  3. Off Topic
  4. Pflege des Betriebssystems
  5. System krumm?
System krumm?
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
27 Beiträge 4 Kommentatoren 2.9k Aufrufe 1 Beobachtet
  • L luft-post
    bei Eingabe kommt nix
    komme nur mit Strg+C wieder raus
    @luft-post
    Ruf das mal so auf:
    curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
    L 1 Antwort Letzte Antwort
    • L luft-post
      @thomas-braun ja, das funktioniert
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.12.34+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       20:40:20 up 26 min,  3 users,  load average: 0.69, 0.61, 0.46
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2025-09-30 20:40:20 CEST
                 Universal time: Tue 2025-09-30 18:40:20 UTC
                       RTC time: Tue 2025-09-30 18:40:20
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi systemd-journal iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         true
      Display-Manager:        * lightdm.service - Light Display Manager
      Desktop:
      Session:                tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.t         arget' or run 'iobroker fix'
      *** MEMORY ***
      Mem:             17G        3.8G         11G         36M        1.5G         13G
      Swap:           536M          0B        536M
      Total:           17G        3.8G         12G
      Active iob-Instances:   31
              16219 M total memory
               3594 M used memory
               3393 M active memory
                913 M inactive memory
              11392 M free memory
                155 M buffer memory
               1231 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 20:40:20 up 26 min,  3 users,  load average: 0.69, 0.61, 0.46
      Tasks: 286 total,   1 running, 285 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  16219.2 total,  11393.0 free,   3594.8 used,   1386.3 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.  12624.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  7.9G     0  7.9G   0% /dev
      tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
      /dev/nvme0n1p2 ext4      117G   12G  100G  11% /
      tmpfs          tmpfs     8.0G  400K  8.0G   1% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/nvme0n1p1 vfat      510M   69M  442M  14% /boot/firmware
      /dev/sda       ext4      234G   28K  222G   1% /backup
      tmpfs          tmpfs     1.6G  176K  1.6G   1% /run/user/1000
      [Tue Sep 30 20:14:12 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory num         a_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=88:A2:9E:1C:3B:23 vc_mem.mem_ba         se=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=541a5899-02 rootfstype=ext4 fsck.repair=         yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
      [Tue Sep 30 20:14:13 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6ecfcd5-2703-41bf-9301-10c403b6fb0c ro with ordered data mode. Qu         ota mode: none.
      [Tue Sep 30 20:14:14 2025] EXT4-fs (nvme0n1p2): re-mounted d6ecfcd5-2703-41bf-9301-10c403b6fb0c r/w.
      [Tue Sep 30 20:14:15 2025] EXT4-fs (sda): mounted filesystem 99c4331b-c542-48d4-9081-700cecce1b69 r/w with ordered data mode. Quota m         ode: none.
      Show mounted filesystems:
      TARGET               SOURCE         FSTYPE      OPTIONS
      /                    /dev/nvme0n1p2 ext4        rw,noatime
      |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      |-/boot/firmware     /dev/nvme0n1p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors
      `-/backup            /dev/sda       ext4        rw,noatime,stripe=8191
      /var:
      2.6G    /var/
      1.4G    /var/lib
      1.2G    /var/lib/mysql
      989M    /var/lib/mysql/iobroker
      697M    /var/cache
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      677M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      716M    /opt/iobroker/iobroker-data/
      443M    /opt/iobroker/iobroker-data/files
      148M    /opt/iobroker/iobroker-data/backup-objects
      72M     /opt/iobroker/iobroker-data/files/vis-2
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      72M     /opt/iobroker/iobroker-data/objects.jsonl
      52M     /opt/iobroker/iobroker-data/states.jsonl
      30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231009140255-if00
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.19.0
      /usr/bin/node           v22.19.0
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.19.0-1nodesource1
        Candidate: 22.20.0-1nodesource1
        Version table:
           22.20.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
       *** 22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           18.20.4+dfsg-1~deb12u1 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 1564)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.2
      javascript:     8.9.2
      nodejs modules from github:     6
      +-- iobroker.alpha2@1.0.3 (git+ssh://git@github.com/Eisbaeeer/ioBroker.alpha2.git#803bd6302dca3e4b44164d23e58a8a096e21e972)
      +-- iobroker.fully-tablet-control@0.3.0-beta.5 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#a9a607c702141a6568b         271464570809d9a27ecf9)
      +-- iobroker.homepilot20@0.0.31 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#201286583714176646bfa1030a7809067872         64e3)
      +-- iobroker.onvif-alt@0.2.0 (git+ssh://git@github.com/Jey-Cee/iobroker.onvif-alt.git#7cd1174688b599cad552d2c6881cd1b6684f99a9)
      +-- iobroker.siegenia@1.1.1 (git+ssh://git@github.com/Apollon77/ioBroker.siegenia.git#b071bc8a25c04204898575d6a2f7e8aef03d2af7)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#38686d69a56249fda3acbcfae9         485a372b9a3b56)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081,          bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
