  4. Test Adapter Unifi Network
    6.3k
173 Beiträge 34 Kommentatoren 26.8k Aufrufe 38 Beobachtet
  • NashraN Offline
    NashraN Offline
    Nashra
    Most Active Forum Testing
    Moin @Scrounger, für den alten Adapter hast Du mal ein Script gemacht mit welchem
    man alle Devices mit Material Design Widgets darstellen konnte,
    welches ich auch bis heute genutzt habe.
    Gibt es für den neuen Adapter auch ein Script damit man dies wieder
    in der VIS anzeigen kann.
    * Listings for UniFi devices (to use with Material Design Widgets)
    * Requirements:
    *  - UniFi controller permanently running on your network
    *  - UniFi ioBroker adapter >= 0.5.8 (https://www.npmjs.com/package/iobroker.unifi)
    *  - Library "moment" in the "Additional npm modules" of the javascript.0 adapter configuration
    *  - Some programming skills
    * @license http://www.opensource.org/licenses/mit-license.html  MIT License
    * @author  Scrounger <Scrounger@gmx.net>
    * @author  web4wasch @WEB4WASCH
    * @author  cdellasanta <70055566+cdellasanta@users.noreply.github.com>
    * @link    https://forum.iobroker.net/topic/30875/material-design-widgets-unifi-netzwerk-status
    // Script configuration
    const statePrefix = '0_userdata.0.vis.NetzwerkDevicesStatus'; // Might be better to use an english statePrefix (e.g. '0_userdata.0.vis.unifiNetworkState'), but then remember to adapt the Views too
    const defaultLocale = 'de';
    const lastDays = 7;       // 7 Show devices that have been seen in the network within the last X days
    const byteUnits = 'SI'; // SI units use the Metric representation based on 10^3 (1'000) as a order of magnitude
                          // IEC units use 2^10 (1'024) as an order of magnitude
    const defaultSortMode = 'ip'; // Value for default and reset sort
    const sortResetAfter = 120;     // Reset sort value after X seconds (0=disabled)
    const filterResetAfter = 120;   // Reset filter after X seconds (0=disabled)
    const imagesPath = '/vis.0/Desktop/Unifi-Alias/'; // Path for images
    // Optional: Path prefix for UniFi device images (see getUnifiImage function for deeper information on how to extract it for your network)
    // @todo Could take controller host and port from the unifi adapter configuration, but thene there is still the angular subdirectory that needs to be configured ..
    //const unifiImagesUrlPrefix = 'https://<your-controller-ip-or-host>:<controller-port>/manage/angular/g7989b19/images/devices/';
    //const unifiImagesUrlPrefix = 'https://192.168.1.15/app-assets/network/angular/gf2f1a60/images/devices/';
    //const unifiImagesUrlPrefix =  'https://192.168.1.15/manage/angular/g7989b19/images/devices/';
    //const unifiImagesUrlPrefix = null; // Use the 'lan_noImage.png' for all devices
    const unifiImagesUrlPrefix = false; // Use '<device model>.png' from your imagesPath
    // Optional: display links into a separate view, instead of new navigation window (set false to disable this feature)
    const devicesView = {currentViewState: '0_userdata.0.vis.currentView', devicesViewKey: 1};
    const offlineTextSize = 14;
    const infoIconSize = 20;
    const infoTextSize = 14;
    const performances = {
      none: {
          color: 'grey',
          experience: 'speedometer',
          speedLan: 'network-off',
          speedWifi: 'wifi-off'
      good: {
          color: 'green',
          speedLan: 'network',
          speedWifi: 'signal-cellular-3'
      low: {
          color: '#ff9800',
          experience: 'speedometer-medium',
          speedWifi: 'signal-cellular-2'
      bad: {
          color: 'FireBrick',
          experience: 'speedometer-slow',
          speedWifi: 'signal-cellular-1'
    // Modules: should not need to 'import' them (ref: https://github.com/ioBroker/ioBroker.javascript/blob/c2725dcd9772627402d0e5bc74bf69b5ed6fe375/docs/en/javascript.md#require---load-some-module),
    // but to avoid TypeScript inspection errors, doing it anyway ...
    // import * as moment from "moment"; // Should work, but typescript raises exception ...
    const moment = require('moment');
    // Initialization create/delete states, register listeners
    // Using my global functions (see global script common-states-handling )
    /** For this script to work as standalone, the following 4 functions have been inlined at the end of script,
    *  if you place them in a global script, then you need to uncomment following "declare" statements **/
    // declare function runAfterInitialization(callback: CallableFunction): void;
    // declare function initializeState(stateId: string, defaultValue: any, common: object, listenerChangeType?: string, listenerCallback?: CallableFunction): void;
    // declare function getStateIfExists(stateId: string): any;
    // declare function getStateValue(stateId: string): any;
    const getLocale = () => getStateValue('0_userdata.0.vis.locale') || defaultLocale;
    initializeState(`${statePrefix}.jsonList`, '[]', {name: 'UniFi devices listing: jsonList', type: 'string'});
    // Change on sort mode triggers list generation and reset of sort-timer-reset
    initializeState(`${statePrefix}.sortMode`, defaultSortMode, {name: 'UniFi device listing: sortMode', type: 'string'}, 'any', () => { updateDeviceLists(); resetSortTimer(); });
    // Change on filter mode triggers list generation and reset of filter-timer-reset
    initializeState(`${statePrefix}.filterMode`, '', {name: 'UniFi device listing: filterMode', type: 'string'}, 'any', () => { updateDeviceLists(); resetFilterTimer(); });
    // Sorters, filters and some additional translations are saved in states to permit texts localization
    initializeState(`${statePrefix}.sortersJsonList`, '{}', {name: 'UniFi device listing: sortersJsonList', type: 'string', read: true, write: false});
    initializeState(`${statePrefix}.filtersJsonList`, '{}', {name: 'UniFi device listing: filtersJsonList', type: 'string', read: true, write: false});
    initializeState(`${statePrefix}.translations`, '{}', {name: 'UniFi device listing: viewTranslations', type: 'string', read: true, write: false});
    if (devicesView) {
      initializeState(`${statePrefix}.linksJsonList`, '[]', {name: 'Device links listing: linksJsonList', type: 'string'});
      initializeState(`${statePrefix}.selectedUrl`, '', {name: 'Selected device link: selectedUrl', type: 'string'}, 'any', () => { setState(devicesView.currentViewState, devicesView.devicesViewKey); }); // On selected device change, go to "Devices" view
    // On locale change, setup correct listings
    if (existsState('0_userdata.0.vis.locale')) {
      runAfterInitialization(() => on('0_userdata.0.vis.locale', 'ne', setup));
    runAfterInitialization(() => {
      setup();
      // Refresh lists every time the unifi adapter has updated its data
      on('unifi.0.info.connection','any', updateDeviceLists);
    function setup(): void {
      setTimeLocale();
      setSortItems();
      setFilterItems();
      setViewTranslations();
      // Fill lists
    function updateDeviceLists() {
      const getNote = (idDevice, name, mac, ip) => {
          try {
              return JSON.parse(getStateValue(`${idDevice}.note`) || '{}');
          } catch (ex) {
              console.error(`${name} (ip: ${ip}, mac: ${mac}): ${ex.message}`);
          return {};
      try {
          // Selector help: https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#---selector
          let devices = $('state[id=unifi\.0\.default\.*\.*\.mac]'); // Query every time function is called (for new devices)
          let deviceList = [];
          for (var i = 0; i <= devices.length - 1; i++) {
              let [,,, deviceType, mac] = devices[i].split('.');
              // Only 'clients' and 'devices' are allowed (not 'alerts' ... can't exclude direclty on selector ...)
