System mit <YES>
                            Wenn in der Folge config-Dateien angezeigt werden, die nun in der neuen Version andere Einträge haben, dann bitte anschauen und überlegen, ob da nicht die eigenen Einträge bebeihalten werden. War auf meinem System bei dem nut-Server der Fall. Da habe ich natürlich die Einstellungen für meine USV z. B. beibehalten.
                            Das Spiel mit
                            sudo apt update
                            wiederholt man solange, bis gemeldet wird:
                            Dann einmal das ganze Spiel neustarten:
                            sudo reboot
                            und man sollte dann z. B. in
                            iob diag
                            sehen, das man nun auf Debian 13 'Trixie' herumturnt:
                            *** BASE SYSTEM ***
                             Static hostname: chet
                                   Icon name: computer
                            Operating System: Debian GNU/Linux 13 (trixie)
                                      Kernel: Linux 6.12.25+rpt-rpi-v8
                                Architecture: arm64
                            OS is similar to:
                            Model           : Raspberry Pi 4 Model B Rev 1.4
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             21:55:13 up 15 min,  1 user,  load average: 1.66, 1.17, 1.04
                            CPU threads: 4
                            *** LIFE CYCLE STATUS ***
                            Operating System codenamed 'trixie' is a testing release! Please use it only for testing purposes!
                            Nachbereitung:
                            Mit
                            apt list '~c'
                            kann man schauen, ob es noch Überreste von alten Paketen gibt, die im Zuge des Upgrades entfernt wurden.
                            Diese kann man per
                            sudo apt purge '~c'
                            noch runterwerfen.
                            Ähnliches macht man mit veralteten und lokal erzeugten Pakten nach Möglichkeit.
                            apt list '~o'
                            sudo apt purge '~o'
                            sudo apt --purge autoremove
                            sudo apt autoclean
                            Zur Zeit noch optional ist die Umstellung auf das neue Format für die Paketquellen:
                            sudo apt modernize-sources
                            Falls Quellen aus dritter Hand verwendet werden manche davon umgestellt werden können, bei anderen wird Handarbeit angesagt sein. Die Umstellung kann durch die Eingabe von N simuliert werden.
                            Bei der Umstellung wird die ursprüngliche sources.list in das neue Format unter sources.list.d überführt. Die dort liegenden Dateien enden nicht mehr auf .list, sondern auf .sources.
                            Noch viel mehr Informationen finden sich hier:
                            https://www.debian.org/releases/trixie/release-notes/upgrading.de.html#
                            Insbesondere bei Fehlern oder einer anderen Ausgangslage finden sich dort wichtige Hinweise zum Upgrade.
                            David G.D Online
                            David G.D Online
                            David G.
                            #190
                            Ich habe mal eine Frage zu den gepinnten Paketen.
                            Warum aktualisiert man diese nicht vor dem Update auf Trixie sondern erst während dessen?
                            • David G.D David G.
                              #191
                              @david-g sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                              Weil es keinen Unterschied macht. Du lässt die ja wieder freilaufen beim Upgrade. Sollten ja auch nicht viele sein.
                                David G.D Online
                                David G.D Online
                                David G.
                                #192
                                Danke.
                                Hatte bisher nie welche.
                                Hab mittlerweile alle Rechner upgedatet.
                                Auf der Arbeit habe ich noch einige.
                                Dafür hab ich mir grad ein kleines Script geschrieben, dabei hab ich mir die Frage grad gestellt.
                                • G Offline
                                  guitardoc
                                  schrieb am zuletzt editiert von guitardoc
                                  #193
                                  Ich habe jetzt auch den Schritt gewagt und auf Trixie aufgesprungen. Und wie viele andere auch habe ich die Warnung drin:
                                  mn@iobroker:~$ sudo apt update --audit
                                  Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                                  Hit:3 http://security.debian.org trixie-security InRelease
                                  Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                  Warning: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                                  Audit: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is:
                                     Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:
                                                No binding signature at time 2025-10-28T19:21:53Z
                                       because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance
                                       because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                                  mn@iobroker:~$
                                  Interessanterweise ist die oben mal angeführte /etc/apt/sources.list.d/raspi.sources bei mir leer. Der Keyring scheint auch nicht installiert zu sein:
                                  mn@iobroker:~$ apt policy raspberrypi-archive-keyring
                                  Notice: Unable to locate package raspberrypi-archive-keyring
                                  mn@iobroker:~$
                                  Die Ausgabe von iob diag liefert:
                                  ```bash
                                  Script v.2025-08-09
                                  *** BASE SYSTEM ***
                                   Static hostname: iobroker
                                         Icon name: computer-container
                                           Chassis: container ☐
                                    Virtualization: lxc
                                            Kernel: Linux 6.14.11-4-pve
                                      Architecture: x86-64
                                  OS is similar to:
                                  model name	: Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
                                  Docker          : false
                                  Virtualization  : lxc
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                   16:07:46 up 25 min,  1 user,  load average: 0.60, 0.75, 1.01
                                  CPU threads: 2
                                  Operating System is the current Debian stable version codenamed 'trixie'!
