  3. Cloud Dienste
  4. BETA-TEST Neuer Amazon Skill "iobroker.assistant"
759 Beiträge 112 Kommentatoren 132.5k Aufrufe 128 Beobachtet
  • Michael SchmittM Michael Schmitt
    @apollon77
    iobroker.assistent skill + iot.0 v 4.1.4
    ich bekomme folgende Meldung beim ausschalten des Lichts. Mit Aliases ebenso direkt mit den deconz Datenpunkten probiert.
    deconz.0
    	2025-10-18 14:23:51.844	warn	{"address":"/lights/9/state/bri","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0
    	2025-10-18 14:23:51.843	warn	Failed action "bri" on light 9! Description: parameter, bri, is not modifiable. Device is set to off.
    deconz.0
    	2025-10-18 14:23:51.832	warn	{"address":"/lights/28/state/bri","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0
    	2025-10-18 14:23:51.831	warn	Failed action "bri" on light 28! Description: parameter, bri, is not modifiable. Device is set to off.
    javascript.0
    	2025-10-18 14:23:37.431	info	script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: iot.0 is connected Wert: true Adapter ist wieder erreichbar
    deconz.0
    	2025-10-18 14:23:28.004	warn	{"address":"/lights/9/state/bri","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0
    	2025-10-18 14:23:28.004	warn	Failed action "bri" on light 9! Description: parameter, bri, is not modifiable. Device is set to off.
    deconz.0
    	2025-10-18 14:23:27.998	warn	{"address":"/lights/28/state/bri","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0
    	2025-10-18 14:23:27.997	warn	Failed action "bri" on light 28! Description: parameter, bri, is not modifiable. Device is set to off.
    apollon77A Online
    apollon77A Online
    #152
    @michael-schmitt Wie sehen die objekte aus? Und als GitHub issue bitte
    Michael SchmittM 1 Antwort Letzte Antwort
    • apollon77A apollon77
      @winni 4.1.5 angeblich gefixt
      WinniW Offline
      WinniW Offline
      Winni
      #153
      @apollon77 ja, mit der Version 4.1.6 kommen alle Geräte im Adapter, aber leider werden die Geräte nicht in der Alexa-App gefunden.
      Ich habe mal ein issue erstellt.
      https://github.com/ioBroker/ioBroker.iot/issues/987
        @fabio
        Ja das kann ich. as Licht geht auch an und aus nur die Meldung kommt jedesmal. Die Meldung kommt jedoch nicht wenn ich mit % sage zB "Alexa licht 0 % dann geht es aus und es kommt keine Meldung.
        apollon77A Online
        apollon77A Online
        #154
        @michael-schmitt Vllrt auch hier das Toggle feature aktiviert?
        • M mameier1234
          Ich habe in der iot instanz auf AlexaV3 umgestellt, die Geräte wurden übernommen.
          Dann habe ich auf dem Iphone in der Alexa app den iobroker.iot skill deaktiviert, dann den neuen Skill aktiviert.
          Die Alexa app sagte: 17 neue Geräte gefunden.
          Allerdings sehe ich in der App gar keine Geräte mehr, die sind komplett leer. Also auch alle anderen , von Hue, Shelly usw werden nicht angezeigt...
          Hat mir da jemand einen tipp ?
          apollon77A Online
          apollon77A Online
          #155
          @mameier1234 Ja manchmal lädt die app nicht immer die Geräte wenn man viele hat. einfach nochmal aus dem Geräte Seite raus und neu rein in der Alexa App
            Krys
            #156
            Hat jemand von euch das Problem, dass er Geräte nicht ausm iot-Adapter löschen kann?
            DuffyD 1 Antwort Letzte Antwort
            • DuffyD Duffy
              Frage an alle, ist bei euch die Reaktion der Zigbee Lampen nach einem einschalt Befehl auch „stark“ verzögert; zumindest im Vergleich zu früher?