              if (!['clients', 'devices'].includes(deviceType)) {
                  continue;
              let idDevice = devices[i].replace('.mac', '');
              let unifiDevice = deviceType === 'devices';
              let isWired = getStateValue(`${idDevice}.is_wired`) || unifiDevice;
              let lastSeen = new Date(getStateValue(`${idDevice}.last_seen`));
              // For clients, if lastSeen difference is bigger than lastDays, then skip the device
              if (!unifiDevice && (new Date().getTime() - lastSeen.getTime()) > lastDays * 86400 * 1000) {
                  continue;
              // Values for all device types and connection
              let isConnected = getStateValue(`${idDevice}.is_online`) || unifiDevice;
              let ip = getStateValue(`${idDevice}.ip`) || '';
              let name = getStateValue(`${idDevice}.name`) || getStateValue(`${idDevice}.hostname`) || ip || mac;
              let isGuest = getStateValue(`${idDevice}.is_guest`);
              let note = getNote(idDevice, name, mac, ip);
              let received = getStateValue(`${idDevice}.${unifiDevice || !isWired ? '' : 'wired-'}tx_bytes`) || 0;
              let sent = getStateValue(`${idDevice}.${unifiDevice || !isWired ? '' : 'wired-'}rx_bytes`) || 0;
              let uptime = getStateValue(`${idDevice}.uptime`);
              let experience = getStateValue(`${idDevice}.satisfaction`) || (isConnected ? 100 : 0); // For LAN devices I got null as expirience .. file a bug?
              let additionalInfoItems = '';
              const infoItem = (icon, color, text) => `<span style="margin: 0 2px">
                  <span class="mdi mdi-${icon}" style="color: ${color}; font-size: ${infoIconSize}px; "></span>
                  <span style="color: gray; font-family: RobotoCondensed-LightItalic; font-size: ${infoTextSize}px; margin-left: 2px;">${text}</span>
                  </span>`;
              if (unifiDevice) {
                  let cpu = getStateValue(`${idDevice}.system-stats.cpu`) || 0;
                  let mem = getStateValue(`${idDevice}.system-stats.mem`) || 0;
                  let cpuPerformance = !isConnected ? 'none' : (cpu <= 70 ? 'good' : (cpu <= 90 ? 'low' : 'bad'));
                  let memPerformance = !isConnected ? 'none' : (mem <= 70 ? 'good' : (mem <= 90 ? 'low' : 'bad'));
                  // The icons do not really fit, there is no good option for a "ram memory bank" in https://materialdesignicons.com/
                  additionalInfoItems += infoItem(/*'cpu-64-bit'*/ 'memory', performances[cpuPerformance].color, `${cpu}%`);
                  additionalInfoItems += infoItem(/*'memory' 'expansion-card-variant'*/ 'sd', performances[memPerformance].color, `${mem}%`);
              } else {
                  let experiencePerformance = !isConnected ? 'none' : (experience >= 70 ? 'good' : (experience >= 40 ? 'low' : 'bad'));
                  let speedText = '';
                  let speedPerformance = 'none';
                  if (isWired) {
                      // If exists prefer uptime on switch port
                      uptime = getStateValue(`${idDevice}.uptime_by_usw`) || uptime;
                      let switchMac = getStateValue(`${idDevice}.sw_mac`) || false;
                      let switchPort = getStateValue(`${idDevice}.sw_port`) || false;
                      if (switchMac && switchPort) {
                          let speed = getStateValue(`unifi.0.default.devices.${switchMac}.port_table.port_${switchPort}.speed`) || 0;
                          speedText = speed === 0 ? '' : (speed < 1000 ? (speed + ' Mbit/s') : (speed/1000 + ' Gbit/s'));
                          speedPerformance = !isConnected ? 'none' : (speed == 1000 ? 'good' : 'low');
                      // Do not consider fiber ports
                      if (switchPort > 24) { // @todo  On some switches the fiber port is already on port 9 .. there are surely better ways to recognise a fiber port
                          // @todo This is legacy code, why are devices connected to fiber ports not of interest?
                          continue; // Skip device
                  } else {
                      let channel = getStateValue(`${idDevice}.channel`);
                      let signal = getStateValue(`${idDevice}.signal`);
                      speedText = channel === null ? '' : (channel > 13 ? '5G' : '2G');
                      speedPerformance = !isConnected ? 'none' : (signal >= -55 ? 'good' : (signal >= -70 ? 'low' : 'bad'));
                  additionalInfoItems += infoItem(performances[speedPerformance][isWired ? 'speedLan' : 'speedWifi'], performances[speedPerformance].color, speedText);
                  additionalInfoItems += infoItem(performances[experiencePerformance].experience, performances[experiencePerformance].color, `${experience}%`);
              deviceList.push({
                  // Visualization data (tplVis-materialdesign-Icon-List)
                  statusBarColor: isConnected ? 'green' : 'FireBrick',
                  text: isGuest ? `<span class="mdi mdi-account-box" style="color: #ff9800;">${name}</span>` : name,
                  subText: `
                      ${ip}
                      <div style="display: flex; flex-direction: row; padding-left: 8px; padding-right: 8px; align-items: center; justify-content: center;">
                          <span style="color: gray; font-size: ${offlineTextSize}px; line-height: 1.3; font-family: RobotoCondensed-LightItalic;">
                              ${translate(isConnected ? 'online' : 'offline')} ${(isConnected ? moment().subtract(uptime, 's') : moment(lastSeen)).fromNow()}
                          </span>
                      </div>
                      <div style="display: flex; flex-direction: row; padding-left: 4px; padding-right: 4px; margin-top: 10px; align-items: center;">
                          <div style="display: flex; flex: 1; text-align: left; align-items: center; position: relative;">
                              ${infoItem('arrow-down', '#44739e', formatBytes(received, byteUnits))}
                              ${infoItem('arrow-up', '#44739e', formatBytes(sent, byteUnits))}
                          </div>
                          <div style="display: flex; margin-left: 8px; align-items: center;">
                              ${additionalInfoItems}
                          </div>
                      </div>
                  listType: !note.link ? 'text' : 'buttonLink',
                  buttonLink: !note.link ? '' : (['http', 'https'].includes(note.link) ? `${note.link}://${ip}` : note.link),
                  image: unifiDevice ? getUnifiImage(getStateValue(`${idDevice}.model`)) : (imagesPath + (note.image ? note.image : ((isWired ? 'lan' : 'wlan') + '_noImage')) + '.png'),
                  icon: note.icon || '',
                  // Additional data used for list sorting
                  ip: ip,
                  connected: isConnected,
                  received: received,
                  sent: sent,
                  experience: experience,