                                  *** TIME AND TIMEZONES ***
                                                 Local time: Wed 2025-10-29 16:07:47 CET
                                             Universal time: Wed 2025-10-29 15:07:47 UTC
                                                   RTC time: n/a
                                                NTP service: inactive
                                            RTC in local TZ: no
                                  *** Users and Groups ***
                                  User that called 'iob diag':
                                  mn
                                  HOME=/home/mn
                                  GROUPS=mn adm dialout sudo users iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  SUDO_HOME=/home/mn
                                  GROUPS=iobroker tty dialout audio video plugdev
                                  *** DISPLAY-SERVER SETUP ***
                                  Display-Server: 	false
                                  Unit display-manager.service could not be found.
                                  Display-Manager:
                                  Desktop:
                                  Session: 		tty
                                  *** MEMORY ***
                                  Mem:             12G        3.6G        8.4G        573K        897M        9.3G
                                  Swap:           536M          0B        536M
                                  Total:           13G        3.6G        8.9G
                                  Active iob-Instances: 	33
                                          12288 M total memory
                                           3466 M used memory
                                           3530 M active memory
                                            635 M inactive memory
                                           7965 M free memory
                                              0 M buffer memory
                                            856 M swap cache
                                            512 M total swap
                                              0 M used swap
                                            512 M free swap
                                  top - 16:07:47 up 25 min,  1 user,  load average: 0.60, 0.75, 1.01
                                  Tasks:  65 total,   1 running,  64 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  5.0 us,  0.0 sy,  0.0 ni, 95.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :  12288.0 total,   7965.6 free,   3466.5 used,    856.3 buff/cache
                                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   8821.5 avail Mem
                                  *** FAILED SERVICES ***
                                    UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                                  * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                                  * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                                  Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                          ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                          SUB    -> The low-level unit activation state, values depend on unit type.
                                  2 loaded units listed.
                                  *** DMESG CRITICAL ERRORS ***
                                  dmesg: read kernel buffer failed: Operation not permitted
                                  No critical errors detected
                                  *** FILESYSTEM ***
                                  Filesystem                       Type      Size  Used Avail Use% Mounted on
                                  /dev/mapper/pve-vm--100--disk--0 ext4       63G   25G   36G  41% /
                                  none                             tmpfs     492K  4.0K  488K   1% /dev
                                  /dev/mapper/pve-root             ext4       94G   14G   76G  16% /dev/ttyACM0
                                  udev                             devtmpfs   32G     0   32G   0% /dev/tty
                                  tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
                                  tmpfs                            tmpfs      13G  136K   13G   1% /run
                                  tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                                  tmpfs                            tmpfs      32G  412K   32G   1% /tmp
                                  tmpfs                            tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
                                  Show mounted filesystems:
                                  TARGET         SOURCE                                                 FSTYPE OPTIONS
                                  /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
                                  `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/101/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
                                  /var:
                                  8.3G	/var/
                                  7.2G	/var/lib
                                  7.0G	/var/lib/mysql
                                  6.9G	/var/lib/mysql/DBioBroker
                                  935M	/var/log
                                  Archived and active journals take up 932M in the file system.
