  3. Einsteigerfragen
  4. Updaten von Debian Buster 10 auf Bookworm 12
    2.3k
    4.2k
31 Beiträge 9 Kommentatoren 2.2k Aufrufe 7 Beobachtet
    @markus-frankl
    Zeig mal den Output von
    iob diag
    Markus Frankl
    Linux iobroker 4.19.0-27-amd64 #1 SMP Debian 4.19.316-1 (2024-06-25) x86_64
    permitted by applicable law.
    Last login: Mon Oct 20 22:19:50 2025 from 192.168.178.64
    markus@iobroker:~$ iob diag
    [sudo] Passwort für markus:
    *** iob diag is starting up, please wait ***
    iob diag needs to be updated. Please execute 'iobroker fix' first.
    /home/iobroker/.diag.sh: line 72: debian-distro-info: command not found
    /home/iobroker/.diag.sh: line 73: ubuntu-distro-info: command not found
    /home/iobroker/.diag.sh: line 74: debian-distro-info: command not found
    /home/iobroker/.diag.sh: line 75: ubuntu-distro-info: command not found
    /home/iobroker/.diag.sh: line 76: ubuntu-distro-info: command not found
    /home/iobroker/.diag.sh: line 77: debian-distro-info: command not found
    /home/iobroker/.diag.sh: line 78: debian-distro-info: command not found
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    * Some output is masked. For full results please use 'iob diag --unmask' *
    Press any key to continue
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 10 (buster)
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
                Kernel: Linux 4.19.0-27-amd64
          Architecture: x86-64
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     22:53:37 up  7:59,  1 user,  load average: 0.25, 0.33, 0.30
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed 'buster'. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-10-20 22:53:37 CEST
               Universal time: Mon 2025-10-20 20:53:37 UTC
                     RTC time: Mon 2025-10-20 20:53:38
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    markus
    HOME=/home/markus
    GROUPS=markus cdrom floppy audio dip video plugdev netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:           9.8G        3.6G        5.0G        8.0M        1.1G        5.8G
    Swap:          4.0G          0B        4.0G
    Total:          13G        3.6G        9.0G
    Active iob-Instances:   49
             9756 M total memory
             3639 M used memory
             3879 M active memory
              499 M inactive memory
             5044 M free memory
              195 M buffer memory
              877 M swap cache
             3996 M total swap
                0 M used swap
             3996 M free swap
    top - 22:53:38 up  7:59,  1 user,  load average: 0.25, 0.33, 0.30
    Tasks: 149 total,   1 running, 148 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 10.0 us,  1.7 sy,  0.0 ni, 88.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   9756.4 total,   5038.5 free,   3645.3 used,   1072.7 buff/cache
    MiB Swap:   3997.0 total,   3997.0 free,      0.0 used.   5821.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  4.8G     0  4.8G   0% /dev
    tmpfs          tmpfs     976M  8.5M  968M   1% /run
    /dev/sda1      ext4       28G   14G   13G  51% /
    tmpfs          tmpfs     4.8G     0  4.8G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     4.8G     0  4.8G   0% /sys/fs/cgroup
    tmpfs          tmpfs     976M     0  976M   0% /run/user/1000
    [Mon Oct 20 14:54:25 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Oct 20 14:54:26 2025] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems:
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
    `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    /var:
    661M    /var/
    469M    /var/cache
    462M    /var/cache/apt
    401M    /var/cache/apt/archives
    162M    /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    No journal files were opened due to insufficient permissions.