      + system.adapter.alpha2.0                 : alpha2                : raspberrypi                              -  enabled
        system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
        system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
        system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.daswetter.1              : daswetter             : raspberrypi                              -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
        system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              - disabled
        system.adapter.fully-tablet-control.0   : fully-tablet-control  : raspberrypi                              - disabled
        system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.homepilot20.0            : homepilot20           : raspberrypi                              -  enabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1885,          bind: 0.0.0.0
        system.adapter.notification-manager.0   : notification-manager  : raspberrypi                              - disabled
        system.adapter.onvif-alt.0              : onvif-alt             : raspberrypi                              - disabled
      + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
        system.adapter.pushover.0               : pushover              : raspberrypi                              - disabled
      + system.adapter.pushsafer.0              : pushsafer             : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
        system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              - disabled
        system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
      + system.adapter.siegenia.0               : siegenia              : raspberrypi                              -  enabled
      + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
        system.adapter.smartcontrol.1           : smartcontrol          : raspberrypi                              - disabled
        system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883,          bind: 192.168.2.70
        system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
        system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
        system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
      + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
        system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
      + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088,          bind: 0.0.0.0, run as: admin
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
        system.adapter.tradfri.0                : tradfri               : raspberrypi                              - disabled
        system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
        system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
        system.adapter.weatherunderground.1     : weatherunderground    : raspberrypi                              - disabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082,          bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
        system.adapter.wifilight.0              : wifilight             : raspberrypi                              - disabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/t         tyACM0
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Upgrade policy: none
      Installed ioBroker-Adapters
      Adapter    "admin"        : 7.7.2    , installed 7.7.2
      Adapter    "alarm"        : 3.7.4    , installed 3.7.4
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "alpha2"       : 1.0.0    , installed 1.0.3
      Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.13.1  , installed 2.13.1
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "hue"          : 3.16.2   , installed 3.16.2
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "iot"          : 3.3.0    , installed 3.4.3
      Adapter    "jarvis"       : 3.1.8    , installed 3.2.0-rc.5
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "notification-manager": 1.3.0, installed 1.3.0
      Adapter    "parser"       : 2.2.4    , installed 2.2.4
      Adapter    "ping"         : 1.6.2    , installed 1.7.9
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "pushsafer"    : 1.1.0    , installed 1.1.0
      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "schoolfree"   : 1.1.12   , installed 1.1.12
      Adapter    "shuttercontrol": 2.0.5   , installed 2.0.5
      Adapter    "siegenia"     : 1.1.1    , installed 1.1.1
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
      Objects and States
      Objects:        38379
      States:         29235
      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists... Done
      Pending Updates: 39
      *** Listening Ports ***
      tcp        0      0 192.168.2.70:1883       0.0.0.0:*               LISTEN      1001       15443      2395/io.sonoff.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5779       795/sshd: /usr/sbin
      tcp        0      0 192.168.2.70:42010      0.0.0.0:*               LISTEN      1001       11041      1805/io.hm-rpc.0
      tcp        0      0 192.168.2.70:42001      0.0.0.0:*               LISTEN      1001       14402      1820/io.hm-rpc.1
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8756       762/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8765       762/iobroker.js-con
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          8208       761/cupsd
      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      112        5829       855/mariadbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5781       795/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          8207       761/cupsd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10643      1508/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16265      2854/io.web.0