                  uptime: uptime,
                  isWired: isWired,
                  isUnifi: unifiDevice
          // Sorting
          let sortMode = getStateValue(`${statePrefix}.sortMode`);
          deviceList.sort((a, b) => {
              switch (sortMode) {
                  case 'ip':
                      const na = Number(a['ip'].split(".").map(v => `000${v}`.slice(-3)).join(''));
                      const nb = Number(b['ip'].split(".").map(v => `000${v}`.slice(-3)).join(''));
                      return na - nb;
                  case 'connected':
                  case 'received':
                  case 'sent':
                  case 'experience':
                  case 'uptime':
                      return a[sortMode] === b[sortMode] ? 0 : +(a[sortMode] < b[sortMode]) || -1;
                  case 'name':
                  default:
                      return a['name'].localeCompare(b['name'], getLocale(), {sensitivity: 'base'});
          if (devicesView) {
              // Create links list (before filtering)
              let linkList = [];
              deviceList.forEach(obj => {
                  if (obj.listType === 'buttonLink') {
                      linkList.push({
                          // Visualization data (tplVis-materialdesign-Select)
                          text: obj.name,
                          value: obj.buttonLink,
                          icon: obj.icon
                          /** @todo Add some properties (connected, ip, received, sent, experience, ...)? */
                      // Change behaviour from 'buttonLink' to 'buttonState',
                      // a listener on the state change of the objectId will trigger the jump to the devices view
                      obj['listType'] = 'buttonState';
                      obj['objectId'] = `${statePrefix}.selectedUrl`;
                      obj['showValueLabel'] = false;
                      obj['buttonStateValue'] = obj.buttonLink;
                      delete obj['buttonLink'];
              let linkListString = JSON.stringify(linkList);
              if (getStateValue(`${statePrefix}.linksJsonList`) !== linkListString) {
                  setState(`${statePrefix}.linksJsonList`, linkListString, true);
          // Filtering
          let filterMode = getStateValue(`${statePrefix}.filterMode`) || '';
          if (filterMode && filterMode !== '') {
              deviceList = deviceList.filter(item => {
                  switch (filterMode) {
                      case 'connected':
                          return item.connected;
                      case 'disconnected':
                          return !item.connected;
                      case 'lan':
                          return item.isWired;
                      case 'wlan':
                          return !item.isWired;
                      case 'unifi':
                          return item.isUnifi;
                      default:
                          return false; // Unknown filter, return no item
          let result = JSON.stringify(deviceList);
          if (getStateValue(`${statePrefix}.jsonList`) !== result) {
              setState(`${statePrefix}.jsonList`, result, true);
      } catch (err) {
          console.error(`[updateDeviceLists] error: ${err.message}`);
          console.error(`[updateDeviceLists] stack: ${err.stack}`);
      log(`Updated lists`, 'debug');
    let sortTimeoutID;
    function resetSortTimer() {
      if (sortResetAfter > 0) {
          this.clearTimeout(sortTimeoutID); // If set then clear previous timer
          sortTimeoutID = this.setTimeout(() => setState(`${statePrefix}.sortMode`, defaultSortMode), sortResetAfter * 1000);
    let filterTimeoutID;
    function resetFilterTimer() {
      if (filterResetAfter > 0) {
          this.clearTimeout(filterTimeoutID); // If set then clear previous timer
          filterTimeoutID = this.setTimeout(() => setState(`${statePrefix}.filterMode`, ''), filterResetAfter * 1000);
    function setTimeLocale(): void {
      let locale = getLocale();
      moment.locale(locale);
      moment.updateLocale(locale, {
          relativeTime: {
              future: translate('in %s'),
              past: translate('since %s'), // Default for past is '%s ago'
              s: translate('a few seconds'),
              ss: translate('%d seconds'),
              m: translate('a minute'),
              mm: translate('%d minutes'),
              h: translate('an hour'),
              hh: translate('%d hours'),
              d: translate('a day'),
              dd: translate('%d days'),
              w: translate('a week'),
              ww: translate('%d weeks'),
              M: translate('a month'),
              MM: translate('%d months'),
              y: translate('a year'),
              yy: translate('%d years')
    function setSortItems(): void {
      setState(
          JSON.stringify([
                  text: translate('Name'),
                  value: 'name',
                  icon: 'sort-alphabetical-variant'
                  text: translate('IP address'),
                  value: 'ip',
                  icon: 'information-variant'
                  text: translate('Connected'),
                  value: 'connected',
                  icon: 'check-network'
                  text: translate('Received data'),
                  value: 'received',
                  icon: 'arrow-down'
                  text: translate('Sent data'),
                  value: 'sent',
                  icon: 'arrow-up'
                  text: translate('Experience'),
                  value: 'experience',
                  icon: 'speedometer'
                  text: translate('Uptime'),
                  value: 'uptime',
                  icon: 'clock-check-outline'
          true
    function setFilterItems(): void {
      setState(
          JSON.stringify([
                  text: translate('connected'),
                  value: 'connected',
                  text: translate('disconnected'),
                  value: 'disconnected',
                  icon: 'network-off'
                  text: translate('LAN connection'),
                  value: 'lan',
                  icon: 'network'
                  text: translate('WLAN connection'),
                  value: 'wlan',
                  icon: 'wifi'
                  text: translate('UniFi network devices'),
                  value: 'unifi',
                  icon: 'router-network'
          true
    function setViewTranslations(): void {
      setState(
          JSON.stringify([
              'Sort by',
              'Filter by',
              'Device'
          ].reduce((o, key) => ({...o, [key]: translate(key)}), {})),
          true
    function translate(enText) {
      const map = { // For translations used https://translator.iobroker.in (that uses Google translator)
          // Sort items
          'Name': {de: 'Name', ru: 'имя', pt: 'Nome', nl: 'Naam', fr: 'Nom', it: 'Nome', es: 'Nombre', pl: 'Nazwa','zh-cn': '名称'},