              Ist evtl das System aufgrund der vielen Tests von uns allen etwas angespannt?
              Viele Grüße Duffy
              apollon77A Online
              apollon77A Online
              #157
              @duffy Nein. Last kein Problem
              • S Sandy
                hat das bei euch keiner das Alexa beim Suchen nach neuen Geräten kein Gerät findet ? :-(
                LG Sandy
                apollon77A Online
                apollon77A Online
                #158
                @sandy Auch hier: Fehler im Log wenn du "suche geräte" sagst?
                • BBTownB BBTown
                  @apollon77
                  ich habe mitlerweile eine ganze Reihe von Problemen, bei denen ich nicht sicher bin ob die Ursache an der Umstellung liegt, oder es nur hier sichtbar wird.
                  • Neuen Skill "iobroker.assist" aktiviert
                  • Alten Skill "iobroker.iot" noch aktiviert gelassen
                  • Alle ioBroker Geräte in der Alexa-App entfernt (sofern diese angezeigt wurden)
                  • In ioBroker wurde in den Optionen der Instanz "iot.0" (v4.1.4) zusätzlich "Amazon Alexa V3" aktiviert.
                  Es werden keine Geräte von "Amazon Alexa" in "Amazon Alexa V3" übernommen
                  Es können manuell keine Geräte in "Amazon Alexa V3" hinzugefügt werden
                  Beim Start der IOT-Instanz bekomme ich eine Reihe von Fehlern
                  iot.0
                  2025-10-18 19:20:42.814	error	[AlexaV3::DeviceManager]: TypeError: Cannot create property 'smartType' on string '' at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:440:36) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1545:13)
                  iot.0
                  2025-10-18 19:20:42.758	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot create property 'smartType' on string ''
                  host.ioBroker
                  2025-10-18 19:20:33.154	error	iobroker Cannot update apt sources: Command failed: apt updateWARNING: apt does not have a stable CLI interface. Use with caution in scripts.Fehler: Sperrdatei /var/lib/apt/lists/lock konnte nicht geöffnet werden. - open (13: Keine Berechtigung)Fehler: Das Verzeichnis /var/lib/apt/lists/ kann nicht gesperrt werden.Warnung: Problem beim Entfernen (unlink) der Datei /var/cache/apt/pkgcache.bin - RemoveCaches (13: Keine Berechtigung)Warnung: Problem beim Entfernen (unlink) der Datei /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Keine Berechtigung)
                  host.ioBroker
                  2025-10-18 19:20:33.110	error	iobroker Cannot detect \"sudo -n apt -v\": sudo: Ein Passwort ist notwendig
                  iot.0
                  2025-10-18 19:19:46.612	error	[AlexaV3::DeviceManager]: TypeError: Cannot create property 'smartType' on string '' at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:440:36) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1531:13)
                  iot.0
                  2025-10-18 19:19:46.526	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot create property 'smartType' on string ''
                  iot.0
                  2025-10-18 19:19:33.580	error	[AlexaV3::DeviceManager]: TypeError: Cannot create property 'smartType' on string '' at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:440:36) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1531:13)
                  iot.0
                  2025-10-18 19:19:33.568	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot create property 'smartType' on string ''
                  iot.0
                  2025-10-18 19:19:33.180	error	Cannot read connection certificates
                  iot.0
                  2025-10-18 19:19:33.172	error	Cannot fetch connection certificates: {"error":"Internal server error","time":"2025-10-18T17:19:33.031Z"}
                  iot.0
                  2025-10-18 19:18:21.674	error	[AlexaV3::DeviceManager]: TypeError: Cannot create property 'smartType' on string '' at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:440:36) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1531:13)
                  iot.0
                  2025-10-18 19:18:21.575	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot create property 'smartType' on string ''
                  Da ich bem Starten ioBroker plötzlich ebenfalls Fehler erhalte - bei denen ich mir schwer tue diese zu lösen/lokalisieren, kann es natürlich sein, dass diese im Zusammenhang mit dem iot-Fehler stehen
                  host.ioBroker
                  2025-10-18 19:40:39.211	error	Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
                  host.ioBroker
                  2025-10-18 19:40:39.209	error	Caught by controller[0]: (node:13552) [DEP0170] DeprecationWarning: The URL http://IP:PORT/api/events/raw is invalid. Future versions of Node.js will throw an error.