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17467      2740/io.terminal.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6363       592/avahi-daemon: r
      udp        0      0 0.0.0.0:42064           0.0.0.0:*                           104        6365       592/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        6364       592/avahi-daemon: r
      udp6       0      0 :::40252                :::*                                104        6366       592/avahi-daemon: r
      udp6       0      0 fe80::ba24:34b9:1b1:546 :::*                                0          10567      668/NetworkManager
      2025-09-30 20:36:12.340  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.5 (ac         k = true)
      2025-09-30 20:36:24.474  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.4 (ac         k = true)
      2025-09-30 20:36:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 48 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 40 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 46 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 34 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257407830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257407830,"c":"script.js.common.11_FensterUeberwachungOG"})
      2025-09-30 20:36:48.957  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
      2025-09-30 20:36:49.004  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.5 (ac         k = true)
      2025-09-30 20:37:01.352  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack =          true)
      2025-09-30 20:37:13.485  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
      2025-09-30 20:37:25.633  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45.1 (ack =          true)
      2025-09-30 20:37:25.677  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.4 (ac         k = true)
      2025-09-30 20:37:37.818  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45.2 (ack =          true)
      2025-09-30 20:37:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 49 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 41 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 47 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 35 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257467830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257467830,"c":"script.js.common.11_FensterUeberwachungOG"})
      2025-09-30 20:38:02.471  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45.1 (ack =          true)
      2025-09-30 20:38:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 50 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 42 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 48 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 36 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257527830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257527830,"c":"script.js.common.11_FensterUeberwachungOG"})
      2025-09-30 20:38:51.080  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
      2025-09-30 20:39:03.580  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.5 (ac         k = true)
      2025-09-30 20:39:15.703  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack =          true)
      2025-09-30 20:39:27.846  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
      2025-09-30 20:39:39.955  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.6 (ac         k = true)
      2025-09-30 20:39:47.804  - info: javascript.0 (1605) script.js.common.10_FensterUeberwachungEG: Reaching Meldung, msg= Gästebadfenste         r seit 8 Std. 8 Min. geöffnet! NoMsgAtPresence= false Presence= true
      2025-09-30 20:39:47.804  - info: javascript.0 (1605) script.js.common.10_FensterUeberwachungEG: Reaching WriteMessageLog, Message=Gäs         tebadfenster seit 8 Std. 8 Min. geöffnet!
      2025-09-30 20:39:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 51 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 43 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 49 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 37 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257587830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257587830,"c":"script.js.common.11_FensterUeberwachungOG"})
      2025-09-30 20:39:52.088  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack =          true)
      2025-09-30 20:40:16.781  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack =          true)
      2025-09-30 20:40:28.904  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.7 (ack =          true)
      2025-09-30 20:40:47.831  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 52 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 44 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 50 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 38 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257647831,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257647831,"c":"script.js.common.11_FensterUeberwachungOG"})
      iob diag has finished.
      pi@raspberrypi:~ $
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
      iob diag has finished.l here for C&P =============":0,"from":"system.adapter.javascript.0","lc":1759257647831,"c":"script.js.common.11_Fenster
      @luft-post sagte in Test Adapter SmartControl 0.3.x-0.6.x Latest:
      Your zigbee.0 COM-Port is NOT matchingYour zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: 'by-id'. Please check your setting.
      Pending Updates: 39
      Korrigier das schon mal und nach einem Reboot
      cd /opt/iobroker/ && npm ls
      zeigen.