          'IP address': {de: 'IP Adresse', ru: 'Aйпи адрес', pt: 'Endereço de IP', nl: 'IP adres', fr: 'Adresse IP', it: 'Indirizzo IP', es: 'Dirección IP', pl: 'Adres IP','zh-cn': 'IP地址'},
          'Connected': {de: 'Verbunden', ru: 'Связано', pt: 'Conectado', nl: 'Verbonden', fr: 'Connecté', it: 'Collegato', es: 'Conectado', pl: 'Połączony','zh-cn': '连接的'},
          'Received data': {de: 'Daten empfangen', ru: 'Полученные данные', pt: 'Dados recebidos', nl: 'Ontvangen data', fr: 'Données reçues', it: 'Dati ricevuti', es: 'Datos recibidos', pl: 'Otrzymane dane','zh-cn': '收到资料'},
          'Sent data': {de: 'Daten gesendet', ru: 'Отправленные данные', pt: 'Dados enviados', nl: 'Verzonden gegevens', fr: 'Données envoyées', it: 'Dati inviati', es: 'Datos enviados', pl: 'Wysłane dane','zh-cn': '发送数据'},
          'Experience': {de: 'Erlebnis', ru: 'Опыт', pt: 'Experiência', nl: 'Ervaring', fr: 'Expérience', it: 'Esperienza', es: 'Experiencia', pl: 'Doświadczenie','zh-cn': '经验'},
          'Uptime': {de: 'Betriebszeit', ru: 'Время безотказной работы', pt: 'Tempo de atividade', nl: 'Uptime', fr: 'Disponibilité', it: 'Disponibilità', es: 'Tiempo de actividad', pl: 'Dostępność','zh-cn': '正常运行时间'},
          // Filter Items
          'connected': {de: 'verbunden', ru: 'связано', pt: 'conectado', nl: 'verbonden', fr: 'connecté', it: 'collegato', es: 'conectado', pl: 'połączony','zh-cn': '连接的'},
          'disconnected': {de: 'nicht verbunden', ru: 'отключен', pt: 'desconectado', nl: 'losgekoppeld', fr: 'débranché', it: 'disconnesso', es: 'desconectado', pl: 'niepowiązany','zh-cn': '断开连接'},
          'LAN connection': {de: 'LAN Verbindungen', ru: 'подключение по локальной сети', pt: 'conexão LAN', nl: 'LAN-verbinding', fr: 'connexion LAN', it: 'connessione LAN', es: 'coneccion LAN', pl: 'połączenie LAN','zh-cn': '局域网连接'},
          'WLAN connection': {de: 'WLAN Verbindungen', ru: 'поединение WLAN', pt: 'conexão WLAN', nl: 'WLAN-verbinding', fr: 'connexion WLAN', it: 'connessione WLAN', es: 'conexión WLAN', pl: 'połączenie WLAN','zh-cn': 'WLAN连接'},
          'UniFi network devices': {de: 'UniFi-Netzwerkgeräte', ru: 'Сетевые устройства UniFi', pt: 'Dispositivos de rede UniFi', nl: 'UniFi-netwerkapparaten', fr: 'Périphériques réseau UniFi', it: 'Dispositivi di rete UniFi', es: 'Dispositivos de red UniFi', pl: 'Urządzenia sieciowe UniFi', 'zh-cn': 'UniFi网络设备'},
          // Additional view translations
          'Sort by': {de: 'Sortieren nach', ru: 'Сортировать по', pt: 'Ordenar por', nl: 'Sorteer op', fr: 'Trier par', it: 'Ordina per', es: 'Ordenar por', pl: 'Sortuj według', 'zh-cn': '排序方式'},
          'Filter by': {de: 'Filtern nach', ru: 'Сортировать по', pt: 'Filtrar por', nl: 'Filteren op', fr: 'Filtrer par', it: 'Filtra per', es: 'Filtrado por', pl: 'Filtruj według','zh-cn': '过滤'},
          'Device': {de: 'Gerät', ru: 'Устройство', pt: 'Dispositivo', nl: 'Apparaat', fr: 'Dispositif', it: 'Dispositivo', es: 'Dispositivo', pl: 'Urządzenie','zh-cn': '设备'},
          // On/off times
          'online': {de: 'online', ru: 'онлайн', pt: 'conectados', nl: 'online', fr: 'en ligne', it: 'in linea', es: 'en línea', pl: 'online', 'zh-cn': "线上"},
          'offline': {de: 'offline', ru: 'не в сети', pt: 'desligada', nl: 'offline', fr: 'hors ligne', it: 'disconnesso', es: 'desconectado', pl: 'offline', 'zh-cn': "离线"},
          // Relative times
          'in %s': {de: 'in %s', ru: 'через %s', pt: 'em %s', nl: 'in %s', fr: 'en %s', it: 'in %s', es: 'en %s', pl: 'w %s','zh-cn': '在%s中'},
          'since %s': {de: 'seit %s', ru: 'поскольку %s', pt: 'desde %s', nl: 'sinds %s', fr: 'depuis %s', it: 'da %s', es: 'desde %s', pl: 'od %s','zh-cn': '自%s'},
          'a few seconds': {de: 'ein paar Sekunden', ru: 'несколько секунд', pt: 'alguns segundos', nl: 'een paar seconden', fr: 'quelques secondes', it: 'pochi secondi', es: 'unos pocos segundos', pl: 'kilka sekund','zh-cn': '几秒钟'},
          '%d seconds': {de: '%d Sekunden', ru: '%d секунд', pt: '%d segundos', nl: '%d seconden', fr: '%d secondes', it: '%d secondi', es: '%d segundos', pl: '%d sekund','zh-cn': '%d秒'},
          'a minute': {de: 'eine Minute', ru: 'минута', pt: 'um minuto', nl: 'een minuut', fr: 'une minute', it: 'un minuto', es: 'un minuto', pl: 'minutę','zh-cn': '一分钟'},
          '%d minutes': {de: '%d Minuten', ru: '%d минут', pt: '%d minutos', nl: '%d minuten', fr: '%d minutes', it: '%d minuti', es: '%d minutos', pl: '%d minut','zh-cn': '%d分钟'},
          'an hour': {de: 'eine Stunde', ru: 'час', pt: 'uma hora', nl: 'een uur', fr: 'une heure', it: 'un\'ora', es: 'una hora', pl: 'godzina','zh-cn': '一小时'},
          '%d hours': {de: '%d Stunden', ru: '%d часов', pt: '%d horas', nl: '%d uur', fr: '%d heures', it: '%d ore', es: '%d horas', pl: '%d godzin','zh-cn': '%d小时'},
          'a day': {de: 'ein Tag', ru: 'день', pt: 'um dia', nl: 'een dag', fr: 'un jour', it: 'un giorno', es: 'un día', pl: 'dzień','zh-cn': '一天'},
          '%d days': {de: '%d Tage', ru: '%d дней', pt: '%d dias', nl: '%d dagen', fr: '%d jours', it: '%d giorni', es: '%d días', pl: '%d dni','zh-cn': '%d天'},
          'a week': {de: 'eine Woche', ru: 'неделя', pt: 'uma semana', nl: 'een week', fr: 'une semaine', it: 'una settimana', es: 'una semana', pl: 'tydzień','zh-cn': '一周'},
          '%d weeks': {de: '%d Wochen', ru: '%d недель', pt: '%d semanas', nl: '%d weken', fr: '%d semaines', it: '%d settimane', es: '%d semanas', pl: '%d tygodni','zh-cn': '%d周'},
          'a month': {de: 'ein Monat', ru: 'месяц', pt: 'um mês', nl: 'een maand', fr: 'un mois', it: 'un mese', es: 'un mes', pl: 'miesiąc','zh-cn': '一个月'},
          '%d months': {de: '%d Monate', ru: '%d месяцев', pt: '%d meses', nl: '%d maanden', fr: '%d mois', it: '%d mesi', es: '%d meses', pl: '%d miesięcy','zh-cn': '%d个月'},
          'a year': {de: 'ein Jahr', ru: 'год', pt: 'um ano', nl: 'een jaar', fr: 'une année', it: 'un anno', es: 'un año', pl: 'rok','zh-cn': '一年'},
          '%d years': {de: '%d Jahre', ru: '%d лет', pt: '%d anos', nl: '%d jaar', fr: '%d années', it: '%d anni', es: '%d años', pl: '%d lat','zh-cn': '%d年'}
      return (map[enText] || {})[getLocale()] || enText;
    function formatBytes(bytes, unit?: 'SI' | 'IEC') : string  {
      if (bytes === 0) return 'N/A';
      const orderOfMagnitude = unit === 'SI' ? Math.pow(10, 3) : Math.pow(2, 10);
      const abbreviations = unit === 'SI' ?
          ['Bytes', 'kB', 'MB', 'GB', 'TB', 'PB', 'EB', 'ZB', 'YB'] :
          ['Bytes', 'KiB', 'MiB', 'GiB', 'TiB', 'PiB', 'EiB', 'ZiB', 'YiB'];
      const i = Math.floor(Math.log(bytes) / Math.log(orderOfMagnitude));
      return parseFloat((bytes / Math.pow(orderOfMagnitude, i)).toFixed(3).substring(0, 4)) + ' ' + abbreviations[i];
    function getUnifiImage(deviceModel: string): string {
      // For unifi devices, there is no 'note' where an image information can be stored, but we have the
      // device 'model' that provides enough information for the choice of the correct image.
      // The images themselves are on your network, hosted by the UniFi controller for its devices grid view.