                  host.ioBroker
                  2025-10-18 19:40:34.562	error	Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
                  host.ioBroker
                  2025-10-18 19:40:34.554	error	Caught by controller[0]: (node:13524) [DEP0170] DeprecationWarning: The URL http://IP:PORT/api/events/raw is invalid. Future versions of Node.js will throw an error.
                  Jede Unterstützung ist herzlich Willkommen 😎😎
                  apollon77A Online
                  apollon77A Online
                  #159
                  @bbtown Sehennach Fehlern in iot aus bzw scheinen da Objekte kaputt zu sein. GitHub issue anlegen bitte
                  • D docsnyder7
                    @samson71 Jepp
                    im Screenshot ist das deprecated wieder deaktiviert, weil ich herumprobieren bin, auch mit Zertifikaten etc
                    apollon77A Online
                    apollon77A Online
                    #160
                    @docsnyder7 AUch hier: Fehler im Log wen. Alexa sucht? Wenn ja GitHub issue bitte
                    • K Krys
                      DuffyD Offline
                      DuffyD Offline
                      Duffy
                      #161
                      @krys
                      Ja, kann auch keine löschen
                      Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                      Node.js: v22.23.2
                      NPM: 10.9.4
                      js-controller 7.1.2
                      Linux: Trixie
                      • WinniW Winni
                        Bei mir läuft leider nicht. Habe gerade die 4.1.5 installiert. Es kommen aber unter Alexa-Geräte V3 weiterhin keine Geräte und Fehlermeldungen im Log sind auch noch da.
                        iot.0
                        2025-10-18 20:41:41.712	error	[AlexaV3::DeviceManager]: TypeError: Cannot read properties of undefined (reading 'type') at /opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:341:47 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:334:42 at Array.forEach (<anonymous>) at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:333:21) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1545:13)
                        iot.0
                        2025-10-18 20:41:41.634	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot read properties of undefined (reading 'type')
                        apollon77A Online
                        apollon77A Online
                        #162
                        @winni Fixed in 4.1.5
                        • R Rushmed
                          Der Umzug hat jetzt größtenteils geklappt. Offen ist noch das Setup von HUE Lmpen.
                          ich habe folgendes eingestellt:
                          Die Farbsteuerung und der dimmer fuktionieren garnicht. Beim Steuern per Sprachbefehlt wird immer auf Kaltweiß und maximale Helligkeit gestellt.
                          Ich weiß auch nicht welchen typ ich für Straturation abgen soll.
                          apollon77A Online
                          apollon77A Online
                          #163
                          @rushmed GitHub issue bitte mit Infos zu objekten und so
                          WinniW 1 Antwort Letzte Antwort
                            WinniW Offline
                            WinniW Offline
                            Winni
                            #164
                            @apollon77 ja, ich weiss ;) , siehe:
                            https://forum.iobroker.net/topic/82526/beta-test-neuer-amazon-skill-iobroker-assistant/153
                            • DuffyD Duffy
                              Hallo an alle,
                              wer kennt folgendes Problem.
                              Ich habe den iot Adapter 4.1.6 (war auch schon bei 4.1.4 so) installiert und in dem auch Amazon Alexa Custom Skill aktiviert.
                              wenn ich mich nun über das Handy in dem Skill anmelde wird folgende Meldung angezeigt:
                              Gleich danach sagt Alexa aber über den Echo:
                              "Ich habe im Moment schwierigkeiten auf deinen Custom iobroker Skill zuzugreifen"
                              Auf dem Handy ist nun bei dem Skill wieder der Urspungsscreen zu sehen:
                              Weis wer Rat?