      • L luft-post
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           536M          0B        536M
        Total:           17G        3.8G         12G
                 3594 M used memory
                11392 M free memory
                  155 M buffer memory
                 1231 M swap cache
                  511 M total swap
                    0 M used swap
                  511 M free swap
        *** FILESYSTEM ***
        /var:
        2.6G    /var/
        1.4G    /var/lib
        1.2G    /var/lib/mysql
        697M    /var/cache
        USB-Devices by-id:
        HINT:
        /dev/ttyACM0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.3
        /usr/bin/npx            10.9.3
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.2
        javascript:     8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        38379
        States:         29235
        Pending Updates: 39
        pi@raspberrypi:~ $
        Script v.2025-08-09
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
        @luft-post
        Und den
        iob fix
        kannste auch mal drüber jagen.
          @luft-post
          Und den
          iob fix
          luft-post
          so, ich denke ich habe alles gemacht. hier die gewünschte Ausgabe. iob fix läuft gerade noch
          pi@raspberrypi:~ $ cd /opt/iobroker/ && npm ls
          iobroker.inst@3.0.0 /opt/iobroker
          ├── @iobroker-javascript.0/hue-push-client@npm:hue-push-client@1.0.5
          ├── iobroker.admin@7.7.2
          ├── iobroker.alarm@3.7.4
          ├── iobroker.alexa2@3.27.3
          ├── iobroker.alpha2@1.0.3 (git+ssh://git@github.com/Eisbaeeer/ioBroker.alpha2.git#803bd6302dca3e4b44164d23e58a8a096e21e972)
          ├── iobroker.awtrix-light@2.0.0
          ├── iobroker.backitup@3.3.5
          ├── iobroker.birthdays@4.0.0
          ├── iobroker.chromecast@4.0.0
          ├── iobroker.cloud@5.0.1
          ├── iobroker.daswetter@3.2.3
          ├── iobroker.device-reminder@3.1.2
          ├── iobroker.device-watcher@2.13.1
          ├── iobroker.discovery@5.0.0
          ├── iobroker.dwd@2.8.5
          ├── iobroker.email@2.0.4
          ├── iobroker.fb-checkpresence@1.4.0
          ├── iobroker.feiertage@1.2.1
          ├── iobroker.flot@1.12.0
          ├── iobroker.fritzbox@0.6.0
          ├── iobroker.fullcalendar@2.4.5
          ├── iobroker.fully-tablet-control@0.3.0-beta.5 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#a9a607c702141a6568b271464570809d9a27ecf9)
          ├── iobroker.fullybrowser@3.1.2
          ├── iobroker.history@3.0.1
          ├── iobroker.hm-rega@5.1.0
          ├── iobroker.hm-rpc@2.0.2
          ├── iobroker.homepilot20@0.0.31 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#201286583714176646bfa1030a780906787264e3)
          ├── iobroker.hue@3.16.2
          ├── iobroker.ical@1.16.2
          ├── iobroker.icons-mfd-png@1.2.1
          ├── iobroker.icons-mfd-svg@1.2.0
          ├── iobroker.iot@3.4.3
          ├── iobroker.jarvis@3.2.0-rc.5
          ├── iobroker.javascript@8.9.2
          ├── iobroker.js-controller@7.0.7
          ├── iobroker.mqtt@6.1.4
          ├── iobroker.notification-manager@1.3.0
          ├── iobroker.onvif-alt@0.2.0 (git+ssh://git@github.com/Jey-Cee/iobroker.onvif-alt.git#7cd1174688b599cad552d2c6881cd1b6684f99a9)
          ├── iobroker.parser@2.2.4
          ├── iobroker.ping@1.7.9
          ├── iobroker.pollenflug@2.0.0
          ├── iobroker.pushover@4.1.0
          ├── iobroker.pushsafer@1.1.0
          ├── iobroker.rpi2@2.4.0
          ├── iobroker.sayit@5.0.0
          ├── iobroker.schoolfree@1.1.12
          ├── iobroker.shuttercontrol@2.0.5
          ├── iobroker.siegenia@1.1.1 (git+ssh://git@github.com/Apollon77/ioBroker.siegenia.git#b071bc8a25c04204898575d6a2f7e8aef03d2af7)
          ├── iobroker.smartcontrol@2.0.1
          ├── iobroker.sonoff@3.2.1
          ├── iobroker.sonos@3.0.0