    /opt/iobroker/backups:
    2.4G    /opt/iobroker/backups/
    436K    /opt/iobroker/backups/scripte
    432K    /opt/iobroker/backups/scripte/common
    316K    /opt/iobroker/backups/scripte/common/Blockly
    112K    /opt/iobroker/backups/scripte/common/Javascript
    /opt/iobroker/iobroker-data:
    727M    /opt/iobroker/iobroker-data/
    290M    /opt/iobroker/iobroker-data/files
    262M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    66M     /opt/iobroker/iobroker-data/states.jsonl
    48M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    18M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    nodejs:
      Installed: 20.16.0-1nodesource1
      Candidate: 20.19.5-1nodesource1
      Version table:
         20.19.5-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
     *** 20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u4 500
            500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://ftp.de.debian.org/debian buster/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    The current Node.js version (v20.16.0) is vulnerable to the following CVEs:
    CVE-2025-23083(high): With the aid of the diagnostics_channel utility, an event can be hooked into whenever a worker thread is created. This is not limited only to workers but also exposes internal workers, where an instance of them can be fetched, and its constructor can be grabbed and reinstated for malicious usage.
    This vulnerability affects Permission Model users (--permission) on Node.js v20, v22, and v23.
    Patched versions: ^20.18.2 || ^22.13.1 || ^23.6.1
    CVE-2025-23085(medium): A memory leak could occur when a remote peer abruptly closes the socket without sending a GOAWAY notification. Additionally, if an invalid header was detected by nghttp2, causing the connection to be terminated by the peer, the same leak was triggered. This flaw could lead to increased memory consumption and potential denial of service under certain conditions.
    This vulnerability affects HTTP/2 Server users on Node.js v18.x, v20.x, v22.x and v23.x.
    Patched versions: ^18.20.6 || ^20.18.2 || ^22.13.1 || ^23.6.1
    CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
    Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
    CVE-2025-23167(medium): A flaw in Node.js 20's HTTP parser allows improper termination of HTTP/1 headers using `\r\n\rX` instead of the required `\r\n\r\n`.
    This inconsistency enables request smuggling, allowing attackers to bypass proxy-based access controls and submit unauthorized requests.
    The issue was resolved by upgrading `llhttp` to version 9, which enforces correct header termination.
    Impact:
    * This vulnerability affects only Node.js 20.x users prior to the `llhttp` v9 upgrade.
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 7502)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.7.2
    javascript:     8.9.2
    nodejs modules from github:     5
    +-- iobroker.alexa-shoppinglist@1.1.0 (git+ssh://git@github.com/MiRo1310/ioBroker.alexa-shoppinglist.git#30ebd89f701179b790dce4705c6e7a943039f6e1)
    +-- iobroker.fully-tablet-control@0.3.8 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#466a9f2565ccaa05fb5536b16a9c46b9d5f76e8a)
    +-- iobroker.homepilot20@0.0.72 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#3706cca661f6ac97f7b2d0a77043b9a79eb2847f)
    +-- iobroker.tesla-motors@1.4.5 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.tesla-motors.git#9325aa23185511923c353bc04c01781057e4f016)
    +-- iobroker.vw-connect@0.6.1 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#309769f6889c08b0789f21d327b98743f7147d3d)
    Adapter State
    + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
    + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : iobroker                                 -  enabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.binance.0                : binance               : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
      system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
    + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
    + system.adapter.homepilot20.0            : homepilot20           : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lametric.0               : lametric              : iobroker                                 -  enabled
    + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      system.adapter.ring.0                   : ring                  : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
    + system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.tesla-motors.0           : tesla-motors          : iobroker                                 -  enabled
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ ''                 │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alarm"        : 3.7.4    , installed 3.7.4
    Adapter    "alexa-shoppinglist": 1.1.0, installed 1.1.0
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.13.1  , installed 2.13.1
    Adapter    "ems-esp"      : 6.0.0    , installed 6.0.0
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.17.0   , installed 1.17.0
    Adapter    "iot"          : 3.3.0    , installed 4.1.10
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
    Adapter    "lametric"     : 4.1.0    , installed 4.1.0
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "ring"         : 6.4.0    , installed 6.3.0  [Updatable]
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 10.2.0   , installed 10.2.0
    Adapter    "shuttercontrol": 2.0.5   , installed 2.0.5
    Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
    Adapter    "tado"         : 0.8.0    , installed 0.8.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
    Adapter    "telegram-menu": 2.4.4    , installed 2.4.4
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tesla-motors" : 1.3.2    , installed 1.4.5
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
    Objects and States
    Objects:        34426
    States:         28275
    E: The repository 'http://security.debian.org/debian-security buster/updates Release' no longer has a Release file.