                                  /opt/iobroker/backups:
                                  8.6G	/opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  785M	/opt/iobroker/iobroker-data/
                                  498M	/opt/iobroker/iobroker-data/files
                                  152M	/opt/iobroker/iobroker-data/backup-objects
                                  92M	/opt/iobroker/iobroker-data/files/vis-2
                                  67M	/opt/iobroker/iobroker-data/files/echarts.admin
                                  114M	/opt/iobroker/iobroker-data/objects.jsonl
                                  30M	/opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
                                  26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                                  26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                                  24M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                                  USB-Devices by-id:
                                  /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00
                                  *** ZigBee Settings ***
                                  HINT:
                                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                  /dev/ttyACM0
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs 	v22.21.1
                                  /usr/bin/node 		v22.21.1
                                  /usr/bin/npm 		10.9.4
                                  /usr/bin/npx 		10.9.4
                                  /usr/bin/corepack 	0.34.0
                                  nodejs:
                                    Installed: 22.21.1-1nodesource1
                                    Candidate: 22.21.1-1nodesource1
                                    Version table:
                                   *** 22.21.1-1nodesource1 1001
                                       22.21.0-1nodesource1 1001
                                       22.20.0-1nodesource1 1001
                                       22.19.0-1nodesource1 1001
                                       22.18.0-1nodesource1 1001
                                       22.17.1-1nodesource1 1001
                                       22.17.0-1nodesource1 1001
                                       22.16.0-1nodesource1 1001
                                       22.15.1-1nodesource1 1001
                                       22.15.0-1nodesource1 1001
                                       22.14.0-1nodesource1 1001
                                       22.13.1-1nodesource1 1001
                                       22.13.0-1nodesource1 1001
                                       22.12.0-1nodesource1 1001
                                       22.11.0-1nodesource1 1001
                                       22.10.0-1nodesource1 1001
                                       22.9.0-1nodesource1 1001
                                       22.8.0-1nodesource1 1001
                                       22.7.0-1nodesource1 1001
                                       22.6.0-1nodesource1 1001
                                       22.5.1-1nodesource1 1001
                                       22.5.0-1nodesource1 1001
                                       22.4.1-1nodesource1 1001
                                       22.4.0-1nodesource1 1001
                                       22.3.0-1nodesource1 1001
                                       22.2.0-1nodesource1 1001
                                       22.1.0-1nodesource1 1001
                                       22.0.0-1nodesource1 1001
                                       20.19.2+dfsg-1 500
                                          500 http://deb.debian.org/debian trixie/main amd64 Packages
                                  No problems detected
                                  Errors in npm tree: 0
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 1560)
                                  Core adapters versions
                                  js-controller: 	7.0.7
                                  admin: 		7.7.2
                                  javascript: 	8.9.2
                                  nodejs modules from github: 	0
                                  Adapter State
                                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                  + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                  + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                                  + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
                                    system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                  + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
                                  + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                                  + system.adapter.hydrawise.0              : hydrawise             : iobroker                                 -  enabled
                                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                  + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
                                  + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                                  + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                                  + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : iobroker                                 -  enabled, port: 16021
                                  + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                                  + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                                  + system.adapter.shuttercontrol.1         : shuttercontrol        : iobroker                                 -  enabled
                                  + system.adapter.shuttercontrol.2         : shuttercontrol        : iobroker                                 -  enabled
                                    system.adapter.solaredge.0              : solaredge             : iobroker                                 -  enabled
                                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1888, bind: 0.0.0.0
                                  + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                    system.adapter.uv-protect.0             : uv-protect            : iobroker                                 -  enabled
                                  + system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
                                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                                  + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                                    system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                  + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                                    system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                                  + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                                  + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                                  + instance is alive
                                  ioBroker-Repositories
                                  │ (index) │ name          │ url                                                      │ auto upgrade │
                                  │ 0       │ 'stable'      │ 'https://download.iobroker.net/sources-dist.json'        │ false        │
                                  │ 1       │ 'beta'        │ 'https://download.iobroker.net/sources-dist-latest.json' │ false        │
                                  │ 2       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'            │ false        │
                                  │ 3       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'     │ false        │
                                  Active repo(s): stable
                                  Upgrade policy: none
                                  Installed ioBroker-Adapters
                                  Used repository: stable
                                  Adapter    "admin"        : 7.7.2    , installed 7.7.2
                                  Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                                  Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                                  Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                  Adapter    "eusec"        : 1.3.3    , installed 2.0.3
                                  Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                                  Adapter    "followthesun" : 0.5.2    , installed 0.5.2
                                  Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
                                  Adapter    "hydrawise"    : 1.0.2    , installed 1.0.2
                                  Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                                  Controller "js-controller": 7.0.7    , installed 7.0.7