          ├── iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#38686d69a56249fda3acbcfae9485a372b9a3b56)
          ├── iobroker.spotify-premium@1.5.2
          ├── iobroker.sql@3.0.1
          ├── iobroker.tankerkoenig@3.4.0
          ├── iobroker.terminal@1.0.0
          ├── iobroker.tr-064@4.3.0
          ├── iobroker.tradfri@3.1.3
          ├── iobroker.tuya@3.16.0
          ├── iobroker.vis-2@2.13.4
          ├── iobroker.vis-bars@0.1.4
          ├── iobroker.vis-canvas-gauges@1.0.1
          ├── iobroker.vis-fancyswitch@1.1.0
          ├── iobroker.vis-history@1.0.0
          ├── iobroker.vis-hqwidgets@1.5.1
          ├── iobroker.vis-icontwo@1.18.0
          ├── iobroker.vis-inventwo@3.3.5
          ├── iobroker.vis-jqui-mfd@1.1.1
          ├── iobroker.vis-justgage@2.1.7
          ├── iobroker.vis-keyboard@0.0.2
          ├── iobroker.vis-map@1.1.2
          ├── iobroker.vis-material-advanced@1.7.4
          ├── iobroker.vis-materialdesign@0.5.9
          ├── iobroker.vis-metro@1.2.0
          ├── iobroker.vis-rgraph@0.0.2
          ├── iobroker.vis-timeandweather@1.2.2
          ├── iobroker.vis@1.5.6
          ├── iobroker.weatherunderground@3.7.0
          ├── iobroker.web@7.0.8
          ├── iobroker.whatsapp-cmb@0.3.0
          ├── iobroker.wifilight@2.0.3
          └── iobroker.zigbee@3.0.5
          • L luft-post
            luft-post
            @luft-post
            Fehler steht leider immer noch an
            • L luft-post
              @luft-post
              luft-post
              hier noch mal der aktuelle iob diag
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
                     Icon name: computer
                        Kernel: Linux 6.12.47+rpt-rpi-2712
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
               21:10:53 up 10 min,  2 users,  load average: 1.06, 1.08, 0.64
              CPU threads: 4
              Current issues:
                             Local time: Tue 2025-09-30 21:10:53 CEST
                         Universal time: Tue 2025-09-30 19:10:53 UTC
                               RTC time: Tue 2025-09-30 19:10:53
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Display-Server:         false
              Desktop:
              Session:                tty
              *** MEMORY ***
              Mem:             17G        3.4G         12G         14M        1.4G         13G
              Swap:           536M          0B        536M
              Total:           17G        3.4G         12G
                       3286 M used memory
                       2981 M active memory
                        869 M inactive memory
                      11710 M free memory
                        196 M buffer memory
                       1159 M swap cache
                        511 M total swap
                          0 M used swap
                        511 M free swap
              top - 21:10:53 up 10 min,  2 users,  load average: 1.06, 1.08, 0.64
              Tasks: 230 total,   1 running, 229 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :  16219.1 total,  11710.8 free,   3286.4 used,   1356.2 buff/cache
              MiB Swap:    512.0 total,    512.0 free,      0.0 used.  12932.7 avail Mem
              *** FILESYSTEM ***
              tmpfs          tmpfs     1.6G   14M  1.6G   1% /run
              tmpfs          tmpfs     8.0G   32K  8.0G   1% /dev/shm
              tmpfs          tmpfs     1.6G  160K  1.6G   1% /run/user/1000
              [Tue Sep 30 21:00:25 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=88:A2:9E:1C:3B:23 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=541a5899-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
              [Tue Sep 30 21:00:26 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6ecfcd5-2703-41bf-9301-10c403b6fb0c ro with ordered data mode. Quota mode: none.
              [Tue Sep 30 21:00:27 2025] EXT4-fs (nvme0n1p2): re-mounted d6ecfcd5-2703-41bf-9301-10c403b6fb0c r/w.