      // Example for my 3 device models (extract using developer console: see backround-image of element):
      //  * US16P150: https://10.10.10.5:8443/manage/angular/g7989b19/images/devices/usw/US16/grid.png
      //  * U7LT:     https://10.10.10.5:8443/manage/angular/g7989b19/images/devices/uap/default/grid.png
      //  * UGW3:     https://10.10.10.5:8443/manage/angular/g7989b19/images/devices/ugw/UGW3/grid.png
      // From the divice model we need some insight to get to the image URL, this is provided by the app.css
      // of the Unifi Controller (I used mine with version 5.13.29)
      // Following list is obtained with some reverse engeeniring: downloaded minified app.css, reformatted code with Phpstorm, then regex-replace: "\.unifiDeviceIcon--([^.]+)\.is-grid[^{]+\{\s+background-image: url\("\.\./images/devices/([^"]+)grid\.png\"\)" with "deviceModel['$1'] = '$2';", ant then some additional parsing ..
      const unifiControllerimagesPaths = {BZ2: 'uap/BZ2', BZ2LR: 'uap/BZ2', p2N: 'uap/p2N', U2HSR: 'uap/U2HSR', U2IW: 'uap/U2IW', U2L48: 'uap/BZ2', U2Lv2: 'uap/BZ2', U2M: 'uap/default', U2O: 'uap/U2O', U2S48: 'uap/BZ2', U2Sv2: 'uap/BZ2', U5O: 'uap/U2O', U7E: 'uap/U7E', U7EDU: 'uap/U7EDU', U7Ev2: 'uap/U7E', U7HD: 'uap/default', U7IW: 'uap/U7IW', U7IWP: 'uap/U7IW', U7LR: 'uap/default', U7LT: 'uap/default', U7MP: 'uap/U7O', U7MSH: 'uap/U7MSH', U7NHD: 'uap/U7NHD', U7O: 'uap/U7O', UFLHD: 'uap/UFLHD', U7P: 'uap/default', U7PG2: 'uap/default', U7SHD: 'uap/default', UCMSH: 'uap/default', UCXG: 'uap/default', UHDIW: 'uap/U7IW', ULTE: 'uap/ULTE', UXSDM: 'uap/UXSDM', UXBSDM: 'uap/UXBSDM', UDMB: 'uap/UDMB', UP1: 'uap/UP1', UBB: 'ubb/UBB', UGW3: 'ugw/UGW3', UGW4: 'ugw/UGW4', UGWXG: 'ugw/UGWXG', S216150: 'usw/US16', S224250: 'usw/US24', S224500: 'usw/US24', S248500: 'usw/US48', S248750: 'usw/US48', S28150: 'usw/US8P150', UDC48X6: 'usw/UDC48X6', US16P150: 'usw/US16', US24: 'usw/US24', US24P250: 'usw/US24', US24P500: 'usw/US24', US24PL2: 'usw/US24', US24PRO: 'usw/US24PRO', US24PRO2: 'usw/US24PRO2', US48: 'usw/US48', US48P500: 'usw/US48', US48P750: 'usw/US48', US48PL2: 'usw/US48', US48PRO: 'usw/US48PRO', US48PRO2: 'usw/US48PRO2', US6XG150: 'usw/US6XG150', US8: 'usw/US8', US8P150: 'usw/US8P150', US8P60: 'usw/US8P60', USC8: 'usw/US8', USC8P450: 'usw/USC8P450', USF5P: 'usw/USF5P', USXG: 'usw/USXG', USL8LP: 'usw/USL8LP', USL16LP: 'usw/USL16LP', USL16P: 'usw/USL16P', USL24: 'usw/USL24', USL48: 'usw/USL48', USL24P: 'usw/USL24P', USL48P: 'usw/USL48P', USMINI: 'usw/USMINI', USPRPS: 'usw/USPRPS', UAS: 'uas/UAS', UCK: 'uas/UCK', UCKG2: 'uas/UCKG2', UCKP: 'uas/UCKP', UMAD: 'ua/UMAD', UDM: 'udm/UDM', 'UDM-UAP': 'udm/UDM-UAP', 'UDM-USW': 'udm/UDM-USW', 'UDM-UGW': 'udm/UDM-UGW', UDMSE: 'udm/UDMSE', 'UDMSE-UAP': 'udm/UDM-UAP', 'UDMSE-USW': 'udm/UDM-USW', 'UDMSE-UGW': 'udm/UDM-UGW', UDMPRO: 'udm/UDMPRO', 'UDMPRO-USW': 'udm/UDMPRO-USW', 'UDMPRO-UGW': 'udm/UDMPRO-UGW'};
      // If prefix set to null return the 'lan_noImage.png' for all devices, if set to false return '<device model>.png'
      if (!unifiImagesUrlPrefix) {
          return imagesPath + (unifiImagesUrlPrefix === null ? 'lan_noImage' : deviceModel) + '.png';
      return unifiImagesUrlPrefix + unifiControllerimagesPaths[deviceModel] + '/grid.png';
    /** Global functions ********************************************************************************/
    // My global functions for state and listener initialization
    // see doc https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#global-functions
    const resetStatesOnReload = false; // Enable only when actively developing
    let statesInitializing = 0; // Semaphore for runAfterInitialization, handled by initializeState
    // Helper function for states setup
    function runAfterInitialization(callback) {
      log(`States initializing: ${statesInitializing}`, 'silly');
      if (statesInitializing <= 0) {
          callback();
          return;
      // Important: use timout instead of wait!
      this.setTimeout(() => runAfterInitialization(callback), 100);
    function initializeState(stateId, defaultValue, common, listenerChangeType?: string, listenerCallback?: CallableFunction) {
      const registerListener = () => {
          if (listenerChangeType) {
              // Register listener only after all states are initialized
                  on(stateId, listenerChangeType, listenerCallback);
                  log(`Registered listener on ${stateId}`, 'debug');
      const myCreateState = () => {
          statesInitializing++;
          log(`myCreateState: increased states initializing: ${statesInitializing}`, 'silly');
          createState(stateId, defaultValue , common, () => {
              log(`Created state ${stateId}`, 'debug');
              registerListener();
              statesInitializing--;
              log(`myCreateState: reduced states initializing: ${statesInitializing}`, 'silly');
      const resetState = () => {
          log(`resetState: increased states initializing: ${statesInitializing}`, 'silly');
          deleteState(stateId, () => {
              log(`Deleted state ${stateId}`, 'debug');
              myCreateState();
              log(`resetState: reduced states initializing: ${statesInitializing}`, 'silly');
      if (!existsState(stateId)) {
          myCreateState();
      } else if (resetStatesOnReload) {
          resetState();
      } else {
          registerListener();
    function getStateIfExists(stateId) {
      // Avoid warning when state does not exists
          return null;
      return getState(stateId);
    function getStateValue(stateId) {
      return (getStateIfExists(stateId) || {}).val || null;
    Gruß Ralf
    • CodierknechtC Codierknecht
      @scrounger sagte in Test Adapter Unifi Network:
      issue auf github
      https://github.com/Scrounger/ioBroker.unifi-network/issues/25
      ScroungerS Offline
      ScroungerS Offline
      Scrounger
      @codierknecht sagte in Test Adapter Unifi Network:
      issue auf github
      Sollte mit version 1.1.2 behoben sein.
      @nashra sagte in Test Adapter Unifi Network:
      Ich nutze das schon lange nicht mehr, deshalb steck ich da auch keine Zeit rein, sorry.
