  4. RPI-Monitor und GPIO rpi2 v2.3.1
    6.4k
64 Beiträge 7 Kommentatoren 4.4k Aufrufe 6 Beobachtet
  • Torsten LehmannT Torsten Lehmann
    @thomas-braun said in RPI-Monitor und GPIO rpi2 v2.3.1:
    @torsten-lehmann sagte in RPI-Monitor und GPIO rpi2 v2.3.1:
    Irgendwie mach ich wohl was falsch bei der iobroker Installation.
    Nein, wenn Adapter via GitHub installiert werden muss die Instanz manuell hinzugefügt werden.
    da bin ich überfordert. Entschuldige, Wie mache ich das?
    Wie mache ich das?
    https://www.iobroker.net/#de/documentation/tutorial/adapter.md
    sogar mit Filmchen
    • Torsten LehmannT Offline
      Torsten Lehmann
      schrieb am zuletzt editiert von Torsten Lehmann
      @thomas-braun weiterhin viele Warn und Error.
      Notice #797?
      pi@raspberrypi:~ $ iobroker url https://github.com/Grothesk242/ioBroker.rpi2.git --host raspberrypi --debug
      install Grothesk242/ioBroker.rpi2#c87e9539d89bac8f4d19b266679bcb78ed554f1d
      NPM version: 10.9.3
      Installing Grothesk242/ioBroker.rpi2#c87e9539d89bac8f4d19b266679bcb78ed554f1d... (System call)
      npm warn skipping integrity check for git dependency ssh://git@github.com/Grothesk242/ioBroker.rpi2.git
      npm warn deprecated npmlog@4.1.2: This package is no longer supported.
      npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
      npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm warn deprecated gauge@2.7.4: This package is no longer supported.
      > iobroker.rpi2@2.4.0 preinstall
      > sudo apt-get install -y libgpiod-dev || exit 0
      Reading package lists...
      Building dependency tree...
      Reading state information...
      libgpiod-dev is already the newest version (2.2.1-2).
      The following package was automatically installed and is no longer required:
        libyuv0
      Use 'sudo apt autoremove' to remove it.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      > @stoprocent/noble@1.19.1 install
      > node-gyp-build
      gyp info it worked if it ends with ok
      gyp info using node-gyp@8.4.1
      gyp info using node@22.20.0 | linux | arm64
      (node:12953) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      (Use `node --trace-deprecation ...` to show where the warning was created)
      gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
      gyp info spawn /usr/bin/python3
      gyp info spawn args [
      gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
      gyp info spawn args   'binding.gyp',
      gyp info spawn args   '-f',
      gyp info spawn args   'make',
      gyp info spawn args   '-I',
      gyp info spawn args   '/opt/iobroker/node_modules/@stoprocent/noble/build/config.gypi',
      gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
      gyp info spawn args   '/home/iobroker/.cache/node-gyp/22.20.0/include/node/common.gypi',
      gyp info spawn args   '-Dlibrary=shared_library',
      gyp info spawn args   '-Dvisibility=default',
      gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.20.0',
      gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
      gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.20.0/<(target_arch)/node.lib',
      gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/@stoprocent/noble',
      gyp info spawn args   '-Dnode_engine=v8',
      gyp info spawn args   '--depth=.',
      gyp info spawn args   '--no-parallel',
      gyp info spawn args   '--generator-output',
      gyp info spawn args   'build',
      gyp info spawn args   '-Goutput_dir=.'
      gyp info spawn args ]
      Traceback (most recent call last):
        File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>
          import gyp  # noqa: E402
        File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>
          import gyp.input
        File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module>
          from distutils.version import StrictVersion
      ModuleNotFoundError: No module named 'distutils'
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)
      gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
      gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
      gyp ERR! System Linux 6.12.47+rpt-rpi-v8
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
      gyp ERR! node -v v22.20.0
      gyp ERR! node-gyp -v v8.4.1
      gyp ERR! not ok
      > mdns@2.7.2 install
      > node-gyp rebuild
      (node:12971) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp info spawn args   '/opt/iobroker/node_modules/mdns/build/config.gypi',
      gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/mdns',
          import gyp.input
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/mdns
      gyp ERR! not ok
      > node-dht-sensor@0.4.5 install
      > node-gyp configure
      (node:12987) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp info spawn args   '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',
      gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',
          import gyp.input
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
      gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
      gyp ERR! not ok
      > opengpio@2.0.2 install
      > node-gyp rebuild
      (node:13003) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp info spawn args   '/opt/iobroker/node_modules/opengpio/build/config.gypi',
      gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',
          import gyp.input
      gyp ERR! cwd /opt/iobroker/node_modules/opengpio
      gyp ERR! not ok
      npm error code 1
      npm error path /opt/iobroker/node_modules/opengpio
      npm error command failed
      npm error command sh -c node-gyp rebuild
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-20T11_05_16_554Z-debug-0.log
          import gyp.input
      gyp ERR! not ok
          import gyp.input
      gyp ERR! not ok
          import gyp.input
      gyp ERR! not ok
          import gyp.input
      gyp ERR! not ok
      npm error code 1
      host.raspberrypi Cannot install Grothesk242/ioBroker.rpi2#c87e9539d89bac8f4d19b266679bcb78ed554f1d: 1
        Notice #797?