              [Tue Sep 30 21:00:28 2025] EXT4-fs (sda): mounted filesystem 99c4331b-c542-48d4-9081-700cecce1b69 r/w with ordered data mode. Quota mode: none.
              |-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              2.6G    /var/
              1.4G    /var/lib
              1.2G    /var/lib/mysql
              698M    /var/cache
              639M    /opt/iobroker/iobroker-data/
              34M     /opt/iobroker/iobroker-data/objects.jsonl
              13M     /opt/iobroker/iobroker-data/states.jsonl
              USB-Devices by-id:
              Your zigbee.0 COM-Port is matching 'by-id'. Very good!
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/nodejs         v22.20.0
              /usr/bin/node           v22.20.0
              /usr/bin/npm            10.9.3
              /usr/bin/npx            10.9.3
              nodejs:
                Installed: 22.20.0-1nodesource1
                Version table:
               *** 22.20.0-1nodesource1 1001
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 242)
              admin:          7.7.2
              javascript:     8.9.2
              +-- iobroker.fully-tablet-control@0.3.0-beta.5 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#a9a607c702141a6568b271464570809d9a27ecf9)
              +-- iobroker.homepilot20@0.0.31 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#201286583714176646bfa1030a780906787264e3)
              +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#38686d69a56249fda3acbcfae9485a372b9a3b56)
              Adapter State
              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231009140255-if00
              + instance is alive
              Objects and States
              Objects:        38379
              States:         29244
              Pending Updates: 0
              tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      112        6119       831/mariadbd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6496       772/sshd: /usr/sbin
              tcp        0      0 192.168.2.70:1883       0.0.0.0:*               LISTEN      1001       22046      3523/io.sonoff.0
              tcp        0      0 192.168.2.70:42001      0.0.0.0:*               LISTEN      1001       20727      3371/io.hm-rpc.1
              tcp        0      0 192.168.2.70:42010      0.0.0.0:*               LISTEN      1001       20699      3356/io.hm-rpc.0
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6010       742/cupsd
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16255      3066/iobroker.js-co
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17358      3066/iobroker.js-co
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6009       742/cupsd
              tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22859      3726/io.terminal.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23579      3834/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18649      3091/io.admin.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          6498       772/sshd: /usr/sbin
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7953       591/avahi-daemon: r
              udp        0      0 0.0.0.0:54916           0.0.0.0:*                           104        7955       591/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        7954       591/avahi-daemon: r
              udp6       0      0 :::47089                :::*                                104        7956       591/avahi-daemon: r
              udp6       0      0 fe80::ba24:34b9:1b1:546 :::*                                0          6708       660/NetworkManager
              2025-09-30 21:09:05.362  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
              2025-09-30 21:09:05.984  - info: host.raspberrypi instance system.adapter.web.0 in version "7.0.8" started with pid 3834
              2025-09-30 21:09:06.444  - info: admin.0 (3091) ==> Connected system.user.admin from ::ffff:192.168.2.211
              2025-09-30 21:09:09.341  - info: web.0 (3834) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.20.0, js-controller: 7.0.7
              2025-09-30 21:09:09.645  - info: web.0 (3834) socket.io server listening on port 8082
              2025-09-30 21:09:09.649  - info: web.0 (3834) http server listening on port 8082
              2025-09-30 21:09:11.072  - info: daswetter.0 (3597) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2025-09-30 21:09:11.583  - info: daswetter.0 (3597) cleaned everything up...
              2025-09-30 21:09:11.715  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2025-09-30 21:09:11.872  - info: daswetter.1 (3614) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2025-09-30 21:09:12.377  - info: daswetter.1 (3614) cleaned everything up...
              2025-09-30 21:09:12.504  - info: host.raspberrypi instance system.adapter.daswetter.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2025-09-30 21:09:12.508  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack = true)
              2025-09-30 21:09:12.548  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.7 (ack = true)
              2025-09-30 21:09:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 20 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 12 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 18 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 7 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259354853,"q":0,"from":"system.adapter.javascript.0","lc":1759259354853,"c":"script.js.common.11_FensterUeberwachungOG"})
              2025-09-30 21:09:16.312  - debug: smartcontrol.0 (3707) [_asyncOnMessage] command 'Verify Adapter Configuration' received from admin/index_m.html. Verifying the configuration and sending the result back to index_m.html...