      Anpassung sollte aber nicht so schwer sein, man muss ja nur auf die neue Struktur ändern.
      NashraN CodierknechtC 2 Antworten Letzte Antwort
      • ScroungerS Scrounger
        issue auf github
        NashraN Offline
        NashraN Offline
        Nashra
        schrieb am zuletzt editiert von Nashra
        issue auf github
        Neue Struktur wäre kein Problem wenn ich Ahnung von TypeScript hätte.
        Nur leider habe ich die nicht 😞
        Gruß Ralf
          issue auf github
          CodierknechtC Offline
          Codierknecht
          Nicht wirklich :-(
          unifi-network.0
          2025-10-02 15:12:52.673	error	[login]: Login to the Unifi-Network controller API failed! (host: 192.168.179.13:8443, site: D*****V)
          unifi-network.0
          2025-10-02 15:12:52.672	error	[NetworkApi.loginController] error: TypeError: selfHostedCookie.find is not a function, stack: TypeError: selfHostedCookie.find is not a function at NetworkApi.loginController (file:///opt/iobroker/node_modules/iobroker.unifi-network/build/lib/api/network-api.js:139:57) at process.processTicksAndRejections (node:internal/process/task_queues:105:5) at async NetworkApi.login (file:///opt/iobroker/node_modules/iobroker.unifi-network/build/lib/api/network-api.js:74:34) at async UnifiNetwork.login (file:///opt/iobroker/node_modules/iobroker.unifi-network/build/main.js:343:41) at async UnifiNetwork.establishConnection (file:///opt/iobroker/node_modules/iobroker.unifi-network/build/main.js:310:17) at async UnifiNetwork.onReady (file:///opt/iobroker/node_modules/iobroker.unifi-network/build/main.js:85:21)
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          ScroungerS 1 Antwort Letzte Antwort
            Nicht wirklich :-(
            unifi-network.0
            unifi-network.0
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            schrieb am zuletzt editiert von Scrounger
            @codierknecht
            teste mal die v1.1.3
            • E Offline
              emil70
              schrieb am zuletzt editiert von emil70
              Teste das gerade auch. Danke für den Adapter
              Blöde Frage:
              [updateClients]: Discovered 152 disconnected clients (clients: 101, guests: 0, vpn: 0, blacklisted: 0)
              Wo finde ich die in der UniFi-OS 4.4.2 Netzwerk 9.4.19
              damit ich die mal löschen kann
              gruss emil70
              iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
              • crunchipC Offline
                crunchipC Offline
                dass ich nur das intergriere was ich wirklich brauche
                ist das auch mit geplant?
                [onNetworkEvent]: not implemented event (key: EVT_IPS_IpsAlert,) - Please report this to the developer and creating an issue on github!
                  ScroungerS Offline
                  ScroungerS Offline
                  Scrounger
                  @crunchip sagte in Test Adapter Unifi Network:
                  Da jede HW andere events haben kann, kenn ich natürlich nicht alle.
                  Wie im log beschrieben, ein issue aufmachen mit allen daten aus der meldung, ggf. vertrauliches infos abändern!
                  Dann schau ich mir an, ob es sinn macht dieses event zu implementieren oder ob es auf die ignore list kommt.
                    crunchipC Offline
                    crunchipC Offline
                    @scrounger ich brauch dies nicht,wollt eher damit den Hinweis geben, daß dies auftaucht. Kann aber wenn gewünscht, trotzdem eins erstellen
                    • ScroungerS Offline
                      ScroungerS Offline
                      Scrounger
                      @crunchip
                      @crunchip
                      Ja wäre super weil sonst komnt halt immer Mal wieder diese warn Meldung im Log.
                        @codierknecht
                        Codierknecht
                        Die gute Nachricht: Die Instanz wird grün.
                        Die schlechte: Ich erhalte keine Daten :-(
                        FYI: Es läuft hier nur ein Unifi-AP-Pro. Also ausschließlich WLAN-Clients und kein Unifi-OS.
                        unifi-network.0
                        	2025-10-05 17:55:09.066	info	[onReady]: WebSocket listener to realtime API successfully started
                        unifi-network.0
                        	2025-10-05 17:55:09.058	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                        unifi-network.0
                        	2025-10-05 17:55:09.047	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                        unifi-network.0
                        	2025-10-05 17:55:09.020	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                        unifi-network.0
                        	2025-10-05 17:55:08.920	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
                        unifi-network.0
                        	2025-10-05 17:55:05.886	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
                        unifi-network.0
                        	2025-10-05 17:55:02.841	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
                        unifi-network.0
                        	2025-10-05 17:54:59.806	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
                        unifi-network.0
                        	2025-10-05 17:54:56.772	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
                        unifi-network.0
                        	2025-10-05 17:54:53.740	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
                        unifi-network.0
                        	2025-10-05 17:54:50.688	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
                        unifi-network.0
                        	2025-10-05 17:54:47.654	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
                        unifi-network.0
                        	2025-10-05 17:54:44.610	info	[login]: WebSocket connection to realtime API successfully established
                        unifi-network.0
                        	2025-10-05 17:54:44.587	debug	[NetworkApi.loginController] login to self hosted UniFi controller successful.
                        unifi-network.0
                        	2025-10-05 17:54:44.263	info	[login]: Logged in successfully to the Unifi-Network controller (host: 192.168.179.13:8443, site: D*****V, isUnifiOs: false)
                        unifi-network.0
                        	2025-10-05 17:54:44.262	debug	[NetworkApi.loginController] login to self hosted UniFi controller successful.
                        unifi-network.0
                        	2025-10-05 17:54:43.974	debug	[NetworkApi.logout] Logging out and clearing credentials.
                        unifi-network.0
                        	2025-10-05 17:54:43.957	info	starting. Version 1.1.3 (non-npm: Scrounger/ioBroker.unifi-network#fab63502974c2b23b621ebc96844f9d5bc0c61ef) in /opt/iobroker/node_modules/iobroker.unifi-network, node: v22.20.0, js-controller: 7.0.7
                        unifi-network.0
                        	2025-10-05 17:54:43.896	debug	States connected to redis: 0.0.0.0:9010
                        unifi-network.0
                        	2025-10-05 17:54:43.846	debug	States create User PubSub Client
                        unifi-network.0
                        	2025-10-05 17:54:43.846	debug	States create System PubSub Client
                        unifi-network.0
                        	2025-10-05 17:54:43.841	debug	Redis States: Use Redis connection: 0.0.0.0:9010
                        unifi-network.0
                        	2025-10-05 17:54:43.829	debug	Objects connected to redis: 0.0.0.0:9011
                        unifi-network.0
                        	2025-10-05 17:54:43.827	debug	Objects client initialize lua scripts
                        unifi-network.0
                        	2025-10-05 17:54:43.812	debug	Objects create User PubSub Client
                        unifi-network.0
                        	2025-10-05 17:54:43.812	debug	Objects create System PubSub Client
                        unifi-network.0
                        	2025-10-05 17:54:43.811	debug	Objects client ready ... initialize now
                        unifi-network.0
                        	2025-10-05 17:54:43.798	debug	Redis Objects: Use Redis connection: 0.0.0.0:9011
                        host.iobroker
                        	2025-10-05 17:54:43.193	info	instance system.adapter.unifi-network.0 in version "1.1.3" (non-npm: Scrounger/ioBroker.unifi-network#fab63502974c2b23b621ebc96844f9d5bc0c61ef) started with pid 3818642
                        host.iobroker
                        	2025-10-05 17:54:42.900	info	"system.adapter.unifi-network.0" enabled
                        Meine Einstellungen:
                        Vielleicht korrigierts Du bei Gelegenheit auch den Fauxpas der automatischen Übersetzung 😁
                          @crunchip
                          @crunchip
                          Rene55R Offline
                          Rene55R Offline
                          Rene55
                          @scrounger Ist das auch wichtig, weil "Please report this to the developer "?