                                  Adapter    "logparser"    : 2.4.0    , installed 2.4.0
                                  Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                                  Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
                                  Adapter    "notification-manager": 1.3.0, installed 1.3.0
                                  Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
                                  Adapter    "shelly"       : 10.2.0   , installed 10.2.0
                                  Adapter    "shuttercontrol": 2.0.5   , installed 2.0.5
                                  Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
                                  Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                                  Adapter    "sql"          : 3.0.1    , installed 3.0.1
                                  Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                  Adapter    "uv-protect"   : 0.6.8    , installed 0.6.8
                                  Adapter    "viessmannapi" : 2.3.0    , installed 2.4.3
                                  Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                                  Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                                  Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                                  Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                  Adapter    "web"          : 7.0.8    , installed 7.0.8
                                  Adapter    "yahka"        : 1.1.5    , installed 1.1.5
                                  Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
                                  Objects and States
                                  Objects: 	68545
                                  States: 	55952
                                  W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                                  Hit:2 http://security.debian.org trixie-security InRelease
                                  Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       115012421  666/io.shelly.1
                                  tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1000       115012240  624/io.mqtt.0
                                  tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       115012239  624/io.mqtt.0
                                  tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1000       115018118  767/io.sonoff.0
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          115007612  1/init
                                  tcp        0      0 127.0.0.1:39081         0.0.0.0:*               LISTEN      1000       115017176  736/io.yahka.0
                                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          115009868  349/master
                                  tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      105        115007110  236/mariadbd
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       115010141  141/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       115010146  141/iobroker.js-con
                                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          115009869  349/master
                                  tcp6       0      0 :::1984                 :::*                    LISTEN      1000       115023888  982/go2rtc
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          115007940  1/init
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          115007614  1/init
                                  tcp6       0      0 :::33743                :::*                    LISTEN      1000       115017158  736/io.yahka.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       115022041  861/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       115010488  435/io.admin.0
                                  tcp6       0      0 :::8555                 :::*                    LISTEN      1000       115023882  982/go2rtc
                                  tcp6       0      0 :::8554                 :::*                    LISTEN      1000       115023880  982/go2rtc
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          115007613  1/init
                                  udp        0      0 0.0.0.0:34140           0.0.0.0:*                           1000       115022091  802/io.eusec.0
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       115022502  1029/io.nanoleaf-li
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       115017163  736/io.yahka.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       115017162  736/io.yahka.0
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       115016741  655/io.shelly.0
                                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       115018462  712/io.tuya.0
                                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       115018463  712/io.tuya.0
                                  udp        0      0 0.0.0.0:49656           0.0.0.0:*                           1000       115022096  802/io.eusec.0
                                  udp6       0      0 :::111                  :::*                                0          115007615  1/init
                                  udp6       0      0 :::8555                 :::*                                1000       115023883  982/go2rtc
                                  2025-10-29 15:45:05.269  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-78ee4cc4e244"
                                  2025-10-29 15:45:05.269  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-78ee4cc4e604"
                                  2025-10-29 15:45:05.269  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-2cbcbb3e9980"
                                  2025-10-29 15:45:05.269  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-c82e189590d4"
                                  2025-10-29 15:45:05.269  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-345f4520313c"
                                  2025-10-29 15:45:05.273  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0dd6c4821e4"
                                  2025-10-29 15:45:05.274  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-ccdba7d035a4"
                                  2025-10-29 15:45:05.281  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-c82e189590d4"
                                  2025-10-29 15:45:05.281  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus1-30c9224c881c"
                                  2025-10-29 15:45:05.281  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a0dd6c312c40"
                                  2025-10-29 15:45:05.285  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0dd6c27921c"
                                  2025-10-29 15:45:05.285  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-c049ef89564c"
                                  2025-10-29 15:45:05.285  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-c049ef8b45c0"
                                  2025-10-29 15:45:05.285  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a898d30"
                                  2025-10-29 15:45:05.285  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0dd6c49bba4"
                                  2025-10-29 15:45:05.285  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-ccdba7d035a4"
                                  2025-10-29 15:45:05.286  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-10061ccac808"
                                  2025-10-29 15:45:05.286  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus1-b0a7324d7b7c"
                                  2025-10-29 15:45:05.286  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-2cbcbb3e7f48"
                                  2025-10-29 15:45:05.286  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-c049ef8b45c0"
                                  2025-10-29 15:45:05.289  - error: shelly.1 (666) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-78ee4cc4e604"
                                  2025-10-29 15:45:36.488  - info: cloud.0 (576) Trying to connect as system.user.admin to cloud
                                  2025-10-29 15:45:36.606  - info: cloud.0 (576) Connection changed: connect
                                  2025-10-29 16:06:05.901  - error: sql.0 (518) Cannot insert INSERT INTO `DBioBroker`.ts_number (id, ts, val, ack, _from, q) VALUES (41, 1761750365856, 0.5776, 1, 7, 0);: Error: Duplicate entry '41-1761750365856' for key 'PRIMARY' (id: alias.0.Solaranlage.DC-Leistungswert)
                                  Der ioBroker scheint aber richtig zu laufen, zumindest sind alle Instanzen grün und unerwartete Fehlermeldungen hab ich bisher auch nicht entdecken können. Muss ich mir da irgendwie Gedanken machen oder geht das von "allein" irgendwie weg?