              2025-09-30 21:09:16.356  - debug: smartcontrol.0 (3707) [_asyncOnMessage] Configuration verification failed, 4 issue(s) found.
              2025-09-30 21:09:24.520  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
              2025-09-30 21:09:24.561  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.8 (ack = true)
              2025-09-30 21:10:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 21 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 13 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 19 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 8 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259414853,"q":0,"from":"system.adapter.javascript.0","lc":1759259414853,"c":"script.js.common.11_FensterUeberwachungOG"})
              2025-09-30 21:10:37.869  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.7 (ack = true)
              2025-09-30 21:10:50.009  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
              2025-09-30 21:11:02.518  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.7 (ack = true)
              2025-09-30 21:11:14.687  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
              2025-09-30 21:11:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 22 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 14 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 20 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 9 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259474853,"q":0,"from":"system.adapter.javascript.0","lc":1759259474853,"c":"script.js.common.11_FensterUeberwachungOG"})
              pi@raspberrypi:/opt/iobroker $
              • L luft-post
                ```bash
                Script v.2025-08-09
                *** BASE SYSTEM ***
                 Static hostname: raspberrypi
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Model           : Raspberry Pi 5 Model B Rev 1.1
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : 64 bit
                Systemuptime and Load:
                CPU threads: 4
                *** LIFE CYCLE STATUS ***
                Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** TIME AND TIMEZONES ***
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi systemd-journal iobroker
                iobroker
                HOME=/home/iobroker
                *** DISPLAY-SERVER SETUP ***
                Display-Manager:        * lightdm.service - Light Display Manager
                Desktop:
                Session:                tty
                *** MEMORY ***
                Swap:           536M          0B        536M
                Total:           17G        3.4G         12G
                Active iob-Instances:   31
                        16219 M total memory
                         3286 M used memory
                        11710 M free memory
                          196 M buffer memory
                         1159 M swap cache
                          511 M total swap
                            0 M used swap
                          511 M free swap
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** DMESG CRITICAL ERRORS ***
                No critical errors detected
                *** FILESYSTEM ***
                udev           devtmpfs  7.9G     0  7.9G   0% /dev
                /dev/nvme0n1p2 ext4      117G   12G  100G  11% /
                tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                /dev/nvme0n1p1 vfat      510M   69M  442M  14% /boot/firmware
                /dev/sda       ext4      234G   28K  222G   1% /backup
                /var:
                2.6G    /var/
                1.4G    /var/lib
                1.2G    /var/lib/mysql
                698M    /var/cache
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.9.3
                /usr/bin/npx            10.9.3
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.7.2
                javascript:     8.9.2
                Adapter State
                + instance is alive
                Objects and States
                Objects:        38379
                States:         29244
                Pending Updates: 0
                @luft-post
                Funktioniert jetzt der Aufruf von
                iob diag
                wieder auf direktem Weg?
                L 1 Antwort Letzte Antwort
                  @luft-post
                  iob diag
                  luft-post
                  @thomas-braun ja
                  • L luft-post
                    @thomas-braun ja
                    @luft-post
                    Gut, dann sind deine verfummelten Rechte jetzt wieder gerade.
                    NICHT als iobroker einloggen, NICHT als root einloggen.
                    Du zerballerst dir damit sonst die Rechte.
                    Und nachdem deine Kiste jetzt wieder senkrecht ist schaut dein Problem mit dem Adapter genau wie aus?
                    HomoranH L 2 Antworten Letzte Antwort
                      ich hab den Teil mal abgetrennt und aus Tester hierher geschoben
                        @luft-post
                        @thomas-braun sagte in System krumm?:
                        dann bitte wieder im Original Thread weitermachen!
                          luft-post
                          @homoran ok vielen Dank