        NPM version: 10.9.3
          libyuv0
        > node-gyp-build
            import gyp.input
        gyp ERR! not ok
        > mdns@2.7.2 install
        > node-gyp rebuild
            import gyp.input
        gyp ERR! not ok
        > node-gyp configure
            import gyp.input
        gyp ERR! not ok
        > node-gyp rebuild
            import gyp.input
        gyp ERR! not ok
        npm error code 1
            import gyp.input
        gyp ERR! not ok
            import gyp.input
        gyp ERR! not ok
            import gyp.input
        gyp ERR! not ok
            import gyp.input
        gyp ERR! not ok
        npm error code 1
        @torsten-lehmann
        Was haste denn jetzt geändert?
        Oben ist es doch durchgelaufen?
        Torsten LehmannT 1 Antwort Letzte Antwort
          @torsten-lehmann
          Torsten Lehmann
          @thomas-braun wenn ich ein Backup zurücksetze geht rpi2 nicht mehr zu installieren. Bin jetzt gerade soweit hab SD Karte iobroker neue aufgesetzt rpi2 Adapter und Instanz funktioniert auch. Befürchte hole ich das gespeichert Backup zurück wird rpi2 nicht mehr funktionieren.
            @torsten-lehmann
            Hast du im Backup vielleicht einen sehr alten Versionsstand eingebacken?
              @torsten-lehmann
              Torsten Lehmann
              @torsten-lehmann
              Danke für Deine Geduld, vor dem zurücksetzen des Backups hab ich opt/iobroker/node_modules/iobroker.rpi2 gesichert und nach dem zurücksetzen des Backups wieder zurück gespeichert. rpi2 v2.4.0 lebenzeichen und mit Host verbunden.
              Wenn es so bleibt, werde ich mich, um das Problem Zigbee upgrade von 2.0.5 auf 3.0.5 kümmern.
                @torsten-lehmann
                Das macht man NICHT. Außer vielleicht unter anderen Betriebssystemen, aber auch da ist das Krampf.
                  Torsten Lehmann
                  @thomas-braun dachte ich mir schon. bekomme es nicht ohne Backup hin. Viele Adapter, Skripte usw. jahrelange Arbeit.
                    @torsten-lehmann
                    Durch das wüste hin- und herkopieren zerballerst du dir die 'npm-Versionsdatenbank'.
                    Kein Wunder, das dann alles ins Schleudern gerät.
                    Wie schaut denn deine Ausgangslage aus?
                    Generelle Vorgehensweise (bei allen Sprüngen): Alt-System auf den allerletzten Stand bringen, davon ein gescheites Backup ziehen (Backitup-Adapter!), neues Betriebssystem installieren, auf den letzten Stand bringen, iobroker leer installieren, in den leeren ioBroker das Backup einspielen.
                      @torsten-lehmann
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @thomas-braun sagte in RPI-Monitor und GPIO rpi2 v2.3.1:
                      Da fehlt ein wichtiger Punkt. Da auch das auf Stand bringen schon Probleme erzeugen kann:
                      • Backup (A) ziehen (So wie das System ist)
                      • Auf den neusten möglichen Stand bringen, ohne das Betriebssystem hoch zu ziehen
                      • Backup (B) ziehen
                      • neues OS installieren
                      • IoBroker installieren
                      • Backup einspielen - wenn Möglich Backup B, im Notfall Backup A
                      A.
                      Torsten LehmannT Thomas BraunT 3 Antworten Letzte Antwort
                      • AsgothianA Asgothian
                        • Backup (B) ziehen
                        A.