                                  • G guitardoc
                                    mn@iobroker:~$
                                    mn@iobroker:~$
                                    ```bash
                                    Script v.2025-08-09
                                    *** BASE SYSTEM ***
                                      Virtualization: lxc
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                    CPU threads: 2
                                                     RTC time: n/a
                                              RTC in local TZ: no
                                    mn
                                    HOME=/home/mn
                                    iobroker
                                    HOME=/home/iobroker
                                    SUDO_HOME=/home/mn
                                    Display-Manager:
                                    Desktop:
                                    Session: 		tty
                                    *** MEMORY ***
                                    Swap:           536M          0B        536M
                                             3466 M used memory
                                             7965 M free memory
                                                0 M buffer memory
                                              856 M swap cache
                                              512 M total swap
                                                0 M used swap
                                              512 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    8.3G	/var/
                                    7.2G	/var/lib
                                    7.0G	/var/lib/mysql
                                    935M	/var/log
                                    USB-Devices by-id:
                                    HINT:
                                    /dev/ttyACM0
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm 		10.9.4
                                    /usr/bin/npx 		10.9.4
                                    nodejs:
                                      Version table:
                                         20.19.2+dfsg-1 500
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin: 		7.7.2
                                    javascript: 	8.9.2
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects: 	68545
                                    States: 	55952
                                    Pending Updates: 0
                                    #194
                                    @guitardoc
                                    Die erste Meldung bezieht sich auf den Schlüssel von nodesource, der ist noch in einem alten Format.
                                    Die Meldung geht weg, wenn du den irgendwann veröffentlichten Schlüssel einspielst.
                                    Die ist solange leer bzw. gar nicht vorhanden, bis du da aktiv auf das jetzt neue Format umstellst. Kannste machen, musste aber noch nicht. Es sollte aber die Vorgängerdatei 'raspi.list' geben.
                                    Edit: Du hast doch gar kein RaspberryOS da am Start...
                                    Dann gibt es natürlich auch diese Distro-spezifischen Quellen nicht.
                                    G 1 Antwort Letzte Antwort
                                      @guitardoc
                                      guitardoc
                                      #195
                                      @thomas-braun Ahhh - die Anleitung war nur für Raspi-OS... Ich hab den ioB in einem LXC auf einem Proxmox laufen. Hmm, was mache ich denn da nun wegen der Fehlermeldung?
                                      • G guitardoc
                                        #196
                                        @guitardoc
                                        Nein, die 'Anleitung' ist generell für ein Inline-Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'.
                                        RaspberryOS setzt jeweils zu weiten Teilen auf dieser Basis auf, sodass die generelle Vorgehensweise da zu 99% gleich ist.
                                        Wegen der 'Fehlermeldung': Abwarten, bis nodesource endlich mal einen aktuellen Schlüssel veröffentlicht, den dann einbinden und die 'Fehlermeldung' ist weg.
                                          @guitardoc
                                          guitardoc
                                          #197
                                          @thomas-braun Ahh, danke für die Info. Kommt dieser Schlüssel bei Veröffentlichung irgendwie per apt auf das System oder muss ich selbst aktiv auf die Suche gehen, wann der wo veröffentlicht wird? Weißt du das?