                              Und hat es schon einer von euch geschafft Temperatursensoren abzufragen? Das klappt auch noch nicht, vielleicht auch wegen oben genanntem Problem.
                              Gruß Duffy
                              apollon77A Online
                              apollon77A Online
                              #165
                              @duffy Also wenn es wirklich die 4.1.4 bzw 4.1.6 oder so ist dann bitte GithUb issue wenn Custom fehlt
                                DuffyD Offline
                                DuffyD Offline
                                Duffy
                                #166
                                @apollon77
                                Bei 4.1.4 und 4.1.6 ist Amazon Alexa Custom Skill da!
                                Node.js: v22.23.2
                                NPM: 10.9.4
                                js-controller 7.1.2
                                Linux: Trixie
                                • Bullet_586B Bullet_586
                                  Ich zünde mein System gleich an!! Hab das gleiche Problem. Hab jetzt keine Ahnung wie oft alles gelöscht neu eingerichtet, anmelde Daten geprüft usw. Alle Geräte sind im IOBroker da aber Alexa findet keine Geräte. Ich bin glaub zu doof dafür !
                                  apollon77A Online
                                  apollon77A Online
                                  #167
                                  @bullet_586 Sorry, aber LOL? Wir sind hier in einem Thread zum BETA Test ... Leute jetzt macht doch mal Locker. Fehler muss man analysieren und lösen und nicht panisch werden. In jeglicher Kommunikation habe ich sehr klar gemacht das es hier ein BETA Testist und nur der mitmachen sollte der weis was da heisst!. Also durchatmen und Geduld haben.
                                  Also neueste Beta nehmen und schauen ob es Logs gibt falls es auch da nicht geht.
                                  Bullet_586B BBTownB 2 Antworten Letzte Antwort
                                  • A australien
                                    Soweit schaut alles ok aus, nur kann ich ein bereits gelöschtes Alias Objekt (Shelly Rollo) nicht mehr hinzufügen. Der Adapter nimmt nur mehr das Objekt direkt.
                                    Neustart des iot Adapters und Skill bei Alexa hat keine Abhilfe gebracht.
                                    edit: iot 4.1.6
                                    apollon77A Online
                                    apollon77A Online
                                    #168
                                    @australien Ich verstehe nicht was du damit sagen willst? itte genau beshcreiben, ggf mit Repro schritten und GitHub issue machen
                                      australien
                                      #169
                                      @apollon77
                                      ich hatte schon ein Objekt (Shelly Rollo) mittels alias DP eingebunden und wieder gelöscht. Nun kann der Adapter den alias DP nicht mehr hinzufügen, nur mehr wenn ich den DP des Shelly direkt. Im Log ist nicht zu sehen.
                                      • BBTownB BBTown
                                        @rushmed
                                        Hast Du zuvor einmal auf der Zugangsseite von ioBroker.Pro deine Zugangsdaten geprüft?
                                        Ansonsten , kann es sein, dass Du in den Einstellungen vom IOT-Adapter einemal neue Verbindungszertifikate erstellen musst?
                                        DuffyD Offline
                                        DuffyD Offline
                                        Duffy
                                        #170
                                        @bbtown sagte in BETA-TEST Neuer Amazon Skill "iobroker.assistant":
                                        @rushmed
                                        @Rushmed
                                        Mit dem neuen Zertifikat hat eine Anmeldung beim Amazon Alexa Custom Skill geklappt.
                                        Danke.
                                        Node.js: v22.23.2
                                        NPM: 10.9.4
                                        js-controller 7.1.2
                                        Linux: Trixie
                                        • A australien
                                          @apollon77
                                          apollon77A Online
                                          apollon77A Online
                                          #171
                                          @australien Bitte zeig mal das Objekt JSON von dem Objekt