                          warn	[onNetworkEvent]: not implemented event (key: EVT_IPS_IpsAlert,) -
                          meta: {
                             "rc":"ok",
                             "message":"events"
                          data: {
                             "dest_ip":"192.168.172.110",
                             "dest_port":80,
                             "dst_mac":"bc:24:11:4f:45:38",
                             "event_type":"alert",
                             "flow":{
                             	"bytes_toclient":0,
                             	"bytes_toserver":66,
                             	"pkts_toclient":0,
                             	"pkts_toserver":1,
                             	"start":"2025-10-03T22:07:34.728843 0200"
                             "flow_id":211562254442251,
                             "host":"usg-sensor",
                             "in_iface":"eth4",
                             "metadata":{
                             	"flowbits":["ET.Evil","ET.DshieldIP"]
                             "out_iface":"lo",
                             "proto":"TCP",
                             "src_ip":"204.76.203.212",
                             "src_mac":"9e:05:d6:b5:df:28",
                             "src_port":35936,
                             "timestamp":1759522054,
                             "ubnt":{
                             	"affected_products":"",
                             	"classtype":"",
                             	"counterpart_hostnames":[],
                             	"cve_reference":"",
                             	"description":"",
                             	"event_version":"3.1",
                             	"reference_url":[],
                             	"signature_type":"ET",
                             	"ubnt_category":"DSHIELD"
                             "usgip":"91.7.160.82",
                             "unique_alertid":"7-2025-10-03T22:07:34.728843 0200",
                             "srcipGeo":{
                             	"address":"204.76.203.212",
                             	"asn":51396,
                             	"organization":"Pfcloud UG",
                             	"isp":"Pfcloud UG",
                             	"country_code":"NL",
                             	"country_name":"The Netherlands",
                             	"continent_code":"EU",
                             	"city":"Eygelshoven",
                             	"latitude":50.8897,
                             	"longitude":6.0563,
                             	"accuracy":20,
                             	"timezone":"Europe/Amsterdam"
                             "dstipGeo":{
                             	"address":"192.168.172.110",
                             	"asn":0,
                             	"organization":"",
                             	"isp":"",
                             	"country_code":"",
                             	"country_name":"",
                             	"continent_code":"",
                             	"city":"",
                             	"latitude":0,
                             	"longitude":0,
                             	"accuracy":0,
                             	"timezone":""
                             "usgipGeo":{
                             	"address":"91.7.160.82",
                             	"asn":3320,
                             	"organization":"Deutsche Telekom AG",
                             	"isp":"VipNet Telecom",
                             	"country_code":"DE",
                             	"country_name":"Germany",
                             	"city":"Köln",
                             	"latitude":50.9427,
                             	"longitude":6.9584,
                             	"accuracy":5,
                             	"timezone":"Europe/Berlin"
                             "srcipCountry":"NL",
                             "srcipASN":"51396 Pfcloud UG",
                             "usgipCountry":"DE",
                             "usgipASN":"3320 Deutsche Telekom AG",
                             "catname":"DSHIELD",
                             "inner_alert_action":"allowed",
                             "inner_alert_category":"Misc Attack",
                             "inner_alert_gid":1,
                             "inner_alert_metadata":{
                             	"affected_product":["Any"],
                             	"attack_target":["Any"],
                             	"created_at":["2010_12_30"],
                             	"deployment":["Perimeter"],
                             	"signature_severity":["Major"],
                             	"tag":["Dshield"],
                             	"ubnt_category":["DSHIELD"],
                             	"updated_at":["2025_10_02"]
                             "inner_alert_rev":7515,
                             "inner_alert_severity":2,
                             "inner_alert_signature":"ET DROP Dshield Block Listed Source group 1",
                             "inner_alert_signature_id":2402000,"key":"EVT_IPS_IpsAlert",
                             "subsystem":"www",
                             "is_negative":true,
                             "site_id":"667fd2400487b63810d07718",
                             "time":1759522054000,
                             "datetime":"2025-10-03T20:07:34Z",
                             "msg":"IPS Alert 2: Misc Attack.
                             		Signature ET DROP Dshield Block Listed Source group 1.
                             		to: 192.168.172.110:80,
                             		protocol: TCP",
                             "_id":"68e02ddd9c5b50427590ff3d"
                          • crunchipC Offline
                            crunchipC Offline
                            @rene55 mach deine privaten Daten raus
                            lobomauL Rene55R 2 Antworten Letzte Antwort
                              lobomauL Offline
                              lobomauL Offline
                              lobomau
                              schrieb am zuletzt editiert von lobomau
                              @Scrounger noch habe ich den Adapter nicht am Laufen. Bisher hatte ich den Unifi-Adapter am Laufen.
                              Ich habe einen "Cloud Gateway Ultra". Ich bin davon ausgegangen, dass dies ein Unifi OS ist. Es läuft Version Network 9.4.19, UniFi OS 4.3.9. Einloggen kann ich mich über 192.168.1.1. Ich gebe da keinen Port zusätzlich an. Der andere Adapter hingegen läuft auf port 8443. Muss ich den hier auch einstellen? Das geht ja nur ohne "ist Unifi OS". Und habe ich "default" controller site? Wie finde ich es heraus?
                              Edit: nee, der andere Adapter hat auch keinen Port vorgewählt... es erscheint geschwächt 8443 (hatte ich früher mal als container laufen)
                              Edit2: ist wohl default:
                              unifi-network.0
                              2025-10-05 21:11:15.517	info	[onReady]: WebSocket listener to realtime API successfully started
                              unifi-network.0
                              2025-10-05 21:11:15.503	error	[login]: Login to the Unifi-Network controller API failed! (host: 192.168.1.1, site: default)
                              unifi-network.0
                              2025-10-05 21:11:15.502	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
                              unifi-network.0
                              2025-10-05 21:11:12.184	info	starting. Version 1.1.3 (non-npm: Scrounger/ioBroker.unifi-network#fab63502974c2b23b621ebc96844f9d5bc0c61ef) in /opt/iobroker/node_modules/iobroker.unifi-network, node: v22.20.0, js-controller: 7.0.7
                              Host: NUC8i3 mit Proxmox:
                              • Slave: Pi4
                                Rene55R Offline
                                Rene55R Offline
                                Rene55
                                @crunchip Thanks, aber die Daten sind schon verfälscht. 🤓
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  unifi-network.0
                                  host.iobroker
                                  host.iobroker
                                  ScroungerS Offline
                                  ScroungerS Offline
                                  Scrounger
                                  @codierknecht
                                  also ich hab jetzt extra mal einen self hosted controller in einem proxmox lxc aufgesetzt und auch ne AP dran gehängt.
                                  Läuft bei mir ohne probleme. Evtl. wird da irgendwas geblockt?
                                  Test mal die v1.1.4, hab ein paar debug info mit eingebaut, damit man sieht was er da genau macht. Am besten den Adapter davor komplett mal löschen.
                                  Und bitte info's nach dem test im issue auf github posten!