    E: The repository 'http://ftp.de.debian.org/debian buster Release' no longer has a Release file.
    E: The repository 'http://ftp.de.debian.org/debian buster-updates Release' no longer has a Release file.
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       468612     15071/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       469107     15071/iobroker.js-c
    tcp        0      0 127.0.0.1:42411         0.0.0.0:*               LISTEN      1001       635203     15464/io.yahka.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1351       1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14595      549/sshd
    tcp6       0      0 :::37761                :::*                    LISTEN      1001       471037     15464/io.yahka.0
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       464592     15286/io.harmony.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          11551      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       469142     15089/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       473592     16297/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       472918     16436/io.socketio.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       502594     17128/io.nuki-exten
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14597      549/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       475918     16267/io.simple-api
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       472570     16158/io.terminal.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       466493     15241/io.deconz.0
    udp        0      0 0.0.0.0:60067           0.0.0.0:*                           108        12221      399/avahi-daemon: r
    udp        0      0 0.0.0.0:53420           0.0.0.0:*                           1001       469826     15662/io.mihome-vac
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       466930     15515/io.mihome-vac
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       464593     15286/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       472805     16359/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       471042     15464/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       471041     15464/io.yahka.0
    udp        0      0 192.168.178.97:5353     0.0.0.0:*                           1001       470408     15346/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12219      399/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       466536     15271/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       473093     15530/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       473094     15530/io.tuya.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13260      331/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10372      1/init
    udp6       0      0 :::1900                 :::*                                1001       466496     15241/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       466495     15241/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       466494     15241/io.deconz.0
    udp6       0      0 :::5353                 :::*                                108        12220      399/avahi-daemon: r
    udp6       0      0 :::38465                :::*                                108        12222      399/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          10377      1/init
    2025-10-20 22:53:06.008  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Green+Grey_NAMES_LIST has changed
    2025-10-20 22:53:06.209  - info: iqontrol.0 (16282) COMBINATION Adapter-Monitor HTML has changed
    2025-10-20 22:53:58.444  - warn: spotify-premium.0 (20742) empty playlist name
    2025-10-20 22:53:58.444  - error: spotify-premium.0 (20742) playlist error empty playlist name
    2025-10-20 22:54:00.006  - info: spotify-premium.0 (20742) Scheduled restart.
    2025-10-20 22:54:00.490  - info: spotify-premium.0 (20742) terminating
    2025-10-20 22:54:00.491  - info: spotify-premium.0 (20742) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2025-10-20 22:54:00.581  - info: spotify-premium.0 (20742) terminating
    2025-10-20 22:54:00.825  - info: iqontrol.0 (16282) COUNTER Adapter-Monitor Red: 2 of 49
    2025-10-20 22:54:01.026  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Red+Yellow has changed
    2025-10-20 22:54:01.027  - info: iqontrol.0 (16282) COMBINATION Adapter-Monitor HTML has changed
    2025-10-20 22:54:01.033  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Red+Yellow_LIST has changed
    2025-10-20 22:54:01.041  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Red+Yellow_LIST_JSON has changed
    2025-10-20 22:54:01.046  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Red+Yellow_NAMES_LIST has changed
    2025-10-20 22:54:01.155  - info: host.iobroker instance system.adapter.spotify-premium.0 scheduled normal terminated and will be restarted on schedule.