                        Torsten Lehmann
                        @asgothian said in RPI-Monitor und GPIO rpi2 v2.3.1:
                        • Backup (B) ziehen
                        A.
                        okay nutze neben das iobroker backup noch ein windows tool (iobroker Tool) um ein komplettes Backup zu erstellen. erstelle neue SD mit iobroker.
                          • Backup (B) ziehen
                          A.
                          Torsten Lehmann
                          @asgothian
                          [How-to] ioBroker richtig installieren
                          sudo apt update && sudo apt upgrade -y
                          curl -sl https://deb.nodesource.com/setup_22.x | sudo bash -
                          sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                          node -v && nodejs -v && npm -v
                          curl -sL https://iobroker.net/install.sh | bash -
                            @asgothian
                            @torsten-lehmann
                            Wo hast du denn das her?
                            Im Grunde reicht der Einzeiler:
                            curl -sLf https://iobroker.net/install.sh | bash -
                            Der Installer zieht dann auch nodejs usw. rein.
                              • Backup (B) ziehen
                              A.
                              @asgothian
                              Naja, ein struppiges Backup (A) würde ich gar nicht einspielen. Die Installation wird ja nicht besser dadurch.
                              Also vorher die ganze Choose auf das richtige Gleis setzen.
                                @asgothian
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @asgothian
                                im ioBroker backup hast du keine Installationsdaten, sondern nur Konfiguration / und Daten. Da kommt vielleicht bei einzelnen Adaptern veraltete Konfigurationen rein - aber in den meisten Fällen kommt man damit brauchbar durch.
                                Und ich hab lieber ein Backup wo ich gezielt bestimmte dinge heraus nehmen kann als nix.
                                A.
                                  @asgothian
                                  A.
                                  @asgothian
                                  Und ich hab lieber ein gescheites, in sich konsistentes Backup eines senkrechten Systems.
                                  So unterschiedlich können die Ansätze sein.
                                    @asgothian
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @thomas-braun Ich denke ich hab nicht besonders gut beschrieben was ich meine:
                                    • Adaptereinstellungen sind üblicherweise OK, auch wenn sie von älteren Versionen stammen - ich kenne Keinen Adapter bei dem die Einstellungen nicht abwärtskompatibel sind. Und was an Einstellungen 'neu' gemacht werden muss sollte beim Versuch das System hoch zu ziehen aufgefallen sein
                                    • Bei Datenbanken ist klar ob sie ok sind oder nicht (sprich - die restauriert man aus dem was du ein struppiges backup nennst sowieso nicht)
                                    • Bei all den Adaptern wo externe Daten existieren (z.Bsp. Yahka, vis, Zigbee) ist auch aus dem Versuch das System hoch zu ziehen klar ob die externen Daten sauber sind oder nicht - auch die restauriert man nur wenn damit das hochziehen klappt.
                                    Und wenn man das System nicht sauber hochgezogen bekommt ist ein vorhandenes Teilbackup besser als kein backup.
                                    Wo ich mit gehe - wenn das Backup nach hochziehen existiert sollte man das nehmen.
                                    Ansonsten bin ich extrem froh das es im ioBroker eine weitergehende Trennung zwischen code und Daten gibt, und das das Backup an den meisten Stellen nur Daten beinhaltet, und eben keinen (extern zu aktualisierenden) code. (Eigene Skripte fallen dabei durchaus unter Daten).
                                    Der Gedanke 'erst hochziehen, dann backup, dann installieren, dann restore' funktioniert ausschliesslich wenn das hochziehen und sauber machen funktioniert. Nur stellt sich dann die Frage - warum neu installieren, wenn man doch alles hochgezogen bekommt ?
                                    A.
                                      A.
                                      @asgothian sagte in RPI-Monitor und GPIO rpi2 v2.3.1:
                                      Um z.B. beim RaspberryPi von einem 32Bit-System auf ein 64Bit-System zu kommen. Oder sauber von 10 auf 11.
                                        @torsten-lehmann
                                        Torsten Lehmann
                                        @torsten-lehmann
                                        hallo Thomas
                                        hab alles so [https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht](link url) gemacht bekomme rpi2 nicht hin und werde solange darauf verzichten bis es über den offizellen Adapter funktioniert
                                          @torsten-lehmann
                                          hallo Thomas
                                          @torsten-lehmann
                                          Hier hat es @plc wohl im ersten Anlauf hinbekommen.
                                          Vielleicht kann er dir sagen, was er gemacht hat.