                                  @lobomau
                                  Test mal die v1.1.4, UniFi OS oder self hosted wird jetzt automatusch erkannt. Am besten den Adapter davor komplett mal löschen.
                                  Wenn noch immer Probleme bestehen, bitte issue auf github erstellen
                                  lobomauL CodierknechtC 2 Antworten Letzte Antwort
                                    @codierknecht
                                    @lobomau
                                    lobomauL Offline
                                    lobomauL Offline
                                    lobomau
                                    Edit. ok... zuerst code eintragen und hinterher den Codeknopf drüber. Hab ich sonst andersrum gemacht...
                                    @scrounger haben die bei Github etwas geändert? Sieht in der Preview nicht nach Code aus:
                                    • Slave: Pi4
                                    • lobomauL lobomau
                                      ScroungerS Offline
                                      ScroungerS Offline
                                      Scrounger
                                      @lobomau
                                      https://docs.github.com/en/get-started/writing-on-github/working-with-advanced-formatting/creating-and-highlighting-code-blocks#fenced-code-blocks
                                        @codierknecht
                                        @lobomau
                                        Codierknecht
                                        unifi-network.0
                                        2025-10-06 11:25:53.661	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/device?separateUnmanaged=false&includeTrafficUsage=false)
                                        unifi-network.0
                                        2025-10-06 11:25:50.633	info	[login]: WebSocket connection to realtime API successfully established
                                        unifi-network.0
                                        2025-10-06 11:25:50.630	info	[login]: Logged in successfully to the Unifi-Network controller (host: 192.168.179.13:8443, site: D*****V, isUnifiOs: false)
                                        unifi-network.0
                                        2025-10-06 11:25:50.629	debug	[NetworkApi.loginController] login to self hosted UniFi controller successful.
                                        unifi-network.0
                                        2025-10-06 11:25:50.302	debug	[NetworkApi.logout] Logging out and clearing credentials.
                                        unifi-network.0
                                        2025-10-06 11:25:50.292	debug	[NetworkApi.logout] Logging out and clearing credentials.
                                        unifi-network.0
                                        2025-10-06 11:25:50.292	warn	[aliveChecker]: No connection to the Unifi-Network controller -> restart connection (retries: 0, no data since 55s)
                                        unifi-network.0
                                        2025-10-06 11:25:20.281	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                        unifi-network.0
                                        2025-10-06 11:25:20.261	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                        unifi-network.0
                                        2025-10-06 11:25:20.231	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                        unifi-network.0
                                        2025-10-06 11:25:20.120	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/wlan/enriched-configuration)
                                        unifi-network.0
                                        2025-10-06 11:25:17.100	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/wlan/enriched-configuration)
                                        unifi-network.0
                                        2025-10-06 11:25:14.060	debug	[createOrUpdateChannel]: creating channel 'wlan'
                                        unifi-network.0
                                        2025-10-06 11:25:14.053	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/clients/history?includeUnifiDevices=true&withinHours=0)
                                        unifi-network.0
                                        2025-10-06 11:25:11.024	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/clients/history?includeUnifiDevices=true&withinHours=0)
                                        unifi-network.0
                                        2025-10-06 11:25:07.992	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/clients/active?includeTrafficUsage=false&includeUnifiDevices=true)
                                        unifi-network.0
                                        2025-10-06 11:25:04.964	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/clients/active?includeTrafficUsage=false&includeUnifiDevices=true)
                                        unifi-network.0
                                        2025-10-06 11:25:01.941	debug	[createOrUpdateChannel]: creating channel 'clients'
                                        unifi-network.0
                                        2025-10-06 11:25:01.939	debug	[createOrUpdateChannel]: creating channel 'clients.vpn'
                                        unifi-network.0
                                        2025-10-06 11:25:01.937	debug	[createOrUpdateChannel]: creating channel 'clients.guests'
                                        unifi-network.0
                                        2025-10-06 11:25:01.934	debug	[createOrUpdateChannel]: creating channel 'clients.users'
                                        unifi-network.0
                                        2025-10-06 11:25:01.929	debug	[createOrUpdateChannel]: creating channel 'devices'
                                        unifi-network.0
                                        2025-10-06 11:25:01.927	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/device?separateUnmanaged=false&includeTrafficUsage=false)
                                        unifi-network.0
                                        2025-10-06 11:24:58.905	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/device?separateUnmanaged=false&includeTrafficUsage=false)
                                        unifi-network.0
                                        2025-10-06 11:24:55.850	info	[login]: WebSocket connection to realtime API successfully established
                                        unifi-network.0
                                        2025-10-06 11:24:55.836	debug	[NetworkApi.loginController] login to self hosted UniFi controller successful.
                                        unifi-network.0
                                        2025-10-06 11:24:55.565	info	[login]: Logged in successfully to the Unifi-Network controller (host: 192.168.179.13:8443, site: D*****V, isUnifiOs: false)
                                        unifi-network.0
                                        2025-10-06 11:24:55.564	debug	[NetworkApi.loginController] login to self hosted UniFi controller successful.
                                        unifi-network.0
                                        2025-10-06 11:24:55.325	debug	[NetworkApi.logout] Logging out and clearing credentials.
                                        unifi-network.0
                                        2025-10-06 11:24:55.325	debug	[NetworkApi.detectUnifiOs] self hosted controller detected
                                        unifi-network.0
                                        2025-10-06 11:24:55.325	debug	[NetworkApi.detectUnifiOs] detect self hosted controller repsonse: {"statusCode":302,"headers":{"location":"/manage","content-length":"0","date":"Mon, 06 Oct 2025 09:24:55 GMT","keep-alive":"timeout=30","connection":"keep-alive"},"trailers":{},"opaque":null,"body":{"_events":{},"_readableState":{"highWaterMark":65536,"buffer":[],"bufferIndex":0,"length":0,"pipes":[],"awaitDrainWriters":null}}}
                                        unifi-network.0
                                        2025-10-06 11:24:55.282	info	starting. Version 1.1.4 (non-npm: Scrounger/ioBroker.unifi-network) in /opt/iobroker/node_modules/iobroker.unifi-network, node: v22.20.0, js-controller: 7.0.7
                                        unifi-network.0
                                        2025-10-06 11:24:55.193	debug	States connected to redis: 0.0.0.0:9010
                                        unifi-network.0
                                        2025-10-06 11:24:55.137	debug	States create User PubSub Client
                                        unifi-network.0
                                        2025-10-06 11:24:55.136	debug	States create System PubSub Client
                                        unifi-network.0
                                        2025-10-06 11:24:55.131	debug	Redis States: Use Redis connection: 0.0.0.0:9010
                                        unifi-network.0
                                        2025-10-06 11:24:55.118	debug	Objects connected to redis: 0.0.0.0:9011
                                        unifi-network.0
                                        2025-10-06 11:24:55.116	debug	Objects client initialize lua scripts
                                        unifi-network.0
                                        2025-10-06 11:24:55.097	debug	Objects create User PubSub Client
                                        unifi-network.0
                                        2025-10-06 11:24:55.096	debug	Objects create System PubSub Client
                                        unifi-network.0
                                        2025-10-06 11:24:55.095	debug	Objects client ready ... initialize now
                                        unifi-network.0
                                        2025-10-06 11:24:55.082	debug	Redis Objects: Use Redis connection: 0.0.0.0:9011
                                        Geht gleich auch noch an GH
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          unifi-network.0
                                          Codierknecht
                                          @Scrounger
                                          Mit einer Site "default" klappt's dann auch. Issue habe ich geschlossen.