    2025-10-20 22:54:01.155  - info: host.iobroker Restart adapter system.adapter.spotify-premium.0 because enabled
    2025-10-20 22:54:01.687  - info: iqontrol.0 (16282) COUNTER Adapter-Monitor Yellow: 0 of 49
    2025-10-20 22:54:01.817  - info: iqontrol.0 (16282) COUNTER Adapter-Monitor Green: 47 of 49
    2025-10-20 22:54:02.019  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Green+Grey has changed
    2025-10-20 22:54:02.019  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Green+Grey_LIST has changed
    2025-10-20 22:54:02.021  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Green+Grey_LIST_JSON has changed
    2025-10-20 22:54:02.022  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Green+Grey_NAMES_LIST has changed
    2025-10-20 22:54:02.023  - info: iqontrol.0 (16282) COMBINATION Adapter-Monitor HTML has changed
    2025-10-20 22:54:02.226  - info: iqontrol.0 (16282) COMBINATION Adapter-Monitor HTML has changed
    2025-10-20 22:54:02.685  - info: host.iobroker instance system.adapter.spotify-premium.0 in version "1.5.2" started with pid 21248
    iob diag has finished.
    markus@iobroker:~$
    • M Markus Frankl
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
                 Chassis: vm
          Virtualization: kvm
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      markus
      HOME=/home/markus
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:          4.0G          0B        4.0G
               9756 M total memory
               3639 M used memory
               5044 M free memory
                195 M buffer memory
                877 M swap cache
               3996 M total swap
                  0 M used swap
               3996 M free swap
      *** FILESYSTEM ***
      /var:
      661M    /var/
      469M    /var/cache
      462M    /var/cache/apt
      162M    /var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      nodejs:
        Version table:
      Impact:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.2
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        34426
      States:         28275
      Pending Updates: 1
      markus@iobroker:~$
      @markus-frankl
      Die ganzen Meldungen zu fehlenden Updates usw. siehste hoffentlich selber.
      • CodierknechtC Codierknecht
        Wenn Du da schon neu aufsetzen musst: Warum eine VM und kein LXC?
        Die sind deutlich schlanker, gehen sparsamer mit den Ressourcen um und starten schneller.
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        Most Active Forum Testing
        @codierknecht sagte in Updaten von Debian Buster 10 auf Bookworm 12:
        LXC? Wird das noch supported? Du meinst doch bestimmt LXD, oder?
        • ArmilarA Armilar
          TT-Tom
          @armilar
          man spricht auch in der 9 Version noch vom LXC Container.
          Gruß Tom
          Public Transport
          NSPanel Adapter Wiki
          • T TT-Tom
            @armilar
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            @tt-tom
            Dann ist das noch nicht gänzlich gestorben... QNAP hat da schon komplett auf LXD Container umgestellt, unterstützt allerdings noch laufende LXC Container
              @markus-frankl
              Markus Frankl
              @thomas-braun ja, Das ich zu spät dran bin weiß ich auch selbst.
              Aus diesem Grund ja hier auch die Frage wie am besten durchführen.
              Wenn ich jetzt jammern würde, würde ich deine Reaktion ja wohl verstehen… Aber ich wollte einfach nur wissen, was nach eurer Sicht die beste Vorgehensweise wäre…
              Hätte ja auch sein können, dass es sich trotzdem einfach hochziehen lässt.
              • M Markus Frankl
                @markus-frankl
                Welche Reaktion bekrittelst du?
                Ich wollte die Ausgabe von iob diag sehen, damit man bewerten kann ob es 'trotzdem einfach hochzuziehen' ist.
                  @markus-frankl
                  Markus Frankl
                  Alles gut. Lassen wir das nicht in eine Wortklauberei ausarten.
                  Ich weiß was zu tun ist und hab auch gelernt öfter mal das Betriebssystem zu checken und ggf hochzuziehen.
                  Da bin ich halt Apple verwöhnt… das sagt mir halt wenn es Zeit is zu updaten. Wenn man eben wenig mit Linux macht, kann sowas halt auch mal passieren.
                  • M Markus Frankl
                    @markus-frankl
                    Das ist die Freiheit von Linux (hier Debian). Das bevormundet dich nicht, weil du ja weißt was du wann zu tun hast.
                    Bei anderen Distributionen sagt die Kiste dir auch Bescheid, wenn der Support aus läuft, bzw. wenn ein neues Release verfügbar ist. Schnubbibuntu macht das soweit ich weiß auf den Desktop-Versionen.
                    Debian (und insbesondere im Serverbetrieb) geht davon aus, das der Administrator so sattelfest ist, das er die Supportzeiträume selber im Blick hat. Gibt ja nicht ohne Grund Übersichten dafür:
                    https://wiki.debian.org/DebianReleases
                      @markus-frankl
                      Markus Frankl
                      @thomas-braun ja, das hatte ich so tatsächlich nicht auf dem Schirm. Auch die relativ kurzen Zeiträume der Versionssprünge nicht.
                      Aber man lernt ja nicht aus und dank Proxmox und Backups vom iOBroker wirds jetzt auch nicht so der Aufwand werden.
                      Vermute ich zumindest.
                      • M Markus Frankl
                        @markus-frankl sagte in Updaten von Debian Buster 10 auf Bookworm 12:
                        Immer im Sommer eines ungeraden Jahres erscheint ein neues Release. Die abgelöste Version wird dann noch ein Jahr voll unterstützt. Und innerhalb dieser 12 Monate sollte man mal ein Stündchen finden für ein Upgrade auf die dann jeweils aktuelle 'stable'. Je zeitnaher das erfolgt desto besser sind die Aussichten auf ein erfolgreiches Dist-Upgrade.
                        Wenn du da zwei Versionen auslässt wird es halt komplizierter und aufwändiger und eine Neuinstallation ist schneller, sicherer und stabiler.
                        Ob die Supportzeiträume (zu) kurz sind liegt im Auge des Betrachters. Denn eigentlich wird Debian ja immer vorgehalten, sich zu lange Zeit zu lassen. Drei Jahre voller Support sind in meinen Augen aber ein guter Kompromiss zwischen Aktualität und Stabilität.
                        AsgothianA M 2 Antworten Letzte Antwort
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @thomas-braun sagte in Updaten von Debian Buster 10 auf Bookworm 12:
                          3 Jahre ist am Ende deutlich zu wenig. Die EU fordert inzwischen 7 Jahre Support mit Sicherheitspatches bei vielen Geräten / Systemen.
                          Das in Verbindung mit der Aussage das man am besten neu installiert, anstatt ein DistUpgrade zu machen - da sind 3 Jahre support schon 'geplante Obsoleszenz'
                          A.
                          Thomas BraunT MartinPM L 3 Antworten Letzte Antwort
                          • AsgothianA Asgothian
                            A.
                            @asgothian Du kannst ja jederzeit hochziehen. Darfst halt nicht den passenden Zeitpunkt dafür verpassen. Die Karawane zieht ja nur weiter, der Support ist ja für das jeweilige stable release gewährt. Wenn du weißt was du wann tun musst/kannst dann auch über Jahre/Jahrzehnte hinweg.
                            LTS (5 Jahre) und ELTS (10 Jahre, musste allerdings dann zukaufen) gibt es ja auch noch für Debian. Nur ist das nix für Systeme, bei denen andere Software im Upstream weiterzieht. Beim ioBroker z. B. nodejs. Irgendwann können die im Upstream halt keine Rücksicht mehr auf Debian oldoldoldstable nehmen. Da wird es dann dünn, insbesondere für Leute, die 'von Linux keine Ahnung haben'.
                            Und deswegen halt die klare Empfehlung, sich mit seinen Kisten immer auf dem aktuellen stable zu bewegen.
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              Da bin ich dabei. Es ist (leider) inzwischen gängige Praxis jedes Jahr was neues zu bringen.
                              Aber ich finde es irritierend das es inzwischen als 'ok' angesehen wird das ein System nur für 2 oder 3 Jahre für einen Endnutzer stabil zu nutzen ist, und das Abwärtskompatibilität und Langzeit-Nutzbarkeit kaum noch ein Thema ist.
                              geplante Obsoleszenz halt.
                              A.
                                A.
                                @asgothian
                                Kannst ja Arch oder Gentoo Linux verwenden.
                                Aber das ist dann naturgemäß nicht 'stabil', da ändern sich "am laufenden Band" die Schnittstellen und Software die letzte Woche noch lief funktioniert plötzlich mit der gerade frisch veröffentlichten libxys nicht mehr und muss angepasst werden.
                                Das haste mit Debian 'stable' halt nicht. Einmal veröffentlicht ist hat das Ding für mindestens 3 Jahre stabile APIs.
                                Fluch und Segen zugleich. Aber halt der beste Kompromiss aus Aktualität und Stabilität. Einen Tod musste halt sterben, 'top aktuell' und 'rockstable' schließt sich aus.
                                  A.
                                  MartinPM Online
                                  MartinPM Online
                                  MartinP
                                  @asgothian sagte in Updaten von Debian Buster 10 auf Bookworm 12:
                                  A.
                                  Das ist eine falsche Interpretation dessen, was die EU verlangt.
                                  In de sieben Jahren wird Dir der Hersteller sukzessive mehrere neue Android Versionen auf Dein Smartphone spielen.
                                  Alternativ sieben Jahre immer bei der gleichen Android Version zu bleiben und nur Patches zu installieren, wird kein Hersteller zubilligen, weil es für ihn Mehraufwand bedeuten würde.
                                  Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                                    A.
                                    Labersack
                                    Ist ja nicht so, dass wie z.B. einem Handy nach 3 Jahren das Gerät nicht mehr nutzbar ist, weil vom Hersteller keine Software mit aktuellen (Sicherheits-)Funktionen mehr verfügbar ist.
                                    Es muss einfach nur eine neue Version installiert werden, wozu man eben ein klein wenig Hand anlegen muss.
                                    Das hat man bei der ersten Inbetriebnahme ja auch hinbekommen.
                                    Nichts muss weggeworfen/verschrottet/neu gekauft werden, sondern es gibt aus offziellen und gut dokumentierten Quellen eine aktuelle Software. Der Support ist weiterhin vom "Hersteller" geleistet, dem du dafür nichtmal Geld geben musstest.
                                    Von daher finde ich den Begriff 'geplante Obsoleszenz' hier nicht ganz zutreffend.
                                    • MartinPM MartinP
                                      A.
                                      @martinp sagte in Updaten von Debian Buster 10 auf Bookworm 12:
                                      Genau das bekommst du aber von Debian für 3 Jahre vollumfänglich und im Anschluss dann etwas eingeschränkt für weitere 2 Jahre. Da werden nie Versionsupgrades gefahren sondern die backporten dann lieber aufwändig nur die jeweiligen Patches. Wird mit der Zeit dann halt immer kniffeliger.
                                      • MartinPM MartinP
                                        A.
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        Bedingt. Die EU ist da relativ pragmatisch - und setzt das 'smartphone' als ein 'system' an - welches über 7 Jahre so Mit Aktualisierungen zu versehen ist das man es als Endnutzer
                                        • einfach auf Stand halten kann
                                        • durchgängig nutzen kann.
                                        Der Hersteller hat die Wahl wie er das umsetzt, da hast du recht. Aber das heisst nicht das man das gut heissen muss wenn sie den einfachsten weg gehen und die Nutzer zum komplettupdate incl. neuen Funktionen zwingen, oder ?
                                        A.
                                          Markus Frankl
                                          Hi @thomas-braun.
                                          Also komplette Neuinstallation mit Grundlage von Debian 13 auf einer neuen VM war definitiv der richtige weg.
                                          Dank dem Backit Up Adapter und Proxmox war ich in unter 2 Std. kplt. fertig mit allem.
                                          Ohne großartige Probleme. Instanz alt abgeschaltet. Instanz neu gestartet und weiter gehts. So macht das schon wirklich spaß. Jetzt teste ich mal 4-5 Tage die neue Instanz und sobald alles wirklich fehlerfrei läuft, bekommt meine SSD durch löschen der alten VM wieder gut Speicherplatz zur Verfügung.
                                          Danke für den Rat und ich werde nun aber trotz alledem gleich jedes ungerade Jahr im Frühherbst mal an ein Update denken. Sowas passiert mir nimmer 💨
                                          Danke!
